commit 92e55f412cffd016cc245a74278cb4d7b89bb3bc upstream.
Unlike ipv4, this control socket is shared by all cpus so we cannot use
it as scratchpad area to annotate the mark that we pass to ip6_xmit().
Add a new parameter to ip6_xmit() to indicate the mark. The SCTP socket
family caches the flowi6 structure in the sctp_transport structure, so
we cannot use to carry the mark unless we later on reset it back, which
I discarded since it looks ugly to me.
Fixes: bf99b4ded5f8 ("tcp: fix mark propagation with fwmark_reflect enabled")
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
commit bf99b4ded5f8a4767dbb9d180626f06c51f9881f upstream.
Otherwise, RST packets generated by the TCP stack for non-existing
sockets always have mark 0.
The mark from the original packet is assigned to the netns_ipv4/6
socket used to send the response so that it can get copied into the
response skb when the socket sends it.
Fixes: e110861f8609 ("net: add a sysctl to reflect the fwmark on replies")
Cc: Lorenzo Colitti <lorenzo@google.com>
Signed-off-by: Pau Espin Pedrol <pau.espin@tessares.net>
[ Upstream commit 9c8bb163ae784be4f79ae504e78c862806087c54 ]
In function igmpv3/mld_add_delrec() we allocate pmc and put it in
idev->mc_tomb, so we should free it when we don't need it in del_delrec().
But I removed kfree(pmc) incorrectly in latest two patches. Now fix it.
Fixes: 24803f38a5c0 ("igmp: do not remove igmp souce list info when ...")
Fixes: 1666d49e1d41 ("mld: do not remove mld souce list info when ...")
Reported-by: Daniel Borkmann <daniel@iogearbox.net>
Signed-off-by: Hangbin Liu <liuhangbin@gmail.com>
[ Upstream commit 1666d49e1d416fcc2cce708242a52fe3317ea8ba ]
This is an IPv6 version of commit 24803f38a5c0 ("igmp: do not remove igmp
souce list..."). In mld_del_delrec(), we will restore back all source filter
info instead of flush them.
Move mld_clear_delrec() from ipv6_mc_down() to ipv6_mc_destroy_dev() since
we should not remove source list info when set link down. Remove
igmp6_group_dropped() in ipv6_mc_destroy_dev() since we have called it in
ipv6_mc_down().
Also clear all source info after igmp6_group_dropped() instead of in it
because ipv6_mc_down() will call igmp6_group_dropped().
[ Upstream commit 72fb96e7bdbbdd4421b0726992496531060f3636 ]
udp_ioctl(), as its name suggests, is used by UDP protocols,
but is also used by L2TP :(
L2TP should use its own handler, because it really does not
look the same.
SIOCINQ for instance should not assume UDP checksum or headers.
Thanks to Andrey and syzkaller team for providing the report
and a nice reproducer.
While crashes only happen on recent kernels (after commit
7c13f97ffde6 ("udp: do fwd memory scheduling on dequeue")), this
probably needs to be backported to older kernels.
Fixes: 7c13f97ffde6 ("udp: do fwd memory scheduling on dequeue")
Fixes: 85584672012e ("udp: Fix udp_poll() and ioctl()")
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Acked-by: Paolo Abeni <pabeni@redhat.com>
[ Upstream commit 382e1eea2d983cd2343482c6a638f497bb44a636 ]
dsa_slave_create() can fail, and dsa_user_port_unapply() will properly check
for the network device not being NULL before attempting to destroy it. We were
not setting the slave network device as NULL if dsa_slave_create() failed, so
we would later on be calling dsa_slave_destroy() on a now free'd and
unitialized network device, causing crashes in dsa_slave_destroy().
Fixes: 83c0afaec7b7 ("net: dsa: Add new binding implementation")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit 73d2c6678e6c3af7e7a42b1e78cd0211782ade32 ]
Andrey reported a kernel crash:
general protection fault: 0000 [#1] SMP KASAN
Dumping ftrace buffer:
(ftrace buffer empty)
Modules linked in:
CPU: 2 PID: 3880 Comm: syz-executor1 Not tainted 4.10.0-rc6+ #124
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
task: ffff880060048040 task.stack: ffff880069be8000
RIP: 0010:ping_v4_push_pending_frames net/ipv4/ping.c:647 [inline]
RIP: 0010:ping_v4_sendmsg+0x1acd/0x23f0 net/ipv4/ping.c:837
RSP: 0018:ffff880069bef8b8 EFLAGS: 00010206
RAX: dffffc0000000000 RBX: ffff880069befb90 RCX: 0000000000000000
RDX: 0000000000000018 RSI: ffff880069befa30 RDI: 00000000000000c2
RBP: ffff880069befbb8 R08: 0000000000000008 R09: 0000000000000000
R10: 0000000000000002 R11: 0000000000000000 R12: ffff880069befab0
R13: ffff88006c624a80 R14: ffff880069befa70 R15: 0000000000000000
FS: 00007f6f7c716700(0000) GS:ffff88006de00000(0000) knlGS:0000000000000000
CR2: 00000000004a6f28 CR3: 000000003a134000 CR4: 00000000000006e0
Call Trace:
inet_sendmsg+0x164/0x5b0 net/ipv4/af_inet.c:744
sock_sendmsg_nosec net/socket.c:635 [inline]
sock_sendmsg+0xca/0x110 net/socket.c:645
SYSC_sendto+0x660/0x810 net/socket.c:1687
SyS_sendto+0x40/0x50 net/socket.c:1655
entry_SYSCALL_64_fastpath+0x1f/0xc2
This is because we miss a check for NULL pointer for skb_peek() when
the queue is empty. Other places already have the same check.
Fixes: c319b4d76b9e ("net: ipv4: add IPPROTO_ICMP socket kind")
Tested-by: Andrey Konovalov <andreyknvl@google.com>
[ Upstream commit 57031eb794906eea4e1c7b31dc1e2429c0af0c66 ]
Link layer protocols may unconditionally pull headers, as Ethernet
does in eth_type_trans. Ensure that the entire link layer header
always lies in the skb linear segment. tpacket_snd has such a check.
Extend this to packet_snd.
Variable length link layer headers complicate the computation
somewhat. Here skb->len may be smaller than dev->hard_header_len.
Round up the linear length to be at least as long as the smallest of
the two.
Signed-off-by: Willem de Bruijn <willemb@google.com>
[ Upstream commit 217e6fa24ce28ec87fca8da93c9016cb78028612 ]
The stack must not pass packets to device drivers that are shorter
than the minimum link layer header length.
Previously, packet sockets would drop packets smaller than or equal
to dev->hard_header_len, but this has false positives. Zero length
payload is used over Ethernet. Other link layer protocols support
variable length headers. Support for validation of these protocols
removed the min length check for all protocols.
Introduce an explicit dev->min_header_len parameter and drop all
packets below this value. Initially, set it to non-zero only for
Ethernet and loopback. Other protocols can follow in a patch to
net-next.
