path: root/net
2009-01-27nfs: note that CONFIG_SUNRPC_XPRT_RDMA turns on server side support tooJ. Bruce Fields
We forgot to update this when adding server-side support. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (92 commits) gianfar: Revive VLAN support vlan: Export symbols as non GPL symbols. bnx2x: tx_has_work should not wait for FW netxen: reduce memory footprint netxen: fix vlan tso/checksum offload net: Fix linux/if_frad.h's suitability for userspace. net: Move config NET_NS to from net/Kconfig to init/Kconfig isdn: Fix missing ifdef in isdn_ppp networking: document "nc" in addition to "netcat" in netconsole.txt e1000e: workaround hw errata af_key: initialize xfrm encap_oa virtio_net: Fix MAX_PACKET_LEN to support 802.1Q VLANs lcs: fix compilation for !CONFIG_IP_MULTICAST rtl8187: Add termination packet to prevent stall iwlwifi: fix rs_get_rate WARN_ON() p54usb: fix packet loss with first generation devices sctp: Fix another socket race during accept/peeloff sctp: Properly timestamp outgoing data chunks for rtx purposes sctp: Correctly start rtx timer on new packet transmissions. sctp: Fix crc32c calculations on big-endian arhes. ...
2009-01-26vlan: Export symbols as non GPL symbols.Ben Greear
In previous kernels, any kernel module could get access to the 'real-device' and the VLAN-ID for a particular VLAN. In more recent kernels, the code was restructured such that this is hard to do without accessing private .h files for any module that cannot use GPL-only symbols. Attached is a patch to once again allow non-GPL modules the ability to access the real-device and VLAN id for VLANs. Signed-off-by: Ben Greear <greearb@candelatech.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-26net: Move config NET_NS to from net/Kconfig to init/KconfigMatt Helsley
Make NET_NS available underneath the generic Namespaces config option since all of the other namespace options are there. Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-25af_key: initialize xfrm encap_oaTimo Teras
Currently encap_oa is left uninitialized, so it contains garbage data which is visible to userland via Netlink. Initialize it by zeroing it out. Signed-off-by: Timo Teras <timo.teras@iki.fi> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-22sctp: Fix another socket race during accept/peeloffVlad Yasevich
There is a race between sctp_rcv() and sctp_accept() where we have moved the association from the listening socket to the accepted socket, but sctp_rcv() processing cached the old socket and continues to use it. The easy solution is to check for the socket mismatch once we've grabed the socket lock. If we hit a mis-match, that means that were are currently holding the lock on the listening socket, but the association is refrencing a newly accepted socket. We need to drop the lock on the old socket and grab the lock on the new one. A more proper solution might be to create accepted sockets when the new association is established, similar to TCP. That would eliminate the race for 1-to-1 style sockets, but it would still existing for 1-to-many sockets where a user wished to peeloff an association. For now, we'll live with this easy solution as it addresses the problem. Reported-by: Michal Hocko <mhocko@suse.cz> Reported-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-22sctp: Properly timestamp outgoing data chunks for rtx purposesVlad Yasevich
Recent changes to the retransmit code exposed a long standing bug where it was possible for a chunk to be time stamped after the retransmit timer was reset. This caused a rare situation where the retrnamist timer has expired, but nothing was marked for retrnasmission because all of timesamps on data were less then 1 rto ago. As result, the timer was never restarted since nothing was retransmitted, and this resulted in a hung association that did couldn't complete the data transfer. The solution is to timestamp the chunk when it's added to the packet for transmission purposes. After the packet is trsnmitted the rtx timer is restarted. This guarantees that when the timer expires, there will be data to retransmit. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-22sctp: Correctly start rtx timer on new packet transmissions.Vlad Yasevich
Commit 62aeaff5ccd96462b7077046357a6d7886175a57 (sctp: Start T3-RTX timer when fast retransmitting lowest TSN) introduced a regression where it was possible to forcibly restart the sctp retransmit timer at the transmission of any new chunk. This resulted in much longer timeout times and sometimes hung sctp connections. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-22mac80211: fix slot time debug messageChristian Lamparter
