commit a068acf2ee77693e0bf39d6e07139ba704f461c3 upstream.
Many file systems that implement the show_options hook fail to correctly
escape their output which could lead to unescaped characters (e.g. new
lines) leaking into /proc/mounts and /proc/[pid]/mountinfo files. This
could lead to confusion, spoofed entries (resulting in things like
systemd issuing false d-bus "mount" notifications), and who knows what
else. This looks like it would only be the root user stepping on
themselves, but it's possible weird things could happen in containers or
in other situations with delegated mount privileges.
Here's an example using overlay with setuid fusermount trusting the
contents of /proc/mounts (via the /etc/mtab symlink). Imagine the use
of "sudo" is something more sneaky:
$ BASE="ovl"
$ MNT="$BASE/mnt"
$ LOW="$BASE/lower"
$ UP="$BASE/upper"
$ WORK="$BASE/work/ 0 0
none /proc fuse.pwn user_id=1000"
$ mkdir -p "$LOW" "$UP" "$WORK"
$ sudo mount -t overlay -o "lowerdir=$LOW,upperdir=$UP,workdir=$WORK" none /mnt
$ cat /proc/mounts
none /root/ovl/mnt overlay rw,relatime,lowerdir=ovl/lower,upperdir=ovl/upper,workdir=ovl/work/ 0 0
none /proc fuse.pwn user_id=1000 0 0
$ fusermount -u /proc
$ cat /proc/mounts
cat: /proc/mounts: No such file or directory
This fixes the problem by adding new seq_show_option and
seq_show_option_n helpers, and updating the vulnerable show_option
handlers to use them as needed. Some, like SELinux, need to be open
coded due to unusual existing escape mechanisms.
[akpm@linux-foundation.org: add lost chunk, per Kees]
[keescook@chromium.org: seq_show_option should be using const parameters]
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Acked-by: Jan Kara <jack@suse.com>
Acked-by: Paul Moore <paul@paul-moore.com>
Cc: J. R. Okajima <hooanon05g@gmail.com>
Pull networking fixes from David Miller:
"Some straggler bug fixes here:
1) Netlink_sendmsg() doesn't check iterator type properly in mmap
case, from Ken-ichirou MATSUZAWA.
2) Don't sleep in atomic context in bcmgenet driver, from Florian
Fainelli.
3) The pfkey_broadcast() code patch can't actually ever use anything
other than GFP_ATOMIC. And the cases that right now pass
GFP_KERNEL or similar will currently trigger an RCU splat. Just
use GFP_ATOMIC unconditionally. From David Ahern.
4) Fix FD bit timings handling in pcan_usb driver, from Marc
Kleine-Budde.
5) Cache dst leaked in ip6_gre tunnel removal, fix from Huaibin Wang.
6) Traversal into drivers/net/ethernet/renesas should be triggered by
CONFIG_NET_VENDOR_RENESAS, not a particular driver's config
option. From Kazuya Mizuguchi.
7) Fix regression in handling of igmp_join errors in vxlan, from
Marcelo Ricardo Leitner.
8) Make phy_{read,write}_mmd_indirect() properly take the mdio_lock
mutex when programming the registers. From Russell King.
9) Fix non-forced handling in u32_destroy(), from WANG Cong.
10) Test the EVENT_NO_RUNTIME_PM flag before it is cleared in
usbnet_stop(), from Eugene Shatokhin.
11) In sfc driver, don't fetch statistics firmware isn't capable of,
from Bert Kenward.
12) Verify ASCONF address parameter location in SCTP, from Xin Long"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net:
sctp: donot reset the overall_error_count in SHUTDOWN_RECEIVE state
sctp: asconf's process should verify address parameter is in the beginning
sfc: only use vadaptor stats if firmware is capable
net: phy: fixed: propagate fixed link values to struct
usbnet: Get EVENT_NO_RUNTIME_PM bit before it is cleared
drivers: net: xgene: fix: Oops in linkwatch_fire_event
cls_u32: complete the check for non-forced case in u32_destroy()
net: fec: use reinit_completion() in mdio accessor functions
net: phy: add locking to phy_read_mmd_indirect()/phy_write_mmd_indirect()
vxlan: re-ignore EADDRINUSE from igmp_join
net: compile renesas directory if NET_VENDOR_RENESAS is configured
ip6_gre: release cached dst on tunnel removal
phylib: Make PHYs children of their MDIO bus, not the bus' parent.
can: pcan_usb: don't provide CAN FD bittimings by non-FD adapters
net: Fix RCU splat in af_key
net: bcmgenet: fix uncleaned dma flags
net: bcmgenet: Avoid sleeping in bcmgenet_timeout
netlink: mmap: fix tx type check
Commit f8d960524328 ("sctp: Enforce retransmission limit during shutdown")
fixed a problem with excessive retransmissions in the SHUTDOWN_PENDING by not
resetting the association overall_error_count. This allowed the association
to better enforce assoc.max_retrans limit.
However, the same issue still exists when the association is in SHUTDOWN_RECEIVED
state. In this state, HB-ACKs will continue to reset the overall_error_count
for the association would extend the lifetime of association unnecessarily.
This patch solves this by resetting the overall_error_count whenever the current
state is small then SCTP_STATE_SHUTDOWN_PENDING. As a small side-effect, we
end up also handling SCTP_STATE_SHUTDOWN_ACK_SENT and SCTP_STATE_SHUTDOWN_SENT
states, but they are not really impacted because we disable Heartbeats in those
states.
Fixes: Commit f8d960524328 ("sctp: Enforce retransmission limit during shutdown")
Signed-off-by: Xin Long <lucien.xin@gmail.com>
Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
in sctp_process_asconf(), we get address parameter from the beginning of
the addip params. but we never check if it's really there. if the addr
param is not there, it still can pass sctp_verify_asconf(), then to be
handled by sctp_process_asconf(), it will not be safe.
so add a code in sctp_verify_asconf() to check the address parameter is in
the beginning, or return false to send abort.
note that this can also detect multiple address parameters, and reject it.
Signed-off-by: Marcelo Ricardo Leitner <mleitner@redhat.com>
In commit 1e052be69d04 ("net_sched: destroy proto tp when all filters are gone")
I added a check in u32_destroy() to see if all real filters are gone
for each tp, however, that is only done for root_ht, same is needed
for others.
