path: root/net
2012-10-28tcp: resets are misroutedAlexey Kuznetsov
[ Upstream commit 4c67525849e0b7f4bd4fab2487ec9e43ea52ef29 ] After commit e2446eaa ("tcp_v4_send_reset: binding oif to iif in no sock case").. tcp resets are always lost, when routing is asymmetric. Yes, backing out that patch will result in misrouting of resets for dead connections which used interface binding when were alive, but we actually cannot do anything here. What's died that's died and correct handling normal unbound connections is obviously a priority. Comment to comment: > This has few benefits: > 1. tcp_v6_send_reset already did that. It was done to route resets for IPv6 link local addresses. It was a mistake to do so for global addresses. The patch fixes this as well. Actually, the problem appears to be even more serious than guaranteed loss of resets. As reported by Sergey Soloviev <sol@eqv.ru>, those misrouted resets create a lot of arp traffic and huge amount of unresolved arp entires putting down to knees NAT firewalls which use asymmetric routing. Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-28RDS: fix rds-ping spinlock recursionjeff.liu
[ Upstream commit 5175a5e76bbdf20a614fb47ce7a38f0f39e70226 ] This is the revised patch for fixing rds-ping spinlock recursion according to Venkat's suggestions. RDS ping/pong over TCP feature has been broken for years(2.6.39 to 3.6.0) since we have to set TCP cork and call kernel_sendmsg() between ping/pong which both need to lock "struct sock *sk". However, this lock has already been hold before rds_tcp_data_ready() callback is triggerred. As a result, we always facing spinlock resursion which would resulting in system panic. Given that RDS ping is only used to test the connectivity and not for serious performance measurements, we can queue the pong transmit to rds_wq as a delayed response. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> CC: Venkat Venkatsubra <venkat.x.venkatsubra@oracle.com> CC: David S. Miller <davem@davemloft.net> CC: James Morris <james.l.morris@oracle.com> Signed-off-by: Jie Liu <jeff.liu@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-28net: Fix skb_under_panic oops in neigh_resolve_outputramesh.nagappa@gmail.com
[ Upstream commit e1f165032c8bade3a6bdf546f8faf61fda4dd01c ] The retry loop in neigh_resolve_output() and neigh_connected_output() call dev_hard_header() with out reseting the skb to network_header. This causes the retry to fail with skb_under_panic. The fix is to reset the network_header within the retry loop. Signed-off-by: Ramesh Nagappa <ramesh.nagappa@ericsson.com> Reviewed-by: Shawn Lu <shawn.lu@ericsson.com> Reviewed-by: Robert Coulson <robert.coulson@ericsson.com> Reviewed-by: Billie Alsup <billie.alsup@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-28SUNRPC: Prevent kernel stack corruption on long values of flushSasha Levin
commit 212ba90696ab4884e2025b0b13726d67aadc2cd4 upstream. The buffer size in read_flush() is too small for the longest possible values for it. This can lead to a kernel stack corruption: [ 43.047329] Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: ffffffff833e64b4 [ 43.047329] [ 43.049030] Pid: 6015, comm: trinity-child18 Tainted: G W 3.5.0-rc7-next-20120716-sasha #221 [ 43.050038] Call Trace: [ 43.050435] [<ffffffff836c60c2>] panic+0xcd/0x1f4 [ 43.050931] [<ffffffff833e64b4>] ? read_flush.isra.7+0xe4/0x100 [ 43.051602] [<ffffffff810e94e6>] __stack_chk_fail+0x16/0x20 [ 43.052206] [<ffffffff833e64b4>] read_flush.isra.7+0xe4/0x100 [ 43.052951] [<ffffffff833e6500>] ? read_flush_pipefs+0x30/0x30 [ 43.053594] [<ffffffff833e652c>] read_flush_procfs+0x2c/0x30 [ 43.053596] [<ffffffff812b9a8c>] proc_reg_read+0x9c/0xd0 [ 43.053596] [<ffffffff812b99f0>] ? proc_reg_write+0xd0/0xd0 [ 43.053596] [<ffffffff81250d5b>] do_loop_readv_writev+0x4b/0x90 [ 43.053596] [<ffffffff81250fd6>] do_readv_writev+0xf6/0x1d0 [ 43.053596] [<ffffffff812510ee>] vfs_readv+0x3e/0x60 [ 43.053596] [<ffffffff812511b8>] sys_readv+0x48/0xb0 [ 43.053596] [<ffffffff8378167d>] system_call_fastpath+0x1a/0x1f Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21netfilter: xt_limit: have r->cost != 0 case workJan Engelhardt
commit 82e6bfe2fbc4d48852114c4f979137cd5bf1d1a8 upstream. Commit v2.6.19-rc1~1272^2~41 tells us that r->cost != 0 can happen when a running state is saved to userspace and then reinstated from there. Make sure that private xt_limit area is initialized with correct values. Otherwise, random matchings due to use of uninitialized memory. Signed-off-by: Jan Engelhardt <jengelh@inai.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21netfilter: limit, hashlimit: avoid duplicated inlineFlorian Westphal
commit 7a909ac70f6b0823d9f23a43f19598d4b57ac901 upstream. credit_cap can be set to credit, which avoids inlining user2credits twice. Also, remove inline keyword and let compiler decide. old: 684 192 0 876 36c net/netfilter/xt_limit.o 4927 344 32 5303 14b7 net/netfilter/xt_hashlimit.o now: 668 192 0 860 35c net/netfilter/xt_limit.o 4793 344 32 5169 1431 net/netfilter/xt_hashlimit.o Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21netfilter: nf_ct_expect: fix possible access to uninitialized timerPablo Neira Ayuso
