path: root/net
2011-11-11net: Handle different key sizes between address families in flow cachedpward
commit aa1c366e4febc7f5c2b84958a2dd7cd70e28f9d0 upstream. With the conversion of struct flowi to a union of AF-specific structs, some operations on the flow cache need to account for the exact size of the key. Signed-off-by: David Ward <david.ward@ll.mit.edu> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11mac80211: disable powersave for broken APsJohannes Berg
commit 05cb91085760ca378f28fc274fbf77fc4fd9886c upstream. Only AID values 1-2007 are valid, but some APs have been found to send random bogus values, in the reported case an AP that was sending the AID field value 0xffff, an AID of 0x3fff (16383). There isn't much we can do but disable powersave since there's no way it can work properly in this case. Reported-by: Bill C Riemers <briemers@redhat.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11mac80211: config hw when going back on-channelEliad Peller
commit 6911bf0453e0d6ea8eb694a4ce67a68d071c538e upstream. When going back on-channel, we should reconfigure the hw iff the hardware is not already configured to the operational channel. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11mac80211: fix remain_off_channel regressionEliad Peller
commit eaa7af2ae582c9a8c51b374c48d5970b748a5ce2 upstream. The offchannel code is currently broken - we should remain_off_channel if the work was started, and the work's channel and channel_type are the same as local->tmp_channel and local->tmp_channel_type. However, if wk->chan_type and local->tmp_channel_type coexist (e.g. have the same channel type), we won't remain_off_channel. This behavior was introduced by commit da2fd1f ("mac80211: Allow work items to use existing channel type.") Tested-by: Ben Greear <greearb@candelatech.com> Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11NFS/sunrpc: don't use a credential with extra groups.NeilBrown
commit dc6f55e9f8dac4b6479be67c5c9128ad37bb491f upstream. The sunrpc layer keeps a cache of recently used credentials and 'unx_match' is used to find the credential which matches the current process. However unx_match allows a match when the cached credential has extra groups at the end of uc_gids list which are not in the process group list. So if a process with a list of (say) 4 group accesses a file and gains access because of the last group in the list, then another process with the same uid and gid, and a gid list being the first tree of the gids of the original process tries to access the file, it will be granted access even though it shouldn't as the wrong rpc credential will be used. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11net: Unlock sock before calling sk_free()Thomas Gleixner
[ Upstream commit b0691c8ee7c28a72748ff32e91b165ec12ae4de6 ] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11bridge: leave carrier on for empty bridgestephen hemminger
[ Upstream commit b64b73d7d0c480f75684519c6134e79d50c1b341 ] This resolves a regression seen by some users of bridging. Some users use the bridge like a dummy device. They expect to be able to put an IPv6 address on the device with no ports attached. Although there are better ways of doing this, there is no reason to not allow it. Note: the bridge still will reflect the state of ports in the bridge if there are any added. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11can bcm: fix incomplete tx_setup fixOliver Hartkopp
commit 12d0d0d3a7349daa95dbfd5d7df8146255bc7c67 upstream. The commit aabdcb0b553b9c9547b1a506b34d55a764745870 ("can bcm: fix tx_setup off-by-one errors") fixed only a part of the original problem reported by Andre Naujoks. It turned out that the original code needed to be re-ordered to reduce complexity and to finally fix the reported frame counting issues. Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11make PACKET_STATISTICS getsockopt report consistently between ring and non-ringWillem de Bruijn