This can be reproduced by the following tc commands:
tc filter add dev eth0 parent 1:0 prio 5 handle 15: protocol ip u32 divisor 256
tc filter add dev eth0 protocol ip parent 1: prio 5 handle 15:2:2 u32
ht 15:2: match ip src 10.0.0.2 flowid 1:10
tc filter add dev eth0 protocol ip parent 1: prio 5 handle 15:2:3 u32
ht 15:2: match ip src 10.0.0.3 flowid 1:10
Fixes: 1e052be69d04 ("net_sched: destroy proto tp when all filters are gone")
Reported-by: Akshat Kakkar <akshat.1984@gmail.com>
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
Signed-off-by: Cong Wang <cwang@twopensource.com>
When a tunnel is deleted, the cached dst entry should be released.
This problem may prevent the removal of a netns (seen with a x-netns IPv6
gre tunnel):
unregister_netdevice: waiting for lo to become free. Usage count = 3
CC: Dmitry Kozlov <xeb@mail.ru>
Fixes: c12b395a4664 ("gre: Support GRE over IPv6")
Signed-off-by: huaibin Wang <huaibin.wang@6wind.com>
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Hit the following splat testing VRF change for ipsec:
[ 113.475692] ===============================
[ 113.476194] [ INFO: suspicious RCU usage. ]
[ 113.476667] 4.2.0-rc6-1+deb7u2+clUNRELEASED #3.2.65-1+deb7u2+clUNRELEASED Not tainted
[ 113.477545] -------------------------------
[ 113.478013] /work/monster-14/dsa/kernel.git/include/linux/rcupdate.h:568 Illegal context switch in RCU read-side critical section!
[ 113.479288]
[ 113.479288] other info that might help us debug this:
[ 113.479288]
[ 113.480207]
[ 113.480207] rcu_scheduler_active = 1, debug_locks = 1
[ 113.480931] 2 locks held by setkey/6829:
[ 113.481371] #0: (&net->xfrm.xfrm_cfg_mutex){+.+.+.}, at: [<ffffffff814e9887>] pfkey_sendmsg+0xfb/0x213
[ 113.482509] #1: (rcu_read_lock){......}, at: [<ffffffff814e767f>] rcu_read_lock+0x0/0x6e
[ 113.483509]
[ 113.483509] stack backtrace:
[ 113.484041] CPU: 0 PID: 6829 Comm: setkey Not tainted 4.2.0-rc6-1+deb7u2+clUNRELEASED #3.2.65-1+deb7u2+clUNRELEASED
[ 113.485422] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.7.5.1-0-g8936dbb-20141113_115728-nilsson.home.kraxel.org 04/01/2014
[ 113.486845] 0000000000000001 ffff88001d4c7a98 ffffffff81518af2 ffffffff81086962
[ 113.487732] ffff88001d538480 ffff88001d4c7ac8 ffffffff8107ae75 ffffffff8180a154
[ 113.488628] 0000000000000b30 0000000000000000 00000000000000d0 ffff88001d4c7ad8
[ 113.489525] Call Trace:
[ 113.489813] [<ffffffff81518af2>] dump_stack+0x4c/0x65
[ 113.490389] [<ffffffff81086962>] ? console_unlock+0x3d6/0x405
[ 113.491039] [<ffffffff8107ae75>] lockdep_rcu_suspicious+0xfa/0x103
[ 113.491735] [<ffffffff81064032>] rcu_preempt_sleep_check+0x45/0x47
[ 113.492442] [<ffffffff8106404d>] ___might_sleep+0x19/0x1c8
[ 113.493077] [<ffffffff81064268>] __might_sleep+0x6c/0x82
[ 113.493681] [<ffffffff81133190>] cache_alloc_debugcheck_before.isra.50+0x1d/0x24
[ 113.494508] [<ffffffff81134876>] kmem_cache_alloc+0x31/0x18f
[ 113.495149] [<ffffffff814012b5>] skb_clone+0x64/0x80
[ 113.495712] [<ffffffff814e6f71>] pfkey_broadcast_one+0x3d/0xff
[ 113.496380] [<ffffffff814e7b84>] pfkey_broadcast+0xb5/0x11e
[ 113.497024] [<ffffffff814e82d1>] pfkey_register+0x191/0x1b1
[ 113.497653] [<ffffffff814e9770>] pfkey_process+0x162/0x17e
[ 113.498274] [<ffffffff814e9895>] pfkey_sendmsg+0x109/0x213
In pfkey_sendmsg the net mutex is taken and then pfkey_broadcast takes
the RCU lock.
Since pfkey_broadcast takes the RCU lock the allocation argument is
pointless since GFP_ATOMIC must be used between the rcu_read_{,un}lock.
The one call outside of rcu can be done with GFP_KERNEL.
Fixes: 7f6b9dbd5afbd ("af_key: locking change")
Signed-off-by: David Ahern <dsa@cumulusnetworks.com>
I can't send netlink message via mmaped netlink socket since
commit: a8866ff6a5bce7d0ec465a63bc482a85c09b0d39
netlink: make the check for "send from tx_ring" deterministic
msg->msg_iter.type is set to WRITE (1) at
SYSCALL_DEFINE6(sendto, ...
import_single_range(WRITE, ...
iov_iter_init(1, WRITE, ...
call path, so that we need to check the type by iter_is_iovec()
to accept the WRITE.
Signed-off-by: Ken-ichirou MATSUZAWA <chamas@h4.dion.ne.jp>
Pull 9p regression fix from Al Viro:
"Fix for breakage introduced when switching p9_client_{read,write}() to
struct iov_iter * (went into 4.1)"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
9p: ensure err is initialized to 0 in p9_client_read/write
Some use of those functions were providing unitialized values to those
functions. Notably, when reading 0 bytes from an empty file on a 9P
filesystem, the return code of read() was not 0.
