commit ce5d0b47f13f83dfb9fbb8ac91adad7120747aaf in mainline
Subject: [PATCH] [PKTGEN]: srcmac fix
commit ef8aef55ce61fd0e2af798695f7386ac756ae1e7 in mainline
Subject: [PATCH] [NET]: Do not dereference iov if length is zero
When msg_iovlen is zero we shouldn't try to dereference
msg_iov. Right now the only thing that tries to do so
is skb_copy_and_csum_datagram_iovec. Since the total
length should also be zero if msg_iovlen is zero, it's
sufficient to check the total length there and simply
return if it's zero.
commit 49ff4bb4cd4c04acf8f9e3d3ec2148305a1db445 in mainline.
[TCP]: DSACK signals data receival, be conservative
In case a DSACK is received, it's better to lower cwnd as it's
a sign of data receival.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
commit 6ee8009e38006da81d2a53da1aaa27365552553e in mainline
Subject: [PATCH 1/1] [TCP]: Also handle snd_una changes in tcp_cwnd_down
tcp_cwnd_down must check for it too as it should be conservative
in case of collapse stuff and also when receiver is trying to
lie (though it wouldn't be successful anyway).
Note:
- Separated also is_dupack and do_lost in fast_retransalert
* Much cleaner look-and-feel now
* This time it really fixes cumulative ACK + many new
SACK blocks recovery entry (I claimed this fixes with
last patch but it wasn't). TCP will now call
tcp_update_scoreboard regardless of is_dupack when
in recovery as long as there is enough fackets_out.
- Introduce FLAG_SND_UNA_ADVANCED
* Some prior_snd_una arguments are unnecessary after it
- Added helper FLAG_ANY_PROGRESS to avoid long FLAG...|FLAG...
constructs
This is a reduced version of a mainline patch.
commit 8c7b43a2e58baa24002fa2b266d9a5007bc52a40 in mainline
I tried to preserve bridging code as it was before, but logic is quite
strange - I think we should free skb on error, since it is already
unshared and thus will just leak.
Herbert Xu states:
> + if ((skb = skb_share_check(skb, GFP_ATOMIC)) == NULL)
> + goto out;
If this happens it'll be a double-free on skb since we'll
return NF_DROP which makes the caller free it too.
We could return NF_STOLEN to prevent that but I'm not sure
whether that's correct netfilter semantics. Patrick, could
you please make a call on this?
Patrick McHardy states:
NF_STOLEN should work fine here.
Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru>
commit 6ae5f983cf8de769214d2d9e8a783c881eccd4cd in mainline
The commit 95c385 broke proper source address selection for cases in which
there is a address which is makred 'deprecated'. The commit mistakenly
changed ifa->flags to ifa_result->flags (probably copy/paste error from a
few lines above) in the 'Rule 3' address selection code.
The patch restores the previous RFC-compliant behavior.
commit 9e3be4b34364a670bd6e57d2e8c3caabdd8d89f8 in mainline
addrconf_dad_failure calls addrconf_dad_stop which takes referenced address
and drops the count. So, in6_ifa_put perrformed at out: is extra. This
results in message: "Freeing alive inet6 address" and not released dst entries.
Signed-off-by: Denis V. Lunev <den@openvz.org>
Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org>
commit 3ef9d943d26dea764f4fecf3767001c90b778b0c in mainline
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
commit 8ee4f391831cb96916a8e8a05f04b1c1d7dd30d8 in mainline.
In testing our ESP/AH offload hardware, I discovered an issue with how
AH handles mutable fields in IPv4. RFC 4302 (AH) states the following
on the subject:
For IPv4, the entire option is viewed as a unit; so even
though the type and length fields within most options are immutable
in transit, if an option is classified as mutable, the entire option
is zeroed for ICV computation purposes.
The current implementation does not zero the type and length fields,
resulting in authentication failures when communicating with hosts
that do (i.e. FreeBSD).
I have tested record route and timestamp options (ping -R and ping -T)
on a small network involving Windows XP, FreeBSD 6.2, and Linux hosts,
with one router. In the presence of these options, the FreeBSD and
Linux hosts (with the patch or with the hardware) can communicate.