[ Upstream commit 7091fbd82cd5686444ffe9935ed6a8190101fe9d ] This is a minor change. Up until kernel 2.6.32, getsockopt(fd, SOL_PACKET, PACKET_STATISTICS, ...) would return total and dropped packets since its last invocation. The introduction of socket queue overflow reporting [1] changed drop rate calculation in the normal packet socket path, but not when using a packet ring. As a result, the getsockopt now returns different statistics depending on the reception method used. With a ring, it still returns the count since the last call, as counts are incremented in tpacket_rcv and reset in getsockopt. Without a ring, it returns 0 if no drops occurred since the last getsockopt and the total drops over the lifespan of the socket otherwise. The culprit is this line in packet_rcv, executed on a drop: drop_n_acct: po->stats.tp_drops = atomic_inc_return(&sk->sk_drops); As it shows, the new drop number it taken from the socket drop counter, which is not reset at getsockopt. I put together a small example that demonstrates the issue [2]. It runs for 10 seconds and overflows the queue/ring on every odd second. The reported drop rates are: ring: 16, 0, 16, 0, 16, ... non-ring: 0, 15, 0, 30, 0, 46, 0, 60, 0 , 74. Note how the even ring counts monotonically increase. Because the getsockopt adds tp_drops to tp_packets, total counts are similarly reported cumulatively. Long story short, reinstating the original code, as the below patch does, fixes the issue at the cost of additional per-packet cycles. Another solution that does not introduce per-packet overhead is be to keep the current data path, record the value of sk_drops at getsockopt() at call N in a new field in struct packetsock and subtract that when reporting at call N+1. I'll be happy to code that, instead, it's just more messy. [1] http://patchwork.ozlabs.org/patch/35665/ [2] http://kernel.googlecode.com/files/test-packetsock-getstatistics.c Signed-off-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11ipv6: nullify ipv6_ac_list and ipv6_fl_list when creating new socketYan, Zheng
[ Upstream commit 676a1184e8afd4fed7948232df1ff91517400859 ] ipv6_ac_list and ipv6_fl_list from listening socket are inadvertently shared with new socket created for connection. Signed-off-by: Zheng Yan <zheng.z.yan@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11tcp: properly update lost_cnt_hint during shiftingYan, Zheng
[ Upstream commit 1e5289e121372a3494402b1b131b41bfe1cf9b7f ] lost_skb_hint is used by tcp_mark_head_lost() to mark the first unhandled skb. lost_cnt_hint is the number of packets or sacked packets before the lost_skb_hint; When shifting a skb that is before the lost_skb_hint, if tcp_is_fack() is ture, the skb has already been counted in the lost_cnt_hint; if tcp_is_fack() is false, tcp_sacktag_one() will increase the lost_cnt_hint. So tcp_shifted_skb() does not need to adjust the lost_cnt_hint by itself. When shifting a skb that is equal to lost_skb_hint, the shifted packets will not be counted by tcp_mark_head_lost(). So tcp_shifted_skb() should adjust the lost_cnt_hint even tcp_is_fack(tp) is true. Signed-off-by: Zheng Yan <zheng.z.yan@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11tcp: properly handle md5sig_pool referencesYan, Zheng
[ Upstream commit 260fcbeb1ae9e768a44c9925338fbacb0d7e5ba9 ] tcp_v4_clear_md5_list() assumes that multiple tcp md5sig peers only hold one reference to md5sig_pool. but tcp_v4_md5_do_add() increases use count of md5sig_pool for each peer. This patch makes tcp_v4_md5_do_add() only increases use count for the first tcp md5sig peer. Signed-off-by: Zheng Yan <zheng.z.yan@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11l2tp: fix a potential skb leak in l2tp_xmit_skb()Eric Dumazet