commit 2614f86490122bf51eb7c12ec73927f1900f4e7d upstream. In __nf_ct_expect_check, the function refresh_timer returns 1 if a matching expectation is found and its timer is successfully refreshed. This results in nf_ct_expect_related returning 0. Note that at this point: - the passed expectation is not inserted in the expectation table and its timer was not initialized, since we have refreshed one matching/existing expectation. - nf_ct_expect_alloc uses kmem_cache_alloc, so the expectation timer is in some undefined state just after the allocation, until it is appropriately initialized. This can be a problem for the SIP helper during the expectation addition: ... if (nf_ct_expect_related(rtp_exp) == 0) { if (nf_ct_expect_related(rtcp_exp) != 0) nf_ct_unexpect_related(rtp_exp); ... Note that nf_ct_expect_related(rtp_exp) may return 0 for the timer refresh case that is detailed above. Then, if nf_ct_unexpect_related(rtcp_exp) returns != 0, nf_ct_unexpect_related(rtp_exp) is called, which does: spin_lock_bh(&nf_conntrack_lock); if (del_timer(&exp->timeout)) { nf_ct_unlink_expect(exp); nf_ct_expect_put(exp); } spin_unlock_bh(&nf_conntrack_lock); Note that del_timer always returns false if the timer has been initialized. However, the timer was not initialized since setup_timer was not called, therefore, the expectation timer remains in some undefined state. If I'm not missing anything, this may lead to the removal an unexistent expectation. To fix this, the optimization that allows refreshing an expectation is removed. Now nf_conntrack_expect_related looks more consistent to me since it always add the expectation in case that it returns success. Thanks to Patrick McHardy for participating in the discussion of this patch. I think this may be the source of the problem described by: http://marc.info/?l=netfilter-devel&m=134073514719421&w=2 Reported-by: Rafal Fitt <rafalf@aplusc.com.pl> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21netfilter: nf_nat_sip: fix via header translation with multiple parametersPatrick McHardy
commit f22eb25cf5b1157b29ef88c793b71972efc47143 upstream. Via-headers are parsed beginning at the first character after the Via-address. When the address is translated first and its length decreases, the offset to start parsing at is incorrect and header parameters might be missed. Update the offset after translating the Via-address to fix this. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21netfilter: nf_nat_sip: fix incorrect handling of EBUSY for RTCP expectationPablo Neira Ayuso
commit 3f509c689a07a4aa989b426893d8491a7ffcc410 upstream. We're hitting bug while trying to reinsert an already existing expectation: kernel BUG at kernel/timer.c:895! invalid opcode: 0000 [#1] SMP [...] Call Trace: <IRQ> [<ffffffffa0069563>] nf_ct_expect_related_report+0x4a0/0x57a [nf_conntrack] [<ffffffff812d423a>] ? in4_pton+0x72/0x131 [<ffffffffa00ca69e>] ip_nat_sdp_media+0xeb/0x185 [nf_nat_sip] [<ffffffffa00b5b9b>] set_expected_rtp_rtcp+0x32d/0x39b [nf_conntrack_sip] [<ffffffffa00b5f15>] process_sdp+0x30c/0x3ec [nf_conntrack_sip] [<ffffffff8103f1eb>] ? irq_exit+0x9a/0x9c [<ffffffffa00ca738>] ? ip_nat_sdp_media+0x185/0x185 [nf_nat_sip] We have to remove the RTP expectation if the RTCP expectation hits EBUSY since we keep trying with other ports until we succeed. Reported-by: Rafal Fitt <rafalf@aplusc.com.pl> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21netfilter: nf_ct_ipv4: packets with wrong ihl are invalidJozsef Kadlecsik
commit 07153c6ec074257ade76a461429b567cff2b3a1e upstream. It was reported that the Linux kernel sometimes logs: klogd: [2629147.402413] kernel BUG at net / netfilter / nf_conntrack_proto_tcp.c: 447! klogd: [1072212.887368] kernel BUG at net / netfilter / nf_conntrack_proto_tcp.c: 392 ipv4_get_l4proto() in nf_conntrack_l3proto_ipv4.c and tcp_error() in nf_conntrack_proto_tcp.c should catch malformed packets, so the errors at the indicated lines - TCP options parsing - should not happen. However, tcp_error() relies on the "dataoff" offset to the TCP header, calculated by ipv4_get_l4proto(). But ipv4_get_l4proto() does not check bogus ihl values in IPv4 packets, which then can slip through tcp_error() and get caught at the TCP options parsing routines. The patch fixes ipv4_get_l4proto() by invalidating packets with bogus ihl value. The patch closes netfilter bugzilla id 771. Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21netfilter: nf_conntrack: fix racy timer handling with reliable eventsPablo Neira Ayuso
commit 5b423f6a40a0327f9d40bc8b97ce9be266f74368 upstream. Existing code assumes that del_timer returns true for alive conntrack entries. However, this is not true if reliable events are enabled. In that case, del_timer may return true for entries that were just inserted in the dying list. Note that packets / ctnetlink may hold references to conntrack entries that were just inserted to such list. This patch fixes the issue by adding an independent timer for event delivery. This increases the size of the ecache extension. Still we can revisit this later and use variable size extensions to allocate this area on demand. Tested-by: Oliver Smith <olipro@8.c.9.b.0.7.4.0.1.0.0.2.ip6.arpa> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21ipvs: fix oops in ip_vs_dst_event on rmmodJulian Anastasov
commit 283283c4da91adc44b03519f434ee1e7e91d6fdb upstream. After commit 39f618b4fd95ae243d940ec64c961009c74e3333 (3.4) "ipvs: reset ipvs pointer in netns" we can oops in ip_vs_dst_event on rmmod ip_vs because ip_vs_control_cleanup is called after the ipvs_core_ops subsys is unregistered and net->ipvs is NULL. Fix it by exiting early from ip_vs_dst_event if ipvs is NULL. It is safe because all services and dests for the net are already freed. Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21pktgen: fix crash when generating IPv6 packetsAmerigo Wang
commit 5aa8b572007c4bca1e6d3dd4c4820f1ae49d6bb2 upstream. For IPv6, sizeof(struct ipv6hdr) = 40, thus the following expression will result negative: datalen = pkt_dev->cur_pkt_size - 14 - sizeof(struct ipv6hdr) - sizeof(struct udphdr) - pkt_dev->pkt_overhead; And, the check "if (datalen < sizeof(struct pktgen_hdr))" will be passed as "datalen" is promoted to unsigned, therefore will cause a crash later. This is a quick fix by checking if "datalen" is negative. The following patch will increase the default value of 'min_pkt_size' for IPv6. This bug should exist for a long time, so Cc -stable too. Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21SUNRPC: Ensure that the TCP socket is closed when in CLOSE_WAITTrond Myklebust
