Upstream commit 71320af:
An old bug crept back into the ICMP/ICMPv6 conntrack protocols: the timeout
values are defined as unsigned longs, the sysctl's maxsize is set to
sizeof(unsigned int). Use unsigned int for the timeout values as in the
other conntrack protocols.
Reported-by: Jean-Mickael Guerin <jean-mickael.guerin@6wind.com>
Upstream commit d61ba9f:
Commit 8cc784ee (netfilter: change return types of match functions
for ebtables extensions) broke ebtables matches by inverting the
sense of match/nomatch.
Reported-by: Matt Cross <matthltc@us.ibm.com>
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
Upstream commit 656caff:
Commit 55b69e91 (netfilter: implement NFPROTO_UNSPEC as a wildcard
for extensions) broke revision probing for matches and targets that
are registered with NFPROTO_UNSPEC.
Fix by continuing the search on the NFPROTO_UNSPEC list if nothing
is found on the af-specific lists.
[ Upstream commit: 4f7d54f59bc470f0aaa932f747a95232d7ebf8b1 ]
Currently, setting SPLICE_F_NONBLOCK on splice from a TCP socket
results in masking of EOF (RDHUP) and error conditions on the socket
by an -EAGAIN return. Move the NONBLOCK check in tcp_splice_read()
to be after the EOF and error checks to fix this.
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
[ Upstream commit: 6f57321422e0d359e83c978c2b03db77b967b7d5 ]
New nodes are inserted in u32_change() under rtnl_lock() with wmb(),
so without tcf_tree_lock() like in other classifiers (e.g. cls_fw).
This isn't enough without rmb() on the read side, but on the other
hand adding such barriers doesn't give any savings, so the lock is
added instead.
Reported-by: m0sia <m0sia@plotinka.ru>
Signed-off-by: Jarek Poplawski <jarkao2@gmail.com>
[ Upstream commit: 9fcb95a105758b81ef0131cd18e2db5149f13e95 ]
If FWD-TSN chunk is received with bad stream ID, the sctp will not do the
validity check, this may cause memory overflow when overwrite the TSN of
the stream ID.
The FORWARD-TSN chunk is like this:
FORWARD-TSN chunk
Type = 192
Flags = 0
Length = 172
NewTSN = 99
Stream = 10000
StreamSequence = 0xFFFF
This patch fix this problem by discard the chunk if stream ID is not
less than MIS.
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
[ Upstream commit: 7891cc818967e186be68caac32d84bfd0a3f0bd2 ]
When a fib6 table dump is prematurely ended, we won't unlink
its walker from the list. This causes all sorts of grief for
other users of the list later.
Reported-by: Chris Caputo <ccaputo@alt.net>
[ Upstream commit: none
This is a quick fix for -stable purposes. Upstream fixes these
problems via a large set of invasive hrtimer changes. ]
Most probably there is a (still unproven) race in hrtimers (before
2.6.29 kernels), which causes a corruption of hrtimers rbtree. This
patch doesn't fix it, but should let HTB avoid triggering the bug.
Reported-by: Denys Fedoryschenko <denys@visp.net.lb>
Reported-by: Badalian Vyacheslav <slavon@bigtelecom.ru>
Tested-by: Badalian Vyacheslav <slavon@bigtelecom.ru>
commit 3e0fa65f8ba4fd24b3dcfaf14d5b15eaab0fdc61 upstream.
commit 20f37034fb966a1c35894f9fe529fda0b6440101 upstream.
commit 754fe8d297bfae7b77f7ce866e2fb0c5fb186506 upstream.
The kernel_accept() does not hold the module refcount of newsock->ops->owner,
so we need __module_get(newsock->ops->owner) code after call kernel_accept()
by hand.
In sunrpc, the module refcount is missing to hold. So this cause kernel panic.
Used following script to reproduct:
while [ 1 ];
do
mount -t nfs4 192.168.0.19:/ /mnt
touch /mnt/file
umount /mnt
lsmod | grep ipv6
done
This patch fixed the problem by add __module_get(newsock->ops->owner) to
kernel_accept(). So we do not need to used __module_get(newsock->ops->owner)
in every place when used kernel_accept().
