commit 990de49f74e772b6db5208457b7aa712a5f4db86 upstream.
When a full scan 2.4 and 5 GHz scan is scheduled, but then the 2.4 GHz
part of the scan disables a 5.2 GHz channel due to, e.g. receiving
country or frequency information, that 5.2 GHz channel might already
be in the list of channels to scan next. Then, when the driver checks
if it should do a passive scan, that will return false and attempt an
active scan. This is not only wrong but can also lead to the iwlwifi
device firmware crashing since it checks regulatory as well.
Fix this by not setting the channel flags to just disabled but rather
OR'ing in the disabled flag. That way, even if the race happens, the
channel will be scanned passively which is still (mostly) correct.
[ Upstream commit 97599dc792b45b1669c3cdb9a4b365aad0232f65 ]
Commit 4a94445c9a5c (net: Use ip_route_input_noref() in input path)
added a bug in IP defragmentation handling, as non refcounted
dst could escape an RCU protected section.
Commit 64f3b9e203bd068 (net: ip_expire() must revalidate route) fixed
the case of timeouts, but not the general problem.
Tom Parkin noticed crashes in UDP stack and provided a patch,
but further analysis permitted us to pinpoint the root cause.
Before queueing a packet into a frag list, we must drop its dst,
as this dst has limited lifetime (RCU protected)
When/if a packet is finally reassembled, we use the dst of the very
last skb, still protected by RCU and valid, as the dst of the
reassembled packet.
Use same logic in IPv6, as there is no need to hold dst references.
Reported-by: Tom Parkin <tparkin@katalix.com>
Tested-by: Tom Parkin <tparkin@katalix.com>
[ Upstream commit c802d759623acbd6e1ee9fbdabae89159a513913 ]
sizeof() when applied to a pointer typed expression gives the size of the
pointer, not that of the pointed data.
Introduced by commit 3ce5ef(netrom: fix info leak via msg_name in nr_recvmsg)
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
[ Upstream commit 60085c3d009b0df252547adb336d1ccca5ce52ec ]
The code in set_orig_addr() does not initialize all of the members of
struct sockaddr_tipc when filling the sockaddr info -- namely the union
is only partly filled. This will make recv_msg() and recv_stream() --
the only users of this function -- leak kernel stack memory as the
msg_name member is a local variable in net/socket.c.
Additionally to that both recv_msg() and recv_stream() fail to update
the msg_namelen member to 0 while otherwise returning with 0, i.e.
"success". This is the case for, e.g., non-blocking sockets. This will
lead to a 128 byte kernel stack leak in net/socket.c.
Fix the first issue by initializing the memory of the union with
memset(0). Fix the second one by setting msg_namelen to 0 early as it
will be updated later if we're going to fill the msg_name member.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Jon Maloy <jon.maloy@ericsson.com>
Cc: Allan Stephens <allan.stephens@windriver.com>
[ Upstream commit 4a184233f21645cf0b719366210ed445d1024d72 ]
The code in rose_recvmsg() does not initialize all of the members of
struct sockaddr_rose/full_sockaddr_rose when filling the sockaddr info.
Nor does it initialize the padding bytes of the structure inserted by
the compiler for alignment. This will lead to leaking uninitialized
kernel stack bytes in net/socket.c.
Fix the issue by initializing the memory used for sockaddr info with
memset(0).
[ Upstream commits 3ce5efad47b62c57a4f5c54248347085a750ce0e and
In case msg_name is set the sockaddr info gets filled out, as
requested, but the code fails to initialize the padding bytes of
struct sockaddr_ax25 inserted by the compiler for alignment. Also
the sax25_ndigis member does not get assigned, leaking four more
bytes.
Both issues lead to the fact that the code will leak uninitialized
Fix both issues by initializing the memory with memset(0).
[ Upstream commit c77a4b9cffb6215a15196ec499490d116dfad181 ]
For stream sockets the code misses to update the msg_namelen member
to 0 and therefore makes net/socket.c leak the local, uninitialized
sockaddr_storage variable to userland -- 128 bytes of kernel stack
memory. The msg_namelen update is also missing for datagram sockets
in case the socket is shutting down during receive.
Fix both issues by setting msg_namelen to 0 early. It will be
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
[ Upstream commit a5598bd9c087dc0efc250a5221e5d0e6f584ee88 ]
The current code does not fill the msg_name member in case it is set.
It also does not set the msg_namelen member to 0 and therefore makes
net/socket.c leak the local, uninitialized sockaddr_storage variable
to userland -- 128 bytes of kernel stack memory.
Fix that by simply setting msg_namelen to 0 as obviously nobody cared
about iucv_sock_recvmsg() not filling the msg_name in case it was set.
