path: root/net
2010-12-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (75 commits) pppoe.c: Fix kernel panic caused by __pppoe_xmit WAN: Fix a TX IRQ causing BUG() in PC300 and PCI200SYN drivers. bnx2x: Advance a version number to 1.60.01-0 bnx2x: Fixed a compilation warning bnx2x: LSO code was broken on BE platforms qlge: Fix deadlock when cancelling worker. net: fix skb_defer_rx_timestamp() cxgb4vf: Ingress Queue Entry Size needs to be 64 bytes phy: add the IC+ IP1001 driver atm: correct sysfs 'device' link creation and parent relationships MAINTAINERS: remove me from tulip SCTP: Fix SCTP_SET_PEER_PRIMARY_ADDR to accpet v4mapped address enic: Bug Fix: Pass napi reference to the isr that services receive queue ipv6: fix nl group when advertising a new link connector: add module alias net: Document the kernel_recvmsg() function r8169: Fix runtime power management hso: IP checksuming doesn't work on GE0301 option cards xfrm: Fix xfrm_state_migrate leak net: Convert netpoll blocking api in bonding driver to be a counter ...
2010-12-10net: fix skb_defer_rx_timestamp()Eric Dumazet
After commit c1f19b51d1d8 (net: support time stamping in phy devices.), kernel might crash if CONFIG_NETWORK_PHY_TIMESTAMPING=y and skb_defer_rx_timestamp() handles a packet without an ethernet header. Fixes kernel bugzilla #24102 Reference: https://bugzilla.kernel.org/show_bug.cgi?id=24102 Reported-and-tested-by: Andrew Watts <akwatts@ymail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-10atm: correct sysfs 'device' link creation and parent relationshipsDan Williams
The ATM subsystem was incorrectly creating the 'device' link for ATM nodes in sysfs. This led to incorrect device/parent relationships exposed by sysfs and udev. Instead of rolling the 'device' link by hand in the generic ATM code, pass each ATM driver's bus device down to the sysfs code and let sysfs do this stuff correctly. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-10SCTP: Fix SCTP_SET_PEER_PRIMARY_ADDR to accpet v4mapped addressWei Yongjun
SCTP_SET_PEER_PRIMARY_ADDR does not accpet v4mapped address, using v4mapped address in SCTP_SET_PEER_PRIMARY_ADDR socket option will get -EADDRNOTAVAIL error if v4map is enabled. This patch try to fix it by mapping v4mapped address to v4 address if allowed. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-10Merge branch 'master' of ↵David S. Miller
2010-12-10ipv6: fix nl group when advertising a new linkNicolas Dichtel
New idev are advertised with NL group RTNLGRP_IPV6_IFADDR, but should use RTNLGRP_IPV6_IFINFO. Bug was introduced by commit 8d7a76c9. Signed-off-by: Wang Xuefu <xuefu.wang@6wind.com> Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Thomas Graf <tgraf@infradead.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-10net: Document the kernel_recvmsg() functionMartin Lucina
Signed-off-by: Martin Lucina <mato@kotelna.sk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-09xfrm: Fix xfrm_state_migrate leakThomas Egerer
xfrm_state_migrate calls kfree instead of xfrm_state_put to free a failed state. According to git commit 553f9118 this can cause memory leaks. Signed-off-by: Thomas Egerer <thomas.egerer@secunet.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-08econet: Fix crash in aun_incoming().David S. Miller
Unconditional use of skb->dev won't work here, try to fetch the econet device via skb_dst()->dev instead. Suggested by Eric Dumazet. Reported-by: Nelson Elhage <nelhage@ksplice.com> Tested-by: Nelson Elhage <nelhage@ksplice.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-08tcp: protect sysctl_tcp_cookie_size readsEric Dumazet
Make sure sysctl_tcp_cookie_size is read once in tcp_cookie_size_check(), or we might return an illegal value to caller if sysctl_tcp_cookie_size is changed by another cpu. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ben Hutchings <bhutchings@solarflare.com> Cc: William Allen Simpson <william.allen.simpson@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-08tcp: avoid a possible divide by zeroEric Dumazet
