Prevents filters from being added if the first generated
handle already exists.
Signed-off-by: Kim Nordlund <kim.nordlund@nokia.com>
Signed-off-by: Thomas Graf <tgraf@suug.ch>
In clip_mkip(), skb->dev is dereferenced after clip_push(),
which frees up skb.
Advisory: AD_LAB-06009 (<adlab@venustech.com.cn>).
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
This patch fixes RTNLGRP_IPV6_IFINFO netlink notifications. Issue
pointed out by Patrick McHardy <kaber@trash.net>.
Acked-by: Patrick McHardy <kaber@trash.net>
Mirror the bug fix from fill_packet_ipv4()
Signed-off-by: Chen-Li Tien <cltien@gmail.com>
Bug noticed by Remi Denis-Courmont <rdenis@simphalempin.com>.
With the recent fix, the callers of sctp_primitive_ABORT()
need to create an ABORT chunk and pass it as an argument rather
than msghdr that was passed earlier.
Adrian Bunk:
Ported to 2.6.16.
Signed-off-by: Sridhar Samudrala <sri@us.ibm.com>
The function pointers which were checked were for their get_* counterparts.
Typically a copy-paste typo.
Signed-off-by: Willy Tarreau <w@1wt.eu>
Acked-by: Jeff Garzik <jeff@garzik.org>
Acked-by: David Miller <davem@davemloft.net>
The function ethtool_get_ufo was referring to ETHTOOL_GTSO instead of
ETHTOOL_GUFO.
Acked-by: Matthew Wilcox <matthew@wil.cx>
table->private might change because of ruleset changes, don't use it without
holding the lock.
Fix kernel panic on various SMP machines. The culprit is a null
ub->skb in ulog_send(). If ulog_timer() has already been scheduled on
one CPU and is spinning on the lock, and ipt_ulog_packet() flushes the
queue on another CPU by calling ulog_send() right before it exits,
there will be no skbuff when ulog_timer() acquires the lock and calls
ulog_send(). Cancelling the timer in ulog_send() doesn't help because
it has already been scheduled and is running on the first CPU.
Similar problem exists in ebt_ulog.c and nfnetlink_log.c.
Signed-off-by: Mark Huang <mlhuang@cs.princeton.edu>
Right now, every time we increase our rwnd by more then MTU bytes, we
trigger a SACK. When processing large messages, this will generate a
SACK for almost every other SCTP fragment. However since we are freeing
the entire message at the same time, we might as well collapse the SACK
generation to 1.
Signed-off-by: Tsutomu Fujii <t-fujii@nb.jp.nec.com>
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
When using ASSOCINFO socket option, we need to limit the number of
maximum association retransmissions to be no greater than the sum
of all the path retransmissions. This is specified in Section 7.1.2
of the SCTP socket API draft.
However, we only do this if the association has multiple paths. If
there is only one path, the protocol stack will use the
assoc_max_retrans setting when trying to retransmit packets.
In the event that our entire receive buffer is full with a series of
chunks that represent a single gap-ack, and then we accept a chunk
(or chunks) that fill in the gap between the ctsn and the first gap,
we renege chunks from the end of the buffer, which effectively does
nothing but move our gap to the end of our received tsn stream. This
does little but move our missing tsns down stream a little, and, if the
sender is sending sufficiently large retransmit frames, the result is a
perpetual slowdown which can never be recovered from, since the only
chunk that can be accepted to allow progress in the tsn stream necessitates
that a new gap be created to make room for it. This leads to a constant
need for retransmits, and subsequent receiver stalls. The fix I've come up
with is to deliver the frame without reneging if we have a full receive
buffer and the receiving sockets sk_receive_queue is empty(indicating that
the receive buffer is being blocked by a missing tsn).
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Make SCTP handle broadcast properly
sctp_make_abort_user() now takes the msg_len along with the msg
so that we don't have to recalculate the bytes in iovec.