Cc: Ursula Braun <ursula.braun@de.ibm.com>
[ Upstream commit 5ae94c0d2f0bed41d6718be743985d61b7f5c47d ]
about irda_recvmsg_dgram() not filling the msg_name in case it was
set.
Cc: Samuel Ortiz <samuel@sortiz.org>
[ Upstream commit 2d6fbfe733f35c6b355c216644e08e149c61b271 ]
about caif_seqpkt_recvmsg() not filling the msg_name in case it was
set.
Cc: Sjur Braendeland <sjur.brandeland@stericsson.com>
[ Upstream commit e11e0455c0d7d3d62276a0c55d9dfbc16779d691 ]
If RFCOMM_DEFER_SETUP is set in the flags, rfcomm_sock_recvmsg() returns
early with 0 without updating the possibly set msg_namelen member. This,
in turn, leads to a 128 byte kernel stack leak in net/socket.c.
Fix this by updating msg_namelen in this case. For all other cases it
will be handled in bt_sock_stream_recvmsg().
Cc: Marcel Holtmann <marcel@holtmann.org>
Cc: Gustavo Padovan <gustavo@padovan.org>
Cc: Johan Hedberg <johan.hedberg@gmail.com>
[ Upstream commit 4683f42fde3977bdb4e8a09622788cc8b5313778 ]
In case the socket is already shutting down, bt_sock_recvmsg() returns
with 0 without updating msg_namelen leading to net/socket.c leaking the
local, uninitialized sockaddr_storage variable to userland -- 128 bytes
Fix this by moving the msg_namelen assignment in front of the shutdown
test.
[ Upstream commit ef3313e84acbf349caecae942ab3ab731471f1a1 ]
When msg_namelen is non-zero the sockaddr info gets filled out, as
requested, but the code fails to initialize the padding bytes of struct
sockaddr_ax25 inserted by the compiler for alignment. Additionally the
msg_namelen value is updated to sizeof(struct full_sockaddr_ax25) but is
not always filled up to this size.
[ Upstream commit 9b3e617f3df53822345a8573b6d358f6b9e5ed87 ]
about vcc_recvmsg() not filling the msg_name in case it was set.
[ Upstream commit 83f1b4ba917db5dc5a061a44b3403ddb6e783494 ]
Commit 257b5358b32f ("scm: Capture the full credentials of the scm
sender") changed the credentials passing code to pass in the effective
uid/gid instead of the real uid/gid.
Obviously this doesn't matter most of the time (since normally they are
the same), but it results in differences for suid binaries when the wrong
uid/gid ends up being used.
This just undoes that (presumably unintentional) part of the commit.
Reported-by: Andy Lutomirski <luto@amacapital.net>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Serge E. Hallyn <serge@hallyn.com>
Cc: stable@vger.kernel.org
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
[ Upstream commit 12fb3dd9dc3c64ba7d64cec977cca9b5fb7b1d4e ]
commit bd090dfc634d (tcp: tcp_replace_ts_recent() should not be called
from tcp_validate_incoming()) introduced a TS ecr bug in slow path
processing.
1 A > B P. 1:10001(10000) ack 1 <nop,nop,TS val 1001 ecr 200>
2 B < A . 1:1(0) ack 1 win 257 <sack 9001:10001,TS val 300 ecr 1001>
3 A > B . 1:1001(1000) ack 1 win 227 <nop,nop,TS val 1002 ecr 200>
4 A > B . 1001:2001(1000) ack 1 win 227 <nop,nop,TS val 1002 ecr 200>
(ecr 200 should be ecr 300 in packets 3 & 4)
Problem is tcp_ack() can trigger send of new packets (retransmits),
reflecting the prior TSval, instead of the TSval contained in the
currently processed incoming packet.
Fix this by calling tcp_replace_ts_recent() from tcp_ack() after the
checks, but before the actions.
Reported-by: Yuchung Cheng <ycheng@google.com>
Cc: Neal Cardwell <ncardwell@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
[ Upstream commit 586c31f3bf04c290dc0a0de7fc91d20aa9a5ee53 ]
For sensitive data like keying material, it is common practice to zero
out keys before returning the memory back to the allocator. Thus, use
kzfree instead of kfree.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit 06848c10f720cbc20e3b784c0df24930b7304b93 ]
Fix to return a negative error code from the error handling
case instead of 0, as returned elsewhere in this function.
Acked-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit d66954a066158781ccf9c13c91d0316970fe57b6 ]
There is a bug in cookie_v4_check (net/ipv4/syncookies.c):
flowi4_init_output(&fl4, 0, sk->sk_mark, RT_CONN_FLAGS(sk),
RT_SCOPE_UNIVERSE, IPPROTO_TCP,
inet_sk_flowi_flags(sk),
(opt && opt->srr) ? opt->faddr : ireq->rmt_addr,
ireq->loc_addr, th->source, th->dest);
Here we do not respect sk->sk_bound_dev_if, therefore wrong dst_entry may be
taken. This dst_entry is used by new socket (get_cookie_sock ->
tcp_v4_syn_recv_sock), so its packets may take the wrong path.