sysctl_tcp_tso_win_divisor might be set to zero while one cpu runs in tcp_tso_should_defer(). Make sure we dont allow a divide by zero by reading sysctl_tcp_tso_win_divisor exactly once. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-08mac80211: Fix BUG in pskb_expand_head when transmitting shared skbsHelmut Schaa
mac80211 doesn't handle shared skbs correctly at the moment. As a result a possible resize can trigger a BUG in pskb_expand_head. [ 676.030000] Kernel bug detected[#1]: [ 676.030000] Cpu 0 [ 676.030000] $ 0 : 00000000 00000000 819662ff 00000002 [ 676.030000] $ 4 : 81966200 00000020 00000000 00000020 [ 676.030000] $ 8 : 819662e0 800043c0 00000002 00020000 [ 676.030000] $12 : 3b9aca00 00000000 00000000 00470000 [ 676.030000] $16 : 80ea2000 00000000 00000000 00000000 [ 676.030000] $20 : 818aa200 80ea2018 80ea2000 00000008 [ 676.030000] $24 : 00000002 800ace5c [ 676.030000] $28 : 8199a000 8199bd20 81938f88 80f180d4 [ 676.030000] Hi : 0000026e [ 676.030000] Lo : 0000757e [ 676.030000] epc : 801245e4 pskb_expand_head+0x44/0x1d8 [ 676.030000] Not tainted [ 676.030000] ra : 80f180d4 ieee80211_skb_resize+0xb0/0x114 [mac80211] [ 676.030000] Status: 1000a403 KERNEL EXL IE [ 676.030000] Cause : 10800024 [ 676.030000] PrId : 0001964c (MIPS 24Kc) [ 676.030000] Modules linked in: mac80211_hwsim rt2800lib rt2x00soc rt2x00pci rt2x00lib mac80211 crc_itu_t crc_ccitt cfg80211 compat arc4 aes_generic deflate ecb cbc [last unloaded: rt2800pci] [ 676.030000] Process kpktgend_0 (pid: 97, threadinfo=8199a000, task=81879f48, tls=00000000) [ 676.030000] Stack : ffffffff 00000000 00000000 00000014 00000004 80ea2000 00000000 00000000 [ 676.030000] 818aa200 80f180d4 ffffffff 0000000a 81879f78 81879f48 81879f48 00000018 [ 676.030000] 81966246 80ea2000 818432e0 80f1a420 80203050 81814d98 00000001 81879f48 [ 676.030000] 81879f48 00000018 81966246 818432e0 0000001a 8199bdd4 0000001c 80f1b72c [ 676.030000] 80203020 8001292c 80ef4aa2 7f10b55d 801ab5b8 81879f48 00000188 80005c90 [ 676.030000] ... [ 676.030000] Call Trace: [ 676.030000] [<801245e4>] pskb_expand_head+0x44/0x1d8 [ 676.030000] [<80f180d4>] ieee80211_skb_resize+0xb0/0x114 [mac80211] [ 676.030000] [<80f1a420>] ieee80211_xmit+0x150/0x22c [mac80211] [ 676.030000] [<80f1b72c>] ieee80211_subif_start_xmit+0x6f4/0x73c [mac80211] [ 676.030000] [<8014361c>] pktgen_thread_worker+0xfac/0x16f8 [ 676.030000] [<8002ebe8>] kthread+0x7c/0x88 [ 676.030000] [<80008e0c>] kernel_thread_helper+0x10/0x18 [ 676.030000] [ 676.030000] [ 676.030000] Code: 24020001 10620005 2502001f <0200000d> 0804917a 00000000 2502001f 00441023 00531021 Fix this by making a local copy of shared skbs prior to mangeling them. To avoid copying the skb unnecessarily move the skb_copy call below the checks that don't need write access to the skb. Also, move the assignment of nh_pos and h_pos below the skb_copy to point to the correct skb. It would be possible to avoid another resize of the copied skb by using skb_copy_expand instead of skb_copy but that would make the patch more complex. Also, shared skbs are a corner case right now, so the resize shouldn't matter much. Cc: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com> Cc: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-08tcp: Replace time wait bucket msg by counterTom Herbert
Rather than printing the message to the log, use a mib counter to keep track of the count of occurences of time wait bucket overflow. Reduces spam in logs. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-08x25: decrement netdev reference counts on unloadApollon Oikonomopoulos
