path: root/net
2015-02-05sit: fix some __be16/u16 mismatchesEric Dumazet
Fixes following sparse warnings : net/ipv6/sit.c:1509:32: warning: incorrect type in assignment (different base types) net/ipv6/sit.c:1509:32: expected restricted __be16 [usertype] sport net/ipv6/sit.c:1509:32: got unsigned short net/ipv6/sit.c:1514:32: warning: incorrect type in assignment (different base types) net/ipv6/sit.c:1514:32: expected restricted __be16 [usertype] dport net/ipv6/sit.c:1514:32: got unsigned short net/ipv6/sit.c:1711:38: warning: incorrect type in argument 3 (different base types) net/ipv6/sit.c:1711:38: expected unsigned short [unsigned] [usertype] value net/ipv6/sit.c:1711:38: got restricted __be16 [usertype] sport net/ipv6/sit.c:1713:38: warning: incorrect type in argument 3 (different base types) net/ipv6/sit.c:1713:38: expected unsigned short [unsigned] [usertype] value net/ipv6/sit.c:1713:38: got restricted __be16 [usertype] dport Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-05net: remove some sparse warningsEric Dumazet
netdev_adjacent_add_links() and netdev_adjacent_del_links() are static. queue->qdisc has __rcu annotation, need to use RCU_INIT_POINTER() Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-05ip6_gre: fix endianness errors in ip6gre_errSabrina Dubroca
info is in network byte order, change it back to host byte order before use. In particular, the current code sets the MTU of the tunnel to a wrong (too big) value. Fixes: c12b395a4664 ("gre: Support GRE over IPv6") Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-04cls_api.c: Fix dumping of non-existing actions' stats.Ignacy Gawędzki
In tcf_exts_dump_stats(), ensure that exts->actions is not empty before accessing the first element of that list and calling tcf_action_copy_stats() on it. This fixes some random segvs when adding filters of type "basic" with no particular action. This also fixes the dumping of those "no-action" filters, which more often than not made calls to tcf_action_copy_stats() fail and consequently netlink attributes added by the caller to be removed by a call to nla_nest_cancel(). Fixes: 33be62715991 ("net_sched: act: use standard struct list_head") Signed-off-by: Ignacy Gawędzki <ignacy.gawedzki@green-communications.fr> Acked-by: Cong Wang <cwang@twopensource.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-04pkt_sched: fq: avoid hang when quantum 0Kenneth Klette Jonassen
Configuring fq with quantum 0 hangs the system, presumably because of a non-interruptible infinite loop. Either way quantum 0 does not make sense. Reproduce with: sudo tc qdisc add dev lo root fq quantum 0 initial_quantum 0 ping 127.0.0.1 Signed-off-by: Kenneth Klette Jonassen <kennetkl@ifi.uio.no> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-04net: rds: use correct size for max unacked packets and bytesSasha Levin
Max unacked packets/bytes is an int while sizeof(long) was used in the sysctl table. This means that when they were getting read we'd also leak kernel memory to userspace along with the timeout values. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-03ipv6: Select fragment id during UFO segmentation if not set.Vlad Yasevich
If the IPv6 fragment id has not been set and we perform fragmentation due to UFO, select a new fragment id. We now consider a fragment id of 0 as unset and if id selection process returns 0 (after all the pertrubations), we set it to 0x80000000, thus giving us ample space not to create collisions with the next packet we may have to fragment. When doing UFO integrity checking, we also select the fragment id if it has not be set yet. This is stored into the skb_shinfo() thus allowing UFO to function correclty. This patch also removes duplicate fragment id generation code and moves ipv6_select_ident() into the header as it may be used during GSO. Signed-off-by: Vladislav Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nfDavid S. Miller
Pablo Neira Ayuso says: ==================== Netfilter/IPVS fixes for net The following patchset contains Netfilter/IPVS fixes for your net tree, they are: 1) Validate hooks for nf_tables NAT expressions, otherwise users can crash the kernel when using them from the wrong hook. We already got one user trapped on this when configuring masquerading. 2) Fix a BUG splat in nf_tables with CONFIG_DEBUG_PREEMPT=y. Reported by Andreas Schultz. 3) Avoid unnecessary reroute of traffic in the local input path in IPVS that triggers a crash in in xfrm. Reported by Florian Wiessner and fixes by Julian Anastasov. 4) Fix memory and module refcount leak from the error path of nf_tables_newchain(). ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-01ipv4: tcp: get rid of ugly unicast_sockEric Dumazet
In commit be9f4a44e7d41 ("ipv4: tcp: remove per net tcp_sock") I tried to address contention on a socket lock, but the solution I chose was horrible : commit 3a7c384ffd57e ("ipv4: tcp: unicast_sock should not land outside of TCP stack") addressed a selinux regression. commit 0980e56e506b ("ipv4: tcp: set unicast_sock uc_ttl to -1") took care of another regression. commit b5ec8eeac46 ("ipv4: fix ip_send_skb()") fixed another regression. commit 811230cd85 ("tcp: ipv4: initialize unicast_sock sk_pacing_rate") was another shot in the dark. Really, just use a proper socket per cpu, and remove the skb_orphan() call, to re-enable flow control. This solves a serious problem with FQ packet scheduler when used in hostile environments, as we do not want to allocate a flow structure for every RST packet sent in response to a spoofed packet. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-30net: Fix vlan_get_protocol for stacked vlanToshiaki Makita