commit a519fc7a70d1a918574bb826cc6905b87b482eb9 upstream. Instead of doing a shutdown() call, we need to do an actual close(). Ditto if/when the server is sending us junk RPC headers. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Tested-by: Simon Kirby <sim@hostway.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13net: do not disable sg for packets requiring no checksumEd Cashin
[ Upstream commit c0d680e577ff171e7b37dbdb1b1bf5451e851f04 ] A change in a series of VLAN-related changes appears to have inadvertently disabled the use of the scatter gather feature of network cards for transmission of non-IP ethernet protocols like ATA over Ethernet (AoE). Below is a reference to the commit that introduces a "harmonize_features" function that turns off scatter gather when the NIC does not support hardware checksumming for the ethernet protocol of an sk buff. commit f01a5236bd4b140198fbcc550f085e8361fd73fa Author: Jesse Gross <jesse@nicira.com> Date: Sun Jan 9 06:23:31 2011 +0000 net offloading: Generalize netif_get_vlan_features(). The can_checksum_protocol function is not equipped to consider a protocol that does not require checksumming. Calling it for a protocol that requires no checksum is inappropriate. The patch below has harmonize_features call can_checksum_protocol when the protocol needs a checksum, so that the network layer is not forced to perform unnecessary skb linearization on the transmission of AoE packets. Unnecessary linearization results in decreased performance and increased memory pressure, as reported here: http://www.spinics.net/lists/linux-mm/msg15184.html The problem has probably not been widely experienced yet, because only recently has the kernel.org-distributed aoe driver acquired the ability to use payloads of over a page in size, with the patchset recently included in the mm tree: https://lkml.org/lkml/2012/8/28/140 The coraid.com-distributed aoe driver already could use payloads of greater than a page in size, but its users generally do not use the newest kernels. Signed-off-by: Ed Cashin <ecashin@coraid.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13netrom: copy_datagram_iovec can failAlan Cox
[ Upstream commit 6cf5c951175abcec4da470c50565cc0afe6cd11d ] Check for an error from this and if so bail properly. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13l2tp: fix a typo in l2tp_eth_dev_recv()Eric Dumazet
[ Upstream commit c0cc88a7627c333de50b07b7c60b1d49d9d2e6cc ] While investigating l2tp bug, I hit a bug in eth_type_trans(), because not enough bytes were pulled in skb head. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13ipv6: mip6: fix mip6_mh_filter()Eric Dumazet
[ Upstream commit 96af69ea2a83d292238bdba20e4508ee967cf8cb ] mip6_mh_filter() should not modify its input, or else its caller would need to recompute ipv6_hdr() if skb->head is reallocated. Use skb_header_pointer() instead of pskb_may_pull() Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13ipv6: raw: fix icmpv6_filter()Eric Dumazet
[ Upstream commit 1b05c4b50edbddbdde715c4a7350629819f6655e ] icmpv6_filter() should not modify its input, or else its caller would need to recompute ipv6_hdr() if skb->head is reallocated. Use skb_header_pointer() instead of pskb_may_pull() and change the prototype to make clear both sk and skb are const. Also, if icmpv6 header cannot be found, do not deliver the packet, as we do in IPv4. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13ipv4: raw: fix icmp_filter()Eric Dumazet
[ Upstream commit ab43ed8b7490cb387782423ecf74aeee7237e591 ] icmp_filter() should not modify its input, or else its caller would need to recompute ip_hdr() if skb->head is reallocated. Use skb_header_pointer() instead of pskb_may_pull() and change the prototype to make clear both sk and skb are const. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13net: guard tcp_set_keepalive() to tcp socketsEric Dumazet
[ Upstream commit 3e10986d1d698140747fcfc2761ec9cb64c1d582 ] Its possible to use RAW sockets to get a crash in tcp_set_keepalive() / sk_reset_timer() Fix is to make sure socket is a SOCK_STREAM one. Reported-by: Dave Jones <davej@redhat.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13net: small bug on rxhash calculationChema Gonzalez
[ Upstream commit 6862234238e84648c305526af2edd98badcad1e0 ] In the current rxhash calculation function, while the sorting of the ports/addrs is coherent (you get the same rxhash for packets sharing the same 4-tuple, in both directions), ports and addrs are sorted independently. This implies packets from a connection between the same addresses but crossed ports hash to the same rxhash. For example, traffic between A=S:l and B=L:s is hashed (in both directions) from {L, S, {s, l}}. The same rxhash is obtained for packets between C=S:s and D=L:l. This patch ensures that you either swap both addrs and ports, or you swap none. Traffic between A and B, and traffic between C and D, get their rxhash from different sources ({L, S, {l, s}} for A<->B, and {L, S, {s, l}} for C<->D) The patch is co-written with Eric Dumazet <edumazet@google.com> Signed-off-by: Chema Gonzalez <chema@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13sctp: Don't charge for data in sndbuf again when transmitting packetThomas Graf
