path: root/net
2010-01-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (56 commits) sky2: Fix oops in sky2_xmit_frame() after TX timeout Documentation/3c509: document ethtool support af_packet: Don't use skb after dev_queue_xmit() vxge: use pci_dma_mapping_error to test return value netfilter: ebtables: enforce CAP_NET_ADMIN e1000e: fix and commonize code for setting the receive address registers e1000e: e1000e_enable_tx_pkt_filtering() returns wrong value e1000e: perform 10/100 adaptive IFS only on parts that support it e1000e: don't accumulate PHY statistics on PHY read failure e1000e: call pci_save_state() after pci_restore_state() netxen: update version to 4.0.72 netxen: fix set mac addr netxen: fix smatch warning netxen: fix tx ring memory leak tcp: update the netstamp_needed counter when cloning sockets TI DaVinci EMAC: Handle emac module clock correctly. dmfe/tulip: Let dmfe handle DM910x except for SPARC on-board chips ixgbe: Fix compiler warning about variable being used uninitialized netfilter: nf_ct_ftp: fix out of bounds read in update_nl_seq() mv643xx_eth: don't include cache padding in rx desc buffer size ... Fix trivial conflict in drivers/scsi/cxgb3i/cxgb3i_offload.c
2010-01-11af_packet: Don't use skb after dev_queue_xmit()Jarek Poplawski
tpacket_snd() can change and kfree an skb after dev_queue_xmit(), which is illegal. With debugging by: Stephen Hemminger <shemminger@vyatta.com> Reported-by: Michael Breuer <mbreuer@majjas.com> With help from: David S. Miller <davem@davemloft.net> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Tested-by: Michael Breuer<mbreuer@majjas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-08Merge branch 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: nfs: fix oops in nfs_rename() sunrpc: fix build-time warning sunrpc: on successful gss error pipe write, don't return error SUNRPC: Fix the return value in gss_import_sec_context() SUNRPC: Fix up an error return value in gss_import_sec_context_kerberos()
2010-01-08Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-2.6
2010-01-08netfilter: ebtables: enforce CAP_NET_ADMINFlorian Westphal
normal users are currently allowed to set/modify ebtables rules. Restrict it to processes with CAP_NET_ADMIN. Note that this cannot be reproduced with unmodified ebtables binary because it uses SOCK_RAW. Signed-off-by: Florian Westphal <fwestphal@astaro.com> Cc: stable@kernel.org Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-01-08tcp: update the netstamp_needed counter when cloning socketsOctavian Purdila
This fixes a netstamp_needed accounting issue when the listen socket has SO_TIMESTAMP set: s = socket(AF_INET, SOCK_STREAM, 0); setsockopt(s, SOL_SOCKET, SO_TIMESTAMP, 1); -> netstamp_needed = 1 bind(s, ...); listen(s, ...); s2 = accept(s, ...); -> netstamp_needed = 1 close(s2); -> netstamp_needed = 0 close(s); -> netstamp_needed = -1 Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07netfilter: nf_ct_ftp: fix out of bounds read in update_nl_seq()Patrick McHardy
As noticed by Dan Carpenter <error27@gmail.com>, update_nl_seq() currently contains an out of bounds read of the seq_aft_nl array when looking for the oldest sequence number position. Fix it to only compare valid positions. Cc: stable@kernel.org Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-01-06ip: fix mc_loop checks for tunnels with multicast outer addressesOctavian Purdila
When we have L3 tunnels with different inner/outer families (i.e. IPV4/IPV6) which use a multicast address as the outer tunnel destination address, multicast packets will be loopbacked back to the sending socket even if IP*_MULTICAST_LOOP is set to disabled. The mc_loop flag is present in the family specific part of the socket (e.g. the IPv4 or IPv4 specific part). setsockopt sets the inner family mc_loop flag. When the packet is pushed through the L3 tunnel it will eventually be processed by the outer family which if different will check the flag in a different part of the socket then it was set. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-06Merge branch 'for-2.6.33' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.33' of git://linux-nfs.org/~bfields/linux: sunrpc: fix peername failed on closed listener nfsd: make sure data is on disk before calling ->fsync nfsd: fix "insecure" export option