vlan_get_protocol() could not get network protocol if a skb has a 802.1ad vlan tag or multiple vlans, which caused incorrect checksum calculation in several drivers. Fix vlan_get_protocol() to retrieve network protocol instead of incorrect vlan protocol. As the logic is the same as skb_network_protocol(), create a common helper function __vlan_get_protocol() and call it from existing functions. Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-30net: sctp: fix passing wrong parameter header to param_type2af in ↵Saran Maruti Ramanara
sctp_process_param When making use of RFC5061, section 4.2.4. for setting the primary IP address, we're passing a wrong parameter header to param_type2af(), resulting always in NULL being returned. At this point, param.p points to a sctp_addip_param struct, containing a sctp_paramhdr (type = 0xc004, length = var), and crr_id as a correlation id. Followed by that, as also presented in RFC5061 section 4.2.4., comes the actual sctp_addr_param, which also contains a sctp_paramhdr, but this time with the correct type SCTP_PARAM_IPV{4,6}_ADDRESS that param_type2af() can make use of. Since we already hold a pointer to addr_param from previous line, just reuse it for param_type2af(). Fixes: d6de3097592b ("[SCTP]: Add the handling of "Set Primary IP Address" parameter to INIT") Signed-off-by: Saran Maruti Ramanara <saran.neti@telus.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-30netlink: fix wrong subscription bitmask to group mapping inPablo Neira
The subscription bitmask passed via struct sockaddr_nl is converted to the group number when calling the netlink_bind() and netlink_unbind() callbacks. The conversion is however incorrect since bitmask (1 << 0) needs to be mapped to group number 1. Note that you cannot specify the group number 0 (usually known as _NONE) from setsockopt() using NETLINK_ADD_MEMBERSHIP since this is rejected through -EINVAL. This problem became noticeable since 97840cb ("netfilter: nfnetlink: fix insufficient validation in nfnetlink_bind") when binding to bitmask (1 << 0) in ctnetlink. Reported-by: Andre Tomt <andre@tomt.net> Reported-by: Ivan Delalande <colona@arista.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-30netfilter: nf_tables: fix leaks in error path of nf_tables_newchain()Pablo Neira Ayuso
Release statistics and module refcount on memory allocation problems. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-01-30ipvs: rerouting to local clients is not needed anymoreJulian Anastasov
commit f5a41847acc5 ("ipvs: move ip_route_me_harder for ICMP") from 2.6.37 introduced ip_route_me_harder() call for responses to local clients, so that we can provide valid rt_src after SNAT. It was used by TCP to provide valid daddr for ip_send_reply(). After commit 0a5ebb8000c5 ("ipv4: Pass explicit daddr arg to ip_send_reply()." from 3.0 this rerouting is not needed anymore and should be avoided, especially in LOCAL_IN. Fixes 3.12.33 crash in xfrm reported by Florian Wiessner: "3.12.33 - BUG xfrm_selector_match+0x25/0x2f6" Reported-by: Smart Weblications GmbH - Florian Wiessner <f.wiessner@smart-weblications.de> Tested-by: Smart Weblications GmbH - Florian Wiessner <f.wiessner@smart-weblications.de> Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Simon Horman <horms@verge.net.au>
2015-01-29ipv4: Don't increase PMTU with Datagram Too Big message.Li Wei
RFC 1191 said, "a host MUST not increase its estimate of the Path MTU in response to the contents of a Datagram Too Big message." Signed-off-by: Li Wei <lw@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-29caif: remove wrong dev_net_set() callNicolas Dichtel
src_net points to the netns where the netlink message has been received. This netns may be different from the netns where the interface is created (because the user may add IFLA_NET_NS_[PID|FD]). In this case, src_net is the link netns. It seems wrong to override the netns in the newlink() handler because if it was not already src_net, it means that the user explicitly asks to create the netdevice in another netns. CC: Sjur Brændeland <sjur.brandeland@stericsson.com> CC: Dmitry Tarnyagin <dmitry.tarnyagin@lockless.no> Fixes: 8391c4aab1aa ("caif: Bugfixes in CAIF netdevice for close and flow control") Fixes: c41254006377 ("caif-hsi: Add rtnl support") Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-28tcp: ipv4: initialize unicast_sock sk_pacing_rateEric Dumazet
When I added sk_pacing_rate field, I forgot to initialize its value in the per cpu unicast_sock used in ip_send_unicast_reply() This means that for sch_fq users, RST packets, or ACK packets sent on behalf of TIME_WAIT sockets might be sent to slowly or even dropped once we reach the per flow limit. Signed-off-by: Eric Dumazet <edumazet@google.com> Fixes: 95bd09eb2750 ("tcp: TSO packets automatic sizing") Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-28bridge: dont send notification when skb->len == 0 in rtnl_bridge_notifyRoopa Prabhu
Reported in: https://bugzilla.kernel.org/show_bug.cgi?id=92081 This patch avoids calling rtnl_notify if the device ndo_bridge_getlink handler does not return any bytes in the skb. Alternately, the skb->len check can be moved inside rtnl_notify. For the bridge vlan case described in 92081, there is also a fix needed in bridge driver to generate a proper notification. Will fix that in subsequent patch. v2: rebase patch on net tree Signed-off-by: Roopa Prabhu <roopa@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-28tcp: fix timing issue in CUBIC slope calculationNeal Cardwell
