commit b560a208cda0297fef6ff85bbfd58a8f0a52a543 upstream.
This checks if BT_HS is enabled relecting it on MGMT_SETTING_HS instead
of always reporting it as supported.
Signed-off-by: Luiz Augusto von Dentz <luiz.von.dentz@intel.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit f19425641cb2572a33cb074d5e30283720bd4d22 upstream.
Only sockets will have the chan->data set to an actual sk, channels
like A2MP would have its own data which would likely cause a crash when
calling sk_filter, in order to fix this a new callback has been
introduced so channels can implement their own filtering if necessary.
commit eddb7732119d53400f48a02536a84c509692faa8 upstream.
This fixes various places where a stack variable is used uninitialized.
This is the 5.4.71 stable release
Signed-off-by: Andrey Zhizhikin <andrey.zhizhikin@leica-geosystems.com>
commit 0fedc63fadf0404a729e73a35349481c8009c02f upstream.
syzbot is able to trigger a failure case inside the loop in
tcf_action_init(), and when this happens we clean up with
tcf_action_destroy(). But, as these actions are already inserted
into the global IDR, other parallel process could free them
before tcf_action_destroy(), then we will trigger a use-after-free.
Fix this by deferring the insertions even later, after the loop,
and committing all the insertions in a separate loop, so we will
never fail in the middle of the insertions any more.
One side effect is that the window between alloction and final
insertion becomes larger, now it is more likely that the loop in
tcf_del_walker() sees the placeholder -EBUSY pointer. So we have
to check for error pointer in tcf_del_walker().
Reported-and-tested-by: syzbot+2287853d392e4b42374a@syzkaller.appspotmail.com
Fixes: 0190c1d452a9 ("net: sched: atomically check-allocate action")
Cc: Vlad Buslov <vladbu@mellanox.com>
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
Cc: Jiri Pirko <jiri@resnulli.us>
commit e49d8c22f1261c43a986a7fdbf677ac309682a07 upstream.
All TC actions call tcf_idr_insert() for new action at the end
of their ->init(), so we can actually move it to a central place
in tcf_action_init_1().
And once the action is inserted into the global IDR, other parallel
process could free it immediately as its refcnt is still 1, so we can
not fail after this, we need to move it after the goto action
validation to avoid handling the failure case after insertion.
This is found during code review, is not directly triggered by syzbot.
And this prepares for the next patch.
commit 38f7e1c0c43dd25b06513137bb6fd35476f9ec6d upstream.
BUG: kernel NULL pointer dereference, address: 00000000000000b8
#PF: supervisor read access in kernel mode
#PF: error_code(0x0000) - not-present page
PGD 80000008b6fef067 P4D 80000008b6fef067 PUD 8b6fe6067 PMD 0
Oops: 0000 [#1] SMP PTI
CPU: 12 PID: 23871 Comm: kworker/12:80 Kdump: loaded Tainted: G S
5.9.0-rc3+ #1
Hardware name: Supermicro X10SRA-F/X10SRA-F, BIOS 2.1 03/29/2018
Workqueue: events tx_work_handler [tls]
RIP: 0010:tx_work_handler+0x1b/0x70 [tls]
Code: dc fe ff ff e8 16 d4 a3 f6 66 0f 1f 44 00 00 0f 1f 44 00 00 55 53 48 8b
6f 58 48 8b bd a0 04 00 00 48 85 ff 74 1c 48 8b 47 28 <48> 8b 90 b8 00 00 00 83
e2 02 75 0c f0 48 0f ba b0 b8 00 00 00 00
RSP: 0018:ffffa44ace61fe88 EFLAGS: 00010286
RAX: 0000000000000000 RBX: ffff91da9e45cc30 RCX: dead000000000122
RDX: 0000000000000001 RSI: ffff91da9e45cc38 RDI: ffff91d95efac200
RBP: ffff91da133fd780 R08: 0000000000000000 R09: 000073746e657665
R10: 8080808080808080 R11: 0000000000000000 R12: ffff91dad7d30700
R13: ffff91dab6561080 R14: 0ffff91dad7d3070 R15: ffff91da9e45cc38
FS: 0000000000000000(0000) GS:ffff91dad7d00000(0000) knlGS:0000000000000000
CR2: 00000000000000b8 CR3: 0000000906478003 CR4: 00000000003706e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
process_one_work+0x1a7/0x370
worker_thread+0x30/0x370
? process_one_work+0x370/0x370
kthread+0x114/0x130
? kthread_park+0x80/0x80
ret_from_fork+0x22/0x30
tls_sw_release_resources_tx() waits for encrypt_pending, which
can have race, so we need similar changes as in commit
0cada33241d9de205522e3858b18e506ca5cce2c here as well.
Fixes: a42055e8d2c3 ("net/tls: Add support for async encryption of records for performance")
Signed-off-by: Rohit Maheshwari <rohitm@chelsio.com>
Acked-by: Jakub Kicinski <kuba@kernel.org>
commit 4296adc3e32f5d544a95061160fe7e127be1b9ff upstream.
Openvswitch allows to drop a packet's Ethernet header, therefore
skb_mpls_push() and skb_mpls_pop() might be called with ethernet=true
and mac_len=0. In that case the pointer passed to skb_mod_eth_type()
doesn't point to an Ethernet header and the new Ethertype is written at
unexpected locations.
Fix this by verifying that mac_len is big enough to contain an Ethernet
header.
Fixes: fa4e0f8855fc ("net/sched: fix corrupted L2 header with MPLS 'push' and 'pop' actions")
Signed-off-by: Guillaume Nault <gnault@redhat.com>
Acked-by: Davide Caratti <dcaratti@redhat.com>
commit 86bccd0367130f481ca99ba91de1c6a5aa1c78c1 upstream.
We got reports from GKE customers flows being reset by netfilter
conntrack unless nf_conntrack_tcp_be_liberal is set to 1.
Traces seemed to suggest ACK packet being dropped by the
packet capture, or more likely that ACK were received in the
wrong order.
wscale=7, SYN and SYNACK not shown here.