The Windows XP host simply fails to accept these packets with or
without the patch.
I have also been trying to test source routing options (using
traceroute -g), but haven't had much luck getting this option to work
*without* AH, let alone with.
Signed-off-by: Nick Bowler <nbowler@ellipticsemi.com>
commit e1f52208bb968291f7d9142eff60b62984b4a511 in mainline.
[IPv6]: Fix NULL pointer dereference in ip6_flush_pending_frames
Some of skbs in sk->write_queue do not have skb->dst because
we do not fill skb->dst when we allocate new skb in append_data().
BTW, I think we may not need to (or we should not) increment some stats
when using corking; if 100 sendmsg() (with MSG_MORE) result in 2 packets,
how many should we increment?
If 100, we should set skb->dst for every queued skbs.
If 1 (or 2 (*)), we increment the stats for the first queued skb and
we should just skip incrementing OutDiscards for the rest of queued skbs,
adn we should also impelement this semantics in other places;
e.g., we should increment other stats just once, not 100 times.
*: depends on the place we are discarding the datagram.
I guess should just increment by 1 (or 2).
commit 0a9c73014415d2a84dac346c1e12169142a6ad37 in mainline
[INET_DIAG]: Fix oops in netlink_rcv_skb
netlink_run_queue() doesn't handle multiple processes processing the
queue concurrently. Serialize queue processing in inet_diag to fix
a oops in netlink_rcv_skb caused by netlink_run_queue passing a
NULL for the skb.
BUG: unable to handle kernel NULL pointer dereference at virtual address 00000054
[349587.500454] printing eip:
[349587.500457] c03318ae
[349587.500459] *pde = 00000000
[349587.500464] Oops: 0000 [#1]
[349587.500466] PREEMPT SMP
[349587.500474] Modules linked in: w83627hf hwmon_vid i2c_isa
[349587.500483] CPU: 0
[349587.500485] EIP: 0060:[<c03318ae>] Not tainted VLI
[349587.500487] EFLAGS: 00010246 (2.6.22.3 #1)
[349587.500499] EIP is at netlink_rcv_skb+0xa/0x7e
[349587.500506] eax: 00000000 ebx: 00000000 ecx: c148d2a0 edx: c0398819
[349587.500510] esi: 00000000 edi: c0398819 ebp: c7a21c8c esp: c7a21c80
[349587.500517] ds: 007b es: 007b fs: 00d8 gs: 0033 ss: 0068
[349587.500521] Process oidentd (pid: 17943, ti=c7a20000 task=cee231c0 task.ti=c7a20000)
[349587.500527] Stack: 00000000 c7a21cac f7c8ba78 c7a21ca4 c0331962 c0398819 f7c8ba00 0000004c
[349587.500542] f736f000 c7a21cb4 c03988e3 00000001 f7c8ba00 c7a21cc4 c03312a5 0000004c
[349587.500558] f7c8ba00 c7a21cd4 c0330681 f7c8ba00 e4695280 c7a21d00 c03307c6 7fffffff
[349587.500578] Call Trace:
[349587.500581] [<c010361a>] show_trace_log_lvl+0x1c/0x33
[349587.500591] [<c01036d4>] show_stack_log_lvl+0x8d/0xaa
[349587.500595] [<c010390e>] show_registers+0x1cb/0x321
[349587.500604] [<c0103bff>] die+0x112/0x1e1
[349587.500607] [<c01132d2>] do_page_fault+0x229/0x565
[349587.500618] [<c03c8d3a>] error_code+0x72/0x78
[349587.500625] [<c0331962>] netlink_run_queue+0x40/0x76
[349587.500632] [<c03988e3>] inet_diag_rcv+0x1f/0x2c
[349587.500639] [<c03312a5>] netlink_data_ready+0x57/0x59
[349587.500643] [<c0330681>] netlink_sendskb+0x24/0x45
[349587.500651] [<c03307c6>] netlink_unicast+0x100/0x116
[349587.500656] [<c0330f83>] netlink_sendmsg+0x1c2/0x280
[349587.500664] [<c02fcce9>] sock_sendmsg+0xba/0xd5
[349587.500671] [<c02fe4d1>] sys_sendmsg+0x17b/0x1e8
[349587.500676] [<c02fe92d>] sys_socketcall+0x230/0x24d
[349587.500684] [<c01028d2>] syscall_call+0x7/0xb
[349587.500691] =======================
[349587.500693] Code: f0 ff 4e 18 0f 94 c0 84 c0 0f 84 66 ff ff ff 89 f0 e8 86 e2 fc ff e9 5a ff ff ff f0 ff 40 10 eb be 55 89 e5 57 89 d7 56 89 c6 53 <8b> 50 54 83 fa 10 72 55 8b 9e 9c 00 00 00 31 c9 8b 03 83 f8 0f
Reported by Athanasius <link@miggy.org>
commit 596e41509550447b030f7b16adaeb0138ab585a8 in mainline
Bug: http://bugzilla.kernel.org/show_bug.cgi?id=8876
Not all ips are shown by "ip addr show" command when IPs number assigned to an
interface is more than 60-80 (in fact it depends on broadcast/label etc
presence on each address).