Tested with this simple program:
#include <assert.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <unistd.h>
int main(int argc, const char **argv)
assert(argc == 2);
char buffer[256];
int fd = open(argv[1], O_RDONLY|O_NOCTTY);
assert(fd >= 0);
assert(read(fd, buffer, 0) == 0);
return 0;
Cc: stable@vger.kernel.org # v4.1
Signed-off-by: Vincent Bernat <vincent@bernat.im>
Commit c48a11c7ad26 ("netvm: propagate page->pfmemalloc to skb") added
checks for page->pfmemalloc to __skb_fill_page_desc():
if (page->pfmemalloc && !page->mapping)
skb->pfmemalloc = true;
It assumes page->mapping == NULL implies that page->pfmemalloc can be
trusted. However, __delete_from_page_cache() can set set page->mapping
to NULL and leave page->index value alone. Due to being in union, a
non-zero page->index will be interpreted as true page->pfmemalloc.
So the assumption is invalid if the networking code can see such a page.
And it seems it can. We have encountered this with a NFS over loopback
setup when such a page is attached to a new skbuf. There is no copying
going on in this case so the page confuses __skb_fill_page_desc which
interprets the index as pfmemalloc flag and the network stack drops
packets that have been allocated using the reserves unless they are to
be queued on sockets handling the swapping which is the case here and
that leads to hangs when the nfs client waits for a response from the
server which has been dropped and thus never arrive.
The struct page is already heavily packed so rather than finding another
hole to put it in, let's do a trick instead. We can reuse the index
again but define it to an impossible value (-1UL). This is the page
index so it should never see the value that large. Replace all direct
users of page->pfmemalloc by page_is_pfmemalloc which will hide this
nastiness from unspoiled eyes.
The information will get lost if somebody wants to use page->index
obviously but that was the case before and the original code expected
that the information should be persisted somewhere else if that is
really needed (e.g. what SLAB and SLUB do).
[akpm@linux-foundation.org: fix blooper in slub]
Fixes: c48a11c7ad26 ("netvm: propagate page->pfmemalloc to skb")
Signed-off-by: Michal Hocko <mhocko@suse.com>
Debugged-by: Vlastimil Babka <vbabka@suse.com>
Debugged-by: Jiri Bohac <jbohac@suse.com>
Cc: <stable@vger.kernel.org> [3.6+]
The object tt_local is allocated with kmalloc and not initialized when the
function batadv_tt_local_add checks for the vlan. But this function can
only cleanup the object when the (not yet initialized) reference counter of
the object is 1. This is unlikely and thus the object would leak when the
vlan could not be found.
Instead the uninitialized object tt_local has to be freed manually and the
pointer has to set to NULL to avoid calling the function which would try to
decrement the reference counter of the not existing object.
CID: 1316518
Fixes: 354136bcc3c4 ("batman-adv: fix kernel crash due to missing NULL checks")
Signed-off-by: Sven Eckelmann <sven@narfation.org>
rt6_make_pcpu_route() is called under read_lock(&table->tb6_lock).
rt6_make_pcpu_route() calls ip6_rt_pcpu_alloc(rt) which then
calls dst_alloc(). dst_alloc() _may_ call ip6_dst_gc() which takes
the write_lock(&tabl->tb6_lock). A visualized version:
read_lock(&table->tb6_lock);
rt6_make_pcpu_route();
=> ip6_rt_pcpu_alloc();
=> dst_alloc();
=> ip6_dst_gc();
=> write_lock(&table->tb6_lock); /* oops */
The fix is to do a read_unlock first before calling ip6_rt_pcpu_alloc().
A reported stack:
[141625.537638] INFO: rcu_sched self-detected stall on CPU { 27} (t=60000 jiffies g=4159086 c=4159085 q=2139)
[141625.547469] Task dump for CPU 27:
[141625.550881] mtr R running task 0 22121 22081 0x00000008
[141625.558069] 0000000000000000 ffff88103f363d98 ffffffff8106e488 000000000000001b
[141625.565641] ffffffff81684900 ffff88103f363db8 ffffffff810702b0 0000000008000000
[141625.573220] ffffffff81684900 ffff88103f363de8 ffffffff8108df9f ffff88103f375a00
[141625.580803] Call Trace:
[141625.583345] <IRQ> [<ffffffff8106e488>] sched_show_task+0xc1/0xc6
[141625.589650] [<ffffffff810702b0>] dump_cpu_task+0x35/0x39
[141625.595144] [<ffffffff8108df9f>] rcu_dump_cpu_stacks+0x6a/0x8c
[141625.601320] [<ffffffff81090606>] rcu_check_callbacks+0x1f6/0x5d4
[141625.607669] [<ffffffff810940c8>] update_process_times+0x2a/0x4f
[141625.613925] [<ffffffff8109fbee>] tick_sched_handle+0x32/0x3e
[141625.619923] [<ffffffff8109fc2f>] tick_sched_timer+0x35/0x5c
[141625.625830] [<ffffffff81094a1f>] __hrtimer_run_queues+0x8f/0x18d
[141625.632171] [<ffffffff81094c9e>] hrtimer_interrupt+0xa0/0x166
[141625.638258] [<ffffffff8102bf2a>] local_apic_timer_interrupt+0x4e/0x52
[141625.645036] [<ffffffff8102c36f>] smp_apic_timer_interrupt+0x39/0x4a
[141625.651643] [<ffffffff8140b9e8>] apic_timer_interrupt+0x68/0x70
[141625.657895] <EOI> [<ffffffff81346ee8>] ? dst_destroy+0x7c/0xb5
[141625.664188] [<ffffffff813d45b5>] ? fib6_flush_trees+0x20/0x20
[141625.670272] [<ffffffff81082b45>] ? queue_write_lock_slowpath+0x60/0x6f
[141625.677140] [<ffffffff8140aa33>] _raw_write_lock_bh+0x23/0x25
[141625.683218] [<ffffffff813d4553>] __fib6_clean_all+0x40/0x82
[141625.689124] [<ffffffff813d45b5>] ? fib6_flush_trees+0x20/0x20