2010-01-06sunrpc: fix peername failed on closed listenerXiaotian Feng
There're some warnings of "nfsd: peername failed (err 107)!" socket error -107 means Transport endpoint is not connected. This warning message was outputed by svc_tcp_accept() [net/sunrpc/svcsock.c], when kernel_getpeername returns -107. This means socket might be CLOSED. And svc_tcp_accept was called by svc_recv() [net/sunrpc/svc_xprt.c] if (test_bit(XPT_LISTENER, &xprt->xpt_flags)) { <snip> newxpt = xprt->xpt_ops->xpo_accept(xprt); <snip> So this might happen when xprt->xpt_flags has both XPT_LISTENER and XPT_CLOSE. Let's take a look at commit b0401d72, this commit has moved the close processing after do recvfrom method, but this commit also introduces this warnings, if the xpt_flags has both XPT_LISTENER and XPT_CLOSED, we should close it, not accpet then close. Signed-off-by: Xiaotian Feng <dfeng@redhat.com> Cc: J. Bruce Fields <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: David S. Miller <davem@davemloft.net> Cc: stable@kernel.org Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2010-01-06sunrpc: fix build-time warningRandy Dunlap
Fix auth_gss printk format warning: net/sunrpc/auth_gss/auth_gss.c:660: warning: format '%ld' expects type 'long int', but argument 3 has type 'ssize_t' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-01-04ipvs: Add boundary check on ioctl argumentsArjan van de Ven
The ipvs code has a nifty system for doing the size of ioctl command copies; it defines an array with values into which it indexes the cmd to find the right length. Unfortunately, the ipvs code forgot to check if the cmd was in the range that the array provides, allowing for an index outside of the array, which then gives a "garbage" result into the length, which then gets used for copying into a stack buffer. Fix this by adding sanity checks on these as well as the copy size. [ horms@verge.net.au: adjusted limit to IP_VS_SO_GET_MAX ] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-01-03net/sctp/socket.c: squish warningAndrew Morton
net/sctp/socket.c: In function 'sctp_setsockopt_autoclose': net/sctp/socket.c:2090: warning: comparison is always false due to limited range of data type Cc: Andrei Pelinescu-Onciul <andrei@iptel.org> Cc: Vlad Yasevich <vladislav.yasevich@hp.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-03rose_loopback_timer sets VC number <= ROSE_DEFAULT_MAXVCBernard Pidoux F6BVP
cat /proc/net/rose displayed a rose sockets abnormal lci value, i.e. greater than maximum number of VCs per neighbour allowed. This number prevents further test of lci value during rose operations. Example (lines shortened) : [bernard]# cat /proc/net/rose dest_addr dest_call src_addr src_call dev lci neigh st vs vr va * * 2080175520 F6BVP-1 rose0 000 00000 0 0 0 0 2080175520 FPAD-0 2080175520 WP-0 rose0 FFE 00001 3 0 0 0 Here are the default parameters : linux/include/net/rose.h:#define ROSE_DEFAULT_MAXVC 50 /* Maximum number of VCs per neighbour */ linux/net/rose/af_rose.c:int sysctl_rose_maximum_vcs = ROSE_DEFAULT_MAXVC; With the following patch, rose_loopback_timer() attributes a VC number within limits. Signed-off-by: Bernard Pidoux <f6bvp@amsat.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (74 commits) Revert "b43: Enforce DMA descriptor memory constraints" iwmc3200wifi: fix array out-of-boundary access wl1251: timeout one too soon in wl1251_boot_run_firmware() mac80211: fix propagation of failed hardware reconfigurations mac80211: fix race with suspend and dynamic_ps_disable_work ath9k: fix missed error codes in the tx status check ath9k: wake hardware during AMPDU TX actions ath9k: wake hardware for interface IBSS/AP/Mesh removal ath9k: fix suspend by waking device prior to stop cfg80211: fix error path in cfg80211_wext_siwscan wl1271_cmd.c: cleanup char => u8 iwlwifi: Storage class should be before const qualifier ath9k: Storage class should be before const qualifier cfg80211: fix race between deauth and assoc response wireless: remove remaining qual code rt2x00: Add USB ID for Linksys WUSB 600N rev 2. ath5k: fix SWI calibration interrupt storm mac80211: fix ibss join with fixed-bssid libertas: Remove carrier signaling from the scan code orinoco: fix GFP_KERNEL in orinoco_set_key with interrupts disabled ...
