path: root/net
2007-07-22[IPV6]: MSG_ERRQUEUE messages do not pass to connected raw socketsDmitry Butskoy
Taken from http://bugzilla.kernel.org/show_bug.cgi?id=8747 Problem Description: It is related to the possibility to obtain MSG_ERRQUEUE messages from the udp and raw sockets, both connected and unconnected. There is a little typo in net/ipv6/icmp.c code, which prevents such messages to be delivered to the errqueue of the correspond raw socket, when the socket is CONNECTED. The typo is due to swap of local/remote addresses. Consider __raw_v6_lookup() function from net/ipv6/raw.c. When a raw socket is looked up usual way, it is something like: sk = __raw_v6_lookup(sk, nexthdr, daddr, saddr, IP6CB(skb)->iif); where "daddr" is a destination address of the incoming packet (IOW our local address), "saddr" is a source address of the incoming packet (the remote end). But when the raw socket is looked up for some icmp error report, in net/ipv6/icmp.c:icmpv6_notify() , daddr/saddr are obtained from the echoed fragment of the "bad" packet, i.e. "daddr" is the original destination address of that packet, "saddr" is our local address. Hence, for icmpv6_notify() must use "saddr, daddr" in its arguments, not "daddr, saddr" ... Steps to reproduce: Create some raw socket, connect it to an address, and cause some error situation: f.e. set ttl=1 where the remote address is more than 1 hop to reach. Set IPV6_RECVERR . Then send something and wait for the error (f.e. poll() with POLLERR|POLLIN). You should receive "time exceeded" icmp message (because of "ttl=1"), but the socket do not receive it. If you do not connect your raw socket, you will receive MSG_ERRQUEUE successfully. (The reason is that for unconnected socket there are no actual checks for local/remote addresses). Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-07-22[NET]: Fix gen_estimator timer removal racePatrick McHardy
As noticed by Jarek Poplawski <jarkao2@o2.pl>, the timer removal in gen_kill_estimator races with the timer function rearming the timer. Check whether the timer list is empty before rearming the timer in the timer function to fix this. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Jarek Poplawski <jarkao2@o2.pl> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-07-22SCTP: Add scope_id validation for link-local bindsVlad Yasevich
SCTP currently permits users to bind to link-local addresses, but doesn't verify that the scope id specified at bind matches the interface that the address is configured on. It was report that this can hang a system. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-07-22[NET] skbuff: remove export of static symbolJohannes Berg
skb_clone_fraglist is static so it shouldn't be exported. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-07-22[NETFILTER]: nf_conntrack: don't track locally generated special ICMP errorYasuyuki Kozakai
The conntrack assigned to locally generated ICMP error is usually the one assigned to the original packet which has caused the error. But if the original packet is handled as invalid by nf_conntrack, no conntrack is assigned to the original packet. Then nf_ct_attach() cannot assign any conntrack to the ICMP error packet. In that case the current nf_conntrack_icmp assigns appropriate conntrack to it. But the current code mistakes the direction of the packet. As a result, NAT code mistakes the address to be mangled. To fix the bug, this changes nf_conntrack_icmp not to assign conntrack to such ICMP error. Actually no address is necessary to be mangled in this case. Spotted by Jordan Russell. Upstream commit ID: 130e7a83d7ec8c5c673225e0fa8ea37b1ed507a5 Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-07-22[TCP]: Use default 32768-61000 outgoing port range in all cases.Mark Glines
This diff changes the default port range used for outgoing connections, from "use 32768-61000 in most cases, but use N-4999 on small boxes (where N is a multiple of 1024, depending on just *how* small the box is)" to just "use 32768-61000 in all cases". I don't believe there are any drawbacks to this change, and it keeps outgoing connection ports farther away from the mess of IANA-registered ports. Signed-off-by: Mark Glines <mark@glines.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-07-22[NET]: "wrong timeout value" in sk_wait_data() v2Vasily Averin