This patch fixes a bug in CUBIC that causes cwnd to increase slightly too slowly when multiple ACKs arrive in the same jiffy. If cwnd is supposed to increase at a rate of more than once per jiffy, then CUBIC was sometimes too slow. Because the bic_target is calculated for a future point in time, calculated with time in jiffies, the cwnd can increase over the course of the jiffy while the bic_target calculated as the proper CUBIC cwnd at time t=tcp_time_stamp+rtt does not increase, because tcp_time_stamp only increases on jiffy tick boundaries. So since the cnt is set to: ca->cnt = cwnd / (bic_target - cwnd); as cwnd increases but bic_target does not increase due to jiffy granularity, the cnt becomes too large, causing cwnd to increase too slowly. For example: - suppose at the beginning of a jiffy, cwnd=40, bic_target=44 - so CUBIC sets: ca->cnt = cwnd / (bic_target - cwnd) = 40 / (44 - 40) = 40/4 = 10 - suppose we get 10 acks, each for 1 segment, so tcp_cong_avoid_ai() increases cwnd to 41 - so CUBIC sets: ca->cnt = cwnd / (bic_target - cwnd) = 41 / (44 - 41) = 41 / 3 = 13 So now CUBIC will wait for 13 packets to be ACKed before increasing cwnd to 42, insted of 10 as it should. The fix is to avoid adjusting the slope (determined by ca->cnt) multiple times within a jiffy, and instead skip to compute the Reno cwnd, the "TCP friendliness" code path. Reported-by: Eyal Perry <eyalpe@mellanox.com> Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Yuchung Cheng <ycheng@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-28tcp: fix stretch ACK bugs in CUBICNeal Cardwell
Change CUBIC to properly handle stretch ACKs in additive increase mode by passing in the count of ACKed packets to tcp_cong_avoid_ai(). In addition, because we are now precisely accounting for stretch ACKs, including delayed ACKs, we can now remove the delayed ACK tracking and estimation code that tracked recent delayed ACK behavior in ca->delayed_ack. Reported-by: Eyal Perry <eyalpe@mellanox.com> Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Yuchung Cheng <ycheng@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-28tcp: fix stretch ACK bugs in RenoNeal Cardwell
Change Reno to properly handle stretch ACKs in additive increase mode by passing in the count of ACKed packets to tcp_cong_avoid_ai(). In addition, if snd_cwnd crosses snd_ssthresh during slow start processing, and we then exit slow start mode, we need to carry over any remaining "credit" for packets ACKed and apply that to additive increase by passing this remaining "acked" count to tcp_cong_avoid_ai(). Reported-by: Eyal Perry <eyalpe@mellanox.com> Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Yuchung Cheng <ycheng@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-28tcp: fix the timid additive increase on stretch ACKsNeal Cardwell
tcp_cong_avoid_ai() was too timid (snd_cwnd increased too slowly) on "stretch ACKs" -- cases where the receiver ACKed more than 1 packet in a single ACK. For example, suppose w is 10 and we get a stretch ACK for 20 packets, so acked is 20. We ought to increase snd_cwnd by 2 (since acked/w = 20/10 = 2), but instead we were only increasing cwnd by 1. This patch fixes that behavior. Reported-by: Eyal Perry <eyalpe@mellanox.com> Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Yuchung Cheng <ycheng@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-28tcp: stretch ACK fixes prepNeal Cardwell
LRO, GRO, delayed ACKs, and middleboxes can cause "stretch ACKs" that cover more than the RFC-specified maximum of 2 packets. These stretch ACKs can cause serious performance shortfalls in common congestion control algorithms that were designed and tuned years ago with receiver hosts that were not using LRO or GRO, and were instead politely ACKing every other packet. This patch series fixes Reno and CUBIC to handle stretch ACKs. This patch prepares for the upcoming stretch ACK bug fix patches. It adds an "acked" parameter to tcp_cong_avoid_ai() to allow for future fixes to tcp_cong_avoid_ai() to correctly handle stretch ACKs, and changes all congestion control algorithms to pass in 1 for the ACKed count. It also changes tcp_slow_start() to return the number of packet ACK "credits" that were not processed in slow start mode, and can be processed by the congestion control module in additive increase mode. In future patches we will fix tcp_cong_avoid_ai() to handle stretch ACKs, and fix Reno and CUBIC handling of stretch ACKs in slow start and additive increase mode. Reported-by: Eyal Perry <eyalpe@mellanox.com> Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Yuchung Cheng <ycheng@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-27net: don't OOPS on socket aioChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-27Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec Steffen Klassert says: ==================== ipsec 2015-01-26 Just two small fixes for _decode_session6() where we might decode to wrong header information in some rare situations. Please pull or let me know if there are problems. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-27ipv6: replacing a rt6_info needs to purge possible propagated rt6_infos tooHannes Frederic Sowa
Lubomir Rintel reported that during replacing a route the interface reference counter isn't correctly decremented. To quote bug <https://bugzilla.kernel.org/show_bug.cgi?id=91941>: | [root@rhel7-5 lkundrak]# sh -x lal | + ip link add dev0 type dummy | + ip link set dev0 up | + ip link add dev1 type dummy | + ip link set dev1 up | + ip addr add 2001:db8:8086::2/64 dev dev0 | + ip route add 2001:db8:8086::/48 dev dev0 proto static metric 20 | + ip route add 2001:db8:8088::/48 dev dev1 proto static metric 10 | + ip route replace 2001:db8:8086::/48 dev dev1 proto static metric 20 | + ip link del dev0 type dummy | Message from syslogd@rhel7-5 at Jan 23 10:54:41 ... | kernel:unregister_netdevice: waiting for dev0 to become free. Usage count = 2 | | Message from syslogd@rhel7-5 at Jan 23 10:54:51 ... | kernel:unregister_netdevice: waiting for dev0 to become free. Usage count = 2 During replacement of a rt6_info we must walk all parent nodes and check if the to be replaced rt6_info got propagated. If so, replace it with an alive one. Fixes: 4a287eba2de3957 ("IPv6 routing, NLM_F_* flag support: REPLACE and EXCL flags support, warn about missing CREATE flag") Reported-by: Lubomir Rintel <lkundrak@v3.sk> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Tested-by: Lubomir Rintel <lkundrak@v3.sk> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-27ping: Fix race in free in receive pathsubashab@codeaurora.org
