path: root/net
2012-07-19cfg80211: check iface combinations only when iface is runningMichal Kazior
commit f8cdddb8d61d16a156229f0910f7ecfc7a82c003 upstream. Don't validate interface combinations on a stopped interface. Otherwise we might end up being able to create a new interface with a certain type, but won't be able to change an existing interface into that type. This also skips some other functions when interface is stopped and changing interface type. Signed-off-by: Michal Kazior <michal.kazior@tieto.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> [Fixes regression introduced by cherry pick of 463454b5dbd8] Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-07-19tcp: drop SYN+FIN messagesEric Dumazet
commit fdf5af0daf8019cec2396cdef8fb042d80fe71fa upstream. Denys Fedoryshchenko reported that SYN+FIN attacks were bringing his linux machines to their limits. Dont call conn_request() if the TCP flags includes SYN flag Reported-by: Denys Fedoryshchenko <denys@visp.net.lb> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16mac80211: correct behaviour on unrecognised action framesJohannes Berg
commit 4b5ebccc40843104d980f0714bc86bfcd5568941 upstream. When receiving an "individually addressed" action frame, the receiver is required to return it to the sender. mac80211 gets this wrong as it also returns group addressed (mcast) frames to the sender. Fix this and update the reference to the new 802.11 standards version since things were shuffled around significantly. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16cfg80211: fix potential deadlock in regulatoryEliad Peller
commit fe20b39ec32e975f1054c0b7866c873a954adf05 upstream. reg_timeout_work() calls restore_regulatory_settings() which takes cfg80211_mutex. reg_set_request_processed() already holds cfg80211_mutex before calling cancel_delayed_work_sync(reg_timeout), so it might deadlock. Call the async cancel_delayed_work instead, in order to avoid the potential deadlock. This is the relevant lockdep warning: cfg80211: Calling CRDA for country: XX ====================================================== [ INFO: possible circular locking dependency detected ] 3.4.0-rc5-wl+ #26 Not tainted ------------------------------------------------------- kworker/0:2/1391 is trying to acquire lock: (cfg80211_mutex){+.+.+.}, at: [<bf28ae00>] restore_regulatory_settings+0x34/0x418 [cfg80211] but task is already holding lock: ((reg_timeout).work){+.+...}, at: [<c0059e94>] process_one_work+0x1f0/0x480 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #2 ((reg_timeout).work){+.+...}: [<c008fd44>] validate_chain+0xb94/0x10f0 [<c0090b68>] __lock_acquire+0x8c8/0x9b0 [<c0090d40>] lock_acquire+0xf0/0x114 [<c005b600>] wait_on_work+0x4c/0x154 [<c005c000>] __cancel_work_timer+0xd4/0x11c [<c005c064>] cancel_delayed_work_sync+0x1c/0x20 [<bf28b274>] reg_set_request_processed+0x50/0x78 [cfg80211] [<bf28bd84>] set_regdom+0x550/0x600 [cfg80211] [<bf294cd8>] nl80211_set_reg+0x218/0x258 [cfg80211] [<c03c7738>] genl_rcv_msg+0x1a8/0x1e8 [<c03c6a00>] netlink_rcv_skb+0x5c/0xc0 [<c03c7584>] genl_rcv+0x28/0x34 [<c03c6720>] netlink_unicast+0x15c/0x228 [<c03c6c7c>] netlink_sendmsg+0x218/0x298 [<c03933c8>] sock_sendmsg+0xa4/0xc0 [<c039406c>] __sys_sendmsg+0x1e4/0x268 [<c0394228>] sys_sendmsg+0x4c/0x70 [<c0013840>] ret_fast_syscall+0x0/0x3c -> #1 (reg_mutex){+.+.+.}: [<c008fd44>] validate_chain+0xb94/0x10f0 [<c0090b68>] __lock_acquire+0x8c8/0x9b0 [<c0090d40>] lock_acquire+0xf0/0x114 [<c04734dc>] mutex_lock_nested+0x48/0x320 [<bf28b2cc>] reg_todo+0x30/0x538 [cfg80211] [<c0059f44>] process_one_work+0x2a0/0x480 [<c005a4b4>] worker_thread+0x1bc/0x2bc [<c0061148>] kthread+0x98/0xa4 [<c0014af4>] kernel_thread_exit+0x0/0x8 -> #0 (cfg80211_mutex){+.+.+.}: [<c008ed58>] print_circular_bug+0x68/0x2cc [<c008fb28>] validate_chain+0x978/0x10f0 [<c0090b68>] __lock_acquire+0x8c8/0x9b0 [<c0090d40>] lock_acquire+0xf0/0x114 [<c04734dc>] mutex_lock_nested+0x48/0x320 [<bf28ae00>] restore_regulatory_settings+0x34/0x418 [cfg80211] [<bf28b200>] reg_timeout_work+0x1c/0x20 [cfg80211] [<c0059f44>] process_one_work+0x2a0/0x480 [<c005a4b4>] worker_thread+0x1bc/0x2bc [<c0061148>] kthread+0x98/0xa4 [<c0014af4>] kernel_thread_exit+0x0/0x8 other info that might help us debug this: Chain exists of: cfg80211_mutex --> reg_mutex --> (reg_timeout).work Possible unsafe locking scenario: CPU0 CPU1 ---- ---- lock((reg_timeout).work); lock(reg_mutex); lock((reg_timeout).work); lock(cfg80211_mutex); *** DEADLOCK *** 2 locks held by kworker/0:2/1391: #0: (events){.+.+.+}, at: [<c0059e94>] process_one_work+0x1f0/0x480 #1: ((reg_timeout).work){+.+...}, at: [<c0059e94>] process_one_work+0x1f0/0x480 stack backtrace: [<c001b928>] (unwind_backtrace+0x0/0x12c) from [<c0471d3c>] (dump_stack+0x20/0x24) [<c0471d3c>] (dump_stack+0x20/0x24) from [<c008ef70>] (print_circular_bug+0x280/0x2cc) [<c008ef70>] (print_circular_bug+0x280/0x2cc) from [<c008fb28>] (validate_chain+0x978/0x10f0) [<c008fb28>] (validate_chain+0x978/0x10f0) from [<c0090b68>] (__lock_acquire+0x8c8/0x9b0) [<c0090b68>] (__lock_acquire+0x8c8/0x9b0) from [<c0090d40>] (lock_acquire+0xf0/0x114) [<c0090d40>] (lock_acquire+0xf0/0x114) from [<c04734dc>] (mutex_lock_nested+0x48/0x320) [<c04734dc>] (mutex_lock_nested+0x48/0x320) from [<bf28ae00>] (restore_regulatory_settings+0x34/0x418 [cfg80211]) [<bf28ae00>] (restore_regulatory_settings+0x34/0x418 [cfg80211]) from [<bf28b200>] (reg_timeout_work+0x1c/0x20 [cfg80211]) [<bf28b200>] (reg_timeout_work+0x1c/0x20 [cfg80211]) from [<c0059f44>] (process_one_work+0x2a0/0x480) [<c0059f44>] (process_one_work+0x2a0/0x480) from [<c005a4b4>] (worker_thread+0x1bc/0x2bc) [<c005a4b4>] (worker_thread+0x1bc/0x2bc) from [<c0061148>] (kthread+0x98/0xa4) [<c0061148>] (kthread+0x98/0xa4) from [<c0014af4>] (kernel_thread_exit+0x0/0x8) cfg80211: Calling CRDA to update world regulatory domain cfg80211: World regulatory domain updated: cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm) cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm) cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16netpoll: fix netpoll_send_udp() bugsEric Dumazet