sys_setsockopt() do not check properly timeout values for SO_RCVTIMEO/SO_SNDTIMEO, for example it's possible to set negative timeout values. POSIX do not defines behaviour for sys_setsockopt in case negative timeouts, but requires that setsockopt() shall fail with -EDOM if the send and receive timeout values are too big to fit into the timeout fields in the socket structure. In current implementation negative timeout can lead to error messages like "schedule_timeout: wrong timeout value". Proposed patch: - checks tv_usec and returns -EDOM if it is wrong - do not allows to set negative timeout values (sets 0 instead) and outputs ratelimited information message about such attempts. Signed-off-By: Vasily Averin <vvs@sw.ru> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-07-22[IPV4]: Correct rp_filter help text.Dave Jones
As mentioned in http://bugzilla.kernel.org/show_bug.cgi?id=5015 The helptext implies that this is on by default. This may be true on some distros (Fedora/RHEL have it enabled in /etc/sysctl.conf), but the kernel defaults to it off. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-07-22[NETFILTER]: {ip,nf}_conntrack_sctp: fix remotely triggerable NULL ptr ↵Patrick McHardy
dereference (CVE-2007-2876) When creating a new connection by sending an unknown chunk type, we don't transition to a valid state, causing a NULL pointer dereference in sctp_packet when accessing sctp_timeouts[SCTP_CONNTRACK_NONE]. Fix by don't creating new conntrack entry if initial state is invalid. Noticed by Vilmos Nebehaj <vilmos.nebehaj@ramsys.hu> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-23[NET_SCHED]: prio qdisc boundary conditionJamal Hadi Salim
This fixes an out-of-boundary condition when the classified band equals q->bands. Caught by Alexey Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-23[IPV6]: Reverse sense of promisc tests in ip6_mc_inputCorey Mutter
Reverse the sense of the promiscuous-mode tests in ip6_mc_input(). Signed-off-by: Corey Mutter <crm-netdev@mutternet.com> Signed-off-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-23[IPV6]: Send ICMPv6 error on scope violations.David L Stevens
When an IPv6 router is forwarding a packet with a link-local scope source address off-link, RFC 4007 requires it to send an ICMPv6 destination unreachable with code 2 ("not neighbor"), but Linux doesn't. Fix below. Signed-off-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-23[TCP]: zero out rx_opt in tcp_disconnect()Srinivas Aji
When the server drops its connection, NFS client reconnects using the same socket after disconnecting. If the new connection's SYN,ACK doesn't contain the TCP timestamp option and the old connection's did, tp->tcp_header_len is recomputed assuming no timestamp header but tp->rx_opt.tstamp_ok remains set. Then tcp_build_and_update_options() adds in a timestamp option past the end of the allocated TCP header, overwriting TCP data, or when the data is in skb_shinfo(skb)->frags[], overwriting skb_shinfo(skb) causing a crash soon after. (The issue was debugged from such a crash.) Similarly, wscale_ok and sack_ok also get set based on the SYN,ACK packet but not reset on disconnect, since they are zeroed out at initialization. The patch zeroes out the entire tp->rx_opt struct in tcp_disconnect() to avoid this sort of problem. Signed-off-by: Srinivas Aji <Aji_Srinivas@emc.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-23[IPV6]: Track device renames in snmp6.Stephen Hemminger
When network device's are renamed, the IPV6 snmp6 code gets confused. It doesn't track name changes so it will OOPS when network device's are removed. The fix is trivial, just unregister/re-register in notify handler. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-23[IPV6]: Fix slab corruption running ip6sicEric Sesterhenn
2007-05-05[X.25]: Add missing sock_put in x25_receive_dataAndrew Hendry
__x25_find_socket does a sock_hold. This adds a missing sock_put in x25_receive_data. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-04[NETFILTER]: ipt_CLUSTERIP: fix oops in checkentry functionJaroslav Kysela
The clusterip_config_find_get() already increases entries reference counter, so there is no reason to do it twice in checkentry() callback. This causes the config to be freed before it is removed from the list, resulting in a crash when adding the next rule. Signed-off-by: Jaroslav Kysela <perex@suse.cz> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-04[NETFILTER]: ip_nat_proto_gre: do not modify/corrupt GREv0 packets through NATJorge Boncompte