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
Phonet: keep TX queue disabled when the device is off
SCHED: netem: Correct documentation comment in code.
netfilter: update rwlock initialization for nat_table
netlabel: Compiler warning and NULL pointer dereference fix
e1000e: fix double release of mutex
IA64: HP_SIMETH needs to depend upon NET
netpoll: fix race on poll_list resulting in garbage entry
ipv6: silence log messages for locally generated multicast
sungem: improve ethtool output with internal pcs and serdes
tcp: tcp_vegas cong avoid fix
sungem: Make PCS PHY support partially work again.
Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com>
The netem simulator is no longer limited by Linux timer resolution HZ.
Not since Patrick McHardy changed the QoS system to use hrtimer.
Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk>
The commit e099a173573ce1ba171092aee7bb3c72ea686e59
(netfilter: netns nat: per-netns NAT table) renamed the
nat_table from __nat_table to nat_table without updating the
__RW_LOCK_UNLOCKED(__nat_table.lock).
Signed-off-by: Steven Rostedt <srostedt@redhat.com>
Fix the two compiler warnings show below. Thanks to Geert Uytterhoeven for
finding and reporting the problem.
net/netlabel/netlabel_unlabeled.c:567: warning: 'entry' may be used
uninitialized in this function
net/netlabel/netlabel_unlabeled.c:629: warning: 'entry' may be used
Signed-off-by: Paul Moore <paul.moore@hp.com>
A few months back a race was discused between the netpoll napi service
path, and the fast path through net_rx_action:
http://kerneltrap.org/mailarchive/linux-netdev/2007/10/16/345470
A patch was submitted for that bug, but I think we missed a case.
Consider the following scenario:
INITIAL STATE
CPU0 has one napi_struct A on its poll_list
CPU1 is calling netpoll_send_skb and needs to call poll_napi on the same
napi_struct A that CPU0 has on its list
CPU0 CPU1
net_rx_action poll_napi
!list_empty (returns true) locks poll_lock for A
poll_one_napi
napi->poll
netif_rx_complete
__napi_complete
(removes A from poll_list)
list_entry(list->next)
In the above scenario, net_rx_action assumes that the per-cpu poll_list is
exclusive to that cpu. netpoll of course violates that, and because the netpoll
path can dequeue from the poll list, its possible for CPU0 to detect a non-empty
list at the top of the while loop in net_rx_action, but have it become empty by
the time it calls list_entry. Since the poll_list isn't surrounded by any other
structure, the returned data from that list_entry call in this situation is
garbage, and any number of crashes can result based on what exactly that garbage
is.
Given that its not fasible for performance reasons to place exclusive locks
arround each cpus poll list to provide that mutal exclusion, I think the best
solution is modify the netpoll path in such a way that we continue to guarantee
that the poll_list for a cpu is in fact exclusive to that cpu. To do this I've
implemented the patch below. It adds an additional bit to the state field in
the napi_struct. When executing napi->poll from the netpoll_path, this bit will
be set. When a driver calls netif_rx_complete, if that bit is set, it will not
remove the napi_struct from the poll_list. That work will be saved for the next
iteration of net_rx_action.
I've tested this and it seems to work well. About the biggest drawback I can
see to it is the fact that it might result in an extra loop through
net_rx_action in the event that the device is actually contended for (i.e. the
netpoll path actually preforms all the needed work no the device, and the call
to net_rx_action winds up doing nothing, except removing the napi_struct from
the poll_list. However I think this is probably a small price to pay, given
that the alternative is a crash.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
This patch fixes minor annoyance during transmission of unsolicited
neighbor advertisements from userspace to multicast addresses (as
far as I can see in RFC, this is allowed and the similar functionality
for IPv4 has been in arping for a long time).
Outgoing multicast packets get reinserted into local processing as if they
are received from the network. The machine thus sees its own NA and fills
the logs with error messages. This patch removes the message if NA has been
generated locally.
Signed-off-by: Jan Sembera <jsembera@suse.cz>
This patch addresses a book-keeping issue in tcp_vegas.c. At present
tcp_vegas does separate book-keeping of cwnd based on packet sequence
numbers. A mismatch can develop between this book-keeping and
tp->snd_cwnd due, for example, to delayed acks acking multiple
packets. When vegas transitions to reno operation (e.g. following
loss), then this mismatch leads to incorrect behaviour (akin to a cwnd
backoff). This seems mostly to affect operation at low cwnds where
delayed acking can lead to a significant fraction of cwnd being
covered by a single ack, leading to the book-keeping mismatch. This
patch modifies the congestion avoidance update to avoid the need for
separate book-keeping while leaving vegas congestion avoidance
functionally unchanged. A secondary advantage of this modification is
that the use of fixed-point (via V_PARAM_SHIFT) and 64 bit arithmetic
is no longer necessary, simplifying the code.
