This is the 5.4.264 stable release
drivers/pci/controller/dwc/pci-imx6.c
commit 0f31993721f92 ("PCI: imx6: Install the fault
handler only on compatible match") overlaps with our
not mainlined THUMB work.
Keep both additions
sound/soc/codecs/sgtl5000.c
commit c062676528865 (ASoC: sgtl5000: Reset the
CHIP_CLK_CTRL reg on remove") with a backport of a
"fixes" commit.
commit e03781879a0d524ce3126678d50a80484a513c4b upstream.
The "NET_DM" generic netlink family notifies drop locations over the
"events" multicast group. This is problematic since by default generic
netlink allows non-root users to listen to these notifications.
Fix by adding a new field to the generic netlink multicast group
structure that when set prevents non-root users or root without the
'CAP_SYS_ADMIN' capability (in the user namespace owning the network
namespace) from joining the group. Set this field for the "events"
group. Use 'CAP_SYS_ADMIN' rather than 'CAP_NET_ADMIN' because of the
nature of the information that is shared over this group.
Note that the capability check in this case will always be performed
against the initial user namespace since the family is not netns aware
and only operates in the initial network namespace.
A new field is added to the structure rather than using the "flags"
field because the existing field uses uAPI flags and it is inappropriate
to add a new uAPI flag for an internal kernel check. In net-next we can
rework the "flags" field to use internal flags and fold the new field
into it. But for now, in order to reduce the amount of changes, add a
new field.
Since the information can only be consumed by root, mark the control
plane operations that start and stop the tracing as root-only using the
'GENL_ADMIN_PERM' flag.
Tested using [1].
Before:
# capsh -- -c ./dm_repo
# capsh --drop=cap_sys_admin -- -c ./dm_repo
After:
Failed to join "events" multicast group
[1]
$ cat dm.c
#include <stdio.h>
#include <netlink/genl/ctrl.h>
#include <netlink/genl/genl.h>
#include <netlink/socket.h>
int main(int argc, char **argv)
struct nl_sock *sk;
int grp, err;
sk = nl_socket_alloc();
if (!sk) {
fprintf(stderr, "Failed to allocate socket\n");
return -1;
err = genl_connect(sk);
if (err) {
fprintf(stderr, "Failed to connect socket\n");
return err;
grp = genl_ctrl_resolve_grp(sk, "NET_DM", "events");
if (grp < 0) {
fprintf(stderr,
"Failed to resolve \"events\" multicast group\n");
return grp;
err = nl_socket_add_memberships(sk, grp, NFNLGRP_NONE);
if (err) {
fprintf(stderr, "Failed to join \"events\" multicast group\n");
return err;
return 0;
$ gcc -I/usr/include/libnl3 -lnl-3 -lnl-genl-3 -o dm_repo dm.c
Fixes: 9a8afc8d3962 ("Network Drop Monitor: Adding drop monitor implementation & Netlink protocol")
Reported-by: "The UK's National Cyber Security Centre (NCSC)" <security@ncsc.gov.uk>
Signed-off-by: Ido Schimmel <idosch@nvidia.com>
Reviewed-by: Jacob Keller <jacob.e.keller@intel.com>
Reviewed-by: Jiri Pirko <jiri@nvidia.com>
Link: https://lore.kernel.org/r/20231206213102.1824398-3-idosch@nvidia.com
Signed-off-by: Jakub Kicinski <kuba@kernel.org>
commit 44ec98ea5ea9cfecd31a5c4cc124703cb5442832 upstream.
The "psample" generic netlink family notifies sampled packets over the
"packets" multicast group. This is problematic since by default generic
Fix by marking the group with the 'GENL_UNS_ADMIN_PERM' flag. This will
prevent non-root users or root without the 'CAP_NET_ADMIN' capability
(in the user namespace owning the network namespace) from joining the
group.
Tested using [1].
Before:
# capsh -- -c ./psample_repo
# capsh --drop=cap_net_admin -- -c ./psample_repo
After:
Failed to join "packets" multicast group
[1]
$ cat psample.c
#include <stdio.h>
int join_grp(struct nl_sock *sk, const char *grp_name)
int grp, err;
grp = genl_ctrl_resolve_grp(sk, "psample", grp_name);
if (grp < 0) {
fprintf(stderr, "Failed to resolve \"%s\" multicast group\n",
grp_name);
return grp;
if (err) {
fprintf(stderr, "Failed to join \"%s\" multicast group\n",
grp_name);
return err;
return 0;
struct nl_sock *sk;
int err;
if (!sk) {
return -1;
if (err) {
return err;
err = join_grp(sk, "config");
if (err)
return err;
err = join_grp(sk, "packets");
if (err)
return err;
return 0;
$ gcc -I/usr/include/libnl3 -lnl-3 -lnl-genl-3 -o psample_repo psample.c
Fixes: 6ae0a6286171 ("net: Introduce psample, a new genetlink channel for packet sampling")
Link: https://lore.kernel.org/r/20231206213102.1824398-2-idosch@nvidia.com
This is a partial backport of upstream commit 4d54cc32112d ("mptcp:
avoid lock_fast usage in accept path"). It is only a partial backport
because the patch in the link below was erroneously squash-merged into
upstream commit 4d54cc32112d ("mptcp: avoid lock_fast usage in accept
path"). Below is the original patch description from Florian Westphal:
genetlink sets NL_CFG_F_NONROOT_RECV for its netlink socket so anyone can
subscribe to multicast messages.
rtnetlink doesn't allow this unconditionally, rtnetlink_bind() restricts
bind requests to CAP_NET_ADMIN for a few groups.
This allows to set GENL_UNS_ADMIN_PERM flag on genl mcast groups to
mandate CAP_NET_ADMIN.
This will be used by the upcoming mptcp netlink event facility which
exposes the token (mptcp connection identifier) to userspace.
Link: https://lore.kernel.org/mptcp/20210213000001.379332-8-mathew.j.martineau@linux.intel.com/
commit f2764bd4f6a8dffaec3e220728385d9756b3c2cb upstream.
When I added support to allow generic netlink multicast groups to be
restricted to subscribers with CAP_NET_ADMIN I was unaware that a
genl_bind implementation already existed in the past.
It was reverted due to ABBA deadlock:
1. ->netlink_bind gets called with the table lock held.
2. genetlink bind callback is invoked, it grabs the genl lock.
But when a new genl subsystem is (un)registered, these two locks are
taken in reverse order.
One solution would be to revert again and add a comment in genl
referring 1e82a62fec613, "genetlink: remove genl_bind").
This would need a second change in mptcp to not expose the raw token
value anymore, e.g. by hashing the token with a secret key so userspace
can still associate subflow events with the correct mptcp connection.
However, Paolo Abeni reminded me to double-check why the netlink table is
locked in the first place.
I can't find one. netlink_bind() is already called without this lock
when userspace joins a group via NETLINK_ADD_MEMBERSHIP setsockopt.
Same holds for the netlink_unbind operation.
Digging through the history, commit f773608026ee1
("netlink: access nlk groups safely in netlink bind and getname")
expanded the lock scope.
commit 3a20773beeeeade ("net: netlink: cap max groups which will be considered in netlink_bind()")
... removed the nlk->ngroups access that the lock scope
extension was all about.