x25 does not decrement the network device reference counts on module unload. Thus unregistering any pre-existing interface after unloading the x25 module hangs and results in unregister_netdevice: waiting for tap0 to become free. Usage count = 1 This patch decrements the reference counts of all interfaces in x25_link_free, the way it is already done in x25_link_device_down for NETDEV_DOWN events. Signed-off-by: Apollon Oikonomopoulos <apollon@noc.grnet.gr> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-08l2tp: Fix modalias of l2tp_ipMichal Marek
Using the SOCK_DGRAM enum results in "net-pf-2-proto-SOCK_DGRAM-type-115", so use the numeric value like it is done in net/dccp. Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-08econet: Do the correct cleanup after an unprivileged SIOCSIFADDR.Nelson Elhage
We need to drop the mutex and do a dev_put, so set an error code and break like the other paths, instead of returning directly. Signed-off-by: Nelson Elhage <nelhage@ksplice.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-08llc: fix a device refcount imbalanceEric Dumazet
Le dimanche 05 décembre 2010 à 12:23 +0100, Eric Dumazet a écrit : > Le dimanche 05 décembre 2010 à 09:19 +0100, Eric Dumazet a écrit : > > > Hmm.. > > > > If somebody can explain why RTNL is held in arp_ioctl() (and therefore > > in arp_req_delete()), we might first remove RTNL use in arp_ioctl() so > > that your patch can be applied. > > > > Right now it is not good, because RTNL wont be necessarly held when you > > are going to call arp_invalidate() ? > > While doing this analysis, I found a refcount bug in llc, I'll send a > patch for net-2.6 Oh well, of course I must first fix the bug in net-2.6, and wait David pull the fix in net-next-2.6 before sending this rcu conversion. Note: this patch should be sent to stable teams (2.6.34 and up) [PATCH net-2.6] llc: fix a device refcount imbalance commit abf9d537fea225 (llc: add support for SO_BINDTODEVICE) added one refcount imbalance in llc_ui_bind(), because dev_getbyhwaddr() doesnt take a reference on device, while dev_get_by_index() does. Fix this using RCU locking. And since an RCU conversion will be done for 2.6.38 for dev_getbyhwaddr(), put the rcu_read_lock/unlock exactly at their final place. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: stable@kernel.org Cc: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-08tcp: Bug fix in initialization of receive window.Nandita Dukkipati
The bug has to do with boundary checks on the initial receive window. If the initial receive window falls between init_cwnd and the receive window specified by the user, the initial window is incorrectly brought down to init_cwnd. The correct behavior is to allow it to remain unchanged. Signed-off-by: Nandita Dukkipati <nanditad@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-08Merge branch 'master' of ↵David S. Miller
2010-12-07sunrpc: prevent use-after-free on clearing XPT_BUSYNeilBrown
When an xprt is created, it has a refcount of 1, and XPT_BUSY is set. The refcount is *not* owned by the thread that created the xprt (as is clear from the fact that creators never put the reference). Rather, it is owned by the absence of XPT_DEAD. Once XPT_DEAD is set, (And XPT_BUSY is clear) that initial reference is dropped and the xprt can be freed. So when a creator clears XPT_BUSY it is dropping its only reference and so must not touch the xprt again. However svc_recv, after calling ->xpo_accept (and so getting an XPT_BUSY reference on a new xprt), calls svc_xprt_recieved. This clears XPT_BUSY and then svc_xprt_enqueue - this last without owning a reference. This is dangerous and has been seen to leave svc_xprt_enqueue working with an xprt containing garbage. So we need to hold an extra counted reference over that call to svc_xprt_received. For safety, any time we clear XPT_BUSY and then use the xprt again, we first get a reference, and the put it again afterwards. Note that svc_close_all does not need this extra protection as there are no threads running, and the final free can only be called asynchronously from such a thread. Signed-off-by: NeilBrown <neilb@suse.de> Cc: stable@kernel.org Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-12-06filter: fix sk_filter rcu handlingEric Dumazet