This ACK allows the sender to send 1871*128 bytes from seq 51359321 :
New right edge of the window -> 51359321+1871*128=51598809
09:17:23.389210 IP A > B: Flags [.], ack 51359321, win 1871, options [nop,nop,TS val 10 ecr 999], length 0
09:17:23.389212 IP B > A: Flags [.], seq 51422681:51424089, ack 1577, win 268, options [nop,nop,TS val 999 ecr 10], length 1408
09:17:23.389214 IP A > B: Flags [.], ack 51422681, win 1376, options [nop,nop,TS val 10 ecr 999], length 0
09:17:23.389253 IP B > A: Flags [.], seq 51424089:51488857, ack 1577, win 268, options [nop,nop,TS val 999 ecr 10], length 64768
09:17:23.389272 IP A > B: Flags [.], ack 51488857, win 859, options [nop,nop,TS val 10 ecr 999], length 0
09:17:23.389275 IP B > A: Flags [.], seq 51488857:51521241, ack 1577, win 268, options [nop,nop,TS val 999 ecr 10], length 32384
Receiver now allows to send 606*128=77568 from seq 51521241 :
New right edge of the window -> 51521241+606*128=51598809
09:17:23.389296 IP A > B: Flags [.], ack 51521241, win 606, options [nop,nop,TS val 10 ecr 999], length 0
09:17:23.389308 IP B > A: Flags [.], seq 51521241:51553625, ack 1577, win 268, options [nop,nop,TS val 999 ecr 10], length 32384
It seems the sender exceeds RWIN allowance, since 51611353 > 51598809
09:17:23.389346 IP B > A: Flags [.], seq 51553625:51611353, ack 1577, win 268, options [nop,nop,TS val 999 ecr 10], length 57728
09:17:23.389356 IP B > A: Flags [.], seq 51611353:51618393, ack 1577, win 268, options [nop,nop,TS val 999 ecr 10], length 7040
09:17:23.389367 IP A > B: Flags [.], ack 51611353, win 0, options [nop,nop,TS val 10 ecr 999], length 0
netfilter conntrack is not happy and sends RST
09:17:23.389389 IP A > B: Flags [R], seq 92176528, win 0, length 0
09:17:23.389488 IP B > A: Flags [R], seq 174478967, win 0, length 0
Now imagine ACK were delivered out of order and tcp_add_backlog() sets window based on wrong packet.
New right edge of the window -> 51521241+859*128=51631193
Normally TCP stack handles OOO packets just fine, but it
turns out tcp_add_backlog() does not. It can update the window
field of the aggregated packet even if the ACK sequence
of the last received packet is too old.
Many thanks to Alexandre Ferrieux for independently reporting the issue
and suggesting a fix.
Fixes: 4f693b55c3d2 ("tcp: implement coalescing on backlog queue")
Reported-by: Alexandre Ferrieux <alexandre.ferrieux@orange.com>
Acked-by: Soheil Hassas Yeganeh <soheil@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
[ Upstream commit 38b1dc47a35ba14c3f4472138ea56d014c2d609b ]
If someone calls setsockopt() twice to set a server key keyring, the first
keyring is leaked.
Fix it to return an error instead if the server key keyring is already set.
Fixes: 17926a79320a ("[AF_RXRPC]: Provide secure RxRPC sockets for use by userspace and kernel both")
[ Upstream commit fea99111244bae44e7d82a973744d27ea1567814 ]
The keyring containing the server's tokens isn't network-namespaced, so it
shouldn't be looked up with a network namespace. It is expected to be
owned specifically by the server, so namespacing is unnecessary.
Fixes: a58946c158a0 ("keys: Pass the network namespace into request_key mechanism")
[ Upstream commit fa1d113a0f96f9ab7e4fe4f8825753ba1e34a9d3 ]
conn->state_lock may be taken in softirq mode, but a previous patch
replaced an outer lock in the response-packet event handling code, and lost
the _bh from that when doing so.
Fix this by applying the _bh annotation to the state_lock locking.
Fixes: a1399f8bb033 ("rxrpc: Call channels should have separate call number spaces")
[ Upstream commit 9a059cd5ca7d9c5c4ca5a6e755cf72f230176b6a ]
If rxrpc_read() (which allows KEYCTL_READ to read a key), sees a token of a
type it doesn't recognise, it can BUG in a couple of places, which is
unnecessary as it can easily get back to userspace.
Fix this to print an error message instead.
Fixes: 99455153d067 ("RxRPC: Parse security index 5 keys (Kerberos 5)")
[ Upstream commit 56305118e05b2db8d0395bba640ac9a3aee92624 ]
The session key should be encoded with just the 8 data bytes and
no length; ENCODE_DATA precedes it with a 4 byte length, which
confuses some existing tools that try to parse this format.
Add an ENCODE_BYTES macro that does not include a length, and use
it for the key. Also adjust the expected length.
Note that commit 774521f353e1d ("rxrpc: Fix an assertion in
rxrpc_read()") had fixed a BUG by changing the length rather than
fixing the encoding. The original length was correct.
Signed-off-by: Marc Dionne <marc.dionne@auristor.com>
[ Upstream commit e94ee171349db84c7cfdc5fefbebe414054d0924 ]
The struct flowi must never be interpreted by itself as its size
depends on the address family. Therefore it must always be grouped
with its original family value.
In this particular instance, the original family value is lost in
the function xfrm_state_find. Therefore we get a bogus read when
it's coupled with the wrong family which would occur with inter-
family xfrm states.
This patch fixes it by keeping the original family value.
Note that the same bug could potentially occur in LSM through
the xfrm_state_pol_flow_match hook. I checked the current code
there and it seems to be safe for now as only secid is used which
is part of struct flowi_common. But that API should be changed
so that so that we don't get new bugs in the future. We could
do that by replacing fl with just secid or adding a family field.
Reported-by: syzbot+577fbac3145a6eb2e7a5@syzkaller.appspotmail.com
Fixes: 48b8d78315bf ("[XFRM]: State selection update to use inner...")
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit 8366685b2883e523f91e9816d7be371eb1144749 ]
When we clone state only add_time was cloned. It missed values like
bytes, packets. Now clone the all members of the structure.
v1->v3:
- use memcpy to copy the entire structure
Fixes: 80c9abaabf42 ("[XFRM]: Extension for dynamic update of endpoint address(es)")
Signed-off-by: Antony Antony <antony.antony@secunet.com>
[ Upstream commit 7aa05d304785204703a67a6aa7f1db402889a172 ]
XFRMA_SEC_CTX was not cloned from the old to the new.
