commit 7eb71e0351fbb1b242ae70abb7bb17107fe2f792 upstream.
It turns out it's possible to get __remove_osd() called twice on the
same OSD. That doesn't sit well with rb_erase() - depending on the
shape of the tree we can get a NULL dereference, a soft lockup or
a random crash at some point in the future as we end up touching freed
memory. One scenario that I was able to reproduce is as follows:
<osd3 is idle, on the osd lru list>
<con reset - osd3>
con_fault_finish()
osd_reset()
<osdmap - osd3 down>
ceph_osdc_handle_map()
<takes map_sem>
kick_requests()
<takes request_mutex>
reset_changed_osds()
__reset_osd()
__remove_osd()
<releases request_mutex>
<releases map_sem>
<takes map_sem>
__kick_osd_requests()
__reset_osd()
__remove_osd() <-- !!!
A case can be made that osd refcounting is imperfect and reworking it
would be a proper resolution, but for now Sage and I decided to fix
this by adding a safe guard around __remove_osd().
Fixes: http://tracker.ceph.com/issues/8087
Cc: Sage Weil <sage@redhat.com>
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
Reviewed-by: Sage Weil <sage@redhat.com>
Reviewed-by: Alex Elder <elder@linaro.org>
commit cc9f1f518cec079289d11d732efa490306b1ddad upstream.
No reason to use BUG_ON for osd request list assertions.
Signed-off-by: Ilya Dryomov <idryomov@redhat.com>
commit 7c6e6fc53e7335570ed82f77656cedce1502744e upstream.
It is important that both regular and lingering requests lists are
empty when the OSD is removed.
Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com>
sctp_process_param
[ Upstream commit cfbf654efc6d78dc9812e030673b86f235bf677d ]
When making use of RFC5061, section 4.2.4. for setting the primary IP
address, we're passing a wrong parameter header to param_type2af(),
resulting always in NULL being returned.
At this point, param.p points to a sctp_addip_param struct, containing
a sctp_paramhdr (type = 0xc004, length = var), and crr_id as a correlation
id. Followed by that, as also presented in RFC5061 section 4.2.4., comes
the actual sctp_addr_param, which also contains a sctp_paramhdr, but
this time with the correct type SCTP_PARAM_IPV{4,6}_ADDRESS that
param_type2af() can make use of. Since we already hold a pointer to
addr_param from previous line, just reuse it for param_type2af().
Fixes: d6de3097592b ("[SCTP]: Add the handling of "Set Primary IP Address" parameter to INIT")
Signed-off-by: Saran Maruti Ramanara <saran.neti@telus.com>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit bdbbb8527b6f6a358dbcb70dac247034d665b8e4 ]
In commit be9f4a44e7d41 ("ipv4: tcp: remove per net tcp_sock")
I tried to address contention on a socket lock, but the solution
I chose was horrible :
commit 3a7c384ffd57e ("ipv4: tcp: unicast_sock should not land outside
of TCP stack") addressed a selinux regression.
commit 0980e56e506b ("ipv4: tcp: set unicast_sock uc_ttl to -1")
took care of another regression.
commit b5ec8eeac46 ("ipv4: fix ip_send_skb()") fixed another regression.
commit 811230cd85 ("tcp: ipv4: initialize unicast_sock sk_pacing_rate")
was another shot in the dark.
Really, just use a proper socket per cpu, and remove the skb_orphan()
call, to re-enable flow control.
This solves a serious problem with FQ packet scheduler when used in
hostile environments, as we do not want to allocate a flow structure
for every RST packet sent in response to a spoofed packet.
[ Upstream commit 811230cd853d62f09ed0addd0ce9a1b9b0e13fb5 ]
When I added sk_pacing_rate field, I forgot to initialize its value
in the per cpu unicast_sock used in ip_send_unicast_reply()
This means that for sch_fq users, RST packets, or ACK packets sent
on behalf of TIME_WAIT sockets might be sent to slowly or even dropped
once we reach the per flow limit.
Fixes: 95bd09eb2750 ("tcp: TSO packets automatic sizing")
[ Upstream commit 59ccaaaa49b5b096cdc1f16706a9f931416b2332 ]
Reported in: https://bugzilla.kernel.org/show_bug.cgi?id=92081
This patch avoids calling rtnl_notify if the device ndo_bridge_getlink
handler does not return any bytes in the skb.
Alternately, the skb->len check can be moved inside rtnl_notify.
For the bridge vlan case described in 92081, there is also a fix needed
in bridge driver to generate a proper notification. Will fix that in
subsequent patch.
v2: rebase patch on net tree
Signed-off-by: Roopa Prabhu <roopa@cumulusnetworks.com>
[ Upstream commit 6e9e16e6143b725662e47026a1d0f270721cdd24 ]
Lubomir Rintel reported that during replacing a route the interface
reference counter isn't correctly decremented.
To quote bug <https://bugzilla.kernel.org/show_bug.cgi?id=91941>:
| [root@rhel7-5 lkundrak]# sh -x lal
| + ip link add dev0 type dummy
| + ip link set dev0 up
| + ip link add dev1 type dummy
| + ip link set dev1 up
| + ip addr add 2001:db8:8086::2/64 dev dev0
| + ip route add 2001:db8:8086::/48 dev dev0 proto static metric 20
| + ip route add 2001:db8:8088::/48 dev dev1 proto static metric 10
| + ip route replace 2001:db8:8086::/48 dev dev1 proto static metric 20
| + ip link del dev0 type dummy
| Message from syslogd@rhel7-5 at Jan 23 10:54:41 ...
| kernel:unregister_netdevice: waiting for dev0 to become free. Usage count = 2
| Message from syslogd@rhel7-5 at Jan 23 10:54:51 ...
During replacement of a rt6_info we must walk all parent nodes and check
if the to be replaced rt6_info got propagated. If so, replace it with
an alive one.
Fixes: 4a287eba2de3957 ("IPv6 routing, NLM_F_* flag support: REPLACE and EXCL flags support, warn about missing CREATE flag")
Reported-by: Lubomir Rintel <lkundrak@v3.sk>
Tested-by: Lubomir Rintel <lkundrak@v3.sk>
[ Upstream commit fc752f1f43c1c038a2c6ae58cc739ebb5953ccb0 ]
An exception is seen in ICMP ping receive path where the skb
destructor sock_rfree() tries to access a freed socket. This happens
because ping_rcv() releases socket reference with sock_put() and this
internally frees up the socket. Later icmp_rcv() will try to free the
skb and as part of this, skb destructor is called and which leads
to a kernel panic as the socket is freed already in ping_rcv().
-->|exception
-007|sk_mem_uncharge
-007|sock_rfree
-008|skb_release_head_state
-009|skb_release_all
-009|__kfree_skb
-010|kfree_skb
-011|icmp_rcv
-012|ip_local_deliver_finish
Fix this incorrect free by cloning this skb and processing this cloned
skb instead.