While porting some changes of the 2.6.21-rc7 pptp/proto_gre conntrack and nat modules to a 2.4.32 kernel I noticed that the gre_key function returns a wrong pointer to the GRE key of a version 0 packet thus corrupting the packet payload. The intended behaviour for GREv0 packets is to act like ip_conntrack_proto_generic/ip_nat_proto_unknown so I have ripped the offending functions (not used anymore) and modified the ip_nat_proto_gre modules to not touch version 0 (non PPTP) packets. Signed-off-by: Jorge Boncompte <jorge@dti2.net> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-01[IPV6]: Disallow RH0 by default (CVE-2007-2242)Adrian Bunk
A security issue is emerging. Disallow Routing Header Type 0 by default as we have been doing for IPv4. This version already includes a fix for the original patch. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-01[NETLINK]: Infinite recursion in netlink (CVE-2007-1861)Adrian Bunk
Reply to NETLINK_FIB_LOOKUP messages were misrouted back to kernel, which resulted in infinite recursion and stack overflow. The bug is present in all kernel versions since the feature appeared. The patch also makes some minimal cleanup: 1. Return something consistent (-ENOENT) when fib table is missing 2. Do not crash when queue is empty (does not happen, but yet) 3. Put result of lookup Sergey Vlasov: Oops fix Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: Sergey Vlasov <vsu@altlinux.ru> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-04-25IrDA: irttp_dup spin_lock initialisationGuennadi Liakhovetski
Without this initialization one gets kernel BUG at kernel/rtmutex_common.h:80! Signed-off-by: G. Liakhovetski <gl@dsa-ac.de> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-04-25IrDA: Incorrect TTP header reservationJeet Chaudhuri
We must reserve SAR + MAX_HEADER bytes for IrLMP to fit in. This fixes an oops reported (and fixed) by Jeet Chaudhuri, when max_sdu_size is greater than 0. Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-04-20[IrDA]: Correctly handling socket errorOlaf Kirch
This patch fixes an oops first reported in mid 2006 - see http://lkml.org/lkml/2006/8/29/358 The cause of this bug report is that when an error is signalled on the socket, irda_recvmsg_stream returns without removing a local wait_queue variable from the socket's sk_sleep queue. This causes havoc further down the road. In response to this problem, a patch was made that invoked sock_orphan on the socket when receiving a disconnect indication. This is not a good fix, as this sets sk_sleep to NULL, causing applications sleeping in recvmsg (and other places) to oops. Signed-off-by: Olaf Kirch <olaf.kirch@oracle.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-04-20[NET]: Fix UDP checksum issue in net poll mode.Aubrey Li
In net poll mode, the current checksum function doesn't consider the kind of packet which is padded to reach a specific minimum length. I believe that's the problem causing my test case failed. The following patch fixed this issue. Signed-off-by: Aubrey Li <aubreylee@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-04-13[NET_SCHED]: cls_tcindex: fix compatibility breakagePatrick McHardy
Userspace uses an integer for TCA_TCINDEX_SHIFT, the kernel was changed to expect and use a u16 value in 2.6.11, which broke compatibility on big endian machines. Change back to use int. Reported by Ole Reinartz <ole.reinartz@gmx.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-04-13[IPSEC]: Reject packets within replay window but outside the bit maskHerbert Xu
Up until this point we've accepted replay window settings greater than 32 but our bit mask can only accomodate 32 packets. Thus any packet with a sequence number within the window but outside the bit mask would be accepted. This patch causes those packets to be rejected instead. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-04-13[TCP]: Do receiver-side SWS avoidance for rcvbuf < MSS.John Heffner
Signed-off-by: John Heffner <jheffner@psc.edu> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-04-13[IPv6]: Fix incorrect length check in rawv6_sendmsg()YOSHIFUJI Hideaki
