path: root/net
2007-06-03[ICMP]: Fix icmp_errors_use_inbound_ifaddr sysctlPatrick McHardy
Currently when icmp_errors_use_inbound_ifaddr is set and an ICMP error is sent after the packet passed through ip_output(), an address from the outgoing interface is chosen as ICMP source address since skb->dev doesn't point to the incoming interface anymore. Fix this by doing an interface lookup on rt->dst.iif and using that device. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-03[IPV4]: Fix "ipOutNoRoutes" counter error for TCP and UDPWei Dong
Signed-off-by: Wei Dong <weidong@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-03[NET] gso: Fix GSO feature mask in sk_setup_capsHerbert Xu
This isn't a bug just yet as only TCP uses sk_setup_caps for GSO. However, if and when UDP or something else starts using it this is likely to cause a problem if we forget to add software emulation for it at the same time. The problem is that right now we translate GSO emulation to the bitmask NETIF_F_GSO_MASK, which includes every protocol, even ones that we cannot emulate. This patch makes it provide only the ones that we can emulate. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-03[TCP]: Fix GSO ignorance of pkts_acked arg (cong.cntrl modules)Ilpo Järvinen
The code used to ignore GSO completely, passing either way too small or zero pkts_acked when GSO skb or part of it got ACKed. In addition, there is no need to calculate the value in the loop but simple arithmetics after the loop is sufficient. There is no need to handle SYN case specially because congestion control modules are not yet initialized when FLAG_SYN_ACKED is set. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-03[NET]: Fix comparisons of unsigned < 0.Bill Nottingham
Recent gcc versions emit warnings when unsigned variables are compared < 0 or >= 0. Signed-off-by: Bill Nottingham <notting@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-03[NET]: Make net watchdog timers 1 sec jiffy aligned.Venkatesh Pallipadi
round_jiffies for net dev watchdog timer. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-03[TCP]: Use default 32768-61000 outgoing port range in all cases.Mark Glines
This diff changes the default port range used for outgoing connections, from "use 32768-61000 in most cases, but use N-4999 on small boxes (where N is a multiple of 1024, depending on just *how* small the box is)" to just "use 32768-61000 in all cases". I don't believe there are any drawbacks to this change, and it keeps outgoing connection ports farther away from the mess of IANA-registered ports. Signed-off-by: Mark Glines <mark@glines.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-03[AF_UNIX]: Fix datagram connect race causing an OOPS.David S. Miller
Based upon an excellent bug report and initial patch by Frederik Deweerdt. The UNIX datagram connect code blindly dereferences other->sk_socket via the call down to the security_unix_may_send() function. Without locking 'other' that pointer can go NULL via unix_release_sock() which does sock_orphan() which also marks the socket SOCK_DEAD. So we have to lock both 'sk' and 'other' yet avoid all kinds of potential deadlocks (connect to self is OK for datagram sockets and it is possible for two datagram sockets to perform a simultaneous connect to each other). So what we do is have a "double lock" function similar to how we handle this situation in other areas of the kernel. We take the lock of the socket pointer with the smallest address first in order to avoid ABBA style deadlocks. Once we have them both locked, we check to see if SOCK_DEAD is set for 'other' and if so, drop everything and retry the lookup. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-03[AF_UNIX]: Make socket locking much less confusing.David S. Miller
The unix_state_*() locking macros imply that there is some rwlock kind of thing going on, but the implementation is actually a spinlock which makes the code more confusing than it needs to be. So use plain unix_state_lock and unix_state_unlock. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-03VLAN: kill_vid is only useful for VLAN filtering devicesStephen Hemminger
The interface for network device VLAN extension was confusing. The kill_vid function is only really useful for devices that do hardware filtering. Devices that only do VLAN receiption without filtering were being forced to provide the hook, and there were bugs in those devices. Many drivers had kill_vid routine that called vlan_group_set_device, with NULL, but that is done already. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-31Merge branch 'mac80211' of ↵David S. Miller
2007-05-31[BRIDGE]: Round off STP perodic timers.Stephen Hemminger
Peroidic STP timers don't have to be exact. The hold timer runs at 1HZ, and the hello timer normally runs at 2HZ; save power by aligning it them to next second. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-31[BRIDGE]: Reduce frequency of forwarding cleanup timer in bridge.Baruch Even
The bridge cleanup timer is fired 10 times a second for timers that are at least 15 seconds ahead in time and that are not critical to be cleaned asap. This patch calculates the next time to run the timer as the minimum of all timers or a minimum based on the current state. Signed-off-by: Baruch Even <baruch@ev-en.org> Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-31[TCP] tcp_probe: use GCC printf attributeStephen Hemminger