Migrate this attribute during XFRMA_MSG_MIGRATE
v1->v2:
- return -ENOMEM on error
v2->v3:
- fix return type to int
[ Upstream commit 545e5c571662b1cd79d9588f9d3b6e36985b8007 ]
XFRMA_SET_MARK and XFRMA_SET_MARK_MASK was not cloned from the old
to the new. Migrate these two attributes during XFRMA_MSG_MIGRATE
Fixes: 9b42c1f179a6 ("xfrm: Extend the output_mark to support input direction and masking.")
commit 8aa7b526dc0b5dbf40c1b834d76a667ad672a410 upstream.
With multiple DNAT rules it's possible that after destination
translation the resulting tuples collide.
For example, two openvswitch flows:
nw_dst=10.0.0.10,tp_dst=10, actions=ct(commit,table=2,nat(dst=20.0.0.1:20))
nw_dst=10.0.0.20,tp_dst=10, actions=ct(commit,table=2,nat(dst=20.0.0.1:20))
Assuming two TCP clients initiating the following connections:
10.0.0.10:5000->10.0.0.10:10
10.0.0.10:5000->10.0.0.20:10
Both tuples would translate to 10.0.0.10:5000->20.0.0.1:20 causing
nf_conntrack_confirm() to fail because of tuple collision.
Netfilter handles this case by allocating a null binding for SNAT at
egress by default. Perform the same operation in openvswitch for DNAT
if no explicit SNAT is requested by the user and allocate a null binding
for SNAT for packets in the "original" direction.
Reported-at: https://bugzilla.redhat.com/1877128
Suggested-by: Florian Westphal <fw@strlen.de>
Fixes: 05752523e565 ("openvswitch: Interface with NAT.")
Signed-off-by: Dumitru Ceara <dceara@redhat.com>
Signed-off-by: Jakub Kicinski <kuba@kernel.org>
commit d42ee76ecb6c49d499fc5eb32ca34468d95dbc3e upstream.
After freeing ep->auth_hmacs we have to clear the pointer
or risk use-after-free as reported by syzbot:
BUG: KASAN: use-after-free in sctp_auth_destroy_hmacs net/sctp/auth.c:509 [inline]
BUG: KASAN: use-after-free in sctp_auth_destroy_hmacs net/sctp/auth.c:501 [inline]
BUG: KASAN: use-after-free in sctp_auth_free+0x17e/0x1d0 net/sctp/auth.c:1070
Read of size 8 at addr ffff8880a8ff52c0 by task syz-executor941/6874
CPU: 0 PID: 6874 Comm: syz-executor941 Not tainted 5.9.0-rc8-syzkaller #0
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x198/0x1fd lib/dump_stack.c:118
print_address_description.constprop.0.cold+0xae/0x497 mm/kasan/report.c:383
__kasan_report mm/kasan/report.c:513 [inline]
kasan_report.cold+0x1f/0x37 mm/kasan/report.c:530
sctp_endpoint_destroy+0x95/0x240 net/sctp/endpointola.c:203
sctp_endpoint_put net/sctp/endpointola.c:236 [inline]
sctp_endpoint_free+0xd6/0x110 net/sctp/endpointola.c:183
sctp_destroy_sock+0x9c/0x3c0 net/sctp/socket.c:4981
sctp_v6_destroy_sock+0x11/0x20 net/sctp/socket.c:9415
sk_common_release+0x64/0x390 net/core/sock.c:3254
sctp_close+0x4ce/0x8b0 net/sctp/socket.c:1533
inet_release+0x12e/0x280 net/ipv4/af_inet.c:431
inet6_release+0x4c/0x70 net/ipv6/af_inet6.c:475
__sock_release+0xcd/0x280 net/socket.c:596
sock_close+0x18/0x20 net/socket.c:1277
__fput+0x285/0x920 fs/file_table.c:281
task_work_run+0xdd/0x190 kernel/task_work.c:141
exit_task_work include/linux/task_work.h:25 [inline]
do_exit+0xb7d/0x29f0 kernel/exit.c:806
do_group_exit+0x125/0x310 kernel/exit.c:903
__do_sys_exit_group kernel/exit.c:914 [inline]
__se_sys_exit_group kernel/exit.c:912 [inline]
__x64_sys_exit_group+0x3a/0x50 kernel/exit.c:912
do_syscall_64+0x2d/0x70 arch/x86/entry/common.c:46
entry_SYSCALL_64_after_hwframe+0x44/0xa9
RIP: 0033:0x43f278
Code: Bad RIP value.
RSP: 002b:00007fffe0995c38 EFLAGS: 00000246 ORIG_RAX: 00000000000000e7
RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 000000000043f278
RDX: 0000000000000000 RSI: 000000000000003c RDI: 0000000000000000
RBP: 00000000004bf068 R08: 00000000000000e7 R09: ffffffffffffffd0
R10: 0000000020000000 R11: 0000000000000246 R12: 0000000000000001
R13: 00000000006d1180 R14: 0000000000000000 R15: 0000000000000000
Allocated by task 6874:
kasan_save_stack+0x1b/0x40 mm/kasan/common.c:48
kasan_set_track mm/kasan/common.c:56 [inline]
__kasan_kmalloc.constprop.0+0xbf/0xd0 mm/kasan/common.c:461
kmem_cache_alloc_trace+0x174/0x300 mm/slab.c:3554
kmalloc include/linux/slab.h:554 [inline]
kmalloc_array include/linux/slab.h:593 [inline]
kcalloc include/linux/slab.h:605 [inline]
sctp_auth_init_hmacs+0xdb/0x3b0 net/sctp/auth.c:464
sctp_auth_init+0x8a/0x4a0 net/sctp/auth.c:1049
sctp_setsockopt_auth_supported net/sctp/socket.c:4354 [inline]
sctp_setsockopt+0x477e/0x97f0 net/sctp/socket.c:4631
__sys_setsockopt+0x2db/0x610 net/socket.c:2132
__do_sys_setsockopt net/socket.c:2143 [inline]
__se_sys_setsockopt net/socket.c:2140 [inline]
__x64_sys_setsockopt+0xba/0x150 net/socket.c:2140
Freed by task 6874:
kasan_set_track+0x1c/0x30 mm/kasan/common.c:56
kasan_set_free_info+0x1b/0x30 mm/kasan/generic.c:355
__kasan_slab_free+0xd8/0x120 mm/kasan/common.c:422
__cache_free mm/slab.c:3422 [inline]
kfree+0x10e/0x2b0 mm/slab.c:3760
sctp_auth_destroy_hmacs net/sctp/auth.c:511 [inline]
sctp_auth_init_hmacs net/sctp/auth.c:496 [inline]
sctp_auth_init_hmacs+0x2b7/0x3b0 net/sctp/auth.c:454
Fixes: 1f485649f529 ("[SCTP]: Implement SCTP-AUTH internals")
Cc: Vlad Yasevich <vyasevich@gmail.com>
Cc: Neil Horman <nhorman@tuxdriver.com>
Cc: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
commit 45a36a18d01907710bad5258d81f76c18882ad88 upstream.