It also uses memcpy_fromiovec() so that we don't go beyond the
length allocated.
It is good to have this fix even if verify_iovec() is fixed to
return error on overflow.
ieee80211_crypt_tkip will not work without CRC32.
LD .tmp_vmlinux1
net/built-in.o: In function `ieee80211_tkip_encrypt':
net/ieee80211/ieee80211_crypt_tkip.c:349: undefined reference to `crc32_le'
Reported by Toralf Foerster <toralf.foerster@gmx.de>
Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com>
CONFIG_IPV6_PRIVACY
We need to update hiscore.rule even if we don't enable CONFIG_IPV6_PRIVACY,
because we have more less significant rule; longest match.
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Two additional labels (RFC 3484, sec. 10.3) for IPv6 addreses
are defined to make a distinction between global unicast
addresses and Unique Local Addresses (fc00::/7, RFC 4193) and
Teredo (2001::/32, RFC 4380). It is necessary to avoid attempts
of connection that would either fail (eg. fec0:: to 2001:feed::)
or be sub-optimal (2001:0:: to 2001:feed::).
Signed-off-by: $,1 aukasz Stelmach <stlman@poczta.fm>
chunks [CVE-2006-2934]
When a packet without any chunks is received, the newconntrack variable
in sctp_packet contains an out of bounds value that is used to look up an
pointer from the array of timeouts, which is then dereferenced, resulting
in a crash. Make sure at least a single chunk is present.
Problem noticed by George A. Theall <theall@tenablesecurity.com>
Fix endless loop in the SCTP match similar to those already fixed in the
SCTP conntrack helper (was CVE-2006-1527).
It appears that sockaddr_in.sin_zero is not zeroed during
getsockopt(...SO_ORIGINAL_DST...) operation. This can lead
to an information leak (CVE-2006-1343).
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
CVE-2006-2444 - Potential remote DoS in SNMP NAT helper.
Fix memory corruption caused by snmp_trap_decode:
- When snmp_trap_decode fails before the id and address are allocated,
the pointers contain random memory, but are freed by the caller
(snmp_parse_mangle).
- When snmp_trap_decode fails after allocating just the ID, it tries
to free both address and ID, but the address pointer still contains
random memory. The caller frees both ID and random memory again.
- When snmp_trap_decode fails after allocating both, it frees both,
and the callers frees both again.
The corruption can be triggered remotely when the ip_nat_snmp_basic
module is loaded and traffic on port 161 or 162 is NATed.
Found by multiple testcases of the trap-app and trap-enc groups of the
PROTOS c06-snmpv1 testsuite.
If SCTP receives a badly formatted HB-ACK chunk, it is possible
that we may access invalid memory and potentially have a buffer
overflow. We should really make sure that the chunk format is
what we expect, before attempting to touch the data.
(CVE-2006-0039)
Solar Designer found a race condition in do_add_counters(). The beginning
of paddc is supposed to be the same as tmp which was sanity-checked
above, but it might not be the same in reality. In case the integer
overflow and/or the race condition are triggered, paddc->num_counters
might not match the allocation size for paddc. If the check below
(t->private->number != paddc->num_counters) nevertheless passes (perhaps
this requires the race condition to be triggered), IPT_ENTRY_ITERATE()
would read kernel memory beyond the allocation size, potentially causing
an oops or leaking sensitive data (e.g., passwords from host system or
from another VPS) via counter increments. This requires CAP_NET_ADMIN.
https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=191698
Cc: Solar Designer <solar@openwall.com>
Cc: Kirill Korotaev <dev@sw.ru>
Cc: Patrick McHardy <kaber@trash.net>
(chrisw: rebase of Kirill's patch to 2.6.16.16)
DATA. (CVE-2006-2274)
There is a rare situation that causes lksctp to go into infinite recursion
and crash the system. The trigger is a packet that contains at least the
first two DATA fragments of a message bundled together. The recursion is
triggered when the user data buffer is smaller that the full data message.