Fixes: 9ed988cd5915 ("packet: validate variable length ll headers")
Reported-by: Sowmini Varadhan <sowmini.varadhan@oracle.com>
Acked-by: Sowmini Varadhan <sowmini.varadhan@oracle.com>
[ Upstream commit d7426c69a1942b2b9b709bf66b944ff09f561484 ]
Dmitry reported a double free in sit_init_net():
kernel BUG at mm/percpu.c:689!
invalid opcode: 0000 [#1] SMP KASAN
Modules linked in:
CPU: 0 PID: 15692 Comm: syz-executor1 Not tainted 4.10.0-rc6-next-20170206 #1
Hardware name: Google Google Compute Engine/Google Compute Engine,
BIOS Google 01/01/2011
task: ffff8801c9cc27c0 task.stack: ffff88017d1d8000
RIP: 0010:pcpu_free_area+0x68b/0x810 mm/percpu.c:689
RSP: 0018:ffff88017d1df488 EFLAGS: 00010046
RAX: 0000000000010000 RBX: 00000000000007c0 RCX: ffffc90002829000
RDX: 0000000000010000 RSI: ffffffff81940efb RDI: ffff8801db841d94
RBP: ffff88017d1df590 R08: dffffc0000000000 R09: 1ffffffff0bb3bdd
R10: dffffc0000000000 R11: 00000000000135dd R12: ffff8801db841d80
R13: 0000000000038e40 R14: 00000000000007c0 R15: 00000000000007c0
FS: 00007f6ea608f700(0000) GS:ffff8801dbe00000(0000) knlGS:0000000000000000
CR2: 000000002000aff8 CR3: 00000001c8d44000 CR4: 00000000001426f0
DR0: 0000000020000000 DR1: 0000000020000000 DR2: 0000000000000000
DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000600
Call Trace:
free_percpu+0x212/0x520 mm/percpu.c:1264
ipip6_dev_free+0x43/0x60 net/ipv6/sit.c:1335
sit_init_net+0x3cb/0xa10 net/ipv6/sit.c:1831
ops_init+0x10a/0x530 net/core/net_namespace.c:115
setup_net+0x2ed/0x690 net/core/net_namespace.c:291
copy_net_ns+0x26c/0x530 net/core/net_namespace.c:396
create_new_namespaces+0x409/0x860 kernel/nsproxy.c:106
unshare_nsproxy_namespaces+0xae/0x1e0 kernel/nsproxy.c:205
SYSC_unshare kernel/fork.c:2281 [inline]
SyS_unshare+0x64e/0xfc0 kernel/fork.c:2231
This is because when tunnel->dst_cache init fails, we free dev->tstats
once in ipip6_tunnel_init() and twice in sit_init_net(). This looks
redundant but its ndo_uinit() does not seem enough to clean up everything
here. So avoid this by setting dev->tstats to NULL after the first free,
at least for -net.
[ Upstream commit 2dcab598484185dea7ec22219c76dcdd59e3cb90 ]
Alexander Popov reported that an application may trigger a BUG_ON in
sctp_wait_for_sndbuf if the socket tx buffer is full, a thread is
waiting on it to queue more data and meanwhile another thread peels off
the association being used by the first thread.
This patch replaces the BUG_ON call with a proper error handling. It
will return -EPIPE to the original sendmsg call, similarly to what would
have been done if the association wasn't found in the first place.
Acked-by: Alexander Popov <alex.popov@linux.com>
Signed-off-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Reviewed-by: Xin Long <lucien.xin@gmail.com>
[ Upstream commit ccf7abb93af09ad0868ae9033d1ca8108bdaec82 ]
Splicing from TCP socket is vulnerable when a packet with URG flag is
received and stored into receive queue.
__tcp_splice_read() returns 0, and sk_wait_data() immediately
returns since there is the problematic skb in queue.
This is a nice way to burn cpu (aka infinite loop) and trigger
soft lockups.
Again, this gem was found by syzkaller tool.
Fixes: 9c55e01c0cc8 ("[TCP]: Splice receive support.")
Cc: Willy Tarreau <w@1wt.eu>
[ Upstream commit ebf6c9cb23d7e56eec8575a88071dec97ad5c6e2 ]
Dmitry reported use-after-free in ip6_datagram_recv_specific_ctl()
A similar bug was fixed in commit 8ce48623f0cf ("ipv6: tcp: restore
IP6CB for pktoptions skbs"), but I missed another spot.
tcp_v6_syn_recv_sock() can indeed set np->pktoptions from ireq->pktopts
Fixes: 971f10eca186 ("tcp: better TCP_SKB_CB layout to reduce cache line misses")
[ Upstream commit 7892032cfe67f4bde6fc2ee967e45a8fbaf33756 ]
Andrey Konovalov reported out of bound accesses in ip6gre_err()
If GRE flags contains GRE_KEY, the following expression
*(((__be32 *)p) + (grehlen / 4) - 1)
accesses data ~40 bytes after the expected point, since
grehlen includes the size of IPv6 headers.
Let's use a "struct gre_base_hdr *greh" pointer to make this
code more readable.
p[1] becomes greh->protocol.
grhlen is the GRE header length.
Fixes: c12b395a4664 ("gre: Support GRE over IPv6")
[ Upstream commit d71b7896886345c53ef1d84bda2bc758554f5d61 ]
syzkaller found another out of bound access in ip_options_compile(),
or more exactly in cipso_v4_validate()
Fixes: 20e2a8648596 ("cipso: handle CIPSO options correctly when NetLabel is disabled")
Fixes: 446fda4f2682 ("[NetLabel]: CIPSOv4 engine")
Cc: Paul Moore <paul@paul-moore.com>
Acked-by: Paul Moore <paul@paul-moore.com>
[ Upstream commit 34b2cef20f19c87999fff3da4071e66937db9644 ]
Andrey Konovalov got crashes in __ip_options_echo() when a NULL skb->dst
is accessed.
ipv4_pktinfo_prepare() should not drop the dst if (evil) IP options
are present.
We could refine the test to the presence of ts_needtime or srr,
but IP options are not often used, so let's be conservative.
Thanks to syzkaller team for finding this bug.
Fixes: d826eb14ecef ("ipv4: PKTINFO doesnt need dst reference")
[ Upstream commit 5fa8bbda38c668e56b0c6cdecced2eac2fe36dec ]
Dmitry reported a warning [1] showing that we were calling
net_disable_timestamp() -> static_key_slow_dec() from a non
process context.
Grabbing a mutex while holding a spinlock or rcu_read_lock()
is not allowed.
As Cong suggested, we now use a work queue.
It is possible netstamp_clear() exits while netstamp_needed_deferred
is not zero, but it is probably not worth trying to do better than that.
netstamp_needed_deferred atomic tracks the exact number of deferred
decrements.