Steps to reproduce:
It's terribly simple to reproduce:
# for i in $(seq 1 100); do ip ad add 10.0.$i.1/24 dev eth10 ; done
# ip addr show
this will _not_ show all IPs.
Looks like the problem is in netlink/ipv4 message processing.
This is fix from bug submitter, it looks correct.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
commit a2221f308dabb95abb914ad858d36c2462705558 in mainline.
Not all are listed, same as the IPV4 devinet bug.
commit 7a1fa065a0264f6b3d3003ba5635289f6583c478 in mainline.
Commit aaf68cfbf2241d24d46583423f6bff5c47e088b3 added a bias
to sk_inuse, so this test for an unused socket now fails. So no
sockets get closed because they are old (they might get closed
if the client closed them).
This bug has existed since 2.6.21-rc1.
Thanks to Wolfgang Walter for finding and reporting the bug.
Cc: Wolfgang Walter <wolfgang.walter@studentenwerk.mhn.de>
Signed-off-by: Neil Brown <neilb@suse.de>
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
commit 9db619e66503494e41159de3c76fafabe80d016b in mainline.
we upgraded the kernel of a nfs-server from 2.6.17.11 to 2.6.22.6. Since
then we get the message
lockd: too many open TCP sockets, consider increasing the number of nfsd threads
lockd: last TCP connect from ^\\236^\É^D
These random characters in the second line are caused by a bug in
svc_tcp_accept.
(Note: there are two previous __svc_print_addr(sin, buf, sizeof(buf))
calls in this function, either of which would initialize buf correctly;
but both are inside "if"'s and are not necessarily executed. This is
less obvious in the second case, which is inside a dprintk(), which is a
macro which expands to an if statement.)
Signed-off-by: Wolfgang Walter <wolfgang.walter@studentenwerk.mhn.de>
It's possible that new SACK blocks that should trigger new LOST
markings arrive with new data (which previously made is_dupack
false). In addition, I think this fixes a case where we get
a cumulative ACK with enough SACK blocks to trigger the fast
recovery (is_dupack would be false there too).
I'm not completely pleased with this solution because readability
of the code is somewhat questionable as 'is_dupack' in SACK case
is no longer about dupacks only but would mean something like
'lost_marker_work_todo' too... But because of Eifel stuff done
in CA_Recovery, the FLAG_DATA_SACKED check cannot be placed to
the if statement which seems attractive solution. Nevertheless,
I didn't like adding another variable just for that either... :-)
Actually, the ratehalving seems to work too well, as cwnd is
reduced on every second ACK even though the packets in flight
remains unchanged. Recoveries in a bidirectional flows suffer
quite badly because of this, both NewReno and SACK are affected.
After this patch, rate halving is performed for ACK only if
packets in flight was supposedly changed too.
[TCP]: Invoke tcp_sendmsg() directly, do not use inet_sendmsg().
As discovered by Evegniy Polyakov, if we try to sendmsg after
a connection reset, we can do incredibly stupid things.