This patch was suggested by Eric Dumazet
Signed-off-by: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org>
Cc: Eric Dumazet <edumazet@google.com>
[ Upstream commit 86f3cddbc3037882414c7308973530167906b7e9 ]
While working on rhashtable walking I noticed that the UDP diag
dumping code is buggy. In particular, the socket skipping within
a chain never happens, even though we record the number of sockets
that should be skipped.
As this code was supposedly copied from TCP, this patch does what
TCP does and resets num before we walk a chain.
Acked-by: Pavel Emelyanov <xemul@parallels.com>
[ Upstream commit df4d92549f23e1c037e83323aff58a21b3de7fe0 ]
Not caching dst_entries which cause redirects could be exploited by hosts
on the same subnet, causing a severe DoS attack. This effect aggravated
since commit f88649721268999 ("ipv4: fix dst race in sk_dst_get()").
Lookups causing redirects will be allocated with DST_NOCACHE set which
will force dst_release to free them via RCU. Unfortunately waiting for
RCU grace period just takes too long, we can end up with >1M dst_entries
waiting to be released and the system will run OOM. rcuos threads cannot
catch up under high softirq load.
Attaching the flag to emit a redirect later on to the specific skb allows
us to cache those dst_entries thus reducing the pressure on allocation
and deallocation.
This issue was discovered by Marcelo Leitner.
Cc: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Marcelo Leitner <mleitner@redhat.com>
Signed-off-by: Julian Anastasov <ja@ssi.bg>
[ Upstream commit 600ddd6825543962fb807884169e57b580dba208 ]
When hitting an INIT collision case during the 4WHS with AUTH enabled, as
already described in detail in commit 1be9a950c646 ("net: sctp: inherit
auth_capable on INIT collisions"), it can happen that we occasionally
still remotely trigger the following panic on server side which seems to
have been uncovered after the fix from commit 1be9a950c646 ...
[ 533.876389] BUG: unable to handle kernel paging request at 00000000ffffffff
[ 533.913657] IP: [<ffffffff811ac385>] __kmalloc+0x95/0x230
[ 533.940559] PGD 5030f2067 PUD 0
[ 533.957104] Oops: 0000 [#1] SMP
[ 533.974283] Modules linked in: sctp mlx4_en [...]
[ 534.939704] Call Trace:
[ 534.951833] [<ffffffff81294e30>] ? crypto_init_shash_ops+0x60/0xf0
[ 534.984213] [<ffffffff81294e30>] crypto_init_shash_ops+0x60/0xf0
[ 535.015025] [<ffffffff8128c8ed>] __crypto_alloc_tfm+0x6d/0x170
[ 535.045661] [<ffffffff8128d12c>] crypto_alloc_base+0x4c/0xb0
[ 535.074593] [<ffffffff8160bd42>] ? _raw_spin_lock_bh+0x12/0x50
[ 535.105239] [<ffffffffa0418c11>] sctp_inet_listen+0x161/0x1e0 [sctp]
[ 535.138606] [<ffffffff814e43bd>] SyS_listen+0x9d/0xb0
[ 535.166848] [<ffffffff816149a9>] system_call_fastpath+0x16/0x1b
... or depending on the the application, for example this one:
[ 1370.026490] BUG: unable to handle kernel paging request at 00000000ffffffff
[ 1370.026506] IP: [<ffffffff811ab455>] kmem_cache_alloc+0x75/0x1d0
[ 1370.054568] PGD 633c94067 PUD 0
[ 1370.070446] Oops: 0000 [#1] SMP
[ 1370.085010] Modules linked in: sctp kvm_amd kvm [...]
[ 1370.963431] Call Trace:
[ 1370.974632] [<ffffffff8120f7cf>] ? SyS_epoll_ctl+0x53f/0x960
[ 1371.000863] [<ffffffff8120f7cf>] SyS_epoll_ctl+0x53f/0x960
[ 1371.027154] [<ffffffff812100d3>] ? anon_inode_getfile+0xd3/0x170
[ 1371.054679] [<ffffffff811e3d67>] ? __alloc_fd+0xa7/0x130
[ 1371.080183] [<ffffffff816149a9>] system_call_fastpath+0x16/0x1b
With slab debugging enabled, we can see that the poison has been overwritten:
[ 669.826368] BUG kmalloc-128 (Tainted: G W ): Poison overwritten
[ 669.826385] INFO: 0xffff880228b32e50-0xffff880228b32e50. First byte 0x6a instead of 0x6b
[ 669.826414] INFO: Allocated in sctp_auth_create_key+0x23/0x50 [sctp] age=3 cpu=0 pid=18494
[ 669.826424] __slab_alloc+0x4bf/0x566
[ 669.826433] __kmalloc+0x280/0x310
[ 669.826453] sctp_auth_create_key+0x23/0x50 [sctp]
[ 669.826471] sctp_auth_asoc_create_secret+0xcb/0x1e0 [sctp]
[ 669.826488] sctp_auth_asoc_init_active_key+0x68/0xa0 [sctp]
[ 669.826505] sctp_do_sm+0x29d/0x17c0 [sctp] [...]
[ 669.826629] INFO: Freed in kzfree+0x31/0x40 age=1 cpu=0 pid=18494
[ 669.826635] __slab_free+0x39/0x2a8
[ 669.826643] kfree+0x1d6/0x230
[ 669.826650] kzfree+0x31/0x40
[ 669.826666] sctp_auth_key_put+0x19/0x20 [sctp]
[ 669.826681] sctp_assoc_update+0x1ee/0x2d0 [sctp]
[ 669.826695] sctp_do_sm+0x674/0x17c0 [sctp]
Since this only triggers in some collision-cases with AUTH, the problem at
heart is that sctp_auth_key_put() on asoc->asoc_shared_key is called twice
when having refcnt 1, once directly in sctp_assoc_update() and yet again
from within sctp_auth_asoc_init_active_key() via sctp_assoc_update() on
the already kzfree'd memory, which is also consistent with the observation
of the poison decrease from 0x6b to 0x6a (note: the overwrite is detected
at a later point in time when poison is checked on new allocation).
Reference counting of auth keys revisited:
Shared keys for AUTH chunks are being stored in endpoints and associations
in endpoint_shared_keys list. On endpoint creation, a null key is being
added; on association creation, all endpoint shared keys are being cached
and thus cloned over to the association. struct sctp_shared_key only holds
a pointer to the actual key bytes, that is, struct sctp_auth_bytes which
keeps track of users internally through refcounting. Naturally, on assoc
or enpoint destruction, sctp_shared_key are being destroyed directly and
the reference on sctp_auth_bytes dropped.