Pavel Emelyanov tried to fix a race between sk_filter_(de|at)tach and sk_clone() in commit 47e958eac280c263397 Problem is we can have several clones sharing a common sk_filter, and these clones might want to sk_filter_attach() their own filters at the same time, and can overwrite old_filter->rcu, corrupting RCU queues. We can not use filter->rcu without being sure no other thread could do the same thing. Switch code to a more conventional ref-counting technique : Do the atomic decrement immediately and queue one rcu call back when last reference is released. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02leds: fix up dependenciesJohannes Berg
It's not useful to build LED triggers when there's no LEDs that can be triggered by them. Therefore, fix up the dependencies so that this cannot happen, and fix a few users that select triggers to depend on LEDS_CLASS as well (there is also one user that also selects LEDS_CLASS, which is OK). Signed-off-by: Johannes Berg <johannes.berg@intel.com> Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Tested-by: Ingo Molnar <mingo@elte.hu> Cc: Arnd Hannemann <arnd@arndnet.de> Cc: Michal Hocko <mhocko@suse.cz> Cc: Richard Purdie <rpurdie@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-02Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/padovan/bluetooth-2.6
2010-12-01net/ipv6/sit.c: return unhandled skb to tunnel4_rcvDavid McCullough
I found a problem using an IPv6 over IPv4 tunnel. When CONFIG_IPV6_SIT was enabled, the packets would be rejected as net/ipv6/sit.c was catching all IPPROTO_IPV6 packets and returning an ICMP port unreachable error. I think this patch fixes the problem cleanly. I believe the code in net/ipv4/tunnel4.c:tunnel4_rcv takes care of it properly if none of the handlers claim the skb. Signed-off-by: David McCullough <david_mccullough@mcafee.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-01Make the ip6_tunnel reflect the true mtu.Anders Franzen
The ip6_tunnel always assumes it consumes 40 bytes (ip6 hdr) of the mtu of the underlaying device. So for a normal ethernet bearer, the mtu of the ip6_tunnel is 1460. However, when creating a tunnel the encap limit option is enabled by default, and it consumes 8 bytes more, so the true mtu shall be 1452. I dont really know if this breaks some statement in some RFC, so this is a request for comments. Signed-off-by: Anders Franzen <anders.franzen@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-30mac80211: Fix STA disconnect due to MIC failureSenthil Balasubramanian
Th commit titled "mac80211: clean up rx handling wrt. found_sta" removed found_sta variable which caused a MIC failure event to be reported twice for a single failure to supplicant resulted in STA disconnect. This should fix WPA specific countermeasures WiFi test case (5.2.17) issues with mac80211 based drivers which report MIC failure events in rx status. Cc: Stable <stable@kernel.org> (2.6.37) Signed-off-by: Senthil Balasubramanian <senthilkumar@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-30mac80211: ignore non-bcast mcast deauth/disassoc franesChristian Lamparter
This patch fixes an curious issue due to insufficient rx frame filtering. Saqeb Akhter reported frequent disconnects while streaming videos over samba: <http://marc.info/?m=128600031109136> > [ 1166.512087] wlan1: deauthenticated from 30:46:9a:10:49:f7 (Reason: 7) > [ 1526.059997] wlan1: deauthenticated from 30:46:9a:10:49:f7 (Reason: 7) > [ 2125.324356] wlan1: deauthenticated from 30:46:9a:10:49:f7 (Reason: 7) > [...] The reason is that the device generates frames with slightly bogus SA/TA addresses. e.g.: [ 2314.402316] Ignore 9f:1f:31:f8:64:ff [ 2314.402321] Ignore 9f:1f:31:f8:64:ff [ 2352.453804] Ignore 0d:1f:31:f8:64:ff [ 2352.453808] Ignore 0d:1f:31:f8:64:ff ^^ the group-address flag is set! (the correct SA/TA would be: 00:1f:31:f8:64:ff) Since the