path: root/net
2011-12-21mac80211: fix race condition caused by late addBA responseNikolay Martynov
Upstream commit d305a6557b2c4dca0110f05ffe745b1ef94adb80. If addBA responses comes in just after addba_resp_timer has expired mac80211 will still accept it and try to open the aggregation session. This causes drivers to be confused and in some cases even crash. This patch fixes the race condition and makes sure that if addba_resp_timer has expired addBA response is not longer accepted and we do not try to open half-closed session. Signed-off-by: Nikolay Martynov <mar.kolya@gmail.com> [some adjustments] Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09cfg80211: amend regulatory NULL dereference fixLuis R. Rodriguez
commit 0bac71af6e66dc798bf07d0c0dd14ee5503362f9 upstream. Johannes' patch for "cfg80211: fix regulatory NULL dereference" broke user regulaotry hints and it did not address the fact that last_request was left populated even if the previous regulatory hint was stale due to the wiphy disappearing. Fix user reguluatory hints by only bailing out if for those regulatory hints where a request_wiphy is expected. The stale last_request considerations are addressed through the previous fixes on last_request where we reset the last_request to a static world regdom request upon reset_regdomains(). In this case though we further enhance the effect by simply restoring reguluatory settings completely. Cc: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09cfg80211: fix race on init and driver registrationLuis R. Rodriguez
commit a042994dd377d86bff9446ee76151ceb6267c9ba upstream. There is a theoretical race that if hit will trigger a crash. The race is between when we issue the first regulatory hint, regulatory_hint_core(), gets processed by the workqueue and between when the first device gets registered to the wireless core. This is not easy to reproduce but it was easy to do so through the regulatory simulator I have been working on. This is a port of the fix I implemented there [1]. [1] https://github.com/mcgrof/regsim/commit/a246ccf81f059cb662eee288aa13100f631e4cc8 Cc: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09mac80211: fix race between the AGG SM and the Tx data pathEmmanuel Grumbach
commit 2a1e0fd175dcfd72096ba9291d31e3b1b5342e60 upstream. When a packet is supposed to sent be as an a-MPDU, mac80211 sets IEEE80211_TX_CTL_AMPDU to let the driver know. On the other hand, mac80211 configures the driver for aggregration with the ampdu_action callback. There is race between these two mechanisms since the following scenario can occur when the BA agreement is torn down: Tx softIRQ drv configuration ========== ================= check OPERATIONAL bit Set the TX_CTL_AMPDU bit in the packet clear OPERATIONAL bit stop Tx AGG Pass Tx packet to the driver. In that case the driver would get a packet with TX_CTL_AMPDU set although it has already been notified that the BA session has been torn down. To fix this, we need to synchronize all the Qdisc activity after we cleared the OPERATIONAL bit. After that step, all the following packets will be buffered until the driver reports it is ready to get new packets for this RA / TID. This buffering allows not to run into another race that would send packets with TX_CTL_AMPDU unset while the driver hasn't been requested to tear down the BA session yet. This race occurs in practice and iwlwifi complains with a WARN_ON when it happens. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09mac80211: don't stop a single aggregation session twiceJohannes Berg
commit 24f50a9d165745fd0701c6e089d35f58a229ea69 upstream. Nikolay noticed (by code review) that mac80211 can attempt to stop an aggregation session while it is already being stopped. So to fix it, check whether stop is already being done and bail out if so. Also move setting the STOPPING state into the lock so things are properly atomic. Reported-by: Nikolay Martynov <mar.kolya@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09cfg80211: fix regulatory NULL dereferenceJohannes Berg
commit de3584bd62d87b4c250129fbc46ca52c80330add upstream. By the time userspace returns with a response to the regulatory domain request, the wiphy causing the request might have gone away. If this is so, reject the update but mark the request as having been processed anyway. Cc: Luis R. Rodriguez <lrodriguez@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09nl80211: fix MAC address validationEliad Peller