xfrm interfaces currently test for !skb->ignore_df when deciding
whether to update the pmtu on the skb's dst. Because of this, no pmtu
exception is created when we do something like:
ping -s 1438 <dest>
By dropping this check, the pmtu exception will be created and the
next ping attempt will work.
Fixes: f203b76d7809 ("xfrm: Add virtual xfrm interfaces")
Reported-by: Xiumei Mu <xmu@redhat.com>
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
commit cf83a17edeeb36195596d2dae060a7c381db35f1 upstream.
commit a10674bf2406 ("tcp: detecting the misuse of .sendpage for Slab
objects") adds the checks for Slab pages, but the pages don't have
page_count are still missing from the check.
Network layer's sendpage method is not designed to send page_count 0
pages neither, therefore both PageSlab() and page_count() should be
both checked for the sending page. This is exactly what sendpage_ok()
does.
This patch uses sendpage_ok() in do_tcp_sendpages() to detect misused
.sendpage, to make the code more robust.
Fixes: a10674bf2406 ("tcp: detecting the misuse of .sendpage for Slab objects")
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
Signed-off-by: Coly Li <colyli@suse.de>
Cc: Vasily Averin <vvs@virtuozzo.com>
Cc: stable@vger.kernel.org
commit 3dc289f8f139997f4e9d3cfccf8738f20d23e47b upstream.
In nl80211_parse_key(), key.idx is first initialized as -1.
If this value of key.idx remains unmodified and gets returned, and
nl80211_key_allowed() also returns 0, then rdev_del_key() gets called
with key.idx = -1.
This causes an out-of-bounds array access.
Handle this issue by checking if the value of key.idx after
nl80211_parse_key() is called and return -EINVAL if key.idx < 0.
Reported-by: syzbot+b1bb342d1d097516cbda@syzkaller.appspotmail.com
Tested-by: syzbot+b1bb342d1d097516cbda@syzkaller.appspotmail.com
Signed-off-by: Anant Thazhemadam <anant.thazhemadam@gmail.com>
Link: https://lore.kernel.org/r/20201007035401.9522-1-anant.thazhemadam@gmail.com
This is the 5.4.70 stable release
commit 1cc5ef91d2ff94d2bf2de3b3585423e8a1051cb6 upstream.
The indexes to the nf_nat_l[34]protos arrays come from userspace. So
check the tuple's family, e.g. l3num, when creating the conntrack in
order to prevent an OOB memory access during setup. Here is an example
kernel panic on 4.14.180 when userspace passes in an index greater than
NFPROTO_NUMPROTO.
Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
Modules linked in:...
Process poc (pid: 5614, stack limit = 0x00000000a3933121)
CPU: 4 PID: 5614 Comm: poc Tainted: G S W O 4.14.180-g051355490483
Hardware name: Qualcomm Technologies, Inc. SM8150 V2 PM8150 Google Inc. MSM
task: 000000002a3dfffe task.stack: 00000000a3933121
pc : __cfi_check_fail+0x1c/0x24
lr : __cfi_check_fail+0x1c/0x24
Call trace:
name_to_dev_t+0x0/0x468
nfnetlink_parse_nat_setup+0x234/0x258
ctnetlink_parse_nat_setup+0x4c/0x228
ctnetlink_new_conntrack+0x590/0xc40
nfnetlink_rcv_msg+0x31c/0x4d4
netlink_rcv_skb+0x100/0x184
nfnetlink_rcv+0xf4/0x180
netlink_unicast+0x360/0x770
netlink_sendmsg+0x5a0/0x6a4
___sys_sendmsg+0x314/0x46c
SyS_sendmsg+0xb4/0x108
el0_svc_naked+0x34/0x38
This crash is not happening since 5.4+, however, ctnetlink still
allows for creating entries with unsupported layer 3 protocol number.
Fixes: c1d10adb4a521 ("[NETFILTER]: Add ctnetlink port for nf_conntrack")
Signed-off-by: Will McVicker <willmcvicker@google.com>
[pablo@netfilter.org: rebased original patch on top of nf.git]
[ Upstream commit 3bd5c7a28a7c3aba07a2d300d43f8e988809e147 ]
Limit maximum VHT MPDU size by local capability.
Signed-off-by: Felix Fietkau <nbd@nbd.name>
Link: https://lore.kernel.org/r/20200917125031.45009-1-nbd@nbd.name
[ Upstream commit 412a84b5714af56f3eb648bba155107b5edddfdf ]
Radiotap header field 'Channel flags' has '2 GHz spectrum' set to
'true' for 6GHz packet.
Change it to 5GHz as there isn't a separate option available for 6GHz.
Signed-off-by: Aloka Dixit <alokad@codeaurora.org>
Link: https://lore.kernel.org/r/010101747ab7b703-1d7c9851-1594-43bf-81f7-f79ce7a67cc6-000000@us-west-2.amazonses.com
[ Upstream commit df12eb6d6cd920ab2f0e0a43cd6e1c23a05cea91 ]
Whenever the vsock backend on the host sends a packet through the RX
queue, it expects an answer on the TX queue. Unfortunately, there is one
case where the host side will hang waiting for the answer and might
effectively never recover if no timeout mechanism was implemented.