AP does not know from where the frames come, it generates a DEAUTH response for the (invalid) mcast address. This mcast deauth frame then passes through all filters and tricks the stack into thinking that the AP brutally kicked us! This patch fixes the problem by simply ignoring non-broadcast, group-addressed deauth/disassoc frames. Cc: Jouni Malinen <j@w1.fi> Cc: Johannes Berg <johannes@sipsolutions.net> Reported-by: Saqeb Akhter <saqeb.akhter@gmail.com> Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (27 commits) af_unix: limit recursion level pch_gbe driver: The wrong of initializer entry pch_gbe dreiver: chang author ucc_geth: fix ucc halt problem in half duplex mode inet: Fix __inet_inherit_port() to correctly increment bsockets and num_owners ehea: Add some info messages and fix an issue hso: fix disable_net NET: wan/x25_asy, move lapb_unregister to x25_asy_close_tty cxgb4vf: fix setting unicast/multicast addresses ... net, ppp: Report correct error code if unit allocation failed DECnet: don't leak uninitialized stack byte au1000_eth: fix invalid address accessing the MAC enable register dccp: fix error in updating the GAR tcp: restrict net.ipv4.tcp_adv_win_scale (#20312) netns: Don't leak others' openreq-s in proc Net: ceph: Makefile: Remove unnessary code vhost/net: fix rcu check usage econet: fix CVE-2010-3848 econet: fix CVE-2010-3850 econet: disallow NULL remote addr for sendmsg(), fixes CVE-2010-3849 ...
2010-11-29mac80211: Fix frame injection using non-AP vifJouni Malinen
In order for frame injection to work properly for some use cases (e.g., finding the station entry and keys for encryption), mac80211 needs to find the correct sdata entry. This works when the main vif is in AP mode, but commit a2c1e3dad516618cb0fbfb1a62c36d0b0744573a broke this particular use case for station main vif. While this type of injection is quite unusual operation, it has some uses and we should fix it. Do this by changing the monitor vif sdata selection to allow station vif to be selected instead of limiting it to just AP vifs. We still need to skip some iftypes to avoid selecting unsuitable vif for injection. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-29af_unix: limit recursion levelEric Dumazet
Its easy to eat all kernel memory and trigger NMI watchdog, using an exploit program that queues unix sockets on top of others. lkml ref : http://lkml.org/lkml/2010/11/25/8 This mechanism is used in applications, one choice we have is to have a recursion limit. Other limits might be needed as well (if we queue other types of files), since the passfd mechanism is currently limited by socket receive queue sizes only. Add a recursion_level to unix socket, allowing up to 4 levels. Each time we send an unix socket through sendfd mechanism, we copy its recursion level (plus one) to receiver. This recursion level is cleared when socket receive queue is emptied. Reported-by: Марк Коренберг <socketpair@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-28inet: Fix __inet_inherit_port() to correctly increment bsockets and num_ownersNagendra Tomar
inet sockets corresponding to passive connections are added to the bind hash using ___inet_inherit_port(). These sockets are later removed from the bind hash using __inet_put_port(). These two functions are not exactly symmetrical. __inet_put_port() decrements hashinfo->bsockets and tb->num_owners, whereas ___inet_inherit_port() does not increment them. This results in both of these going to -ve values. This patch fixes this by calling inet_bind_hash() from ___inet_inherit_port(), which does the right thing. 'bsockets' and 'num_owners' were introduced by commit a9d8f9110d7e953c (inet: Allowing more than 64k connections and heavily optimize bind(0)) Signed-off-by: Nagendra Singh Tomar <tomer_iisc@yahoo.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-28DECnet: don't leak uninitialized stack byteDan Rosenberg