commit e007b857e88097c96c45620bf3b04a4e309053d1 upstream. MAC addresses have a fixed length. The current policy allows passing < ETH_ALEN bytes, which might result in reading beyond the buffer. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09SUNRPC: Ensure we return EAGAIN in xs_nospace if congestion is clearedTrond Myklebust
commit 24ca9a847791fd53d9b217330b15f3c285827a18 upstream. By returning '0' instead of 'EAGAIN' when the tests in xs_nospace() fail to find evidence of socket congestion, we are making the RPC engine believe that the message was incorrectly sent and so it disconnects the socket instead of just retrying. The bug appears to have been introduced by commit 5e3771ce2d6a69e10fcc870cdf226d121d868491 (SUNRPC: Ensure that xs_nospace return values are propagated). Reported-by: Andrew Cooper <andrew.cooper3@citrix.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Tested-by: Andrew Cooper <andrew.cooper3@citrix.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26ip6_tunnel: copy parms.name after register_netdeviceJosh Boyer
commit 731abb9cb27aef6013ce60808a04e04a545f3f4e upstream. Commit 1c5cae815d removed an explicit call to dev_alloc_name in ip6_tnl_create because register_netdevice will now create a valid name. This works for the net_device itself. However the tunnel keeps a copy of the name in the parms structure for the ip6_tnl associated with the tunnel. parms.name is set by copying the net_device name in ip6_tnl_dev_init_gen. That function is called from ip6_tnl_dev_init in ip6_tnl_create, but it is done before register_netdevice is called so the name is set to a bogus value in the parms.name structure. This shows up if you do a simple tunnel add, followed by a tunnel show: [root@localhost ~]# ip -6 tunnel add remote fec0::100 local fec0::200 [root@localhost ~]# ip -6 tunnel show ip6tnl0: ipv6/ipv6 remote :: local :: encaplimit 0 hoplimit 0 tclass 0x00 flowlabel 0x00000 (flowinfo 0x00000000) ip6tnl%d: ipv6/ipv6 remote fec0::100 local fec0::200 encaplimit 4 hoplimit 64 tclass 0x00 flowlabel 0x00000 (flowinfo 0x00000000) [root@localhost ~]# Fix this by moving the strcpy out of ip6_tnl_dev_init_gen, and calling it after register_netdevice has successfully returned. Signed-off-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26cfg80211: fix bug on regulatory core exit on access to last_requestLuis R. Rodriguez
commit 58ebacc66bd11be2327edcefc79de94bd6f5bb4a upstream. Commit 4d9d88d1 by Scott James Remnant <keybuk@google.com> added the .uevent() callback for the regulatory device used during the platform device registration. The change was done to account for queuing up udev change requests through udevadm triggers. The change also meant that upon regulatory core exit we will now send a uevent() but the uevent() callback, reg_device_uevent(), also accessed last_request. Right before commiting device suicide we free'd last_request but never set it to NULL so platform_device_unregister() would lead to bogus kernel paging request. Fix this and also simply supress uevents right before we commit suicide as they are pointless. This fix is required for kernels >= v2.6.39 $ git describe --contains 4d9d88d1 v2.6.39-rc1~468^2~25^2^2~21 The impact of not having this present is that a bogus paging access may occur (only read) upon cfg80211 unload time. You may also get this BUG complaint below. Although Johannes could not reproduce the issue this fix is theoretically correct. mac80211_hwsim: unregister radios mac80211_hwsim: closing netlink BUG: unable to handle kernel paging request at ffff88001a06b5ab IP: [<ffffffffa030df9a>] reg_device_uevent+0x1a/0x50 [cfg80211] PGD 1836063 PUD 183a063 PMD 1ffcb067 PTE 1a06b160 Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC CPU 0 Modules linked in: cfg80211(-) [last unloaded: mac80211] Pid: 2279, comm: rmmod Tainted: G W 3.1.0-wl+ #663 Bochs Bochs RIP: 0010:[<ffffffffa030df9a>] [<ffffffffa030df9a>] reg_device_uevent+0x1a/0x50 [cfg80211] RSP: 0000:ffff88001c5f9d58 EFLAGS: 00010286 RAX: 0000000000000000 RBX: ffff88001d2eda88 RCX: ffff88001c7468fc RDX: ffff88001a06b5a0 RSI: ffff88001c7467b0 RDI: ffff88001c7467b0 RBP: ffff88001c5f9d58 R08: 000000000000ffff R09: 000000000000ffff R10: 0000000000000000 R11: 0000000000000001 R12: ffff88001c7467b0 R13: ffff88001d2eda78 R14: ffffffff8164a840 R15: 0000000000000001 FS: 00007f8a91d8a6e0(0000) GS:ffff88001fc00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: ffff88001a06b5ab CR3: 000000001c62e000 CR4: 00000000000006f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process rmmod (pid: 2279, threadinfo ffff88001c5f8000, task ffff88000023c780) Stack: ffff88001c5f9d98 ffffffff812ff7e5 ffffffff8176ab3d ffff88001c7468c2 000000000000ffff ffff88001d2eda88 ffff88001c7467b0 ffff880000114820 ffff88001c5f9e38 ffffffff81241dc7 ffff88001c5f9db8 ffffffff81040189 Call Trace: [<ffffffff812ff7e5>] dev_uevent+0xc5/0x170 [<ffffffff81241dc7>] kobject_uevent_env+0x1f7/0x490 [<ffffffff81040189>] ? sub_preempt_count+0x29/0x60 [<ffffffff814cab1a>] ? _raw_spin_unlock_irqrestore+0x4a/0x90 [<ffffffff81305307>] ? devres_release_all+0x27/0x60 [<ffffffff8124206b>] kobject_uevent+0xb/0x10 [<ffffffff812fee27>] device_del+0x157/0x1b0 [<ffffffff8130377d>] platform_device_del+0x1d/0x90 [<ffffffff81303b76>] platform_device_unregister+0x16/0x30 [<ffffffffa030fffd>] regulatory_exit+0x5d/0x180 [cfg80211] [<ffffffffa032bec3>] cfg80211_exit+0x2b/0x45 [cfg80211] [<ffffffff8109a84c>] sys_delete_module+0x16c/0x220 [<ffffffff8108a23e>] ? trace_hardirqs_on_caller+0x7e/0x120 [<ffffffff814cba02>] system_call_fastpath+0x16/0x1b Code: <all your base are belong to me> RIP [<ffffffffa030df9a>] reg_device_uevent+0x1a/0x50 [cfg80211] RSP <ffff88001c5f9d58> CR2: ffff88001a06b5ab ---[ end trace 147c5099a411e8c0 ]--- Reported-by: Johannes Berg <johannes@sipsolutions.net> Cc: Scott James Remnant <keybuk@google.com> Signed-off-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26nl80211: fix HT capability attribute validationJohannes Berg
commit 6c7394197af90f6a332180e33f5d025d3037d883 upstream. Since the NL80211_ATTR_HT_CAPABILITY attribute is used as a struct, it needs a minimum, not maximum length. Enforce that properly. Not doing so could potentially lead to reading after the buffer. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26mac80211: fix bug in ieee80211_build_probe_reqJohannes Berg
commit 5b2bbf75a24d6b06afff6de0eb4819413fd81971 upstream. ieee80211_probereq_get() can return NULL in which case we should clean up & return NULL in ieee80211_build_probe_req() as well. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-26mac80211: fix NULL dereference in radiotap codeJohannes Berg
commit f8d1ccf15568268c76f913b45ecdd33134387f1a upstream. When receiving failed PLCP frames is enabled, there won't be a rate pointer when we add the radiotap header and thus the kernel will crash. Fix this by not assuming the rate pointer is always valid. It's still always valid for frames that have good PLCP though, and that is checked & enforced. This was broken by my commit fc88518916793af8ad6a02e05ff254d95c36d875 Author: Johannes Berg <johannes.berg@intel.com> Date: Fri Jul 30 13:23:12 2010 +0200 mac80211: don't check rates on PLCP error frames where I removed the check in this case but didn't take into account that the rate info would be used. Reported-by: Xiaokang Qin <xiaokang.qin@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11net: Handle different key sizes between address families in flow cachedpward
commit aa1c366e4febc7f5c2b84958a2dd7cd70e28f9d0 upstream. With the conversion of struct flowi to a union of AF-specific structs, some operations on the flow cache need to account for the exact size of the key. Signed-off-by: David Ward <david.ward@ll.mit.edu> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11mac80211: disable powersave for broken APsJohannes Berg
commit 05cb91085760ca378f28fc274fbf77fc4fd9886c upstream. Only AID values 1-2007 are valid, but some APs have been found to send random bogus values, in the reported case an AP that was sending the AID field value 0xffff, an AID of 0x3fff (16383). There isn't much we can do but disable powersave since there's no way it can work properly in this case. Reported-by: Bill C Riemers <briemers@redhat.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11mac80211: config hw when going back on-channelEliad Peller