[ Upstream commit 835acf5da239b91edb9f7ebe36516999e156e6ee ] l2tp_xmit_skb() can leak one skb if skb_cow_head() returns an error. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11ipv4: fix ipsec forward performance regressionYan, Zheng
[ Upstream commit b73233960a59ee66e09d642f13d0592b13651e94 ] There is bug in commit 5e2b61f(ipv4: Remove flowi from struct rtable). It makes xfrm4_fill_dst() modify wrong data structure. Signed-off-by: Zheng Yan <zheng.z.yan@intel.com> Reported-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11can bcm: fix tx_setup off-by-one errorsOliver Hartkopp
[ Upstream commit aabdcb0b553b9c9547b1a506b34d55a764745870 ] This patch fixes two off-by-one errors that canceled each other out. Checking for the same condition two times in bcm_tx_timeout_tsklet() reduced the count of frames to be sent by one. This did not show up the first time tx_setup is invoked as an additional frame is sent due to TX_ANNONCE. Invoking a second tx_setup on the same item led to a reduced (by 1) number of sent frames. Reported-by: Andre Naujoks <nautsch@gmail.com> Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11bridge: fix hang on removal of bridge via netlinkstephen hemminger
[ Upstream commit 1ce5cce895309862d2c35d922816adebe094fe4a ] Need to cleanup bridge device timers and ports when being bridge device is being removed via netlink. This fixes the problem of observed when doing: ip link add br0 type bridge ip link set dev eth1 master br0 ip link set br0 up ip link del br0 which would cause br0 to hang in unregister_netdev because of leftover reference count. Reported-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11net: hold sock reference while processing tx timestampsRichard Cochran
commit da92b194cc36b5dc1fbd85206aeeffd80bee0c39 upstream. The pair of functions, * skb_clone_tx_timestamp() * skb_complete_tx_timestamp() were designed to allow timestamping in PHY devices. The first function, called during the MAC driver's hard_xmit method, identifies PTP protocol packets, clones them, and gives them to the PHY device driver. The PHY driver may hold onto the packet and deliver it at a later time using the second function, which adds the packet to the socket's error queue. As pointed out by Johannes, nothing prevents the socket from disappearing while the cloned packet is sitting in the PHY driver awaiting a timestamp. This patch fixes the issue by taking a reference on the socket for each such packet. In addition, the comments regarding the usage of these function are expanded to highlight the rule that PHY drivers must use skb_complete_tx_timestamp() to release the packet, in order to release the socket reference, too. These functions first appeared in v2.6.36. Reported-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Richard Cochran <richard.cochran@omicron.at> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11mac80211: fix offchannel TX cookie matchingJohannes Berg
commit 28a1bcdb57d50f3038a255741ecc83e391e5282e upstream. When I introduced in-kernel off-channel TX I introduced a bug -- the work can't be canceled again because the code clear the skb pointer. Fix this by keeping track separately of whether TX status has already been reported. Reported-by: Jouni Malinen <j@w1.fi> Tested-by: Jouni Malinen <j@w1.fi> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11rtnetlink: Add missing manual netlink notification in dev_change_net_namespacesEric W. Biederman
commit d2237d35748e7f448a9c2d9dc6a85ef637466e24 upstream. Renato Westphal noticed that since commit a2835763e130c343ace5320c20d33c281e7097b7 "rtnetlink: handle rtnl_link netlink notifications manually" was merged we no longer send a netlink message when a networking device is moved from one network namespace to another. Fix this by adding the missing manual notification in dev_change_net_namespaces. Since all network devices that are processed by dev_change_net_namspaces are in the initialized state the complicated tests that guard the manual rtmsg_ifinfo calls in rollback_registered and register_netdevice are unnecessary and we can just perform a plain notification. Tested-by: Renato Westphal <renatowestphal@gmail.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11caif: Fix BUG() with network namespacesDavid Woodhouse