[141625.695207] [<ffffffff813d6058>] fib6_clean_all+0xe/0x10
[141625.700854] [<ffffffff813d60d3>] fib6_run_gc+0x79/0xc8
[141625.706329] [<ffffffff813d0510>] ip6_dst_gc+0x85/0xf9
[141625.711718] [<ffffffff81346d68>] dst_alloc+0x55/0x159
[141625.717105] [<ffffffff813d09b5>] __ip6_dst_alloc.isra.32+0x19/0x63
[141625.723620] [<ffffffff813d1830>] ip6_pol_route+0x36a/0x3e8
[141625.729441] [<ffffffff813d18d6>] ip6_pol_route_output+0x11/0x13
[141625.735700] [<ffffffff813f02c8>] fib6_rule_action+0xa7/0x1bf
[141625.741698] [<ffffffff813d18c5>] ? ip6_pol_route_input+0x17/0x17
[141625.748043] [<ffffffff81357c48>] fib_rules_lookup+0xb5/0x12a
[141625.754050] [<ffffffff81141628>] ? poll_select_copy_remaining+0xf9/0xf9
[141625.761002] [<ffffffff813f0535>] fib6_rule_lookup+0x37/0x5c
[141625.766914] [<ffffffff813d18c5>] ? ip6_pol_route_input+0x17/0x17
[141625.773260] [<ffffffff813d008c>] ip6_route_output+0x7a/0x82
[141625.779177] [<ffffffff813c44c8>] ip6_dst_lookup_tail+0x53/0x112
[141625.785437] [<ffffffff813c45c3>] ip6_dst_lookup_flow+0x2a/0x6b
[141625.791604] [<ffffffff813ddaab>] rawv6_sendmsg+0x407/0x9b6
[141625.797423] [<ffffffff813d7914>] ? do_ipv6_setsockopt.isra.8+0xd87/0xde2
[141625.804464] [<ffffffff8139d4b4>] inet_sendmsg+0x57/0x8e
[141625.810028] [<ffffffff81329ba3>] sock_sendmsg+0x2e/0x3c
[141625.815588] [<ffffffff8132be57>] SyS_sendto+0xfe/0x143
[141625.821063] [<ffffffff813dd551>] ? rawv6_setsockopt+0x5e/0x67
[141625.827146] [<ffffffff8132c9f8>] ? sock_common_setsockopt+0xf/0x11
[141625.833660] [<ffffffff8132c08c>] ? SyS_setsockopt+0x81/0xa2
[141625.839565] [<ffffffff8140ac17>] entry_SYSCALL_64_fastpath+0x12/0x6a
Fixes: d52d3997f843 ("pv6: Create percpu rt6_info")
Signed-off-by: Martin KaFai Lau <kafai@fb.com>
CC: Hannes Frederic Sowa <hannes@stressinduktion.org>
Reported-by: Steinar H. Gunderson <sgunderson@bigfoot.com>
It is a prep work for fixing a potential deadlock when creating
a pcpu rt.
The current rt6_get_pcpu_route() will also create a pcpu rt if one does not
exist. This patch moves the pcpu rt creation logic into another function,
rt6_make_pcpu_route().
After 4b32b5ad31a6 ("ipv6: Stop rt6_info from using inet_peer's metrics"),
ip6_dst_alloc() does not need the 'table' argument. This patch
cleans it up.
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211
Johannes Berg says:
We have a single bugfix for an invalid memory read.
Commit 8133534c760d4083 ("net: limit tcp/udp rmem/wmem to
SOCK_{RCV,SND}BUF_MIN") modified four sysctls to enforce that the values
written to them are not less than SOCK_MIN_{RCV,SND}BUF.
That change causes 4096 to no longer be accepted as a valid value for
'min' in tcp_wmem and udp_wmem_min. 4096 has been the default for both
of those sysctls for a long time, and unfortunately seems to be an
extremely popular setting. This change breaks a large number of sysctl
configurations at Facebook.
That commit referred to b1cb59cf2efe7971 ("net: sysctl_net_core: check
SNDBUF and RCVBUF for min length"), which choose to use the SOCK_MIN
constants as the lower limits to avoid nasty bugs. But AFAICS, a limit
of SOCK_MIN_SNDBUF isn't necessary to do that: the BUG_ON cited in the
commit message seems to have happened because unix_stream_sendmsg()
expects a minimum of a full page (ie SK_MEM_QUANTUM) and the math broke,
not because it had less than SOCK_MIN_SNDBUF allocated.
This particular issue doesn't seem to affect TCP however: using a
setting of "1 1 1" for tcp_{r,w}mem works, although it's obviously
suboptimal. SK_MEM_QUANTUM would be a nice minimum, but it's 64K on
some archs, so there would still be breakage.
Since a value of one doesn't seem to cause any problems, we can drop the
minimum 8133534c added to fix this.
This reverts commit 8133534c760d4083f79d2cde42c636ccc0b2792e.
Fixes: 8133534c760d4083 ("net: limit tcp/udp rmem/wmem to SOCK_MIN...")
Cc: Sorin Dumitru <sorin@returnze.ro>
Signed-off-by: Calvin Owens <calvinowens@fb.com>
When replacing del_timer() with del_timer_sync(), I introduced
a deadlock condition :
reqsk_queue_unlink() is called from inet_csk_reqsk_queue_drop()
inet_csk_reqsk_queue_drop() can be called from many contexts,
one being the timer handler itself (reqsk_timer_handler()).
In this case, del_timer_sync() loops forever.
Simple fix is to test if timer is pending.
Fixes: 2235f2ac75fd ("inet: fix races with reqsk timers")
When generating /proc/net/route we emit a header followed by a line for
each route. When a short read is performed we will restart this process
based on the open file descriptor. When calculating the start point we
fail to take into account that the 0th entry is the header. This leads
us to skip the first entry when doing a continuation read.
This can be easily seen with the comparison below:
while read l; do echo "$l"; done </proc/net/route >A
cat /proc/net/route >B
diff -bu A B | grep '^[+-]'
On my example machine I have approximatly 10KB of route output. There we
see the very first non-title element is lost in the while read case,
and an entry around the 8K mark in the cat case:
+wlan0 00000000 02021EAC 0003 0 0 400 00000000 0 0 0
-tun1 00C0AC0A 00000000 0001 0 0 950 00C0FFFF 0 0 0
Fix up the off-by-one when reaquiring position on continuation.
