commit a8659597bf744b0f8d2560e2a734b5c941569e0e upstream
pid doesn't count with some band having more bitrates than the one
associated the first time.
Fix that by counting the maximal available bitrate count and allocate
big enough space.
Secondly, fix touching uninitialized memory which causes panics.
Index sucked from this random memory points to the hell.
The fix is to sort the rates on each band change.
Also remove a comment which is wrong now.
This version also contains half of
mac80211: avoid NULL ptr deref when finding max_rates in PID and minstrel
patch by John W. Linville, which is namely:
- if (sband->n_bitrates > max_rates)
+ if (sband && sband->n_bitrates > max_rates)
to fix oopses on one band devices.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Cc: John W. Linville <linville@tuxdriver.com>
[ Upstream commit 86bcebafc5e7f5163ccf828792fe694b112ed6fa ]
A long-standing feature in tcp_init_metrics() is such that
any of its goto reset prevents call to tcp_init_cwnd().
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
[ Upstream commit 995b337952cdf7e05d288eede580257b632a8343 ]
When called with a consumed value that is less than skb_headlen(skb)
bytes into a page frag, skb_seq_read() incorrectly returns an
offset/length relative to skb->data. Ensure that data which should come
from a page frag does.
Signed-off-by: Thomas Chenault <thomas_chenault@dell.com>
Tested-by: Shyam Iyer <shyam_iyer@dell.com>
[ Upstream commit 5b5f792a6a9a2f9ae812d151ed621f72e99b1725 ]
typo -- pkt_dev->nflows is for stats only, the number of concurrent
flows is stored in cflows.
Reported-By: Vladimir Ivashchenko <hazard@francoudi.com>
upstream commit: 1f9352ae2253a97b07b34dcf16ffa3b4ca12c558
Commit e1b4b9f ([NETFILTER]: {ip,ip6,arp}_tables: fix exponential worst-case
search for loops) introduced a regression in the loop detection algorithm,
causing sporadic incorrectly detected loops.
When a chain has already been visited during the check, it is treated as
having a standard target containing a RETURN verdict directly at the
beginning in order to not check it again. The real target of the first
rule is then incorrectly treated as STANDARD target and checked not to
contain invalid verdicts.
Fix by making sure the rule does actually contain a standard target.
Based on patch by Francis Dupont <Francis_Dupont@isc.org>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
upstream commit: cc29c70dd581f85ee7a3e7980fb031f90b90a2ab
Patch "af_rose/x25: Sanity check the maximum user frame size"
(commit 83e0bbcbe2145f160fbaa109b0439dae7f4a38a9) from Alan Cox got
locking wrong. If we bail out due to user frame size being too large,
we must unlock the socket beforehand.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
upstream commit: 83e0bbcbe2145f160fbaa109b0439dae7f4a38a9
CVE-2009-0795.
Otherwise we can wrap the sizes and end up sending garbage.
Closes #10423
Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
[ Upstream commit cb0dc77de0d23615a845e45844a2e22fc224d7fe ]
broken by commit 5e739d1752aca4e8f3e794d431503bfca3162df4; AFAICS should
be -stable fodder as well...
Aced-by: Vlad Yasevich <vladislav.yasevich@hp.com>
[ Upstream commit 534f81a5068799799e264fd162e9488a129f98d4 ]
This patch fixes an unaligned memory access in tcp_sack while reading
sequence numbers from TCP selective acknowledgement options. Prior to
applying this patch, upstream linux-2.6.27.20 was occasionally
generating messages like this on my sparc64 system:
[54678.532071] Kernel unaligned access at TPC[6b17d4] tcp_packet+0xcd4/0xd00
[ Upstream commit 71f6f6dfdf7c7a67462386d9ea05c1095a89c555 ]
Commit 778d80be52699596bf70e0eb0761cf5e1e46088d
(ipv6: Add disable_ipv6 sysctl to disable IPv6 operaion on specific interface)
seems to have introduced a leak of sk_buff's for ipv6 traffic,
at least in some configurations where idev is NULL, or when ipv6
is disabled via sysctl.
The problem is that if the first condition of the if-statement
returns non-NULL, it returns an skb with only one reference,
and when the other conditions apply, execution jumps to the "out"
label, which does not call kfree_skb for it.
To plug this leak, change to use the "drop" label instead.