Signed-off-by: Dmitry Popov <dp@highloadlab.com>
[ Upstream commit 88c5b5ce5cb57af6ca2a7cf4d5715fa320448ff9 ]
Signed-off-by: Michael Riesch <michael.riesch@omicron.at>
Cc: Jiri Benc <jbenc@redhat.com>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Acked-by: Mark Rustad <mark.d.rustad@intel.com>
[ Upstream commit 124dff01afbdbff251f0385beca84ba1b9adda68 ]
Commit 130549fe ("netfilter: reset nf_trace in nf_reset") added code
to reset nf_trace in nf_reset(). This is wrong and unnecessary.
nf_reset() is used in the following cases:
- when passing packets up the the socket layer, at which point we want to
release all netfilter references that might keep modules pinned while
the packet is queued. nf_trace doesn't matter anymore at this point.
- when encapsulating or decapsulating IPsec packets. We want to continue
tracing these packets after IPsec processing.
- when passing packets through virtual network devices. Only devices on
that encapsulate in IPv4/v6 matter since otherwise nf_trace is not
used anymore. Its not entirely clear whether those packets should
be traced after that, however we've always done that.
- when passing packets through virtual network devices that make the
packet cross network namespace boundaries. This is the only cases
where we clearly want to reset nf_trace and is also what the
original patch intended to fix.
Add a new function nf_reset_trace() and use it in dev_forward_skb() to
fix this properly.
[ Upstream commit 0e82e7f6dfeec1013339612f74abc2cdd29d43d2 ]
It was reported that the following LSB test case failed
https://lsbbugs.linuxfoundation.org/attachment.cgi?id=2144 because we
were not coallescing unix stream messages when the application was
expecting us to.
The problem was that the first send was before the socket was accepted
and thus sock->sk_socket was NULL in maybe_add_creds, and the second
send after the socket was accepted had a non-NULL value for sk->socket
and thus we could tell the credentials were not needed so we did not
bother.
The unnecessary credentials on the first message cause
unix_stream_recvmsg to start verifying that all messages had the same
credentials before coallescing and then the coallescing failed because
the second message had no credentials.
Ignoring credentials when we don't care in unix_stream_recvmsg fixes a
long standing pessimization which would fail to coallesce messages when
reading from a unix stream socket if the senders were different even if
we did not care about their credentials.
I have tested this and verified that the in the LSB test case mentioned
above that the messages do coallesce now, while the were failing to
coallesce without this change.
Reported-by: Karel Srot <ksrot@redhat.com>
Reported-by: Ding Tianhong <dingtianhong@huawei.com>
[ Upstream commit 4543fbefe6e06a9e40d9f2b28d688393a299f079 ]
A few drivers use dev_uc_sync/unsync to synchronize the
address lists from master down to slave/lower devices. In
some cases (bond/team) a single address list is synched down
to multiple devices. At the time of unsync, we have a leak
in these lower devices, because "synced" is treated as a
boolean and the address will not be unsynced for anything after
the first device/call.
Treat "synced" as a count (same as refcount) and allow all
unsync calls to work.
Signed-off-by: Vlad Yasevich <vyasevic@redhat.com>
[ Upstream commit 25fb6ca4ed9cad72f14f61629b68dc03c0d9713f ]
IPv6 Routing table becomes broken once we do ifdown, ifup of the loopback(lo)
interface. After down-up, routes of other interface's IPv6 addresses through
'lo' are lost.
IPv6 addresses assigned to all interfaces are routed through 'lo' for internal
communication. Once 'lo' is down, those routing entries are removed from routing
table. But those removed entries are not being re-created properly when 'lo' is
brought up. So IPv6 addresses of other interfaces becomes unreachable from the
same machine. Also this breaks communication with other machines because of
NDISC packet processing failure.
This patch fixes this issue by reading all interface's IPv6 addresses and adding
them to IPv6 routing table while bringing up 'lo'.
==Testing==
Before applying the patch:
$ route -A inet6
Kernel IPv6 routing table
Destination Next Hop Flag Met Ref Use If
2000::20/128 :: U 256 0 0 eth0
fe80::/64 :: U 256 0 0 eth0
::/0 :: !n -1 1 1 lo
::1/128 :: Un 0 1 0 lo
2000::20/128 :: Un 0 1 0 lo
fe80::xxxx:xxxx:xxxx:xxxx/128 :: Un 0 1 0 lo
ff00::/8 :: U 256 0 0 eth0
$ sudo ifdown lo
$ sudo ifup lo
$ route -A inet6
After applying the patch:
$ route -A inet6
Kernel IPv6 routing
table
$ sudo ifdown lo
$ sudo ifup lo
$ route -A inet6
Signed-off-by: Balakumaran Kannan <Balakumaran.Kannan@ap.sony.com>
Signed-off-by: Maruthi Thotad <Maruthi.Thotad@ap.sony.com>
[ Upstream commit f0f6ee1f70c4eaab9d52cf7d255df4bd89f8d1c2 ]
currently cbq works incorrectly for limits > 10% real link bandwidth,
and practically does not work for limits > 50% real link bandwidth.