Fixes: 8be33e955cb9 ("fib_trie: Fib walk rcu should take a tnode and key instead of a trie and a leaf")
BugLink: http://bugs.launchpad.net/bugs/1483440
Acked-by: Alexander Duyck <alexander.h.duyck@redhat.com>
Signed-off-by: Andy Whitcroft <apw@canonical.com>
The recent refactoring of the IGMP and MLD parsing code into
ipv6_mc_check_mld() / ip_mc_check_igmp() introduced a potential crash /
BUG() invocation for bridges:
I wrongly assumed that skb_get() could be used as a simple reference
counter for an skb which is not the case. skb_get() bears additional
semantics, a user count. This leads to a BUG() invocation in
pskb_expand_head() / kernel panic if pskb_may_pull() is called on an skb
with a user count greater than one - unfortunately the refactoring did
just that.
Fixing this by removing the skb_get() call and changing the API: The
caller of ipv6_mc_check_mld() / ip_mc_check_igmp() now needs to
additionally check whether the returned skb_trimmed is a clone.
Fixes: 9afd85c9e455 ("net: Export IGMP/MLD message validation code")
Reported-by: Brenden Blanco <bblanco@plumgrid.com>
Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue>
Acked-by: Alexei Starovoitov <ast@plumgrid.com>
At the last iteration of the loop, j may equal zero and thus
tp_list[j - 1] causes an invalid read.
Change the logic of the loop so that j - 1 is always >= 0.
Signed-off-by: Adrien Schildknecht <adrien+dev@schischi.me>
In case we need to divert reads/writes using the slave MII bus, we may have
already fetched a valid PHY interface property from Device Tree, and that
mode is used by the PHY driver to make configuration decisions.
If we could not fetch the "phy-mode" property, we will assign p->phy_interface
to PHY_INTERFACE_MODE_NA, such that we can actually check for that condition as
to whether or not we should override the interface value.
Fixes: 19334920eaf7 ("net: dsa: Set valid phy interface type")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth
Johan Hedberg says:
pull request: bluetooth 2015-08-11
Here's an important regression fix for the 4.2-rc series that ensures
user space isn't given invalid LTK values. The bug essentially prevents
the encryption of subsequent LE connections, i.e. makes it impossible to
pair devices over LE.
Let me know if there are any issues pulling. Thanks.
In commit b357a364c57c9 ("inet: fix possible panic in
reqsk_queue_unlink()"), I missed fact that tcp_check_req()
can return the listener socket in one case, and that we must
release the request socket refcount or we leak it.
Tested:
Following packetdrill test template shows the issue
0 socket(..., SOCK_STREAM, IPPROTO_TCP) = 3
+0 setsockopt(3, SOL_SOCKET, SO_REUSEADDR, [1], 4) = 0
+0 bind(3, ..., ...) = 0
+0 listen(3, 1) = 0
+0 < S 0:0(0) win 2920 <mss 1460,sackOK,nop,nop>
+0 > S. 0:0(0) ack 1 <mss 1460,nop,nop,sackOK>
+.002 < . 1:1(0) ack 21 win 2920
+0 > R 21:21(0)
Fixes: b357a364c57c9 ("inet: fix possible panic in reqsk_queue_unlink()")
reqsk_queue_destroy() and reqsk_queue_unlink() should use
del_timer_sync() instead of del_timer() before calling reqsk_put(),
otherwise we could free a req still used by another cpu.
But before doing so, reqsk_queue_destroy() must release syn_wait_lock
spinlock or risk a dead lock, as reqsk_timer_handler() might
need to take this same spinlock from reqsk_queue_unlink() (called from
inet_csk_reqsk_queue_drop())
Fixes: fa76ce7328b2 ("inet: get rid of central tcp/dccp listener timer")
Pablo Neira Ayuso says:
Netfilter fixes for net
The following patchset contains five Netfilter fixes for your net tree,
they are:
1) Silence a warning on falling back to vmalloc(). Since 88eab472ec21, we can
easily hit this warning message, that gets users confused. So let's get rid
of it.
2) Recently when porting the template object allocation on top of kmalloc to
fix the netns dependencies between x_tables and conntrack, the error
checks where left unchanged. Remove IS_ERR() and check for NULL instead.
Patch from Dan Carpenter.
3) Don't ignore gfp_flags in the new nf_ct_tmpl_alloc() function, from
Joe Stringer.
4) Fix a crash due to NULL pointer dereference in ip6t_SYNPROXY, patch from
Phil Sutter.
5) The sequence number of the Syn+ack that is sent from SYNPROXY to clients is
not adjusted through our NAT infrastructure, as a result the client may
ignore this TCP packet and TCP flow hangs until the client probes us. Also
from Phil Sutter.
48ed7b26faa7 ("ipv6: reject locally assigned nexthop addresses") is too
strict; it rejects following corner-case:
ip -6 route add default via fe80::1:2:3 dev eth1
[ where fe80::1:2:3 is assigned to a local interface, but not eth1 ]
Fix this by restricting search to given device if nh is linklocal.
Joint work with Hannes Frederic Sowa.