Reduce the lock scope again and always call ->netlink_bind without
the table lock.
The Fixes tag should be vs. the patch mentioned in the link below,
but that one got squash-merged into the patch that came earlier in the
series.
Fixes: 4d54cc32112d8d ("mptcp: avoid lock_fast usage in accept path")
Link: https://lore.kernel.org/mptcp/20210213000001.379332-8-mathew.j.martineau@linux.intel.com/T/#u
Cc: Cong Wang <xiyou.wangcong@gmail.com>
Cc: Xin Long <lucien.xin@gmail.com>
Cc: Johannes Berg <johannes.berg@intel.com>
Cc: Sean Tranchetti <stranche@codeaurora.org>
Cc: Paolo Abeni <pabeni@redhat.com>
Cc: Pablo Neira Ayuso <pablo@netfilter.org>
commit 705318a99a138c29a512a72c3e0043b3cd7f55f4 upstream.
File reference cycles have caused lots of problems for io_uring
in the past, and it still doesn't work exactly right and races with
unix_stream_read_generic(). The safest fix would be to completely
disallow sending io_uring files via sockets via SCM_RIGHT, so there
are no possible cycles invloving registered files and thus rendering
SCM accounting on the io_uring side unnecessary.
Cc: <stable@vger.kernel.org>
Fixes: 0091bfc81741b ("io_uring/af_unix: defer registered files gc to io_uring release")
Reported-and-suggested-by: Jann Horn <jannh@google.com>
Signed-off-by: Pavel Begunkov <asml.silence@gmail.com>
Link: https://lore.kernel.org/r/c716c88321939156909cfa1bd8b0faaf1c804103.1701868795.git.asml.silence@gmail.com
commit db3fadacaf0c817b222090290d06ca2a338422d0 upstream.
In some potential instances the reference count on struct packet_sock
could be saturated and cause overflows which gets the kernel a bit
confused. To prevent this, move to a 64-bit atomic reference count on
64-bit architectures to prevent the possibility of this type to overflow.
Because we can not handle saturation, using refcount_t is not possible
in this place. Maybe someday in the future if it changes it could be
used. Also, instead of using plain atomic64_t, use atomic_long_t instead.
32-bit machines tend to be memory-limited (i.e. anything that increases
a reference uses so much memory that you can't actually get to 2**32
references). 32-bit architectures also tend to have serious problems
with 64-bit atomics. Hence, atomic_long_t is the more natural solution.
Co-developed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Cc: stable@kernel.org
Reviewed-by: Willem de Bruijn <willemb@google.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
Link: https://lore.kernel.org/r/20231201131021.19999-1-daniel@iogearbox.net
[ Upstream commit bb9aefde5bbaf6c168c77ba635c155b4980c2287 ]
Curr pointer should be updated when the sg structure is shifted.
Fixes: 7246d8ed4dcce ("bpf: helper to pop data from messages")
Signed-off-by: John Fastabend <john.fastabend@gmail.com>
Link: https://lore.kernel.org/r/20231206232706.374377-3-john.fastabend@gmail.com
[ Upstream commit 3d501dd326fb1c73f1b8206d4c6e1d7b15c07e27 ]
This patch is based on a detailed report and ideas from Yepeng Pan
and Christian Rossow.
ACK seq validation is currently following RFC 5961 5.2 guidelines:
The ACK value is considered acceptable only if
it is in the range of ((SND.UNA - MAX.SND.WND) <= SEG.ACK <=
SND.NXT). All incoming segments whose ACK value doesn't satisfy the
above condition MUST be discarded and an ACK sent back. It needs to
be noted that RFC 793 on page 72 (fifth check) says: "If the ACK is a
duplicate (SEG.ACK < SND.UNA), it can be ignored. If the ACK
acknowledges something not yet sent (SEG.ACK > SND.NXT) then send an
ACK, drop the segment, and return". The "ignored" above implies that
the processing of the incoming data segment continues, which means
the ACK value is treated as acceptable. This mitigation makes the
ACK check more stringent since any ACK < SND.UNA wouldn't be
accepted, instead only ACKs that are in the range ((SND.UNA -
MAX.SND.WND) <= SEG.ACK <= SND.NXT) get through.
This can be refined for new (and possibly spoofed) flows,
by not accepting ACK for bytes that were never sent.
This greatly improves TCP security at a little cost.
I added a Fixes: tag to make sure this patch will reach stable trees,
even if the 'blamed' patch was adhering to the RFC.
tp->bytes_acked was added in linux-4.2
Following packetdrill test (courtesy of Yepeng Pan) shows
the issue at hand:
0 socket(..., SOCK_STREAM, IPPROTO_TCP) = 3
+0 setsockopt(3, SOL_SOCKET, SO_REUSEADDR, [1], 4) = 0
+0 bind(3, ..., ...) = 0
+0 listen(3, 1024) = 0
// ---------------- Handshake ------------------- //
// when window scale is set to 14 the window size can be extended to
// 65535 * (2^14) = 1073725440. Linux would accept an ACK packet
// with ack number in (Server_ISN+1-1073725440. Server_ISN+1)
// ,though this ack number acknowledges some data never
// sent by the server.
+0 < S 0:0(0) win 65535 <mss 1400,nop,wscale 14>
+0 > S. 0:0(0) ack 1 <...>
+0 < . 1:1(0) ack 1 win 65535
+0 accept(3, ..., ...) = 4
// For the established connection, we send an ACK packet,
// the ack packet uses ack number 1 - 1073725300 + 2^32,
// where 2^32 is used to wrap around.
// Note: we used 1073725300 instead of 1073725440 to avoid possible
// edge cases.
// 1 - 1073725300 + 2^32 = 3221241997
// Oops, old kernels happily accept this packet.
+0 < . 1:1001(1000) ack 3221241997 win 65535
// After the kernel fix the following will be replaced by a challenge ACK,
// and prior malicious frame would be dropped.
+0 > . 1:1(0) ack 1001
Fixes: 354e4aa391ed ("tcp: RFC 5961 5.2 Blind Data Injection Attack Mitigation")
Reported-by: Yepeng Pan <yepeng.pan@cispa.de>
Reported-by: Christian Rossow <rossow@cispa.de>
Acked-by: Neal Cardwell <ncardwell@google.com>
Link: https://lore.kernel.org/r/20231205161841.2702925-1-edumazet@google.com
[ Upstream commit 7ae836a3d630e146b732fe8ef7d86b243748751f ]
A concurrently running sock_orphan() may NULL the sk_socket pointer in
between check and deref. Follow other users (like nft_meta.c for
instance) and acquire sk_callback_lock before dereferencing sk_socket.
Fixes: 0265ab44bacc ("[NETFILTER]: merge ipt_owner/ip6t_owner in xt_owner")
Reported-by: Jann Horn <jannh@google.com>
Signed-off-by: Phil Sutter <phil@nwl.cc>
[ Upstream commit 80d875cfc9d3711a029f234ef7d680db79e8fa4b ]
In ipgre_xmit(), skb_pull() may fail even if pskb_inet_may_pull() returns
true. For example, applications can use PF_PACKET to create a malformed
packet with no IP header. This type of packet causes a problem such as
uninit-value access.
