path: root/net
2005-10-31[MCAST] IPv6: Check packet size when process MulticastYan Zheng
Signed-off-by: Yan Zheng <yanzheng@21cn.com Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-31[DCCP]: Set socket owner iff packet is not dataHerbert Xu
Here is a complimentary insurance policy for those feeling a bit insecure. You don't have to accept this. However, if you do, you can't blame me for it :) > 1) dccp_transmit_skb sets the owner for all packets except data packets. We can actually verify this by looking at pkt_type. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-31[DCCP]: Simplify skb_set_owner_w semanticsHerbert Xu
While we're at it let's reorganise the set_owner_w calls a little so that: 1) dccp_transmit_skb sets the owner for all packets except data packets. 2) Add dccp_skb_entail to set owner for packets queued for retransmission. 3) Make dccp_transmit_skb static. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-31[IPV6]: Fix behavior of ip6_route_input() for link local addressYan Zheng
I find that linux will reply echo request destined to an address which belongs to an interface other than the one from which the request received. This behavior doesn't make sense for link local address. YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> said: Please note that sender does need to setup neighbor entry by hand to reproduce this bug. (Link-local address on eth1 is not visible on eth0, from the point of view of neighbor discovery in IPv6.) +--------+ +--------+ | sender | | router | +---+----+ +-+----+-+ |eth0 eth0| |eth1 -----+----------------------+- -+-------------- Signed-off-by: Yan Zheng <yanzheng@21cn.com> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Andrew Morton <akpm@osdl.org> (forwarded) Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-31[ROSE]: rose_heartbeat_expiry() locking fixAndrew Morton
Missing unlock, as noted by Ted Unangst <tedu@coverity.com>. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-31[NETFILTER]: Add "revision" support to arp_tables and ip6_tablesHarald Welte
Like ip_tables already has it for some time, this adds support for having multiple revisions for each match/target. We steal one byte from the name in order to accomodate a 8 bit version number. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-31[BRIDGE]: Use ether_compareStephen Hemminger
Use compare_ether_addr in bridge code. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-30[PATCH] Typo fix: dot after newline in printk stringsJean Delvare
Typo fix: dots appearing after a newline in printk strings. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[CRYPTO] Simplify one-member scatterlist expressionsHerbert Xu
This patch rewrites various occurences of &sg[0] where sg is an array of length one to simply sg. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2005-10-30[PATCH] Use sg_set_buf/sg_init_one where applicableDavid Hardeman
This patch uses sg_set_buf/sg_init_one in some places where it was duplicated. Signed-off-by: David Hardeman <david@2gen.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2005-10-29[PATCH] bluetooth hidp is broken on s390Al Viro
Bluetooth HIDP selects INPUT and it really needs it to be there - module depends on input core. And input core is never built on s390... Marked as broken on s390, for now; if somebody has better ideas, feel free to fix it and remove dependency... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[IPV4]: Fix issue reported by Coverity in ipv4/fib_frontend.cJayachandran C
fib_del_ifaddr() dereferences ifa->ifa_dev, so the code already assumes that ifa->ifa_dev is non-NULL, the check is unnecessary. Signed-off-by: Jayachandran C. <c.jayachandran at gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-29[ETH]: ether address compareStephen Hemminger
Expose faster ether compare for use by protocols and other driver. And change name to be more consistent with other ether address manipulation routines in same file Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-28Merge master.kernel.org:/pub/scm/linux/kernel/git/sridhar/lksctp-2.6Arnaldo Carvalho de Melo
2005-10-28[SCTP] Do not allow unprivileged programs initiating new associations onIvan Skytte Jorgensen
privileged ports. Signed-off-by: Ivan Skytte Jorgensen <isj-sctp@i1.dk> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com>
2005-10-28[SCTP] Allow SCTP_MAXSEG to revert to default frag point with a '0' value.Ivan Skytte Jorgensen
2005-10-28[SCTP] Fix SCTP_SETADAPTION sockopt to use the correct structure.Ivan Skytte Jorgensen
2005-10-28[SCTP] Rename SCTP specific control message flags.Ivan Skytte Jorgensen
Rename SCTP specific control message flags to use SCTP_ prefix rather than MSG_ prefix as per the latest sctp sockets API draft. Signed-off-by: Ivan Skytte Jorgensen <isj-sctp@i1.dk> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com>
2005-10-28Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
2005-10-28[MCAST] IPv6: Fix algorithm to compute Querier's Query IntervalYan Zheng