A single uninitialized padding byte is leaked to userspace. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> CC: stable <stable@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-28dccp: fix error in updating the GARGerrit Renker
This fixes a bug in updating the Greatest Acknowledgment number Received (GAR): the current implementation does not track the greatest received value - lower values in the range AWL..AWH (RFC 4340, 7.5.1) erase higher ones. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-28tcp: restrict net.ipv4.tcp_adv_win_scale (#20312)Alexey Dobriyan
tcp_win_from_space() does the following: if (sysctl_tcp_adv_win_scale <= 0) return space >> (-sysctl_tcp_adv_win_scale); else return space - (space >> sysctl_tcp_adv_win_scale); "space" is int. As per C99 6.5.7 (3) shifting int for 32 or more bits is undefined behaviour. Indeed, if sysctl_tcp_adv_win_scale is exactly 32, space >> 32 equals space and function returns 0. Which means we busyloop in tcp_fixup_rcvbuf(). Restrict net.ipv4.tcp_adv_win_scale to [-31, 31]. Fix https://bugzilla.kernel.org/show_bug.cgi?id=20312 Steps to reproduce: echo 32 >/proc/sys/net/ipv4/tcp_adv_win_scale wget www.kernel.org [softlockup] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-27netns: Don't leak others' openreq-s in procPavel Emelyanov
The /proc/net/tcp leaks openreq sockets from other namespaces. Signed-off-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-27Net: ceph: Makefile: Remove unnessary codeTracey Dent
Remove the if and else conditional because the code is in mainline and there is no need in it being there. Signed-off-by: Tracey Dent <tdent48227@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-27Merge branch 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: NFS: Ensure we return the dirent->d_type when it is known NFS: Correct the array bound calculation in nfs_readdir_add_to_array NFS: Don't ignore errors from nfs_do_filldir() NFS: Fix the error handling in "uncached_readdir()" NFS: Fix a page leak in uncached_readdir() NFS: Fix a page leak in nfs_do_filldir() NFS: Assume eof if the server returns no readdir records NFS: Buffer overflow in ->decode_dirent() should not be fatal Pure nfs client performance using odirect. SUNRPC: Fix an infinite loop in call_refresh/call_refreshresult
2010-11-24econet: fix CVE-2010-3848Phil Blundell
Don't declare variable sized array of iovecs on the stack since this could cause stack overflow if msg->msgiovlen is large. Instead, coalesce the user-supplied data into a new buffer and use a single iovec for it. Signed-off-by: Phil Blundell <philb@gnu.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-24econet: fix CVE-2010-3850Phil Blundell
Add missing check for capable(CAP_NET_ADMIN) in SIOCSIFADDR operation. Signed-off-by: Phil Blundell <philb@gnu.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-24econet: disallow NULL remote addr for sendmsg(), fixes CVE-2010-3849Phil Blundell
Later parts of econet_sendmsg() rely on saddr != NULL, so return early with EINVAL if NULL was passed otherwise an oops may occur. Signed-off-by: Phil Blundell <philb@gnu.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-24tcp: Make TCP_MAXSEG minimum more correct.David S. Miller
Use TCP_MIN_MSS instead of constant 64. Reported-by: Min Zhang <mzhang@mvista.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-24af_unix: limit unix_tot_inflightEric Dumazet