The core issue is that inet_sendmsg() tries to autobind the
socket, but we should never do that for TCP. Instead we should
just go straight into TCP's sendmsg() code which will do all
of the necessary state and pending socket error checks.
TCP's sendpage already directly vectors to tcp_sendpage(), so this
merely brings sendmsg() in line with that.
[NET]: Fix unbalanced rcu_read_unlock in __sock_create
The recent RCU work created an unbalanced rcu_read_unlock
in __sock_create. This patch fixes that. Reported by
oleg 123.
The snap_rcv code reads 5 bytes so we should make sure that
we have 5 bytes in the head before proceeding.
Based on diagnosis and fix by Evgeniy Polyakov, reported by
Alan J. Wylie.
Patch also kills the skb->sk assignment before kfree_skb
since it's redundant.
Author: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
A similar fix to netfilter from Eric Dumazet inspired me to
look around a bit by using some grep/sed stuff as looking for
this kind of bugs seemed easy to automate. This is one of them
I found where it looks like this semicolon is not valid.
If ICMP6 message with "Packet Too Big" is received after send SCTP DATA,
kernel panic will occur when SCTP DATA is send again.
This is because of a bad dest address when call to skb_copy_bits().
The messages sequence is like this:
Endpoint A Endpoint B
<------- SCTP DATA (size=1432)
ICMP6 message ------->
(Packet Too Big pmtu=1280)
<------- Resend SCTP DATA (size=1432)
------------kernel panic---------------
printing eip:
c05be62a
*pde = 00000000
Oops: 0002 [#1]
SMP
Modules linked in: scomm l2cap bluetooth ipv6 dm_mirror dm_mod video output sbs battery lp floppy sg i2c_piix4 i2c_core pcnet32 mii button ac parport_pc parport ide_cd cdrom serio_raw mptspi mptscsih mptbase scsi_transport_spi sd_mod scsi_mod ext3 jbd ehci_hcd ohci_hcd uhci_hcd
CPU: 0
EIP: 0060:[<c05be62a>] Not tainted VLI
EFLAGS: 00010282 (2.6.23-rc2 #1)
EIP is at skb_copy_bits+0x4f/0x1ef
eax: 000004d0 ebx: ce12a980 ecx: 00000134 edx: cfd5a880
esi: c8246858 edi: 00000000 ebp: c0759b14 esp: c0759adc
ds: 007b es: 007b fs: 00d8 gs: 0000 ss: 0068
Process swapper (pid: 0, ti=c0759000 task=c06d0340 task.ti=c0713000)
Stack: c0759b88 c0405867 ce12a980 c8bff838 c789c084 00000000 00000028 cfd5a880
d09f1890 000005dc 0000007b ce12a980 cfd5a880 c8bff838 c0759b88 d09bc521
000004d0 fffff96c 00000200 00000100 c0759b50 cfd5a880 00000246 c0759bd4
Call Trace:
[<c0405e1d>] show_trace_log_lvl+0x1a/0x2f
[<c0405ecd>] show_stack_log_lvl+0x9b/0xa3
[<c040608d>] show_registers+0x1b8/0x289
[<c0406271>] die+0x113/0x246
[<c0625dbc>] do_page_fault+0x4ad/0x57e
[<c0624642>] error_code+0x72/0x78
[<d09bc521>] ip6_output+0x8e5/0xab2 [ipv6]
[<d09bcec1>] ip6_xmit+0x2ea/0x3a3 [ipv6]
[<d0a3f2ca>] sctp_v6_xmit+0x248/0x253 [sctp]
[<d0a3c934>] sctp_packet_transmit+0x53f/0x5ae [sctp]
[<d0a34bf8>] sctp_outq_flush+0x555/0x587 [sctp]
[<d0a34d3c>] sctp_retransmit+0xf8/0x10f [sctp]
[<d0a3d183>] sctp_icmp_frag_needed+0x57/0x5b [sctp]
[<d0a3ece2>] sctp_v6_err+0xcd/0x148 [sctp]