commit 08613e4626c06ca408fc55071f6aedee36986a87 upstream. The caif code will register its own pernet_operations, and then register a netdevice_notifier. Each time the netdevice_notifier is triggered, it'll do some stuff... including a lookup of its own pernet stuff with net_generic(). If the net_generic() call ever returns NULL, the caif code will BUG(). That doesn't seem *so* unreasonable, I suppose — it does seem like it should never happen. However, it *does* happen. When we clone a network namespace, setup_net() runs through all the pernet_operations one at a time. It gets to loopback before it gets to caif. And loopback_net_init() registers a netdevice... while caif hasn't been initialised. So the caif netdevice notifier triggers, and immediately goes BUG(). We could imagine a complex and overengineered solution to this generic class of problems, but this patch takes the simple approach. It just makes caif_device_notify() *not* go looking for its pernet data structures if the device it's being notified about isn't a caif device in the first place. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Acked-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-25x25: Prevent skb overreads when checking call user dataMatthew Daley
commit 7f81e25befdfb3272345a2e775f520e1d515fa20 upstream. x25_find_listener does not check that the amount of call user data given in the skb is big enough in per-socket comparisons, hence buffer overreads may occur. Fix this by adding a check. Signed-off-by: Matthew Daley <mattjd@gmail.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Andrew Hendry <andrew.hendry@gmail.com> Acked-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-16ipv6: fix NULL dereference in udp6_ufo_fragment()Jason Wang
This patch fixes the issue caused by ef81bb40bf15f350fe865f31fa42f1082772a576 which is a backport of upstream 87c48fa3b4630905f98268dde838ee43626a060c. The problem does not exist in upstream. We do not check whether route is attached before trying to assign ip identification through route dest which lead NULL pointer dereference. This happens when host bridge transmit a packet from guest. This patch changes ipv6_select_ident() to accept in6_addr as its paramter and fix the issue by using the destination address in ipv6 header when no route is attached. Signed-off-by: Jason Wang <jasowang@redhat.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03cfg80211: Fix validation of AKM suitesJouni Malinen
commit 1b9ca0272ffae212e726380f66777b30a56ed7a5 upstream. Incorrect variable was used in validating the akm_suites array from NL80211_ATTR_AKM_SUITES. In addition, there was no explicit validation of the array length (we only have room for NL80211_MAX_NR_AKM_SUITES). This can result in a buffer write overflow for stack variables with arbitrary data from user space. The nl80211 commands using the affected functionality require GENL_ADMIN_PERM, so this is only exposed to admin users. Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03Bluetooth: Fix timeout on scanning for the second timeOliver Neukum
commit 2d20a26a92f72e3bb658fe8ce99c3663756e9e7a upstream. The checks for HCI_INQUIRY and HCI_MGMT were in the wrong order, so that second scans always failed. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03bridge: fix a possible use after freeEric Dumazet
[ Upstream commit 22df13319d1fec30b8f9bcaadc295829647109bb ] br_multicast_ipv6_rcv() can call pskb_trim_rcsum() and therefore skb head can be reallocated. Cache icmp6_type field instead of dereferencing twice the struct icmp6hdr pointer. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03bridge: Pseudo-header required for the checksum of ICMPv6Yan, Zheng