(this relies on it being ok to call kfree_skb on NULL)
This also allows us to avoid calling rcu_read_unlock here,
and removes the only user of the "out" label.
Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
[ Upstream commit 3f53a38131a4e7a053c0aa060aba0411242fb6b9 ]
We already have a valid net in that place, but this is not just a
cleanup - the tw pointer can be NULL there sometimes, thus causing
an oops in NET_NS=y case.
The same place in ipv4 code already works correctly using existing
net, rather than tw's one.
The bug exists since 2.6.27.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
[ Upstream commit cda6d377ec6b2ee2e58d563d0bd7eb313e0165df ]
This fixes an crash when empty bond device is added to a bridge.
If an interface with invalid ethernet address (all zero) is added
to a bridge, then bridge code detects it when setting up the forward
databas entry. But the error unwind is broken, the bridge port object
can get freed twice: once when ref count went to zeo, and once by kfree.
Since object is never really accessible, just free it.
[ Upstream commit 92a0acce186cde8ead56c6915d9479773673ea1a ]
A long time ago we had bugs, primarily in TCP, where we would modify
skb->truesize (for TSO queue collapsing) in ways which would corrupt
the socket memory accounting.
skb_truesize_check() was added in order to try and catch this error
more systematically.
However this debugging check has morphed into a Frankenstein of sorts
and these days it does nothing other than catch false-positives.
[ Upstream commit 50fee1dec5d71b8a14c1b82f2f42e16adc227f8b ]
The fix for CVE-2009-0676 (upstream commit df0bca04) is incomplete. Note
that the same problem of leaking kernel memory will reappear if someone
on some architecture uses struct timeval with some internal padding (for
example tv_sec 64-bit and tv_usec 32-bit) --- then, you are going to
leak the padded bytes to userspace.
Signed-off-by: Eugene Teo <eugeneteo@kernel.sg>
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
[ Upstream commit 631339f1e544a4d39a63cfe6708c5bddcd5a2c48 ]
As GRE tries to call the update_pmtu function on skb->dst and
bridge supplies an skb->dst that has a NULL ops field, all is
not well.
This patch fixes this by giving the bridge device an ops field
with an update_pmtu function. For the moment I've left all
other fields blank but we can fill them in later should the
need arise.
Based on report and patch by Philip Craig.
[ Upstream commit 8b9d3728977760f6bd1317c4420890f73695354e ]
The trick in socket splicing where we try to convert the skb->data
into a page based reference using virt_to_page() does not work so
well.
The idea is to pass the virt_to_page() reference via the pipe
buffer, and refcount the buffer using a SKB reference.
But if we are splicing from a socket to a socket (via sendpage)
this doesn't work.
The from side processing will grab the page (and SKB) references.
The sendpage() calls will grab page references only, return, and
then the from side processing completes and drops the SKB ref.
The page based reference to skb->data is not enough to keep the
kmalloc() buffer backing it from being reused. Yet, that is
all that the socket send side has at this point.
This leads to data corruption if the skb->data buffer is reused
by SLAB before the send side socket actually gets the TX packet
out to the device.
The fix employed here is to simply allocate a page and copy the
skb->data bytes into that page.
This will hurt performance, but there is no clear way to fix this
properly without a copy at the present time, and it is important
to get rid of the data corruption.
With fixes from Herbert Xu.
Tested-by: Willy Tarreau <w@1wt.eu>
Foreseen-by: Changli Gao <xiaosuo@gmail.com>
Diagnosed-by: Willy Tarreau <w@1wt.eu>
Reported-by: Willy Tarreau <w@1wt.eu>
Fixed-by: Jens Axboe <jens.axboe@oracle.com>
Signed-off-by: Jarek Poplawski <jarkao2@gmail.com>
commit 013cd397532e5803a1625954a884d021653da720 upstream.
net/mac80211/debugfs_sta.c
The trailing zero was written to state[4], it's out of bounds.
Signed-off-by: Jianjun Kong <jianjun@zeuux.org>
This patch is basically a backport of
commit ee8a1a0a1a5817accd03ced7e7ffde3a4430f485 upstream
which was made after the big HID overhaul in 2.6.28.
Kernel 2.6.27 fails to handle quirks for the aluminum Apple Wireless
Keyboard because it is handled as USB device and not as Bluetooth
device. This patch expands 'hidp_blacklist' to make the kernel handle
the keyboard in the same way as the Apple wireless Mighty Mouse (also a
Bluetooth device).