[ Upstream commit 4c3a5bdae293f75cdf729c6c00124e8489af2276 ] SCTP charges wmem_alloc via sctp_set_owner_w() in sctp_sendmsg() and via skb_set_owner_w() in sctp_packet_transmit(). If a sender runs out of sndbuf it will sleep in sctp_wait_for_sndbuf() and expects to be waken up by __sctp_write_space(). Buffer space charged via sctp_set_owner_w() is released in sctp_wfree() which calls __sctp_write_space() directly. Buffer space charged via skb_set_owner_w() is released via sock_wfree() which calls sk->sk_write_space() _if_ SOCK_USE_WRITE_QUEUE is not set. sctp_endpoint_init() sets SOCK_USE_WRITE_QUEUE on all sockets. Therefore if sctp_packet_transmit() manages to queue up more than sndbuf bytes, sctp_wait_for_sndbuf() will never be woken up again unless it is interrupted by a signal. This could be fixed by clearing the SOCK_USE_WRITE_QUEUE flag but ... Charging for the data twice does not make sense in the first place, it leads to overcharging sndbuf by a factor 2. Therefore this patch only charges a single byte in wmem_alloc when transmitting an SCTP packet to ensure that the socket stays alive until the packet has been released. This means that control chunks are no longer accounted for in wmem_alloc which I believe is not a problem as skb->truesize will typically lead to overcharging anyway and thus compensates for any control overhead. Signed-off-by: Thomas Graf <tgraf@suug.ch> CC: Vlad Yasevich <vyasevic@redhat.com> CC: Neil Horman <nhorman@tuxdriver.com> CC: David Miller <davem@davemloft.net> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13tcp: flush DMA queue before sk_wait_data if rcv_wnd is zeroMichal Kubeček
[ Upstream commit 15c041759bfcd9ab0a4e43f1c16e2644977d0467 ] If recv() syscall is called for a TCP socket so that - IOAT DMA is used - MSG_WAITALL flag is used - requested length is bigger than sk_rcvbuf - enough data has already arrived to bring rcv_wnd to zero then when tcp_recvmsg() gets to calling sk_wait_data(), receive window can be still zero while sk_async_wait_queue exhausts enough space to keep it zero. As this queue isn't cleaned until the tcp_service_net_dma() call, sk_wait_data() cannot receive any data and blocks forever. If zero receive window and non-empty sk_async_wait_queue is detected before calling sk_wait_data(), process the queue first. Signed-off-by: Michal Kubecek <mkubecek@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13ipv6: release reference of ip6_null_entry's dst entry in __ip6_del_rtGao feng
[ Upstream commit 6825a26c2dc21eb4f8df9c06d3786ddec97cf53b ] as we hold dst_entry before we call __ip6_del_rt, so we should alse call dst_release not only return -ENOENT when the rt6_info is ip6_null_entry. and we already hold the dst entry, so I think it's safe to call dst_release out of the write-read lock. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-138021q: fix mac_len recomputation in vlan_untag()Antonio Quartulli
[ Upstream commit 5316cf9a5197eb80b2800e1acadde287924ca975 ] skb_reset_mac_len() relies on the value of the skb->network_header pointer, therefore we must wait for such pointer to be recalculated before computing the new mac_len value. Signed-off-by: Antonio Quartulli <ordex@autistici.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13pkt_sched: fix virtual-start-time update in QFQPaolo Valente
[ Upstream commit 71261956973ba9e0637848a5adb4a5819b4bae83 ] If the old timestamps of a class, say cl, are stale when the class becomes active, then QFQ may assign to cl a much higher start time than the maximum value allowed. This may happen when QFQ assigns to the start time of cl the finish time of a group whose classes are characterized by a higher value of the ratio max_class_pkt/weight_of_the_class with respect to that of cl. Inserting a class with a too high start time into the bucket list corrupts the data structure and may eventually lead to crashes. This patch limits the maximum start time assigned to a class. Signed-off-by: Paolo Valente <paolo.valente@unimore.it> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13net-sched: sch_cbq: avoid infinite loopEric Dumazet
[ Upstream commit bdfc87f7d1e253e0a61e2fc6a75ea9d76f7fc03a ] Its possible to setup a bad cbq configuration leading to an infinite loop in cbq_classify() DEV_OUT=eth0 ICMP="match ip protocol 1 0xff" U32="protocol ip u32" DST="match ip dst" tc qdisc add dev $DEV_OUT root handle 1: cbq avpkt 1000 \ bandwidth 100mbit tc class add dev $DEV_OUT parent 1: classid 1:1 cbq \ rate 512kbit allot 1500 prio 5 bounded isolated tc filter add dev $DEV_OUT parent 1: prio 3 $U32 \ $ICMP $DST 192.168.3.234 flowid 1: Reported-by: Denys Fedoryschenko <denys@visp.net.lb> Tested-by: Denys Fedoryschenko <denys@visp.net.lb> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13xfrm_user: ensure user supplied esn replay window is validMathias Krause
[ Upstream commit ecd7918745234e423dd87fcc0c077da557909720 ] The current code fails to ensure that the netlink message actually contains as many bytes as the header indicates. If a user creates a new state or updates an existing one but does not supply the bytes for the whole ESN replay window, the kernel copies random heap bytes into the replay bitmap, the ones happen to follow the XFRMA_REPLAY_ESN_VAL netlink attribute. This leads to following issues: 1. The replay window has random bits set confusing the replay handling code later on. 2. A malicious user could use this flaw to leak up to ~3.5kB of heap memory when she has access to the XFRM netlink interface (requires CAP_NET_ADMIN). Known users of the ESN replay window are strongSwan and Steffen's iproute2 patch (<http://patchwork.ozlabs.org/patch/85962/>). The latter uses the interface with a bitmap supplied while the former does not. strongSwan is therefore prone to run into issue 1. To fix both issues without breaking existing userland allow using the XFRMA_REPLAY_ESN_VAL netlink attribute with either an empty bitmap or a fully specified one. For the former case we initialize the in-kernel bitmap with zero, for the latter we copy the user supplied bitmap. For state updates the full bitmap must be supplied. To prevent overflows in the bitmap length calculation the maximum size of bmp_len is limited to 128 by this patch -- resulting in a maximum replay window of 4096 packets. This should be sufficient for all real life scenarios (RFC 4303 recommends a default replay window size of 64). Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Steffen Klassert <steffen.klassert@secunet.com> Cc: Martin Willi <martin@revosec.ch> Cc: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13xfrm_user: don't copy esn replay window twice for new statesMathias Krause