[ Upstream commit 4b275d7efa1c4412f0d572fcd7f78ed0919370b3 ] Checksum of ICMPv6 is not properly computed because the pseudo header is not used. Thus, the MLD packet gets dropped by the bridge. Signed-off-by: Zheng Yan <zheng.z.yan@intel.com> Reported-by: Ang Way Chuang <wcang@sfc.wide.ad.jp> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03xfrm: Perform a replay check after return from async codepathsSteffen Klassert
[ Upstream commit bcf66bf54aabffc150acd1c99e0f4bc51935eada ] When asyncronous crypto algorithms are used, there might be many packets that passed the xfrm replay check, but the replay advance function is not called yet for these packets. So the replay check function would accept a replay of all of these packets. Also the system might crash if there are more packets in async processing than the size of the anti replay window, because the replay advance function would try to update the replay window beyond the bounds. This pach adds a second replay check after resuming from the async processing to fix these issues. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03vlan: reset headers on accel emulation pathJiri Pirko
[ Upstream commit c5114cd59d2664f258b0d021d79b1532d94bdc2b ] It's after all necessary to do reset headers here. The reason is we cannot depend that it gets reseted in __netif_receive_skb once skb is reinjected. For incoming vlanids without vlan_dev, vlan_do_receive() returns false with skb != NULL and __netif_reveive_skb continues, skb is not reinjected. This might be good material for 3.0-stable as well Reported-by: Mike Auty <mike.auty@gmail.com> Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03tcp: initialize variable ecn_ok in syncookies pathMike Waychison
[ Upstream commit f0e3d0689da401f7d1981c2777a714ba295ea5ff ] Using a gcc 4.4.3, warnings are emitted for a possibly uninitialized use of ecn_ok. This can happen if cookie_check_timestamp() returns due to not having seen a timestamp. Defaulting to ecn off seems like a reasonable thing to do in this case, so initialized ecn_ok to false. Signed-off-by: Mike Waychison <mikew@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03tcp: fix validation of D-SACKZheng Yan
[ Upstream commit f779b2d60ab95c17f1e025778ed0df3ec2f05d75 ] D-SACK is allowed to reside below snd_una. But the corresponding check in tcp_is_sackblock_valid() is the exact opposite. It looks like a typo. Signed-off-by: Zheng Yan <zheng.z.yan@intel.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03scm: Capture the full credentials of the scm senderTim Chen
[ Upstream commit e33f7a9f37d486f4c6cce5de18a6eea11d68f64f ] This patch corrects an erroneous update of credential's gid with uid introduced in commit 257b5358b32f17 since 2.6.36. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Reviewed-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03net_sched: prio: use qdisc_dequeue_peekedFlorian Westphal
[ Upstream commit 3557619f0f6f7496ed453d4825e24958ab1884e0 ] commit 07bd8df5df4369487812bf85a237322ff3569b77 (sch_sfq: fix peek() implementation) changed sfq to use generic peek helper. This makes HFSC complain about a non-work-conserving child qdisc, if prio with sfq child is used within hfsc: hfsc peeks into prio qdisc, which will then peek into sfq. returned skb is stashed in sch->gso_skb. Next, hfsc tries to dequeue from prio, but prio will call sfq dequeue directly, which may return NULL instead of previously peeked-at skb. Have prio call qdisc_dequeue_peeked, so sfq->dequeue() is not called in this case. Cc: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03netfilter: TCP and raw fix for ip_route_me_harderJulian Anastasov