Fixes: 48ed7b26faa7 ("ipv6: reject locally assigned nexthop addresses")
Linus reports the following deadlock on rtnl_mutex; triggered only
once so far (extract):
[12236.694209] NetworkManager D 0000000000013b80 0 1047 1 0x00000000
[12236.694218] ffff88003f902640 0000000000000000 ffffffff815d15a9 0000000000000018
[12236.694224] ffff880119538000 ffff88003f902640 ffffffff81a8ff84 00000000ffffffff
[12236.694230] ffffffff81a8ff88 ffff880119c47f00 ffffffff815d133a ffffffff81a8ff80
[12236.694235] Call Trace:
[12236.694250] [<ffffffff815d15a9>] ? schedule_preempt_disabled+0x9/0x10
[12236.694257] [<ffffffff815d133a>] ? schedule+0x2a/0x70
[12236.694263] [<ffffffff815d15a9>] ? schedule_preempt_disabled+0x9/0x10
[12236.694271] [<ffffffff815d2c3f>] ? __mutex_lock_slowpath+0x7f/0xf0
[12236.694280] [<ffffffff815d2cc6>] ? mutex_lock+0x16/0x30
[12236.694291] [<ffffffff814f1f90>] ? rtnetlink_rcv+0x10/0x30
[12236.694299] [<ffffffff8150ce3b>] ? netlink_unicast+0xfb/0x180
[12236.694309] [<ffffffff814f5ad3>] ? rtnl_getlink+0x113/0x190
[12236.694319] [<ffffffff814f202a>] ? rtnetlink_rcv_msg+0x7a/0x210
[12236.694331] [<ffffffff8124565c>] ? sock_has_perm+0x5c/0x70
[12236.694339] [<ffffffff814f1fb0>] ? rtnetlink_rcv+0x30/0x30
[12236.694346] [<ffffffff8150d62c>] ? netlink_rcv_skb+0x9c/0xc0
[12236.694354] [<ffffffff814f1f9f>] ? rtnetlink_rcv+0x1f/0x30
[12236.694360] [<ffffffff8150ce3b>] ? netlink_unicast+0xfb/0x180
[12236.694367] [<ffffffff8150d344>] ? netlink_sendmsg+0x484/0x5d0
[12236.694376] [<ffffffff810a236f>] ? __wake_up+0x2f/0x50
[12236.694387] [<ffffffff814cad23>] ? sock_sendmsg+0x33/0x40
[12236.694396] [<ffffffff814cb05e>] ? ___sys_sendmsg+0x22e/0x240
[12236.694405] [<ffffffff814cab75>] ? ___sys_recvmsg+0x135/0x1a0
[12236.694415] [<ffffffff811a9d12>] ? eventfd_write+0x82/0x210
[12236.694423] [<ffffffff811a0f9e>] ? fsnotify+0x32e/0x4c0
[12236.694429] [<ffffffff8108cb70>] ? wake_up_q+0x60/0x60
[12236.694434] [<ffffffff814cba09>] ? __sys_sendmsg+0x39/0x70
[12236.694440] [<ffffffff815d4797>] ? entry_SYSCALL_64_fastpath+0x12/0x6a
It seems so far plausible that the recursive call into rtnetlink_rcv()
looks suspicious. One way, where this could trigger is that the senders
NETLINK_CB(skb).portid was wrongly 0 (which is rtnetlink socket), so
the rtnl_getlink() request's answer would be sent to the kernel instead
to the actual user process, thus grabbing rtnl_mutex() twice.
One theory would be that netlink_autobind() triggered via netlink_sendmsg()
internally overwrites the -EBUSY error to 0, but where it is wrongly
originating from __netlink_insert() instead. That would reset the
socket's portid to 0, which is then filled into NETLINK_CB(skb).portid
later on. As commit d470e3b483dc ("[NETLINK]: Fix two socket hashing bugs.")
also puts it, -EBUSY should not be propagated from netlink_insert().
It looks like it's very unlikely to reproduce. We need to trigger the
rhashtable_insert_rehash() handler under a situation where rehashing
currently occurs (one /rare/ way would be to hit ht->elasticity limits
while not filled enough to expand the hashtable, but that would rather
require a specifically crafted bind() sequence with knowledge about
destination slots, seems unlikely). It probably makes sense to guard
__netlink_insert() in any case and remap that error. It was suggested
that EOVERFLOW might be better than an already overloaded ENOMEM.
Reference: http://thread.gmane.org/gmane.linux.network/372676
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Acked-by: Thomas Graf <tgraf@suug.ch>
Upon receipt of SYNACK from the server, ipt_SYNPROXY first sends back an ACK to
finish the server handshake, then calls nf_ct_seqadj_init() to initiate
sequence number adjustment of forwarded packets to the client and finally sends
a window update to the client to unblock it's TX queue.
Since synproxy_send_client_ack() does not set synproxy_send_tcp()'s nfct
parameter, no sequence number adjustment happens and the client receives the
window update with incorrect sequence number. Depending on client TCP
implementation, this leads to a significant delay (until a window probe is
being sent).
Signed-off-by: Phil Sutter <phil@nwl.cc>
This happens when networking namespaces are enabled.
Suggested-by: Patrick McHardy <kaber@trash.net>
Acked-by: Patrick McHardy <kaber@trash.net>
Antonio Quartulli says:
Included changes:
- prevent DAT from replying on behalf of local clients and confuse L2
bridges
- fix crash on double list removal of TT objects (tt_local_entry)
- fix crash due to missing NULL checks
- initialize bw values for new GWs objects to prevent memory leak
and policy
The attribute size wasn't accounted for in the get_slave_size() callback
(br_port_get_slave_size) when it was introduced, so fix it now. Also add
a policy entry for it in br_port_policy.
Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
Fixes: 842a9ae08a25 ("bridge: Extend Proxy ARP design to allow optional rules for Wi-Fi")
Fixes: 958501163ddd ("bridge: Add support for IEEE 802.11 Proxy ARP")
Commit 1fbe4b46caca "net: pktgen: kill the Wait for kthread_stop
code in pktgen_thread_worker()" removed (in particular) the final
__set_current_state(TASK_RUNNING) and I didn't notice the previous
set_current_state(TASK_INTERRUPTIBLE). This triggers the warning
in __might_sleep() after return.
Afaics, we can simply remove both set_current_state()'s, and we
could do this a long ago right after ef87979c273a2 "pktgen: better
scheduler friendliness" which changed pktgen_thread_worker() to
use wait_event_interruptible_timeout().
Reported-by: Huang Ying <ying.huang@intel.com>
The commit 738ac1ebb96d02e0d23bc320302a6ea94c612dec ("net: Clone
skb before setting peeked flag") introduced a use-after-free bug
in skb_recv_datagram. This is because skb_set_peeked may create
a new skb and free the existing one. As it stands the caller will
continue to use the old freed skb.
This patch fixes it by making skb_set_peeked return the new skb
(or the old one if unchanged).
Fixes: 738ac1ebb96d ("net: Clone skb before setting peeked flag")
Tested-by: Brenden Blanco <bblanco@plumgrid.com>
Reviewed-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
This patch fixes how MGMT_EV_NEW_LONG_TERM_KEY event is build. Right now
val vield is filled with only 1 byte, instead of whole value. This bug
was introduced in
commit 1fc62c526a57 ("Bluetooth: Fix exposing full value of shortened LTKs")
Before that patch, if you paired with device using bluetoothd using simple
pairing, and then restarted bluetoothd, you would be able to re-connect,
but device would fail to establish encryption and would terminate
connection. After this patch connecting after bluetoothd restart works
fine.