2009-12-29Merge branch 'master' of ↵David S. Miller
2009-12-28mac80211: fix propagation of failed hardware reconfigurationsLuis R. Rodriguez
mac80211 does not propagate failed hardware reconfiguration requests. For suspend and resume this is important due to all the possible issues that can come out of the suspend <-> resume cycle. Not propagating the error means cfg80211 will assume the resume for the device went through fine and mac80211 will continue on trying to poke at the hardware, enable timers, queue work, and so on for a device which is completley unfunctional. The least we can do is to propagate device start issues and warn when this occurs upon resume. A side effect of this patch is we also now propagate the start errors upon harware reconfigurations (non-suspend), but this should also be desirable anyway, there is not point in continuing to reconfigure a device if mac80211 was unable to start the device. For further details refer to the thread: http://marc.info/?t=126151038700001&r=1&w=2 Cc: stable@kernel.org Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-28mac80211: fix race with suspend and dynamic_ps_disable_workLuis R. Rodriguez
When mac80211 suspends it calls a driver's suspend callback as a last step and after that the driver assumes no calls will be made to it until we resume and its start callback is kicked. If such calls are made, however, suspend can end up throwing hardware in an unexpected state and making the device unusable upon resume. Fix this by preventing mac80211 to schedule dynamic_ps_disable_work by checking for when mac80211 starts to suspend and starts quiescing. Frames should be allowed to go through though as that is part of the quiescing steps and we do not flush the mac80211 workqueue since it was already done towards the beginning of suspend cycle. The other mac80211 issue will be hanled in the next patch. For further details see refer to the thread: http://marc.info/?t=126144866100001&r=1&w=2 Cc: stable@kernel.org Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-28cfg80211: fix error path in cfg80211_wext_siwscanJohannes Berg
If there's an invalid channel or SSID, the code leaks the scan request. Always free the scan request, unless it was successfully given to the driver. Reported-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Dan Carpenter <error27@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-28cfg80211: fix race between deauth and assoc responseJohannes Berg
Joseph Nahmias reported, in http://bugs.debian.org/562016, that he was getting the following warning (with some log around the issue): ath0: direct probe to AP 00:11:95:77:e0:b0 (try 1) ath0: direct probe responded ath0: authenticate with AP 00:11:95:77:e0:b0 (try 1) ath0: authenticated ath0: associate with AP 00:11:95:77:e0:b0 (try 1) ath0: deauthenticating from 00:11:95:77:e0:b0 by local choice (reason=3) ath0: direct probe to AP 00:11:95:77:e0:b0 (try 1) ath0: RX AssocResp from 00:11:95:77:e0:b0 (capab=0x421 status=0 aid=2) ath0: associated ------------[ cut here ]------------ WARNING: at net/wireless/mlme.c:97 cfg80211_send_rx_assoc+0x14d/0x152 [cfg80211]() Hardware name: 7658CTO ... Pid: 761, comm: phy0 Not tainted 2.6.32-trunk-686 #1 Call Trace: [<c1030a5d>] ? warn_slowpath_common+0x5e/0x8a [<c1030a93>] ? warn_slowpath_null+0xa/0xc [<f86cafc7>] ? cfg80211_send_rx_assoc+0x14d/0x152 ... ath0: link becomes ready ath0: deauthenticating from 00:11:95:77:e0:b0 by local choice (reason=3) ath0: no IPv6 routers present ath0: link is not ready ath0: direct probe to AP 00:11:95:77:e0:b0 (try 1) ath0: direct probe responded ath0: authenticate with AP 00:11:95:77:e0:b0 (try 1) ath0: authenticated ath0: associate with AP 00:11:95:77:e0:b0 (try 1) ath0: RX ReassocResp from 00:11:95:77:e0:b0 (capab=0x421 status=0 aid=2) ath0: associated It is not clear to me how the first "direct probe" here happens, but this seems to be a race condition, if the user requests to deauth after requesting assoc, but before the assoc response is received. In that case, it may