Some example test measurements with the patched code (confirming no functional
change in the congestion avoidance algorithm) can be seen at:
http://www.hamilton.ie/doug/vegaspatch/
Signed-off-by: Doug Leith <doug.leith@nuim.ie>
tproxy: fixe a possible read from an invalid location in the socket match
zd1211rw: use unaligned safe memcmp() in-place of compare_ether_addr()
mac80211: use unaligned safe memcmp() in-place of compare_ether_addr()
ipw2200: fix netif_*_queue() removal regression
iwlwifi: clean key table in iwl_clear_stations_table function
tcp: tcp_vegas ssthresh bug fix
can: omit received RTR frames for single ID filter lists
ATM: CVE-2008-5079: duplicate listen() on socket corrupts the vcc table
netx-eth: initialize per device spinlock
tcp: make urg+gso work for real this time
enc28j60: Fix sporadic packet loss (corrected again)
hysdn: fix writing outside the field on 64 bits
b1isa: fix b1isa_exit() to really remove registered capi controllers
can: Fix CAN_(EFF|RTR)_FLAG handling in can_filter
Phonet: do not dump addresses from other namespaces
netlabel: Fix a potential NULL pointer dereference
bnx2: Add workaround to handle missed MSI.
xfrm: Fix kernel panic when flush and dump SPD entries
TIME_WAIT sockets need to be handled specially, and the socket match
casted inet_timewait_sock instances to inet_sock, which are not
compatible.
Handle this special case by checking sk->sk_state.
Signed-off-by: Balazs Scheidler <bazsi@balabit.hu>
After fixing zd1211rw: use unaligned safe memcmp() in-place of
compare_ether_addr(), I started to see kernel log messages detailing
unaligned access:
Kernel unaligned access at TPC[100f7f44] sta_info_get+0x24/0x68 [mac80211]
As with the aforementioned patch, the unaligned access was eminating
from a compare_ether_addr() call. Concerned that whilst it was safe to
assume that unalignment was the norm for the zd1211rw, and take
preventative measures, it may not be the case or acceptable to use the
easy fix of changing the call to memcmp().
My research however indicated that it was OK to do this, as there are
a few instances where memcmp() is the preferred mechanism for doing
mac address comparisons throughout the module.
Signed-off-by: Shaddy Baddah <shaddy_baddah@hotmail.com>
This patch fixes a bug in tcp_vegas.c. At the moment this code leaves
ssthresh untouched. However, this means that the vegas congestion
control algorithm is effectively unable to reduce cwnd below the
ssthresh value (if the vegas update lowers the cwnd below ssthresh,
then slow start is activated to raise it back up). One example where
this matters is when during slow start cwnd overshoots the link
capacity and a flow then exits slow start with ssthresh set to a value
above where congestion avoidance would like to adjust it.
Since commit d253eee20195b25e298bf162a6e72f14bf4803e5 the single CAN
identifier filter lists handle only non-RTR CAN frames.
So we need to omit the check of these filter lists when receiving RTR
CAN frames.
Signed-off-by: Oliver Hartkopp <oliver@hartkopp.net>
As reported by Hugo Dias that it is possible to cause a local denial
of service attack by calling the svc_listen function twice on the same
socket and reading /proc/net/atm/*vc
Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil>
I should have noticed this earlier... :-) The previous solution
to URG+GSO/TSO will cause SACK block tcp_fragment to do zig-zig
patterns, or even worse, a steep downward slope into packet
counting because each skb pcount would be truncated to pcount
of 2 and then the following fragments of the later portion would
restore the window again.
Basically this reverts "tcp: Do not use TSO/GSO when there is
urgent data" (33cf71cee1). It also removes some unnecessary code
from tcp_current_mss that didn't work as intented either (could
be that something was changed down the road, or it might have
been broken since the dawn of time) because it only works once
urg is already written while this bug shows up starting from
~64k before the urg point.