An exception is seen in ICMP ping receive path where the skb destructor sock_rfree() tries to access a freed socket. This happens because ping_rcv() releases socket reference with sock_put() and this internally frees up the socket. Later icmp_rcv() will try to free the skb and as part of this, skb destructor is called and which leads to a kernel panic as the socket is freed already in ping_rcv(). -->|exception -007|sk_mem_uncharge -007|sock_rfree -008|skb_release_head_state -009|skb_release_all -009|__kfree_skb -010|kfree_skb -011|icmp_rcv -012|ip_local_deliver_finish Fix this incorrect free by cloning this skb and processing this cloned skb instead. This patch was suggested by Eric Dumazet Signed-off-by: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org> Cc: Eric Dumazet <edumazet@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-27udp_diag: Fix socket skipping within chainHerbert Xu
While working on rhashtable walking I noticed that the UDP diag dumping code is buggy. In particular, the socket skipping within a chain never happens, even though we record the number of sockets that should be skipped. As this code was supposedly copied from TCP, this patch does what TCP does and resets num before we walk a chain. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-26Merge tag 'mac80211-for-davem-2015-01-23' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211 Another set of last-minute fixes: * fix station double-removal when suspending while associating * fix the HT (802.11n) header length calculation * fix the CCK radiotap flag used for monitoring, a pretty old regression but a simple one-liner * fix per-station group-key handling Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-26ipv4: try to cache dst_entries which would cause a redirectHannes Frederic Sowa
Not caching dst_entries which cause redirects could be exploited by hosts on the same subnet, causing a severe DoS attack. This effect aggravated since commit f88649721268999 ("ipv4: fix dst race in sk_dst_get()"). Lookups causing redirects will be allocated with DST_NOCACHE set which will force dst_release to free them via RCU. Unfortunately waiting for RCU grace period just takes too long, we can end up with >1M dst_entries waiting to be released and the system will run OOM. rcuos threads cannot catch up under high softirq load. Attaching the flag to emit a redirect later on to the specific skb allows us to cache those dst_entries thus reducing the pressure on allocation and deallocation. This issue was discovered by Marcelo Leitner. Cc: Julian Anastasov <ja@ssi.bg> Signed-off-by: Marcelo Leitner <mleitner@redhat.com> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-26net: sctp: fix slab corruption from use after free on INIT collisionsDaniel Borkmann
When hitting an INIT collision case during the 4WHS with AUTH enabled, as already described in detail in commit 1be9a950c646 ("net: sctp: inherit auth_capable on INIT collisions"), it can happen that we occasionally still remotely trigger the following panic on server side which seems to have been uncovered after the fix from commit 1be9a950c646 ... [ 533.876389] BUG: unable to handle kernel paging request at 00000000ffffffff [ 533.913657] IP: [<ffffffff811ac385>] __kmalloc+0x95/0x230 [ 533.940559] PGD 5030f2067 PUD 0 [ 533.957104] Oops: 0000 [#1] SMP [ 533.974283] Modules linked in: sctp mlx4_en [...] [ 534.939704] Call Trace: [ 534.951833] [<ffffffff81294e30>] ? crypto_init_shash_ops+0x60/0xf0 [ 534.984213] [<ffffffff81294e30>] crypto_init_shash_ops+0x60/0xf0 [ 535.015025] [<ffffffff8128c8ed>] __crypto_alloc_tfm+0x6d/0x170 [ 535.045661] [<ffffffff8128d12c>] crypto_alloc_base+0x4c/0xb0 [ 535.074593] [<ffffffff8160bd42>] ? _raw_spin_lock_bh+0x12/0x50 [ 535.105239] [<ffffffffa0418c11>] sctp_inet_listen+0x161/0x1e0 [sctp] [ 535.138606] [<ffffffff814e43bd>] SyS_listen+0x9d/0xb0 [ 535.166848] [<ffffffff816149a9>] system_call_fastpath+0x16/0x1b ... or depending on the the application, for example this one: [ 1370.026490] BUG: unable to handle kernel paging request at 00000000ffffffff [ 1370.026506] IP: [<ffffffff811ab455>] kmem_cache_alloc+0x75/0x1d0 [ 1370.054568] PGD 633c94067 PUD 0 [ 1370.070446] Oops: 0000 [#1] SMP [ 1370.085010] Modules linked in: sctp kvm_amd kvm [...] [ 1370.963431] Call Trace: [ 1370.974632] [<ffffffff8120f7cf>] ? SyS_epoll_ctl+0x53f/0x960 [ 1371.000863] [<ffffffff8120f7cf>] SyS_epoll_ctl+0x53f/0x960 [ 1371.027154] [<ffffffff812100d3>] ? anon_inode_getfile+0xd3/0x170 [ 1371.054679] [<ffffffff811e3d67>] ? __alloc_fd+0xa7/0x130 [ 1371.080183] [<ffffffff816149a9>] system_call_fastpath+0x16/0x1b With slab debugging enabled, we can see that the poison has been overwritten: [ 669.826368] BUG kmalloc-128 (Tainted: G W ): Poison overwritten [ 669.826385] INFO: 0xffff880228b32e50-0xffff880228b32e50. First byte 0x6a instead of 0x6b [ 669.826414] INFO: Allocated in sctp_auth_create_key+0x23/0x50 [sctp] age=3 cpu=0 pid=18494 [ 669.826424] __slab_alloc+0x4bf/0x566 [ 669.826433] __kmalloc+0x280/0x310 [ 669.826453] sctp_auth_create_key+0x23/0x50 [sctp] [ 669.826471] sctp_auth_asoc_create_secret+0xcb/0x1e0 [sctp] [ 669.826488] sctp_auth_asoc_init_active_key+0x68/0xa0 [sctp] [ 669.826505] sctp_do_sm+0x29d/0x17c0 [sctp] [...] [ 669.826629] INFO: Freed in kzfree+0x31/0x40 age=1 cpu=0 pid=18494 [ 669.826635] __slab_free+0x39/0x2a8 [ 669.826643] kfree+0x1d6/0x230 [ 669.826650] kzfree+0x31/0x40 [ 669.826666] sctp_auth_key_put+0x19/0x20 [sctp] [ 