This issue happens when the guest side starts binding to the socket,
which insert a new bound socket into the list of already bound sockets.
At this time, we expect the guest to also start listening, which will
trigger the sk_state to move from TCP_CLOSE to TCP_LISTEN. The problem
occurs if the host side queued a RX packet and triggered an interrupt
right between the end of the binding process and the beginning of the
listening process. In this specific case, the function processing the
packet virtio_transport_recv_pkt() will find a bound socket, which means
it will hit the switch statement checking for the sk_state, but the
state won't be changed into TCP_LISTEN yet, which leads the code to pick
the default statement. This default statement will only free the buffer,
while it should also respond to the host side, by sending a packet on
its TX queue.
In order to simply fix this unfortunate chain of events, it is important
that in case the default statement is entered, and because at this stage
we know the host side is waiting for an answer, we must send back a
packet containing the operation VIRTIO_VSOCK_OP_RST.
One could say that a proper timeout mechanism on the host side will be
enough to avoid the backend to hang. But the point of this patch is to
ensure the normal use case will be provided with proper responsiveness
when it comes to establishing the connection.
Signed-off-by: Sebastien Boeuf <sebastien.boeuf@intel.com>
[ Upstream commit 4c7246dc45e2706770d5233f7ce1597a07e069ba ]
We are going to add 'struct vsock_sock *' parameter to
virtio_transport_get_ops().
In some cases, like in the virtio_transport_reset_no_sock(),
we don't have any socket assigned to the packet received,
so we can't use the virtio_transport_get_ops().
In order to allow virtio_transport_reset_no_sock() to use the
'.send_pkt' callback from the 'vhost_transport' or 'virtio_transport',
we add the 'struct virtio_transport *' to it and to its caller:
virtio_transport_recv_pkt().
We moved the 'vhost_transport' and 'virtio_transport' definition,
to pass their address to the virtio_transport_recv_pkt().
Reviewed-by: Stefan Hajnoczi <stefanha@redhat.com>
Signed-off-by: Stefano Garzarella <sgarzare@redhat.com>
This is the 5.4.69 stable release
[ Upstream commit b959ba9f468b1c581f40e92661ad58b093abaa03 ]
When LIB80211_CRYPT_CCMP is enabled and CRYPTO is disabled, it results in unmet
direct dependencies config warning. The reason is that LIB80211_CRYPT_CCMP
selects CRYPTO_AES and CRYPTO_CCM, which are subordinate to CRYPTO. This is
reproducible with CRYPTO disabled and R8188EU enabled, where R8188EU selects
LIB80211_CRYPT_CCMP but does not select or depend on CRYPTO.
Honor the kconfig menu hierarchy to remove kconfig dependency warnings.
Fixes: a11e2f85481c ("lib80211: use crypto API ccm(aes) transform for CCMP processing")
Signed-off-by: Necip Fazil Yildiran <fazilyildiran@gmail.com>
Link: https://lore.kernel.org/r/20200909095452.3080-1-fazilyildiran@gmail.com
[ Upstream commit 2369e827046920ef0599e6a36b975ac5c0a359c2 ]
Scenario:
* Multicast frame send from BLA backbone gateways (multiple nodes
with their bat0 bridged together, with BLA enabled) sharing the same
LAN to nodes in the mesh
Issue:
* Nodes receive the frame multiple times on bat0 from the mesh,
once from each foreign BLA backbone gateway which shares the same LAN
with another
For multicast frames via batman-adv broadcast packets coming from the
same BLA backbone but from different backbone gateways duplicates are
currently detected via a CRC history of previously received packets.
However this CRC so far was not performed for multicast frames received
via batman-adv unicast packets. Fixing this by appyling the same check
for such packets, too.
Room for improvements in the future: Ideally we would introduce the
possibility to not only claim a client, but a complete originator, too.
This would allow us to only send a multicast-in-unicast packet from a BLA
backbone gateway claiming the node and by that avoid potential redundant
transmissions in the first place.
Fixes: 279e89b2281a ("batman-adv: add broadcast duplicate check")
Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue>
Signed-off-by: Sven Eckelmann <sven@narfation.org>
Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
[ Upstream commit 74c09b7275126da1b642b90c9cdc3ae8b729ad4b ]
Scenario:
* Multicast frame send from mesh to a BLA backbone (multiple nodes
Issue:
* BLA backbone nodes receive the frame multiple times on bat0,
once from mesh->bat0 and once from each backbone_gw from LAN
For unicast, a node will send only to the best backbone gateway
according to the TQ. However for multicast we currently cannot determine
if multiple destination nodes share the same backbone if they don't share
the same backbone with us. So we need to keep sending the unicasts to
all backbone gateways and let the backbone gateways decide which one
will forward the frame. We can use the CLAIM mechanism to make this
decision.
One catch: The batman-adv gateway feature for DHCP packets potentially
sends multicast packets in the same batman-adv unicast header as the
multicast optimizations code. And we are not allowed to drop those even
if we did not claim the source address of the sender, as for such
packets there is only this one multicast-in-unicast packet.
How can we distinguish the two cases?
The gateway feature uses a batman-adv unicast 4 address header. While
the multicast-to-unicasts feature uses a simple, 3 address batman-adv
unicast header. So let's use this to distinguish.
Fixes: fe2da6ff27c7 ("batman-adv: check incoming packet type for bla")
[ Upstream commit 3236d215ad38a3f5372e65cd1e0a52cf93d3c6a2 ]
Scenario:
* Multicast frame send from a BLA backbone (multiple nodes with
Issue:
For multicast frames received via batman-adv broadcast packets the
originator of the broadcast packet is checked before decapsulating and
forwarding the frame to bat0 (batadv_bla_is_backbone_gw()->
batadv_recv_bcast_packet()). If it came from a node which shares the
same BLA backbone with us then it is not forwarded to bat0 to avoid a
loop.
When sending a multicast frame in a non-4-address batman-adv unicast
packet we are currently missing this check - and cannot do so because
the batman-adv unicast packet has no originator address field.