[1]
[ INFO: suspicious RCU usage. ]
4.10.0-rc5+ #192 Not tainted
./include/linux/rcupdate.h:561 Illegal context switch in RCU read-side
critical section!
rcu_scheduler_active = 2, debug_locks = 0
2 locks held by syz-executor14/23111:
#0: (sk_lock-AF_INET6){+.+.+.}, at: [<ffffffff83a35c35>] lock_sock
include/net/sock.h:1454 [inline]
rawv6_sendmsg+0x1e65/0x3ec0 net/ipv6/raw.c:919
#1: (rcu_read_lock){......}, at: [<ffffffff83ae2678>] nf_hook
include/linux/netfilter.h:201 [inline]
__ip6_local_out+0x258/0x840 net/ipv6/output_core.c:160
stack backtrace:
CPU: 2 PID: 23111 Comm: syz-executor14 Not tainted 4.10.0-rc5+ #192
01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:15 [inline]
dump_stack+0x2ee/0x3ef lib/dump_stack.c:51
lockdep_rcu_suspicious+0x139/0x180 kernel/locking/lockdep.c:4452
rcu_preempt_sleep_check include/linux/rcupdate.h:560 [inline]
___might_sleep+0x560/0x650 kernel/sched/core.c:7748
__might_sleep+0x95/0x1a0 kernel/sched/core.c:7739
mutex_lock_nested+0x24f/0x1730 kernel/locking/mutex.c:752
atomic_dec_and_mutex_lock+0x119/0x160 kernel/locking/mutex.c:1060
__static_key_slow_dec+0x7a/0x1e0 kernel/jump_label.c:149
static_key_slow_dec+0x51/0x90 kernel/jump_label.c:174
net_disable_timestamp+0x3b/0x50 net/core/dev.c:1728
sock_disable_timestamp+0x98/0xc0 net/core/sock.c:403
__sk_destruct+0x27d/0x6b0 net/core/sock.c:1441
sk_destruct+0x47/0x80 net/core/sock.c:1460
__sk_free+0x57/0x230 net/core/sock.c:1468
sock_wfree+0xae/0x120 net/core/sock.c:1645
skb_release_head_state+0xfc/0x200 net/core/skbuff.c:655
skb_release_all+0x15/0x60 net/core/skbuff.c:668
__kfree_skb+0x15/0x20 net/core/skbuff.c:684
kfree_skb+0x16e/0x4c0 net/core/skbuff.c:705
inet_frag_destroy+0x121/0x290 net/ipv4/inet_fragment.c:304
inet_frag_put include/net/inet_frag.h:133 [inline]
nf_ct_frag6_gather+0x1106/0x3840
net/ipv6/netfilter/nf_conntrack_reasm.c:617
ipv6_defrag+0x1be/0x2b0 net/ipv6/netfilter/nf_defrag_ipv6_hooks.c:68
nf_hook_entry_hookfn include/linux/netfilter.h:102 [inline]
nf_hook_slow+0xc3/0x290 net/netfilter/core.c:310
nf_hook include/linux/netfilter.h:212 [inline]
__ip6_local_out+0x489/0x840 net/ipv6/output_core.c:160
ip6_local_out+0x2d/0x170 net/ipv6/output_core.c:170
ip6_send_skb+0xa1/0x340 net/ipv6/ip6_output.c:1722
ip6_push_pending_frames+0xb3/0xe0 net/ipv6/ip6_output.c:1742
rawv6_push_pending_frames net/ipv6/raw.c:613 [inline]
rawv6_sendmsg+0x2d1a/0x3ec0 net/ipv6/raw.c:927
sock_write_iter+0x326/0x600 net/socket.c:848
do_iter_readv_writev+0x2e3/0x5b0 fs/read_write.c:695
do_readv_writev+0x42c/0x9b0 fs/read_write.c:872
vfs_writev+0x87/0xc0 fs/read_write.c:911
do_writev+0x110/0x2c0 fs/read_write.c:944
SYSC_writev fs/read_write.c:1017 [inline]
SyS_writev+0x27/0x30 fs/read_write.c:1014
RIP: 0033:0x445559
RSP: 002b:00007f6f46fceb58 EFLAGS: 00000292 ORIG_RAX: 0000000000000014
RAX: ffffffffffffffda RBX: 0000000000000005 RCX: 0000000000445559
RDX: 0000000000000001 RSI: 0000000020f1eff0 RDI: 0000000000000005
RBP: 00000000006e19c0 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000292 R12: 0000000000700000
R13: 0000000020f59000 R14: 0000000000000015 R15: 0000000000020400
BUG: sleeping function called from invalid context at
in_atomic(): 1, irqs_disabled(): 0, pid: 23111, name: syz-executor14
INFO: lockdep is turned off.
01/01/2011
Call Trace:
___might_sleep+0x47e/0x650 kernel/sched/core.c:7780
RIP: 0033:0x445559
Fixes: b90e5794c5bd ("net: dont call jump_label_dec from irq context")
Suggested-by: Cong Wang <xiyou.wangcong@gmail.com>
[ Upstream commit 06425c308b92eaf60767bc71d359f4cbc7a561f8 ]
syszkaller fuzzer was able to trigger a divide by zero, when
TCP window scaling is not enabled.
SO_RCVBUF can be used not only to increase sk_rcvbuf, also
to decrease it below current receive buffers utilization.
If mss is negative or 0, just return a zero TCP window.
Acked-by: Neal Cardwell <ncardwell@google.com>
[ Upstream commit 63117f09c768be05a0bf465911297dc76394f686 ]
Casting is a high precedence operation but "off" and "i" are in terms of
bytes so we need to have some parenthesis here.
Fixes: fbfa743a9d2a ("ipv6: fix ip6_tnl_parse_tlv_enc_lim()")
[ Upstream commit fbfa743a9d2a0ffa24251764f10afc13eb21e739 ]
This function suffers from multiple issues.
First one is that pskb_may_pull() may reallocate skb->head,
so the 'raw' pointer needs either to be reloaded or not used at all.
Second issue is that NEXTHDR_DEST handling does not validate
that the options are present in skb->data, so we might read
garbage or access non existent memory.
With help from Willem de Bruijn.
Cc: Willem de Bruijn <willemb@google.com>
[ Upstream commit fd62d9f5c575f0792f150109f1fd24a0d4b3f854 ]
In the current version, the matchall internal state is split into two
structs: cls_matchall_head and cls_matchall_filter. This makes little
sense, as matchall instance supports only one filter, and there is no
situation where one exists and the other does not. In addition, that led
to some races when filter was deleted while packet was processed.
Unify that two structs into one, thus simplifying the process of matchall
creation and deletion. As a result, the new, delete and get callbacks have
a dummy implementation where all the work is done in destroy and change
callbacks, as was done in cls_cgroup.
Fixes: bf3994d2ed31 ("net/sched: introduce Match-all classifier")
Signed-off-by: Yotam Gigi <yotamg@mellanox.com>
Acked-by: Jiri Pirko <jiri@mellanox.com>
[ Upstream commit f1712c73714088a7252d276a57126d56c7d37e64 ]
Zhang Yanmin reported crashes [1] and provided a patch adding a
synchronize_rcu() call in can_rx_unregister()
The main problem seems that the sockets themselves are not RCU
protected.