669.826681] sctp_assoc_update+0x1ee/0x2d0 [sctp] [ 669.826695] sctp_do_sm+0x674/0x17c0 [sctp] Since this only triggers in some collision-cases with AUTH, the problem at heart is that sctp_auth_key_put() on asoc->asoc_shared_key is called twice when having refcnt 1, once directly in sctp_assoc_update() and yet again from within sctp_auth_asoc_init_active_key() via sctp_assoc_update() on the already kzfree'd memory, which is also consistent with the observation of the poison decrease from 0x6b to 0x6a (note: the overwrite is detected at a later point in time when poison is checked on new allocation). Reference counting of auth keys revisited: Shared keys for AUTH chunks are being stored in endpoints and associations in endpoint_shared_keys list. On endpoint creation, a null key is being added; on association creation, all endpoint shared keys are being cached and thus cloned over to the association. struct sctp_shared_key only holds a pointer to the actual key bytes, that is, struct sctp_auth_bytes which keeps track of users internally through refcounting. Naturally, on assoc or enpoint destruction, sctp_shared_key are being destroyed directly and the reference on sctp_auth_bytes dropped. User space can add keys to either list via setsockopt(2) through struct sctp_authkey and by passing that to sctp_auth_set_key() which replaces or adds a new auth key. There, sctp_auth_create_key() creates a new sctp_auth_bytes with refcount 1 and in case of replacement drops the reference on the old sctp_auth_bytes. A key can be set active from user space through setsockopt() on the id via sctp_auth_set_active_key(), which iterates through either endpoint_shared_keys and in case of an assoc, invokes (one of various places) sctp_auth_asoc_init_active_key(). sctp_auth_asoc_init_active_key() computes the actual secret from local's and peer's random, hmac and shared key parameters and returns a new key directly as sctp_auth_bytes, that is asoc->asoc_shared_key, plus drops the reference if there was a previous one. The secret, which where we eventually double drop the ref comes from sctp_auth_asoc_set_secret() with intitial refcount of 1, which also stays unchanged eventually in sctp_assoc_update(). This key is later being used for crypto layer to set the key for the hash in crypto_hash_setkey() from sctp_auth_calculate_hmac(). To close the loop: asoc->asoc_shared_key is freshly allocated secret material and independant of the sctp_shared_key management keeping track of only shared keys in endpoints and assocs. Hence, also commit 4184b2a79a76 ("net: sctp: fix memory leak in auth key management") is independant of this bug here since it concerns a different layer (though same structures being used eventually). asoc->asoc_shared_key is reference dropped correctly on assoc destruction in sctp_association_free() and when active keys are being replaced in sctp_auth_asoc_init_active_key(), it always has a refcount of 1. Hence, it's freed prematurely in sctp_assoc_update(). Simple fix is to remove that sctp_auth_key_put() from there which fixes these panics. Fixes: 730fc3d05cd4 ("[SCTP]: Implete SCTP-AUTH parameter processing") Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-26net: cls_bpf: fix auto generation of per list handlesDaniel Borkmann
When creating a bpf classifier in tc with priority collisions and invoking automatic unique handle assignment, cls_bpf_grab_new_handle() will return a wrong handle id which in fact is non-unique. Usually altering of specific filters is being addressed over major id, but in case of collisions we result in a filter chain, where handle ids address individual cls_bpf_progs inside the classifier. Issue is, in cls_bpf_grab_new_handle() we probe for head->hgen handle in cls_bpf_get() and in case we found a free handle, we're supposed to use exactly head->hgen. In case of insufficient numbers of handles, we bail out later as handle id 0 is not allowed. Fixes: 7d1d65cb84e1 ("net: sched: cls_bpf: add BPF-based classifier") Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Jiri Pirko <jiri@resnulli.us> Acked-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-26net: cls_bpf: fix size mismatch on filter preparationDaniel Borkmann
In cls_bpf_modify_existing(), we read out the number of filter blocks, do some sanity checks, allocate a block on that size, and copy over the BPF instruction blob from user space, then pass everything through the classic BPF checker prior to installation of the classifier. We should reject mismatches here, there are 2 scenarios: the number of filter blocks could be smaller than the provided instruction blob, so we do a partial copy of the BPF program, and thus the instructions will either be rejected from the verifier or a valid BPF program will be run; in the other case, we'll end up copying more than we're supposed to, and most likely the trailing garbage will be rejected by the verifier as well (i.e. we need to fit instruction pattern, ret {A,K} needs to be last instruction, load/stores must be correct, etc); in case not, we would leak memory when dumping back instruction patterns. The code should have only used nla_len() as Dave noted to avoid this from the beginning. Anyway, lets fix it by rejecting such load attempts. Fixes: 7d1d65cb84e1 ("net: sched: cls_bpf: add BPF-based classifier") Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-26netfilter: nf_tables: disable preemption when restoring chain countersPablo Neira Ayuso