However, we can simply fix this on the sender side by only sending the
multicast frame via unicasts to interested nodes which do not share the
same BLA backbone with us. This also nicely avoids some unnecessary
transmissions on mesh side.
Note that no infinite loop was observed, probably because of dropping
via batadv_interface_tx()->batadv_bla_tx(). However the duplicates still
utterly confuse switches/bridges, ICMPv6 duplicate address detection and
neighbor discovery and therefore leads to long delays before being able
to establish TCP connections, for instance. And it also leads to the Linux
bridge printing messages like:
"br-lan: received packet on eth1 with own address as source address ..."
Fixes: 2d3f6ccc4ea5 ("batman-adv: Modified forwarding behaviour for multicast packets")
[ Upstream commit 4bba9dab86b6ac15ca560ef1f2b5aa4529cbf784 ]
The fix for receiving (internally generated) bla packets outside the
interrupt context introduced the usage of in_interrupt(). But this
functionality is only defined in linux/preempt.h which was not included
with the same patch.
Fixes: 279e89b2281a ("batman-adv: bla: use netif_rx_ni when not in interrupt context")
[ Upstream commit e6a18d36118bea3bf497c9df4d9988b6df120689 ]
Bryce reported that he saw the following with:
0: r6 = r1
1: r1 = 12
2: r0 = *(u16 *)skb[r1]
The xlated sequence was incorrectly clobbering r2 with pointer
value of r6 ...
0: (bf) r6 = r1
1: (b7) r1 = 12
2: (bf) r1 = r6
3: (bf) r2 = r1
4: (85) call bpf_skb_load_helper_16_no_cache#7692160
... and hence call to the load helper never succeeded given the
offset was too high. Fix it by reordering the load of r6 to r1.
Other than that the insn has similar calling convention than BPF
helpers, that is, r0 - r5 are scratch regs, so nothing else
affected after the insn.
Fixes: e0cea7ce988c ("bpf: implement ld_abs/ld_ind in native bpf")
Reported-by: Bryce Kahle <bryce.kahle@datadoghq.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
Link: https://lore.kernel.org/bpf/cace836e4d07bb63b1a53e49c5dfb238a040c298.1599512096.git.daniel@iogearbox.net
[ Upstream commit 0ff4628f4c6c1ab87eef9f16b25355cadc426d64 ]
syzbot reported a bug in ieee802154_tx() [1]
A similar issue in ieee802154_xmit_worker() is also fixed in this patch.
[1]
BUG: KASAN: use-after-free in ieee802154_tx+0x3d2/0x480 net/mac802154/tx.c:88
Read of size 4 at addr ffff8880251a8c70 by task syz-executor.3/928
CPU: 0 PID: 928 Comm: syz-executor.3 Not tainted 5.9.0-rc3-syzkaller #0
Call Trace:
ieee802154_subif_start_xmit+0xbe/0xe4 net/mac802154/tx.c:130
__netdev_start_xmit include/linux/netdevice.h:4634 [inline]
netdev_start_xmit include/linux/netdevice.h:4648 [inline]
dev_direct_xmit+0x4e9/0x6e0 net/core/dev.c:4203
packet_snd net/packet/af_packet.c:2989 [inline]
packet_sendmsg+0x2413/0x5290 net/packet/af_packet.c:3014
sock_sendmsg_nosec net/socket.c:651 [inline]
sock_sendmsg+0xcf/0x120 net/socket.c:671
____sys_sendmsg+0x6e8/0x810 net/socket.c:2353
___sys_sendmsg+0xf3/0x170 net/socket.c:2407
__sys_sendmsg+0xe5/0x1b0 net/socket.c:2440
RIP: 0033:0x45d5b9
Code: 5d b4 fb ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 2b b4 fb ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007fc98e749c78 EFLAGS: 00000246 ORIG_RAX: 000000000000002e
RAX: ffffffffffffffda RBX: 000000000002ccc0 RCX: 000000000045d5b9
RDX: 0000000000000000 RSI: 0000000020007780 RDI: 000000000000000b
RBP: 000000000118d020 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 000000000118cfec
R13: 00007fff690c720f R14: 00007fc98e74a9c0 R15: 000000000118cfec
Allocated by task 928:
slab_post_alloc_hook mm/slab.h:518 [inline]
slab_alloc_node mm/slab.c:3254 [inline]
kmem_cache_alloc_node+0x136/0x3e0 mm/slab.c:3574
__alloc_skb+0x71/0x550 net/core/skbuff.c:198
alloc_skb include/linux/skbuff.h:1094 [inline]
alloc_skb_with_frags+0x92/0x570 net/core/skbuff.c:5771
sock_alloc_send_pskb+0x72a/0x880 net/core/sock.c:2348
packet_alloc_skb net/packet/af_packet.c:2837 [inline]
packet_snd net/packet/af_packet.c:2932 [inline]
packet_sendmsg+0x19fb/0x5290 net/packet/af_packet.c:3014
Freed by task 928:
__cache_free mm/slab.c:3418 [inline]
kmem_cache_free.part.0+0x74/0x1e0 mm/slab.c:3693
kfree_skbmem+0xef/0x1b0 net/core/skbuff.c:622
__kfree_skb net/core/skbuff.c:679 [inline]
consume_skb net/core/skbuff.c:838 [inline]
consume_skb+0xcf/0x160 net/core/skbuff.c:832
__dev_kfree_skb_any+0x9c/0xc0 net/core/dev.c:3107
fakelb_hw_xmit+0x20e/0x2a0 drivers/net/ieee802154/fakelb.c:81
drv_xmit_async net/mac802154/driver-ops.h:16 [inline]
ieee802154_tx+0x282/0x480 net/mac802154/tx.c:81
The buggy address belongs to the object at ffff8880251a8c00
which belongs to the cache skbuff_head_cache of size 224
The buggy address is located 112 bytes inside of
224-byte region [ffff8880251a8c00, ffff8880251a8ce0)
The buggy address belongs to the page:
page:0000000062b6a4f1 refcount:1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x251a8
flags: 0xfffe0000000200(slab)
raw: 00fffe0000000200 ffffea0000435c88 ffffea00028b6c08 ffff8880a9055d00
raw: 0000000000000000 ffff8880251a80c0 000000010000000c 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff8880251a8b00: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8880251a8b80: fb fb fb fb fc fc fc fc fc fc fc fc fc fc fc fc
>ffff8880251a8c00: fa fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8880251a8c80: fb fb fb fb fb fb fb fb fb fb fb fb fc fc fc fc
ffff8880251a8d00: fc fc fc fc fc fc fc fc fa fb fb fb fb fb fb fb
Fixes: 409c3b0c5f03 ("mac802154: tx: move stats tx increment")
Reported-by: syzbot <syzkaller@googlegroups.com>
Cc: Alexander Aring <alex.aring@gmail.com>
Cc: Stefan Schmidt <stefan@datenfreihafen.org>
Cc: linux-wpan@vger.kernel.org
Link: https://lore.kernel.org/r/20200908104025.4009085-1-edumazet@google.com
Signed-off-by: Stefan Schmidt <stefan@datenfreihafen.org>
[ Upstream commit 526e81b990e53e31ba40ba304a2285ffd098721f ]
The openvswitch module fails initialization when used in a kernel
without IPv6 enabled. nf_conncount_init() fails because the ct code
unconditionally tries to initialize the netns IPv6 related bit,
regardless of the build option. The change below ignores the IPv6
part if not enabled.