happen that mac80211 tries to report the assoc success to cfg80211, but gets blocked on the wdev lock that is held because the user is requesting the deauth. The result is that we run into a warning. This is mostly harmless, but maybe cause an unexpected event to be sent to userspace; we'd send an assoc success event although userspace was no longer expecting that. To fix this, remove the warning and check whether the race happened and in that case abort processing. Reported-by: Joseph Nahmias <joe@nahmias.net> Cc: stable@kernel.org Cc: 562016-quiet@bugs.debian.org Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-28mac80211: fix ibss join with fixed-bssidFelix Fietkau
When fixed bssid is requested when joining an ibss network, incoming beacons that match the configured bssid cause mac80211 to create new sta entries, even before the ibss interface is in joined state. When that happens, it fails to bring up the interface entirely, because it checks for existing sta entries before joining. This patch fixes this bug by refusing to create sta info entries before the interface is fully operational. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-26NET: XFRM: Fix spelling of neighbour.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> net/xfrm/xfrm_policy.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-25net: restore ip source validationJamal Hadi Salim
when using policy routing and the skb mark: there are cases where a back path validation requires us to use a different routing table for src ip validation than the one used for mapping ingress dst ip. One such a case is transparent proxying where we pretend to be the destination system and therefore the local table is used for incoming packets but possibly a main table would be used on outbound. Make the default behavior to allow the above and if users need to turn on the symmetry via sysctl src_valid_mark Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-23pktgen: ndo_start_xmit can return NET_XMIT_xxx valuesJohn Fastabend
This updates pktgen so that it does not decrement skb->users when it receives valid NET_XMIT_xxx values. These are now valid return values from ndo_start_xmit in net-next-2.6. They also indicate the skb has been consumed. This fixes pktgen to work correctly with vlan devices. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-22kfifo: rename kfifo_put... into kfifo_in... and kfifo_get... into kfifo_out...Stefani Seibold
rename kfifo_put... into kfifo_in... to prevent miss use of old non in kernel-tree drivers ditto for kfifo_get... -> kfifo_out... Improve the prototypes of kfifo_in and kfifo_out to make the kerneldoc annotations more readable. Add mini "howto porting to the new API" in kfifo.h Signed-off-by: Stefani Seibold <stefani@seibold.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Andi Kleen <ak@linux.intel.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-22kfifo: cleanup namespaceStefani Seibold
change name of __kfifo_* functions to kfifo_*, because the prefix __kfifo should be reserved for internal functions only. Signed-off-by: Stefani Seibold <stefani@seibold.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Andi Kleen <ak@linux.intel.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-22kfifo: move out spinlockStefani Seibold
Move the pointer to the spinlock out of struct kfifo. Most users in tree do not actually use a spinlock, so the few exceptions now have to call kfifo_{get,put}_locked, which takes an extra argument to a spinlock. Signed-off-by: Stefani Seibold <stefani@seibold.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Andi Kleen <ak@linux.intel.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-22kfifo: move struct kfifo in placeStefani Seibold