With CONFIG_DEBUG_PREEMPT=y [22144.496057] BUG: using smp_processor_id() in preemptible [00000000] code: iptables-compat/10406 [22144.496061] caller is debug_smp_processor_id+0x17/0x1b [22144.496065] CPU: 2 PID: 10406 Comm: iptables-compat Not tainted 3.19.0-rc4+ # [...] [22144.496092] Call Trace: [22144.496098] [<ffffffff8145b9fa>] dump_stack+0x4f/0x7b [22144.496104] [<ffffffff81244f52>] check_preemption_disabled+0xd6/0xe8 [22144.496110] [<ffffffff81244f90>] debug_smp_processor_id+0x17/0x1b [22144.496120] [<ffffffffa07c557e>] nft_stats_alloc+0x94/0xc7 [nf_tables] [22144.496130] [<ffffffffa07c73d2>] nf_tables_newchain+0x471/0x6d8 [nf_tables] [22144.496140] [<ffffffffa07c5ef6>] ? nft_trans_alloc+0x18/0x34 [nf_tables] [22144.496154] [<ffffffffa063c8da>] nfnetlink_rcv_batch+0x2b4/0x457 [nfnetlink] Reported-by: Andreas Schultz <aschultz@tpip.net> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-01-25ipv6: Fix __ip6_route_redirectMartin KaFai Lau
In my last commit (a3c00e4: ipv6: Remove BACKTRACK macro), the changes in __ip6_route_redirect is incorrect. The following case is missed: 1. The for loop tries to find a valid gateway rt. If it fails to find one, rt will be NULL. 2. When rt is NULL, it is set to the ip6_null_entry. 3. The newly added 'else if', from a3c00e4, will stop the backtrack from happening. Signed-off-by: Martin KaFai Lau <kafai@fb.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-25net: dsa: set slave MII bus PHY maskVivien Didelot
When registering a mdio bus, Linux assumes than every port has a PHY and tries to scan it. If a switch port has no PHY registered, DSA will fail to register the slave MII bus. To fix this, set the slave MII bus PHY mask to the switch PHYs mask. As an example, if we use a Marvell MV88E6352 (which is a 7-port switch with no registered PHYs for port 5 and port 6), with the following declared names: static struct dsa_chip_data switch_cdata = { [...] .port_names[0] = "sw0", .port_names[1] = "sw1", .port_names[2] = "sw2", .port_names[3] = "sw3", .port_names[4] = "sw4", .port_names[5] = "cpu", }; DSA will fail to create the switch instance. With the PHY mask set for the slave MII bus, only the PHY for ports 0-4 will be scanned and the instance will be successfully created. Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com> Tested-by: Florian Fainelli <f.fainelli@gmail.com> Acked-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-25net: llc: use correct size for sysctl timeout entriesSasha Levin
The timeout entries are sizeof(int) rather than sizeof(long), which means that when they were getting read we'd also leak kernel memory to userspace along with the timeout values. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-23nl80211: fix per-station group key get/del and memory leakJohannes Berg
In case userspace attempts to obtain key information for or delete a unicast key, this is currently erroneously rejected unless the driver sets the WIPHY_FLAG_IBSS_RSN flag. Apparently enough drivers do so it was never noticed. Fix that, and while at it fix a potential memory leak: the error path in the get_key() function was placed after allocating a message but didn't free it - move it to a better place. Luckily admin permissions are needed to call this operation. Cc: stable@vger.kernel.org Fixes: e31b82136d1ad ("cfg80211/mac80211: allow per-station GTKs") Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2015-01-23mac80211: properly set CCK flag in radiotapMathy Vanhoef
Fix a regression introduced by commit a5e70697d0c4 ("mac80211: add radiotap flag and handling for 5/10 MHz") where the IEEE80211_CHAN_CCK channel type flag was incorrectly replaced by the IEEE80211_CHAN_OFDM flag. This commit fixes that by using the CCK flag again. Cc: stable@vger.kernel.org Fixes: a5e70697d0c4 ("mac80211: add radiotap flag and handling for 5/10 MHz") Signed-off-by: Mathy Vanhoef <vanhoefm@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2015-01-23mac80211: correct header length calculationFred Chou
HT Control field may also be present in management frames, as defined in 8.2.4.1.10 of 802.11-2012. Account for this in calculation of header length. Signed-off-by: Fred Chou <fred.chou.nd@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2015-01-23mac80211: only roll back station states for WDS when suspendingLuciano Coelho
In normal cases (i.e. when we are fully associated), cfg80211 takes care of removing all the stations before calling suspend in mac80211. But in the corner case when we suspend during authentication or association, mac80211 needs to roll back the station states. But we shouldn't roll back the station states in the suspend function, because this is taken care of in other parts of the code, except for WDS interfaces. For AP types of interfaces, cfg80211 takes care of disconnecting all stations before calling the driver's suspend code. For station interfaces, this is done in the quiesce code. For WDS interfaces we still need to do it here, so move the code into a new switch case for WDS. Cc: stable@kernel.org [3.15+] Signed-off-by: Luciano Coelho <luciano.coelho@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2015-01-19ipv6: stop sending PTB packets for MTU < 1280Hagen Paul Pfeifer
Reduce the attack vector and stop generating IPv6 Fragment Header for paths with an MTU smaller than the minimum required IPv6 MTU size (1280 byte) - called atomic fragments. See IETF I-D "Deprecating the Generation of IPv6 Atomic Fragments" [1] for more information and how this "feature" can be misused. [1] https://tools.ietf.org/html/draft-ietf-6man-deprecate-atomfrag-generation-00 Signed-off-by: Fernando Gont <fgont@si6networks.com> Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-19netfilter: nf_tables: validate hooks in NAT expressionsPablo Neira Ayuso
The user can crash the kernel if it uses any of the existing NAT expressions from the wrong hook, so add some code to validate this when loading the rule. This patch introduces nft_chain_validate_hooks() which is based on an existing function in the bridge version of the reject expression. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-01-17net: sctp: fix race for one-to-many sockets in sendmsg's auto associateDaniel Borkmann