The retransmissions already are split to mss sized chunks, so
only new data sending paths need splitting in case they have
a segment otherwise suitable for gso/tso. The actually check
can be improved to be more narrow but since this is late -rc
already, I'll postpone thinking the more fine-grained things.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
* 'for-2.6.28' of git://linux-nfs.org/~bfields/linux:
NLM: client-side nlm_lookup_host() should avoid matching on srcaddr
nfsd: use of unitialized list head on error exit in nfs4recover.c
Add a reference to sunrpc in svc_addsock
nfsd: clean up grace period on early exit
Due to a wrong safety check in af_can.c it was not possible to filter
for SFF frames with a specific CAN identifier without getting the
same selected CAN identifier from a received EFF frame also.
This fix has a minimum (but user visible) impact on the CAN filter
API and therefore the CAN version is set to a new date.
Indeed the 'old' API is still working as-is. But when now setting
CAN_(EFF|RTR)_FLAG in can_filter.can_mask you might get less traffic
than before - but still the stuff that you expected to get for your
defined filter ...
Thanks to Kurt Van Dijck for pointing at this issue and for the review.
Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be>
Fix a potential NULL pointer dereference seen when trying to remove a
static label configuration with an invalid address/mask combination.
After flush the SPD entries, dump the SPD entries will cause kernel painc.
Used the following commands to reproduct:
- echo 'spdflush;' | setkey -c
- echo 'spdadd 3ffe:501:ffff:ff01::/64 3ffe:501:ffff:ff04::/64 any -P out ipsec \
ah/tunnel/3ffe:501:ffff:ff00:200:ff:fe00:b0b0-3ffe:501:ffff:ff02:200:ff:fe00:a1a1/require;\
spddump;' | setkey -c
- echo 'spdflush; spddump;' | setkey -c
This is because when flush the SPD entries, the SPD entry is not remove
from the list.
This patch fix the problem by remove the SPD entry from the list.
This is an implementation of David Miller's suggested fix in:
https://bugzilla.redhat.com/show_bug.cgi?id=470201
It has been updated to use wait_event() instead of
wait_event_interruptible().
Paraphrasing the description from the above report, it makes sendmsg()
block while UNIX garbage collection is in progress. This avoids a
situation where child processes continue to queue new FDs over a
AF_UNIX socket to a parent which is in the exit path and running
garbage collection on these FDs. This contention can result in soft
lockups and oom-killing of unrelated processes.
Signed-off-by: dann frazier <dannf@hp.com>
A NULL dereference would occur when trying to delete an addres from a
network device that does not have any Phonet address.
The previous fix for the conntrack creation race (netfilter: ctnetlink:
fix conntrack creation race) missed a GFP_KERNEL allocation that is
now performed while holding a spinlock. Switch to GFP_ATOMIC.
Reported-and-tested-by: Zoltan Borbely <bozo@andrews.hu>
The truesize message check is important enough to make it print "BUG"
to the user console... lets also make it important enough to spit a
backtrace/module list etc so that kerneloops.org can track them.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
fix:
net/wireless/reg.c:348:29: error: macro "if" passed 2 arguments, but takes just 1
triggered by the branch-tracer.
Patch fixes the kernel trace when user tries to set
ad-hoc mode on non IBSS channel.
e.g iwconfig wlan0 chan 36 mode ad-hoc
Signed-off-by: Abhijeet Kolekar <abhijeet.kolekar@intel.com>
Since changeset e79ad711a0108475c1b3a03815527e7237020b08 from mainline,
>From David S. Miller,
empty packet can be transmitted on connected socket for datagram protocols.
However, this patch broke a high level application using ROSE network protocol with connected datagram.
Bulletin Board Stations perform bulletins forwarding between BBS stations via ROSE network using a forward protocol.
Now, if for some reason, a buffer in the application software happens to be empty at a specific moment,
ROSE sends an empty packet via unfiltered packet socket.
When received, this ROSE packet introduces perturbations of data exchange of BBS forwarding,
for the application message forwarding protocol is waiting for something else.
We agree that a more careful programming of the application protocol would avoid this situation and we are
willing to debug it.
But, as an empty frame is no use and does not have any meaning for ROSE protocol,
we may consider filtering zero length data both when sending and receiving socket data.
The proposed patch repaired BBS data exchange through ROSE network that were broken since 2.6.22.11 kernel.
Signed-off-by: Bernard Pidoux <f6bvp@amsat.org>
As GRE tries to call the update_pmtu function on skb->dst and
bridge supplies an skb->dst that has a NULL ops field, all is
not well.
This patch fixes this by giving the bridge device an ops field
with an update_pmtu function. For the moment I've left all
other fields blank but we can fill them in later should the
need arise.