If CAN uses RCU for delivery, then sockets should be freed only after
one RCU grace period.
Recent kernels could use sock_set_flag(sk, SOCK_RCU_FREE), but let's
ease stable backports with the following fix instead.
[1]
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff81495e25>] selinux_socket_sock_rcv_skb+0x65/0x2a0
Call Trace:
<IRQ>
[<ffffffff81485d8c>] security_sock_rcv_skb+0x4c/0x60
[<ffffffff81d55771>] sk_filter+0x41/0x210
[<ffffffff81d12913>] sock_queue_rcv_skb+0x53/0x3a0
[<ffffffff81f0a2b3>] raw_rcv+0x2a3/0x3c0
[<ffffffff81f06eab>] can_rcv_filter+0x12b/0x370
[<ffffffff81f07af9>] can_receive+0xd9/0x120
[<ffffffff81f07beb>] can_rcv+0xab/0x100
[<ffffffff81d362ac>] __netif_receive_skb_core+0xd8c/0x11f0
[<ffffffff81d36734>] __netif_receive_skb+0x24/0xb0
[<ffffffff81d37f67>] process_backlog+0x127/0x280
[<ffffffff81d36f7b>] net_rx_action+0x33b/0x4f0
[<ffffffff810c88d4>] __do_softirq+0x184/0x440
[<ffffffff81f9e86c>] do_softirq_own_stack+0x1c/0x30
<EOI>
[<ffffffff810c76fb>] do_softirq.part.18+0x3b/0x40
[<ffffffff810c8bed>] do_softirq+0x1d/0x20
[<ffffffff81d30085>] netif_rx_ni+0xe5/0x110
[<ffffffff8199cc87>] slcan_receive_buf+0x507/0x520
[<ffffffff8167ef7c>] flush_to_ldisc+0x21c/0x230
[<ffffffff810e3baf>] process_one_work+0x24f/0x670
[<ffffffff810e44ed>] worker_thread+0x9d/0x6f0
[<ffffffff810e4450>] ? rescuer_thread+0x480/0x480
[<ffffffff810ebafc>] kthread+0x12c/0x150
[<ffffffff81f9ccef>] ret_from_fork+0x3f/0x70
Reported-by: Zhang Yanmin <yanmin.zhang@intel.com>
Acked-by: Oliver Hartkopp <socketcan@hartkopp.net>
commit da7061c82e4a1bc6a5e134ef362c86261906c860 upstream.
The function ieee80211_ie_split_vendor doesn't return 0 on errors. Instead
it returns any offset < ielen when WLAN_EID_VENDOR_SPECIFIC is found. The
return value in mesh_add_vendor_ies must therefore be checked against
ifmsh->ie_len and not 0. Otherwise all ifmsh->ie starting with
WLAN_EID_VENDOR_SPECIFIC will be rejected.
Fixes: 082ebb0c258d ("mac80211: fix mesh beacon format")
Signed-off-by: Thorsten Horstmann <thorsten@defutech.de>
Signed-off-by: Mathias Kretschmer <mathias.kretschmer@fit.fraunhofer.de>
Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
[sven@narfation.org: Add commit message]
Signed-off-by: Sven Eckelmann <sven@narfation.org>
commit fd551bac4795854adaa87bad7e5136083719802b upstream.
A previous change to fix checks for NL80211_MESHCONF_HT_OPMODE
missed setting the flag when replacing FILL_IN_MESH_PARAM_IF_SET
with checking codes. This results in dropping the received HT
operation value when called by nl80211_update_mesh_config(). Fix
this by setting the flag properly.
Fixes: 9757235f451c ("nl80211: correct checks for NL80211_MESHCONF_HT_OPMODE value")
Signed-off-by: Masashi Honma <masashi.honma@gmail.com>
[rewrite commit message to use Fixes: line]
commit a06393ed03167771246c4c43192d9c264bc48412 upstream.
When removing a bcm tx operation either a hrtimer or a tasklet might run.
As the hrtimer triggers its associated tasklet and vice versa we need to
take care to mutually terminate both handlers.
Reported-by: Michael Josenhans <michael.josenhans@web.de>
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
Tested-by: Michael Josenhans <michael.josenhans@web.de>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit 034dd34ff4916ec1f8f74e39ca3efb04eab2f791 upstream.
Olga Kornievskaia says: "I ran into this oops in the nfsd (below)
(4.10-rc3 kernel). To trigger this I had a client (unsuccessfully) try
to mount the server with krb5 where the server doesn't have the
rpcsec_gss_krb5 module built."
The problem is that rsci.cred is copied from a svc_cred structure that
gss_proxy didn't properly initialize. Fix that.
[120408.542387] general protection fault: 0000 [#1] SMP
[120408.565724] CPU: 0 PID: 3601 Comm: nfsd Not tainted 4.10.0-rc3+ #16
[120408.567037] Hardware name: VMware, Inc. VMware Virtual =
Platform/440BX Desktop Reference Platform, BIOS 6.00 07/02/2015
[120408.569225] task: ffff8800776f95c0 task.stack: ffffc90003d58000
[120408.570483] RIP: 0010:gss_mech_put+0xb/0x20 [auth_rpcgss]
[120408.584946] ? rsc_free+0x55/0x90 [auth_rpcgss]
[120408.585901] gss_proxy_save_rsc+0xb2/0x2a0 [auth_rpcgss]
[120408.587017] svcauth_gss_proxy_init+0x3cc/0x520 [auth_rpcgss]
[120408.588257] ? __enqueue_entity+0x6c/0x70
[120408.589101] svcauth_gss_accept+0x391/0xb90 [auth_rpcgss]
[120408.590212] ? try_to_wake_up+0x4a/0x360
[120408.591036] ? wake_up_process+0x15/0x20
[120408.592093] ? svc_xprt_do_enqueue+0x12e/0x2d0 [sunrpc]
[120408.593177] svc_authenticate+0xe1/0x100 [sunrpc]
[120408.594168] svc_process_common+0x203/0x710 [sunrpc]
[120408.595220] svc_process+0x105/0x1c0 [sunrpc]
[120408.596278] nfsd+0xe9/0x160 [nfsd]
[120408.597060] kthread+0x101/0x140
[120408.597734] ? nfsd_destroy+0x60/0x60 [nfsd]
[120408.598626] ? kthread_park+0x90/0x90
[120408.599448] ret_from_fork+0x22/0x30
Fixes: 1d658336b05f "SUNRPC: Add RPC based upcall mechanism for RPCGSS auth"
Cc: Simo Sorce <simo@redhat.com>
Reported-by: Olga Kornievskaia <kolga@netapp.com>
Tested-by: Olga Kornievskaia <kolga@netapp.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
[ Upstream commit f154be241d22298d2b63c9b613f619fa1086ea75 ]
Commit 448b4482c671 ("net: dsa: Add lockdep class to tx queues to avoid
lockdep splat") removed the netif_device_detach() call done in
dsa_slave_suspend() which is necessary, and paired with a corresponding
netif_device_attach(), bring it back.