5.1.3. Maximum Response Code The Maximum Response Code field specifies the maximum time allowed before sending a responding Report. The actual time allowed, called the Maximum Response Delay, is represented in units of milliseconds, and is derived from the Maximum Response Code as follows: If Maximum Response Code < 32768, Maximum Response Delay = Maximum Response Code If Maximum Response Code >=32768, Maximum Response Code represents a floating-point value as follows: 0 1 2 3 4 5 6 7 8 9 A B C D E F +-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+ |1| exp | mant | +-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+ Maximum Response Delay = (mant | 0x1000) << (exp+3) 5.1.9. QQIC (Querier's Query Interval Code) The Querier's Query Interval Code field specifies the [Query Interval] used by the Querier. The actual interval, called the Querier's Query Interval (QQI), is represented in units of seconds, and is derived from the Querier's Query Interval Code as follows: If QQIC < 128, QQI = QQIC If QQIC >= 128, QQIC represents a floating-point value as follows: 0 1 2 3 4 5 6 7 +-+-+-+-+-+-+-+-+ |1| exp | mant | +-+-+-+-+-+-+-+-+ QQI = (mant | 0x10) << (exp + 3) -- rfc3810 #define MLDV2_QQIC(value) MLDV2_EXP(0x80, 4, 3, value) #define MLDV2_MRC(value) MLDV2_EXP(0x8000, 12, 3, value) Above macro are defined in mcast.c. but 1 << 4 == 0x10 and 1 << 12 == 0x1000. So the result computed by original Macro is larger. Signed-off-by: Yan Zheng <yanzheng@21cn.com> Acked-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-28[IPv4/IPv6]: UFO Scatter-gather approachAnanda Raju
Attached is kernel patch for UDP Fragmentation Offload (UFO) feature. 1. This patch incorporate the review comments by Jeff Garzik. 2. Renamed USO as UFO (UDP Fragmentation Offload) 3. udp sendfile support with UFO This patches uses scatter-gather feature of skb to generate large UDP datagram. Below is a "how-to" on changes required in network device driver to use the UFO interface. UDP Fragmentation Offload (UFO) Interface: ------------------------------------------- UFO is a feature wherein the Linux kernel network stack will offload the IP fragmentation functionality of large UDP datagram to hardware. This will reduce the overhead of stack in fragmenting the large UDP datagram to MTU sized packets 1) Drivers indicate their capability of UFO using dev->features |= NETIF_F_UFO | NETIF_F_HW_CSUM | NETIF_F_SG NETIF_F_HW_CSUM is required for UFO over ipv6. 2) UFO packet will be submitted for transmission using driver xmit routine. UFO packet will have a non-zero value for "skb_shinfo(skb)->ufo_size" skb_shinfo(skb)->ufo_size will indicate the length of data part in each IP fragment going out of the adapter after IP fragmentation by hardware. skb->data will contain MAC/IP/UDP header and skb_shinfo(skb)->frags[] contains the data payload. The skb->ip_summed will be set to CHECKSUM_HW indicating that hardware has to do checksum calculation. Hardware should compute the UDP checksum of complete datagram and also ip header checksum of each fragmented IP packet. For IPV6 the UFO provides the fragment identification-id in skb_shinfo(skb)->ip6_frag_id. The adapter should use this ID for generating IPv6 fragments. Signed-off-by: Ananda Raju <ananda.raju@neterion.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (forwarded) Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-28Merge master.kernel.org:/pub/scm/linux/kernel/git/holtmann/bluetooth-2.6Arnaldo Carvalho de Melo
2005-10-28[Bluetooth] Update security filter for Extended Inquiry ResponseMarcel Holtmann
This patch updates the HCI security filter with support for the Extended Inquiry Response (EIR) feature. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2005-10-28[Bluetooth] Make more functions staticMarcel Holtmann
This patch makes another bunch of functions static. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2005-10-28[Bluetooth] Move CRC table into RFCOMM coreMarcel Holtmann
This patch moves rfcomm_crc_table[] into the RFCOMM core, because there is no need to keep it in a separate file. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2005-10-28Merge ../bleed-2.6Greg KH
2005-10-28[PATCH] Input: convert net/bluetooth to dynamic input_dev allocationDmitry Torokhov
Input: convert net/bluetooth to dynamic input_dev allocation This is required for input_dev sysfs integration Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28Merge branch 'upstream' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
2005-10-28Merge master.kernel.org:/pub/scm/linux/kernel/git/acme/net-2.6.15Linus Torvalds
2005-10-28[PATCH] gfp_t: net/*Al Viro
2005-10-27Merge /home/trondmy/scm/kernel/git/torvalds/linux-2.6Trond Myklebust
2005-10-27RPC: Ensure that nobody can queue up new upcalls after rpc_close_pipes()Trond Myklebust
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-10-27Merge branch 'master'Jeff Garzik
2005-10-27Revert "RPC: stops the release_pipe() funtion from being called twice"Trond Myklebust
This reverts 747c5534c9a6da4aa87e7cdc2209ea98ea27f381 commit.