Based on report and patch by Philip Craig.
Conntrack creation through ctnetlink has two races:
- the timer may expire and free the conntrack concurrently, causing an
invalid memory access when attempting to put it in the hash tables
- an identical conntrack entry may be created in the packet processing
path in the time between the lookup and hash insertion
Hold the conntrack lock between the lookup and insertion to avoid this.
Reported-by: Zoltan Borbely <bozo@andrews.hu>
The svc_addsock function adds transport instances without taking a
reference on the sunrpc.ko module, however, the generic transport
destruction code drops a reference when a transport instance
is destroyed.
Add a try_module_get call to the svc_addsock function for transport
instances added by this function.
Signed-off-by: Tom Tucker <tom@opengridcomputing.com>
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
Tested-by: Jeff Moyer <jmoyer@redhat.com>
If the slub allocator is used, kmem_cache_create() may merge two or more
kmem_cache's into one but the cache name pointer is not updated and
kmem_cache_name() is no longer guaranteed to return the pointer passed
to the former function. This patch stores the kmalloc'ed pointers in the
corresponding request_sock_ops and timewait_sock_ops structures.
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
This patch fixes http://bugzilla.kernel.org/show_bug.cgi?id=12014
Since most (if not all) implementations of TSO and even the in-kernel
software GSO do not update the urgent pointer when splitting a large
segment, it is necessary to turn off TSO/GSO for all outgoing traffic
with the URG pointer set.
Looking at tcp_current_mss (and the preceding comment) I even think
this was the original intention. However, this approach is insufficient,
because TSO/GSO is turned off only for newly created frames, not for
frames which were already pending at the arrival of a message with
MSG_OOB set. These frames were created when TSO/GSO was enabled,
so they may be large, and they will have the urgent pointer set
in tcp_transmit_skb().
With this patch, such large packets will be fragmented again before
going to the transmit routine.
As a side note, at least the following NICs are known to screw up
the urgent pointer in the TCP header when doing TSO:
Intel 82566MM (PCI ID 8086:1049)
Intel 82566DC (PCI ID 8086:104b)
Intel 82541GI (PCI ID 8086:1076)
Broadcom NetXtreme II BCM5708 (PCI ID 14e4:164c)
Signed-off-by: Petr Tesarik <ptesarik@suse.cz>
Fix a regression reported by Max Kellermann whereby kernel profiling
showed that his clients were spending 45% of their time in
rpcauth_lookup_credcache.
It turns out that although his processes had identical uid/gid/groups,
generic_match() was failing to detect this, because the task->group_info
pointers were not shared. This again lead to the creation of a huge number
of identical credentials at the RPC layer.
The regression is fixed by comparing the contents of task->group_info
if the actual pointers are not identical.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (23 commits)
net: fix tiny output corruption of /proc/net/snmp6
atl2: don't request irq on resume if netif running
ipv6: use seq_release_private for ip6mr.c /proc entries
pkt_sched: fix missing check for packet overrun in qdisc_dump_stab()
smc911x: Fix printf format typo in smc911x driver.
asix: Fix asix-based cards connecting to 10/100Mbs LAN.
mv643xx_eth: fix recycle check bound
mv643xx_eth: fix the order of mdiobus_{unregister, free}() calls
sh: sh_eth: Update to change of mii_bus
TPROXY: supply a struct flowi->flags argument in inet_sk_rebuild_header()
TPROXY: fill struct flowi->flags in udp_sendmsg()
net: ipg.c fix bracing on endian swapping
phylib: Fix auto-negotiation restart avoidance
net: jme.c rxdesc.flags is __le16, other missing endian swaps
phylib: fix phy name example in documentation
net: Do not fire linkwatch events until the device is registered.
phonet: fix compilation with gcc-3.4
ixgbe: fix compilation with gcc-3.4
pktgen: fix multiple queue warning
net: fix ip_mr_init() error path
Because "name" is static, it can be occasionally be filled with
somewhat garbage if two processes read /proc/net/snmp6.
Also, remove useless casts and "-1" -- snprintf() correctly terminates it's
output.
In ip6mr.c, /proc entries /proc/net/ip6_mr_cache and /proc/net/ip6_mr_vif
are opened with seq_open_private(), thus seq_release_private() should be
used to release them.
Should fix a small memory leak.
Signed-off-by: Benjamin Thery <benjamin.thery@bull.net>