Fixes: 448b4482c671 ("net: dsa: Add lockdep class to tx queues to avoid lockdep splat")
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
[ Upstream commit 85c814016ce3b371016c2c054a905fa2492f5a65 ]
When attempting to free lwtunnel state after the module for the encap
has been unloaded an oops occurs:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
IP: lwtstate_free+0x18/0x40
task: ffff88003e372380 task.stack: ffffc900001fc000
RIP: 0010:lwtstate_free+0x18/0x40
RSP: 0018:ffff88003fd83e88 EFLAGS: 00010246
RAX: 0000000000000000 RBX: ffff88002bbb3380 RCX: ffff88000c91a300
Call Trace:
<IRQ>
free_fib_info_rcu+0x195/0x1a0
? rt_fibinfo_free+0x50/0x50
rcu_process_callbacks+0x2d3/0x850
? rcu_process_callbacks+0x296/0x850
__do_softirq+0xe4/0x4cb
irq_exit+0xb0/0xc0
smp_apic_timer_interrupt+0x3d/0x50
apic_timer_interrupt+0x93/0xa0
Code: e8 6e c6 fc ff 89 d8 5b 5d c3 bb de ff ff ff eb f4 66 90 66 66 66 66 90 55 48 89 e5 53 0f b7 07 48 89 fb 48 8b 04 c5 00 81 d5 81 <48> 8b 40 08 48 85 c0 74 13 ff d0 48 8d 7b 20 be 20 00 00 00 e8
The problem is after the module for the encap can be unloaded the
corresponding ops is removed and is thus NULL here.
Modules implementing lwtunnel ops should not be allowed to unload
while there is state alive using those ops, so grab the module
reference for the ops on creating lwtunnel state and of course release
the reference when freeing the state.
Fixes: 1104d9ba443a ("lwtunnel: Add destroy state operation")
Signed-off-by: Robert Shearman <rshearma@brocade.com>
[ Upstream commit 88ff7334f25909802140e690c0e16433e485b0a0 ]
while there is state alive using those ops, so specify the owning
module for all lwtunnel ops.
[ Upstream commit 0fb44559ffd67de8517098b81f675fa0210f13f0 ]
Dmitry reported a deadlock scenario:
unix_bind() path:
u->bindlock ==> sb_writer
do_splice() path:
sb_writer ==> pipe->mutex ==> u->bindlock
In the unix_bind() code path, unix_mknod() does not have to
be done with u->bindlock held, since it is a pure fs operation,
so we can just move unix_mknod() out.
Tested-by: Dmitry Vyukov <dvyukov@google.com>
Cc: Rainer Weikusat <rweikusat@mobileactivedefense.com>
[ Upstream commit 9f427a0e474a67b454420c131709600d44850486 ]
MPLS multipath for LSR is broken -- always selecting the first nexthop
in the one label case. For example:
$ ip -f mpls ro ls
100
nexthop as to 200 via inet 172.16.2.2 dev virt12
nexthop as to 300 via inet 172.16.3.2 dev virt13
101
nexthop as to 201 via inet6 2000:2::2 dev virt12
nexthop as to 301 via inet6 2000:3::2 dev virt13
In this example incoming packets have a single MPLS labels which means
BOS bit is set. The BOS bit is passed from mpls_forward down to
mpls_multipath_hash which never processes the hash loop because BOS is 1.
Update mpls_multipath_hash to process the entire label stack. mpls_hdr_len
tracks the total mpls header length on each pass (on pass N mpls_hdr_len
is N * sizeof(mpls_shim_hdr)). When the label is found with the BOS set
it verifies the skb has sufficient header for ipv4 or ipv6, and find the
IPv4 and IPv6 header by using the last mpls_hdr pointer and adding 1 to
advance past it.
With these changes I have verified the code correctly sees the label,
BOS, IPv4 and IPv6 addresses in the network header and icmp/tcp/udp
traffic for ipv4 and ipv6 are distributed across the nexthops.
Fixes: 1c78efa8319ca ("mpls: flow-based multipath selection")
Acked-by: Robert Shearman <rshearma@brocade.com>
Signed-off-by: David Ahern <dsa@cumulusnetworks.com>
[ Upstream commit b6677449dff674cf5b81429b11d5c7f358852ef9 ]
Any bridge options specified during link creation (e.g. ip link add)
are ignored as br_dev_newlink() does not process them.
Use br_changelink() to do it.
Fixes: 133235161721 ("bridge: implement rtnl_link_ops->changelink")
Signed-off-by: Ivan Vecera <cera@cera.cz>
Reviewed-by: Jiri Pirko <jiri@mellanox.com>
[ Upstream commit 0dbd7ff3ac5017a46033a9d0a87a8267d69119d9 ]
Found that if we run LTP netstress test with large MSS (65K),
the first attempt from server to send data comparable to this
MSS on fastopen connection will be delayed by the probe timer.
Here is an example:
< S seq 0:0 win 43690 options [mss 65495 wscale 7 tfo cookie] length 32
> S. seq 0:0 ack 1 win 43690 options [mss 65495 wscale 7] length 0
< . ack 1 win 342 length 0
Inside tcp_sendmsg(), tcp_send_mss() returns max MSS in 'mss_now',
as well as in 'size_goal'. This results the segment not queued for
transmition until all the data copied from user buffer. Then, inside
__tcp_push_pending_frames(), it breaks on send window test and
continues with the check probe timer.
Fragmentation occurs in tcp_write_wakeup()...
+0.2 > P. seq 1:43777 ack 1 win 342 length 43776
< . ack 43777, win 1365 length 0
> P. seq 43777:65001 ack 1 win 342 options [...] length 21224
This also contradicts with the fact that we should bound to the half
of the window if it is large.
Fix this flaw by correctly initializing max_window. Before that, it
could have large values that affect further calculations of 'size_goal'.
Fixes: 168a8f58059a ("tcp: TCP Fast Open Server - main code path")
Signed-off-by: Alexey Kodanev <alexey.kodanev@oracle.com>
[ Upstream commit 03e4deff4987f79c34112c5ba4eb195d4f9382b0 ]
Just like commit 4acd4945cd1e ("ipv6: addrconf: Avoid calling
netdevice notifiers with RCU read-side lock"), it is unnecessary
to make addrconf_disable_change() use RCU iteration over the
netdev list, since it already holds the RTNL lock, or we may meet
Illegal context switch in RCU read-side critical section.
Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com>
[ Upstream commit 9ed59592e3e379b2e9557dc1d9e9ec8fcbb33f16]
Trying to add an mpls encap route when the MPLS modules are not loaded
hangs. For example:
CONFIG_MPLS=y
CONFIG_NET_MPLS_GSO=m
CONFIG_MPLS_ROUTING=m
CONFIG_MPLS_IPTUNNEL=m
$ ip route add 10.10.10.10/32 encap mpls 100 via inet 10.100.1.2
The ip command hangs:
root 880 826 0 21:25 pts/0 00:00:00 ip route add 10.10.10.10/32 encap mpls 100 via inet 10.100.1.2
$ cat /proc/880/stack
[<ffffffff81065a9b>] call_usermodehelper_exec+0xd6/0x134
[<ffffffff81065efc>] __request_module+0x27b/0x30a
[<ffffffff814542f6>] lwtunnel_build_state+0xe4/0x178
[<ffffffff814aa1e4>] fib_create_info+0x47f/0xdd4
[<ffffffff814ae451>] fib_table_insert+0x90/0x41f
[<ffffffff814a8010>] inet_rtm_newroute+0x4b/0x52
modprobe is trying to load rtnl-lwt-MPLS:
root 881 5 0 21:25 ? 00:00:00 /sbin/modprobe -q -- rtnl-lwt-MPLS
and it hangs after loading mpls_router:
$ cat /proc/881/stack
[<ffffffff81441537>] rtnl_lock+0x12/0x14
[<ffffffff8142ca2a>] register_netdevice_notifier+0x16/0x179
[<ffffffffa0033025>] mpls_init+0x25/0x1000 [mpls_router]
[<ffffffff81000471>] do_one_initcall+0x8e/0x13f
[<ffffffff81119961>] do_init_module+0x5a/0x1e5
[<ffffffff810bd070>] load_module+0x13bd/0x17d6
The problem is that lwtunnel_build_state is called with rtnl lock
held preventing mpls_init from registering.
Given the potential references held by the time lwtunnel_build_state it
can not drop the rtnl lock to the load module. So, extract the module
loading code from lwtunnel_build_state into a new function to validate
the encap type. The new function is called while converting the user
request into a fib_config which is well before any table, device or
fib entries are examined.
Fixes: 745041e2aaf1 ("lwtunnel: autoload of lwt modules")
[ Upstream commit 7be2c82cfd5d28d7adb66821a992604eb6dd112e ]
Ashizuka reported a highmem oddity and sent a patch for freescale
fec driver.
But the problem root cause is that core networking stack
must ensure no skb with highmem fragment is ever sent through
a device that does not assert NETIF_F_HIGHDMA in its features.
We need to call illegal_highdma() from harmonize_features()
regardless of CSUM checks.
Fixes: ec5f06156423 ("net: Kill link between CSUM and SG features.")
Cc: Pravin Shelar <pshelar@ovn.org>
Reported-by: "Ashizuka, Yuusuke" <ashiduka@jp.fujitsu.com>
[ Upstream commit 6391a4481ba0796805d6581e42f9f0418c099e34 ]
Commit 501db511397f ("virtio: don't set VIRTIO_NET_HDR_F_DATA_VALID on
xmit") in fact disables VIRTIO_HDR_F_DATA_VALID on receiving path too,
fixing this by adding a hint (has_data_valid) and set it only on the
receiving path.
Cc: Rolf Neugebauer <rolf.neugebauer@docker.com>
Signed-off-by: Jason Wang <jasowang@redhat.com>
Acked-by: Rolf Neugebauer <rolf.neugebauer@docker.com>
[ Upstream commit 0faa9cb5b3836a979864a6357e01d2046884ad52 ]
Demonstrating the issue:
.. add a drop action
$sudo $TC actions add action drop index 10
.. retrieve it
$ sudo $TC -s actions get action gact index 10
action order 1: gact action drop
random type none pass val 0
index 10 ref 2 bind 0 installed 29 sec used 29 sec
Action statistics:
Sent 0 bytes 0 pkt (dropped 0, overlimits 0 requeues 0)
backlog 0b 0p requeues 0
... bug 1 above: reference is two.
Reference is actually 1 but we forget to subtract 1.
... do a GET again and we see the same issue
try a few times and nothing changes
~$ sudo $TC -s actions get action gact index 10
index 10 ref 2 bind 0 installed 31 sec used 31 sec
Action statistics:
... lets try to bind the action to a filter..
$ sudo $TC qdisc add dev lo ingress
$ sudo $TC filter add dev lo parent ffff: protocol ip prio 1 \
u32 match ip dst 127.0.0.1/32 flowid 1:1 action gact index 10
... and now a few GETs:
index 10 ref 3 bind 1 installed 204 sec used 204 sec
Action statistics:
index 10 ref 4 bind 1 installed 206 sec used 206 sec
Action statistics:
index 10 ref 5 bind 1 installed 235 sec used 235 sec
Action statistics:
.... as can be observed the reference count keeps going up.
After the fix
$ sudo $TC actions add action drop index 10
index 10 ref 1 bind 0 installed 4 sec used 4 sec
Action statistics:
index 10 ref 1 bind 0 installed 6 sec used 6 sec
Action statistics:
index 10 ref 2 bind 1 installed 32 sec used 32 sec
Action statistics:
index 10 ref 2 bind 1 installed 33 sec used 33 sec
Action statistics:
Fixes: aecc5cefc389 ("net sched actions: fix GETing actions")
Signed-off-by: Jamal Hadi Salim <jhs@mojatatu.com>
[ Upstream commit 8a367e74c0120ef68c8c70d5a025648c96626dff ]
The ax.25 socket connection timed out & the sock struct has been
previously taken down ie. sock struct is now a NULL pointer. Checking
the sock_flag causes the segfault. Check if the socket struct pointer
is NULL before checking sock_flag. This segfault is seen in
timed out netrom connections.
Please submit to -stable.
Signed-off-by: Basil Gunn <basil@pacabunga.com>
[ Upstream commit 02ca0423fd65a0a9c4d70da0dbb8f4b8503f08c7 ]
With ip6gre we have a tunnel header which also makes the tunnel MTU
smaller. We need to reserve room for it. Previously we were using up
space reserved for the Tunnel Encapsulation Limit option
header (RFC 2473).
Also, after commit b05229f44228 ("gre6: Cleanup GREv6 transmit path,
call common GRE functions") our contract with the caller has
changed. Now we check if the packet length exceeds the tunnel MTU after
the tunnel header has been pushed, unlike before.
This is reflected in the check where we look at the packet length minus
the size of the tunnel header, which is already accounted for in tunnel
MTU.