This patch ensures that skb_pull() can pull the required size by checking
the skb with pskb_network_may_pull() before skb_pull().
Fixes: c54419321455 ("GRE: Refactor GRE tunneling code.")
Signed-off-by: Shigeru Yoshida <syoshida@redhat.com>
Reviewed-by: Suman Ghosh <sumang@marvell.com>
Link: https://lore.kernel.org/r/20231202161441.221135-1-syoshida@redhat.com
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
[ Upstream commit 75475bb51e78a3f54ad2f69380f2a1c985e85f2d ]
If fib6_find_prefix() returns NULL, we should silently fallback
using fib6_null_entry regardless of RT6_DEBUG value.
syzbot reported:
WARNING: CPU: 0 PID: 5477 at net/ipv6/ip6_fib.c:1516 fib6_add+0x310d/0x3fa0 net/ipv6/ip6_fib.c:1516
Modules linked in:
CPU: 0 PID: 5477 Comm: syz-executor.0 Not tainted 6.7.0-rc2-syzkaller-00029-g9b6de136b5f0 #0
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 11/10/2023
RIP: 0010:fib6_add+0x310d/0x3fa0 net/ipv6/ip6_fib.c:1516
Code: 00 48 8b 54 24 68 e8 42 22 00 00 48 85 c0 74 14 49 89 c6 e8 d5 d3 c2 f7 eb 5d e8 ce d3 c2 f7 e9 ca 00 00 00 e8 c4 d3 c2 f7 90 <0f> 0b 90 48 b8 00 00 00 00 00 fc ff df 48 8b 4c 24 38 80 3c 01 00
RSP: 0018:ffffc90005067740 EFLAGS: 00010293
RAX: ffffffff89cba5bc RBX: ffffc90005067ab0 RCX: ffff88801a2e9dc0
RDX: 0000000000000000 RSI: 0000000000000001 RDI: 0000000000000000
RBP: ffffc90005067980 R08: ffffffff89cbca85 R09: 1ffff110040d4b85
R10: dffffc0000000000 R11: ffffed10040d4b86 R12: 00000000ffffffff
R13: 1ffff110051c3904 R14: ffff8880206a5c00 R15: ffff888028e1c820
FS: 00007f763783c6c0(0000) GS:ffff8880b9800000(0000) knlGS:0000000000000000
CR2: 00007f763783bff8 CR3: 000000007f74d000 CR4: 00000000003506f0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
<TASK>
__ip6_ins_rt net/ipv6/route.c:1303 [inline]
ip6_route_add+0x88/0x120 net/ipv6/route.c:3847
ipv6_route_ioctl+0x525/0x7b0 net/ipv6/route.c:4467
inet6_ioctl+0x21a/0x270 net/ipv6/af_inet6.c:575
sock_do_ioctl+0x152/0x460 net/socket.c:1220
sock_ioctl+0x615/0x8c0 net/socket.c:1339
vfs_ioctl fs/ioctl.c:51 [inline]
__do_sys_ioctl fs/ioctl.c:871 [inline]
__se_sys_ioctl+0xf8/0x170 fs/ioctl.c:857
do_syscall_x64 arch/x86/entry/common.c:51 [inline]
do_syscall_64+0x45/0x110 arch/x86/entry/common.c:82
Fixes: 7bbfe00e0252 ("ipv6: fix general protection fault in fib6_add()")
Reported-by: syzbot <syzkaller@googlegroups.com>
Cc: Wei Wang <weiwan@google.com>
Reviewed-by: David Ahern <dsahern@kernel.org>
Link: https://lore.kernel.org/r/20231129160630.3509216-1-edumazet@google.com
add/del/test
[ Upstream commit 28628fa952fefc7f2072ce6e8016968cc452b1ba ]
Linkui Xiao reported that there's a race condition when ipset swap and destroy is
called, which can lead to crash in add/del/test element operations. Swap then
destroy are usual operations to replace a set with another one in a production
system. The issue can in some cases be reproduced with the script:
ipset create hash_ip1 hash:net family inet hashsize 1024 maxelem 1048576
ipset add hash_ip1 172.20.0.0/16
ipset add hash_ip1 192.168.0.0/16
iptables -A INPUT -m set --match-set hash_ip1 src -j ACCEPT
while [ 1 ]
do
# ... Ongoing traffic...
ipset create hash_ip2 hash:net family inet hashsize 1024 maxelem 1048576
ipset add hash_ip2 172.20.0.0/16
ipset swap hash_ip1 hash_ip2
ipset destroy hash_ip2
sleep 0.05
done
In the race case the possible order of the operations are
CPU0 CPU1
ip_set_test
hash_net_kadt
Swap replaces hash_ip1 with hash_ip2 and then destroy removes hash_ip2 which
is the original hash_ip1. ip_set_test was called on hash_ip1 and because destroy
removed it, hash_net_kadt crashes.
The fix is to force ip_set_swap() to wait for all readers to finish accessing the
old set pointers by calling synchronize_rcu().
The first version of the patch was written by Linkui Xiao <xiaolinkui@kylinos.cn>.
v2: synchronize_rcu() is moved into ip_set_swap() in order not to burden
ip_set_destroy() unnecessarily when all sets are destroyed.
v3: Florian Westphal pointed out that all netfilter hooks run with rcu_read_lock() held
and em_ipset.c wraps the entire ip_set_test() in rcu read lock/unlock pair.
So there's no need to extend the rcu read locked area in ipset itself.
Closes: https://lore.kernel.org/all/69e7963b-e7f8-3ad0-210-7b86eebf7f78@netfilter.org/
Reported by: Linkui Xiao <xiaolinkui@kylinos.cn>
Signed-off-by: Jozsef Kadlecsik <kadlec@netfilter.org>
[ Upstream commit e2b706c691905fe78468c361aaabc719d0a496f1 ]
When I perform the following test operations:
1.ip link add br0 type bridge
2.brctl addif br0 eth0
3.ip addr add 239.0.0.1/32 dev eth0
4.ip addr add 239.0.0.1/32 dev br0
5.ip addr add 224.0.0.1/32 dev br0
6.while ((1))
do
ifconfig br0 up
ifconfig br0 down
done
7.send IGMPv2 query packets to port eth0 continuously. For example,
./mausezahn ethX -c 0 "01 00 5e 00 00 01 00 72 19 88 aa 02 08 00 45 00 00
1c 00 01 00 00 01 02 0e 7f c0 a8 0a b7 e0 00 00 01 11 64 ee 9b 00 00 00 00"
The preceding tests may trigger the refcnt uaf issue of the mc list. The
stack is as follows:
refcount_t: addition on 0; use-after-free.