[ Upstream commit 797fd3913abf2f7036003ab8d3d019cbea41affd ] TCP in some cases uses different global (raw) socket to send RST and ACK. The transparent flag is not set there. Currently, it is a problem for rerouting after the previous change. Fix it by simplifying the checks in ip_route_me_harder and use FLOWI_FLAG_ANYSRC even for sockets. It looks safe because the initial routing allowed this source address to be used and now we just have to make sure the packet is rerouted. As a side effect this also allows rerouting for normal raw sockets that use spoofed source addresses which was not possible even before we eliminated the ip_route_input call. Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03mcast: Fix source address selection for multicast listener reportYan, Zheng
[ Upstream commit e05c4ad3ed874ee4f5e2c969e55d318ec654332c ] Should check use count of include mode filter instead of total number of include mode filters. Signed-off-by: Zheng Yan <zheng.z.yan@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03ipv6: Fix ipv6_getsockopt for IPV6_2292PKTOPTIONSDaniel Baluta
[ Upstream commit 98e77438aed3cd3343cbb86825127b1d9d2bea33 ] IPV6_2292PKTOPTIONS is broken for 32-bit applications running in COMPAT mode on 64-bit kernels. The same problem was fixed for IPv4 with the patch: ipv4: Fix ip_getsockopt for IP_PKTOPTIONS, commit dd23198e58cd35259dd09e8892bbdb90f1d57748 Signed-off-by: Sorin Dumitru <sdumitru@ixiacom.com> Signed-off-by: Daniel Baluta <dbaluta@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03ipv4: some rt_iif -> rt_route_iif conversionsJulian Anastasov
[ Upstream commit 97a804102021431fa6fa33c21c85df762b0f5cb9 ] As rt_iif represents input device even for packets coming from loopback with output route, it is not an unique key specific to input routes. Now rt_route_iif has such role, it was fl.iif in 2.6.38, so better to change the checks at some places to save CPU cycles and to restore 2.6.38 semantics. compare_keys: - input routes: only rt_route_iif matters, rt_iif is same - output routes: only rt_oif matters, rt_iif is not used for matching in __ip_route_output_key - now we are back to 2.6.38 state ip_route_input_common: - matching rt_route_iif implies input route - compared to 2.6.38 we eliminated one rth->fl.oif check because it was not needed even for 2.6.38 compare_hash_inputs: Only the change here is not an optimization, it has effect only for output routes. I assume I'm restoring the original intention to ignore oif, it was using fl.iif - now we are back to 2.6.38 state Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03fib:fix BUG_ON in fib_nl_newrule when add new fib ruleGao feng
[ Upstream commit 561dac2d410ffac0b57a23b85ae0a623c1a076ca ] add new fib rule can cause BUG_ON happen the reproduce shell is ip rule add pref 38 ip rule add pref 38 ip rule add to 192.168.3.0/24 goto 38 ip rule del pref 38 ip rule add to 192.168.3.0/24 goto 38 ip rule add pref 38 then the BUG_ON will happen del BUG_ON and use (ctarget == NULL) identify whether this rule is unresolved Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03bridge: fix a possible net_device leakEric Dumazet
[ Upstream commit 11f3a6bdc2528d1ce2af50202dbf7138fdee1b34 ] Jan Beulich reported a possible net_device leak in bridge code after commit bb900b27a2f4 (bridge: allow creating bridge devices with netlink) Reported-by: Jan Beulich <JBeulich@novell.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03arp: fix rcu lockdep splat in arp_process()Eric Dumazet