Below are results of experiments taken on 1 Gbit link
In shaper | Actual Result
100M | 108 Mbps
200M | 244 Mbps
300M | 412 Mbps
500M | 893 Mbps
This happen because of q->now changes incorrectly in cbq_dequeue():
when it is called before real end of packet transmitting,
L2T is greater than real time delay, q_now gets an extra boost
but never compensate it.
To fix this problem we prevent change of q->now until its synchronization
with real time.
Signed-off-by: Vasily Averin <vvs@openvz.org>
Reviewed-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
This reverts commit 9829fe9806e22d7a822f4c947cc432c8d1774b54 which is
upstream commit 4a7df340ed1bac190c124c1601bfc10cde9fb4fb
It turns out this causes problems on the 3.0-stable release.
Reported-by: Thomas Voegtle <tv@lio96.de>
Acked-by: Cong Wang <amwang@redhat.com>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Eric Dumazet <edumazet@google.com>
[ Upstream commit 00cfec37484761a44a3b6f4675a54caa618210ae ]
commit 35d48903e97819 (bonding: fix rx_handler locking) added a race
in bonding driver, reported by Steven Rostedt who did a very good
diagnosis :
<quoting Steven>
I'm currently debugging a crash in an old 3.0-rt kernel that one of our
customers is seeing. The bug happens with a stress test that loads and
unloads the bonding module in a loop (I don't know all the details as
I'm not the one that is directly interacting with the customer). But the
bug looks to be something that may still be present and possibly present
in mainline too. It will just be much harder to trigger it in mainline.
In -rt, interrupts are threads, and can schedule in and out just like
any other thread. Note, mainline now supports interrupt threads so this
may be easily reproducible in mainline as well. I don't have the ability
to tell the customer to try mainline or other kernels, so my hands are
somewhat tied to what I can do.
But according to a core dump, I tracked down that the eth irq thread
crashed in bond_handle_frame() here:
slave = bond_slave_get_rcu(skb->dev);
bond = slave->bond; <--- BUG
the slave returned was NULL and accessing slave->bond caused a NULL
pointer dereference.
Looking at the code that unregisters the handler:
void netdev_rx_handler_unregister(struct net_device *dev)
ASSERT_RTNL();
RCU_INIT_POINTER(dev->rx_handler, NULL);
RCU_INIT_POINTER(dev->rx_handler_data, NULL);
Which is basically:
dev->rx_handler = NULL;
dev->rx_handler_data = NULL;
And looking at __netif_receive_skb() we have:
rx_handler = rcu_dereference(skb->dev->rx_handler);
if (rx_handler) {
if (pt_prev) {
ret = deliver_skb(skb, pt_prev, orig_dev);
pt_prev = NULL;
switch (rx_handler(&skb)) {
My question to all of you is, what stops this interrupt from happening
while the bonding module is unloading? What happens if the interrupt
triggers and we have this:
CPU0 CPU1
rx_handler = skb->dev->rx_handler
netdev_rx_handler_unregister() {
rx_handler()
bond_handle_frame() {
slave = skb->dev->rx_handler;
bond = slave->bond; <-- NULL pointer dereference!!!
What protection am I missing in the bond release handler that would
prevent the above from happening?
</quoting Steven>
We can fix bug this in two ways. First is adding a test in
bond_handle_frame() and others to check if rx_handler_data is NULL.
A second way is adding a synchronize_net() in
netdev_rx_handler_unregister() to make sure that a rcu protected reader
has the guarantee to see a non NULL rx_handler_data.
The second way is better as it avoids an extra test in fast path.
Reported-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Jiri Pirko <jpirko@redhat.com>
Cc: Paul E. McKenney <paulmck@us.ibm.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
[ Upstream commit a79ca223e029aa4f09abb337accf1812c900a800 ]
Signed-off-by: Hong Zhiguo <honkiko@gmail.com>
[ Upstream commit ded34e0fe8fe8c2d595bfa30626654e4b87621e0 ]
As reported by Jan, and others over the past few years, there is a
race condition caused by unix_release setting the sock->sk pointer
to NULL before properly marking the socket as dead/orphaned. This
can cause a problem with the LSM hook security_unix_may_send() if
there is another socket attempting to write to this partially
released socket in between when sock->sk is set to NULL and it is
marked as dead/orphaned. This patch fixes this by only setting
sock->sk to NULL after the socket has been marked as dead; I also
take the opportunity to make unix_release_sock() a void function
as it only ever returned 0/success.