Vegard Nossum found a unix socket OOM was possible, posting an exploit program. My analysis is we can eat all LOWMEM memory before unix_gc() being called from unix_release_sock(). Moreover, the thread blocked in unix_gc() can consume huge amount of time to perform cleanup because of huge working set. One way to handle this is to have a sensible limit on unix_tot_inflight, tested from wait_for_unix_gc() and to force a call to unix_gc() if this limit is hit. This solves the OOM and also reduce overall latencies, and should not slowdown normal workloads. Reported-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: of/phylib: Use device tree properties to initialize Marvell PHYs. phylib: Add support for Marvell 88E1149R devices. phylib: Use common page register definition for Marvell PHYs. qlge: Fix incorrect usage of module parameters and netdev msg level ipv6: fix missing in6_ifa_put in addrconf SuperH IrDA: correct Baud rate error correction atl1c: Fix hardware type check for enabling OTP CLK net: allow GFP_HIGHMEM in __vmalloc() bonding: change list contact to netdev@vger.kernel.org e1000: fix screaming IRQ
2010-11-22Bluetooth: Fix not returning proper error in SCOGustavo F. Padovan
Return 0 in that situation could lead to errors in the caller. Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2010-11-22SUNRPC: Fix an infinite loop in call_refresh/call_refreshresultTrond Myklebust
If the rpcauth_refreshcred() call returns an error other than EACCES, ENOMEM or ETIMEDOUT, we currently end up looping forever between call_refresh and call_refreshresult. The correct thing to do here is to exit on all errors except EAGAIN and ETIMEDOUT, for which case we retry 3 times, then return EACCES. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-11-22ipv6: fix missing in6_ifa_put in addrconfJohn Fastabend
Fix ref count bug introduced by commit 2de795707294972f6c34bae9de713e502c431296 Author: Lorenzo Colitti <lorenzo@google.com> Date: Wed Oct 27 18:16:49 2010 +0000 ipv6: addrconf: don't remove address state on ifdown if the address is being kept Fix logic so that addrconf_ifdown() decrements the inet6_ifaddr refcnt correctly with in6_ifa_put(). Reported-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-21net: allow GFP_HIGHMEM in __vmalloc()Eric Dumazet
We forgot to use __GFP_HIGHMEM in several __vmalloc() calls. In ceph, add the missing flag. In fib_trie.c, xfrm_hash.c and request_sock.c, using vzalloc() is cleaner and allows using HIGHMEM pages as well. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: ceph: fix readdir EOVERFLOW on 32-bit archs ceph: fix frag offset for non-leftmost frags ceph: fix dangling pointer ceph: explicitly specify page alignment in network messages ceph: make page alignment explicit in osd interface ceph: fix comment, remove extraneous args ceph: fix update of ctime from MDS ceph: fix version check on racing inode updates ceph: fix uid/gid on resent mds requests ceph: fix rdcache_gen usage and invalidate ceph: re-request max_size if cap auth changes ceph: only let auth caps update max_size ceph: fix open for write on clustered mds ceph: fix bad pointer dereference in ceph_fill_trace ceph: fix small seq message skipping Revert "ceph: update issue_seq on cap grant"
2010-11-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (31 commits) net: fix kernel-doc for sk_filter_rcu_release be2net: Fix to avoid firmware update when interface is not open. netfilter: fix IP_VS dependencies net: irda: irttp: sync error paths of data- and udata-requests ipv6: Expose reachable and retrans timer values as msecs ipv6: Expose IFLA_PROTINFO timer values in msecs instead of jiffies 3c59x: fix build failure on !CONFIG_PCI ipg.c: remove id [SUNDANCE, 0x1021] net: caif: spi: fix potential NULL dereference ath9k_htc: Avoid setting QoS control for non-QoS frames net: zero kobject in rx_queue_release net: Fix duplicate volatile warning. MAINTAINERS: Add stmmac maintainer bonding: fix a race in IGMP handling cfg80211: fix can_beacon_sec_chan, reenable HT40 gianfar: fix signedness issue net: bnx2x: fix error value sign 8139cp: fix checksum broken r8169: fix checksum broken rds: Integer overflow in RDS cmsg handling ...
2010-11-19net: fix kernel-doc for sk_filter_rcu_releaseRandy Dunlap
Fix kernel-doc warning for sk_filter_rcu_release(): Warning(net/core/filter.c:586): missing initial short description on line: * sk_filter_rcu_release: Release a socket filter by rcu_head Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