WARNING: CPU: 21 PID: 144 at lib/refcount.c:25 refcount_warn_saturate (lib/refcount.c:25)
CPU: 21 PID: 144 Comm: ksoftirqd/21 Kdump: loaded Not tainted 6.7.0-rc1-next-20231117-dirty #80
Hardware name: Red Hat KVM, BIOS 0.5.1 01/01/2011
RIP: 0010:refcount_warn_saturate (lib/refcount.c:25)
RSP: 0018:ffffb68f00657910 EFLAGS: 00010286
RAX: 0000000000000000 RBX: ffff8a00c3bf96c0 RCX: ffff8a07b6160908
RDX: 00000000ffffffd8 RSI: 0000000000000027 RDI: ffff8a07b6160900
RBP: ffff8a00cba36862 R08: 0000000000000000 R09: 00000000ffff7fff
R10: ffffb68f006577c0 R11: ffffffffb0fdcdc8 R12: ffff8a00c3bf9680
R13: ffff8a00c3bf96f0 R14: 0000000000000000 R15: ffff8a00d8766e00
FS: 0000000000000000(0000) GS:ffff8a07b6140000(0000) knlGS:0000000000000000
CR2: 000055f10b520b28 CR3: 000000039741a000 CR4: 00000000000006f0
Call Trace:
<TASK>
igmp_heard_query (net/ipv4/igmp.c:1068)
igmp_rcv (net/ipv4/igmp.c:1132)
ip_protocol_deliver_rcu (net/ipv4/ip_input.c:205)
ip_local_deliver_finish (net/ipv4/ip_input.c:234)
__netif_receive_skb_one_core (net/core/dev.c:5529)
netif_receive_skb_internal (net/core/dev.c:5729)
netif_receive_skb (net/core/dev.c:5788)
br_handle_frame_finish (net/bridge/br_input.c:216)
nf_hook_bridge_pre (net/bridge/br_input.c:294)
__netif_receive_skb_core (net/core/dev.c:5423)
__netif_receive_skb_list_core (net/core/dev.c:5606)
__netif_receive_skb_list (net/core/dev.c:5674)
netif_receive_skb_list_internal (net/core/dev.c:5764)
napi_gro_receive (net/core/gro.c:609)
e1000_clean_rx_irq (drivers/net/ethernet/intel/e1000/e1000_main.c:4467)
e1000_clean (drivers/net/ethernet/intel/e1000/e1000_main.c:3805)
__napi_poll (net/core/dev.c:6533)
net_rx_action (net/core/dev.c:6735)
__do_softirq (kernel/softirq.c:554)
run_ksoftirqd (kernel/softirq.c:913)
smpboot_thread_fn (kernel/smpboot.c:164)
kthread (kernel/kthread.c:388)
ret_from_fork (arch/x86/kernel/process.c:153)
ret_from_fork_asm (arch/x86/entry/entry_64.S:250)
</TASK>
The root causes are as follows:
Thread A Thread B
... netif_receive_skb
br_dev_stop ...
br_multicast_leave_snoopers ...
__ip_mc_dec_group ...
__igmp_group_dropped igmp_rcv
igmp_stop_timer igmp_heard_query //ref = 1
ip_ma_put igmp_mod_timer
refcount_dec_and_test igmp_start_timer //ref = 0
... refcount_inc //ref increases from 0
When the device receives an IGMPv2 Query message, it starts the timer
immediately, regardless of whether the device is running. If the device is
down and has left the multicast group, it will cause the mc list refcount
uaf issue.
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Signed-off-by: Zhengchao Shao <shaozhengchao@huawei.com>
Reviewed-by: Hangbin Liu <liuhangbin@gmail.com>
[ Upstream commit c0e2926266af3b5acf28df0a8fc6e4d90effe0bb ]
net/ipv4/route.c:783:46: warning: incorrect type in argument 2 (different base types)
net/ipv4/route.c:783:46: expected unsigned int [usertype] key
net/ipv4/route.c:783:46: got restricted __be32 [usertype] new_gw
Fixes: 969447f226b4 ("ipv4: use new_gw for redirect neigh lookup")
Suggested-by: Eric Dumazet <edumazet@google.com>
Signed-off-by: Kunwu Chan <chentao@kylinos.cn>
Link: https://lore.kernel.org/r/20231119141759.420477-1-chentao@kylinos.cn
3f0465a9ef02 ("netfilter: nf_tables: dynamically allocate hooks per
net_device in flowtables") reworks flowtable support to allow for
dynamic allocation of hooks, which implicitly fixes the following
bogus EBUSY in transaction:
delete flowtable
add flowtable # same flowtable with same devices, it hits EBUSY
This patch does not exist in any tree, but it fixes this issue for
-stable Linux kernel 5.4
commit c9bd26513b3a11b3adb3c2ed8a31a01a87173ff1 upstream.
nft -f -<<EOF
add table ip t
add table ip t { flags dormant; }
add chain ip t c { type filter hook input priority 0; }
add table ip t
EOF
Triggers a splat from nf core on next table delete because we lose
track of right hook register state:
WARNING: CPU: 2 PID: 1597 at net/netfilter/core.c:501 __nf_unregister_net_hook
RIP: 0010:__nf_unregister_net_hook+0x41b/0x570
nf_unregister_net_hook+0xb4/0xf0
__nf_tables_unregister_hook+0x160/0x1d0
The above should have table in *active* state, but in fact no
hooks were registered.
Reject on/off/on games rather than attempting to fix this.
Fixes: 179d9ba5559a ("netfilter: nf_tables: fix table flag updates")
Reported-by: "Lee, Cherie-Anne" <cherie.lee@starlabs.sg>
Cc: Bing-Jhong Billy Jheng <billy@starlabs.sg>
Cc: info@starlabs.sg
commit 179d9ba5559a756f4322583388b3213fe4e391b0 upstream.
The dormant flag need to be updated from the preparation phase,
otherwise, two consecutive requests to dorm a table in the same batch
might try to remove the same hooks twice, resulting in the following
warning:
hook not found, pf 3 num 0
WARNING: CPU: 0 PID: 334 at net/netfilter/core.c:480 __nf_unregister_net_hook+0x1eb/0x610 net/netfilter/core.c:480
Modules linked in:
CPU: 0 PID: 334 Comm: kworker/u4:5 Not tainted 5.12.0-syzkaller #0
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Workqueue: netns cleanup_net
RIP: 0010:__nf_unregister_net_hook+0x1eb/0x610 net/netfilter/core.c:480
This patch is a partial revert of 0ce7cf4127f1 ("netfilter: nftables:
update table flags from the commit phase") to restore the previous
behaviour.
However, there is still another problem: A batch containing a series of
dorm-wakeup-dorm table and vice-versa also trigger the warning above
since hook unregistration happens from the preparation phase, while hook
registration occurs from the commit phase.
To fix this problem, this patch adds two internal flags to annotate the
original dormant flag status which are __NFT_TABLE_F_WAS_DORMANT and
__NFT_TABLE_F_WAS_AWAKEN, to restore it from the abort path.
The __NFT_TABLE_F_UPDATE bitmask allows to handle the dormant flag update
with one single transaction.
Reported-by: syzbot+7ad5cd1615f2d89c6e7e@syzkaller.appspotmail.com
Fixes: 0ce7cf4127f1 ("netfilter: nftables: update table flags from the commit phase")
commit 0ce7cf4127f14078ca598ba9700d813178a59409 upstream.