Dave, I think this one should go on the -stable pile.
Special thanks to Jan for coming up with a reproducer for this
problem.
Reported-by: Jan Stancek <jan.stancek@gmail.com>
Signed-off-by: Paul Moore <pmoore@redhat.com>
[ Upstream commits 73214f5d9f33b79918b1f7babddd5c8af28dd23d
and f1e79e208076ffe7bad97158275f1c572c04f5c7, the latter
adds an assertion to genetlink to prevent this from happening
again in the future. ]
The original name is too long.
Signed-off-by: Masatake YAMATO <yamato@redhat.com>
[ Upstream commit 4a7df340ed1bac190c124c1601bfc10cde9fb4fb ]
vlan_vid_del() could possibly free ->vlan_info after a RCU grace
period, however, we may still refer to the freed memory area
by 'grp' pointer. Found by code inspection.
This patch moves vlan_vid_del() as behind as possible.
Signed-off-by: Cong Wang <amwang@redhat.com>
[ Upstream commit 7ebe183c6d444ef5587d803b64a1f4734b18c564 ]
On SACK reneging the sender immediately retransmits and forces a
timeout but disables Eifel (undo). If the (buggy) receiver does not
drop any packet this can trigger a false slow-start retransmit storm
driven by the ACKs of the original packets. This can be detected with
undo and TCP timestamps.
Signed-off-by: Yuchung Cheng <ycheng@google.com>
[ Upstream commit f4541d60a449afd40448b06496dcd510f505928e ]
A long standing problem with TSO is the fact that tcp_tso_should_defer()
rearms the deferred timer, while it should not.
Current code leads to following bad bursty behavior :
20:11:24.484333 IP A > B: . 297161:316921(19760) ack 1 win 119
20:11:24.484337 IP B > A: . ack 263721 win 1117
20:11:24.485086 IP B > A: . ack 265241 win 1117
20:11:24.485925 IP B > A: . ack 266761 win 1117
20:11:24.486759 IP B > A: . ack 268281 win 1117
20:11:24.487594 IP B > A: . ack 269801 win 1117
20:11:24.488430 IP B > A: . ack 271321 win 1117
20:11:24.489267 IP B > A: . ack 272841 win 1117
20:11:24.490104 IP B > A: . ack 274361 win 1117
20:11:24.490939 IP B > A: . ack 275881 win 1117
20:11:24.491775 IP B > A: . ack 277401 win 1117
20:11:24.491784 IP A > B: . 316921:332881(15960) ack 1 win 119
20:11:24.492620 IP B > A: . ack 278921 win 1117
20:11:24.493448 IP B > A: . ack 280441 win 1117
20:11:24.494286 IP B > A: . ack 281961 win 1117
20:11:24.495122 IP B > A: . ack 283481 win 1117
20:11:24.495958 IP B > A: . ack 285001 win 1117
20:11:24.496791 IP B > A: . ack 286521 win 1117
20:11:24.497628 IP B > A: . ack 288041 win 1117
20:11:24.498459 IP B > A: . ack 289561 win 1117
20:11:24.499296 IP B > A: . ack 291081 win 1117
20:11:24.500133 IP B > A: . ack 292601 win 1117
20:11:24.500970 IP B > A: . ack 294121 win 1117
20:11:24.501388 IP B > A: . ack 295641 win 1117
20:11:24.501398 IP A > B: . 332881:351881(19000) ack 1 win 119
While the expected behavior is more like :
20:19:49.259620 IP A > B: . 197601:202161(4560) ack 1 win 119
20:19:49.260446 IP B > A: . ack 154281 win 1212
20:19:49.261282 IP B > A: . ack 155801 win 1212
20:19:49.262125 IP B > A: . ack 157321 win 1212
20:19:49.262136 IP A > B: . 202161:206721(4560) ack 1 win 119
20:19:49.262958 IP B > A: . ack 158841 win 1212
20:19:49.263795 IP B > A: . ack 160361 win 1212
20:19:49.264628 IP B > A: . ack 161881 win 1212
20:19:49.264637 IP A > B: . 206721:211281(4560) ack 1 win 119
20:19:49.265465 IP B > A: . ack 163401 win 1212
20:19:49.265886 IP B > A: . ack 164921 win 1212
20:19:49.266722 IP B > A: . ack 166441 win 1212
20:19:49.266732 IP A > B: . 211281:215841(4560) ack 1 win 119
20:19:49.267559 IP B > A: . ack 167961 win 1212
20:19:49.268394 IP B > A: . ack 169481 win 1212
20:19:49.269232 IP B > A: . ack 171001 win 1212
20:19:49.269241 IP A > B: . 215841:221161(5320) ack 1 win 119
Cc: Yuchung Cheng <ycheng@google.com>
Cc: Van Jacobson <vanj@google.com>
Cc: Nandita Dukkipati <nanditad@google.com>
commit bf118a342f10dafe44b14451a1392c3254629a1f upstream.