[<d09cf1ce>] icmpv6_notify+0xe6/0x167 [ipv6]
[<d09d009a>] icmpv6_rcv+0x7d7/0x849 [ipv6]
[<d09be240>] ip6_input+0x1dc/0x310 [ipv6]
[<d09be965>] ipv6_rcv+0x294/0x2df [ipv6]
[<c05c3789>] netif_receive_skb+0x2d2/0x335
[<c05c5733>] process_backlog+0x7f/0xd0
[<c05c58f6>] net_rx_action+0x96/0x17e
[<c042e722>] __do_softirq+0x64/0xcd
[<c0406f37>] do_softirq+0x5c/0xac
Code: 00 00 29 ca 89 d0 2b 45 e0 89 55 ec 85 c0 7e 35 39 45 08 8b 55 e4 0f 4e 45 08 8b 75 e0 8b 7d dc 89 c1 c1 e9 02 03 b2 a0 00 00 00 <f3> a5 89 c1 83 e1 03 74 02 f3 a4 29 45 08 0f 84 7b 01 00 00 01
EIP: [<c05be62a>] skb_copy_bits+0x4f/0x1ef SS:ESP 0068:c0759adc
Kernel panic - not syncing: Fatal exception in interrupt
Arnaldo says:
Thanks! I'm to blame for this one, problem was introduced in:
b0e380b1d8a8e0aca215df97702f99815f05c094
* Copy a block of the IP datagram.
- if (skb_copy_bits(skb, ptr, frag->h.raw, len))
+ if (skb_copy_bits(skb, ptr, skb_transport_header(skb),
len))
BUG();
left -= len;
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
This fixes the following bug reported in syslog:
[ 4039.051658] BUG: sleeping function called from invalid context at /usr/src/davem-2.6/mm/slab.c:3032
[ 4039.051668] in_atomic():1, irqs_disabled():0
[ 4039.051670] INFO: lockdep is turned off.
[ 4039.051674] [<c0104c0f>] show_trace_log_lvl+0x1a/0x30
[ 4039.051687] [<c0104d4d>] show_trace+0x12/0x14
[ 4039.051691] [<c0104d65>] dump_stack+0x16/0x18
[ 4039.051695] [<c011371e>] __might_sleep+0xaf/0xbe
[ 4039.051700] [<c0157b66>] __kmalloc+0xb1/0xd0
[ 4039.051706] [<f090416f>] ccid2_hc_tx_alloc_seq+0x35/0xc3 [dccp_ccid2]
[ 4039.051717] [<f09048d6>] ccid2_hc_tx_packet_sent+0x27f/0x2d9 [dccp_ccid2]
[ 4039.051723] [<f085486b>] dccp_write_xmit+0x1eb/0x338 [dccp]
[ 4039.051741] [<f085603d>] dccp_sendmsg+0x113/0x18f [dccp]
[ 4039.051750] [<c03907fc>] inet_sendmsg+0x2e/0x4c
[ 4039.051758] [<c033a47d>] sock_aio_write+0xd5/0x107
[ 4039.051766] [<c015abc1>] do_sync_write+0xcd/0x11c
[ 4039.051772] [<c015b296>] vfs_write+0x118/0x11f
[ 4039.051840] [<c015b932>] sys_write+0x3d/0x64
[ 4039.051845] [<c0103e7c>] syscall_call+0x7/0xb
[ 4039.051848] =======================
The problem was that GFP_KERNEL was used; fixed by using gfp_any().
Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
[NET]: Share correct feature code between bridging and bonding
http://bugzilla.kernel.org/show_bug.cgi?id=8797 shows that the
bonding driver may produce bogus combinations of the checksum
flags and SG/TSO.
For example, if you bond devices with NETIF_F_HW_CSUM and
NETIF_F_IP_CSUM you'll end up with a bonding device that
has neither flag set. If both have TSO then this produces
an illegal combination.
The bridge device on the other hand has the correct code to
deal with this.
In fact, the same code can be used for both. So this patch
moves that logic into net/core/dev.c and uses it for both
bonding and bridging.
In the process I've made small adjustments such as only
setting GSO_ROBUST if at least one constituent device
supports it.