Do not update table flags from the preparation phase. Store the flags
update into the transaction, then update the flags from the commit
phase.
commit f9a43007d3f7ba76d5e7f9421094f00f2ef202f8 upstream.
__nft_release_hooks() is called from pre_netns exit path which
unregisters the hooks, then the NETDEV_UNREGISTER event is triggered
which unregisters the hooks again.
[ 565.221461] WARNING: CPU: 18 PID: 193 at net/netfilter/core.c:495 __nf_unregister_net_hook+0x247/0x270
[ 565.246890] CPU: 18 PID: 193 Comm: kworker/u64:1 Tainted: G E 5.18.0-rc7+ #27
[ 565.253682] Workqueue: netns cleanup_net
[ 565.257059] RIP: 0010:__nf_unregister_net_hook+0x247/0x270
[ 565.297120] Call Trace:
[ 565.300900] <TASK>
[ 565.304683] nf_tables_flowtable_event+0x16a/0x220 [nf_tables]
[ 565.308518] raw_notifier_call_chain+0x63/0x80
[ 565.312386] unregister_netdevice_many+0x54f/0xb50
Unregister and destroy netdev hook from netns pre_exit via kfree_rcu
so the NETDEV_UNREGISTER path see unregistered hooks.
Fixes: 767d1216bff8 ("netfilter: nftables: fix possible UAF over chains from packet path in netns")
commit 6069da443bf65f513bb507bb21e2f87cfb1ad0b6 upstream.
Unregister flowtable hooks before they are releases via
nf_tables_flowtable_destroy() otherwise hook core reports UAF.
BUG: KASAN: use-after-free in nf_hook_entries_grow+0x5a7/0x700 net/netfilter/core.c:142 net/netfilter/core.c:142
Read of size 4 at addr ffff8880736f7438 by task syz-executor579/3666
CPU: 0 PID: 3666 Comm: syz-executor579 Not tainted 5.16.0-rc5-syzkaller #0
Call Trace:
<TASK>
__dump_stack lib/dump_stack.c:88 [inline]
__dump_stack lib/dump_stack.c:88 [inline] lib/dump_stack.c:106
dump_stack_lvl+0x1dc/0x2d8 lib/dump_stack.c:106 lib/dump_stack.c:106
print_address_description+0x65/0x380 mm/kasan/report.c:247 mm/kasan/report.c:247
__kasan_report mm/kasan/report.c:433 [inline]
__kasan_report mm/kasan/report.c:433 [inline] mm/kasan/report.c:450
kasan_report+0x19a/0x1f0 mm/kasan/report.c:450 mm/kasan/report.c:450
__nf_register_net_hook+0x27e/0x8d0 net/netfilter/core.c:429 net/netfilter/core.c:429
nf_register_net_hook+0xaa/0x180 net/netfilter/core.c:571 net/netfilter/core.c:571
nft_register_flowtable_net_hooks+0x3c5/0x730 net/netfilter/nf_tables_api.c:7232 net/netfilter/nf_tables_api.c:7232
nf_tables_newflowtable+0x2022/0x2cf0 net/netfilter/nf_tables_api.c:7430 net/netfilter/nf_tables_api.c:7430
nfnetlink_rcv_batch net/netfilter/nfnetlink.c:513 [inline]
nfnetlink_rcv_skb_batch net/netfilter/nfnetlink.c:634 [inline]
nfnetlink_rcv_batch net/netfilter/nfnetlink.c:513 [inline] net/netfilter/nfnetlink.c:652
nfnetlink_rcv_skb_batch net/netfilter/nfnetlink.c:634 [inline] net/netfilter/nfnetlink.c:652
nfnetlink_rcv+0x10e6/0x2550 net/netfilter/nfnetlink.c:652 net/netfilter/nfnetlink.c:652
__nft_release_hook() calls nft_unregister_flowtable_net_hooks() which
only unregisters the hooks, then after RCU grace period, it is
guaranteed that no packets add new entries to the flowtable (no flow
offload rules and flowtable hooks are reachable from packet path), so it
is safe to call nf_flow_table_free() which cleans up the remaining
entries from the flowtable (both software and hardware) and it unbinds
the flow_block.
Fixes: ff4bf2f42a40 ("netfilter: nf_tables: add nft_unregister_flowtable_hook()")
Reported-by: syzbot+e918523f77e62790d6d9@syzkaller.appspotmail.com
commit cf5000a7787cbc10341091d37245a42c119d26c5 upstream.
When more than 255 elements expired we're supposed to switch to a new gc
container structure.
This never happens: u8 type will wrap before reaching the boundary
and nft_trans_gc_space() always returns true.
This means we recycle the initial gc container structure and
lose track of the elements that came before.
While at it, don't deref 'gc' after we've passed it to call_rcu.
Fixes: 5f68718b34a5 ("netfilter: nf_tables: GC transaction API to avoid race with control plane")
Reported-by: Pablo Neira Ayuso <pablo@netfilter.org>
commit b079155faae94e9b3ab9337e82100a914ebb4e8d upstream.
Skip GC run if iterator rewinds to the beginning with EAGAIN, otherwise GC
might collect the same element more than once.
Fixes: f6c383b8c31a ("netfilter: nf_tables: adapt set backend to use GC transaction API")
commit 96b33300fba880ec0eafcf3d82486f3463b4b6da upstream.
rbtree GC does not modify the datastructure, instead it collects expired
elements and it enqueues a GC transaction. Use a read spinlock instead
to avoid data contention while GC worker is running.
commit 2ee52ae94baabf7ee09cf2a8d854b990dac5d0e4 upstream.
New elements in this transaction might expired before such transaction
ends. Skip sync GC for such elements otherwise commit path might walk
over an already released object. Once transaction is finished, async GC
will collect such expired element.
commit 8e51830e29e12670b4c10df070a4ea4c9593e961 upstream.
Don't queue more gc work, else we may queue the same elements multiple
times.
If an element is flagged as dead, this can mean that either the previous
gc request was invalidated/discarded by a transaction or that the previous
request is still pending in the system work queue.
The latter will happen if the gc interval is set to a very low value,
e.g. 1ms, and system work queue is backlogged.
The sets refcount is 1 if no previous gc requeusts are queued, so add
a helper for this and skip gc run if old requests are pending.
Add a helper for this and skip the gc run in this case.
commit 8357bc946a2abc2a10ca40e5a2105d2b4c57515e upstream.
Use nf_tables_gc_list_lock spinlock, not nf_tables_destroy_list_lock to
protect the gc_list.
commit 720344340fb9be2765bbaab7b292ece0a4570eae upstream.
Abort path is missing a synchronization point with GC transactions. Add
GC sequence number hence any GC transaction losing race will be
discarded.
commit 02c6c24402bf1c1e986899c14ba22a10b510916b upstream.
Use maybe_get_net() since GC workqueue might race with netns exit path.
exit path
commit 6a33d8b73dfac0a41f3877894b38082bd0c9a5bc upstream.
Netlink event path is missing a synchronization point with GC
transactions. Add GC sequence number update to netns release path and
netlink event path, any GC transaction losing race will be discarded.
commit a2dd0233cbc4d8a0abb5f64487487ffc9265beb5 upstream.