User space can add keys to either list via setsockopt(2) through struct
sctp_authkey and by passing that to sctp_auth_set_key() which replaces or
adds a new auth key. There, sctp_auth_create_key() creates a new sctp_auth_bytes
with refcount 1 and in case of replacement drops the reference on the old
sctp_auth_bytes. A key can be set active from user space through setsockopt()
on the id via sctp_auth_set_active_key(), which iterates through either
endpoint_shared_keys and in case of an assoc, invokes (one of various places)
sctp_auth_asoc_init_active_key().
sctp_auth_asoc_init_active_key() computes the actual secret from local's
and peer's random, hmac and shared key parameters and returns a new key
directly as sctp_auth_bytes, that is asoc->asoc_shared_key, plus drops
the reference if there was a previous one. The secret, which where we
eventually double drop the ref comes from sctp_auth_asoc_set_secret() with
intitial refcount of 1, which also stays unchanged eventually in
sctp_assoc_update(). This key is later being used for crypto layer to
set the key for the hash in crypto_hash_setkey() from sctp_auth_calculate_hmac().
To close the loop: asoc->asoc_shared_key is freshly allocated secret
material and independant of the sctp_shared_key management keeping track
of only shared keys in endpoints and assocs. Hence, also commit 4184b2a79a76
("net: sctp: fix memory leak in auth key management") is independant of
this bug here since it concerns a different layer (though same structures
being used eventually). asoc->asoc_shared_key is reference dropped correctly
on assoc destruction in sctp_association_free() and when active keys are
being replaced in sctp_auth_asoc_init_active_key(), it always has a refcount
of 1. Hence, it's freed prematurely in sctp_assoc_update(). Simple fix is
to remove that sctp_auth_key_put() from there which fixes these panics.
Fixes: 730fc3d05cd4 ("[SCTP]: Implete SCTP-AUTH parameter processing")
[ Upstream commit 9d289715eb5c252ae15bd547cb252ca547a3c4f2 ]
Reduce the attack vector and stop generating IPv6 Fragment Header for
paths with an MTU smaller than the minimum required IPv6 MTU
size (1280 byte) - called atomic fragments.
See IETF I-D "Deprecating the Generation of IPv6 Atomic Fragments" [1]
for more information and how this "feature" can be misused.
[1] https://tools.ietf.org/html/draft-ietf-6man-deprecate-atomfrag-generation-00
Signed-off-by: Fernando Gont <fgont@si6networks.com>
Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
[ Upstream commit ac64da0b83d82abe62f78b3d0e21cca31aea24fa ]
softnet_data.input_pkt_queue is protected by a spinlock that
we must hold when transferring packets from victim queue to an active
one. This is because other cpus could still be trying to enqueue packets
into victim queue.
A second problem is that when we transfert the NAPI poll_list from
victim to current cpu, we absolutely need to special case the percpu
backlog, because we do not want to add complex locking to protect
process_queue : Only owner cpu is allowed to manipulate it, unless cpu
is offline.
Based on initial patch from Prasad Sodagudi & Subash Abhinov
Kasiviswanathan.
This version is better because we do not slow down packet processing,
only make migration safer.
Reported-by: Prasad Sodagudi <psodagud@codeaurora.org>
Reported-by: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org>
Cc: Tom Herbert <therbert@google.com>
[ Upstream commit f812116b174e59a350acc8e4856213a166a91222 ]
The sockaddr is returned in IP(V6)_RECVERR as part of errhdr. That
structure is defined and allocated on the stack as
struct {
struct sock_extended_err ee;
struct sockaddr_in(6) offender;
} errhdr;
The second part is only initialized for certain SO_EE_ORIGIN values.
Always initialize it completely.
An MTU exceeded error on a SOCK_RAW/IPPROTO_RAW is one example that
would return uninitialized bytes.
Signed-off-by: Willem de Bruijn <willemb@google.com>
Also verified that there is no padding between errhdr.ee and
errhdr.offender that could leak additional kernel data.
commit 0fa7b39131576dd1baa6ca17fca53c65d7f62249 upstream.
In case userspace attempts to obtain key information for or delete a
unicast key, this is currently erroneously rejected unless the driver
sets the WIPHY_FLAG_IBSS_RSN flag. Apparently enough drivers do so it
was never noticed.
Fix that, and while at it fix a potential memory leak: the error path
in the get_key() function was placed after allocating a message but
didn't free it - move it to a better place. Luckily admin permissions
are needed to call this operation.
Fixes: e31b82136d1ad ("cfg80211/mac80211: allow per-station GTKs")
commit 3b05ac3824ed9648c0d9c02d51d9b54e4e7e874f upstream.
The app_tcp_pkt_out() function expects "*diff" to be set and ends up
using uninitialized data if CONFIG_IP_VS_IPV6 is turned on.
The same issue is there in app_tcp_pkt_in(). Thanks to Julian Anastasov
for noticing that.
Acked-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Simon Horman <horms@verge.net.au>
commit 2196937e12b1b4ba139806d132647e1651d655df upstream.
We could be reading 8 bytes into a 4 byte buffer here. It seems
harmless but adding a check is the right thing to do and it silences a
static checker warning.
Acked-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
commit 08f6f147773b23b765b94633a8eaa82e7defcf4c upstream.
The VHT supported channel width field is a two bit integer, not a
bitfield. cfg80211_chandef_usable() was interpreting it incorrectly and
ended up rejecting 160 MHz channel width if the driver indicated support
for both 160 and 80+80 MHz channels.
Fixes: 3d9d1d6656a73 ("nl80211/cfg80211: support VHT channel configuration")
(however, no real drivers had 160 MHz support it until 3.16)
Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com>
[ Upstream commit 843925f33fcc293d80acf2c5c8a78adf3344d49b ]
Thomas Jarosch reported IPsec TCP stalls when a PMTU event occurs.
In fact the problem was completely unrelated to IPsec. The bug is
also reproducible if you just disable TSO/GSO.
The problem is that when the MSS goes down, existing queued packet
on the TX queue that have not been transmitted yet all look like
TSO packets and get treated as such.
This then triggers a bug where tcp_mss_split_point tells us to
generate a zero-sized packet on the TX queue. Once that happens
we're screwed because the zero-sized packet can never be removed
by ACKs.
Fixes: 1485348d242 ("tcp: Apply device TSO segment limit earlier")
Reported-by: Thomas Jarosch <thomas.jarosch@intra2net.com>
Cheers,
available
[ Upstream commit a18e6a186f53af06937a2c268c72443336f4ab56 ]
Each mmap Netlink frame contains a status field which indicates
whether the frame is unused, reserved, contains data or needs to
be skipped. Both loads and stores may not be reordeded and must
complete before the status field is changed and another CPU might
pick up the frame for use. Use an smp_mb() to cover needs of both
types of callers to netlink_set_status(), callers which have been
reading data frame from the frame, and callers which have been
filling or releasing and thus writing to the frame.