This is a new generic kernel FIFO implementation. The current kernel fifo API is not very widely used, because it has to many constrains. Only 17 files in the current 2.6.31-rc5 used it. FIFO's are like list's a very basic thing and a kfifo API which handles the most use case would save a lot of development time and memory resources. I think this are the reasons why kfifo is not in use: - The API is to simple, important functions are missing - A fifo can be only allocated dynamically - There is a requirement of a spinlock whether you need it or not - There is no support for data records inside a fifo So I decided to extend the kfifo in a more generic way without blowing up the API to much. The new API has the following benefits: - Generic usage: For kernel internal use and/or device driver. - Provide an API for the most use case. - Slim API: The whole API provides 25 functions. - Linux style habit. - DECLARE_KFIFO, DEFINE_KFIFO and INIT_KFIFO Macros - Direct copy_to_user from the fifo and copy_from_user into the fifo. - The kfifo itself is an in place member of the using data structure, this save an indirection access and does not waste the kernel allocator. - Lockless access: if only one reader and one writer is active on the fifo, which is the common use case, no additional locking is necessary. - Remove spinlock - give the user the freedom of choice what kind of locking to use if one is required. - Ability to handle records. Three type of records are supported: - Variable length records between 0-255 bytes, with a record size field of 1 bytes. - Variable length records between 0-65535 bytes, with a record size field of 2 bytes. - Fixed size records, which no record size field. - Preserve memory resource. - Performance! - Easy to use! This patch: Since most users want to have the kfifo as part of another object, reorganize the code to allow including struct kfifo in another data structure. This requires changing the kfifo_alloc and kfifo_init prototypes so that we pass an existing kfifo pointer into them. This patch changes the implementation and all existing users. [akpm@linux-foundation.org: fix warning] Signed-off-by: Stefani Seibold <stefani@seibold.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Andi Kleen <ak@linux.intel.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-22ipvs: ip_vs_wrr.c: use lib/gcd.cFlorian Fainelli
Remove the private version of the greatest common divider to use lib/gcd.c, the latter also implementing the a < b case. [akpm@linux-foundation.org: repair neighboring whitespace because the diff looked odd] Signed-off-by: Florian Fainelli <florian@openwrt.org> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Takashi Iwai <tiwai@suse.de> Acked-by: Simon Horman <horms@verge.net.au> Cc: Julius Volz <juliusv@google.com> Cc: David S. Miller <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-12-21Merge branch 'master' of ↵David S. Miller
2009-12-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: bnx2: Fix bnx2_netif_stop() merge error. gianfar: Fix bit definitions of IMASK_GRSC and IMASK_GTSC gianfar: Fix stats support gianfar: Fix a filer bug bnx2: fixing a timout error due not refreshing TX timers correctly can/at91: don't check platform_get_irq's return value against zero mISDN: use DECLARE_COMPLETION_ONSTACK for non-constant completion bnx2: reset_task is crashing the kernel. Fixing it. ipv6: fix an oops when force unload ipv6 module TI DaVinci EMAC: Fix MDIO bus frequency configuration e100: Fix broken cbs accounting due to missing memset. broadcom: bcm54xx_shadow_read() errors ignored in bcm54xx_adjust_rxrefclk() e1000e: LED settings in EEPROM ignored on 82571 and 82572 netxen: use module parameter correctly netns: fix net.ipv6.route.gc_min_interval_ms in netns Bluetooth: Prevent ill-timed autosuspend in USB driver Bluetooth: Fix L2CAP locking scheme regression Bluetooth: Ack L2CAP I-frames before retransmit missing packet Bluetooth: Fix unset of RemoteBusy flag for L2CAP Bluetooth: Fix PTR_ERR return of wrong pointer in hidp_setup_hid()
2009-12-21mac80211: fix WMM AP settings applicationJohannes Berg