Note that the corresponding _put() function already has this IPv6
configuration check.
Fixes: 11efd5cb04a1 ("openvswitch: Support conntrack zone limit")
Signed-off-by: Eelco Chaudron <echaudro@redhat.com>
Reviewed-by: Simon Horman <simon.horman@netronome.com>
[ Upstream commit 7dda5b3384121181c4e79f6eaeac2b94c0622c8d ]
The unicast packet rerouting code makes several assumptions. For
instance it assumes that there is always exactly one destination in the
TT. This breaks for multicast frames in a unicast packets in several ways:
For one thing if there is actually no TT entry and the destination node
was selected due to the multicast tvlv flags it announced. Then an
intermediate node will wrongly drop the packet.
For another thing if there is a TT entry but the TTVN of this entry is
newer than the originally addressed destination node: Then the
intermediate node will wrongly redirect the packet, leading to
duplicated multicast packets at a multicast listener and missing
packets at other multicast listeners or multicast routers.
Fixing this by not applying the unicast packet rerouting to batman-adv
unicast packets with a multicast payload. We are not able to detect a
roaming multicast listener at the moment and will just continue to send
the multicast frame to both the new and old destination for a while in
case of such a roaming multicast listener.
Fixes: a73105b8d4c7 ("batman-adv: improved client announcement mechanism")
[ Upstream commit 097930e85f90f252c44dc0d084598265dd44ca48 ]
It seems that due to a copy & paste error the void pointer
in batadv_choose_backbone_gw() is cast to the wrong type.
Fixing this by using "struct batadv_bla_backbone_gw" instead of "struct
batadv_bla_claim" which better matches the caller's side.
For now it seems that we were lucky because the two structs both have
their orig/vid and addr/vid in the beginning. However I stumbled over
this issue when I was trying to add some debug variables in front of
"orig" in batadv_backbone_gw, which caused hash lookups to fail.
Fixes: 07568d0369f9 ("batman-adv: don't rely on positions in struct for hashing")
Signed-off-by: Linus Lüssing <ll@simonwunderlich.de>
[ Upstream commit 659d4587fe7233bfdff303744b20d6f41ad04362 ]
Compile the kernel for arm 32 platform, the build warning found.
To fix that, should use div_u64() for divisions.
| net/openvswitch/meter.c:396: undefined reference to `__udivdi3'
[add more commit msg, change reported tag, and use div_u64 instead
of do_div by Tonghao]
Fixes: e57358873bb5d6ca ("net: openvswitch: use u64 for meter bucket")
Reported-by: kbuild test robot <lkp@intel.com>
Signed-off-by: Tonghao Zhang <xiangxia.m.yue@gmail.com>
Tested-by: Tonghao Zhang <xiangxia.m.yue@gmail.com>
[ Upstream commit 5af7fef39d7952c0f5551afa7b821ee7b6c9dd3d ]
When using 802.1X over mesh networks, at first an ordinary
mesh peering is established, then the 802.1X EAPOL dialog
happens, afterwards an authenticated mesh peering exchange
(AMPE) happens, finally the peering is complete and we can
set the STA authorized flag.
As 802.1X is an intermediate step here and key material is
not yet exchanged for stations we have to skip mesh path lookup
for these EAPOL frames. Otherwise the already configure mesh
group encryption key would be used to send a mesh path request
which no one can decipher, because we didn't already establish
key material on both peers, like with SAE and directly using AMPE.
Signed-off-by: Markus Theil <markus.theil@tu-ilmenau.de>
Link: https://lore.kernel.org/r/20200617082637.22670-2-markus.theil@tu-ilmenau.de
[remove pointless braces, remove unnecessary local variable,
the list can only process one such frame (or its fragments)]
[ Upstream commit ea740bd5f58e2912e74f401fd01a9d6aa985ca05 ]
Way back when I was writing the RPC/RDMA server-side backchannel
code, I misread the TCP backchannel reply handler logic. When
svc_tcp_recvfrom() successfully receives a backchannel reply, it
does not return -EAGAIN. It sets XPT_DATA and returns zero.
Update svc_rdma_recvfrom() to return zero. Here, XPT_DATA doesn't
need to be set again: it is set whenever a new message is received,
behind a spin lock in a single threaded context.
Also, if handling the cb reply is not successful, the message is
simply dropped. There's no special message framing to deal with as
there is in the TCP case.
Now that the handle_bc_reply() return value is ignored, I've removed
the dprintk call sites in the error exit of handle_bc_reply() in
favor of trace points in other areas that already report the error
cases.
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
[ Upstream commit 0771d7df819284d46cf5cfb57698621b503ec17f ]
Upon receipt of a service subscription request from user via a topology
connection, one 'sub' object will be allocated in kernel, so it will be
able to send an event of the service if any to the user correspondingly
then. Also, in case of any failure, the connection will be shutdown and
all the pertaining 'sub' objects will be freed.