- Example code path requiring a smp_rmb():
memcpy(skb->data, (void *)hdr + NL_MMAP_HDRLEN, hdr->nm_len);
netlink_set_status(hdr, NL_MMAP_STATUS_UNUSED);
- Example code path requiring a smp_wmb():
hdr->nm_uid = from_kuid(sk_user_ns(sk), NETLINK_CB(skb).creds.uid);
hdr->nm_gid = from_kgid(sk_user_ns(sk), NETLINK_CB(skb).creds.gid);
netlink_frame_flush_dcache(hdr);
netlink_set_status(hdr, NL_MMAP_STATUS_VALID);
Fixes: f9c228 ("netlink: implement memory mapped recvmsg()")
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
Signed-off-by: Thomas Graf <tgraf@suug.ch>
[ Upstream commit 4682a0358639b29cf69437ed909c6221f8c89847 ]
Checking the file f_count and the nlk->mapped count is not completely
sufficient to prevent the mmap'd area contents from changing from
under us during netlink mmap sendmsg() operations.
Be careful to sample the header's length field only once, because this
could change from under us as well.
Fixes: 5fd96123ee19 ("netlink: implement memory mapped sendmsg()")
Acked-by: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Thomas Graf <tgraf@suug.ch>
commit 28a9bc68124c319b2b3dc861e80828a8865fd1ba upstream.
When writing the code to allow per-station GTKs, I neglected to
take into account the management frame keys (index 4 and 5) when
freeing the station and only added code to free the first four
data frame keys.
Fix this by iterating the array of keys over the right length.
Fixes: e31b82136d1a ("cfg80211/mac80211: allow per-station GTKs")
commit d025933e29872cb1fe19fc54d80e4dfa4ee5779c upstream.
As multicast-frames can't be fragmented, "dot11MulticastReceivedFrameCount"
stopped being incremented after the use-after-free fix. Furthermore, the
RX-LED will be triggered by every multicast frame (which wouldn't happen
before) which wouldn't allow the LED to rest at all.
Fixes https://bugzilla.kernel.org/show_bug.cgi?id=89431 which also had the
patch.
Fixes: b8fff407a180 ("mac80211: fix use-after-free in defragmentation")
Signed-off-by: Andreas Müller <goo@stapelspeicher.org>
[rewrite commit message]
[ Upstream commit 9772b54c55266ce80c639a80aa68eeb908f8ecf5 ]
To accomodate for enough headroom for tunnels, use MAX_HEADER instead
of LL_MAX_HEADER. Robert reported that he has hit after roughly 40hrs
of trinity an skb_under_panic() via SCTP output path (see reference).
I couldn't reproduce it from here, but not using MAX_HEADER as elsewhere
in other protocols might be one possible cause for this.
In any case, it looks like accounting on chunks themself seems to look
good as the skb already passed the SCTP output path and did not hit
any skb_over_panic(). Given tunneling was enabled in his .config, the
headroom would have been expanded by MAX_HEADER in this case.
Reported-by: Robert Święcki <robert@swiecki.net>
Reference: https://lkml.org/lkml/2014/12/1/507
Fixes: 594ccc14dfe4d ("[SCTP] Replace incorrect use of dev_alloc_skb with alloc_skb in sctp_packet_transmit().")
[ Upstream commit e0ebde0e131b529fd721b24f62872def5ec3718c ]
rtnl_link_get_net() holds a reference on the 'struct net', we need to release
it in case of error.
CC: Eric W. Biederman <ebiederm@xmission.com>
Fixes: b51642f6d77b ("net: Enable a userns root rtnl calls that are safe for unprivilged users")
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com>
[ Upstream commit be6572fdb1bfbe23b2624d477de50af50b02f5d6 ]
When using GRE redirection in WCCP, it sets the wrong skb->protocol,
that is, ETH_P_IP instead of ETH_P_IPV6 for the encapuslated traffic.
Fixes: c12b395a4664 ("gre: Support GRE over IPv6")
Cc: Dmitry Kozlov <xeb@mail.ru>
Signed-off-by: Yuri Chislov <yuri.chislov@gmail.com>
Tested-by: Yuri Chislov <yuri.chislov@gmail.com>
[ Upstream commit 01462405f0c093b2f8dfddafcadcda6c9e4c5cdf ]
This fixes an old regression introduced by commit
b0d0d915 (ipx: remove the BKL).
When a recvmsg syscall blocks waiting for new data, no data can be sent on the
same socket with sendmsg because ipx_recvmsg() sleeps with the socket locked.
This breaks mars-nwe (NetWare emulator):
- the ncpserv process reads the request using recvmsg
- ncpserv forks and spawns nwconn
- ncpserv calls a (blocking) recvmsg and waits for new requests
- nwconn deadlocks in sendmsg on the same socket
Commit b0d0d915 has simply replaced BKL locking with
lock_sock/release_sock. Unlike now, BKL got unlocked while
sleeping, so a blocking recvmsg did not block a concurrent
sendmsg.
Only keep the socket locked while actually working with the socket data and
release it prior to calling skb_recv_datagram().
Signed-off-by: Jiri Bohac <jbohac@suse.cz>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
[ Upstream commit 49dd18ba4615eaa72f15c9087dea1c2ab4744cf5 ]
Trying to add an unreachable route incorrectly returns -ESRCH if
if custom FIB rules are present:
[root@localhost ~]# ip route add 74.125.31.199 dev eth0 via 1.2.3.4
RTNETLINK answers: Network is unreachable
[root@localhost ~]# ip rule add to 55.66.77.88 table 200
RTNETLINK answers: No such process
[root@localhost ~]#
Commit 83886b6b636173b206f475929e58fac75c6f2446 ("[NET]: Change "not found"
return value for rule lookup") changed fib_rules_lookup()
to use -ESRCH as a "not found" code internally, but for user space it
should be translated into -ENETUNREACH. Handle the translation centrally in
ipv4-specific fib_lookup(), leaving the DECnet case alone.
On a related note, commit b7a71b51ee37d919e4098cd961d59a883fd272d8
("ipv4: removed redundant conditional") removed a similar translation from
ip_route_input_slow() prematurely AIUI.
Fixes: b7a71b51ee37 ("ipv4: removed redundant conditional")
Signed-off-by: Panu Matilainen <pmatilai@redhat.com>
commit 9de7922bc709eee2f609cd01d98aaedc4cf5ea74 upstream.
Commit 6f4c618ddb0 ("SCTP : Add paramters validity check for
ASCONF chunk") added basic verification of ASCONF chunks, however,
it is still possible to remotely crash a server by sending a
special crafted ASCONF chunk, even up to pre 2.6.12 kernels:
skb_over_panic: text:ffffffffa01ea1c3 len:31056 put:30768
head:ffff88011bd81800 data:ffff88011bd81800 tail:0x7950
end:0x440 dev:<NULL>
kernel BUG at net/core/skbuff.c:129!