[ Upstream commit e3ac104d41a97b42316915020ba228c505447d21 ] The ESN replay window was already fully initialized in xfrm_alloc_replay_state_esn(). No need to copy it again. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Steffen Klassert <steffen.klassert@secunet.com> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13xfrm_user: fix info leak in copy_to_user_tmpl()Mathias Krause
[ Upstream commit 1f86840f897717f86d523a13e99a447e6a5d2fa5 ] The memory used for the template copy is a local stack variable. As struct xfrm_user_tmpl contains multiple holes added by the compiler for alignment, not initializing the memory will lead to leaking stack bytes to userland. Add an explicit memset(0) to avoid the info leak. Initial version of the patch by Brad Spengler. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Brad Spengler <spender@grsecurity.net> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13xfrm_user: fix info leak in copy_to_user_policy()Mathias Krause
[ Upstream commit 7b789836f434c87168eab067cfbed1ec4783dffd ] The memory reserved to dump the xfrm policy includes multiple padding bytes added by the compiler for alignment (padding bytes in struct xfrm_selector and struct xfrm_userpolicy_info). Add an explicit memset(0) before filling the buffer to avoid the heap info leak. Signed-off-by: Mathias Krause <minipli@googlemail.com> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13xfrm_user: fix info leak in copy_to_user_state()Mathias Krause
[ Upstream commit f778a636713a435d3a922c60b1622a91136560c1 ] The memory reserved to dump the xfrm state includes the padding bytes of struct xfrm_usersa_info added by the compiler for alignment (7 for amd64, 3 for i386). Add an explicit memset(0) before filling the buffer to avoid the info leak. Signed-off-by: Mathias Krause <minipli@googlemail.com> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13xfrm_user: fix info leak in copy_to_user_auth()Mathias Krause
[ Upstream commit 4c87308bdea31a7b4828a51f6156e6f721a1fcc9 ] copy_to_user_auth() fails to initialize the remainder of alg_name and therefore discloses up to 54 bytes of heap memory via netlink to userland. Use strncpy() instead of strcpy() to fill the trailing bytes of alg_name with null bytes. Signed-off-by: Mathias Krause <minipli@googlemail.com> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13xfrm: fix a read lock imbalance in make_blackholeLi RongQing
[ Upstream commit 433a19548061bb5457b6ab77ed7ea58ca6e43ddb ] if xfrm_policy_get_afinfo returns 0, it has already released the read lock, xfrm_policy_put_afinfo should not be called again. Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13xfrm_user: return error pointer instead of NULL #2Mathias Krause
[ Upstream commit c25463722509fef0ed630b271576a8c9a70236f3 ] When dump_one_policy() returns an error, e.g. because of a too small buffer to dump the whole xfrm policy, xfrm_policy_netlink() returns NULL instead of an error pointer. But its caller expects an error pointer and therefore continues to operate on a NULL skbuff. Signed-off-by: Mathias Krause <minipli@googlemail.com> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13xfrm_user: return error pointer instead of NULLMathias Krause
[ Upstream commit 864745d291b5ba80ea0bd0edcbe67273de368836 ] When dump_one_state() returns an error, e.g. because of a too small buffer to dump the whole xfrm state, xfrm_state_netlink() returns NULL instead of an error pointer. But its callers expect an error pointer and therefore continue to operate on a NULL skbuff. This could lead to a privilege escalation (execution of user code in kernel context) if the attacker has CAP_NET_ADMIN and is able to map address 0. Signed-off-by: Mathias Krause <minipli@googlemail.com> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13xfrm: Workaround incompatibility of ESN and async cryptoSteffen Klassert
[ Upstream commit 3b59df46a449ec9975146d71318c4777ad086744 ] ESN for esp is defined in RFC 4303. This RFC assumes that the sequence number counters are always up to date. However, this is not true if an async crypto algorithm is employed. If the sequence number counters are not up to date on sequence number check, we may incorrectly update the upper 32 bit of the sequence number. This leads to a DOS. We workaround this by comparing the upper sequence number, (used for authentication) with the upper sequence number computed after the async processing. We drop the packet if these numbers are different. To do this, we introduce a recheck function that does this check in the ESN case. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02drop_monitor: dont sleep in atomic contextEric Dumazet