The problem is that we clone the skb for every fragment in the message.
When reassembling the full message, we try to link skbs from the "first
fragment" clone using the frag_list. However, since the frag_list is shared
between two clones in this rare situation, we end up setting the frag_list
pointer of the second fragment to point to itself. This causes
sctp_skb_pull() to potentially recurse indefinitely.
Proposed solution is to make a copy of the skb when attempting to link
things using frag_list.
Signed-off-by: Vladislav Yasevich <vladsilav.yasevich@hp.com>
(CVE-2006-2275)
This patch fixes a deadlock situation in the receive path by allowing
temporary spillover of the receive buffer.
- If the chunk we receive has a tsn that immediately follows the ctsn,
accept it even if we run out of receive buffer space and renege data with
higher TSNs.
- Once we accept one chunk in a packet, accept all the remaining chunks
even if we run out of receive buffer space.
Acked-by: Mark Butler <butlerm@middle.net>
Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com>
(CVE-2006-2271)
Discard an unexpected chunk in CLOSED state rather can calling BUG().
(CVE-2006-2272)
Use pskb_pull() to handle incoming COOKIE_ECHO and HEARTBEAT chunks that
are received as skb's with fragment list.
[NETFILTER]: SCTP conntrack: fix infinite loop
fix infinite loop in the SCTP-netfilter code: check SCTP chunk size to
guarantee progress of for_each_sctp_chunk(). (all other uses of
for_each_sctp_chunk() are preceded by do_basic_checks(), so this fix
should be complete.)
Based on patch from Ingo Molnar <mingo@elte.hu>
[IPV6] XFRM: Fix decoding session with preceding extension header(s).
We did not correctly decode session with preceding extension
header(s). This was because we had already pulled preceding
headers, skb->nh.raw + 40 + 1 - skb->data was minus, and
pskb_may_pull() failed.
We now have IP6CB(skb)->nhoff and skb->h.raw, and we can
start parsing / decoding upper layer protocol from current
position.
Tracked down by Noriaki TAKAMIYA <takamiya@po.ntts.co.jp>
and tested by Kazunori Miyazawa <kazunori@miyazawa.org>.
[IPV6] XFRM: Don't use old copy of pointer after pskb_may_pull().
[IPV6]: Ensure to have hop-by-hop options in our header of &sk_buff.
On Sun, 9 Apr 2006 21:56:59 +0400,
Sergey Vlasov <vsu@altlinux.ru> wrote:
> However, show_address() does not output anything unless
> dev->reg_state == NETREG_REGISTERED - and this state is set by
> netdev_run_todo() only after netdev_register_sysfs() returns, so in
> the meantime (while netdev_register_sysfs() is busy adding the
> "statistics" attribute group) some process may see an empty "address"
> attribute.
I've tried the attached patch, suggested by Sergey Vlasov on
hotplug-devel@, and as far as i can test it works just fine.
Signed-off-by: Alexander Patrakov <patrakov@ums.usu.ru>
Signed-off-by: David Miller <davem@davemloft.net>
[TCP]: Fix truesize underflow
There is a problem with the TSO packet trimming code. The cause of
this lies in the tcp_fragment() function.
When we allocate a fragment for a completely non-linear packet the
truesize is calculated for a payload length of zero. This means that
truesize could in fact be less than the real payload length.
When that happens the TSO packet trimming can cause truesize to become
negative. This in turn can cause sk_forward_alloc to be -n * PAGE_SIZE
which would trigger the warning.
I've copied the code DaveM used in tso_fragment which should work here.
This fixes http://bugzilla.kernel.org/show_bug.cgi?id=6388
The bug is caused by ip_route_input dereferencing skb->nh.protocol of
the dummy skb passed dow from inet_rtm_getroute (Thanks Thomas for seeing
it). It only happens if the route requested is for a multicast IP
address.
Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
If Classical IP over ATM module is loaded, its neighbor table gets
populated when permanent neighbor entries are created; but these entries
are not flushed when the device is removed. Since the entry never gets
flushed the unregister of the network device never completes.
This version of the patch also adds locking around the reference to
the atm arp daemon to avoid races with events and daemon state changes.
(Note: barrier() was never really safe)
Bug-reference: http://bugzilla.kernel.org/show_bug.cgi?id=6295
[NETFILTER]: Fix fragmentation issues with bridge netfilter
The conntrack code doesn't do re-fragmentation of defragmented packets
anymore but relies on fragmentation in the IP layer. Purely bridged
packets don't pass through the IP layer, so the bridge netfilter code
needs to take care of fragmentation itself.
Please apply to 2.6.{14,15,16} -stable, thanks a lot.
[FIB_TRIE]: Fix leaf freeing.
Seems like leaf (end-nodes) has been freed by __tnode_free_rcu and not
by __leaf_free_rcu. This fixes the problem. Only tnode_free is now
used which checks for appropriate node type. free_leaf can be removed.
Signed-off-by: Robert Olsson <robert.olsson@its.uu.se>
[NETFILTER]: {ip,nf}_conntrack_netlink: fix expectation notifier unregistration
This patch fixes expectation notifier unregistration on module unload to
use ip_conntrack_expect_unregister_notifier(). This bug causes a soft
lockup at the first expectation created after a rmmod ; insmod of this
module.
Should go into -stable as well.
Signed-off-by: Martin Josefsson <gandalf@wlug.westbo.se>
The user can pass us arbitrary garbage so we should ensure the
string they give us is null terminated before we pass it on
to dev_get_by_index() et al.
Found by Solar Designer.
(CVE-2006-1242)
The problem is in ip_push_pending_frames(), which uses:
if (!df) {
__ip_select_ident(iph, &rt->u.dst, 0);
} else {
iph->id = htons(inet->id++);
instead of ip_select_ident().
Right now I think the code is a nonsense. Most likely, I copied it from
old ip_build_xmit(), where it was really special, we had to decide
whether to generate unique ID when generating the first (well, the last)
fragment.
In ip_push_pending_frames() it does not make sense, it should use plain
ip_select_ident() instead.
Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
If the AX.25 dialect chosen by the sysadmin is set to DAMA master / 3
(or DAMA slave / 2, if CONFIG_AX25_DAMA_SLAVE=n) ax25_kick() will fall
through the switch statement without calling ax25_send_iframe() or any
other function that would eventually free skbn thus leaking the packet.
Fix by restricting the sysctl inferface to allow only actually supported
AX.25 dialects.
The system administration mistake needed for this to happen is rather
unlikely, so this is an uncritical hole.
Coverity #651.
Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org>
Fix QoS is not active even the network and the card is QOS enabled.
The problem is we pass the wrong ieee80211_network address to
ipw_handle_beacon/ipw_handle_probe_response, thus the
ieee80211_network->qos_data.active will not be set, causing the driver
not sending QoS frames at all.
Signed-off-by: Hong Liu <hong.liu@intel.com>
Signed-off-by: Zhu Yi <yi.zhu@intel.com>
Use the correct STYPE for Qos data.
In rpc_wake_up() and rpc_wake_up_status(), it is possible for the call to
__rpc_wake_up_task() to fail if another thread happens to be calling
rpc_wake_up_task() on the same rpc_task.
Problem noticed by Bruno Faccini.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
The Coverity checker spotted this possible NULL pointer dereference in
rpc_new_client().
When we link a socket into the hash table, we need to make sure that we
set the num/port fields so that it shows us with a non-zero port value
in proc/netlink and on the wire. This code and comment is copied over
from the IPv4 stack as is.
The check is wrong and lets NULL-ptrs slip through since !IS_ERR(NULL)
is true.
Coverity #190