Call Trace:
<IRQ>
[<ffffffff8144fb1c>] skb_put+0x5c/0x70
[<ffffffffa01ea1c3>] sctp_addto_chunk+0x63/0xd0 [sctp]
[<ffffffffa01eadaf>] sctp_process_asconf+0x1af/0x540 [sctp]
[<ffffffff8152d025>] ? _read_unlock_bh+0x15/0x20
[<ffffffffa01e0038>] sctp_sf_do_asconf+0x168/0x240 [sctp]
[<ffffffffa01e3751>] sctp_do_sm+0x71/0x1210 [sctp]
[<ffffffff8147645d>] ? fib_rules_lookup+0xad/0xf0
[<ffffffffa01e6b22>] ? sctp_cmp_addr_exact+0x32/0x40 [sctp]
[<ffffffffa01e8393>] sctp_assoc_bh_rcv+0xd3/0x180 [sctp]
[<ffffffffa01ee986>] sctp_inq_push+0x56/0x80 [sctp]
[<ffffffffa01fcc42>] sctp_rcv+0x982/0xa10 [sctp]
[<ffffffffa01d5123>] ? ipt_local_in_hook+0x23/0x28 [iptable_filter]
[<ffffffff8148bdc9>] ? nf_iterate+0x69/0xb0
[<ffffffff81496d10>] ? ip_local_deliver_finish+0x0/0x2d0
[<ffffffff8148bf86>] ? nf_hook_slow+0x76/0x120
[<ffffffff81496ded>] ip_local_deliver_finish+0xdd/0x2d0
[<ffffffff81497078>] ip_local_deliver+0x98/0xa0
[<ffffffff8149653d>] ip_rcv_finish+0x12d/0x440
[<ffffffff81496ac5>] ip_rcv+0x275/0x350
[<ffffffff8145c88b>] __netif_receive_skb+0x4ab/0x750
[<ffffffff81460588>] netif_receive_skb+0x58/0x60
This can be triggered e.g., through a simple scripted nmap
connection scan injecting the chunk after the handshake, for
example, ...
-------------- INIT[ASCONF; ASCONF_ACK] ------------->
<----------- INIT-ACK[ASCONF; ASCONF_ACK] ------------
-------------------- COOKIE-ECHO -------------------->
<-------------------- COOKIE-ACK ---------------------
------------------ ASCONF; UNKNOWN ------------------>
... where ASCONF chunk of length 280 contains 2 parameters ...
1) Add IP address parameter (param length: 16)
2) Add/del IP address parameter (param length: 255)
... followed by an UNKNOWN chunk of e.g. 4 bytes. Here, the
Address Parameter in the ASCONF chunk is even missing, too.
This is just an example and similarly-crafted ASCONF chunks
could be used just as well.
The ASCONF chunk passes through sctp_verify_asconf() as all
parameters passed sanity checks, and after walking, we ended
up successfully at the chunk end boundary, and thus may invoke
sctp_process_asconf(). Parameter walking is done with
WORD_ROUND() to take padding into account.
In sctp_process_asconf()'s TLV processing, we may fail in
sctp_process_asconf_param() e.g., due to removal of the IP
address that is also the source address of the packet containing
the ASCONF chunk, and thus we need to add all TLVs after the
failure to our ASCONF response to remote via helper function
sctp_add_asconf_response(), which basically invokes a
sctp_addto_chunk() adding the error parameters to the given
skb.
When walking to the next parameter this time, we proceed
with ...
length = ntohs(asconf_param->param_hdr.length);
asconf_param = (void *)asconf_param + length;
... instead of the WORD_ROUND()'ed length, thus resulting here
in an off-by-one that leads to reading the follow-up garbage
parameter length of 12336, and thus throwing an skb_over_panic
for the reply when trying to sctp_addto_chunk() next time,
which implicitly calls the skb_put() with that length.
Fix it by using sctp_walk_params() [ which is also used in
INIT parameter processing ] macro in the verification *and*
in ASCONF processing: it will make sure we don't spill over,
that we walk parameters WORD_ROUND()'ed. Moreover, we're being
more defensive and guard against unknown parameter types and
missized addresses.
Joint work with Vlad Yasevich.
Fixes: b896b82be4ae ("[SCTP] ADDIP: Support for processing incoming ASCONF_ACK chunks.")
Signed-off-by: Vlad Yasevich <vyasevich@gmail.com>
Cc: Josh Boyer <jwboyer@fedoraproject.org>
commit b69040d8e39f20d5215a03502a8e8b4c6ab78395 upstream.
When receiving a e.g. semi-good formed connection scan in the
form of ...
---------------- ASCONF_a; ASCONF_b ----------------->
... where ASCONF_a equals ASCONF_b chunk (at least both serials
need to be equal), we panic an SCTP server!
The problem is that good-formed ASCONF chunks that we reply with
ASCONF_ACK chunks are cached per serial. Thus, when we receive a
same ASCONF chunk twice (e.g. through a lost ASCONF_ACK), we do
not need to process them again on the server side (that was the
idea, also proposed in the RFC). Instead, we know it was cached
and we just resend the cached chunk instead. So far, so good.
Where things get nasty is in SCTP's side effect interpreter, that
is, sctp_cmd_interpreter():
While incoming ASCONF_a (chunk = event_arg) is being marked
!end_of_packet and !singleton, and we have an association context,
we do not flush the outqueue the first time after processing the
ASCONF_ACK singleton chunk via SCTP_CMD_REPLY. Instead, we keep it
queued up, although we set local_cork to 1. Commit 2e3216cd54b1
changed the precedence, so that as long as we get bundled, incoming
chunks we try possible bundling on outgoing queue as well. Before
this commit, we would just flush the output queue.
Now, while ASCONF_a's ASCONF_ACK sits in the corked outq, we
continue to process the same ASCONF_b chunk from the packet. As
we have cached the previous ASCONF_ACK, we find it, grab it and
do another SCTP_CMD_REPLY command on it. So, effectively, we rip
the chunk->list pointers and requeue the same ASCONF_ACK chunk
another time. Since we process ASCONF_b, it's correctly marked
with end_of_packet and we enforce an uncork, and thus flush, thus
crashing the kernel.
Fix it by testing if the ASCONF_ACK is currently pending and if
that is the case, do not requeue it. When flushing the output
queue we may relink the chunk for preparing an outgoing packet,
but eventually unlink it when it's copied into the skb right
before transmission.
Fixes: 2e3216cd54b1 ("sctp: Follow security requirement of responding with 1 packet")
commit 26b87c7881006311828bb0ab271a551a62dcceb4 upstream.
This scenario is not limited to ASCONF, just taken as one
example triggering the issue. When receiving ASCONF probes
in the form of ...