[ Upstream commit 20e6074eb8e096b3a595c093d1cb222f378cd671 ] Dave Jones reported a lockdep splat triggered by an arp_process() call from parp_redo(). Commit faa9dcf793be (arp: RCU changes) is the origin of the bug, since it assumed arp_process() was called under rcu_read_lock(), which is not true in this particular path. Instead of adding rcu_read_lock() in parp_redo(), I chose to add it in neigh_proxy_process() to take care of IPv6 side too. =================================================== [ INFO: suspicious rcu_dereference_check() usage. ] --------------------------------------------------- include/linux/inetdevice.h:209 invoked rcu_dereference_check() without protection! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 0 4 locks held by setfiles/2123: #0: (&sb->s_type->i_mutex_key#13){+.+.+.}, at: [<ffffffff8114cbc4>] walk_component+0x1ef/0x3e8 #1: (&isec->lock){+.+.+.}, at: [<ffffffff81204bca>] inode_doinit_with_dentry+0x3f/0x41f #2: (&tbl->proxy_timer){+.-...}, at: [<ffffffff8106a803>] run_timer_softirq+0x157/0x372 #3: (class){+.-...}, at: [<ffffffff8141f256>] neigh_proxy_process +0x36/0x103 stack backtrace: Pid: 2123, comm: setfiles Tainted: G W 3.1.0-0.rc2.git7.2.fc16.x86_64 #1 Call Trace: <IRQ> [<ffffffff8108ca23>] lockdep_rcu_dereference+0xa7/0xaf [<ffffffff8146a0b7>] __in_dev_get_rcu+0x55/0x5d [<ffffffff8146a751>] arp_process+0x25/0x4d7 [<ffffffff8146ac11>] parp_redo+0xe/0x10 [<ffffffff8141f2ba>] neigh_proxy_process+0x9a/0x103 [<ffffffff8106a8c4>] run_timer_softirq+0x218/0x372 [<ffffffff8106a803>] ? run_timer_softirq+0x157/0x372 [<ffffffff8141f220>] ? neigh_stat_seq_open+0x41/0x41 [<ffffffff8108f2f0>] ? mark_held_locks+0x6d/0x95 [<ffffffff81062bb6>] __do_softirq+0x112/0x25a [<ffffffff8150d27c>] call_softirq+0x1c/0x30 [<ffffffff81010bf5>] do_softirq+0x4b/0xa2 [<ffffffff81062f65>] irq_exit+0x5d/0xcf [<ffffffff8150dc11>] smp_apic_timer_interrupt+0x7c/0x8a [<ffffffff8150baf3>] apic_timer_interrupt+0x73/0x80 <EOI> [<ffffffff8108f439>] ? trace_hardirqs_on_caller+0x121/0x158 [<ffffffff814fc285>] ? __slab_free+0x30/0x24c [<ffffffff814fc283>] ? __slab_free+0x2e/0x24c [<ffffffff81204e74>] ? inode_doinit_with_dentry+0x2e9/0x41f [<ffffffff81204e74>] ? inode_doinit_with_dentry+0x2e9/0x41f [<ffffffff81204e74>] ? inode_doinit_with_dentry+0x2e9/0x41f [<ffffffff81130cb0>] kfree+0x108/0x131 [<ffffffff81204e74>] inode_doinit_with_dentry+0x2e9/0x41f [<ffffffff81204fc6>] selinux_d_instantiate+0x1c/0x1e [<ffffffff81200f4f>] security_d_instantiate+0x21/0x23 [<ffffffff81154625>] d_instantiate+0x5c/0x61 [<ffffffff811563ca>] d_splice_alias+0xbc/0xd2 [<ffffffff811b17ff>] ext4_lookup+0xba/0xeb [<ffffffff8114bf1e>] d_alloc_and_lookup+0x45/0x6b [<ffffffff8114cbea>] walk_component+0x215/0x3e8 [<ffffffff8114cdf8>] lookup_last+0x3b/0x3d [<ffffffff8114daf3>] path_lookupat+0x82/0x2af [<ffffffff8110fc53>] ? might_fault+0xa5/0xac [<ffffffff8110fc0a>] ? might_fault+0x5c/0xac [<ffffffff8114c564>] ? getname_flags+0x31/0x1ca [<ffffffff8114dd48>] do_path_lookup+0x28/0x97 [<ffffffff8114df2c>] user_path_at+0x59/0x96 [<ffffffff811467ad>] ? cp_new_stat+0xf7/0x10d [<ffffffff811469a6>] vfs_fstatat+0x44/0x6e [<ffffffff811469ee>] vfs_lstat+0x1e/0x20 [<ffffffff81146b3d>] sys_newlstat+0x1a/0x33 [<ffffffff8108f439>] ? trace_hardirqs_on_caller+0x121/0x158 [<ffffffff812535fe>] ? trace_hardirqs_on_thunk+0x3a/0x3f [<ffffffff8150af82>] system_call_fastpath+0x16/0x1b Reported-by: Dave Jones <davej@redhat.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03wireless: Reset beacon_found while updating regulatoryRajkumar Manoharan
commit aa3d7eef398dd4f29045e9889b817d5161afe03e upstream. During the association, the regulatory is updated by country IE that reaps the previously found beacons. The impact is that after a STA disconnects *or* when for any reason a regulatory domain change happens the beacon hint flag is not cleared therefore preventing future beacon hints to be learned. This is important as a regulatory domain change or a restore of regulatory settings would set back the passive scan and no-ibss flags on the channel. This is the right place to do this given that it covers any regulatory domain change. Reviewed-by: Luis R. Rodriguez <mcgrof@gmail.com> Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com> Acked-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03mac80211: fix missing sta_lock in __sta_info_destroyJohannes Berg