Fixes: b05229f44228 ("gre6: Cleanup GREv6 transmit path, call common GRE functions")
Signed-off-by: Jakub Sitnicki <jkbs@redhat.com>
[ Upstream commit 75f01a4c9cc291ff5cb28ca1216adb163b7a20ee ]
When executing conntrack actions on skbuffs with checksum mode
CHECKSUM_COMPLETE, the checksum must be updated to account for
header pushes and pulls. Otherwise we get "hw csum failure"
logs similar to this (ICMP packet received on geneve tunnel
via ixgbe NIC):
[ 405.740065] genev_sys_6081: hw csum failure
[ 405.740106] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G I 4.10.0-rc3+ #1
[ 405.740108] Call Trace:
[ 405.740110] <IRQ>
[ 405.740113] dump_stack+0x63/0x87
[ 405.740116] netdev_rx_csum_fault+0x3a/0x40
[ 405.740118] __skb_checksum_complete+0xcf/0xe0
[ 405.740120] nf_ip_checksum+0xc8/0xf0
[ 405.740124] icmp_error+0x1de/0x351 [nf_conntrack_ipv4]
[ 405.740132] nf_conntrack_in+0xe1/0x550 [nf_conntrack]
[ 405.740137] ? find_bucket.isra.2+0x62/0x70 [openvswitch]
[ 405.740143] __ovs_ct_lookup+0x95/0x980 [openvswitch]
[ 405.740145] ? netif_rx_internal+0x44/0x110
[ 405.740149] ovs_ct_execute+0x147/0x4b0 [openvswitch]
[ 405.740153] do_execute_actions+0x22e/0xa70 [openvswitch]
[ 405.740157] ovs_execute_actions+0x40/0x120 [openvswitch]
[ 405.740161] ovs_dp_process_packet+0x84/0x120 [openvswitch]
[ 405.740166] ovs_vport_receive+0x73/0xd0 [openvswitch]
[ 405.740168] ? udp_rcv+0x1a/0x20
[ 405.740170] ? ip_local_deliver_finish+0x93/0x1e0
[ 405.740172] ? ip_local_deliver+0x6f/0xe0
[ 405.740174] ? ip_rcv_finish+0x3a0/0x3a0
[ 405.740176] ? ip_rcv_finish+0xdb/0x3a0
[ 405.740177] ? ip_rcv+0x2a7/0x400
[ 405.740180] ? __netif_receive_skb_core+0x970/0xa00
[ 405.740185] netdev_frame_hook+0xd3/0x160 [openvswitch]
[ 405.740187] __netif_receive_skb_core+0x1dc/0xa00
[ 405.740194] ? ixgbe_clean_rx_irq+0x46d/0xa20 [ixgbe]
[ 405.740197] __netif_receive_skb+0x18/0x60
[ 405.740199] netif_receive_skb_internal+0x40/0xb0
[ 405.740201] napi_gro_receive+0xcd/0x120
[ 405.740204] gro_cell_poll+0x57/0x80 [geneve]
[ 405.740206] net_rx_action+0x260/0x3c0
[ 405.740209] __do_softirq+0xc9/0x28c
[ 405.740211] irq_exit+0xd9/0xf0
[ 405.740213] do_IRQ+0x51/0xd0
[ 405.740215] common_interrupt+0x93/0x93
Fixes: 7f8a436eaa2c ("openvswitch: Add conntrack action")
Signed-off-by: Lance Richardson <lrichard@redhat.com>
Acked-by: Pravin B Shelar <pshelar@ovn.org>
[ Upstream commit 003c941057eaa868ca6fedd29a274c863167230d ]
Fix up a data alignment issue on sparc by swapping the order
of the cookie byte array field with the length field in
struct tcp_fastopen_cookie, and making it a proper union
to clean up the typecasting.
This addresses log complaints like these:
log_unaligned: 113 callbacks suppressed
Kernel unaligned access at TPC[976490] tcp_try_fastopen+0x2d0/0x360
Kernel unaligned access at TPC[9764ac] tcp_try_fastopen+0x2ec/0x360
Kernel unaligned access at TPC[9764c8] tcp_try_fastopen+0x308/0x360
Kernel unaligned access at TPC[9764e4] tcp_try_fastopen+0x324/0x360
Signed-off-by: Shannon Nelson <shannon.nelson@oracle.com>
[ Upstream commit 8a430ed50bb1b19ca14a46661f3b1b35f2fb5c39 ]
rtm_table is an 8-bit field while table ids are allowed up to u32. Commit
709772e6e065 ("net: Fix routing tables with id > 255 for legacy software")
added the preference to set rtm_table in dumps to RT_TABLE_COMPAT if the
table id is > 255. The table id returned on get route requests should do
the same.
Fixes: c36ba6603a11 ("net: Allow user to get table id from route lookup")
[ Upstream commit ea7a80858f57d8878b1499ea0f1b8a635cc48de7 ]
Handle failure in lwtunnel_fill_encap adding attributes to skb.
Fixes: 571e722676fe ("ipv4: support for fib route lwtunnel encap attributes")
Fixes: 19e42e451506 ("ipv6: support for fib route lwtunnel encap attributes")
commit c929ea0b910355e1876c64431f3d5802f95b3d75 upstream.
After removing sunrpc module, I get many kmemleak information as,
unreferenced object 0xffff88003316b1e0 (size 544):
comm "gssproxy", pid 2148, jiffies 4294794465 (age 4200.081s)
hex dump (first 32 bytes):
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<ffffffffb0cfb58a>] kmemleak_alloc+0x4a/0xa0
[<ffffffffb03507fe>] kmem_cache_alloc+0x15e/0x1f0
[<ffffffffb0639baa>] ida_pre_get+0xaa/0x150
[<ffffffffb0639cfd>] ida_simple_get+0xad/0x180
[<ffffffffc06054fb>] nlmsvc_lookup_host+0x4ab/0x7f0 [lockd]
[<ffffffffc0605e1d>] lockd+0x4d/0x270 [lockd]
[<ffffffffc06061e5>] param_set_timeout+0x55/0x100 [lockd]
[<ffffffffc06cba24>] svc_defer+0x114/0x3f0 [sunrpc]
[<ffffffffc06cbbe7>] svc_defer+0x2d7/0x3f0 [sunrpc]
[<ffffffffc06c71da>] rpc_show_info+0x8a/0x110 [sunrpc]
[<ffffffffb044a33f>] proc_reg_write+0x7f/0xc0
[<ffffffffb038e41f>] __vfs_write+0xdf/0x3c0
[<ffffffffb0390f1f>] vfs_write+0xef/0x240
[<ffffffffb0392fbd>] SyS_write+0xad/0x130
[<ffffffffb0d06c37>] entry_SYSCALL_64_fastpath+0x1a/0xa9
[<ffffffffffffffff>] 0xffffffffffffffff
I found, the ida information (dynamic memory) isn't cleanup.
Signed-off-by: Kinglong Mee <kinglongmee@gmail.com>
Fixes: 2f048db4680a ("SUNRPC: Add an identifier for struct rpc_clnt")
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit 7af3ea189a9a13f090de51c97f676215dabc1205 upstream.