The essid wireless extension does deadlock against the assoc mutex,
as we don't unlock the assoc mutex when flushing the workqueue, which
also holds the lock.
Signed-off-by: Michael Buesch <mb@bu3sch.de>
[NETFILTER]: Fix logging regression
Loading one of the LOG target fails if a different target has already
registered itself as backend for the same family. This can affect the
ipt_LOG and ipt_ULOG modules when both are loaded.
Reported and tested by: <t.artem@mailcity.com>
Upstream-commit: 7e2acc7e
Reading /proc/net/anycast6 when there is no anycast address
on an interface results in an ever-increasing inet6_dev reference
count, as well as a reference to the netdevice you can't get rid of.
Cc: Marcus Meissner <meissner@suse.de>
[NETFILTER]: nf_conntrack: don't track locally generated special ICMP error
The conntrack assigned to locally generated ICMP error is usually the one
assigned to the original packet which has caused the error. But if
the original packet is handled as invalid by nf_conntrack, no conntrack
is assigned to the original packet. Then nf_ct_attach() cannot assign
any conntrack to the ICMP error packet. In that case the current
nf_conntrack_icmp assigns appropriate conntrack to it. But the current
code mistakes the direction of the packet. As a result, NAT code mistakes
the address to be mangled.
To fix the bug, this changes nf_conntrack_icmp not to assign conntrack
to such ICMP error. Actually no address is necessary to be mangled
in this case.
Spotted by Jordan Russell.
Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp>
Upstream commit ID: 130e7a83d7ec8c5c673225e0fa8ea37b1ed507a5
This patch changes the RFCOMM TTY release process so that the TTY is kept
on the list until it is really freed. A new device flag is used to keep
track of released TTYs.
Signed-off-by: Ville Tervo <ville.tervo@nokia.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
The core problem is that RFCOMM socket layer ioctl can release
rfcomm_dev struct while RFCOMM TTY layer is still actively using
it. Calling tty_vhangup() is needed for a synchronous hangup before
rfcomm_dev is freed.
Addresses the oops at http://bugzilla.kernel.org/show_bug.cgi?id=7509
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
The handling of the re-registration case is wrong here; the "test" that was
returned from auth_domain_lookup will not be used again, so that reference
should be put. And auth_domain_lookup never did anything with "new" in
this case, so we should just clean it up ourself.
Thanks to Akinobu Mita for bug report, analysis, and testing.
Cc: Akinobu Mita <akinobu.mita@gmail.com>
Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu>
Cc: Neil Brown <neilb@suse.de>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Victor Porton reported that the SoftMAC layer had random problem when setting the ESSID :
http://bugzilla.kernel.org/show_bug.cgi?id=8686 After investigation, it turned out to be
worse, the SoftMAC layer is left in an inconsistent state. The fix is pretty trivial.
Signed-off-by: Jean Tourrilhes <jt@hpl.hp.com>
Acked-by: Michael Buesch <mb@bu3sch.de>
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
Acked-by: John W. Linville <linville@tuxdriver.com>
[TCPv6] MD5SIG: Ensure to reset allocation count to avoid panic.
After clearing all passwords for IPv6 peers, we need to
set allocation count to zero as well as we free the storage.
Otherwise, we panic when a user trys to (re)add a password.
Discovered and fixed by MIYAJIMA Mitsuharu <miyajima.mitsuharu@anchor.jp>.
[IPV6]: endianness bug in ip6_tunnel
[NETPOLL]: Fix a leak-n-bug in netpoll_cleanup()
93ec2c723e3f8a216dde2899aeb85c648672bc6b applied excessive duct tape to
the netpoll beast's netpoll_cleanup(), thus substituting one leak with
another, and opening up a little buglet :-)
net_device->npinfo (netpoll_info) is a shared and refcounted object and
cannot simply be set NULL the first time netpoll_cleanup() is called.
Otherwise, further netpoll_cleanup()'s see np->dev->npinfo == NULL and
become no-ops, thus leaking. And it's a bug too: the first call to
netpoll_cleanup() would thus (annoyingly) "disable" other (still alive)
netpolls too. Maybe nobody noticed this because netconsole (only user
of netpoll) never supported multiple netpoll objects earlier.