Ditch it, it has been replace it by the GC transaction API and it has no
clients anymore.
commit c92db3030492b8ad1d0faace7a93bbcf53850d0c upstream.
Set on the NFT_SET_ELEM_DEAD_BIT flag on this element, instead of
performing element removal which might race with an ongoing transaction.
Enable gc when dynamic flag is set on since dynset deletion requires
garbage collection after this patch.
Fixes: d0a8d877da97 ("netfilter: nft_dynset: support for element deletion")
commit f6c383b8c31a93752a52697f8430a71dcbc46adf upstream.
Use the GC transaction API to replace the old and buggy gc API and the
busy mark approach.
No set elements are removed from async garbage collection anymore,
instead the _DEAD bit is set on so the set element is not visible from
lookup path anymore. Async GC enqueues transaction work that might be
aborted and retried later.
rbtree and pipapo set backends does not set on the _DEAD bit from the
sync GC path since this runs in control plane path where mutex is held.
In this case, set elements are deactivated, removed and then released
via RCU callback, sync GC never fails.
Fixes: 3c4287f62044 ("nf_tables: Add set type for arbitrary concatenation of ranges")
Fixes: 8d8540c4f5e0 ("netfilter: nft_set_rbtree: add timeout support")
Fixes: 9d0982927e79 ("netfilter: nft_hash: add support for timeouts")
commit 5f68718b34a531a556f2f50300ead2862278da26 upstream.
The set types rhashtable and rbtree use a GC worker to reclaim memory.
>From system work queue, in periodic intervals, a scan of the table is
done.
The major caveat here is that the nft transaction mutex is not held.
This causes a race between control plane and GC when they attempt to
delete the same element.
We cannot grab the netlink mutex from the work queue, because the
control plane has to wait for the GC work queue in case the set is to be
removed, so we get following deadlock:
cpu 1 cpu2
GC work transaction comes in , lock nft mutex
`acquire nft mutex // BLOCKS
transaction asks to remove the set
set destruction calls cancel_work_sync()
cancel_work_sync will now block forever, because it is waiting for the
mutex the caller already owns.
This patch adds a new API that deals with garbage collection in two
steps:
1) Lockless GC of expired elements sets on the NFT_SET_ELEM_DEAD_BIT
so they are not visible via lookup. Annotate current GC sequence in
the GC transaction. Enqueue GC transaction work as soon as it is
full. If ruleset is updated, then GC transaction is aborted and
retried later.
2) GC work grabs the mutex. If GC sequence has changed then this GC
transaction lost race with control plane, abort it as it contains
stale references to objects and let GC try again later. If the
ruleset is intact, then this GC transaction deactivates and removes
the elements and it uses call_rcu() to destroy elements.
Note that no elements are removed from GC lockless path, the _DEAD bit
is set and pointers are collected. GC catchall does not remove the
elements anymore too. There is a new set->dead flag that is set on to
abort the GC transaction to deal with set->ops->destroy() path which
removes the remaining elements in the set from commit_release, where no
mutex is held.
To deal with GC when mutex is held, which allows safe deactivate and
removal, add sync GC API which releases the set element object via
call_rcu(). This is used by rbtree and pipapo backends which also
perform garbage collection from control plane path.
Since element removal from sets can happen from control plane and
element garbage collection/timeout, it is necessary to keep the set
structure alive until all elements have been deactivated and destroyed.
We cannot do a cancel_work_sync or flush_work in nft_set_destroy because
its called with the transaction mutex held, but the aforementioned async
work queue might be blocked on the very mutex that nft_set_destroy()
callchain is sitting on.
This gives us the choice of ABBA deadlock or UaF.
To avoid both, add set->refs refcount_t member. The GC API can then
increment the set refcount and release it once the elements have been
free'd.
Set backends are adapted to use the GC transaction API in a follow up
patch entitled:
("netfilter: nf_tables: use gc transaction API in set backends")
This is joint work with Florian Westphal.
Fixes: cfed7e1b1f8e ("netfilter: nf_tables: add set garbage collection helpers")
commit 24138933b97b055d486e8064b4a1721702442a9b upstream.
There is an asymmetry between commit/abort and preparation phase if the
following conditions are met:
1. set is a verdict map ("1.2.3.4 : jump foo")
2. timeouts are enabled
In this case, following sequence is problematic:
1. element E in set S refers to chain C
2. userspace requests removal of set S
3. kernel does a set walk to decrement chain->use count for all elements
from preparation phase
4. kernel does another set walk to remove elements from the commit phase
(or another walk to do a chain->use increment for all elements from
abort phase)
If E has already expired in 1), it will be ignored during list walk, so its use count
won't have been changed.
Then, when set is culled, ->destroy callback will zap the element via
nf_tables_set_elem_destroy(), but this function is only safe for
elements that have been deactivated earlier from the preparation phase:
lack of earlier deactivate removes the element but leaks the chain use
count, which results in a WARN splat when the chain gets removed later,
plus a leak of the nft_chain structure.
Update pipapo_get() not to skip expired elements, otherwise flush
command reports bogus ENOENT errors.
commit f718863aca469a109895cb855e6b81fff4827d71 upstream.
The lazy gc on insert that should remove timed-out entries fails to release
the other half of the interval, if any.
Can be reproduced with tests/shell/testcases/sets/0044interval_overlap_0
in nftables.git and kmemleak enabled kernel.
Second bug is the use of rbe_prev vs. prev pointer.
If rbe_prev() returns NULL after at least one iteration, rbe_prev points
to element that is not an end interval, hence it should not be removed.
Lastly, check the genmask of the end interval if this is active in the
current generation.
Fixes: c9e6978e2725 ("netfilter: nft_set_rbtree: Switch to node list walk for overlap detection")
commit 61ae320a29b0540c16931816299eb86bf2b66c08 upstream.
There is no guarantee that rb_prev() will not return NULL in nft_rbtree_gc_elem():
general protection fault, probably for non-canonical address 0xdffffc0000000003: 0000 [#1] PREEMPT SMP KASAN
KASAN: null-ptr-deref in range [0x0000000000000018-0x000000000000001f]
nft_add_set_elem+0x14b0/0x2990
nf_tables_newsetelem+0x528/0xb30
Furthermore, there is a possible use-after-free while iterating,
'node' can be free'd so we need to cache the next value to use.
commit c9e6978e2725a7d4b6cd23b2facd3f11422c0643 upstream.
...instead of a tree descent, which became overly complicated in an
attempt to cover cases where expired or inactive elements would affect
comparisons with the new element being inserted.
Further, it turned out that it's probably impossible to cover all those
cases, as inactive nodes might entirely hide subtrees consisting of a
complete interval plus a node that makes the current insertion not
overlap.
To speed up the overlap check, descent the tree to find a greater
element that is closer to the key value to insert. Then walk down the
node list for overlap detection. Starting the overlap check from
rb_first() unconditionally is slow, it takes 10 times longer due to the
full linear traversal of the list.
Moreover, perform garbage collection of expired elements when walking
down the node list to avoid bogus overlap reports.