commit bec4596b4e6770c7037f21f6bd27567b152dc0d6 upstream. drop_monitor calls several sleeping functions while in atomic context. BUG: sleeping function called from invalid context at mm/slub.c:943 in_atomic(): 1, irqs_disabled(): 0, pid: 2103, name: kworker/0:2 Pid: 2103, comm: kworker/0:2 Not tainted 3.5.0-rc1+ #55 Call Trace: [<ffffffff810697ca>] __might_sleep+0xca/0xf0 [<ffffffff811345a3>] kmem_cache_alloc_node+0x1b3/0x1c0 [<ffffffff8105578c>] ? queue_delayed_work_on+0x11c/0x130 [<ffffffff815343fb>] __alloc_skb+0x4b/0x230 [<ffffffffa00b0360>] ? reset_per_cpu_data+0x160/0x160 [drop_monitor] [<ffffffffa00b022f>] reset_per_cpu_data+0x2f/0x160 [drop_monitor] [<ffffffffa00b03ab>] send_dm_alert+0x4b/0xb0 [drop_monitor] [<ffffffff810568e0>] process_one_work+0x130/0x4c0 [<ffffffff81058249>] worker_thread+0x159/0x360 [<ffffffff810580f0>] ? manage_workers.isra.27+0x240/0x240 [<ffffffff8105d403>] kthread+0x93/0xa0 [<ffffffff816be6d4>] kernel_thread_helper+0x4/0x10 [<ffffffff8105d370>] ? kthread_freezable_should_stop+0x80/0x80 [<ffffffff816be6d0>] ? gs_change+0xb/0xb Rework the logic to call the sleeping functions in right context. Use standard timer/workqueue api to let system chose any cpu to perform the allocation and netlink send. Also avoid a loop if reset_per_cpu_data() cannot allocate memory : use mod_timer() to wait 1/10 second before next try. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Neil Horman <nhorman@tuxdriver.com> Reviewed-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02drop_monitor: prevent init path from scheduling on the wrong cpuNeil Horman
commit 4fdcfa12843bca38d0c9deff70c8720e4e8f515f upstream. I just noticed after some recent updates, that the init path for the drop monitor protocol has a minor error. drop monitor maintains a per cpu structure, that gets initalized from a single cpu. Normally this is fine, as the protocol isn't in use yet, but I recently made a change that causes a failed skb allocation to reschedule itself . Given the current code, the implication is that this workqueue reschedule will take place on the wrong cpu. If drop monitor is used early during the boot process, its possible that two cpus will access a single per-cpu structure in parallel, possibly leading to data corruption. This patch fixes the situation, by storing the cpu number that a given instance of this per-cpu data should be accessed from. In the case of a need for a reschedule, the cpu stored in the struct is assigned the rescheule, rather than the currently executing cpu Tested successfully by myself. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> CC: David Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02drop_monitor: Make updating data->skb smp safeNeil Horman
commit 3885ca785a3618593226687ced84f3f336dc3860 upstream. Eric Dumazet pointed out to me that the drop_monitor protocol has some holes in its smp protections. Specifically, its possible to replace data->skb while its being written. This patch corrects that by making data->skb an rcu protected variable. That will prevent it from being overwritten while a tracepoint is modifying it. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Reported-by: Eric Dumazet <eric.dumazet@gmail.com> CC: David Miller <davem@davemloft.net> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02drop_monitor: fix sleeping in invalid context warningNeil Horman
commit cde2e9a651b76d8db36ae94cd0febc82b637e5dd upstream. Eric Dumazet pointed out this warning in the drop_monitor protocol to me: [ 38.352571] BUG: sleeping function called from invalid context at kernel/mutex.c:85 [ 38.352576] in_atomic(): 1, irqs_disabled(): 0, pid: 4415, name: dropwatch [ 38.352580] Pid: 4415, comm: dropwatch Not tainted 3.4.0-rc2+ #71 [ 38.352582] Call Trace: [ 38.352592] [<ffffffff8153aaf0>] ? trace_napi_poll_hit+0xd0/0xd0 [ 38.352599] [<ffffffff81063f2a>] __might_sleep+0xca/0xf0 [ 38.352606] [<ffffffff81655b16>] mutex_lock+0x26/0x50 [ 38.352610] [<ffffffff8153aaf0>] ? trace_napi_poll_hit+0xd0/0xd0 [ 38.352616] [<ffffffff810b72d9>] tracepoint_probe_register+0x29/0x90 [ 38.352621] [<ffffffff8153a585>] set_all_monitor_traces+0x105/0x170 [ 38.352625] [<ffffffff8153a8ca>] net_dm_cmd_trace+0x2a/0x40 [ 38.352630] [<ffffffff8154a81a>] genl_rcv_msg+0x21a/0x2b0 [ 38.352636] [<ffffffff810f8029>] ? zone_statistics+0x99/0xc0 [ 38.352640] [<ffffffff8154a600>] ? genl_rcv+0x30/0x30 [ 38.352645] [<ffffffff8154a059>] netlink_rcv_skb+0xa9/0xd0 [ 38.352649] [<ffffffff8154a5f0>] genl_rcv+0x20/0x30 [ 38.352653] [<ffffffff81549a7e>] netlink_unicast+0x1ae/0x1f0 [ 38.352658] [<ffffffff81549d76>] netlink_sendmsg+0x2b6/0x310 [ 38.352663] [<ffffffff8150824f>] sock_sendmsg+0x10f/0x130 [ 38.352668] [<ffffffff8150abe0>] ? move_addr_to_kernel+0x60/0xb0 [ 38.352673] [<ffffffff81515f04>] ? verify_iovec+0x64/0xe0 [ 38.352677] [<ffffffff81509c46>] __sys_sendmsg+0x386/0x390 [ 38.352682] [<ffffffff810ffaf9>] ? handle_mm_fault+0x139/0x210 [ 38.352687] [<ffffffff8165b5bc>] ? do_page_fault+0x1ec/0x4f0 [ 38.352693] [<ffffffff8106ba4d>] ? set_next_entity+0x9d/0xb0 [ 38.352699] [<ffffffff81310b49>] ? tty_ldisc_deref+0x9/0x10 [ 38.352703] [<ffffffff8106d363>] ? pick_next_task_fair+0x63/0x140 [ 38.352708] [<ffffffff8150b8d4>] sys_sendmsg+0x44/0x80 [ 38.352713] [<ffffffff8165f8e2>] system_call_fastpath+0x16/0x1b It stems from holding a spinlock (trace_state_lock) while attempting to register or unregister tracepoint hooks, making in_atomic() true in this context, leading to the warning when the tracepoint calls might_sleep() while its taking a mutex. Since we only use the trace_state_lock to prevent trace protocol state races, as well as hardware stat list updates on an rcu write side, we can just convert the spinlock to a mutex to avoid this problem. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Reported-by: Eric Dumazet <eric.dumazet@gmail.com> CC: David Miller <davem@davemloft.net> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02rds: set correct msg_namelenWeiping Pan