The NFSv4 bitmap size is unbounded: a server can return an arbitrary
sized bitmap in an FATTR4_WORD0_ACL request. Replace using the
nfs4_fattr_bitmap_maxsz as a guess to the maximum bitmask returned by a server
with the inclusion of the bitmap (xdr length plus bitmasks) and the acl data
xdr length to the (cached) acl page data.
This is a general solution to commit e5012d1f "NFSv4.1: update
nfs4_fattr_bitmap_maxsz" and fixes hitting a BUG_ON in xdr_shrink_bufhead
when getting ACLs.
Fix a bug in decode_getacl that returned -EINVAL on ACLs > page when getxattr
was called with a NULL buffer, preventing ACL > PAGE_SIZE from being retrieved.
Signed-off-by: Andy Adamson <andros@netapp.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit b5a1eeef04cc7859f34dec9b72ea1b28e4aba07c upstream.
Don't write more than the requested number of bytes of an batman-adv icmp
packet to the userspace buffer. Otherwise unrelated userspace memory might get
overridden by the kernel.
Signed-off-by: Sven Eckelmann <sven@narfation.org>
Signed-off-by: Marek Lindner <lindner_marek@yahoo.de>
commit c00b6856fc642b234895cfabd15b289e76726430 upstream.
Writing a icmp_packet_rr and then reading icmp_packet can lead to kernel
memory corruption, if __user *buf is just below TASK_SIZE.
Signed-off-by: Paul Kot <pawlkt@gmail.com>
[sven@narfation.org: made it checkpatch clean]
commit cb101ed2c3c7c0224d16953fe77bfb9d6c2cb9df upstream.
There are multiple locations in the X.25 packet layer where a skb is
assumed to be of at least a certain size and that all its data is
currently available at skb->data. These assumptions are not checked,
hence buffer overreads may occur. Use pskb_may_pull to check these
minimal size assumptions and ensure that data is available at skb->data
when necessary, as well as use skb_copy_bits where needed.
Signed-off-by: Matthew Daley <mattjd@gmail.com>
Cc: Andrew Hendry <andrew.hendry@gmail.com>
Acked-by: Andrew Hendry <andrew.hendry@gmail.com>
commit c7fd0d48bde943e228e9c28ce971a22d6a1744c4 upstream.
X.25 call user data is being copied in its entirety from incoming messages
without consideration to the size of the destination buffers, leading to
possible buffer overflows. Validate incoming call user data lengths before
these copies are performed.
It appears this issue was noticed some time ago, however nothing seemed to
come of it: see http://www.spinics.net/lists/linux-x25/msg00043.html and
commit 8db09f26f912f7c90c764806e804b558da520d4f.
Tested-by: Andrew Hendry <andrew.hendry@gmail.com>
commit 896ee0eee6261e30c3623be931c3f621428947df upstream.
This makes sure that release_sock is called for all error conditions in
irda_getsockopt.
Reported-by: Brad Spengler <spender@grsecurity.net>
commit eb20ff9c91ddcb2d55c1849a87d3db85af5e88a9 upstream.
With deferred setup for SCO, it is possible that userspace closes the
socket when it is in the BT_CONNECT2 state, after the Connect Request is
received but before the Accept Synchonous Connection is sent.