[ Upstream commit 954fba0274058d27c7c07b5ea07c41b3b7477894 ] Bogdan Hamciuc diagnosed and fixed following bug in netpoll_send_udp() : "skb->len += len;" instead of "skb_put(skb, len);" Meaning that _if_ a network driver needs to call skb_realloc_headroom(), only packet headers would be copied, leaving garbage in the payload. However the skb_realloc_headroom() must be avoided as much as possible since it requires memory and netpoll tries hard to work even if memory is exhausted (using a pool of preallocated skbs) It appears netpoll_send_udp() reserved 16 bytes for the ethernet header, which happens to work for typicall drivers but not all. Right thing is to use LL_RESERVED_SPACE(dev) (And also add dev->needed_tailroom of tailroom) This patch combines both fixes. Many thanks to Bogdan for raising this issue. Reported-by: Bogdan Hamciuc <bogdan.hamciuc@freescale.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Tested-by: Bogdan Hamciuc <bogdan.hamciuc@freescale.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Neil Horman <nhorman@tuxdriver.com> Reviewed-by: Neil Horman <nhorman@tuxdriver.com> Reviewed-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16ipv6: Move ipv6 proc file registration to end of init orderThomas Graf
[ Upstream commit d189634ecab947c10f6f832258b103d0bbfe73cc ] /proc/net/ipv6_route reflects the contents of fib_table_hash. The proc handler is installed in ip6_route_net_init() whereas fib_table_hash is allocated in fib6_net_init() _after_ the proc handler has been installed. This opens up a short time frame to access fib_table_hash with its pants down. Move the registration of the proc files to a later point in the init order to avoid the race. Tested :-) Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16bridge: Assign rtnl_link_ops to bridge devices created via ioctl (v2)stephen hemminger
[ Upstream commit 149ddd83a92b02c658d6c61f3276eb6500d585e8 ] This ensures that bridges created with brctl(8) or ioctl(2) directly also carry IFLA_LINKINFO when dumped over netlink. This also allows to create a bridge with ioctl(2) and delete it with RTM_DELLINK. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16ethtool: allow ETHTOOL_GSSET_INFO for usersMichał Mirosław
[ Upstream commit f80400a26a2e8bff541de12834a1134358bb6642 ] Allow ETHTOOL_GSSET_INFO ethtool ioctl() for unprivileged users. ETHTOOL_GSTRINGS is already allowed, but is unusable without this one. Signed-off-by: Micha©© Miros©©aw <mirq-linux@rere.qmqm.pl> Acked-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16net: l2tp_eth: fix kernel panic on rmmod l2tp_ethEric Dumazet
[ Upstream commit a06998b88b1651c5f71c0e35f528bf2057188ead ] We must prevent module unloading if some devices are still attached to l2tp_eth driver. Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Denys Fedoryshchenko <denys@visp.net.lb> Tested-by: Denys Fedoryshchenko <denys@visp.net.lb> Cc: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16net: sock: validate data_len before allocating skb in sock_alloc_send_pskb()Jason Wang
[ Upstream commit cc9b17ad29ecaa20bfe426a8d4dbfb94b13ff1cc ] We need to validate the number of pages consumed by data_len, otherwise frags array could be overflowed by userspace. So this patch validate data_len and return -EMSGSIZE when data_len may occupies more frags than MAX_SKB_FRAGS. Signed-off-by: Jason Wang <jasowang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-22NFSv4.1: Fix a request leak on the back channelTrond Myklebust
commit b3b02ae5865c2dcd506322e0fc6def59a042e72f upstream. If the call to svc_process_common() fails, then the request needs to be freed before we can exit bc_svc_process. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-17cfg80211: fix interface combinations checkJohannes Berg
commit 463454b5dbd8dbab6e2fc6c557329e5b811b9c32 upstream. If a given interface combination doesn't contain a required interface type then we missed checking that and erroneously allowed it even though iface type wasn't there at all. Add a check that makes sure that all interface types are accounted for. Reported-by: Mohammed Shafi Shajakhan <mohammed@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-17mac80211: clean up remain-on-channel on interface stopJohannes Berg
commit 71ecfa1893034eeb1c93e02e22ee2ad26d080858 upstream. When any interface goes down, it could be the one that we were doing a remain-on-channel with. We therefore need to cancel the remain-on-channel and flush the related work structs so they don't run after the interface has been removed or even destroyed. It's also possible in this case that an off-channel SKB was never transmitted, so free it if this is the case. Note that this can also happen if the driver finishes the off-channel period without ever starting it. Reported-by: Nirav Shah <nirav.j2.shah@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-10xfrm: take net hdr len into account for esp payload size calculationBenjamin Poirier
[ Upstream commit 91657eafb64b4cb53ec3a2fbc4afc3497f735788 ] Corrects the function that determines the esp payload size. The calculations done in esp{4,6}_get_mtu() lead to overlength frames in transport mode for certain mtu values and suboptimal frames for others. According to what is done, mainly in esp{,6}_output() and tcp_mtu_to_mss(), net_header_len must be taken into account before doing the alignment calculation. Signed-off-by: Benjamin Poirier <bpoirier@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-10sctp: check cached dst before using itNicolas Dichtel