I.e. one-to-many sockets in SCTP are not required to explicitly call into connect(2) or sctp_connectx(2) prior to data exchange. Instead, they can directly invoke sendmsg(2) and the SCTP stack will automatically trigger connection establishment through 4WHS via sctp_primitive_ASSOCIATE(). However, this in its current implementation is racy: INIT is being sent out immediately (as it cannot be bundled anyway) and the rest of the DATA chunks are queued up for later xmit when connection is established, meaning sendmsg(2) will return successfully. This behaviour can result in an undesired side-effect that the kernel made the application think the data has already been transmitted, although none of it has actually left the machine, worst case even after close(2)'ing the socket. Instead, when the association from client side has been shut down e.g. first gracefully through SCTP_EOF and then close(2), the client could afterwards still receive the server's INIT_ACK due to a connection with higher latency. This INIT_ACK is then considered out of the blue and hence responded with ABORT as there was no alive assoc found anymore. This can be easily reproduced f.e. with sctp_test application from lksctp. One way to fix this race is to wait for the handshake to actually complete. The fix defers waiting after sctp_primitive_ASSOCIATE() and sctp_primitive_SEND() succeeded, so that DATA chunks cooked up from sctp_sendmsg() have already been placed into the output queue through the side-effect interpreter, and therefore can then be bundeled together with COOKIE_ECHO control chunks. strace from example application (shortened): socket(PF_INET, SOCK_SEQPACKET, IPPROTO_SCTP) = 3 sendmsg(3, {msg_name(28)={sa_family=AF_INET, sin_port=htons(8888), sin_addr=inet_addr("192.168.1.115")}, msg_iov(1)=[{"hello", 5}], msg_controllen=0, msg_flags=0}, 0) = 5 sendmsg(3, {msg_name(28)={sa_family=AF_INET, sin_port=htons(8888), sin_addr=inet_addr("192.168.1.115")}, msg_iov(1)=[{"hello", 5}], msg_controllen=0, msg_flags=0}, 0) = 5 sendmsg(3, {msg_name(28)={sa_family=AF_INET, sin_port=htons(8888), sin_addr=inet_addr("192.168.1.115")}, msg_iov(1)=[{"hello", 5}], msg_controllen=0, msg_flags=0}, 0) = 5 sendmsg(3, {msg_name(28)={sa_family=AF_INET, sin_port=htons(8888), sin_addr=inet_addr("192.168.1.115")}, msg_iov(1)=[{"hello", 5}], msg_controllen=0, msg_flags=0}, 0) = 5 sendmsg(3, {msg_name(28)={sa_family=AF_INET, sin_port=htons(8888), sin_addr=inet_addr("192.168.1.115")}, msg_iov(0)=[], msg_controllen=48, {cmsg_len=48, cmsg_level=0x84 /* SOL_??? */, cmsg_type=, ...}, msg_flags=0}, 0) = 0 // graceful shutdown for SOCK_SEQPACKET via SCTP_EOF close(3) = 0 tcpdump before patch (fooling the application): 22:33:36.306142 IP 192.168.1.114.41462 > 192.168.1.115.8888: sctp (1) [INIT] [init tag: 3879023686] [rwnd: 106496] [OS: 10] [MIS: 65535] [init TSN: 3139201684] 22:33:36.316619 IP 192.168.1.115.8888 > 192.168.1.114.41462: sctp (1) [INIT ACK] [init tag: 3345394793] [rwnd: 106496] [OS: 10] [MIS: 10] [init TSN: 3380109591] 22:33:36.317600 IP 192.168.1.114.41462 > 192.168.1.115.8888: sctp (1) [ABORT] tcpdump after patch: 14:28:58.884116 IP 192.168.1.114.35846 > 192.168.1.115.8888: sctp (1) [INIT] [init tag: 438593213] [rwnd: 106496] [OS: 10] [MIS: 65535] [init TSN: 3092969729] 14:28:58.888414 IP 192.168.1.115.8888 > 192.168.1.114.35846: sctp (1) [INIT ACK] [init tag: 381429855] [rwnd: 106496] [OS: 10] [MIS: 10] [init TSN: 2141904492] 14:28:58.888638 IP 192.168.1.114.35846 > 192.168.1.115.8888: sctp (1) [COOKIE ECHO] , (2) [DATA] (B)(E) [TSN: 3092969729] [...] 14:28:58.893278 IP 192.168.1.115.8888 > 192.168.1.114.35846: sctp (1) [COOKIE ACK] , (2) [SACK] [cum ack 3092969729] [a_rwnd 106491] [#gap acks 0] [#dup tsns 0] 14:28:58.893591 IP 192.168.1.114.35846 > 192.168.1.115.8888: sctp (1) [DATA] (B)(E) [TSN: 3092969730] [...] 14:28:59.096963 IP 192.168.1.115.8888 > 192.168.1.114.35846: sctp (1) [SACK] [cum ack 3092969730] [a_rwnd 106496] [#gap acks 0] [#dup tsns 0] 14:28:59.097086 IP 192.168.1.114.35846 > 192.168.1.115.8888: sctp (1) [DATA] (B)(E) [TSN: 3092969731] [...] , (2) [DATA] (B)(E) [TSN: 3092969732] [...] 14:28:59.103218 IP 192.168.1.115.8888 > 192.168.1.114.35846: sctp (1) [SACK] [cum ack 3092969732] [a_rwnd 106486] [#gap acks 0] [#dup tsns 0] 14:28:59.103330 IP 192.168.1.114.35846 > 192.168.1.115.8888: sctp (1) [SHUTDOWN] 14:28:59.107793 IP 192.168.1.115.8888 > 192.168.1.114.35846: sctp (1) [SHUTDOWN ACK] 14:28:59.107890 IP 192.168.1.114.35846 > 192.168.1.115.8888: sctp (1) [SHUTDOWN COMPLETE] Looks like this bug is from the pre-git history museum. ;) Fixes: 08707d5482df ("lksctp-2_5_31-0_5_1.patch") Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-16genetlink: synchronize socket closing and family removalJohannes Berg
In addition to the problem Jeff Layton reported, I looked at the code and reproduced the same warning by subscribing and removing the genl family with a socket still open. This is a fairly tricky race which originates in the fact that generic netlink allows the family to go away while sockets are still open - unlike regular netlink which has a module refcount for every open socket so in general this cannot be triggered. Trying to resolve this issue by the obvious locking isn't possible as it will result in deadlocks between unregistration and group unbind notification (which incidentally lockdep doesn't find due to the home grown locking in the netlink table.) To really resolve this, introduce a "closing socket" reference counter (for generic netlink only, as it's the only affected family) in the core netlink code and use that in generic netlink to wait for all the sockets that are being closed at the same time as a generic netlink family is removed. This fixes the race that when a socket is closed, it will should call the unbind, but if the family is removed at the same time the unbind will not find it, leading to the warning. The real problem though is that in this case the unbind could actually find a new family that is registered to have a multicast group with the same ID, and call its mcast_unbind() leading to confusing. Also remove the warning since it would still trigger, but is now no longer a problem. This also moves the code in af_netlink.c to before unreferencing the module to avoid having the same problem in the normal non-genl case. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-16genetlink: disallow subscribing to unknown mcast groupsJohannes Berg