If this happens the following crash was observed, when the connection is
terminated:
[ +0.000003] hci_sync_conn_complete_evt: hci0 status 0x10
[ +0.000005] sco_connect_cfm: hcon ffff88003d1bd800 bdaddr 40:98:4e:32:d7:39 status 16
[ +0.000003] sco_conn_del: hcon ffff88003d1bd800 conn ffff88003cc8e300, err 110
[ +0.000015] BUG: unable to handle kernel NULL pointer dereference at 0000000000000199
[ +0.000906] IP: [<ffffffff810620dd>] __lock_acquire+0xed/0xe82
[ +0.000000] PGD 3d21f067 PUD 3d291067 PMD 0
[ +0.000000] Oops: 0002 [#1] SMP
[ +0.000000] Modules linked in: rfcomm bnep btusb bluetooth
[ +0.000000] CPU 0
[ +0.000000] Pid: 1481, comm: kworker/u:2H Not tainted 3.9.0-rc1-25019-gad82cdd #1 Bochs Bochs
[ +0.000000] RIP: 0010:[<ffffffff810620dd>] [<ffffffff810620dd>] __lock_acquire+0xed/0xe82
[ +0.000000] RSP: 0018:ffff88003c3c19d8 EFLAGS: 00010002
[ +0.000000] RAX: 0000000000000001 RBX: 0000000000000246 RCX: 0000000000000000
[ +0.000000] RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff88003d1be868
[ +0.000000] RBP: ffff88003c3c1a98 R08: 0000000000000002 R09: 0000000000000000
[ +0.000000] R10: ffff88003d1be868 R11: ffff88003e20b000 R12: 0000000000000002
[ +0.000000] R13: ffff88003aaa8000 R14: 000000000000006e R15: ffff88003d1be850
[ +0.000000] FS: 0000000000000000(0000) GS:ffff88003e200000(0000) knlGS:0000000000000000
[ +0.000000] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ +0.000000] CR2: 0000000000000199 CR3: 000000003c1cb000 CR4: 00000000000006b0
[ +0.000000] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ +0.000000] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ +0.000000] Process kworker/u:2H (pid: 1481, threadinfo ffff88003c3c0000, task ffff88003aaa8000)
[ +0.000000] Stack:
[ +0.000000] ffffffff81b16342 0000000000000000 0000000000000000 ffff88003d1be868
[ +0.000000] ffffffff00000000 00018c0c7863e367 000000003c3c1a28 ffffffff8101efbd
[ +0.000000] 0000000000000000 ffff88003e3d2400 ffff88003c3c1a38 ffffffff81007c7a
[ +0.000000] Call Trace:
[ +0.000000] [<ffffffff8101efbd>] ? kvm_clock_read+0x34/0x3b
[ +0.000000] [<ffffffff81007c7a>] ? paravirt_sched_clock+0x9/0xd
[ +0.000000] [<ffffffff81007fd4>] ? sched_clock+0x9/0xb
[ +0.000000] [<ffffffff8104fd7a>] ? sched_clock_local+0x12/0x75
[ +0.000000] [<ffffffff810632d1>] lock_acquire+0x93/0xb1
[ +0.000000] [<ffffffffa0022339>] ? spin_lock+0x9/0xb [bluetooth]
[ +0.000000] [<ffffffff8105f3d8>] ? lock_release_holdtime.part.22+0x4e/0x55
[ +0.000000] [<ffffffff814f6038>] _raw_spin_lock+0x40/0x74
[ +0.000000] [<ffffffff814f6936>] ? _raw_spin_unlock+0x23/0x36
[ +0.000000] [<ffffffffa0022339>] spin_lock+0x9/0xb [bluetooth]
[ +0.000000] [<ffffffffa00230cc>] sco_conn_del+0x76/0xbb [bluetooth]
[ +0.000000] [<ffffffffa002391d>] sco_connect_cfm+0x2da/0x2e9 [bluetooth]
[ +0.000000] [<ffffffffa000862a>] hci_proto_connect_cfm+0x38/0x65 [bluetooth]
[ +0.000000] [<ffffffffa0008d30>] hci_sync_conn_complete_evt.isra.79+0x11a/0x13e [bluetooth]
[ +0.000000] [<ffffffffa000cd96>] hci_event_packet+0x153b/0x239d [bluetooth]
[ +0.000000] [<ffffffff814f68ff>] ? _raw_spin_unlock_irqrestore+0x48/0x5c
[ +0.000000] [<ffffffffa00025f6>] hci_rx_work+0xf3/0x2e3 [bluetooth]
[ +0.000000] [<ffffffff8103efed>] process_one_work+0x1dc/0x30b
[ +0.000000] [<ffffffff8103ef83>] ? process_one_work+0x172/0x30b
[ +0.000000] [<ffffffff8103e07f>] ? spin_lock_irq+0x9/0xb
[ +0.000000] [<ffffffff8103fc8d>] worker_thread+0x123/0x1d2
[ +0.000000] [<ffffffff8103fb6a>] ? manage_workers+0x240/0x240
[ +0.000000] [<ffffffff81044211>] kthread+0x9d/0xa5
[ +0.000000] [<ffffffff81044174>] ? __kthread_parkme+0x60/0x60
[ +0.000000] [<ffffffff814f75bc>] ret_from_fork+0x7c/0xb0
[ +0.000000] Code: d7 44 89 8d 50 ff ff ff 4c 89 95 58 ff ff ff e8 44 fc ff ff 44 8b 8d 50 ff ff ff 48 85 c0 4c 8b 95 58 ff ff ff 0f 84 7a 04 00 00 <f0> ff 80 98 01 00 00 83 3d 25 41 a7 00 00 45 8b b5 e8 05 00 00
[ +0.000000] RIP [<ffffffff810620dd>] __lock_acquire+0xed/0xe82
[ +0.000000] RSP <ffff88003c3c19d8>
[ +0.000000] ---[ end trace e73cd3b52352dd34 ]---
Signed-off-by: Vinicius Costa Gomes <vinicius.gomes@openbossa.org>
Tested-by: Frederic Dalleau <frederic.dalleau@intel.com>
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
commit 1166fde6a923c30f4351515b6a9a1efc513e7d00 upstream.