wlan0: switched to short barker preamble (BSSID=00:01:aa:bb:cc:dd) wlan0: switched to short slot (BSSID=) <something is missing here> should be: wlan0: switched to short barker preamble (BSSID=00:01:aa:bb:cc:dd) wlan0: switched to short slot (BSSID=00:01:aa:bb:cc:dd) Signed-off-by: Christian Lamparter <chunkeey@web.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-22mac80211: decrement ref count to netdev after launching mesh discoveryBrian Cavagnolo
After launching mesh discovery in tx path, reference count was not being decremented. This was preventing module unload. Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: Andrey Yurovsky <andrey@cozybit.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-22fs/Kconfig: move sunrpc outAlexey Dobriyan
2009-01-21netfilter: ctnetlink: fix scheduling while atomicPatrick McHardy
Caused by call to request_module() while holding nf_conntrack_lock. Reported-and-tested-by: Kövesdi György <kgy@teledigit.hu> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-20gro: Fix merging of paged packetsHerbert Xu
The previous fix to paged packets broke the merging because it reset the skb->len before we added it to the merged packet. This wasn't detected because it simply resulted in the truncation of the packet while the missing bit is subsequently retransmitted. The fix is to store skb->len before we clobber it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-20gro: Fix error handling on extremely short fragsHerbert Xu
When a frag is shorter than an Ethernet header, we'd return a zeroed packet instead of aborting. This patch fixes that. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-20gro: Fix handling of complete checksums in IPv6Herbert Xu
We need to perform skb_postpull_rcsum after pulling the IPv6 header in order to maintain the correctness of the complete checksum. This patch also adds a missing iph reload after pulling. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-20NET: net_namespace, fix lock imbalanceJiri Slaby
register_pernet_gen_subsys omits mutex_unlock in one fail path. Fix it. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-20Merge branch 'master' of ↵David S. Miller
2009-01-20Revert "xfrm: For 32/64 compatability wrt. xfrm_usersa_info"David S. Miller
This reverts commit fc8c7dc1b29560c016a67a34ccff32a712b5aa86. As indicated by Jiri Klimes, this won't work. These numbers are not only used the size validation, they are also used to locate attributes sitting after the message. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-19net: Fix data corruption when splicing from sockets.Jarek Poplawski
The trick in socket splicing where we try to convert the skb->data into a page based reference using virt_to_page() does not work so well. The idea is to pass the virt_to_page() reference via the pipe buffer, and refcount the buffer using a SKB reference. But if we are splicing from a socket to a socket (via sendpage) this doesn't work. The from side processing will grab the page (and SKB) references. The sendpage() calls will grab page references only, return, and then the from side processing completes and drops the SKB ref. The page based reference to skb->data is not enough to keep the kmalloc() buffer backing it from being reused. Yet, that is all that the socket send side has at this point. This leads to data corruption if the skb->data buffer is reused by SLAB before the send side socket actually gets the TX packet out to the device. The fix employed here is to simply allocate a page and copy the skb->data bytes into that page. This will hurt performance, but there is no clear way to fix this properly without a copy at the present time, and it is important to get rid of the data corruption. With fixes from Herbert Xu. Tested-by: Willy Tarreau <w@1wt.eu> Foreseen-by: Changli Gao <xiaosuo@gmail.com> Diagnosed-by: Willy Tarreau <w@1wt.eu> Reported-by: Willy Tarreau <w@1wt.eu> Fixed-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-19net: Add debug info to track down GSO checksum bugHerbert Xu
I'm trying to track down why people're hitting the checksum warning in skb_gso_segment. As the problem seems to be hitting lots of people and I can't reproduce it or locate the bug, here is a patch to print out more details which hopefully should help us to track this down. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-19net/9p: fid->fid is used uninitializedRoel Kluin
Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-16cfg80211: Fix parsed country IE info for 5 GHzLuis R. Rodriguez
The country IE number of channels on 5 GHz specifies the number of 5 GHz channels, not the number of sequential channel numbers. For example, if in a country IEs if the first channel given is 36 and the number of channels passed is 4 then the individual channel numbers defined for the 5 GHz PHY by these parameters are: 36, 40, 44, 48 not: 36, 37, 38, 39 See: http://tinyurl.com/11d-clarification Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-16cfg80211: Fix regression with 11d on bandsLuis R. Rodriguez
This fixes a regression on disallowing bands introduced with the new 802.11d support. The issue is that IEEE-802.11 allows APs to send a subset of what a country regulatory domain defines. This was clarified in this document: http://tinyurl.com/11d-clarification As such it is possible, and this is what is done in practice, that a single band 2.4 GHz AP will only send 2.4 GHz band regulatory information through the 802.11 country information element and then the current intersection with what CRDA provided yields a regulatory domain with no 5 GHz information -- even though that country may actually allow 5 GHz operation. We correct this by only applying the intersection rules on a channel if the the intersection yields a regulatory rule on the same band the channel is on. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-16cfg80211: make handle_band() and handle_channel() wiphy specificLuis R. Rodriguez
This allows us to make more wiphy specific judgements when handling the channels later on. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-16mac80211: more kernel-doc fixesRandy Dunlap
Fix (delete) more mac80211 kernel-doc: Warning(linux-2.6.28-git13//include/net/mac80211.h:375): Excess struct/union/enum/typedef member 'retry_count' description in 'ieee80211_tx_info' Warning(linux-2.6.28-git13//net/mac80211/sta_info.h:308): Excess struct/union/enum/typedef member 'last_txrate' description in 'sta_info' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (95 commits) b44: GFP_DMA skb should not escape from driver korina: do not use IRQF_SHARED with IRQF_DISABLED korina: do not stop queue here korina: fix handling tx_chain_tail korina: do tx at the right position korina: do schedule napi after testing for it korina: rework korina_rx() for use with napi korina: disable napi on close and restart korina: reset resource buffer size to 1536 korina: fix usage of driver_data bnx2x: First slow path interrupt race bnx2x: MTU Filter bnx2x: Indirection table initialization index bnx2x: Missing brackets bnx2x: Fixing the doorbell size bnx2x: Endianness issues bnx2x: VLAN tagged packets without VLAN offload bnx2x: Protecting the link change indication bnx2x: Flow control updated before reporting the link bnx2x: Missing mask when calculating flow control ...
2009-01-159p: disallow RDMA if RDMA CM isn't availableRoland Dreier
If INET=y and INFINIBAND=y, but IPV6=m then INFINIBAND_ADDR_TRANS is set to n and the RDMA CM functions rdma_connect() et al are not built. However, the current config dependencies allow NET_9P_RDMA to be selected in this, which leads to a build failure. Fix this by adding a dependency on INFINIBAND_ADDR_TRANS to disallow NET_9P_RDMA in this case. Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Roland Dreier <rolandd@cisco.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Tested-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-14can: fix slowpath issue in hrtimer callback functionOliver Hartkopp
Due to the loopback functionality in can_send() we can not invoke it from hardirq context which was done inside the bcm_tx_timeout_handler() hrtimer callback: [ 700.361154] [<c012228c>] warn_slowpath+0x80/0xb6 [ 700.361163] [<c013d559>] valid_state+0x125/0x136 [ 700.361171] [<c013d858>] mark_lock+0x18e/0x332 [ 700.361180] [<c013e300>] __lock_acquire+0x12e/0xb1e [ 700.361189] [<f8ab5915>] bcm_tx_timeout_handler+0x0/0xbc [can_bcm] [ 700.361198] [<c031e20a>] dev_queue_xmit+0x191/0x479 [ 700.361206] [<c01262a7>] __local_bh_disable+0x2b/0x64 [ 700.361213] [<c031e20a>] dev_queue_xmit+0x191/0x479 [ 700.361225] [<f8aa69a1>] can_send+0xd7/0x11a [can] [ 700.361235] [<f8ab522b>] bcm_can_tx+0x9d/0xd9 [can_bcm] [ 700.361245] [<f8ab597f>] bcm_tx_timeout_handler+0x6a/0xbc [can_bcm] [ 700.361255] [<f8ab5915>] bcm_tx_timeout_handler+0x0/0xbc [can_bcm] [ 700.361263] [<c0134143>] __run_hrtimer+0x5a/0x86 [ 700.361273] [<f8ab5915>] bcm_tx_timeout_handler+0x0/0xbc [can_bcm] [ 700.361282] [<c0134a50>] hrtimer_interrupt+0xb9/0x110 This patch moves the rest of the functionality from the hrtimer callback to the already existing tasklet to fix this slowpath problem. Signed-off-by: Oliver Hartkopp <oliver@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-14net: Add init_dummy_netdev() and fix EMAC driver using itBenjamin Herrenschmidt