2005-10-27[TCP]: Clear stale pred_flags when snd_wnd changesHerbert Xu
This bug is responsible for causing the infamous "Treason uncloaked" messages that's been popping up everywhere since the printk was added. It has usually been blamed on foreign operating systems. However, some of those reports implicate Linux as both systems are running Linux or the TCP connection is going across the loopback interface. In fact, there really is a bug in the Linux TCP header prediction code that's been there since at least 2.1.8. This bug was tracked down with help from Dale Blount. The effect of this bug ranges from harmless "Treason uncloaked" messages to hung/aborted TCP connections. The details of the bug and fix is as follows. When snd_wnd is updated, we only update pred_flags if tcp_fast_path_check succeeds. When it fails (for example, when our rcvbuf is used up), we will leave pred_flags with an out-of-date snd_wnd value. When the out-of-date pred_flags happens to match the next incoming packet we will again hit the fast path and use the current snd_wnd which will be wrong. In the case of the treason messages, it just happens that the snd_wnd cached in pred_flags is zero while tp->snd_wnd is non-zero. Therefore when a zero-window packet comes in we incorrectly conclude that the window is non-zero. In fact if the peer continues to send us zero-window pure ACKs we will continue making the same mistake. It's only when the peer transmits a zero-window packet with data attached that we get a chance to snap out of it. This is what triggers the treason message at the next retransmit timeout. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-26[PATCH] svcsock timestamp fixAndrew Morton
Convert nanoseconds to microseconds correctly. Spotted by Steve Dickson <SteveD@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-26[PATCH] kill massive wireless-related log spamJeff Garzik
Although this message is having the intended effect of causing wireless driver maintainers to upgrade their code, I never should have merged this patch in its present form. Leading to tons of bug reports and unhappy users. Some wireless apps poll for statistics regularly, which leads to a printk() every single time they ask for stats. That's a little bit _too_ much of a reminder that the driver is using an old API. Change this to printing out the message once, per kernel boot. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-26Merge branch 'master'Jeff Garzik
2005-10-26[PATCH] ieee80211 build fixJames Ketrenos
James Ketrenos wrote: > [3/4] Use the tx_headroom and reserve requested space. This patch introduced a compile problem; patch below corrects this. Fixed compilation error due to not passing tx_headroom in ieee80211_tx_frame. Signed-off-by: James Ketrenos <jketreno@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-26[IPV4]: Fix setting broadcast for SIOCSIFNETMASKDavid Engel
Fix setting of the broadcast address when the netmask is set via SIOCSIFNETMASK in Linux 2.6. The code wanted the old value of ifa->ifa_mask but used it after it had already been overwritten with the new value. Signed-off-by: David Engel <gigem@comcast.net> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-26[AX.25]: Use constant instead of magic numberRalf Baechle
Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-26[SK_BUFF] kernel-doc: fix skbuff warningsRandy Dunlap
Add kernel-doc to skbuff.h, skbuff.c to eliminate kernel-doc warnings. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-26[IPV4]: Remove dead code from ip_output.cJayachandran C
skb_prev is assigned from skb, which cannot be NULL. This patch removes the unnecessary NULL check. Signed-off-by: Jayachandran C. <c.jayachandran at gmail.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-26[NETLINK]: Remove dead code in af_netlink.cJayachandran C
Remove the variable nlk & call to nlk_sk as it does not have any side effect. Signed-off-by: Jayachandran C. <c.jayachandran at gmail.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-26[IPSEC]: Kill obsolete get_mss functionHerbert Xu
Now that we've switched over to storing MTUs in the xfrm_dst entries, we no longer need the dst's get_mss methods. This patch gets rid of them. It also documents the fact that our MTU calculation is not optimal for ESP. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-26[IPV4]: Kill redundant rcu_dereference on fa_infoHerbert Xu
This patch kills a redundant rcu_dereference on fa->fa_info in fib_trie.c. As this dereference directly follows a list_for_each_entry_rcu line, we have already taken a read barrier with respect to getting an entry from the list. This read barrier guarantees that all values read out of fa are valid. In particular, the contents of structure pointed to by fa->fa_info is initialised before fa->fa_info is actually set (see fn_trie_insert); the setting of fa->fa_info itself is further separated with a write barrier from the insertion of fa into the list. Therefore by taking a read barrier after obtaining fa from the list (which is given by list_for_each_entry_rcu), we can be sure that fa->fa_info contains a valid pointer, as well as the fact that the data pointed to by fa->fa_info is itself valid. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-26[NETFILTER] ip_conntrack: Make "hashsize" conntrack parameter writableHarald Welte
It's fairly simple to resize the hash table, but currently you need to remove and reinsert the module. That's bad (we lose connection state). Harald has even offered to write a daemon which sets this based on load. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-26[PKTGEN]: proc interface revisionStephen Hemminger
The code to handle the /proc interface can be cleaned up in several places: * use seq_file for read * don't need to remember all the filenames separately * use for_online_cpu's * don't vmalloc a buffer for small command from user. Committer note: This patch clashed with John Hawkes's "[NET]: Wider use of for_each_*cpu()", so I fixed it up manually. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Robert Olsson <robert.olsson@its.uu.se> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-26[PKTGEN]: Spelling and white spaceStephen Hemminger
Fix some cosmetic issues. Indentation, spelling errors, and some whitespace. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Robert Olsson <robert.olsson@its.uu.se> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