This is a trivial and obvious one-line fixlet.
Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in>
[IPV6]: Call inet6addr_chain notifiers on link down
Currently if the link is brought down via ip link or ifconfig down,
the inet6addr_chain notifiers are not called even though all
the addresses are removed from the interface. This caused SCTP
to add duplicate addresses to it's list.
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
[IPV6]: MSG_ERRQUEUE messages do not pass to connected raw sockets
Taken from http://bugzilla.kernel.org/show_bug.cgi?id=8747
Problem Description:
It is related to the possibility to obtain MSG_ERRQUEUE messages from the udp
and raw sockets, both connected and unconnected.
There is a little typo in net/ipv6/icmp.c code, which prevents such messages
to be delivered to the errqueue of the correspond raw socket, when the socket
is CONNECTED. The typo is due to swap of local/remote addresses.
Consider __raw_v6_lookup() function from net/ipv6/raw.c. When a raw socket is
looked up usual way, it is something like:
sk = __raw_v6_lookup(sk, nexthdr, daddr, saddr, IP6CB(skb)->iif);
where "daddr" is a destination address of the incoming packet (IOW our local
address), "saddr" is a source address of the incoming packet (the remote end).
But when the raw socket is looked up for some icmp error report, in
net/ipv6/icmp.c:icmpv6_notify() , daddr/saddr are obtained from the echoed
fragment of the "bad" packet, i.e. "daddr" is the original destination
address of that packet, "saddr" is our local address. Hence, for
icmpv6_notify() must use "saddr, daddr" in its arguments, not "daddr, saddr"
Steps to reproduce:
Create some raw socket, connect it to an address, and cause some error
situation: f.e. set ttl=1 where the remote address is more than 1 hop to reach.
Set IPV6_RECVERR .
Then send something and wait for the error (f.e. poll() with POLLERR|POLLIN).
You should receive "time exceeded" icmp message (because of "ttl=1"), but the
socket do not receive it.
If you do not connect your raw socket, you will receive MSG_ERRQUEUE
successfully. (The reason is that for unconnected socket there are no actual
checks for local/remote addresses).
[NET]: gen_estimator deadlock fix
-Fixes ABBA deadlock noted by Patrick McHardy <kaber@trash.net>:
> There is at least one ABBA deadlock, est_timer() does:
> read_lock(&est_lock)
> spin_lock(e->stats_lock) (which is dev->queue_lock)
> and qdisc_destroy calls htb_destroy under dev->queue_lock, which
> calls htb_destroy_class, then gen_kill_estimator and this
> write_locks est_lock.
To fix the ABBA deadlock the rate estimators are now kept on an rcu list.
-The est_lock changes the use from protecting the list to protecting
the update to the 'bstat' pointer in order to avoid NULL dereferencing.
-The 'interval' member of the gen_estimator structure removed as it is
not needed.
Signed-off-by: Ranko Zivojnovic <ranko@spidernet.net>
[NET]: Fix gen_estimator timer removal race
As noticed by Jarek Poplawski <jarkao2@o2.pl>, the timer removal in
gen_kill_estimator races with the timer function rearming the timer.
Check whether the timer list is empty before rearming the timer
in the timer function to fix this.
Acked-by: Jarek Poplawski <jarkao2@o2.pl>
[RFKILL]: fix net/rfkill/rfkill-input.c bug on 64-bit systems
Subject: [patch] net/input: fix net/rfkill/rfkill-input.c bug on 64-bit systems
this recent commit:
commit cf4328cd949c2086091c62c5685f1580fe9b55e4
Author: Ivo van Doorn <IvDoorn@gmail.com>
Date: Mon May 7 00:34:20 2007 -0700
[NET]: rfkill: add support for input key to control wireless radio
added this 64-bit bug:
unsigned int flags;
spin_lock_irqsave(&task->lock, flags);
irq 'flags' must be unsigned long, not unsigned int. The -rt tree has
strict checks about this on 64-bit so this triggered a build failure.