This adds an init_dummy_netdev() function that gets a network device structure (allocation and lifetime entirely under caller's control) and initialize the minimum amount of fields so it can be used to schedule NAPI polls without registering a full blown interface. This is to be used by drivers that need to tie several hardware interfaces to a single NAPI poll scheduler due to HW limitations. It also updates the ibm_newemac driver to use that, this fixing the oops on 2.6.29 due to passing NULL as "dev" to netif_napi_add() Symbol is exported GPL only a I don't think we want binary drivers doing that sort of acrobatics (if we want them at all). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Tested-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-14gso: Ensure that the packet is long enoughHerbert Xu
When we get a GSO packet from an untrusted source, we need to ensure that it is sufficiently long so that we don't end up crashing. Based on discovery and patch by Ian Campbell. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-14gro: Fix page ref count for skbs freed normallyHerbert Xu
When an skb with page frags is merged into an existing one, we cannibalise its reference count. This is OK when the skb is reused because we set nr_frags to zero in that case. However, for the case where the skb is freed through kfree_skb, we didn't clear nr_frags which causes the page to be freed prematurely. This is fixed by moving the skb resetting into skb_gro_receive. Reported-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-14xfrm: For 32/64 compatability wrt. xfrm_usersa_infoDavid S. Miller
Reported by Jiri Klimes. Fix suggested by Patrick McHardy. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-14gro: Check for GSO packets and packets with frag_listHerbert Xu
As GRO cannot be applied to packets with frag_list we need to make sure that we reject such packets if they are fed to us, e.g., through a tunnel device. Also there is no point in applying GRO on GSO packets so they too should be rejected. This allows GRO to be used in virtio-net which may produce GSO packets directly but may still benefit from GRO if the other end of it doesn't support GSO. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-14[CVE-2009-0029] System call wrappers part 22Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 21Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 07Heiko Carstens
2009-01-13ipv6: Fix fib6_dump_table walker leakHerbert Xu
When a fib6 table dump is prematurely ended, we won't unlink its walker from the list. This causes all sorts of grief for other users of the list later. Reported-by: Chris Caputo <ccaputo@alt.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-13tcp: splice as many packets as possible at onceWilly Tarreau
As spotted by Willy Tarreau, current splice() from tcp socket to pipe is not optimal. It processes at most one segment per call. This results in low performance and very high overhead due to syscall rate when splicing from interfaces which do not support LRO. Willy provided a patch inside tcp_splice_read(), but a better fix is to let tcp_read_sock() process as many segments as possible, so that tcp_rcv_space_adjust() and tcp_cleanup_rbuf() are called less often. With this change, splice() behaves like tcp_recvmsg(), being able to consume many skbs in one system call. With typical 1460 bytes of payload per frame, that means splice(SPLICE_F_NONBLOCK) can return 16*1460 = 23360 bytes. Signed-off-by: Willy Tarreau <w@1wt.eu> Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-13Merge branch 'master' of ↵David S. Miller
2009-01-13mac80211: fix "‘ret’ may be used uninitialized" warningJohn W. Linville
net/mac80211/ht.c: In function ‘ieee80211_start_tx_ba_session’: net/mac80211/ht.c:472: warning: ‘ret’ may be used uninitialized in this function Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-12pkt_sched: sch_htb: Break all htb_do_events() after 2 jiffiesJarek Poplawski
Currently htb_do_events() breaks events recounting for a level after 2 jiffies, but there is no reason to repeat this for next levels and increase delays even more (with softirqs disabled). htb_dequeue_tree() can add to this too, btw. In such a case q->now time is invalid anyway. Thanks to Patrick McHardy for spotting an error around earlier version of this patch. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-12pkt_sched: sch_htb: Consider used jiffies in htb_do_events()Jarek Poplawski