Signed-off-by: Jakub Pawlowski <jpawlowski@google.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
The flags were ignored for this function when it was introduced. Also
fix the style problem in kzalloc.
Fixes: 0838aa7fc (netfilter: fix netns dependencies with conntrack
templates)
Signed-off-by: Joe Stringer <joestringer@nicira.com>
Without this initialization, gateways which actually announce up/down
bandwidth of 0/0 could be added. If these nodes get purged via
_batadv_purge_orig() later, the gw_node structure does not get removed
since batadv_gw_node_delete() updates the gw_node with up/down
bandwidth of 0/0, and the updating function then discards the change
and does not free gw_node.
This results in leaking the gw_node structures, which references other
structures: gw_node -> orig_node -> orig_node_ifinfo -> hardif. When
removing the interface later, the open reference on the hardif may cause
hangs with the infamous "unregister_netdevice: waiting for mesh1 to
become free. Usage count = 1" message.
Signed-off-by: Simon Wunderlich <simon@open-mesh.com>
Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
The tt_local_entry deletion performed in batadv_tt_local_remove() was neither
protecting against simultaneous deletes nor checking whether the element was
still part of the list before calling hlist_del_rcu().
Replacing the hlist_del_rcu() call with batadv_hash_remove() provides adequate
protection via hash spinlocks as well as an is-element-still-in-hash check to
avoid 'blind' hash removal.
Fixes: 068ee6e204e1 ("batman-adv: roaming handling mechanism redesign")
Reported-by: alfonsname@web.de
batadv_softif_vlan_get() may return NULL which has to be verified
by the caller.
Fixes: 35df3b298fc8 ("batman-adv: fix TT VLAN inconsistency on VLAN re-add")
Reported-by: Ryan Thompson <ryan@eero.com>
When a node running DAT receives an ARP request from the LAN for the
first time, it is likely that this node will request the ARP entry
through the distributed ARP table (DAT) in the mesh.
Once a DAT reply is received the asking node must check if the MAC
address for which the IP address has been asked is local. If it is, the
node must drop the ARP reply bceause the client should have replied on
its own locally.
Forwarding this reply means fooling any L2 bridge (e.g. Ethernet
switches) lying between the batman-adv node and the LAN. This happens
because the L2 bridge will think that the client sending the ARP reply
lies somewhere in the mesh, while this node is sitting in the same LAN.
Reported-by: Simon Wunderlich <sw@simonwunderlich.de>
Multicast dst are not cached. They carry DST_NOCACHE.
As mentioned in commit f8864972126899 ("ipv4: fix dst race in
sk_dst_get()"), these dst need special care before caching them
into a socket.
Caching them is allowed only if their refcnt was not 0, ie we
must use atomic_inc_not_zero()
Also, we must use READ_ONCE() to fetch sk->sk_rx_dst, as mentioned
in commit d0c294c53a771 ("tcp: prevent fetching dst twice in early demux
code")
Fixes: 421b3885bf6d ("udp: ipv4: Add udp early demux")
Tested-by: Gregory Hoggarth <Gregory.Hoggarth@alliedtelesis.co.nz>
Reported-by: Gregory Hoggarth <Gregory.Hoggarth@alliedtelesis.co.nz>
Reported-by: Alex Gartrell <agartrell@fb.com>
Cc: Michal Kubeček <mkubecek@suse.cz>
"len" is a signed integer. We check that len is not negative, so it
goes from zero to INT_MAX. PAGE_SIZE is unsigned long so the comparison
is type promoted to unsigned long. ULONG_MAX - 4095 is a higher than
INT_MAX so the condition can never be true.
I don't know if this is harmful but it seems safe to limit "len" to
INT_MAX - 4095.
Fixes: a8c879a7ee98 ('RDS: Info and stats')
When we share an action within a filter, the bind refcnt
should increase, therefore we should not call tcf_hash_release().
Cc: Daniel Borkmann <daniel@iogearbox.net>
openvswitch modifies the L4 checksum of a packet when modifying
the ip address. When an IP packet is fragmented only the first
fragment contains an L4 header and checksum. Prior to this change
openvswitch would modify all fragments, modifying application data
in non-first fragments, causing checksum failures in the
reassembled packet.
Signed-off-by: Glenn Griffin <ggriffin.kernel@gmail.com>
Acked-by: Pravin B Shelar <pshelar@nicira.com>
Alex reported the following crash when using fq_codel
with htb:
crash> bt
PID: 630839 TASK: ffff8823c990d280 CPU: 14 COMMAND: "tc"
[... snip ...]
#8 [ffff8820ceec17a0] page_fault at ffffffff8160a8c2
[exception RIP: htb_qlen_notify+24]
RIP: ffffffffa0841718 RSP: ffff8820ceec1858 RFLAGS: 00010282
RAX: 0000000000000000 RBX: 0000000000000000 RCX: ffff88241747b400
RDX: ffff88241747b408 RSI: 0000000000000000 RDI: ffff8811fb27d000
RBP: ffff8820ceec1868 R8: ffff88120cdeff24 R9: ffff88120cdeff30
R10: 0000000000000bd4 R11: ffffffffa0840919 R12: ffffffffa0843340
R13: 0000000000000000 R14: 0000000000000001 R15: ffff8808dae5c2e8
ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0018
#9 [...] qdisc_tree_decrease_qlen at ffffffff81565375
#10 [...] fq_codel_dequeue at ffffffffa084e0a0 [sch_fq_codel]
#11 [...] fq_codel_reset at ffffffffa084e2f8 [sch_fq_codel]
#12 [...] qdisc_destroy at ffffffff81560d2d
#13 [...] htb_destroy_class at ffffffffa08408f8 [sch_htb]
#14 [...] htb_put at ffffffffa084095c [sch_htb]
#15 [...] tc_ctl_tclass at ffffffff815645a3
#16 [...] rtnetlink_rcv_msg at ffffffff81552cb0
[... snip ...]
As Jamal pointed out, there is actually no need to call dequeue
to purge the queued skb's in reset, data structures can be just
reset explicitly. Therefore, we reset everything except config's
and stats, so that we would have a fresh start after device flipping.