Signed-off-by: Torsten Rausche <torsten@rausche.net>
Cc: Jan Scholz <Scholz@fias.uni-frankfurt.de>
Cc: Jiri Kosina <jkosina@suse.cz>
netfilter: xt_sctp: sctp chunk mapping doesn't work
Upstream commit: d4e2675a
When user tries to map all chunks given in argument, kernel
works on a copy of the chunkmap, but at the end it doesn't
check the copy, but the orginal one.
Signed-off-by: Qu Haoran <haoran.qu@6wind.com>
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
netfilter: fix tuple inversion for Node information request
Upstream commit: a51f42f3c
The patch fixes a typo in the inverse mapping of Node Information
request. Following draft-ietf-ipngwg-icmp-name-lookups-09, "Querier"
sends a type 139 (ICMPV6_NI_QUERY) packet to "Responder" which answer
with a type 140 (ICMPV6_NI_REPLY) packet.
Signed-off-by: Eric Leblond <eric@inl.fr>
[ Upstream commit 9fa5fdf291c9b58b1cb8b4bb2a0ee57efa21d635 ]
tcp_splice_data_recv has two lengths to consider: the len parameter it
gets from tcp_read_sock, which specifies the amount of data in the skb,
and rd_desc->count, which is the amount of data the splice caller still
wants. Currently it passes just the latter to skb_splice_bits, which then
splices min(rd_desc->count, skb->len - offset) bytes.
Most of the time this is fine, except when the skb contains urgent data.
In that case len goes only up to the urgent byte and is less than
skb->len - offset. By ignoring len tcp_splice_data_recv may a) splice
data tcp_read_sock told it not to, b) return to tcp_read_sock a value > len.
Now, tcp_read_sock doesn't handle used > len and leaves the socket in a
bad state (both sk_receive_queue and copied_seq are bad at that point)
resulting in duplicated data and corruption.
Fix by passing min(rd_desc->count, len) to skb_splice_bits.
Signed-off-by: Dimitris Michailidis <dm@chelsio.com>
Acked-by: Eric Dumazet <dada1@cosmosbay.com>
[ Upstream commit 33966dd0e2f68f26943cd9ee93ec6abbc6547a8e ]
As spotted by Willy Tarreau, current splice() from tcp socket to pipe is not
optimal. It processes at most one segment per call.
This results in low performance and very high overhead due to syscall rate
when splicing from interfaces which do not support LRO.
Willy provided a patch inside tcp_splice_read(), but a better fix
is to let tcp_read_sock() process as many segments as possible, so
that tcp_rcv_space_adjust() and tcp_cleanup_rbuf() are called less
often.
With this change, splice() behaves like tcp_recvmsg(), being able
to consume many skbs in one system call. With typical 1460 bytes
of payload per frame, that means splice(SPLICE_F_NONBLOCK) can return
16*1460 = 23360 bytes.
Signed-off-by: Willy Tarreau <w@1wt.eu>
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
[ Upstream commit 905db44087855e3c1709f538ecdc22fd149cadd8 ]
As the mmap handler gets called under mmap_sem, and we may grab
mmap_sem elsewhere under the socket lock to access user data, we
should avoid grabbing the socket lock in the mmap handler.
Since the only thing we care about in the mmap handler is for
pg_vec* to be invariant, i.e., to exclude packet_set_ring, we
can achieve this by simply using a new mutex.
Tested-by: Martin MOKREJŠ <mmokrejs@ribosome.natur.cuni.cz>
[ Upstream commit 71b3346d182355f19509fadb8fe45114a35cc499 ]
It oopsd for me in skb_seq_read. addr2line said it was
linux-2.6/net/core/skbuff.c:2228, which is this line:
while (st->frag_idx < skb_shinfo(st->cur_skb)->nr_frags) {
I added some printks in there and it looks like we hit this:
} else if (st->root_skb == st->cur_skb &&
skb_shinfo(st->root_skb)->frag_list) {
st->cur_skb = skb_shinfo(st->root_skb)->frag_list;
st->frag_idx = 0;
goto next_skb;
Actually I did some testing and added a few printks and found that the
st->cur_skb->data was 0 and hence the ptr used by iscsi_tcp was null.