commit 06b6a1cf6e776426766298d055bb3991957d90a7 upstream. Jay Fenlason (fenlason@redhat.com) found a bug, that recvfrom() on an RDS socket can return the contents of random kernel memory to userspace if it was called with a address length larger than sizeof(struct sockaddr_in). rds_recvmsg() also fails to set the addr_len paramater properly before returning, but that's just a bug. There are also a number of cases wher recvfrom() can return an entirely bogus address. Anything in rds_recvmsg() that returns a non-negative value but does not go through the "sin = (struct sockaddr_in *)msg->msg_name;" code path at the end of the while(1) loop will return up to 128 bytes of kernel memory to userspace. And I write two test programs to reproduce this bug, you will see that in rds_server, fromAddr will be overwritten and the following sock_fd will be destroyed. Yes, it is the programmer's fault to set msg_namelen incorrectly, but it is better to make the kernel copy the real length of address to user space in such case. How to run the test programs ? I test them on 32bit x86 system, 3.5.0-rc7. 1 compile gcc -o rds_client rds_client.c gcc -o rds_server rds_server.c 2 run ./rds_server on one console 3 run ./rds_client on another console 4 you will see something like: server is waiting to receive data... old socket fd=3 server received data from client:data from client msg.msg_namelen=32 new socket fd=-1067277685 sendmsg() : Bad file descriptor /***************** rds_client.c ********************/ int main(void) { int sock_fd; struct sockaddr_in serverAddr; struct sockaddr_in toAddr; char recvBuffer[128] = "data from client"; struct msghdr msg; struct iovec iov; sock_fd = socket(AF_RDS, SOCK_SEQPACKET, 0); if (sock_fd < 0) { perror("create socket error\n"); exit(1); } memset(&serverAddr, 0, sizeof(serverAddr)); serverAddr.sin_family = AF_INET; serverAddr.sin_addr.s_addr = inet_addr("127.0.0.1"); serverAddr.sin_port = htons(4001); if (bind(sock_fd, (struct sockaddr*)&serverAddr, sizeof(serverAddr)) < 0) { perror("bind() error\n"); close(sock_fd); exit(1); } memset(&toAddr, 0, sizeof(toAddr)); toAddr.sin_family = AF_INET; toAddr.sin_addr.s_addr = inet_addr("127.0.0.1"); toAddr.sin_port = htons(4000); msg.msg_name = &toAddr; msg.msg_namelen = sizeof(toAddr); msg.msg_iov = &iov; msg.msg_iovlen = 1; msg.msg_iov->iov_base = recvBuffer; msg.msg_iov->iov_len = strlen(recvBuffer) + 1; msg.msg_control = 0; msg.msg_controllen = 0; msg.msg_flags = 0; if (sendmsg(sock_fd, &msg, 0) == -1) { perror("sendto() error\n"); close(sock_fd); exit(1); } printf("client send data:%s\n", recvBuffer); memset(recvBuffer, '\0', 128); msg.msg_name = &toAddr; msg.msg_namelen = sizeof(toAddr); msg.msg_iov = &iov; msg.msg_iovlen = 1; msg.msg_iov->iov_base = recvBuffer; msg.msg_iov->iov_len = 128; msg.msg_control = 0; msg.msg_controllen = 0; msg.msg_flags = 0; if (recvmsg(sock_fd, &msg, 0) == -1) { perror("recvmsg() error\n"); close(sock_fd); exit(1); } printf("receive data from server:%s\n", recvBuffer); close(sock_fd); return 0; } /***************** rds_server.c ********************/ int main(void) { struct sockaddr_in fromAddr; int sock_fd; struct sockaddr_in serverAddr; unsigned int addrLen; char recvBuffer[128]; struct msghdr msg; struct iovec iov; sock_fd = socket(AF_RDS, SOCK_SEQPACKET, 0); if(sock_fd < 0) { perror("create socket error\n"); exit(0); } memset(&serverAddr, 0, sizeof(serverAddr)); serverAddr.sin_family = AF_INET; serverAddr.sin_addr.s_addr = inet_addr("127.0.0.1"); serverAddr.sin_port = htons(4000); if (bind(sock_fd, (struct sockaddr*)&serverAddr, sizeof(serverAddr)) < 0) { perror("bind error\n"); close(sock_fd); exit(1); } printf("server is waiting to receive data...\n"); msg.msg_name = &fromAddr; /* * I add 16 to sizeof(fromAddr), ie 32, * and pay attention to the definition of fromAddr, * recvmsg() will overwrite sock_fd, * since kernel will copy 32 bytes to userspace. * * If you just use sizeof(fromAddr), it works fine. * */ msg.msg_namelen = sizeof(fromAddr) + 16; /* msg.msg_namelen = sizeof(fromAddr); */ msg.msg_iov = &iov; msg.msg_iovlen = 1; msg.msg_iov->iov_base = recvBuffer; msg.msg_iov->iov_len = 128; msg.msg_control = 0; msg.msg_controllen = 0; msg.msg_flags = 0; while (1) { printf("old socket fd=%d\n", sock_fd); if (recvmsg(sock_fd, &msg, 0) == -1) { perror("recvmsg() error\n"); close(sock_fd); exit(1); } printf("server received data from client:%s\n", recvBuffer); printf("msg.msg_namelen=%d\n", msg.msg_namelen); printf("new socket fd=%d\n", sock_fd); strcat(recvBuffer, "--data from server"); if (sendmsg(sock_fd, &msg, 0) == -1) { perror("sendmsg()\n"); close(sock_fd); exit(1); } } close(sock_fd); return 0; } Signed-off-by: Weiping Pan <wpan@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02net: Statically initialize init_net.dev_base_headRustad, Mark D
commit 734b65417b24d6eea3e3d7457e1f11493890ee1d upstream. This change eliminates an initialization-order hazard most recently seen when netprio_cgroup is built into the kernel. With thanks to Eric Dumazet for catching a bug. Signed-off-by: Mark Rustad <mark.d.rustad@intel.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02cfg80211: fix possible circular lock on reg_regdb_search()Luis R. Rodriguez
commit a85d0d7f3460b1a123b78e7f7e39bf72c37dfb78 upstream. When call_crda() is called we kick off a witch hunt search for the same regulatory domain on our internal regulatory database and that work gets kicked off on a workqueue, this is done while the cfg80211_mutex is held. If that workqueue kicks off it will first lock reg_regdb_search_mutex and later cfg80211_mutex but to ensure two CPUs will not contend against cfg80211_mutex the right thing to do is to have the reg_regdb_search() wait until the cfg80211_mutex is let go. The lockdep report is pasted below. cfg80211: Calling CRDA to update world regulatory domain ====================================================== [ INFO: possible circular locking dependency detected ] 3.3.8 #3 Tainted: G O ------------------------------------------------------- kworker/0:1/235 is trying to acquire lock: (cfg80211_mutex){+.+...}, at: [<816468a4>] set_regdom+0x78c/0x808 [cfg80211] but task is already holding lock: (reg_regdb_search_mutex){+.+...}, at: [<81646828>] set_regdom+0x710/0x808 [cfg80211] which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #2 (reg_regdb_search_mutex){+.+...