This is useless and more importantly not allowed on the writeback path,
because crypto_alloc_skcipher() allocates memory with GFP_KERNEL, which
can recurse back into the filesystem:
kworker/9:3 D ffff92303f318180 0 20732 2 0x00000080
Workqueue: ceph-msgr ceph_con_workfn [libceph]
ffff923035dd4480 ffff923038f8a0c0 0000000000000001 000000009eb27318
ffff92269eb28000 ffff92269eb27338 ffff923036b145ac ffff923035dd4480
00000000ffffffff ffff923036b145b0 ffffffff951eb4e1 ffff923036b145a8
Call Trace:
[<ffffffff951eb4e1>] ? schedule+0x31/0x80
[<ffffffff951eb77a>] ? schedule_preempt_disabled+0xa/0x10
[<ffffffff951ed1f4>] ? __mutex_lock_slowpath+0xb4/0x130
[<ffffffff951ed28b>] ? mutex_lock+0x1b/0x30
[<ffffffffc0a974b3>] ? xfs_reclaim_inodes_ag+0x233/0x2d0 [xfs]
[<ffffffff94d92ba5>] ? move_active_pages_to_lru+0x125/0x270
[<ffffffff94f2b985>] ? radix_tree_gang_lookup_tag+0xc5/0x1c0
[<ffffffff94dad0f3>] ? __list_lru_walk_one.isra.3+0x33/0x120
[<ffffffffc0a98331>] ? xfs_reclaim_inodes_nr+0x31/0x40 [xfs]
[<ffffffff94e05bfe>] ? super_cache_scan+0x17e/0x190
[<ffffffff94d919f3>] ? shrink_slab.part.38+0x1e3/0x3d0
[<ffffffff94d9616a>] ? shrink_node+0x10a/0x320
[<ffffffff94d96474>] ? do_try_to_free_pages+0xf4/0x350
[<ffffffff94d967ba>] ? try_to_free_pages+0xea/0x1b0
[<ffffffff94d863bd>] ? __alloc_pages_nodemask+0x61d/0xe60
[<ffffffff94ddf42d>] ? cache_grow_begin+0x9d/0x560
[<ffffffff94ddfb88>] ? fallback_alloc+0x148/0x1c0
[<ffffffff94ed84e7>] ? __crypto_alloc_tfm+0x37/0x130
[<ffffffff94de09db>] ? __kmalloc+0x1eb/0x580
[<ffffffffc09fe2db>] ? crush_choose_firstn+0x3eb/0x470 [libceph]
[<ffffffff94ed9c19>] ? crypto_spawn_tfm+0x39/0x60
[<ffffffffc08b30a3>] ? crypto_cbc_init_tfm+0x23/0x40 [cbc]
[<ffffffff94ed857c>] ? __crypto_alloc_tfm+0xcc/0x130
[<ffffffff94edcc23>] ? crypto_skcipher_init_tfm+0x113/0x180
[<ffffffff94ed7cc3>] ? crypto_create_tfm+0x43/0xb0
[<ffffffff94ed83b0>] ? crypto_larval_lookup+0x150/0x150
[<ffffffff94ed7da2>] ? crypto_alloc_tfm+0x72/0x120
[<ffffffffc0a01dd7>] ? ceph_aes_encrypt2+0x67/0x400 [libceph]
[<ffffffffc09fd264>] ? ceph_pg_to_up_acting_osds+0x84/0x5b0 [libceph]
[<ffffffff950d40a0>] ? release_sock+0x40/0x90
[<ffffffff95139f94>] ? tcp_recvmsg+0x4b4/0xae0
[<ffffffffc0a02714>] ? ceph_encrypt2+0x54/0xc0 [libceph]
[<ffffffffc0a02b4d>] ? ceph_x_encrypt+0x5d/0x90 [libceph]
[<ffffffffc0a02bdf>] ? calcu_signature+0x5f/0x90 [libceph]
[<ffffffffc0a02ef5>] ? ceph_x_sign_message+0x35/0x50 [libceph]
[<ffffffffc09e948c>] ? prepare_write_message_footer+0x5c/0xa0 [libceph]
[<ffffffffc09ecd18>] ? ceph_con_workfn+0x2258/0x2dd0 [libceph]
[<ffffffffc09e9903>] ? queue_con_delay+0x33/0xd0 [libceph]
[<ffffffffc09f68ed>] ? __submit_request+0x20d/0x2f0 [libceph]
[<ffffffffc09f6ef8>] ? ceph_osdc_start_request+0x28/0x30 [libceph]
[<ffffffffc0b52603>] ? rbd_queue_workfn+0x2f3/0x350 [rbd]
[<ffffffff94c94ec0>] ? process_one_work+0x160/0x410
[<ffffffff94c951bd>] ? worker_thread+0x4d/0x480
[<ffffffff94c95170>] ? process_one_work+0x410/0x410
[<ffffffff94c9af8d>] ? kthread+0xcd/0xf0
[<ffffffff951efb2f>] ? ret_from_fork+0x1f/0x40
[<ffffffff94c9aec0>] ? kthread_create_on_node+0x190/0x190
Allocating the cipher along with the key fixes the issue - as long the
key doesn't change, a single cipher context can be used concurrently in
multiple requests.
We still can't take that GFP_KERNEL allocation though. Both
ceph_crypto_key_clone() and ceph_crypto_key_decode() are called from
GFP_NOFS context, so resort to memalloc_noio_{save,restore}() here.
Reported-by: Lucas Stach <l.stach@pengutronix.de>
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
Reviewed-by: Sage Weil <sage@redhat.com>
commit 6db2304aabb070261ad34923bfd83c43dfb000e3 upstream.
commit 6d6bf72de914059b304f7b99530a7856e5c846aa upstream.
Clean up: This message was intended to be a dprintk, as it is on the
server-side.
Fixes: 87cfb9a0c85c ('xprtrdma: Client-side support for ...')
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
commit 8d38de65644d900199f035277aa5f3da4aa9fc17 upstream.
Verbs providers may perform house-keeping on the Send Queue during
each signaled send completion. It is necessary therefore for a verbs
consumer (like xprtrdma) to occasionally force a signaled send
completion if it runs unsignaled most of the time.
xprtrdma does not require signaled completions for Send or FastReg
Work Requests, but does signal some LocalInv Work Requests. To
ensure that Send Queue house-keeping can run before the Send Queue
is more than half-consumed, xprtrdma forces a signaled completion
on occasion by counting the number of Send Queue Entries it
consumes. It currently does this by counting each ib_post_send as
one Entry.
Commit c9918ff56dfb ("xprtrdma: Add ro_unmap_sync method for FRWR")
introduced the ability for frwr_op_unmap_sync to post more than one
Work Request with a single post_send. Thus the underlying assumption
of one Send Queue Entry per ib_post_send is no longer true.
Also, FastReg Work Requests are currently never signaled. They
should be signaled once in a while, just as Send is, to keep the
accounting of consumed SQEs accurate.
While we're here, convert the CQCOUNT macros to the currently
preferred kernel coding style, which is inline functions.
Fixes: c9918ff56dfb ("xprtrdma: Add ro_unmap_sync method for FRWR")
commit 124f930b8cbc4ac11236e6eb1c5f008318864588 upstream.
... otherwise the crypto stack will align it for us with a GFP_ATOMIC
allocation and a memcpy() -- see skcipher_walk_first().