This caused the kernel panic.
if (abs_offset < block_limit) {
- *data = st->cur_skb->data + abs_offset;
+ *data = st->cur_skb->data + (abs_offset - st->stepped_offset);
I enabled the debug_tcp and with a few printks found that the code did
not go to the next_skb label and could find that the sequence being
followed was this -
It hit this if condition -
if (st->cur_skb->next) {
st->cur_skb = st->cur_skb->next;
st->frag_idx = 0;
goto next_skb;
And so, now the st pointer is shifted to the next skb whereas actually
it should have hit the second else if first since the data is in the
frag_list.
goto next_skb;
Reversing the two conditions the attached patch fixes the issue for me
on top of Herbert's patches.
Signed-off-by: Shyam Iyer <shyam_iyer@dell.com>
[ Upstream commit 95e3b24cfb4ec0479d2c42f7a1780d68063a542a ]
The frag_list handling was broken in skb_seq_read:
1) We didn't add the stepped offset when looking at the head
are of fragments other than the first.
2) We didn't take the stepped offset away when setting the data
pointer in the head area.
3) The frag index wasn't reset.
This patch fixes both issues.
[ Upstream commit e408b8dcb5ce42243a902205005208e590f28454 ]
Commit 93821778def10ec1e69aa3ac10adee975dad4ff3 (udp: Fix rcv socket
locking) accidentally removed sk_drops increments for UDP IPV4
sockets.
This field can be used to detect incorrect sizing of socket receive
buffers.
[ Upstream commit 7b5e56f9d635643ad54f2f42e69ad16b80a2cff1 ]
The UDP header pointer assignment must happen after calling
pskb_may_pull(). As pskb_may_pull() can potentially alter the SKB
buffer.
This was exposted by running multicast traffic through the NIU driver,
as it won't prepull the protocol headers into the linear area on
receive.
Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk>
[ Upstream commit f9e6934502e46c363100245f137ddf0f4b1cb574 ]
packet_lookup_frames() fails to get user frame if current frame header
status contains extra flags.
This is due to the wrong assumption on the operators precedence during
frame status tests.
Fixed by forcing the right operators precedence order with explicit brackets.
Signed-off-by: Paolo Abeni <paolo.abeni@gmail.com>
Signed-off-by: Sebastiano Di Paola <sebastiano.dipaola@gmail.com>
[ Upstream commit df0bca049d01c0ee94afb7cd5dfd959541e6c8da ]
In function sock_getsockopt() located in net/core/sock.c, optval v.val
is not correctly initialized and directly returned in userland in case
we have SO_BSDCOMPAT option set.
This dummy code should trigger the bug:
int main(void)
unsigned char buf[4] = { 0, 0, 0, 0 };
int len;
int sock;
sock = socket(33, 2, 2);
getsockopt(sock, 1, SO_BSDCOMPAT, &buf, &len);
printf("%x%x%x%x\n", buf[0], buf[1], buf[2], buf[3]);
close(sock);
Here is a patch that fix this bug by initalizing v.val just after its
declaration.
Signed-off-by: Clément Lecigne <clement.lecigne@netasq.com>
[ Upstream commit 0178b695fd6b40a62a215cbeb03dd51ada3bb5e0 ]
As the options passed to ip6_append_data may be ephemeral, we need
to duplicate it for corking. This patch applies the simplest fix
which is to memdup all the relevant bits.
[ Upstream commit 684de409acff8b1fe8bf188d75ff2f99c624387d ]
Just like PKTINFO, limit the options area to 64K.
Based upon report by Eric Sesterhenn and analysis by
Roland Dreier.
[ Upstream commit 9d8dba6c979fa99c96938c869611b9a23b73efa9 ]
Signed-off-by: Benjamin Zores <benjamin.zores@alcatel-lucent.fr>
[ Upstream commit 759af00ebef858015eb68876ac1f383bcb6a1774 ]
Recent changes to the retransmit code exposed a long standing
bug where it was possible for a chunk to be time stamped
after the retransmit timer was reset. This caused a rare
situation where the retrnamist timer has expired, but
nothing was marked for retrnasmission because all of
timesamps on data were less then 1 rto ago. As result,
the timer was never restarted since nothing was retransmitted,
and this resulted in a hung association that did couldn't
complete the data transfer. The solution is to timestamp
the chunk when it's added to the packet for transmission
purposes. After the packet is trsnmitted the rtx timer
is restarted. This guarantees that when the timer expires,
there will be data to retransmit.