In article <20070329.142644.70222545.davem@davemloft.net> (at Thu, 29 Mar 2007 14:26:44 -0700 (PDT)), David Miller <davem@davemloft.net> says: > From: Sridhar Samudrala <sri@us.ibm.com> > Date: Thu, 29 Mar 2007 14:17:28 -0700 > > > The check for length in rawv6_sendmsg() is incorrect. > > As len is an unsigned int, (len < 0) will never be TRUE. > > I think checking for IPV6_MAXPLEN(65535) is better. > > > > Is it possible to send ipv6 jumbo packets using raw > > sockets? If so, we can remove this check. > > I don't see why such a limitation against jumbo would exist, > does anyone else? > > Thanks for catching this Sridhar. A good compiler should simply > fail to compile "if (x < 0)" when 'x' is an unsigned type, don't > you think :-) Dave, we use "int" for returning value, so we should fix this anyway, IMHO; we should not allow len > INT_MAX. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Acked-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-04-13[NET_SCHED]: cls_basic: fix memory leak in basic_destroyPatrick McHardy
tp->root is not freed on destruction. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-04-10APPLETALK: Fix a remotely triggerable crash (CVE-2007-1357)Jean Delvare
When we receive an AppleTalk frame shorter than what its header says, we still attempt to verify its checksum, and trip on the BUG_ON() at the end of function atalk_sum_skb() because of the length mismatch. This has security implications because this can be triggered by simply sending a specially crafted ethernet frame to a target victim, effectively crashing that host. Thus this qualifies, I think, as a remote DoS. Here is the frame I used to trigger the crash, in npg format: <Appletalk Killer> { # Ethernet header ----- XX XX XX XX XX XX # Destination MAC 00 00 00 00 00 00 # Source MAC 00 1D # Length # LLC header ----- AA AA 03 08 00 07 80 9B # Appletalk # Appletalk header ----- 00 1B # Packet length (invalid) 00 01 # Fake checksum 00 00 00 00 # Destination and source networks 00 00 00 00 # Destination and source nodes and ports # Payload ----- 0C 0D 0E 0F 10 11 12 13 14 } The destination MAC address must be set to those of the victim. The severity is mitigated by two requirements: * The target host must have the appletalk kernel module loaded. I suspect this isn't so frequent. * AppleTalk frames are non-IP, thus I guess they can only travel on local networks. I am no network expert though, maybe it is possible to somehow encapsulate AppleTalk packets over IP. The bug has been reported back in June 2004: http://bugzilla.kernel.org/show_bug.cgi?id=2979 But it wasn't investigated, and was closed in July 2006 as both reporters had vanished meanwhile. This code was new in kernel 2.6.0-test5: http://git.kernel.org/?p=linux/kernel/git/tglx/history.git;a=commitdiff;h=7ab442d7e0a76402c12553ee256f756097cae2d2 And not modified since then, so we can assume that vanilla kernels 2.6.0-test5 and later, and distribution kernels based thereon, are affected. Note that I still do not know for sure what triggered the bug in the real-world cases. The frame could have been corrupted by the kernel if we have a bug hiding somewhere. But more likely, we are receiving the faulty frame from the network. Signed-off-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-04-08tcp: fix cubic scaling errorStephen Hemminger
Doug Leith observed a discrepancy between the version of CUBIC described in the papers and the version in 2.6.18. A math error related to scaling causes Cubic to grow too slowly. Patch is from "Sangtae Ha" <sha2@ncsu.edu>. I validated that it does fix the problems. See the following to show behavior over 500ms 100 Mbit link. Sender (2.6.19-rc3) --- Bridge (2.6.18-rt7) ------- Receiver (2.6.19-rc3) 1G [netem] 100M http://developer.osdl.org/shemminger/tcp/2.6.19-rc3/cubic-orig.png http://developer.osdl.org/shemminger/tcp/2.6.19-rc3/cubic-fix.png Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-04-03[IFB]: Fix crash on input device removalPatrick McHardy
The input_device pointer is not refcounted, which means the device may disappear while packets are queued, causing a crash when ifb passes packets with a stale skb->dev pointer to netif_rx(). Fix by storing the interface index instead and do a lookup where neccessary. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-28[IPV6] HASHTABLES: Use appropriate seed for caluculating ehash index.YOSHIFUJI Hideaki