commit 4bae7d976976fa52d345805ba686934cd548343e upstream. Since my commit 34e895075e21be3e21e71d6317440d1ee7969ad0 ("mac80211: allow station add/remove to sleep") there is a race in mac80211 when it clears the TIM bit because a sleeping station disconnected, the spinlock isn't held around the relevant code any more. Use the right API to acquire the spinlock correctly. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03net/9p: Fix kernel crash with msize 512KAneesh Kumar K.V
commit b49d8b5d7007a673796f3f99688b46931293873e upstream. With msize equal to 512K (PAGE_SIZE * VIRTQUEUE_NUM), we hit multiple crashes. This patch fix those. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03net/9p: Fix the msize calculation.Venkateswararao Jujjuri (JV)
commit c9ffb05ca5b5098d6ea468c909dd384d90da7d54 upstream. msize represents the maximum PDU size that includes P9_IOHDRSZ. Signed-off-by: Venkateswararao Jujjuri "<jvrao@linux.vnet.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03fs/9p: Fid is not valid after a failed clunk.Aneesh Kumar K.V
commit 5034990e28efb2d232ee82443a9edd62defd17ba upstream. free the fid even in case of failed clunk. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03VirtIO can transfer VIRTQUEUE_NUM of pages.jvrao
commit 7f781679dd596c8abde8336b4d0d166d6a4aad04 upstream. Signed-off-by: Venkateswararao Jujjuri "<jvrao@linux.vnet.ibm.com> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03Fix the size of receive buffer packing onto VirtIO ring.jvrao
commit 114e6f3a5ede73d5b56e145f04680c61c3dd67c4 upstream. Signed-off-by: Venkateswararao Jujjuri "<jvrao@linux.vnet.ibm.com> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03net/9p: fix client code to fail more gracefully on protocol errorEric Van Hensbergen
commit b85f7d92d7bd7e3298159e8b1eed8cb8cbbb0348 upstream. There was a BUG_ON to protect against a bad id which could be dealt with more gracefully. Reported-by: Natalie Orlin <norlin@us.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03atm: br2684: Fix oops due to skb->dev being NULLDaniel Schwierzeck
commit fbe5e29ec1886967255e76946aaf537b8cc9b81e upstream. This oops have been already fixed with commit 27141666b69f535a4d63d7bc6d9e84ee5032f82a atm: [br2684] Fix oops due to skb->dev being NULL It happens that if a packet arrives in a VC between the call to open it on the hardware and the call to change the backend to br2684, br2684_regvcc processes the packet and oopses dereferencing skb->dev because it is NULL before the call to br2684_push(). but have been introduced again with commit b6211ae7f2e56837c6a4849316396d1535606e90 atm: Use SKB queue and list helpers instead of doing it by-hand. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03sendmmsg/sendmsg: fix unsafe user pointer accessMathieu Desnoyers
commit bc909d9ddbf7778371e36a651d6e4194b1cc7d4c upstream. Dereferencing a user pointer directly from kernel-space without going through the copy_from_user family of functions is a bad idea. Two of such usages can be found in the sendmsg code path called from sendmmsg, added by commit c71d8ebe7a4496fb7231151cb70a6baa0cb56f9a upstream. commit 5b47b8038f183b44d2d8ff1c7d11a5c1be706b34 in the 3.0-stable tree. Usages are performed through memcmp() and memcpy() directly. Fix those by using the already copied msg_sys structure instead of the __user *msg structure. Note that msg_sys can be set to NULL by verify_compat_iovec() or verify_iovec(), which requires additional NULL pointer checks. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: David Goulet <dgoulet@ev0ke.net> CC: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> CC: Anton Blanchard <anton@samba.org> CC: David S. Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-17atm: br2864: sent packets truncated in VC routed modeChas Williams
commit a08af810cdc29d2ca930e8a869d3d01744c392d8 upstream. Reported-by: Pascal Hambourg <pascal@plouf.fr.eu.org> Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