}: [<800a8384>] lock_acquire+0x60/0x88 [<802950a8>] mutex_lock_nested+0x54/0x31c [<81645778>] is_world_regdom+0x9f8/0xc74 [cfg80211] -> #1 (reg_mutex#2){+.+...}: [<800a8384>] lock_acquire+0x60/0x88 [<802950a8>] mutex_lock_nested+0x54/0x31c [<8164539c>] is_world_regdom+0x61c/0xc74 [cfg80211] -> #0 (cfg80211_mutex){+.+...}: [<800a77b8>] __lock_acquire+0x10d4/0x17bc [<800a8384>] lock_acquire+0x60/0x88 [<802950a8>] mutex_lock_nested+0x54/0x31c [<816468a4>] set_regdom+0x78c/0x808 [cfg80211] other info that might help us debug this: Chain exists of: cfg80211_mutex --> reg_mutex#2 --> reg_regdb_search_mutex Possible unsafe locking scenario: CPU0 CPU1 ---- ---- lock(reg_regdb_search_mutex); lock(reg_mutex#2); lock(reg_regdb_search_mutex); lock(cfg80211_mutex); *** DEADLOCK *** 3 locks held by kworker/0:1/235: #0: (events){.+.+..}, at: [<80089a00>] process_one_work+0x230/0x460 #1: (reg_regdb_work){+.+...}, at: [<80089a00>] process_one_work+0x230/0x460 #2: (reg_regdb_search_mutex){+.+...}, at: [<81646828>] set_regdom+0x710/0x808 [cfg80211] stack backtrace: Call Trace: [<80290fd4>] dump_stack+0x8/0x34 [<80291bc4>] print_circular_bug+0x2ac/0x2d8 [<800a77b8>] __lock_acquire+0x10d4/0x17bc [<800a8384>] lock_acquire+0x60/0x88 [<802950a8>] mutex_lock_nested+0x54/0x31c [<816468a4>] set_regdom+0x78c/0x808 [cfg80211] Reported-by: Felix Fietkau <nbd@openwrt.org> Tested-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02net: ipv4: ipmr_expire_timer causes crash when removing net namespaceFrancesco Ruggeri
[ Upstream commit acbb219d5f53821b2d0080d047800410c0420ea1 ] When tearing down a net namespace, ipv4 mr_table structures are freed without first deactivating their timers. This can result in a crash in run_timer_softirq. This patch mimics the corresponding behaviour in ipv6. Locking and synchronization seem to be adequate. We are about to kfree mrt, so existing code should already make sure that no other references to mrt are pending or can be created by incoming traffic. The functions invoked here do not cause new references to mrt or other race conditions to be created. Invoking del_timer_sync guarantees that ipmr_expire_timer is inactive. Both ipmr_expire_process (whose completion we may have to wait in del_timer_sync) and mroute_clean_tables internally use mfc_unres_lock or other synchronizations when needed, and they both only modify mrt. Tested in Linux 3.4.8. Signed-off-by: Francesco Ruggeri <fruggeri@aristanetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02l2tp: avoid to use synchronize_rcu in tunnel free functionxeb@mail.ru
[ Upstream commit 99469c32f79a32d8481f87be0d3c66dad286f4ec ] Avoid to use synchronize_rcu in l2tp_tunnel_free because context may be atomic. Signed-off-by: Dmitry Kozlov <xeb@mail.ru> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02netlink: fix possible spoofing from non-root processesPablo Neira Ayuso
[ Upstream commit 20e1db19db5d6b9e4e83021595eab0dc8f107bef ] Non-root user-space processes can send Netlink messages to other processes that are well-known for being subscribed to Netlink asynchronous notifications. This allows ilegitimate non-root process to send forged messages to Netlink subscribers. The userspace process usually verifies the legitimate origin in two ways: a) Socket credentials. If UID != 0, then the message comes from some ilegitimate process and the message needs to be dropped. b) Netlink portID. In general, portID == 0 means that the origin of the messages comes from the kernel. Thus, discarding any message not coming from the kernel. However, ctnetlink sets the portID in event messages that has been triggered by some user-space process, eg. conntrack utility. So other processes subscribed to ctnetlink events, eg. conntrackd, know that the event was triggered by some user-space action. Neither of the two ways to discard ilegitimate messages coming from non-root processes can help for ctnetlink. This patch adds capability validation in case that dst_pid is set in netlink_sendmsg(). This approach is aggressive since existing applications using any Netlink bus to deliver messages between two user-space processes will break. Note that the exception is NETLINK_USERSOCK, since it is reserved for netlink-to-netlink userspace communication. Still, if anyone wants that his Netlink bus allows netlink-to-netlink userspace, then they can set NL_NONROOT_SEND. However, by default, I don't think it makes sense to allow to use NETLINK_ROUTE to communicate two processes that are sending no matter what information that is not related to link/neighbouring/routing. They should be using NETLINK_USERSOCK instead for that. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02net: fix info leak in compat dev_ifconf()Mathias Krause
[ Upstream commit 43da5f2e0d0c69ded3d51907d9552310a6b545e8 ] The implementation of dev_ifconf() for the compat ioctl interface uses an intermediate ifc structure allocated in userland for the duration of the syscall. Though, it fails to initialize the padding bytes inserted for alignment and that for leaks four bytes of kernel stack. Add an explicit memset(0) before filling the structure to avoid the info leak. Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02ipvs: fix info leak in getsockopt(IP_VS_SO_GET_TIMEOUT)Mathias Krause
[ Upstream commit 2d8a041b7bfe1097af21441cb77d6af95f4f4680 ] If at least one of CONFIG_IP_VS_PROTO_TCP or CONFIG_IP_VS_PROTO_UDP is not set, __ip_vs_get_timeouts() does not fully initialize the structure that gets copied to userland and that for leaks up to 12 bytes of kernel stack. Add an explicit memset(0) before passing the structure to __ip_vs_get_timeouts() to avoid the info leak. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Wensong Zhang <wensong@linux-vs.org> Cc: Simon Horman <horms@verge.net.au> Cc: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