---- ASCONF_a; [ASCONF_b; ...; ASCONF_n;] JUNK ------>
---- ASCONF_m; [ASCONF_o; ...; ASCONF_z;] JUNK ------>
... where ASCONF_a, ASCONF_b, ..., ASCONF_z are good-formed
ASCONFs and have increasing serial numbers, we process such
ASCONF chunk(s) marked with !end_of_packet and !singleton,
since we have not yet reached the SCTP packet end. SCTP does
only do verification on a chunk by chunk basis, as an SCTP
packet is nothing more than just a container of a stream of
chunks which it eats up one by one.
We could run into the case that we receive a packet with a
malformed tail, above marked as trailing JUNK. All previous
chunks are here goodformed, so the stack will eat up all
previous chunks up to this point. In case JUNK does not fit
into a chunk header and there are no more other chunks in
the input queue, or in case JUNK contains a garbage chunk
header, but the encoded chunk length would exceed the skb
tail, or we came here from an entirely different scenario
and the chunk has pdiscard=1 mark (without having had a flush
point), it will happen, that we will excessively queue up
the association's output queue (a correct final chunk may
then turn it into a response flood when flushing the
queue ;)): I ran a simple script with incremental ASCONF
serial numbers and could see the server side consuming
excessive amount of RAM [before/after: up to 2GB and more].
The issue at heart is that the chunk train basically ends
with !end_of_packet and !singleton markers and since commit
with 1 packet") therefore preventing an output queue flush
point in sctp_do_sm() -> sctp_cmd_interpreter() on the input
chunk (chunk = event_arg) even though local_cork is set,
but its precedence has changed since then. In the normal
case, the last chunk with end_of_packet=1 would trigger the
queue flush to accommodate possible outgoing bundling.
In the input queue, sctp_inq_pop() seems to do the right thing
in terms of discarding invalid chunks. So, above JUNK will
not enter the state machine and instead be released and exit
the sctp_assoc_bh_rcv() chunk processing loop. It's simply
the flush point being missing at loop exit. Adding a try-flush
approach on the output queue might not work as the underlying
infrastructure might be long gone at this point due to the
side-effect interpreter run.
One possibility, albeit a bit of a kludge, would be to defer
invalid chunk freeing into the state machine in order to
possibly trigger packet discards and thus indirectly a queue
flush on error. It would surely be better to discard chunks
as in the current, perhaps better controlled environment, but
going back and forth, it's simply architecturally not possible.
I tried various trailing JUNK attack cases and it seems to
look good now.
commit 859828c0ea476b42f3a93d69d117aaba90994b6f upstream.
br_stp_rcv() is reached by non-rx_handler path. That means there is no
guarantee that dev is bridge port and therefore simple NULL check of
->rx_handler_data is not enough. There is need to check if dev is really
bridge port and since only rcu read lock is held here, do it by checking
->rx_handler pointer.
Note that synchronize_net() in netdev_rx_handler_unregister() ensures
this approach as valid.
Introduced originally by:
commit f350a0a87374418635689471606454abc7beaa3a
"bridge: use rx_handler_data pointer to store net_bridge_port pointer"
Fixed but not in the best way by:
commit b5ed54e94d324f17c97852296d61a143f01b227a
"bridge: fix RCU races with bridge port"
Reintroduced by:
commit 716ec052d2280d511e10e90ad54a86f5b5d4dcc2
"bridge: fix NULL pointer deref of br_port_get_rcu"
Please apply to stable trees as well. Thanks.
RH bugzilla reference: https://bugzilla.redhat.com/show_bug.cgi?id=1025770
Reported-by: Laine Stump <laine@redhat.com>
Debugged-by: Michael S. Tsirkin <mst@redhat.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
Cc: Andrew Collins <bsderandrew@gmail.com>
commit 945b2b2d259d1a4364a2799e80e8ff32f8c6ee6f upstream.
Quoting Samu Kallio:
Basically what's happening is, during netns cleanup,
nf_nat_net_exit gets called before ipv4_net_exit. As I understand
it, nf_nat_net_exit is supposed to kill any conntrack entries which
have NAT context (through nf_ct_iterate_cleanup), but for some
reason this doesn't happen (perhaps something else is still holding
refs to those entries?).
When ipv4_net_exit is called, conntrack entries (including those
with NAT context) are cleaned up, but the
nat_bysource hashtable is long gone - freed in nf_nat_net_exit. The
bug happens when attempting to free a conntrack entry whose NAT hash
'prev' field points to a slot in the freed hash table (head for that
bin).
We ignore conntracks with null nat bindings. But this is wrong,
as these are in bysource hash table as well.
Restore nat-cleaning for the netns-is-being-removed case.
bug:
https://bugzilla.kernel.org/show_bug.cgi?id=65191
Fixes: c2d421e1718 ('netfilter: nf_nat: fix race when unloading protocol modules')
Reported-by: Samu Kallio <samu.kallio@aberdeencloud.com>
Debugged-by: Samu Kallio <samu.kallio@aberdeencloud.com>
Tested-by: Samu Kallio <samu.kallio@aberdeencloud.com>
[samu.kallio@aberdeencloud.com: backport to 3.10-stable]
Signed-off-by: Samu Kallio <samu.kallio@aberdeencloud.com>
commit b51d3fa364885a2c1e1668f88776c67c95291820 upstream.
The kernel should reserve enough room in the skb so that the DONE
message can always be appended. However, in case of e.g. new attribute
erronously not being size-accounted for, __nfulnl_send() will still
try to put next nlmsg into this full skbuf, causing the skb to be stuck
forever and blocking delivery of further messages.
Fix issue by releasing skb immediately after nlmsg_put error and
WARN() so we can track down the cause of such size mismatch.
[ fw@strlen.de: add tailroom/len info to WARN ]
Signed-off-by: Houcheng Lin <houcheng@gmail.com>
commit c1e7dc91eed0ed1a51c9b814d648db18bf8fc6e9 upstream.
don't try to queue payloads > 0xffff - NLA_HDRLEN, it does not work.
The nla length includes the size of the nla struct, so anything larger
results in u16 integer overflow.
This patch is similar to
9cefbbc9c8f9abe (netfilter: nfnetlink_queue: cleanup copy_range usage).
commit 9dfa1dfe4d5e5e66a991321ab08afe69759d797a upstream.
We currently neither account for the nlattr size, nor do we consider
the size of the trailing NLMSG_DONE when allocating nlmsg skb.
This can result in nflog to stop working, as __nfulnl_send() re-tries
sending forever if it failed to append NLMSG_DONE (which will never
work if buffer is not large enough).
Reported-by: Houcheng Lin <houcheng@gmail.com>
commit b8fff407a180286aa683d543d878d98d9fc57b13 upstream.
Upon receiving the last fragment, all but the first fragment
are freed, but the multicast check for statistics at the end
of the function refers to the current skb (the last fragment)
causing a use-after-free bug.