My commit 77fdaa12cea26c204cc12c312fe40bc0f3dcdfd8 Author: Johannes Berg <johannes@sipsolutions.net> Date: Tue Jul 7 03:45:17 2009 +0200 mac80211: rework MLME for multiple authentications inadvertedly broke WMM because it removed, along with a bunch of other now useless initialisations, the line initialising sdata->u.mgd.wmm_last_param_set to -1 which would make it adopt any WMM parameter set. If, as is usually the case, the AP uses WMM parameter set sequence number zero, we'd never update it until the AP changes the sequence number. Add the missing initialisation back to get the WMM settings from the AP applied locally. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: stable@kernel.org [2.6.31+] Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21mac80211: fix peer HT capabilitiesJohannes Berg
I noticed yesterday, because Jeff had noticed a speed regression, cf. bug http://bugzilla.intellinuxwireless.org/show_bug.cgi?id=2138 that the SM PS settings for peers were wrong. Instead of overwriting the SM PS settings with the local bits, we need to keep the remote bits. The bug was part of the original HT code from over two years ago, but unfortunately nobody noticed that it makes no sense -- we shouldn't be overwriting the peer's setting with our own but rather keep it intact when masking the peer capabilities with our own. While fixing that, I noticed that the masking of capabilities is completely useless for most of the bits, so also fix those other bits. Finally, I also noticed that PSMP_SUPPORT no longer exists in the final 802.11n version, so also remove that. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-18ipv6: fix an oops when force unload ipv6 moduleYang Hongyang
When I do an ipv6 module force unload,I got the following oops: #rmmod -f ipv6 ------------[ cut here ]------------ kernel BUG at mm/slub.c:2969! invalid opcode: 0000 [#1] SMP last sysfs file: /sys/devices/pci0000:00/0000:00:11.0/0000:02:03.0/net/eth2/ifindex Modules linked in: ipv6(-) dm_multipath uinput ppdev tpm_tis tpm tpm_bios pcspkr pcnet32 mii parport_pc i2c_piix4 parport i2c_core floppy mptspi mptscsih mptbase scsi_transport_spi Pid: 2530, comm: rmmod Tainted: G R 2.6.32 #2 440BX Desktop Reference Platform/VMware Virtual Platform EIP: 0060:[<c04b73f2>] EFLAGS: 00010246 CPU: 0 EIP is at kfree+0x6a/0xdd EAX: 00000000 EBX: c09e86bc ECX: c043e4dd EDX: c14293e0 ESI: e141f1d8 EDI: e140fc31 EBP: dec58ef0 ESP: dec58ed0 DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 Process rmmod (pid: 2530, ti=dec58000 task=decb1940 task.ti=dec58000) Stack: c14293e0 00000282 df624240 c0897d08 c09e86bc c09e86bc e141f1d8 dec58f1c <0> dec58f00 e140fc31 c09e84c4 e141f1bc dec58f14 c0689d21 dec58f1c e141f1bc <0> 00000000 dec58f2c c0689eff c09e84d8 c09e84d8 e141f1bc bff33a90 dec58f38 Call Trace: [<e140fc31>] ? ipv6_frags_exit_net+0x22/0x32 [ipv6] [<c0689d21>] ? ops_exit_list+0x19/0x3d [<c0689eff>] ? unregister_pernet_operations+0x2a/0x51 [<c0689f70>] ? unregister_pernet_subsys+0x17/0x24 [<e140fbfe>] ? ipv6_frag_exit+0x21/0x32 [ipv6] [<e141a361>] ? inet6_exit+0x47/0x122 [ipv6] [<c045f5de>] ? sys_delete_module+0x198/0x1f6 [<c04a8acf>] ? remove_vma+0x57/0x5d [<c070f63f>] ? do_page_fault+0x2e7/0x315 [<c0403218>] ? sysenter_do_call+0x12/0x28 Code: 86 00 00 00 40 c1 e8 0c c1 e0 05 01 d0 89 45 e0 66 83 38 00 79 06 8b 40 0c 89 45 e0 8b 55 e0 8b 02 84 c0 78 14 66 a9 00 c0 75 04 <0f> 0b eb fe 8b 45 e0 e8 35 15 fe ff eb 5d 8b 45 04 8b 55 e0 89 EIP: [<c04b73f2>] kfree+0x6a/0xdd SS:ESP 0068:dec58ed0 ---[ end trace 4475d1a5b0afa7e5 ]--- It's because in ip6_frags_ns_sysctl_register, "table" only alloced when "net" is not equals to "init_net".So when we free "table" in ip6_frags_ns_sysctl_unregister,we should check this first. This patch fix the problem. Signed-off-by: Yang Hongyang <yanghy@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-18netns: fix net.ipv6.route.gc_min_interval_ms in netnsAlexey Dobriyan
sysctl table was copied, all right, but ->data for net.ipv6.route.gc_min_interval_ms was not reinitialized for "!= &init_net" case. In init_net everthing works by accident due to correct ->data initialization in source table. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-18sunrpc: on successful gss error pipe write, don't return errorJeff Layton