For the insertion operation itself, this essentially reverts back to the
implementation before commit 7c84d41416d8 ("netfilter: nft_set_rbtree:
Detect partial overlaps on insertion"), except that cases of complete
overlap are already handled in the overlap detection phase itself, which
slightly simplifies the loop to find the insertion point.
Based on initial patch from Stefano Brivio, including text from the
original patch description too.
Fixes: 7c84d41416d8 ("netfilter: nft_set_rbtree: Detect partial overlaps on insertion")
Reviewed-by: Stefano Brivio <sbrivio@redhat.com>
commit 628bd3e49cba1c066228e23d71a852c23e26da73 upstream.
set .destroy callback releases the references to other objects in maps.
This is very late and it results in spurious EBUSY errors. Drop refcount
from the preparation phase instead, update set backend not to drop
reference counter from set .destroy path.
Exceptions: NFT_TRANS_PREPARE_ERROR does not require to drop the
reference counter because the transaction abort path releases the map
references for each element since the set is unbound. The abort path
also deals with releasing reference counter for new elements added to
unbound sets.
Fixes: 591054469b3e ("netfilter: nf_tables: revisit chain/object refcounting from elements")
commit f8bb7889af58d8e74d2d61c76b1418230f1610fa upstream.
Rename:
- nft_set_elem_activate() to nft_set_elem_data_activate().
- nft_set_elem_deactivate() to nft_set_elem_data_deactivate().
To prepare for updates in the set element infrastructure to add support
for the special catch-all element.
commit 0c2a85edd143162b3a698f31e94bf8cdc041da87 upstream.
The patch that adds support for stateful expressions in set definitions
require this.
commit 9e2e7efbbbff69d8340abb56d375dd79d1f5770f upstream.
This reverts commit 3780bb29311eccb7a1c9641032a112eed237f7e3.
The cited commit introduced unwanted behavior.
The intent for the commit was to be able to detect carrier loss/gain
for just the NIC connected to the BMC. The unwanted effect is a
carrier loss for auxiliary paths also causes the BMC to lose
carrier. The BMC never regains carrier despite the secondary NIC
regaining a link.
This change, when merged, needs to be backported to stable kernels.
5.4-stable, 5.10-stable, 5.15-stable, 6.1-stable, 6.5-stable
Fixes: 3780bb29311e ("ncsi: Propagate carrier gain/loss events to the NCSI controller")
CC: stable@vger.kernel.org
Signed-off-by: Johnathan Mantey <johnathanx.mantey@intel.com>
Reviewed-by: Simon Horman <horms@kernel.org>
[ Upstream commit a44af08e3d4d7566eeea98d7a29fe06e7b9de944 ]
K2CI reported a problem:
consume_skb(skb);
return err;
[nf_br_ip_fragment() error] uninitialized symbol 'err'.
err is not initialized, because returning 0 is expected, initialize err
to 0.
Fixes: 3c171f496ef5 ("netfilter: bridge: add connection tracking system")
Reported-by: k2ci <kernel-bot@kylinos.cn>
Signed-off-by: Linkui Xiao <xiaolinkui@kylinos.cn>
[ Upstream commit fb317eb23b5ee4c37b0656a9a52a3db58d9dd072 ]
KMSAN reported the following kernel-infoleak issue:
BUG: KMSAN: kernel-infoleak in instrument_copy_to_user include/linux/instrumented.h:114 [inline]
BUG: KMSAN: kernel-infoleak in copy_to_user_iter lib/iov_iter.c:24 [inline]
BUG: KMSAN: kernel-infoleak in iterate_ubuf include/linux/iov_iter.h:29 [inline]
BUG: KMSAN: kernel-infoleak in iterate_and_advance2 include/linux/iov_iter.h:245 [inline]
BUG: KMSAN: kernel-infoleak in iterate_and_advance include/linux/iov_iter.h:271 [inline]
BUG: KMSAN: kernel-infoleak in _copy_to_iter+0x4ec/0x2bc0 lib/iov_iter.c:186
copy_to_iter include/linux/uio.h:197 [inline]
simple_copy_to_iter net/core/datagram.c:532 [inline]
__skb_datagram_iter.5+0x148/0xe30 net/core/datagram.c:420
skb_copy_datagram_iter+0x52/0x210 net/core/datagram.c:546
skb_copy_datagram_msg include/linux/skbuff.h:3960 [inline]
netlink_recvmsg+0x43d/0x1630 net/netlink/af_netlink.c:1967
sock_recvmsg_nosec net/socket.c:1044 [inline]
sock_recvmsg net/socket.c:1066 [inline]
__sys_recvfrom+0x476/0x860 net/socket.c:2246
__do_sys_recvfrom net/socket.c:2264 [inline]
__se_sys_recvfrom net/socket.c:2260 [inline]
__x64_sys_recvfrom+0x130/0x200 net/socket.c:2260
do_syscall_64+0x44/0x110 arch/x86/entry/common.c:82
entry_SYSCALL_64_after_hwframe+0x63/0x6b
Uninit was created at:
slab_post_alloc_hook+0x103/0x9e0 mm/slab.h:768
slab_alloc_node mm/slub.c:3478 [inline]
kmem_cache_alloc_node+0x5f7/0xb50 mm/slub.c:3523
kmalloc_reserve+0x13c/0x4a0 net/core/skbuff.c:560
__alloc_skb+0x2fd/0x770 net/core/skbuff.c:651
alloc_skb include/linux/skbuff.h:1286 [inline]
tipc_tlv_alloc net/tipc/netlink_compat.c:156 [inline]
tipc_get_err_tlv+0x90/0x5d0 net/tipc/netlink_compat.c:170
tipc_nl_compat_recv+0x1042/0x15d0 net/tipc/netlink_compat.c:1324
genl_family_rcv_msg_doit net/netlink/genetlink.c:972 [inline]
genl_family_rcv_msg net/netlink/genetlink.c:1052 [inline]
genl_rcv_msg+0x1220/0x12c0 net/netlink/genetlink.c:1067
netlink_rcv_skb+0x4a4/0x6a0 net/netlink/af_netlink.c:2545
genl_rcv+0x41/0x60 net/netlink/genetlink.c:1076
netlink_unicast_kernel net/netlink/af_netlink.c:1342 [inline]
netlink_unicast+0xf4b/0x1230 net/netlink/af_netlink.c:1368
netlink_sendmsg+0x1242/0x1420 net/netlink/af_netlink.c:1910
sock_sendmsg_nosec net/socket.c:730 [inline]
__sock_sendmsg net/socket.c:745 [inline]
____sys_sendmsg+0x997/0xd60 net/socket.c:2588
___sys_sendmsg+0x271/0x3b0 net/socket.c:2642
__sys_sendmsg net/socket.c:2671 [inline]
__do_sys_sendmsg net/socket.c:2680 [inline]
__se_sys_sendmsg net/socket.c:2678 [inline]
__x64_sys_sendmsg+0x2fa/0x4a0 net/socket.c:2678
Bytes 34-35 of 36 are uninitialized
Memory access of size 36 starts at ffff88802d464a00
Data copied to user address 00007ff55033c0a0
CPU: 0 PID: 30322 Comm: syz-executor.0 Not tainted 6.6.0-14500-g1c41041124bd #10
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.16.2-1.fc38 04/01/2014
tipc_add_tlv() puts TLV descriptor and value onto `skb`. This size is
calculated with TLV_SPACE() macro. It adds the size of struct tlv_desc and
the length of TLV value passed as an argument, and aligns the result to a
multiple of TLV_ALIGNTO, i.e., a multiple of 4 bytes.