Next event time should consider jiffies used for recounting. Otherwise qdisc_watchdog_schedule() triggers hrtimer immediately with the event in the past, and may cause very high ksoftirqd cpu usage (if highres is on). There is also removed checking "event" for zero in htb_dequeue(): it's always true in this place. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-12netfilter 08/09: xt_time: print timezone for user informationJan Engelhardt
netfilter: xt_time: print timezone for user information Let users have a way to figure out if their distro set the kernel timezone at all. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-12netfilter 07/09: simplify nf_conntrack_alloc() error handlingJulia Lawall
nf_conntrack_alloc cannot return NULL, so there is no need to check for NULL before using the value. I have also removed the initialization of ct to NULL in nf_conntrack_alloc, since the value is never used, and since perhaps it might lead one to think that return ct at the end might return NULL. The semantic patch that finds this problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @match exists@ expression x, E; position p1,p2; statement S1, S2; @@ x@p1 = nf_conntrack_alloc(...) ... when != x = E ( if (x@p2 == NULL || ...) S1 else S2 | if (x@p2 == NULL && ...) S1 else S2 ) @other_match exists@ expression match.x, E1, E2; position p1!=match.p1,match.p2; @@ x@p1 = E1 ... when != x = E2 x@p2 @ script:python depends on !other_match@ p1 << match.p1; p2 << match.p2; @@ print "%s: call to nf_conntrack_alloc %s bad test %s" % (p1[0].file,p1[0].line,p2[0].line) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-12netfilter 06/09: nf_conntrack: fix ICMP/ICMPv6 timeout sysctls on big-endianPatrick McHardy
An old bug crept back into the ICMP/ICMPv6 conntrack protocols: the timeout values are defined as unsigned longs, the sysctl's maxsize is set to sizeof(unsigned int). Use unsigned int for the timeout values as in the other conntrack protocols. Reported-by: Jean-Mickael Guerin <jean-mickael.guerin@6wind.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-12netfilter 05/09: ebtables: fix inversion in match codeJan Engelhardt
Commit 8cc784ee (netfilter: change return types of match functions for ebtables extensions) broke ebtables matches by inverting the sense of match/nomatch. Reported-by: Matt Cross <matthltc@us.ibm.com> Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-12netfilter 04/09: x_tables: fix match/target revision lookupPatrick McHardy
Commit 55b69e91 (netfilter: implement NFPROTO_UNSPEC as a wildcard for extensions) broke revision probing for matches and targets that are registered with NFPROTO_UNSPEC. Fix by continuing the search on the NFPROTO_UNSPEC list if nothing is found on the af-specific lists. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-12netfilter 03/09: bridge: Disable PPPOE/VLAN processing by defaultHerbert Xu
The PPPOE/VLAN processing code in the bridge netfilter is broken by design. The VLAN tag and the PPPOE session ID are an integral part of the packet flow information, yet they're completely ignored by the bridge netfilter. This is potentially a security hole as it treats all VLANs and PPPOE sessions as the same. What's more, it's actually broken for PPPOE as the bridge netfilter tries to trim the packets to the IP length without adjusting the PPPOE header (and adjusting the PPPOE header isn't much better since the PPPOE peer may require the padding to be present). Therefore we should disable this by default. It does mean that people relying on this feature may lose networking depending on how their bridge netfilter rules are configured. However, IMHO the problems this code causes are serious enough to warrant this. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-12netfilter 02/09: bridge: Fix handling of non-IP packets in FORWARD/POST_ROUTINGHerbert Xu
Currently the bridge FORWARD/POST_ROUTING chains treats all non-IPv4 packets as IPv6. This packet fixes that by returning NF_ACCEPT on non-IP packets instead, just as is done in PRE_ROUTING. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-12netfilter 01/09: remove "happy cracking" messagePatrick McHardy
Don't spam logs for locally generated short packets. these can only be generated by root. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