[ Upstream commit e0268868ba064980488fc8c194db3d8e9fb2959c ] dst_check() will take care of SA (and obsolete field), hence IPsec rekeying scenario is taken into account. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Vlad Yaseivch <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-10Revert "net: maintain namespace isolation between vlan and real device"David S. Miller
[ Upstream commit 59b9997baba5242997ddc7bd96b1391f5275a5a4 ] This reverts commit 8a83a00b0735190384a348156837918271034144. It causes regressions for S390 devices, because it does an unconditional DST drop on SKBs for vlans and the QETH device needs the neighbour entry hung off the DST for certain things on transmit. Arnd can't remember exactly why he even needed this change. Conflicts: drivers/net/macvlan.c net/8021q/vlan_dev.c net/core/dev.c Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-10pktgen: fix module unload for goodEric Dumazet
[ Upstream commit d4b1133558e0d417342d5d2c49e4c35b428ff20d ] commit c57b5468406 (pktgen: fix crash at module unload) did a very poor job with list primitives. 1) list_splice() arguments were in the wrong order 2) list_splice(list, head) has undefined behavior if head is not initialized. 3) We should use the list_splice_init() variant to clear pktgen_threads list. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-10pktgen: fix crash at module unloadEric Dumazet
[ Upstream commit c57b54684060c8aced64a5b78ff69ff289af97b9 ] commit 7d3d43dab4e9 (net: In unregister_netdevice_notifier unregister the netdevices.) makes pktgen crashing at module unload. [ 296.820578] BUG: spinlock bad magic on CPU#6, rmmod/3267 [ 296.820719] lock: ffff880310c38000, .magic: ffff8803, .owner: <none>/-1, .owner_cpu: -1 [ 296.820943] Pid: 3267, comm: rmmod Not tainted 3.4.0-rc5+ #254 [ 296.821079] Call Trace: [ 296.821211] [<ffffffff8168a715>] spin_dump+0x8a/0x8f [ 296.821345] [<ffffffff8168a73b>] spin_bug+0x21/0x26 [ 296.821507] [<ffffffff812b4741>] do_raw_spin_lock+0x131/0x140 [ 296.821648] [<ffffffff8169188e>] _raw_spin_lock+0x1e/0x20 [ 296.821786] [<ffffffffa00cc0fd>] __pktgen_NN_threads+0x4d/0x140 [pktgen] [ 296.821928] [<ffffffffa00ccf8d>] pktgen_device_event+0x10d/0x1e0 [pktgen] [ 296.822073] [<ffffffff8154ed4f>] unregister_netdevice_notifier+0x7f/0x100 [ 296.822216] [<ffffffffa00d2a0b>] pg_cleanup+0x48/0x73 [pktgen] [ 296.822357] [<ffffffff8109528e>] sys_delete_module+0x17e/0x2a0 [ 296.822502] [<ffffffff81699652>] system_call_fastpath+0x16/0x1b Hold the pktgen_thread_lock while splicing pktgen_threads, and test pktgen_exiting in pktgen_device_event() to make unload faster. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-10l2tp: fix oops in L2TP IP sockets for connect() AF_UNSPEC caseJames Chapman
[ Upstream commit c51ce49735c183ef2592db70f918ee698716276b ] An application may call connect() to disconnect a socket using an address with family AF_UNSPEC. The L2TP IP sockets were not handling this case when the socket is not bound and an attempt to connect() using AF_UNSPEC in such cases would result in an oops. This patch addresses the problem by protecting the sk_prot->disconnect() call against trying to unhash the socket before it is bound. The patch also adds more checks that the sockaddr supplied to bind() and connect() calls is valid. RIP: 0010:[<ffffffff82e133b0>] [<ffffffff82e133b0>] inet_unhash+0x50/0xd0 RSP: 0018:ffff88001989be28 EFLAGS: 00010293 Stack: ffff8800407a8000 0000000000000000 ffff88001989be78 ffffffff82e3a249 ffffffff82e3a050 ffff88001989bec8 ffff88001989be88 ffff8800407a8000 0000000000000010 ffff88001989bec8 ffff88001989bea8 ffffffff82e42639 Call Trace: [<ffffffff82e3a249>] udp_disconnect+0x1f9/0x290 [<ffffffff82e42639>] inet_dgram_connect+0x29/0x80 [<ffffffff82d012fc>] sys_connect+0x9c/0x100 Reported-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-10ipv6: fix incorrect ipsec fragmentGao feng
[ Upstream commit 0c1833797a5a6ec23ea9261d979aa18078720b74 ] Since commit ad0081e43a "ipv6: Fragment locally generated tunnel-mode IPSec6 packets as needed" the fragment of packets is incorrect. because tunnel mode needs IPsec headers and trailer for all fragments, while on transport mode it is sufficient to add the headers to the first fragment and the trailer to the last. so modify mtu and maxfraglen base on ipsec mode and if fragment is first or last. with my test,it work well(every fragment's size is the mtu) and does not trigger slow fragment path. Changes from v1: though optimization, mtu_prev and maxfraglen_prev can be delete. replace xfrm mode codes with dst_entry's new frag DST_XFRM_TUNNEL. add fuction ip6_append_data_mtu to make codes clearer. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-10ipv4: fix the rcu race between free_fib_info and ip_route_output_slowYanmin Zhang
[ Upstream commit e49cc0da7283088c5e03d475ffe2fdcb24a6d5b1 ] We hit a kernel OOPS. <3>[23898.789643] BUG: sleeping function called from invalid context at /data/buildbot/workdir/ics/hardware/intel/linux-2.6/arch/x86/mm/fault.c:1103 <3>[23898.862215] in_atomic(): 0, irqs_disabled(): 0, pid: 10526, name: Thread-6683 <4>[23898.967805] HSU serial 0000:00:05.1: 0000:00:05.2:HSU serial prevented me to suspend... <4>[23899.258526] Pid: 10526, comm: Thread-6683 Tainted: G W 3.0.8-137685-ge7742f9 #1 <4>[23899.357404] HSU serial 0000:00:05.1: 0000:00:05.2:HSU serial prevented me to suspend... <4>[23899.904225] Call Trace: <4>[23899.989209] [<c1227f50>] ? pgtable_bad+0x130/0x130 <4>[23900.000416] [<c1238c2a>] __might_sleep+0x10a/0x110 <4>[23900.007357] [<c1228021>] do_page_fault+0xd1/0x3c0 <4>[23900.013764] [<c18e9ba9>] ? restore_all+0xf/0xf <4>[23900.024024] [<c17c007b>] ? napi_complete+0x8b/0x690 <4>[23900.029297] [<c1227f50>] ? pgtable_bad+0x130/0x130 <4>[23900.123739] [<c1227f50>] ? pgtable_bad+0x130/0x130 <4>[23900.128955] [<c18ea0c3>] error_code+0x5f/0x64 <4>[23900.133466] [<c1227f50>] ? pgtable_bad+0x130/0x130 <4>[23900.138450] [<c17f6298>] ? __ip_route_output_key+0x698/0x7c0 <4>[23900.144312] [<c17f5f8d>] ? __ip_route_output_key+0x38d/0x7c0 <4>[23900.150730] [<c17f63df>] ip_route_output_flow+0x1f/0x60 <4>[23900.156261] [<c181de58>] ip4_datagram_connect+0x188/0x2b0 <4>[23900.161960] [<c18e981f>] ? _raw_spin_unlock_bh+0x1f/0x30 <4>[23900.167834] [<c18298d6>] inet_dgram_connect+0x36/0x80 <4>[23900.173224] [<c14f9e88>] ? _copy_from_user+0x48/0x140 <4>[23900.178817] [<c17ab9da>] sys_connect+0x9a/0xd0 <4>[23900.183538] [<c132e93c>] ? alloc_file+0xdc/0x240 <4>[23900.189111] [<c123925d>] ? sub_preempt_count+0x3d/0x50 Function free_fib_info resets nexthop_nh->nh_dev to NULL before releasing fi. Other cpu might be accessing fi. Fixing it by delaying the releasing. With the patch, we ran MTBF testing on Android mobile for 12 hours and didn't trigger the issue. Thank Eric for very detailed review/checking the issue. Signed-off-by: Yanmin Zhang <yanmin_zhang@linux.intel.com> Signed-off-by: Kun Jiang <kunx.jiang@intel.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-10ipv4: Do not use dead fib_info entries.David S. Miller
[ Upstream commit dccd9ecc374462e5d6a5b8f8110415a86c2213d8 ] Due to RCU lookups and RCU based release, fib_info objects can be found during lookup which have fi->fib_dead set. We must ignore these entries, otherwise we risk dereferencing the parts of the entry which are being torn down. Reported-by: Yevgen Pronenko <yevgen.pronenko@sonymobile.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-10mac80211: fix ADDBA declined after suspend with wowlanEyal Shapira
commit 7b21aea04d084916ac4e0e8852dcc9cd60ec0d1d upstream. WLAN_STA_BLOCK_BA is set while suspending but doesn't get cleared when resuming in case of wowlan. This causes further ADDBA requests received to be rejected. Fix it by clearing it in the wowlan path as well. Signed-off-by: Eyal Shapira <eyal@wizery.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-01cfg80211: warn if db.txt is empty with CONFIG_CFG80211_INTERNAL_REGDBLuis R. Rodriguez
commit 80007efeff0568375b08faf93c7aad65602cb97e upstream. It has happened twice now where elaborate troubleshooting has undergone on systems where CONFIG_CFG80211_INTERNAL_REGDB [0] has been set but yet net/wireless/db.txt was not updated. Despite the documentation on this it seems system integrators could use some more help with this, so throw out a kernel warning at boot time when their database is empty. This does mean that the error-prone system integrator won't likely realize the issue until they boot the machine but -- it does not seem to make sense to enable a build bug breaking random build testing. [0] http://wireless.kernel.org/en/developers/Regulatory/CRDA#CONFIG_CFG80211_INTERNAL_REGDB Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Youngsin Lee <youngsin@qualcomm.com> Cc: Raja Mani <rmani@qca.qualcomm.com> Cc: Senthil Kumar Balasubramanian <senthilb@qca.qualcomm.com> Cc: Vipin Mehta <vipimeht@qca.qualcomm.com> Cc: yahuan@qca.qualcomm.com Cc: jjan@qca.qualcomm.com Cc: vthiagar@qca.qualcomm.com Cc: henrykim@qualcomm.com Cc: jouni@qca.qualcomm.com Cc: athiruve@qca.qualcomm.com Cc: cjkim@qualcomm.com Cc: philipk@qca.qualcomm.com Cc: sunnykim@qualcomm.com Cc: sskwak@qualcomm.com Cc: kkim@qualcomm.com Cc: mattbyun@qualcomm.com Cc: ryanlee@qualcomm.com Cc: simbap@qualcomm.com Cc: krislee@qualcomm.com Cc: conner@qualcomm.com Cc: hojinkim@qualcomm.com Cc: honglee@qualcomm.com Cc: johnwkim@qualcomm.com Cc: jinyong@qca.qualcomm.com Signed-off-by: Luis R. Rodriguez <mcgrof@frijolero.org> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21tcp: do_tcp_sendpages() must try to push data out on oom conditionsWilly Tarreau
commit bad115cfe5b509043b684d3a007ab54b80090aa1 upstream. Since recent changes on TCP splicing (starting with commits 2f533844 "tcp: allow splice() to build full TSO packets" and 35f9c09f "tcp: tcp_sendpages() should call tcp_push() once"), I started seeing massive stalls when forwarding traffic between two sockets using splice() when pipe buffers were larger than socket buffers. Latest changes (net: netdev_alloc_skb() use build_skb()) made the problem even more apparent. The reason seems to be that if do_tcp_sendpages() fails on out of memory condition without being able to send at least one byte, tcp_push() is not called and the buffers cannot be flushed. After applying the attached patch, I cannot reproduce the stalls at all and the data rate it perfectly stable and steady under any condition which previously caused the problem to be permanent. The issue seems to have been there since before the kernel migrated to git, which makes me think that the stalls I occasionally experienced with tux during stress-tests years ago were probably related to the same issue. This issue was first encountered on 3.0.31 and 3.2.17, so please backport to -stable. Signed-off-by: Willy Tarreau <w@1wt.eu> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21tcp: change tcp_adv_win_scale and tcp_rmem[2]Eric Dumazet