commit 6911bf0453e0d6ea8eb694a4ce67a68d071c538e upstream. When going back on-channel, we should reconfigure the hw iff the hardware is not already configured to the operational channel. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11mac80211: fix remain_off_channel regressionEliad Peller
commit eaa7af2ae582c9a8c51b374c48d5970b748a5ce2 upstream. The offchannel code is currently broken - we should remain_off_channel if the work was started, and the work's channel and channel_type are the same as local->tmp_channel and local->tmp_channel_type. However, if wk->chan_type and local->tmp_channel_type coexist (e.g. have the same channel type), we won't remain_off_channel. This behavior was introduced by commit da2fd1f ("mac80211: Allow work items to use existing channel type.") Tested-by: Ben Greear <greearb@candelatech.com> Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11NFS/sunrpc: don't use a credential with extra groups.NeilBrown
commit dc6f55e9f8dac4b6479be67c5c9128ad37bb491f upstream. The sunrpc layer keeps a cache of recently used credentials and 'unx_match' is used to find the credential which matches the current process. However unx_match allows a match when the cached credential has extra groups at the end of uc_gids list which are not in the process group list. So if a process with a list of (say) 4 group accesses a file and gains access because of the last group in the list, then another process with the same uid and gid, and a gid list being the first tree of the gids of the original process tries to access the file, it will be granted access even though it shouldn't as the wrong rpc credential will be used. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11net: Unlock sock before calling sk_free()Thomas Gleixner
[ Upstream commit b0691c8ee7c28a72748ff32e91b165ec12ae4de6 ] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11bridge: leave carrier on for empty bridgestephen hemminger
[ Upstream commit b64b73d7d0c480f75684519c6134e79d50c1b341 ] This resolves a regression seen by some users of bridging. Some users use the bridge like a dummy device. They expect to be able to put an IPv6 address on the device with no ports attached. Although there are better ways of doing this, there is no reason to not allow it. Note: the bridge still will reflect the state of ports in the bridge if there are any added. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11can bcm: fix incomplete tx_setup fixOliver Hartkopp
commit 12d0d0d3a7349daa95dbfd5d7df8146255bc7c67 upstream. The commit aabdcb0b553b9c9547b1a506b34d55a764745870 ("can bcm: fix tx_setup off-by-one errors") fixed only a part of the original problem reported by Andre Naujoks. It turned out that the original code needed to be re-ordered to reduce complexity and to finally fix the reported frame counting issues. Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11make PACKET_STATISTICS getsockopt report consistently between ring and non-ringWillem de Bruijn
[ Upstream commit 7091fbd82cd5686444ffe9935ed6a8190101fe9d ] This is a minor change. Up until kernel 2.6.32, getsockopt(fd, SOL_PACKET, PACKET_STATISTICS, ...) would return total and dropped packets since its last invocation. The introduction of socket queue overflow reporting [1] changed drop rate calculation in the normal packet socket path, but not when using a packet ring. As a result, the getsockopt now returns different statistics depending on the reception method used. With a ring, it still returns the count since the last call, as counts are incremented in tpacket_rcv and reset in getsockopt. Without a ring, it returns 0 if no drops occurred since the last getsockopt and the total drops over the lifespan of the socket otherwise. The culprit is this line in packet_rcv, executed on a drop: drop_n_acct: po->stats.tp_drops = atomic_inc_return(&sk->sk_drops); As it shows, the new drop number it taken from the socket drop counter, which is not reset at getsockopt. I put together a small example that demonstrates the issue [2]. It runs for 10 seconds and overflows the queue/ring on every odd second. The reported drop rates are: ring: 16, 0, 16, 0, 16, ... non-ring: 0, 15, 0, 30, 0, 46, 0, 60, 0 , 74. Note how the even ring counts monotonically increase. Because the getsockopt adds tp_drops to tp_packets, total