SCTP: Add scope_id validation for link-local binds
SCTP currently permits users to bind to link-local addresses,
but doesn't verify that the scope id specified at bind matches
the interface that the address is configured on. It was report
that this can hang a system.
[XFRM]: Fix crash introduced by struct dst_entry reordering
XFRM expects xfrm_dst->u.next to be same pointer as dst->next, which
was broken by the dst_entry reordering in commit 1e19e02c~, causing
an oops in xfrm_bundle_ok when walking the bundle upwards.
Kill xfrm_dst->u.next and change the only user to use dst->next instead.
[NET_SCHED]: Revert "avoid transmit softirq on watchdog wakeup" optimization
As noticed by Ranko Zivojnovic <ranko@spidernet.net>, calling qdisc_run
from the timer handler can result in deadlock:
> CPU#0
> qdisc_watchdog() fires and gets dev->queue_lock
> qdisc_run()...qdisc_restart()...
> -> releases dev->queue_lock and enters dev_hard_start_xmit()
> CPU#1
> tc del qdisc dev ...
> qdisc_graft()...dev_graft_qdisc()...dev_deactivate()...
> -> grabs dev->queue_lock ...
> qdisc_reset()...{cbq,hfsc,htb,netem,tbf}_reset()...qdisc_watchdog_cancel()...
> -> hrtimer_cancel() - waiting for the qdisc_watchdog() to exit, while still
> holding dev->queue_lock
> CPU#0
> dev_hard_start_xmit() returns ...
> -> wants to get dev->queue_lock(!)
> DEADLOCK!
The entire optimization is a bit questionable IMO, it moves potentially
large parts of NET_TX_SOFTIRQ work to TIMER_SOFTIRQ/HRTIMER_SOFTIRQ,
which kind of defeats the separation of them.
Acked-by: Ranko Zivojnovic <ranko@spidernet.net>
[TCP]: Verify the presence of RETRANS bit when leaving FRTO
For yet unknown reason, something cleared SACKED_RETRANS bit
underneath FRTO.
dereference (CVE-2007-2876)
When creating a new connection by sending an unknown chunk type, we
don't transition to a valid state, causing a NULL pointer dereference in
sctp_packet when accessing sctp_timeouts[SCTP_CONNTRACK_NONE].
Fix by don't creating new conntrack entry if initial state is invalid.
Noticed by Vilmos Nebehaj <vilmos.nebehaj@ramsys.hu>
CC: Kiran Kumar Immidi <immidi_kiran@yahoo.com>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
When cleaning up HIDP sessions, we currently close the ACL connection
before deregistering the input device. Closing the ACL connection
schedules a workqueue to remove the associated objects from sysfs, but
the input device still refers to them -- and if the workqueue happens to
run before the input device removal, the kernel will oops when trying to
look up PHYSDEVPATH for the removed input device.
Fix this by deregistering the input device before closing the
connections.
Acked-by: Marcel Holtmann <marcel@holtmann.org>
>From my recent patch:
> > #1
> > Until kernel ver. 2.6.21 (including) cancel_rearming_delayed_work()
> > required a work function should always (unconditionally) rearm with
> > delay > 0 - otherwise it would endlessly loop. This patch replaces
> > this function with cancel_delayed_work(). Later kernel versions don't
> > require this, so here it's only for uniformity.
But Oleg Nesterov <oleg@tv-sign.ru> found:
> But 2.6.22 doesn't need this change, why it was merged?
> In fact, I suspect this change adds a race,
His description was right (thanks), so this patch reverts #1.
Signed-off-by: Jarek Poplawski <jarkao2@o2.pl>
Every file should include the headers containing the prototypes for
its global functions.
index values
Choices' index values may be out of range while still encoded in the fixed
length bit-field. This bug may cause access to undefined types (NULL
pointers) and thus crashes (Reported by Zhongling Wen).
This patch also adds checking of decode flag when decoding SEQUENCEs.
Signed-off-by: Jing Min Zhao <zhaojingmin@vivecode.com>
skb_clone_fraglist is static so it shouldn't be exported.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