The function in tcp_probe is printf like, use GCC to check the args. Sighed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-31[TCP] tcp_probe: a trivial fix for mismatched number of printl arguments.Sangtae Ha
Just a fix to correct the number of printl arguments. Now, srtt is logging correctly. Signed-off-by: Sangtae Ha <sangtae.ha@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-31[TCP]: Consolidate checking for tcp orphan count being too big.Pavel Emelianov
tcp_out_of_resources() and tcp_close() perform the same checking of number of orphan sockets. Move this code into common place. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-31[AF_PACKET]: Kill CONFIG_PACKET_SOCKET.David S. Miller
Always set, but af_packet.c, not by the Kconfig subsystem, so just get rid of it. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-31[IPV6]: Fix build warning.David S. Miller
net/ipv6/ip6_fib.c: In function ‘fib6_add_rt2node’: net/ipv6/ip6_fib.c:661: warning: label ‘out’ defined but not used Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-31[AF_PACKET]: Kill bogus CONFIG_PACKET_MULTICASTDavid S. Miller
It is unconditionally set by af_packet.c, not by the Kconfig subsystem, so just kill it off. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-31[IPV4]: Kill references to bogus non-existent CONFIG_IP_NOSIOCRTDavid S. Miller
2007-05-31[IPSEC]: Fix panic when using inter address familiy IPsec on loopback.Kazunori MIYAZAWA
Signed-off-by: Kazunori MIYAZAWA <kazunori@miyazawa.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-31[NET]: parse ip:port strings correctly in in4_ptonJerome Borsboom
in4_pton converts a textual representation of an ip4 address into an integer representation. However, when the textual representation is of in the form ip:port, e.g. 192.168.1.1:5060, and 'delim' is set to -1, the function bails out with an error when reading the colon. It makes sense to allow the colon as a delimiting character without explicitly having to set it through the 'delim' variable as there can be no ambiguity in the point where the ip address is completely parsed. This function is indeed called from nf_conntrack_sip.c in this way to parse textual ip:port combinations which fails due to the reason stated above. Signed-off-by: Jerome Borsboom <j.borsboom@erasmusmc.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-31[IPV6] ROUTE: No longer handle ::/0 specially.YOSHIFUJI Hideaki
We do not need to handle ::/0 routes specially any longer. This should fix BUG #8349. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Acked-by: Yuji Sekiya <sekiya@wide.ad.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-31[IPSEC]: Fix IPv6 AH calculation in outboundKazunori MIYAZAWA
Signed-off-by: Kazunori MIYAZAWA <miyazawa@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-31[XFRM]: xfrm_larval_drop sysctl should be __read_mostly.David S. Miller
2007-05-31[XFRM]: Allow XFRM_ACQ_EXPIRES to be tunable via sysctl.David S. Miller
2007-05-29[PATCH] softmac: alloc_ieee80211() NULL checkAkinobu Mita
This patch adds missing NULL check and trims a line longer than 80 columns. Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Joe Jezak <josejx@gentoo.org> Cc: Daniel Drake <dsd@gentoo.org> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-05-29[PATCH] ieee80211: fix incomplete error messageAkinobu Mita
Fix error message: Unable to network device. --> Unable to allocate network device. Cc: James Ketrenos <jketreno@linux.intel.com> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-05-29[PATCH] mac80211: avoid null ptr deref in ieee80211_ibss_add_staJohn W. Linville
avoid sdata null pointer dereference in ieee80211_ibss_add_sta. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-05-29[PATCH] mac80211: always set carrier status on openMichael Wu
ieee80211_open should always set the carrier status since we may have set it to off before. Signed-off-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-05-29[PATCH] mac80211: fix memory leak when defrag fragmentsHong Liu
We forget to free all the fragments when defraging them into one packet. Signed-off-by: Hong Liu <hong.liu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-05-29[PATCH] mac80211: fail back to use associate from reassociateZhu Yi
Some APs have strict checking between associate and reassociate. In a case when an AP is restarted during a connection, it denies the mac80211 reassoc request since this is a new association for the AP. To fix this problem, we need to check the status code against WLAN_STATUS_REASSOC_NO_ASSOC and clear ifsta->prev_bssid_set in handling the association failure response. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-05-24[XFRM]: Allow packet drops during larval state resolution.David S. Miller
The current IPSEC rule resolution behavior we have does not work for a lot of people, even though technically it's an improvement from the -EAGAIN buisness we had before. Right now we'll block until the key manager resolves the route. That works for simple cases, but many folks would rather packets get silently dropped until the key manager resolves the IPSEC rules. We can't tell these folks to "set the socket non-blocking" because they don't have control over the non-block setting of things like the sockets used to resolve DNS deep inside of the resolver libraries in libc. With that in mind I coded up the patch below with some help from Herbert Xu which provides packet-drop behavior during larval state resolution, controllable via sysctl and off by default. This lays the framework to either: 1) Make this default at some point or... 2) Move this logic into xfrm{4,6}_policy.c and implement the ARP-like resolution queue we've all been dreaming of. The idea would be to queue packets to the policy, then once the larval state is resolved by the key manager we re-resolve the route and push the packets out. The packets would timeout if the rule didn't get resolved in a certain amount of time. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-24[NET]: "wrong timeout value" in sk_wait_data() v2Vasily Averin