Since multicast frames cannot be fragmented and we check for
this early in the function, just modify that check to also
do the accounting to fix the issue.
Reported-by: Yosef Khyal <yosefx.khyal@intel.com>
commit aaef31703a0cf6a733e651885bfb49edc3ac6774 upstream.
Large (greater than 32k, the value of PAGE_ALLOC_COSTLY_ORDER) auth
tickets will have their buffers vmalloc'ed, which leads to the
following crash in crypto:
[ 28.685082] BUG: unable to handle kernel paging request at ffffeb04000032c0
[ 28.686032] IP: [<ffffffff81392b42>] scatterwalk_pagedone+0x22/0x80
[ 28.686032] PGD 0
[ 28.688088] Oops: 0000 [#1] PREEMPT SMP
[ 28.688088] Modules linked in:
[ 28.688088] CPU: 0 PID: 878 Comm: kworker/0:2 Not tainted 3.17.0-vm+ #305
[ 28.688088] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2007
[ 28.688088] Workqueue: ceph-msgr con_work
[ 28.688088] task: ffff88011a7f9030 ti: ffff8800d903c000 task.ti: ffff8800d903c000
[ 28.688088] RIP: 0010:[<ffffffff81392b42>] [<ffffffff81392b42>] scatterwalk_pagedone+0x22/0x80
[ 28.688088] RSP: 0018:ffff8800d903f688 EFLAGS: 00010286
[ 28.688088] RAX: ffffeb04000032c0 RBX: ffff8800d903f718 RCX: ffffeb04000032c0
[ 28.688088] RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffff8800d903f750
[ 28.688088] RBP: ffff8800d903f688 R08: 00000000000007de R09: ffff8800d903f880
[ 28.688088] R10: 18df467c72d6257b R11: 0000000000000000 R12: 0000000000000010
[ 28.688088] R13: ffff8800d903f750 R14: ffff8800d903f8a0 R15: 0000000000000000
[ 28.688088] FS: 00007f50a41c7700(0000) GS:ffff88011fc00000(0000) knlGS:0000000000000000
[ 28.688088] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 28.688088] CR2: ffffeb04000032c0 CR3: 00000000da3f3000 CR4: 00000000000006b0
[ 28.688088] Stack:
[ 28.688088] ffff8800d903f698 ffffffff81392ca8 ffff8800d903f6e8 ffffffff81395d32
[ 28.688088] ffff8800dac96000 ffff880000000000 ffff8800d903f980 ffff880119b7e020
[ 28.688088] ffff880119b7e010 0000000000000000 0000000000000010 0000000000000010
[ 28.688088] Call Trace:
[ 28.688088] [<ffffffff81392ca8>] scatterwalk_done+0x38/0x40
[ 28.688088] [<ffffffff81395d32>] blkcipher_walk_done+0x182/0x220
[ 28.688088] [<ffffffff813990bf>] crypto_cbc_encrypt+0x15f/0x180
[ 28.688088] [<ffffffff81399780>] ? crypto_aes_set_key+0x30/0x30
[ 28.688088] [<ffffffff8156c40c>] ceph_aes_encrypt2+0x29c/0x2e0
[ 28.688088] [<ffffffff8156d2a3>] ceph_encrypt2+0x93/0xb0
[ 28.688088] [<ffffffff8156d7da>] ceph_x_encrypt+0x4a/0x60
[ 28.688088] [<ffffffff8155b39d>] ? ceph_buffer_new+0x5d/0xf0
[ 28.688088] [<ffffffff8156e837>] ceph_x_build_authorizer.isra.6+0x297/0x360
[ 28.688088] [<ffffffff8112089b>] ? kmem_cache_alloc_trace+0x11b/0x1c0
[ 28.688088] [<ffffffff8156b496>] ? ceph_auth_create_authorizer+0x36/0x80
[ 28.688088] [<ffffffff8156ed83>] ceph_x_create_authorizer+0x63/0xd0
[ 28.688088] [<ffffffff8156b4b4>] ceph_auth_create_authorizer+0x54/0x80
[ 28.688088] [<ffffffff8155f7c0>] get_authorizer+0x80/0xd0
[ 28.688088] [<ffffffff81555a8b>] prepare_write_connect+0x18b/0x2b0
[ 28.688088] [<ffffffff81559289>] try_read+0x1e59/0x1f10
This is because we set up crypto scatterlists as if all buffers were
kmalloc'ed. Fix it.
[ Upstream commit 4184b2a79a7612a9272ce20d639934584a1f3786 ]
A very minimal and simple user space application allocating an SCTP
socket, setting SCTP_AUTH_KEY setsockopt(2) on it and then closing
the socket again will leak the memory containing the authentication
key from user space:
unreferenced object 0xffff8800837047c0 (size 16):
comm "a.out", pid 2789, jiffies 4296954322 (age 192.258s)
hex dump (first 16 bytes):
01 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<ffffffff816d7e8e>] kmemleak_alloc+0x4e/0xb0
[<ffffffff811c88d8>] __kmalloc+0xe8/0x270
[<ffffffffa0870c23>] sctp_auth_create_key+0x23/0x50 [sctp]
[<ffffffffa08718b1>] sctp_auth_set_key+0xa1/0x140 [sctp]
[<ffffffffa086b383>] sctp_setsockopt+0xd03/0x1180 [sctp]
[<ffffffff815bfd94>] sock_common_setsockopt+0x14/0x20
[<ffffffff815beb61>] SyS_setsockopt+0x71/0xd0
[<ffffffff816e58a9>] system_call_fastpath+0x12/0x17
[<ffffffffffffffff>] 0xffffffffffffffff
This is bad because of two things, we can bring down a machine from
user space when auth_enable=1, but also we would leave security sensitive
keying material in memory without clearing it after use. The issue is
that sctp_auth_create_key() already sets the refcount to 1, but after
allocation sctp_auth_set_key() does an additional refcount on it, and
thus leaving it around when we free the socket.
Fixes: 65b07e5d0d0 ("[SCTP]: API updates to suport SCTP-AUTH extensions.")
Cc: Vlad Yasevich <vyasevich@gmail.com>
packet
[ Upstream commit e40607cbe270a9e8360907cb1e62ddf0736e4864 ]
An SCTP server doing ASCONF will panic on malformed INIT ping-of-death
in the form of:
------------ INIT[PARAM: SET_PRIMARY_IP] ------------>
While the INIT chunk parameter verification dissects through many things
in order to detect malformed input, it misses to actually check parameters
inside of parameters. E.g. RFC5061, section 4.2.4 proposes a 'set primary
IP address' parameter in ASCONF, which has as a subparameter an address
parameter.
So an attacker may send a parameter type other than SCTP_PARAM_IPV4_ADDRESS
or SCTP_PARAM_IPV6_ADDRESS, param_type2af() will subsequently return 0
and thus sctp_get_af_specific() returns NULL, too, which we then happily
dereference unconditionally through af->from_addr_param().