[ Upstream commit b49960a05e32121d29316cfdf653894b88ac9190 ] tcp_adv_win_scale default value is 2, meaning we expect a good citizen skb to have skb->len / skb->truesize ratio of 75% (3/4) In 2.6 kernels we (mis)accounted for typical MSS=1460 frame : 1536 + 64 + 256 = 1856 'estimated truesize', and 1856 * 3/4 = 1392. So these skbs were considered as not bloated. With recent truesize fixes, a typical MSS=1460 frame truesize is now the more precise : 2048 + 256 = 2304. But 2304 * 3/4 = 1728. So these skb are not good citizen anymore, because 1460 < 1728 (GRO can escape this problem because it build skbs with a too low truesize.) This also means tcp advertises a too optimistic window for a given allocated rcvspace : When receiving frames, sk_rmem_alloc can hit sk_rcvbuf limit and we call tcp_prune_queue()/tcp_collapse() too often, especially when application is slow to drain its receive queue or in case of losses (netperf is fast, scp is slow). This is a major latency source. We should adjust the len/truesize ratio to 50% instead of 75% This patch : 1) changes tcp_adv_win_scale default to 1 instead of 2 2) increase tcp_rmem[2] limit from 4MB to 6MB to take into account better truesize tracking and to allow autotuning tcp receive window to reach same value than before. Note that same amount of kernel memory is consumed compared to 2.6 kernels. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Neal Cardwell <ncardwell@google.com> Cc: Tom Herbert <therbert@google.com> Cc: Yuchung Cheng <ycheng@google.com> Acked-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21net: l2tp: unlock socket lock before returning from l2tp_ip_sendmsgSasha Levin
[ Upstream commit 84768edbb2721637620b2d84501bb0d5aed603f1 ] l2tp_ip_sendmsg could return without releasing socket lock, making it all the way to userspace, and generating the following warning: [ 130.891594] ================================================ [ 130.894569] [ BUG: lock held when returning to user space! ] [ 130.897257] 3.4.0-rc5-next-20120501-sasha #104 Tainted: G W [ 130.900336] ------------------------------------------------ [ 130.902996] trinity/8384 is leaving the kernel with locks still held! [ 130.906106] 1 lock held by trinity/8384: [ 130.907924] #0: (sk_lock-AF_INET){+.+.+.}, at: [<ffffffff82b9503f>] l2tp_ip_sendmsg+0x2f/0x550 Introduced by commit 2f16270 ("l2tp: Fix locking in l2tp_ip.c"). Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21net: In unregister_netdevice_notifier unregister the netdevices.Eric W. Biederman
[ Upstream commit 7d3d43dab4e978d8d9ad1acf8af15c9b1c4b0f0f ] We already synthesize events in register_netdevice_notifier and synthesizing events in unregister_netdevice_notifier allows to us remove the need for special case cleanup code. This change should be safe as it adds no new cases for existing callers of unregiser_netdevice_notifier to handle. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21netem: fix possible skb leakEric Dumazet
[ Upstream commit 116a0fc31c6c9b8fc821be5a96e5bf0b43260131 ] skb_checksum_help(skb) can return an error, we must free skb in this case. qdisc_drop(skb, sch) can also be feeded with a NULL skb (if skb_unshare() failed), so lets use this generic helper. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-07mac80211: fix AP mode EAP tx for VLAN stationsFelix Fietkau
commit 66f2c99af3d6f2d0aa1120884cf1c60613ef61c0 upstream. EAP frames for stations in an AP VLAN are sent on the main AP interface to avoid race conditions wrt. moving stations. For that to work properly, sta_info_get_bss must be used instead of sta_info_get when sending EAP packets. Previously this was only done for cooked monitor injected packets, so this patch adds a check for tx->skb->protocol to the same place. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-07nl80211: ensure interface is up in various APIsJohannes Berg
commit 2b5f8b0b44e17e625cfba1e7b88db44f4dcc0441 upstream. [backported by Ben Greear] The nl80211 handling code should ensure as much as it can that the interface is in a valid state, it can certainly ensure the interface is running. Not doing so can cause calls through mac80211 into the driver that result in warnings and unspecified behaviour in the driver. Reported-by: Ben Greear <greearb@candelatech.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Ben Greear <greearb@candelatech.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-27tcp: fix TCP_MAXSEG for established IPv6 passive socketsNeal Cardwell
[ Upstream commit d135c522f1234f62e81be29cebdf59e9955139ad ] Commit f5fff5d forgot to fix TCP_MAXSEG behavior IPv6 sockets, so IPv6 TCP server sockets that used TCP_MAXSEG would find that the advmss of child sockets would be incorrect. This commit mirrors the advmss logic from tcp_v4_syn_recv_sock in tcp_v6_syn_recv_sock. Eventually this logic should probably be shared between IPv4 and IPv6, but this at least fixes this issue. Signed-off-by: Neal Cardwell <ncardwell@google.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-27net ax25: Reorder ax25_exit to remove races.Eric W. Biederman
[ Upstream commit 3adadc08cc1e2cbcc15a640d639297ef5fcb17f5 ] While reviewing the sysctl code in ax25 I spotted races in ax25_exit where it is possible to receive notifications and packets after already freeing up some of the data structures needed to process those notifications and updates. Call unregister_netdevice_notifier early so that the rest of the cleanup code does not need to deal with network devices. This takes advantage of my recent enhancement to unregister_netdevice_notifier to send unregister notifications of all network devices that are current registered. Move the unregistration for packet types, socket types and protocol types before we cleanup any of the ax25 data structures to remove the possibilities of other races. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-27netns: do not leak net_generic data on failed initJulian Anastasov
[ Upstream commit b922934d017f1cc831b017913ed7d1a56c558b43 ] ops_init should free the net_generic data on init failure and __register_pernet_operations should not call ops_free when NET_NS is not enabled. Signed-off-by: Julian Anastasov <ja@ssi.bg> Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-27tcp: fix tcp_grow_window() for large incoming framesEric Dumazet
[ Upstream commit 4d846f02392a710f9604892ac3329e628e60a230 ] tcp_grow_window() has to grow rcv_ssthresh up to window_clamp, allowing sender to increase its window. tcp_grow_window() still assumes a tcp frame is under MSS, but its no longer true with LRO/GRO. This patch fixes one of the performance issue we noticed with GRO on. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Neal Cardwell <ncardwell@google.com> Cc: Tom Herbert <therbert@google.com> Acked-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-27net_sched: gred: Fix oops in gred_dump() in WRED modeDavid Ward