Jeff Layton reported that he could trigger the multicast unbind warning in generic netlink using trinity. I originally thought it was a race condition between unregistering the generic netlink family and closing the socket, but there's a far simpler explanation: genetlink currently allows subscribing to groups that don't (yet) exist, and the warning is triggered when unsubscribing again while the group still doesn't exist. Originally, I had a warning in the subscribe case and accepted it out of userspace API concerns, but the warning was of course wrong and removed later. However, I now think that allowing userspace to subscribe to groups that don't exist is wrong and could possibly become a security problem: Consider a (new) genetlink family implementing a permission check in the mcast_bind() function similar to the like the audit code does today; it would be possible to bypass the permission check by guessing the ID and subscribing to the group it exists. This is only possible in case a family like that would be dynamically loaded, but it doesn't seem like a huge stretch, for example wireless may be loaded when you plug in a USB device. To avoid this reject such subscription attempts. If this ends up causing userspace issues we may need to add a workaround in af_netlink to deny such requests but not return an error. Reported-by: Jeff Layton <jeff.layton@primarydata.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-16net: rps: fix cpu unplugEric Dumazet
softnet_data.input_pkt_queue is protected by a spinlock that we must hold when transferring packets from victim queue to an active one. This is because other cpus could still be trying to enqueue packets into victim queue. A second problem is that when we transfert the NAPI poll_list from victim to current cpu, we absolutely need to special case the percpu backlog, because we do not want to add complex locking to protect process_queue : Only owner cpu is allowed to manipulate it, unless cpu is offline. Based on initial patch from Prasad Sodagudi & Subash Abhinov Kasiviswanathan. This version is better because we do not slow down packet processing, only make migration safer. Reported-by: Prasad Sodagudi <psodagud@codeaurora.org> Reported-by: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-15ip: zero sockaddr returned on error queueWillem de Bruijn
The sockaddr is returned in IP(V6)_RECVERR as part of errhdr. That structure is defined and allocated on the stack as struct { struct sock_extended_err ee; struct sockaddr_in(6) offender; } errhdr; The second part is only initialized for certain SO_EE_ORIGIN values. Always initialize it completely. An MTU exceeded error on a SOCK_RAW/IPPROTO_RAW is one example that would return uninitialized bytes. Signed-off-by: Willem de Bruijn <willemb@google.com> ---- Also verified that there is no padding between errhdr.ee and errhdr.offender that could leak additional kernel data. Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-15Merge tag 'mac80211-for-davem-2015-01-15' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211 Just two fixes - one for an uninialized variable and one for a deadlock in regulatory processing. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Don't use uninitialized data in IPVS, from Dan Carpenter. 2) conntrack race fixes from Pablo Neira Ayuso. 3) Fix TX hangs with i40e, from Jesse Brandeburg. 4) Fix budget return from poll calls in dnet and alx, from Eric Dumazet. 5) Fix bugus "if (unlikely(x) < 0)" test in AF_PACKET, from Christoph Jaeger. 6) Fix bug introduced by conversion to list_head in TIPC retransmit code, from Jon Paul Maloy. 7) Don't use GFP_NOIO under spinlock in USB kaweth driver, from Alexey Khoroshilov. 8) Fix bridge build with INET disabled, from Arnd Bergmann. 9) Fix netlink array overrun for PROBE attributes in openvswitch, from Thomas Graf. 10) Don't hold spinlock across synchronize_irq() in tg3 driver, from Prashant Sreedharan. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (44 commits) tg3: Release tp->lock before invoking synchronize_irq() tg3: tg3_reset_task() needs to use rtnl_lock to synchronize tg3: tg3_timer() should grab tp->lock before checking for tp->irq_sync team: avoid possible underflow of count_pending value for notify_peers and mcast_rejoin openvswitch: packet messages need their own probe attribtue i40e: adds FCoE configure option cxgb4vf: Fix queue allocation for 40G adapter netdevice: Add missing parentheses in macro bridge: only provide proxy ARP when CONFIG_INET is enabled neighbour: fix base_reachable_time(_ms) not effective immediatly when changed net: fec: fix MDIO bus assignement for dual fec SoC's xen-netfront: use different locks for Rx and Tx stats drivers: net: cpsw: fix multicast flush in dual emac mode cxgb4vf: Initialize mdio_addr before using it net: Corrected the comment describing the ndo operations to reflect the actual prototype for couple of operations usb/kaweth: use GFP_ATOMIC under spin_lock in usb_start_wait_urb() MAINTAINERS: add me as ibmveth maintainer tipc: fix bug in broadcast retransmit code update ip-sysctl.txt documentation (v2) net/at91_ether: prepare and unprepare clock ...