However, there is a race condition as follows resulting in memory leak:
receive-work connection send-work
sub-1 |<------//-------| |
sub-2 |<------//-------| |
| |<---------------| evt for sub-x
sub-3 |<------//-------| |
| | * peer closed |
| | |<-------X-------| evt for sub-y
sub-n |<------/ X shutdown |
-> orphan | |
That is, the 'receive-work' may get the last subscription request while
the 'send-work' is shutting down the connection due to peer close.
We had a 'lock' on the connection, so the two actions cannot be carried
out simultaneously. If the last subscription is allocated e.g. 'sub-n',
before the 'send-work' closes the connection, there will be no issue at
all, the 'sub' objects will be freed. In contrast the last subscription
will become orphan since the connection was closed, and we released all
references.
This commit fixes the issue by simply adding one test if the connection
remains in 'connected' state right after we obtain the connection lock,
then a subscription object can be created as usual, otherwise we ignore
it.
Acked-by: Ying Xue <ying.xue@windriver.com>
Acked-by: Jon Maloy <jmaloy@redhat.com>
Reported-by: Thang Ngo <thang.h.ngo@dektech.com.au>
Signed-off-by: Tuong Lien <tuong.t.lien@dektech.com.au>
[ Upstream commit adf1d6926444029396861413aba8a0f2a805742a ]
After sending Inquiry Cancel command to the controller, it is possible
that Inquiry Complete event comes before Inquiry Cancel command complete
event. In this case the Inquiry Cancel command will have status of
Command Disallowed since there is no Inquiry session to be cancelled.
This case should not be treated as error, otherwise we can reach an
inconsistent state.
Example of a btmon trace when this happened:
< HCI Command: Inquiry Cancel (0x01|0x0002) plen 0
> HCI Event: Inquiry Complete (0x01) plen 1
Status: Success (0x00)
> HCI Event: Command Complete (0x0e) plen 4
Inquiry Cancel (0x01|0x0002) ncmd 1
Status: Command Disallowed (0x0c)
Signed-off-by: Sonny Sasaka <sonnysasaka@chromium.org>
[ Upstream commit 8d9f73c0ad2f20e9fed5380de0a3097825859d03 ]
In lec_arp_clear_vccs() only entry->vcc is freed, but vcc
could be installed on entry->recv_vcc too in lec_vcc_added().
This fixes the following memory leak:
unreferenced object 0xffff8880d9266b90 (size 16):
comm "atm2", pid 425, jiffies 4294907980 (age 23.488s)
hex dump (first 16 bytes):
00 00 00 00 00 00 00 00 00 00 00 00 6b 6b 6b a5 ............kkk.
backtrace:
[<(____ptrval____)>] kmem_cache_alloc_trace+0x10e/0x151
[<(____ptrval____)>] lane_ioctl+0x4b3/0x569
[<(____ptrval____)>] do_vcc_ioctl+0x1ea/0x236
[<(____ptrval____)>] svc_ioctl+0x17d/0x198
[<(____ptrval____)>] sock_do_ioctl+0x47/0x12f
[<(____ptrval____)>] sock_ioctl+0x2f9/0x322
[<(____ptrval____)>] vfs_ioctl+0x1e/0x2b
[<(____ptrval____)>] ksys_ioctl+0x61/0x80
[<(____ptrval____)>] __x64_sys_ioctl+0x16/0x19
[<(____ptrval____)>] do_syscall_64+0x57/0x65
[<(____ptrval____)>] entry_SYSCALL_64_after_hwframe+0x49/0xb3
Cc: Gengming Liu <l.dmxcsnsbh@gmail.com>
[ Upstream commit bea0c5c942d3b4e9fb6ed45f6a7de74c6b112437 ]
Devlink health core conditions the reporter's recovery with the
expiration of the grace period. This is not relevant for the first
recovery. Explicitly demand that the grace period will only apply to
recoveries other than the first.
Fixes: c8e1da0bf923 ("devlink: Add health report functionality")
Signed-off-by: Aya Levin <ayal@mellanox.com>
Reviewed-by: Moshe Shemesh <moshe@mellanox.com>
Reviewed-by: Jiri Pirko <jiri@mellanox.com>
[ Upstream commit e57358873bb5d6caa882b9684f59140912b37dde ]
When setting the meter rate to 4+Gbps, there is an
overflow, the meters don't work as expected.
Cc: Pravin B Shelar <pshelar@ovn.org>
Cc: Andy Zhou <azhou@ovn.org>
Acked-by: Pravin B Shelar <pshelar@ovn.org>
[ Upstream commit 1fab7dc477241c12f977955aa6baea7938b6f08d ]
Move the test for whether a task is already queued to prevent
corruption of the timer list in __rpc_sleep_on_priority_timeout().
Signed-off-by: Trond Myklebust <trond.myklebust@hammerspace.com>
[ Upstream commit 0a6a9515fe390976cd762c52d8d4f446d7a14285 ]
It is safe to traverse &net->nft.tables with &net->nft.commit_mutex
held using list_for_each_entry_rcu(). Silence the PROVE_RCU_LIST false
positive,
WARNING: suspicious RCU usage
net/netfilter/nf_tables_api.c:523 RCU-list traversed in non-reader section!!
rcu_scheduler_active = 2, debug_locks = 1
1 lock held by iptables/1384:
#0: ffffffff9745c4a8 (&net->nft.commit_mutex){+.+.}, at: nf_tables_valid_genid+0x25/0x60 [nf_tables]
Call Trace:
dump_stack+0xa1/0xea
lockdep_rcu_suspicious+0x103/0x10d
nft_table_lookup.part.0+0x116/0x120 [nf_tables]
nf_tables_newtable+0x12c/0x7d0 [nf_tables]
nfnetlink_rcv_batch+0x559/0x1190 [nfnetlink]
nfnetlink_rcv+0x1da/0x210 [nfnetlink]
netlink_unicast+0x306/0x460
netlink_sendmsg+0x44b/0x770
____sys_sendmsg+0x46b/0x4a0
___sys_sendmsg+0x138/0x1a0
__sys_sendmsg+0xb6/0x130
__x64_sys_sendmsg+0x48/0x50
do_syscall_64+0x69/0xf4
Signed-off-by: Qian Cai <cai@lca.pw>
Acked-by: Florian Westphal <fw@strlen.de>