[ Upstream commit 244b65dbfede788f2fa3fe2463c44d0809e97c6b ] A parameter set exists for WRED mode, called wred_set, to hold the same values for qavg and qidlestart across all VQs. The WRED mode values had been previously held in the VQ for the default DP. After these values were moved to wred_set, the VQ for the default DP was no longer created automatically (so that it could be omitted on purpose, to have packets in the default DP enqueued directly to the device without using RED). However, gred_dump() was overlooked during that change; in WRED mode it still reads qavg/qidlestart from the VQ for the default DP, which might not even exist. As a result, this command sequence will cause an oops: tc qdisc add dev $DEV handle $HANDLE parent $PARENT gred setup \ DPs 3 default 2 grio tc qdisc change dev $DEV handle $HANDLE gred DP 0 prio 8 $RED_OPTIONS tc qdisc change dev $DEV handle $HANDLE gred DP 1 prio 8 $RED_OPTIONS This fixes gred_dump() in WRED mode to use the values held in wred_set. Signed-off-by: David Ward <david.ward@ll.mit.edu> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-27tcp: fix tcp_rcv_rtt_update() use of an unscaled RTT sampleNeal Cardwell
[ Upstream commit 18a223e0b9ec8979320ba364b47c9772391d6d05 ] Fix a code path in tcp_rcv_rtt_update() that was comparing scaled and unscaled RTT samples. The intent in the code was to only use the 'm' measurement if it was a new minimum. However, since 'm' had not yet been shifted left 3 bits but 'new_sample' had, this comparison would nearly always succeed, leading us to erroneously set our receive-side RTT estimate to the 'm' sample when that sample could be nearly 8x too high to use. The overall effect is to often cause the receive-side RTT estimate to be significantly too large (up to 40% too large for brief periods in my tests). Signed-off-by: Neal Cardwell <ncardwell@google.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-27net: fix a race in sock_queue_err_skb()Eric Dumazet
[ Upstream commit 110c43304db6f06490961529536c362d9ac5732f ] As soon as an skb is queued into socket error queue, another thread can consume it, so we are not allowed to reference skb anymore, or risk use after free. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-27netlink: fix races after skb queueingEric Dumazet
[ Upstream commit 4a7e7c2ad540e54c75489a70137bf0ec15d3a127 ] As soon as an skb is queued into socket receive_queue, another thread can consume it, so we are not allowed to reference skb anymore, or risk use after free. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-27phonet: Check input from user before allocatingSasha Levin
[ Upstream commit bcf1b70ac6eb0ed8286c66e6bf37cb747cbaa04c ] A phonet packet is limited to USHRT_MAX bytes, this is never checked during tx which means that the user can specify any size he wishes, and the kernel will attempt to allocate that size. In the good case, it'll lead to the following warning, but it may also cause the kernel to kick in the OOM and kill a random task on the server. [ 8921.744094] WARNING: at mm/page_alloc.c:2255 __alloc_pages_slowpath+0x65/0x730() [ 8921.749770] Pid: 5081, comm: trinity Tainted: G W 3.4.0-rc1-next-20120402-sasha #46 [ 8921.756672] Call Trace: [ 8921.758185] [<ffffffff810b2ba7>] warn_slowpath_common+0x87/0xb0 [ 8921.762868] [<ffffffff810b2be5>] warn_slowpath_null+0x15/0x20 [ 8921.765399] [<ffffffff8117eae5>] __alloc_pages_slowpath+0x65/0x730 [ 8921.769226] [<ffffffff81179c8a>] ? zone_watermark_ok+0x1a/0x20 [ 8921.771686] [<ffffffff8117d045>] ? get_page_from_freelist+0x625/0x660 [ 8921.773919] [<ffffffff8117f3a8>] __alloc_pages_nodemask+0x1f8/0x240 [ 8921.776248] [<ffffffff811c03e0>] kmalloc_large_node+0x70/0xc0 [ 8921.778294] [<ffffffff811c4bd4>] __kmalloc_node_track_caller+0x34/0x1c0 [ 8921.780847] [<ffffffff821b0e3c>] ? sock_alloc_send_pskb+0xbc/0x260 [ 8921.783179] [<ffffffff821b3c65>] __alloc_skb+0x75/0x170 [ 8921.784971] [<ffffffff821b0e3c>] sock_alloc_send_pskb+0xbc/0x260 [ 8921.787111] [<ffffffff821b002e>] ? release_sock+0x7e/0x90 [ 8921.788973] [<ffffffff821b0ff0>] sock_alloc_send_skb+0x10/0x20 [ 8921.791052] [<ffffffff824cfc20>] pep_sendmsg+0x60/0x380 [ 8921.792931] [<ffffffff824cb4a6>] ? pn_socket_bind+0x156/0x180 [ 8921.794917] [<ffffffff824cb50f>] ? pn_socket_autobind+0x3f/0x90 [ 8921.797053] [<ffffffff824cb63f>] pn_socket_sendmsg+0x4f/0x70 [ 8921.798992] [<ffffffff821ab8e7>] sock_aio_write+0x187/0x1b0 [ 8921.801395] [<ffffffff810e325e>] ? sub_preempt_count+0xae/0xf0 [ 8921.803501] [<ffffffff8111842c>] ? __lock_acquire+0x42c/0x4b0 [ 8921.805505] [<ffffffff821ab760>] ? __sock_recv_ts_and_drops+0x140/0x140 [ 8921.807860] [<ffffffff811e07cc>] do_sync_readv_writev+0xbc/0x110 [ 8921.809986] [<ffffffff811958e7>] ? might_fault+0x97/0xa0 [ 8921.811998] [<ffffffff817bd99e>] ? security_file_permission+0x1e/0x90 [ 8921.814595] [<ffffffff811e17e2>] do_readv_writev+0xe2/0x1e0 [ 8921.816702] [<ffffffff810b8dac>] ? do_setitimer+0x1ac/0x200 [ 8921.818819] [<ffffffff810e2ec1>] ? get_parent_ip+0x11/0x50 [ 8921.820863] [<ffffffff810e325e>] ? sub_preempt_count+0xae/0xf0 [ 8921.823318] [<ffffffff811e1926>] vfs_writev+0x46/0x60 [ 8921.825219] [<ffffffff811e1a3f>] sys_writev+0x4f/0xb0 [ 8921.827127] [<ffffffff82658039>] system_call_fastpath+0x16/0x1b [ 8921.829384] ---[ end trace dffe390f30db9eb7 ]--- Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Acked-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-27ipv6: fix array index in ip6_mc_add_src()RongQing.Li