If the size of struct tlv_desc plus the length of TLV value is not aligned,
the current implementation leaves the remaining bytes uninitialized. This
is the cause of the above kernel-infoleak issue.
This patch resolves this issue by clearing data up to an aligned size.
Fixes: d0796d1ef63d ("tipc: convert legacy nl bearer dump to nl compat")
[ Upstream commit a85fb91e3d728bdfc80833167e8162cce8bc7004 ]
syzbot reports a slab use-after-free in hci_conn_hash_flush [1].
After releasing an object using hci_conn_del_sysfs in the
hci_conn_cleanup function, releasing the same object again
using the hci_dev_put and hci_conn_put functions causes a double free.
Here's a simplified flow:
hci_conn_del_sysfs:
hci_dev_put
put_device
kobject_put
kref_put
kobject_release
kobject_cleanup
kfree_const
kfree(name)
hci_dev_put:
kfree(name)
hci_conn_put:
put_device
kfree(name)
This patch drop the hci_dev_put and hci_conn_put function
call in hci_conn_cleanup function, because the object is
freed in hci_conn_del_sysfs function.
This patch also fixes the refcounting in hci_conn_add_sysfs() and
hci_conn_del_sysfs() to take into account device_add() failures.
This fixes CVE-2023-28464.
Link: https://syzkaller.appspot.com/bug?id=1bb51491ca5df96a5f724899d1dbb87afda61419 [1]
Signed-off-by: ZhengHan Wang <wzhmmmmm@gmail.com>
Co-developed-by: Luiz Augusto von Dentz <luiz.von.dentz@intel.com>
Signed-off-by: Luiz Augusto von Dentz <luiz.von.dentz@intel.com>
[ Upstream commit eb44ad4e635132754bfbcb18103f1dcb7058aedd ]
This field can be read or written without socket lock being held.
Add annotations to avoid load-store tearing.
[ Upstream commit e160ab85166e77347d0cbe5149045cb25e83937f ]
We can get a UBSAN warning if ieee80211_get_tx_power() returns the
INT_MIN value mac80211 internally uses for "unset power level".
UBSAN: signed-integer-overflow in net/wireless/nl80211.c:3816:5
-2147483648 * 100 cannot be represented in type 'int'
CPU: 0 PID: 20433 Comm: insmod Tainted: G WC OE
Call Trace:
dump_stack+0x74/0x92
ubsan_epilogue+0x9/0x50
handle_overflow+0x8d/0xd0
__ubsan_handle_mul_overflow+0xe/0x10
nl80211_send_iface+0x688/0x6b0 [cfg80211]
cfg80211_register_wdev+0x78/0xb0 [cfg80211]
cfg80211_netdev_notifier_call+0x200/0x620 [cfg80211]
ieee80211_if_add+0x60e/0x8f0 [mac80211]
ieee80211_register_hw+0xda5/0x1170 [mac80211]
In this case, simply return an error instead, to indicate
that no data is available.
Cc: Zong-Zhe Yang <kevin_yang@realtek.com>
Signed-off-by: Ping-Ke Shih <pkshih@realtek.com>
Link: https://lore.kernel.org/r/20230203023636.4418-1-pkshih@realtek.com
[ Upstream commit 80abbe8a8263106fe45a4f293b92b5c74cc9cc8a ]
The ipv6 redirect target was derived from the ipv4 one, i.e. its
identical to a 'dnat' with the first (primary) address assigned to the
network interface. The code has been moved around to make it usable
from nf_tables too, but its still the same as it was back when this
was added in 2012.
IPv6, however, has different types of addresses, if the 'wrong' address
comes first the redirection does not work.
In Daniels case, the addresses are:
inet6 ::ffff:192 ...
inet6 2a01: ...
... so the function attempts to redirect to the mapped address.
Add more checks before the address is deemed correct:
1. If the packets' daddr is scoped, search for a scoped address too
2. skip tentative addresses
3. skip mapped addresses
Use the first address that appears to match our needs.
Reported-by: Daniel Huhardeaux <tech@tootai.net>
Closes: https://lore.kernel.org/netfilter/71be06b8-6aa0-4cf9-9e0b-e2839b01b22f@tootai.net/
Fixes: 115e23ac78f8 ("netfilter: ip6tables: add REDIRECT target")
eval call-backs
[ Upstream commit 6f56ad1b92328997e1b1792047099df6f8d7acb5 ]
`nf_nat_redirect_ipv4` takes a `struct nf_nat_ipv4_multi_range_compat`,
but converts it internally to a `struct nf_nat_range2`. Change the
function to take the latter, factor out the code now shared with
`nf_nat_redirect_ipv6`, move the conversion to the xt_REDIRECT module,
and update the ipv4 range initialization in the nft_redir module.
Replace a bare hex constant for 127.0.0.1 with a macro.
Remove `WARN_ON`. `nf_nat_setup_info` calls `nf_ct_is_confirmed`:
/* Can't setup nat info for confirmed ct. */
if (nf_ct_is_confirmed(ct))
return NF_ACCEPT;
This means that `ct` cannot be null or the kernel will crash, and
implies that `ctinfo` is `IP_CT_NEW` or `IP_CT_RELATED`.
nft_redir has separate ipv4 and ipv6 call-backs which share much of
their code, and an inet one switch containing a switch that calls one of
the others based on the family of the packet. Merge the ipv4 and ipv6
ones into the inet one in order to get rid of the duplicate code.
Const-qualify the `priv` pointer since we don't need to write through
it.
Assign `priv->flags` to the range instead of OR-ing it in.
Set the `NF_NAT_RANGE_PROTO_SPECIFIED` flag once during init, rather
than on every eval.
Signed-off-by: Jeremy Sowden <jeremy@azazel.net>
Stable-dep-of: 80abbe8a8263 ("netfilter: nat: fix ipv6 nat redirect with mapped and scoped addresses")
[ Upstream commit 7b308feb4fd2d1c06919445c65c8fbf8e9fd1781 ]
in6_pton() supports 'low-32-bit dot-decimal representation'
(this is useful with DNS64/NAT64 networks for example):
# echo +aaaa:bbbb:cccc:dddd:eeee:ffff:1.2.3.4 > /proc/self/net/xt_recent/DEFAULT
# cat /proc/self/net/xt_recent/DEFAULT
src=aaaa:bbbb:cccc:dddd:eeee:ffff:0102:0304 ttl: 0 last_seen: 9733848829 oldest_pkt: 1 9733848829
but the provided buffer is too short:
# echo +aaaa:bbbb:cccc:dddd:eeee:ffff:255.255.255.255 > /proc/self/net/xt_recent/DEFAULT
-bash: echo: write error: Invalid argument
Fixes: 079aa88fe717 ("netfilter: xt_recent: IPv6 support")
Signed-off-by: Maciej Żenczykowski <zenczykowski@gmail.com>