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
[ Upstream commit 6574df9a89f9f7da3a4e5cee7633d430319d3350 ]
Commit 62aeaff5ccd96462b7077046357a6d7886175a57
(sctp: Start T3-RTX timer when fast retransmitting lowest TSN)
introduced a regression where it was possible to forcibly
restart the sctp retransmit timer at the transmission of any
new chunk. This resulted in much longer timeout times and
sometimes hung sctp connections.
commit ae53b5bd77719fed58086c5be60ce4f22bffe1c6 upstream.
There is a race between sctp_rcv() and sctp_accept() where we
have moved the association from the listening socket to the
accepted socket, but sctp_rcv() processing cached the old
socket and continues to use it.
The easy solution is to check for the socket mismatch once we've
grabed the socket lock. If we hit a mis-match, that means
that were are currently holding the lock on the listening socket,
but the association is refrencing a newly accepted socket. We need
to drop the lock on the old socket and grab the lock on the new one.
A more proper solution might be to create accepted sockets when
the new association is established, similar to TCP. That would
eliminate the race for 1-to-1 style sockets, but it would still
existing for 1-to-many sockets where a user wished to peeloff an
association. For now, we'll live with this easy solution as
it addresses the problem.
Reported-by: Michal Hocko <mhocko@suse.cz>
Reported-by: Karsten Keil <kkeil@suse.de>
commit 2da2c21d7508d34bc6d600df665d84871b65d2b9 upstream.
The svc_addsock function adds transport instances without taking a
reference on the sunrpc.ko module, however, the generic transport
destruction code drops a reference when a transport instance
is destroyed.
Add a try_module_get call to the svc_addsock function for transport
instances added by this function.
Signed-off-by: Tom Tucker <tom@opengridcomputing.com>
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
Tested-by: Jeff Moyer <jmoyer@redhat.com>
Cc: Neil Brown <neilb@suse.de>
commit 9b22ea560957de1484e6b3e8538f7eef202e3596 upstream.
The changes to deliver hardware accelerated VLAN packets to packet
sockets (commit bc1d0411) caused a warning for non-NAPI drivers.
The __vlan_hwaccel_rx() function is called directly from the drivers
RX function, for non-NAPI drivers that means its still in RX IRQ
context:
[ 27.779463] ------------[ cut here ]------------
[ 27.779509] WARNING: at kernel/softirq.c:136 local_bh_enable+0x37/0x81()
[ 27.782520] [<c0264755>] netif_nit_deliver+0x5b/0x75
[ 27.782590] [<c02bba83>] __vlan_hwaccel_rx+0x79/0x162
[ 27.782664] [<f8851c1d>] atl1_intr+0x9a9/0xa7c [atl1]
[ 27.782738] [<c0155b17>] handle_IRQ_event+0x23/0x51
[ 27.782808] [<c015692e>] handle_edge_irq+0xc2/0x102
[ 27.782878] [<c0105fd5>] do_IRQ+0x4d/0x64
Split hardware accelerated VLAN reception into two parts to fix this:
- __vlan_hwaccel_rx just stores the VLAN TCI and performs the VLAN
device lookup, then calls netif_receive_skb()/netif_rx()
- vlan_hwaccel_do_receive(), which is invoked by netif_receive_skb()
in softirq context, performs the real reception and delivery to
packet sockets.
Reported-and-tested-by: Ramon Casellas <ramon.casellas@cttc.es>
Cc: Jesse Brandeburg <jesse.brandeburg@intel.com>
commit 9a4bd29fe8f6d3f015fe1c8e5450eb62cfebfcc9 upstream.
Despite the fact that cloned rpc clients won't have the cl_autobind flag
set, they may still find themselves calling rpcb_getport_async(). For this
to happen, it suffices for a _parent_ rpc_clnt to use autobinding, in which
case any clone may find itself triggering the !xprt_bound() case in
call_bind().
The correct fix for this is to walk back up the tree of cloned rpc clients,
in order to find the parent that 'owns' the transport, either because it
has clnt->cl_autobind set, or because it originally created the
transport...
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 96165e2b7c4e2c82a0b60c766d4a2036444c21a0 upstream.
commit 5dc306f3bd1d4cfdf79df39221b3036eab1ddcf3 upstream.