[ Upstream commit 78d50217baf36093ab320f95bae0d6452daec85c ] Convert array index from the loop bound to the loop index. And remove the void type conversion to ip6_mc_del1_src() return code, seem it is unnecessary, since ip6_mc_del1_src() does not use __must_check similar attribute, no compiler will report the warning when it is removed. v2: enrich the commit header Signed-off-by: RongQing.Li <roy.qing.li@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-27bridge: Do not send queries on multicast group leavesHerbert Xu
[ Upstream commit 996304bbea3d2a094b7ba54c3bd65d3fffeac57b ] As it stands the bridge IGMP snooping system will respond to group leave messages with queries for remaining membership. This is both unnecessary and undesirable. First of all any multicast routers present should be doing this rather than us. What's more the queries that we send may end up upsetting other multicast snooping swithces in the system that are buggy. In fact, we can simply remove the code that send these queries because the existing membership expiry mechanism doesn't rely on them anyway. So this patch simply removes all code associated with group queries in response to group leave messages. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-27sctp: Allow struct sctp_event_subscribe to grow without breaking binariesThomas Graf
[ Upstream commit acdd5985364f8dc511a0762fab2e683f29d9d692 ] getsockopt(..., SCTP_EVENTS, ...) performs a length check and returns an error if the user provides less bytes than the size of struct sctp_event_subscribe. Struct sctp_event_subscribe needs to be extended by an u8 for every new event or notification type that is added. This obviously makes getsockopt fail for binaries that are compiled against an older versions of <net/sctp/user.h> which do not contain all event types. This patch changes getsockopt behaviour to no longer return an error if not enough bytes are being provided by the user. Instead, it returns as much of sctp_event_subscribe as fits into the provided buffer. This leads to the new behavior that users see what they have been aware of at compile time. The setsockopt(..., SCTP_EVENTS, ...) API is already behaving like this. Signed-off-by: Thomas Graf <tgraf@suug.ch> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-27tcp: allow splice() to build full TSO packetsEric Dumazet
[ This combines upstream commit 2f53384424251c06038ae612e56231b96ab610ee and the follow-on bug fix commit 35f9c09fe9c72eb8ca2b8e89a593e1c151f28fc2 ] vmsplice()/splice(pipe, socket) call do_tcp_sendpages() one page at a time, adding at most 4096 bytes to an skb. (assuming PAGE_SIZE=4096) The call to tcp_push() at the end of do_tcp_sendpages() forces an immediate xmit when pipe is not already filled, and tso_fragment() try to split these skb to MSS multiples. 4096 bytes are usually split in a skb with 2 MSS, and a remaining sub-mss skb (assuming MTU=1500) This makes slow start suboptimal because many small frames are sent to qdisc/driver layers instead of big ones (constrained by cwnd and packets in flight of course) In fact, applications using sendmsg() (adding an additional memory copy) instead of vmsplice()/splice()/sendfile() are a bit faster because of this anomaly, especially if serving small files in environments with large initial [c]wnd. Call tcp_push() only if MSG_MORE is not set in the flags parameter. This bit is automatically provided by splice() internals but for the last page, or on all pages if user specified SPLICE_F_MORE splice() flag. In some workloads, this can reduce number of sent logical packets by an order of magnitude, making zero-copy TCP actually faster than one-copy :) Reported-by: Tom Herbert <therbert@google.com> Cc: Nandita Dukkipati <nanditad@google.com> Cc: Neal Cardwell <ncardwell@google.com> Cc: Tom Herbert <therbert@google.com> Cc: Yuchung Cheng <ycheng@google.com> Cc: H.K. Jerry Chu <hkchu@google.com> Cc: Maciej Żenczykowski <maze@google.com> Cc: Mahesh Bandewar <maheshb@google.com> Cc: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-27cfg80211: fix interface combinations check.Lukasz Kucharczyk
commit e55a4046dab28c440c96890bdddcf02dc8981f2d upstream. Signed-off-by: Lukasz Kucharczyk <lukasz.kucharczyk@tieto.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-22Bluetooth: hci_core: fix NULL-pointer dereference at unregisterJohan Hovold
commit 94324962066231a938564bebad0f941cd2d06bb2 upstream. Make sure hci_dev_open returns immediately if hci_dev_unregister has been called. This fixes a race between hci_dev_open and hci_dev_unregister which can lead to a NULL-pointer dereference. Bug is 100% reproducible using hciattach and a disconnected serial port: 0. # hciattach -n /dev/ttyO1 any noflow 1. hci_dev_open called from hci_power_on grabs req lock 2. hci_init_req executes but device fails to initialise (times out eventually) 3. hci_dev_open is called from hci_sock_ioctl and sleeps on req lock 4. hci_uart_tty_close calls hci_dev_unregister and sleeps on req lock in hci_dev_do_close 5. hci_dev_open (1) releases req lock 6. hci_dev_do_close grabs req lock and returns as device is not up 7. hci_dev_unregister sleeps in destroy_workqueue 8. hci_dev_open (3) grabs req lock, calls hci_init_req and eventually sleeps 9. hci_dev_unregister finishes, while hci_dev_open is still running... [ 79.627136] INFO: trying to register non-static key. [ 79.632354] the code is fine but needs lockdep annotation. [ 79.638122] turning off the locking correctness validator. [ 79.643920] [<c00188bc>] (unwind_backtrace+0x0/0xf8) from [<c00729c4>] (__lock_acquire+0x1590/0x1ab0) [ 79.653594] [<c00729c4>] (__lock_acquire+0x1590/0x1ab0) from [<c00733f8>] (lock_acquire+0x9c/0x128) [ 79.663085] [<c00733f8>] (lock_acquire+0x9c/0x128) from [<c0040a88>] (run_timer_softirq+0x150/0x3ac) [ 79.672668] [<c0040a88>] (run_timer_softirq+0x150/0x3ac) from [<c003a3b8>] (__do_softirq+0xd4/0x22c) [ 79.682281] [<c003a3b8>] (__do_softirq+0xd4/0x22c) from [<c003a924>] (irq_exit+0x8c/0x94) [ 79.690856] [<c003a924>] (irq_exit+0x8c/0x94) from [<c0013a50>] (handle_IRQ+0x34/0x84) [ 79.699157] [<c0013a50>] (handle_IRQ+0x34/0x84) from [<c0008530>] (omap3_intc_handle_irq+0x48/0x4c) [ 79.708648] [<c0008530>] (omap3_intc_handle_irq+0x48/0x4c) from [<c037499c>] (__irq_usr+0x3c/0x60) [ 79.718048] Exception stack(0xcf281fb0 to 0xcf281ff8) [ 79.723358] 1fa0: 0001e6a0 be8dab00 0001e698 00036698 [ 79.731933] 1fc0: 0002df98 0002df38 0000001f 00000000 b6f234d0 00000000 00000004 00000000 [ 79.740509] 1fe0: 0001e6f8 be8d6aa0 be8dac50 0000aab8 80000010 ffffffff [ 79.747497] Unable to handle kernel NULL pointer dereference at virtual address 00000000 [ 79.756011] pgd = cf3b4000 [ 79.758850] [00000000] *pgd=8f0c7831, *pte=00000000, *ppte=00000000 [ 79.765502] Internal error: Oops: 80000007 [#1] [ 79.770294] Modules linked in: [ 79.773529] CPU: 0 Tainted: G W (3.3.0-rc6-00002-gb5d5c87 #421) [ 79.781066] PC is at 0x0 [ 79.783721] LR is at run_timer_softirq+0x16c/0x3ac [ 79.788787] pc : [<00000000>] lr : [<c0040aa4>] psr: 60000113 [ 79.788787] sp : cf281ee0 ip : 00000000 fp : cf280000 [ 79.800903] r10: 00000004 r9 : 00000100 r8 : b6f234d0 [ 79.806427] r7 : c0519c28 r6 : cf093488 r5 : c0561a00 r4 : 00000000 [ 79.813323] r3 : 00000000 r2 : c054eee0 r1 : 00000001 r0 : 00000000 [ 79.820190] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user [ 79.827728] Control: 10c5387d Table: 8f3b4019 DAC: 00000015 [ 79.833801] Process gpsd (pid: 1265, stack limit = 0xcf2802e8) [ 79.839965] Stack: (0xcf281ee0 to 0xcf282000) [ 79.844573] 1ee0: 00000002 00000000 c0040a24 00000000 00000002 cf281f08 00200200 00000000 [ 79.853210] 1f00: 00000000 cf281f18 cf281f08 00000000 00000000 00000000 cf281f18 cf281f18 [ 79.861816] 1f20: 00000000 00000001 c056184c 00000000 00000001 b6f234d0 c0561848 00000004 [ 79.870452] 1f40: cf280000 c003a3b8 c051e79c 00000001 00000000 00000100 3fa9e7b8 0000000a [ 79.879089] 1f60: 00000025 cf280000 00000025 00000000 00000000 b6f234d0 00000000 00000004 [ 79.887756] 1f80: 00000000 c003a924 c053ad38 c0013a50 fa200000 cf281fb0 ffffffff c0008530 [ 79.896362] 1fa0: 0001e6a0 0000aab8 80000010 c037499c 0001e6a0 be8dab00 0001e698 00036698 [ 79.904998] 1fc0: 0002df98 0002df38 0000001f 00000000 b6f234d0 00000000 00000004 00000000 [ 79.913665] 1fe0: 0001e6f8 be8d6aa0 be8dac50 0000aab8 80000010 ffffffff 00fbf700 04ffff00 [ 79.922302] [<c0040aa4>] (run_timer_softirq+0x16c/0x3ac) from [<c003a3b8>] (__do_softirq+0xd4/0x22c) [ 79.931945] [<c003a3b8>] (__do_softirq+0xd4/0x22c) from [<c003a924>] (irq_exit+0x8c/0x94) [ 79.940582] [<c003a924>] (irq_exit+0x8c/0x94) from [<c0013a50>] (handle_IRQ+0x34/0x84) [ 79.948913] [<c0013a50>] (handle_IRQ+0x34/0x84) from [<c0008530>] (omap3_intc_handle_irq+0x48/0x4c) [ 79.958404] [<c0008530>] (omap3_intc_handle_irq+0x48/0x4c) from [<c037499c>] (__irq_usr+0x3c/0x60) [ 79.967773] Exception stack(0xcf281fb0 to 0xcf281ff8) [ 79.973083] 1fa0: 0001e6a0 be8dab00 0001e698 00036698 [ 79.981658] 1fc0: 0002df98 0002df38 0000001f 00000000 b6f234d0 00000000 00000004 00000000 [ 79.990234] 1fe0: 0001e6f8 be8d6aa0 be8dac50 0000aab8 80000010 ffffffff [ 79.997161] Code: bad PC value [ 80.000396] ---[ end trace 6f6739840475f9ee ]--- [ 80.005279] Kernel panic - not syncing: Fatal exception in interrupt Signed-off-by: Johan Hovold <jhovold@gmail.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13Bluetooth: Fix l2cap conn failures for ssp devicesPeter Hurley
commit 18daf1644e634bae951a6e3d4d19d89170209762 upstream Commit 330605423c fixed l2cap conn establishment for non-ssp remote devices by not setting HCI_CONN_ENCRYPT_PEND every time conn security is tested (which was always returning failure on any subsequent security checks). However, this broke l2cap conn establishment for ssp remote devices when an ACL link was already established at SDP-level security. This fix ensures that encryption must be pending whenever authentication is also pending. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Tested-by: Daniel Wagner <daniel.wagner@bmw-carit.de> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2012-04-13mac80211: fix possible tid_rx->reorder_timer use after freeStanislaw Gruszka
commit d72308bff5c2fa207949a5925b020bce74495e33 upstream. Is possible that we will arm the tid_rx->reorder_timer after del_timer_sync() in ___ieee80211_stop_rx_ba_session(). We need to stop timer after RCU grace period finish, so move it to ieee80211_free_tid_rx(). Timer will not be armed again, as rcu_dereference(sta->ampdu_mlme.tid_rx[tid]) will return NULL. Debug object detected problem with the following warning: ODEBUG: free active (active state 0) object type: timer_list hint: sta_rx_agg_reorder_timer_expired+0x0/0xf0 [mac80211] Bug report (with all warning messages): https://bugzilla.redhat.com/show_bug.cgi?id=804007 Reported-by: "jan p. springer" <jsd@igroup.org> Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13rose_dev: fix memcpy-bug in rose_set_mac_addressdanborkmann@iogearbox.net
[ Upstream commit 81213b5e8ae68e204aa7a3f83c4f9100405dbff9 ] If both addresses equal, nothing needs to be done. If the device is down, then we simply copy the new address to dev->dev_addr. If the device is up, then we add another loopback device with the new address, and if that does not fail, we remove the loopback device with the old address. And only then, we update the dev->dev_addr. Signed-off-by: Daniel Borkmann <daniel.borkmann@tik.ee.ethz.ch> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02nfsd: don't allow zero length strings in cache_parse()Dan Carpenter
commit 6d8d17499810479eabd10731179c04b2ca22152f upstream. There is no point in passing a zero length string here and quite a few of that cache_parse() implementations will Oops if count is zero. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