counts are similarly reported cumulatively. Long story short, reinstating the original code, as the below patch does, fixes the issue at the cost of additional per-packet cycles. Another solution that does not introduce per-packet overhead is be to keep the current data path, record the value of sk_drops at getsockopt() at call N in a new field in struct packetsock and subtract that when reporting at call N+1. I'll be happy to code that, instead, it's just more messy. [1] http://patchwork.ozlabs.org/patch/35665/ [2] http://kernel.googlecode.com/files/test-packetsock-getstatistics.c Signed-off-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11ipv6: nullify ipv6_ac_list and ipv6_fl_list when creating new socketYan, Zheng
[ Upstream commit 676a1184e8afd4fed7948232df1ff91517400859 ] ipv6_ac_list and ipv6_fl_list from listening socket are inadvertently shared with new socket created for connection. Signed-off-by: Zheng Yan <zheng.z.yan@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11tcp: properly update lost_cnt_hint during shiftingYan, Zheng
[ Upstream commit 1e5289e121372a3494402b1b131b41bfe1cf9b7f ] lost_skb_hint is used by tcp_mark_head_lost() to mark the first unhandled skb. lost_cnt_hint is the number of packets or sacked packets before the lost_skb_hint; When shifting a skb that is before the lost_skb_hint, if tcp_is_fack() is ture, the skb has already been counted in the lost_cnt_hint; if tcp_is_fack() is false, tcp_sacktag_one() will increase the lost_cnt_hint. So tcp_shifted_skb() does not need to adjust the lost_cnt_hint by itself. When shifting a skb that is equal to lost_skb_hint, the shifted packets will not be counted by tcp_mark_head_lost(). So tcp_shifted_skb() should adjust the lost_cnt_hint even tcp_is_fack(tp) is true. Signed-off-by: Zheng Yan <zheng.z.yan@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11tcp: properly handle md5sig_pool referencesYan, Zheng
[ Upstream commit 260fcbeb1ae9e768a44c9925338fbacb0d7e5ba9 ] tcp_v4_clear_md5_list() assumes that multiple tcp md5sig peers only hold one reference to md5sig_pool. but tcp_v4_md5_do_add() increases use count of md5sig_pool for each peer. This patch makes tcp_v4_md5_do_add() only increases use count for the first tcp md5sig peer. Signed-off-by: Zheng Yan <zheng.z.yan@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11l2tp: fix a potential skb leak in l2tp_xmit_skb()Eric Dumazet
[ Upstream commit 835acf5da239b91edb9f7ebe36516999e156e6ee ] l2tp_xmit_skb() can leak one skb if skb_cow_head() returns an error. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11ipv4: fix ipsec forward performance regressionYan, Zheng
[ Upstream commit b73233960a59ee66e09d642f13d0592b13651e94 ] There is bug in commit 5e2b61f(ipv4: Remove flowi from struct rtable). It makes xfrm4_fill_dst() modify wrong data structure. Signed-off-by: Zheng Yan <zheng.z.yan@intel.com> Reported-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11can bcm: fix tx_setup off-by-one errorsOliver Hartkopp
[ Upstream commit aabdcb0b553b9c9547b1a506b34d55a764745870 ] This patch fixes two off-by-one errors that canceled each other out. Checking for the same condition two times in bcm_tx_timeout_tsklet() reduced the count of frames to be sent by one. This did not show up the first time tx_setup is invoked as an additional frame is sent due to TX_ANNONCE. Invoking a second tx_setup on the same item led to a reduced (by 1) number of sent frames. Reported-by: Andre Naujoks <nautsch@gmail.com> Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11bridge: fix hang on removal of bridge via netlinkstephen hemminger
[ Upstream commit 1ce5cce895309862d2c35d922816adebe094fe4a ] Need to cleanup bridge device timers and ports when being bridge device is being removed via netlink. This fixes the problem of observed when doing: ip link add br0 type bridge ip link set dev eth1 master br0 ip link set br0 up ip link del br0 which would cause br0 to hang in unregister_netdev because of leftover reference count. Reported-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11net: hold sock reference while processing tx timestampsRichard Cochran