We need to be careful when testing task->tk_waitqueue in
rpc_wake_up_task_queue_locked, because it can be changed while we
are holding the queue->lock.
By adding appropriate memory barriers, we can ensure that it is safe to
test task->tk_waitqueue for equality if the RPC_TASK_QUEUED bit is set.
[ Upstream commit 5a3da1fe9561828d0ca7eca664b16ec2b9bf0055 ]
This patch introduces a constant limit of the fragment queue hash
table bucket list lengths. Currently the limit 128 is choosen somewhat
arbitrary and just ensures that we can fill up the fragment cache with
empty packets up to the default ip_frag_high_thresh limits. It should
just protect from list iteration eating considerable amounts of cpu.
If we reach the maximum length in one hash bucket a warning is printed.
This is implemented on the caller side of inet_frag_find to distinguish
between the different users of inet_fragment.c.
I dropped the out of memory warning in the ipv4 fragment lookup path,
because we already get a warning by the slab allocator.
Cc: Jesper Dangaard Brouer <jbrouer@redhat.com>
[ Upstream commit a5b8db91442fce9c9713fcd656c3698f1adde1d6 ]
Range/validity checks on rta_type in rtnetlink_rcv_msg() do
not account for flags that may be set. This causes the function
to return -EINVAL when flags are set on the type (for example
NLA_F_NESTED).
Acked-by: Thomas Graf <tgraf@suug.ch>
matched transport
[ Upstream commit 2317f449af30073cfa6ec8352e4a65a89e357bdd ]
sctp_assoc_lookup_tsn() function searchs which transport a certain TSN
was sent on, if not found in the active_path transport, then go search
all the other transports in the peer's transport_addr_list, however, we
should continue to the next entry rather than break the loop when meet
the active_path transport.
Signed-off-by: Xufeng Zhang <xufeng.zhang@windriver.com>
[ Upstream commit 4660c7f498c07c43173142ea95145e9dac5a6d14 ]
This is needed in order to detect if the timestamp option appears
more than once in a packet, to remove the option if the packet is
fragmented, etc. My previous change neglected to store the option
location when the router addresses were prespecified and Pointer >
Length. But now the option location is also stored when Flag is an
unrecognized value, to ensure these option handling behaviors are
still performed.
Signed-off-by: David Ward <david.ward@ll.mit.edu>
[ Upstream commit 29cd8ae0e1a39e239a3a7b67da1986add1199fc0 ]
The dcb netlink interface leaks stack memory in various places:
* perm_addr[] buffer is only filled at max with 12 of the 32 bytes but
copied completely,
* no in-kernel driver fills all fields of an IEEE 802.1Qaz subcommand,
so we're leaking up to 58 bytes for ieee_ets structs, up to 136 bytes
for ieee_pfc structs, etc.,
* the same is true for CEE -- no in-kernel driver fills the whole
struct,
Prevent all of the above stack info leaks by properly initializing the
buffers/structures involved.
[ Upstream commit 84d73cd3fb142bf1298a8c13fd4ca50fd2432372 ]
Initialize the mac address buffer with 0 as the driver specific function
will probably not fill the whole buffer. In fact, all in-kernel drivers
fill only ETH_ALEN of the MAX_ADDR_LEN bytes, i.e. 6 of the 32 possible
bytes. Therefore we currently leak 26 bytes of stack memory to userland
via the netlink interface.
[ Upstream commit ddf64354af4a702ee0b85d0a285ba74c7278a460 ]
v2:
a) used struct ipv6_addr_props
v3:
a) reverted changes for ipv6_addr_props
v4:
a) do not use __ipv6_addr_needs_scope_id
Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
[ Upstream commit 3bc1b1add7a8484cc4a261c3e128dbe1528ce01f ]
The frames for which rx_handlers return RX_HANDLER_CONSUMED are no longer
counted as dropped. They are counted as successfully received by
'netif_receive_skb'.
This allows network interface drivers to correctly update their RX-OK and
RX-DRP counters based on the result of 'netif_receive_skb'.
Signed-off-by: Cristian Bercaru <B43982@freescale.com>
[ Upstream commits 0c1233aba1e948c37f6dc7620cb7c253fcd71ce9 and
a6a8fe950e1b8596bb06f2c89c3a1a4bf2011ba9 ]
When we have a large number of static label mappings that spill across
the netlink message boundary we fail to properly save our state in the
netlink_callback struct which causes us to repeat the same listings.
This patch fixes this problem by saving the state correctly between
calls to the NetLabel static label netlink "dumpit" routines.