Fixes: 4b549a2ef4be ("fq_codel: Fair Queue Codel AQM")
Cc: Alex Gartrell <agartrell@fb.com>
[xiyou.wangcong@gmail.com: added codel_vars_init() and qdisc_qstats_backlog_dec()]
1) Must teardown SR-IOV before unregistering netdev in igb driver, from
Alex Williamson.
2) Fix ipv6 route unreachable crash in IPVS, from Alex Gartrell.
3) Default route selection in ipv4 should take the prefix length, table
ID, and TOS into account, from Julian Anastasov.
4) sch_plug must have a reset method in order to purge all buffered
packets when the qdisc is reset, likewise for sch_choke, from WANG
Cong.
5) Fix deadlock and races in slave_changelink/br_setport in bridging.
From Nikolay Aleksandrov.
6) mlx4 bug fixes (wrong index in port even propagation to VFs,
overzealous BUG_ON assertion, etc.) from Ido Shamay, Jack
Morgenstein, and Or Gerlitz.
7) Turn off klog message about SCTP userspace interface compat that
makes no sense at all, from Daniel Borkmann.
8) Fix unbounded restarts of inet frag eviction process, causing NMI
watchdog soft lockup messages, from Florian Westphal.
9) Suspend/resume fixes for r8152 from Hayes Wang.
10) Fix busy loop when MSG_WAITALL|MSG_PEEK is used in TCP recv, from
Sabrina Dubroca.
11) Fix performance regression when removing a lot of routes from the
ipv4 routing tables, from Alexander Duyck.
12) Fix device leak in AF_PACKET, from Lars Westerhoff.
13) AF_PACKET also has a header length comparison bug due to signedness,
from Alexander Drozdov.
14) Fix bug in EBPF tail call generation on x86, from Daniel Borkmann.
15) Memory leaks, TSO stats, watchdog timeout and other fixes to
thunderx driver from Sunil Goutham and Thanneeru Srinivasulu.
16) act_bpf can leak memory when replacing programs, from Daniel
Borkmann.
17) WOL packet fixes in gianfar driver, from Claudiu Manoil.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (79 commits)
stmmac: fix missing MODULE_LICENSE in stmmac_platform
gianfar: Enable device wakeup when appropriate
gianfar: Fix suspend/resume for wol magic packet
gianfar: Fix warning when CONFIG_PM off
act_pedit: check binding before calling tcf_hash_release()
net: sk_clone_lock() should only do get_net() if the parent is not a kernel socket
net: sched: fix refcount imbalance in actions
r8152: reset device when tx timeout
r8152: add pre_reset and post_reset
qlcnic: Fix corruption while copying
act_bpf: fix memory leaks when replacing bpf programs
net: thunderx: Fix for crash while BGX teardown
net: thunderx: Add PCI driver shutdown routine
net: thunderx: Fix crash when changing rss with mutliple traffic flows
net: thunderx: Set watchdog timeout value
net: thunderx: Wakeup TXQ only if CQE_TX are processed
net: thunderx: Suppress alloc_pages() failure warnings
net: thunderx: Fix TSO packet statistic
net: thunderx: Fix memory leak when changing queue count
net: thunderx: Fix RQ_DROP miscalculation
Fixes: 1a29321ed045 ("net_sched: act: Dont increment refcnt on replace")
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
socket
The newsk returned by sk_clone_lock should hold a get_net()
reference if, and only if, the parent is not a kernel socket
(making this similar to sk_alloc()).
E.g,. for the SYN_RECV path, tcp_v4_syn_recv_sock->..inet_csk_clone_lock
sets up the syn_recv newsk from sk_clone_lock. When the parent (listen)
socket is a kernel socket (defined in sk_alloc() as having
sk_net_refcnt == 0), then the newsk should also have a 0 sk_net_refcnt
and should not hold a get_net() reference.
Fixes: 26abe14379f8 ("net: Modify sk_alloc to not reference count the
netns of kernel sockets.")
Cc: Eric W. Biederman <ebiederm@xmission.com>
Signed-off-by: Sowmini Varadhan <sowmini.varadhan@oracle.com>
Since commit 55334a5db5cd ("net_sched: act: refuse to remove bound action
outside"), we end up with a wrong reference count for a tc action.
Test case 1:
FOO="1,6 0 0 4294967295,"
BAR="1,6 0 0 4294967294,"
tc filter add dev foo parent 1: bpf bytecode "$FOO" flowid 1:1 \
action bpf bytecode "$FOO"
tc actions show action bpf
action order 0: bpf bytecode '1,6 0 0 4294967295' default-action pipe
index 1 ref 1 bind 1
tc actions replace action bpf bytecode "$BAR" index 1
action order 0: bpf bytecode '1,6 0 0 4294967294' default-action pipe
index 1 ref 2 bind 1
tc actions replace action bpf bytecode "$FOO" index 1
index 1 ref 3 bind 1
Test case 2:
tc filter add dev foo parent 1: bpf bytecode "$FOO" flowid 1:1 action ok
tc actions show action gact
action order 0: gact action pass
random type none pass val 0
tc actions add action drop index 1
RTNETLINK answers: File exists [...]
What happens is that in tcf_hash_check(), we check tcf_common for a given
index and increase tcfc_refcnt and conditionally tcfc_bindcnt when we've
found an existing action. Now there are the following cases:
1) We do a late binding of an action. In that case, we leave the
tcfc_refcnt/tcfc_bindcnt increased and are done with the ->init()
handler. This is correctly handeled.
2) We replace the given action, or we try to add one without replacing
and find out that the action at a specific index already exists
(thus, we go out with error in that case).
In case of 2), we have to undo the reference count increase from
tcf_hash_check() in the tcf_hash_check() function. Currently, we fail to
do so because of the 'tcfc_bindcnt > 0' check which bails out early with
an -EPERM error.
Now, while commit 55334a5db5cd prevents 'tc actions del action ...' on an
already classifier-bound action to drop the reference count (which could
then become negative, wrap around etc), this restriction only accounts for
invocations outside a specific action's ->init() handler.
One possible solution would be to add a flag thus we possibly trigger
the -EPERM ony in situations where it is indeed relevant.
After the patch, above test cases have correct reference count again.
Fixes: 55334a5db5cd ("net_sched: act: refuse to remove bound action outside")
Reviewed-by: Cong Wang <cwang@twopensource.com>