The trace for the log:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000078
IP: [<ffffffffa01e9c62>] sctp_process_init+0x492/0x990 [sctp]
PGD 0
Oops: 0000 [#1] SMP
Pid: 0, comm: swapper Not tainted 2.6.32-504.el6.x86_64 #1 Bochs Bochs
RIP: 0010:[<ffffffffa01e9c62>] [<ffffffffa01e9c62>] sctp_process_init+0x492/0x990 [sctp]
Call Trace:
<IRQ>
[<ffffffffa01f2add>] ? sctp_bind_addr_copy+0x5d/0xe0 [sctp]
[<ffffffffa01e1fcb>] sctp_sf_do_5_1B_init+0x21b/0x340 [sctp]
[<ffffffffa01e5c09>] ? sctp_endpoint_lookup_assoc+0xc9/0xf0 [sctp]
[<ffffffffa01e61f6>] sctp_endpoint_bh_rcv+0x116/0x230 [sctp]
A minimal way to address this is to check for NULL as we do on all
other such occasions where we know sctp_get_af_specific() could
possibly return with NULL.
[ Upstream commit f03eb128e3f4276f46442d14f3b8f864f3775821 ]
Otherwise it gets overwritten by register_netdev().
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit 6c6151daaf2d8dc2046d9926539feed5f66bf74e ]
ip6_tnl_dev_init() sets the dev->iflink via a call to
ip6_tnl_link_config(). After that, register_netdevice()
sets dev->iflink = -1. So we loose the iflink configuration
for ipv6 tunnels. Fix this by using ip6_tnl_dev_init() as the
ndo_init function. Then ip6_tnl_dev_init() is called after
dev->iflink is set to -1 from register_netdevice().
commit f9865f06f7f18c6661c88d0511f05c48612319cc upstream.
Commit f363e45fd118 ("net/ceph: make ceph_msgr_wq non-reentrant")
effectively removed WQ_MEM_RECLAIM flag from ceph_msgr_wq. This is
wrong - libceph is very much a memory reclaim path, so restore it.
Tested-by: Micha Krause <micha@krausam.de>
commit c7abf25af0f41be4b50d44c5b185d52eea360cb8 upstream.
It affects non-(V)HT rates and can lead to selecting an rts_cts rate
that is not a basic rate or way superior to the reference rate (ATM
rates[0] used for the 1st attempt of the protected frame data).
E.g, assuming drivers register growing (bitrate) sorted tables of
ieee80211_rate-s, having :
- rates[0].idx == d'2 and basic_rates == b'10100
will select rts_cts idx b'10011 & ~d'(BIT(2)-1), i.e. 1, likewise
- rates[0].idx == d'2 and basic_rates == b'10001
will select rts_cts idx b'10000
The first is not a basic rate and the second is > rates[0].
Also, wrt severity of the addressed misbehavior, ATM we only have one
rts_cts_rate_idx rather than one per rate table entry, so this idx might
still point to bitrates > rates[1..MAX_RATES].
Fixes: 5253ffb8c9e1 ("mac80211: always pick a basic rate to tx RTS/CTS for pre-HT rates")
Signed-off-by: Karl Beldan <karl.beldan@rivierawaves.com>
commit 24dff96a37a2ca319e75a74d3929b2de22447ca6 upstream.
we used to check for "nobody else could start doing anything with
that opened file" by checking that refcount was 2 or less - one
for descriptor table and one we'd acquired in fget() on the way to
wherever we are. That was race-prone (somebody else might have
had a reference to descriptor table and do fget() just as we'd
been checking) and it had become flat-out incorrect back when
we switched to fget_light() on those codepaths - unlike fget(),
it doesn't grab an extra reference unless the descriptor table
is shared. The same change allowed a race-free check, though -
we are safe exactly when refcount is less than 2.
It was a long time ago; pre-2.6.12 for ioctl() (the codepath leading
to ppp one) and 2.6.17 for sendmsg() (netlink one). OTOH,
netlink hadn't grown that check until 3.9 and ppp used to live
in drivers/net, not drivers/net/ppp until 3.1. The bug existed
well before that, though, and the same fix used to apply in old
location of file.
[ Upstream commit 4062090e3e5caaf55bed4523a69f26c3265cc1d2 ]
ip_setup_cork() called inside ip_append_data() steals dst entry from rt to cork
and in case errors in __ip_append_data() nobody frees stolen dst entry
Fixes: 2e77d89b2fa8 ("net: avoid a pair of dst_hold()/dst_release() in ip_append_data()")
Signed-off-by: Vasily Averin <vvs@parallels.com>
[ Upstream commit f76936d07c4eeb36d8dbb64ebd30ab46ff85d9f7 ]
fib_nh_match does not match nexthops correctly. Example:
ip route add 172.16.10/24 nexthop via 192.168.122.12 dev eth0 \
nexthop via 192.168.122.13 dev eth0
ip route del 172.16.10/24 nexthop via 192.168.122.14 dev eth0 \
nexthop via 192.168.122.15 dev eth0
Del command is successful and route is removed. After this patch
applied, the route is correctly matched and result is:
Please consider this for stable trees as well.
Fixes: 4e902c57417c4 ("[IPv4]: FIB configuration using struct fib_config")
[ Upstream commit 33d99113b1102c2d2f8603b9ba72d89d915c13f5 ]
commit 25fb6ca4ed9cad72f14f61629b68dc03c0d9713f
"net IPv6 : Fix broken IPv6 routing table after loopback down-up"
allocates addrconf router for ipv6 address when lo device up.
but commit a881ae1f625c599b460cc8f8a7fcb1c438f699ad
"ipv6:don't call addrconf_dst_alloc again when enable lo" breaks
this behavior.
Since the addrconf router is moved to the garbage list when
lo device down, we should release this router and rellocate
a new one for ipv6 address when lo device up.
This patch solves bug 67951 on bugzilla
https://bugzilla.kernel.org/show_bug.cgi?id=67951
change from v1:
use ip6_rt_put to repleace ip6_del_rt, thanks Hannes!
change code style, suggested by Sergei.
CC: Sabrina Dubroca <sd@queasysnail.net>
CC: Hannes Frederic Sowa <hannes@stressinduktion.org>
Reported-by: Weilong Chen <chenweilong@huawei.com>
Signed-off-by: Weilong Chen <chenweilong@huawei.com>
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
[ Upstream commit bef1909ee3ed1ca39231b260a8d3b4544ecd0c8f ]
Fix to a problem observed when losing a FIN segment that does not
contain data. In such situations, TLP is unable to recover from
*any* tail loss and instead adds at least PTO ms to the
retransmission process, i.e., RTO = RTO + PTO.
Signed-off-by: Per Hurtig <per.hurtig@kau.se>
Acked-by: Nandita Dukkipati <nanditad@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