When handling the gssd downcall, the kernel should distinguish between a successful downcall that contains an error code and a failed downcall (i.e. where the parsing failed or some other sort of problem occurred). In the former case, gss_pipe_downcall should be returning the number of bytes written to the pipe instead of an error. In the event of other errors, we generally want the initiating task to retry the upcall so we set msg.errno to -EAGAIN. An unexpected error code here is a bug however, so BUG() in that case. Signed-off-by: Jeff Layton <jlayton@redhat.com> Cc: stable@kernel.org Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-12-18SUNRPC: Fix the return value in gss_import_sec_context()Trond Myklebust
If the context allocation fails, it will return GSS_S_FAILURE, which is neither a valid error code, nor is it even negative. Return ENOMEM instead... Reported-by: Jeff Layton <jlayton@redhat.com> Cc: stable@kernel.org Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-12-18SUNRPC: Fix up an error return value in gss_import_sec_context_kerberos()Trond Myklebust
If the context allocation fails, the function currently returns a random error code, since the variable 'p' still points to a valid memory location. Ensure that it returns ENOMEM... Cc: stable@kernel.org Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-12-17Bluetooth: Fix L2CAP locking scheme regressionAndrei Emeltchenko
When locking was introduced the error path branch was not taken into account. Error was found in sparse code checking. Kudos to Jani Nikula. Signed-off-by: Andrei Emeltchenko <andrei.emeltchenko@nokia.com> Acked-by: Gustavo F. Padovan <gustavo@las.ic.unicamp.br> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-12-17Bluetooth: Ack L2CAP I-frames before retransmit missing packetGustavo F. Padovan
Moving the Ack to before l2cap_retransmit_frame() we can avoid the case where txWindow is full and the packet can't be retransmited. Signed-off-by: Gustavo F. Padovan <gustavo@las.ic.unicamp.br> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-12-17Bluetooth: Fix unset of RemoteBusy flag for L2CAPGustavo F. Padovan
RemoteBusy flag need to be unset before l2cap_ertm_send(), otherwise l2cap_ertm_send() will return without sending packets because it checks that flag before start sending. Signed-off-by: Gustavo F. Padovan <gustavo@las.ic.unicamp.br> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-12-17Bluetooth: Fix PTR_ERR return of wrong pointer in hidp_setup_hid()Roel Kluin
Return the PTR_ERR of the correct pointer. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-12-17fs: no games with DCACHE_UNHASHEDNick Piggin
Filesystems outside the regular namespace do not have to clear DCACHE_UNHASHED in order to have a working /proc/$pid/fd/XXX. Nothing in proc prevents the fd link from being used if its dentry is not in the hash. Also, it does not get put into the dcache hash if DCACHE_UNHASHED is clear; that depends on the filesystem calling d_add or d_rehash. So delete the misleading comments and needless code. Acked-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (38 commits) direct I/O fallback sync simplification ocfs: stop using do_sync_mapping_range cleanup blockdev_direct_IO locking make generic_acl slightly more generic sanitize xattr handler prototypes libfs: move EXPORT_SYMBOL for d_alloc_name vfs: force reval of target when following LAST_BIND symlinks (try #7) ima: limit imbalance msg Untangling ima mess, part 3: kill dead code in ima Untangling ima mess, part 2: deal with counters Untangling ima mess, part 1: alloc_file() O_TRUNC open shouldn't fail after file truncation ima: call ima_inode_free ima_inode_free IMA: clean up the IMA counts updating code ima: only insert at inode creation time ima: valid return code from ima_inode_alloc fs: move get_empty_filp() deffinition to internal.h Sanitize exec_permission_lite() Kill cached_lookup() and real_lookup() Kill path_lookup_open() ... Trivial conflicts in fs/direct-io.c