commit da92b194cc36b5dc1fbd85206aeeffd80bee0c39 upstream. The pair of functions, * skb_clone_tx_timestamp() * skb_complete_tx_timestamp() were designed to allow timestamping in PHY devices. The first function, called during the MAC driver's hard_xmit method, identifies PTP protocol packets, clones them, and gives them to the PHY device driver. The PHY driver may hold onto the packet and deliver it at a later time using the second function, which adds the packet to the socket's error queue. As pointed out by Johannes, nothing prevents the socket from disappearing while the cloned packet is sitting in the PHY driver awaiting a timestamp. This patch fixes the issue by taking a reference on the socket for each such packet. In addition, the comments regarding the usage of these function are expanded to highlight the rule that PHY drivers must use skb_complete_tx_timestamp() to release the packet, in order to release the socket reference, too. These functions first appeared in v2.6.36. Reported-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Richard Cochran <richard.cochran@omicron.at> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11mac80211: fix offchannel TX cookie matchingJohannes Berg
commit 28a1bcdb57d50f3038a255741ecc83e391e5282e upstream. When I introduced in-kernel off-channel TX I introduced a bug -- the work can't be canceled again because the code clear the skb pointer. Fix this by keeping track separately of whether TX status has already been reported. Reported-by: Jouni Malinen <j@w1.fi> Tested-by: Jouni Malinen <j@w1.fi> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11rtnetlink: Add missing manual netlink notification in dev_change_net_namespacesEric W. Biederman
commit d2237d35748e7f448a9c2d9dc6a85ef637466e24 upstream. Renato Westphal noticed that since commit a2835763e130c343ace5320c20d33c281e7097b7 "rtnetlink: handle rtnl_link netlink notifications manually" was merged we no longer send a netlink message when a networking device is moved from one network namespace to another. Fix this by adding the missing manual notification in dev_change_net_namespaces. Since all network devices that are processed by dev_change_net_namspaces are in the initialized state the complicated tests that guard the manual rtmsg_ifinfo calls in rollback_registered and register_netdevice are unnecessary and we can just perform a plain notification. Tested-by: Renato Westphal <renatowestphal@gmail.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11caif: Fix BUG() with network namespacesDavid Woodhouse
commit 08613e4626c06ca408fc55071f6aedee36986a87 upstream. The caif code will register its own pernet_operations, and then register a netdevice_notifier. Each time the netdevice_notifier is triggered, it'll do some stuff... including a lookup of its own pernet stuff with net_generic(). If the net_generic() call ever returns NULL, the caif code will BUG(). That doesn't seem *so* unreasonable, I suppose — it does seem like it should never happen. However, it *does* happen. When we clone a network namespace, setup_net() runs through all the pernet_operations one at a time. It gets to loopback before it gets to caif. And loopback_net_init() registers a netdevice... while caif hasn't been initialised. So the caif netdevice notifier triggers, and immediately goes BUG(). We could imagine a complex and overengineered solution to this generic class of problems, but this patch takes the simple approach. It just makes caif_device_notify() *not* go looking for its pernet data structures if the device it's being notified about isn't a caif device in the first place. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Acked-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-25x25: Prevent skb overreads when checking call user dataMatthew Daley
commit 7f81e25befdfb3272345a2e775f520e1d515fa20 upstream. x25_find_listener does not check that the amount of call user data given in the skb is big enough in per-socket comparisons, hence buffer overreads may occur. Fix this by adding a check. Signed-off-by: Matthew Daley <mattjd@gmail.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Andrew Hendry <andrew.hendry@gmail.com> Acked-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-16ipv6: fix NULL dereference in udp6_ufo_fragment()Jason Wang