sys_setsockopt() do not check properly timeout values for SO_RCVTIMEO/SO_SNDTIMEO, for example it's possible to set negative timeout values. POSIX do not defines behaviour for sys_setsockopt in case negative timeouts, but requires that setsockopt() shall fail with -EDOM if the send and receive timeout values are too big to fit into the timeout fields in the socket structure. In current implementation negative timeout can lead to error messages like "schedule_timeout: wrong timeout value". Proposed patch: - checks tv_usec and returns -EDOM if it is wrong - do not allows to set negative timeout values (sets 0 instead) and outputs ratelimited information message about such attempts. Signed-off-By: Vasily Averin <vvs@sw.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/holtmann/bluetooth-2.6David S. Miller
2007-05-24[NETFILTER]: nf_nat_h323: call set_h225_addr instead of set_h225_addr_hookJing Min Zhao
They're the same. Signed-off-by: Jing Min Zhao <zhaojingmin@vivecode.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-24[NETFILTER]: nf_conntrack_h323: add missing T.120 address in OLCAJing Min Zhao
Add missing process of T.120 address in OpenLogicalChannelAck signal. Signed-off-by: Jing Min Zhao <zhaojingmin@vivecode.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-24[NETFILTER]: nf_conntrack_h323: remove unnecessary process of Information signalJing Min Zhao
According to the implementation of H.323, it's not necessary to check the addresses in Information signals. Signed-off-by: Jing Min Zhao <zhaojingmin@vivecode.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-24[NETFILTER]: nf_conntrack_h323: fix get_h225_addr() for IPv6 address accessJing Min Zhao
Update get_h225_addr() to meet the changes in ASN.1 types. It was using field ip6 to access IPv6 TransportAddress, it should be ip according the ASN.1 definition. Signed-off-by: Jing Min Zhao <zhaojingmin@vivecode.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-24[NETFILTER]: nf_conntrack_h323: fix ASN.1 typesJing Min Zhao
1. Add support for decoding IPv6 address. I know it was manually added in the header file, but not in the template file. That wouldn't work. 2. Add missing support for decoding T.120 address in OLCA. 3. Remove unnecessary decoding of Information signal. Signed-off-by: Jing Min Zhao <zhaojingmin@vivecode.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-24[NETFILTER]: nf_conntrack_ftp: fix newline sequence number calculationPatrick McHardy
When the packet size is changed by the FTP NAT helper, the connection tracking helper adjusts the sequence number of the newline character by the size difference. This is wrong because NAT sequence number adjustment happens after helpers are called, so the unadjusted number is compared to the already adjusted one. Based on report by YU, Haitao <yuhaitao@tsinghua.org.cn> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-24[NETFILTER]: nf_conntrack_ftp: fix newline sequence number updatePatrick McHardy
When trying to locate the oldest entry in the history of newline character sequence numbers, the sequence number of the current entry is incorrectly compared with the index of the oldest sequence number instead of the number itself. Additionally it is not made sure that the current sequence number really is after the oldest known one. Based on report by YU, Haitao <yuhaitao@tsinghua.org.cn> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-24[NET_SCHED]: sch_htb: fix event cache time calculationPatrick McHardy
The event cache time must be an absolute value, when no event exists it is incorrectly set to 1s instead of 1s in the future. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-24[DCCP]: Fix build warning when debugging is disabled.David S. Miller
2007-05-24[TIPC]: Fixed erroneous introduction of for_each_netdevJon Paul Maloy
Signed-off-by: Jon Paul Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-24[RTNETLINK]: Fix sending netlink message when replace route.Milan Kocian
When you replace route via ip r r command the netlink multicast message is not send. This patch corrects it. NL message is sent with NLM_F_REPLACE flag. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=8320 Signed-off-by: Milan Kocian <milon@wq.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-24[TIPC]: Use menuconfig objects.Jan Engelhardt
Use menuconfigs instead of menus, so the whole menu can be disabled at once instead of going through all options. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-24[SCTP]: Use menuconfig objects.Jan Engelhardt
2007-05-24[IPVS]: Use menuconfig objects.Jan Engelhardt
Use menuconfigs instead of menus, so the whole menu can be disabled at once instead of going through all options. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Acked-by: Simon Horman <horms@verge.net.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-24[DCCP]: Use menuconfig objects.Jan Engelhardt