2009-12-16Merge branch 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: NFSv4: Fix a regression in the NFSv4 state manager NFSv4: Release the sequence id before restarting a CLOSE rpc call nfs41: fix session fore channel negotiation nfs41: do not zero seqid portion of stateid on close nfs: run state manager in privileged mode nfs: make recovery state manager operations privileged nfs: enforce FIFO ordering of operations trying to acquire slot rpc: add a new priority in RPC task nfs: remove rpc_task argument from nfs4_find_slot rpc: add rpc_queue_empty function nfs: change nfs4_do_setlk params to identify recovery type nfs: do not do a LOOKUP after open nfs: minor cleanup of session draining
2009-12-16Merge branch 'for-2.6.33' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.33' of git://linux-nfs.org/~bfields/linux: (42 commits) nfsd: remove pointless paths in file headers nfsd: move most of nfsfh.h to fs/nfsd nfsd: remove unused field rq_reffh nfsd: enable V4ROOT exports nfsd: make V4ROOT exports read-only nfsd: restrict filehandles accepted in V4ROOT case nfsd: allow exports of symlinks nfsd: filter readdir results in V4ROOT case nfsd: filter lookup results in V4ROOT case nfsd4: don't continue "under" mounts in V4ROOT case nfsd: introduce export flag for v4 pseudoroot nfsd: let "insecure" flag vary by pseudoflavor nfsd: new interface to advertise export features nfsd: Move private headers to source directory vfs: nfsctl.c un-used nfsd #includes lockd: Remove un-used nfsd headers #includes s390: remove un-used nfsd #includes sparc: remove un-used nfsd #includes parsic: remove un-used nfsd #includes compat.c: Remove dependence on nfsd private headers ...
2009-12-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (26 commits) net: sh_eth alignment fix for sh7724 using NET_IP_ALIGN V2 ixgbe: allow tx of pre-formatted vlan tagged packets ixgbe: Fix 82598 premature copper PHY link indicatation ixgbe: Fix tx_restart_queue/non_eop_desc statistics counters bcm63xx_enet: fix compilation failure after get_stats_count removal packet: dont call sleeping functions while holding rcu_read_lock() tcp: Revert per-route SACK/DSACK/TIMESTAMP changes. ipvs: zero usvc and udest netfilter: fix crashes in bridge netfilter caused by fragment jumps ipv6: reassembly: use seperate reassembly queues for conntrack and local delivery sky2: leave PCI config space writeable sky2: print Optima chip name x25: Update maintainer. ipvs: fix synchronization on connection close netfilter: xtables: document minimal required version drivers/net/bonding/: : use pr_fmt can: CAN_MCP251X should depend on HAS_DMA drivers/net/usb: Correct code taking the size of a pointer drivers/net/cpmac.c: Correct code taking the size of a pointer drivers/net/sfc: Correct code taking the size of a pointer ...
2009-12-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (45 commits) RDMA/cxgb3: Fix error paths in post_send and post_recv RDMA/nes: Fix stale ARP issue RDMA/nes: FIN during MPA startup causes timeout RDMA/nes: Free kmap() resources RDMA/nes: Check for zero STag RDMA/nes: Fix Xansation test crash on cm_node ref_count RDMA/nes: Abnormal listener exit causes loopback node crash RDMA/nes: Fix crash in nes_accept() RDMA/nes: Resource not freed for REJECTed connections RDMA/nes: MPA request/response error checking RDMA/nes: Fix query of ORD values RDMA/nes: Fix MAX_CM_BUFFER define RDMA/nes: Pass correct size to ioremap_nocache() RDMA/nes: Update copyright and branding string RDMA/nes: Add max_cqe check to nes_create_cq() RDMA/nes: Clean up struct nes_qp RDMA/nes: Implement IB_SIGNAL_ALL_WR as an iWARP extension RDMA/nes: Add additional SFP+ PHY uC status check and PHY reset RDMA/nes: Correct fast memory registration implementation IB/ehca: Fix error paths in post_send and post_recv ...
2009-12-16switch alloc_file() to passing struct pathAl Viro
... and have the caller grab both mnt and dentry; kill leak in infiniband, while we are at it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16switch sock_alloc_file() to alloc_file()Al Viro