After launching mesh discovery in tx path, reference count was not being
decremented. This was preventing module unload.
Signed-off-by: Brian Cavagnolo <brian@cozybit.com>
Signed-off-by: Andrey Yurovsky <andrey@cozybit.com>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
[ Upstream commit: 4f7d54f59bc470f0aaa932f747a95232d7ebf8b1 ]
Currently, setting SPLICE_F_NONBLOCK on splice from a TCP socket
results in masking of EOF (RDHUP) and error conditions on the socket
by an -EAGAIN return. Move the NONBLOCK check in tcp_splice_read()
to be after the EOF and error checks to fix this.
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
[ Upstream commit: 6f57321422e0d359e83c978c2b03db77b967b7d5 ]
New nodes are inserted in u32_change() under rtnl_lock() with wmb(),
so without tcf_tree_lock() like in other classifiers (e.g. cls_fw).
This isn't enough without rmb() on the read side, but on the other
hand adding such barriers doesn't give any savings, so the lock is
added instead.
Reported-by: m0sia <m0sia@plotinka.ru>
[ Upstream commit: 9fcb95a105758b81ef0131cd18e2db5149f13e95 ]
If FWD-TSN chunk is received with bad stream ID, the sctp will not do the
validity check, this may cause memory overflow when overwrite the TSN of
the stream ID.
The FORWARD-TSN chunk is like this:
FORWARD-TSN chunk
Type = 192
Flags = 0
Length = 172
NewTSN = 99
Stream = 10000
StreamSequence = 0xFFFF
This patch fix this problem by discard the chunk if stream ID is not
less than MIS.
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
[ Upstream commit: 7891cc818967e186be68caac32d84bfd0a3f0bd2 ]
When a fib6 table dump is prematurely ended, we won't unlink
its walker from the list. This causes all sorts of grief for
other users of the list later.
Reported-by: Chris Caputo <ccaputo@alt.net>
[ Upstream commit: none
This is a quick fix for -stable purposes. Upstream fixes these
problems via a large set of invasive hrtimer changes. ]
Most probably there is a (still unproven) race in hrtimers (before
2.6.29 kernels), which causes a corruption of hrtimers rbtree. This
patch doesn't fix it, but should let HTB avoid triggering the bug.
Reported-by: Denys Fedoryschenko <denys@visp.net.lb>
Reported-by: Badalian Vyacheslav <slavon@bigtelecom.ru>
Tested-by: Badalian Vyacheslav <slavon@bigtelecom.ru>
commit 3e0fa65f8ba4fd24b3dcfaf14d5b15eaab0fdc61 upstream.
commit 20f37034fb966a1c35894f9fe529fda0b6440101 upstream.
commit 754fe8d297bfae7b77f7ce866e2fb0c5fb186506 upstream.
commit 23918b03060f6e572168fdde1798a905679d2e06 upstream.
Fix a regression reported by Max Kellermann whereby kernel profiling
showed that his clients were spending 45% of their time in
rpcauth_lookup_credcache.
It turns out that although his processes had identical uid/gid/groups,
generic_match() was failing to detect this, because the task->group_info
pointers were not shared. This again lead to the creation of a huge number
of identical credentials at the RPC layer.
The regression is fixed by comparing the contents of task->group_info
if the actual pointers are not identical.
commit 920da6923cf03c8a78fbaffa408f8ab37f6abfc1 upstream.
Steps to reproduce:
#/usr/sbin/setkey -f
flush;
spdflush;
add 192.168.0.42 192.168.0.1 ah 24500 -A hmac-md5 "1234567890123456";
add 192.168.0.42 192.168.0.1 esp 24501 -E 3des-cbc "123456789012123456789012";
spdadd 192.168.0.42 192.168.0.1 any -P out ipsec
esp/transport//require
ah/transport//require;
setkey: invalid keymsg length
Policy dump will bail out with the same message after that.
-recv(4, "\2\16\0\0\32\0\3\0\0\0\0\0\37\r\0\0\3\0\5\0\377 \0\0\2\0\0\0\300\250\0*\0"..., 32768, 0) = 208
+recv(4, "\2\16\0\0\36\0\3\0\0\0\0\0H\t\0\0\3\0\5\0\377 \0\0\2\0\0\0\300\250\0*\0"..., 32768, 0) = 208
Cc: Kadianakis George <desnacked@gmail.com>