This patch fixes the issue caused by ef81bb40bf15f350fe865f31fa42f1082772a576 which is a backport of upstream 87c48fa3b4630905f98268dde838ee43626a060c. The problem does not exist in upstream. We do not check whether route is attached before trying to assign ip identification through route dest which lead NULL pointer dereference. This happens when host bridge transmit a packet from guest. This patch changes ipv6_select_ident() to accept in6_addr as its paramter and fix the issue by using the destination address in ipv6 header when no route is attached. Signed-off-by: Jason Wang <jasowang@redhat.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03cfg80211: Fix validation of AKM suitesJouni Malinen
commit 1b9ca0272ffae212e726380f66777b30a56ed7a5 upstream. Incorrect variable was used in validating the akm_suites array from NL80211_ATTR_AKM_SUITES. In addition, there was no explicit validation of the array length (we only have room for NL80211_MAX_NR_AKM_SUITES). This can result in a buffer write overflow for stack variables with arbitrary data from user space. The nl80211 commands using the affected functionality require GENL_ADMIN_PERM, so this is only exposed to admin users. Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03Bluetooth: Fix timeout on scanning for the second timeOliver Neukum
commit 2d20a26a92f72e3bb658fe8ce99c3663756e9e7a upstream. The checks for HCI_INQUIRY and HCI_MGMT were in the wrong order, so that second scans always failed. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03bridge: fix a possible use after freeEric Dumazet
[ Upstream commit 22df13319d1fec30b8f9bcaadc295829647109bb ] br_multicast_ipv6_rcv() can call pskb_trim_rcsum() and therefore skb head can be reallocated. Cache icmp6_type field instead of dereferencing twice the struct icmp6hdr pointer. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03bridge: Pseudo-header required for the checksum of ICMPv6Yan, Zheng
[ Upstream commit 4b275d7efa1c4412f0d572fcd7f78ed0919370b3 ] Checksum of ICMPv6 is not properly computed because the pseudo header is not used. Thus, the MLD packet gets dropped by the bridge. Signed-off-by: Zheng Yan <zheng.z.yan@intel.com> Reported-by: Ang Way Chuang <wcang@sfc.wide.ad.jp> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03xfrm: Perform a replay check after return from async codepathsSteffen Klassert
[ Upstream commit bcf66bf54aabffc150acd1c99e0f4bc51935eada ] When asyncronous crypto algorithms are used, there might be many packets that passed the xfrm replay check, but the replay advance function is not called yet for these packets. So the replay check function would accept a replay of all of these packets. Also the system might crash if there are more packets in async processing than the size of the anti replay window, because the replay advance function would try to update the replay window beyond the bounds. This pach adds a second replay check after resuming from the async processing to fix these issues. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03vlan: reset headers on accel emulation pathJiri Pirko
[ Upstream commit c5114cd59d2664f258b0d021d79b1532d94bdc2b ] It's after all necessary to do reset headers here. The reason is we cannot depend that it gets reseted in __netif_receive_skb once skb is reinjected. For incoming vlanids without vlan_dev, vlan_do_receive() returns false with skb != NULL and __netif_reveive_skb continues, skb is not reinjected. This might be good material for 3.0-stable as well Reported-by: Mike Auty <mike.auty@gmail.com> Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03tcp: initialize variable ecn_ok in syncookies pathMike Waychison
[ Upstream commit f0e3d0689da401f7d1981c2777a714ba295ea5ff ] Using a gcc 4.4.3, warnings are emitted for a possibly uninitialized use of ecn_ok. This can happen if cookie_check_timestamp() returns due to not having seen a timestamp. Defaulting to ecn off seems like a reasonable thing to do in this case, so initialized ecn_ok to false. Signed-off-by: Mike Waychison <mikew@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03tcp: fix validation of D-SACKZheng Yan
[ Upstream commit f779b2d60ab95c17f1e025778ed0df3ec2f05d75 ] D-SACK is allowed to reside below snd_una. But the corresponding check in tcp_is_sackblock_valid() is the exact opposite. It looks like a typo. Signed-off-by: Zheng Yan <zheng.z.yan@intel.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03scm: Capture the full credentials of the scm senderTim Chen