Tetsuo Handa <handat@pm.nttdata.co.jp> told me that connect(2) with TCPv6 socket almost always took a few minutes to return when we did not have any ports available in the range of net.ipv4.ip_local_port_range. The reason was that we used incorrect seed for calculating index of hash when we check established sockets in __inet6_check_established(). Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-28[NET_SCHED]: Fix ingress lockingPatrick McHardy
Ingress queueing uses a seperate lock for serializing enqueue operations, but fails to properly protect itself against concurrent changes to the qdisc tree. Use queue_lock for now since the real fix it quite intrusive. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-28[NET_SCHED]: cls_basic: fix NULL pointer dereferencePatrick McHardy
cls_basic doesn't allocate tp->root before it is linked into the active classifier list, resulting in a NULL pointer dereference when packets hit the classifier before its ->change function is called. Reported by Chris Madden <chris@reflexsecurity.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-28[NET_SCHED]: Fix endless loops caused by inaccurate qlen countersPatrick McHardy
There are multiple problems related to qlen adjustment that can lead to an upper qdisc getting out of sync with the real number of packets queued, leading to endless dequeueing attempts by the upper layer code. All qdiscs must maintain an accurate q.qlen counter. There are basically two groups of operations affecting the qlen: operations that propagate down the tree (enqueue, dequeue, requeue, drop, reset) beginning at the root qdisc and operations only affecting a subtree or single qdisc (change, graft, delete class). Since qlen changes during operations from the second group don't propagate to ancestor qdiscs, their qlen values become desynchronized. This patch adds a function to propagate qlen changes up the qdisc tree, optionally calling a callback function to perform qdisc-internal maintenance when the child qdisc is deactivated, and converts all qdiscs to use this where necessary. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-24[NETFILTER]: tcp conntrack: accept SYN|URG as validPatrick McHardy
Some stacks apparently send packets with SYN|URG set. Linux accepts these packets, so TCP conntrack should to. Pointed out by Martijn Posthuma <posthuma@sangine.com>. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-24[NETFILTER]: nfnetlink_log: fix use after freeMichał Mirosław
Paranoia: instance_put() might have freed the inst pointer when we spin_unlock_bh(). Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-24[NETFILTER]: nfnetlink_log: fix reference leakMichał Mirosław
Stop reference leaking in nfulnl_log_packet(). If we start a timer we are already taking another reference. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-24[NETFILTER]: nfnetlink_log: fix possible NULL pointer dereferenceMichał Mirosław
Eliminate possible NULL pointer dereference in nfulnl_recv_config(). Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-24[NETFILTER]: nfnetlink_log: fix NULL pointer dereferenceMichał Mirosław
Fix the nasty NULL dereference on multiple packets per netlink message. BUG: unable to handle kernel NULL pointer dereference at virtual address 00000004 printing eip: f8a4b3bf *pde = 00000000 Oops: 0002 [#1] SMP Modules linked in: nfnetlink_log ipt_ttl ipt_REDIRECT xt_tcpudp iptable_nat nf_nat nf_conntrack _ipv4 xt_state ipt_ipp2p xt_NFLOG xt_hashlimit ip6_tables iptable_filter xt_multiport xt_mark i pt_set iptable_raw xt_MARK iptable_mangle ip_tables cls_fw cls_u32 sch_esfq sch_htb ip_set_ipma p ip_set ipt_ULOG x_tables dm_snapshot dm_mirror loop e1000 parport_pc parport e100 floppy ide_ cd cdrom CPU: 0 EIP: 0060:[<f8a4b3bf>] Not tainted VLI EFLAGS: 00010206 (2.6.20 #5) EIP is at __nfulnl_send+0x24/0x51 [nfnetlink_log] eax: 00000000 ebx: f2b5cbc0 ecx: c03f5f54 edx: c03f4000 esi: f2b5cbc8 edi: c03f5f54 ebp: f8a4b3ec esp: c03f5f30 ds: 007b es: 007b ss: 0068 Process swapper (pid: 0, ti=c03f4000 task=c03bece0 task.ti=c03f4000) Stack: f2b5cbc0 f8a4b401 00000100 c0444080 c012af49 00000000 f6f19100 f6f19000 c1707800 c03f5f54 c03f5f54 00000123 00000021 c03e8d08 c0426380 00000009 c0126932 00000000 00000046 c03e9980 c03e6000 0047b007 c01269bd 00000000 Call Trace: [<f8a4b401>] nfulnl_timer+0x15/0x25 [nfnetlink_log] [<c012af49>] run_timer_softirq+0x10a/0x164 [<c0126932>] __do_softirq+0x60/0xba [<c01269bd>] do_softirq+0x31/0x35 [<c0104f6e>] do_IRQ+0x62/0x74 [<c01036cb>] common_interrupt+0x23/0x28 [<c0101018>] default_idle+0x0/0x3f [<c0101045>] default_idle+0x2d/0x3f [<c01010fa>] cpu_idle+0xa0/0xb9 [<c03fb7f5>] start_kernel+0x1a8/0x1ac [<c03fb293>] unknown_bootoption+0x0/0x181 ======================= Code: 5e 5f 5b 5e 5f 5d c3 53 89 c3 8d 40 1c 83 7b 1c 00 74 05 e8 2c ee 6d c7 83 7b 14 00 75 04 31 c0 eb 34 83 7b 10 01 76 09 8b 43 18 <66> c7 40 04 03 00 8b 53 34 8b 43 14 b9 40 00 00 00 e8 08 9a 84 EIP: [<f8a4b3bf>] __nfulnl_send+0x24/0x51 [nfnetlink_log] SS:ESP 0068:c03f5f30 <0>Kernel panic - not syncing: Fatal exception in interrupt <0>Rebooting in 5 seconds.. Panic no more! Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-24[NETFILTER]: nfnetlink_log: fix crash on bridged packetPatrick McHardy
physoutdev is only set on purely bridged packet, when nfnetlink_log is used in the OUTPUT/FORWARD/POSTROUTING hooks on packets forwarded from or to a bridge it crashes when trying to dereference skb->nf_bridge->physoutdev. Reported by Holger Eitzenberger <heitzenberger@astaro.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-24[NETFILTER]: nf_conntrack: fix incorrect classification of IPv6 fragments as ↵Patrick McHardy
ESTABLISHED The individual fragments of a packet reassembled by conntrack have the conntrack reference from the reassembled packet attached, but nfctinfo is not copied. This leaves it initialized to 0, which unfortunately is the value of IP_CT_ESTABLISHED. The result is that all IPv6 fragments are tracked as ESTABLISHED, allowing them to bypass a usual ruleset which accepts ESTABLISHED packets early. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-24Fix reference counting (memory leak) problem in __nfulnl_send() and callers ↵Michał Mirosław
related to packet queueing. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-24NETFILTER: xt_connbytes: fix division by zeroPatrick McHardy
When the packet counter of a connection is zero a division by zero occurs in div64_64(). Fix that by using zero as average value, which is correct as long as the packet counter didn't overflow, at which point we have lost anyway. Based on patch from Jonas Berlin <xkr47@outerspace.dyndns.org>, with suggestions from KOVACS Krisztian <hidden@balabit.hu>. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-24NETFILTER: nf_conntrack_ipv6: fix crash when handling fragmentsPatrick McHardy
When IPv6 connection tracking splits up a defragmented packet into its original fragments, the packets are taken from a list and are passed to the network stack with skb->next still set. This causes dev_hard_start_xmit to treat them as GSO fragments, resulting in a use after free when connection tracking handles the next fragment. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-24NETFILTER: ctnetlink: check for status attribute existence on conntrack creationPablo Neira Ayuso
Check that status flags are available in the netlink message received to create a new conntrack. Fixes a crash in ctnetlink_create_conntrack when the CTA_STATUS attribute is not present. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-24NETFILTER: Kconfig: fix xt_physdev dependenciesPatrick McHardy
xt_physdev depends on bridge netfilter, which is a boolean, but can still be built modular because of special handling in the bridge makefile. Add a dependency on BRIDGE to prevent XT_MATCH_PHYSDEV=y, BRIDGE=m. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-20[NET]: Copy mac_len in skb_clone() as wellAlexey Dobriyan
ANK says: "It is rarely used, that's wy it was not noticed. But in the places, where it is used, it should be disaster." Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-20[IPV6]: ipv6_fl_socklist is inadvertently shared.Masayuki Nakagawa
The ipv6_fl_socklist from listening socket is inadvertently shared with new socket created for connection. This leads to a variety of interesting, but fatal, bugs. For example, removing one of the sockets may lead to the other socket's encountering a page fault when the now freed list is referenced. The fix is to not share the flow label list with the new socket. Signed-off-by: Masayuki Nakagawa <nakagawa.msy@ncos.nec.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