[ Upstream commit e33f7a9f37d486f4c6cce5de18a6eea11d68f64f ] This patch corrects an erroneous update of credential's gid with uid introduced in commit 257b5358b32f17 since 2.6.36. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Reviewed-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03net_sched: prio: use qdisc_dequeue_peekedFlorian Westphal
[ Upstream commit 3557619f0f6f7496ed453d4825e24958ab1884e0 ] commit 07bd8df5df4369487812bf85a237322ff3569b77 (sch_sfq: fix peek() implementation) changed sfq to use generic peek helper. This makes HFSC complain about a non-work-conserving child qdisc, if prio with sfq child is used within hfsc: hfsc peeks into prio qdisc, which will then peek into sfq. returned skb is stashed in sch->gso_skb. Next, hfsc tries to dequeue from prio, but prio will call sfq dequeue directly, which may return NULL instead of previously peeked-at skb. Have prio call qdisc_dequeue_peeked, so sfq->dequeue() is not called in this case. Cc: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03netfilter: TCP and raw fix for ip_route_me_harderJulian Anastasov
[ Upstream commit 797fd3913abf2f7036003ab8d3d019cbea41affd ] TCP in some cases uses different global (raw) socket to send RST and ACK. The transparent flag is not set there. Currently, it is a problem for rerouting after the previous change. Fix it by simplifying the checks in ip_route_me_harder and use FLOWI_FLAG_ANYSRC even for sockets. It looks safe because the initial routing allowed this source address to be used and now we just have to make sure the packet is rerouted. As a side effect this also allows rerouting for normal raw sockets that use spoofed source addresses which was not possible even before we eliminated the ip_route_input call. Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03mcast: Fix source address selection for multicast listener reportYan, Zheng
[ Upstream commit e05c4ad3ed874ee4f5e2c969e55d318ec654332c ] Should check use count of include mode filter instead of total number of include mode filters. Signed-off-by: Zheng Yan <zheng.z.yan@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03ipv6: Fix ipv6_getsockopt for IPV6_2292PKTOPTIONSDaniel Baluta
[ Upstream commit 98e77438aed3cd3343cbb86825127b1d9d2bea33 ] IPV6_2292PKTOPTIONS is broken for 32-bit applications running in COMPAT mode on 64-bit kernels. The same problem was fixed for IPv4 with the patch: ipv4: Fix ip_getsockopt for IP_PKTOPTIONS, commit dd23198e58cd35259dd09e8892bbdb90f1d57748 Signed-off-by: Sorin Dumitru <sdumitru@ixiacom.com> Signed-off-by: Daniel Baluta <dbaluta@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03ipv4: some rt_iif -> rt_route_iif conversionsJulian Anastasov
[ Upstream commit 97a804102021431fa6fa33c21c85df762b0f5cb9 ] As rt_iif represents input device even for packets coming from loopback with output route, it is not an unique key specific to input routes. Now rt_route_iif has such role, it was fl.iif in 2.6.38, so better to change the checks at some places to save CPU cycles and to restore 2.6.38 semantics. compare_keys: - input routes: only rt_route_iif matters, rt_iif is same - output routes: only rt_oif matters, rt_iif is not used for matching in __ip_route_output_key - now we are back to 2.6.38 state ip_route_input_common: - matching rt_route_iif implies input route - compared to 2.6.38 we eliminated one rth->fl.oif check because it was not needed even for 2.6.38 compare_hash_inputs: Only the change here is not an optimization, it has effect only for output routes. I assume I'm restoring the original intention to ignore oif, it was using fl.iif - now we are back to 2.6.38 state Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03fib:fix BUG_ON in fib_nl_newrule when add new fib ruleGao feng
[ Upstream commit 561dac2d410ffac0b57a23b85ae0a623c1a076ca ] add new fib rule can cause BUG_ON happen the reproduce shell is ip rule add pref 38 ip rule add pref 38 ip rule add to 192.168.3.0/24 goto 38 ip rule del pref 38 ip rule add to 192.168.3.0/24 goto 38 ip rule add pref 38 then the BUG_ON will happen del BUG_ON and use (ctarget == NULL) identify whether this rule is unresolved Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
