path: root/net
2016-05-18nf_conntrack: avoid kernel pointer value leak in slab nameLinus Torvalds
commit 31b0b385f69d8d5491a4bca288e25e63f1d945d0 upstream. The slab name ends up being visible in the directory structure under /sys, and even if you don't have access rights to the file you can see the filenames. Just use a 64-bit counter instead of the pointer to the 'net' structure to generate a unique name. This code will go away in 4.7 when the conntrack code moves to a single kmemcache, but this is the backportable simple solution to avoiding leaking kernel pointers to user space. Fixes: 5b3501faa874 ("netfilter: nf_conntrack: per netns nf_conntrack_cachep") Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-18net/route: enforce hoplimit max valuePaolo Abeni
[ Upstream commit 626abd59e51d4d8c6367e03aae252a8aa759ac78 ] Currently, when creating or updating a route, no check is performed in both ipv4 and ipv6 code to the hoplimit value. The caller can i.e. set hoplimit to 256, and when such route will be used, packets will be sent with hoplimit/ttl equal to 0. This commit adds checks for the RTAX_HOPLIMIT value, in both ipv4 ipv6 route code, substituting any value greater than 255 with 255. This is consistent with what is currently done for ADVMSS and MTU in the ipv4 code. Signed-off-by: Paolo Abeni <pabeni@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-18tcp: refresh skb timestamp at retransmit timeEric Dumazet
[ Upstream commit 10a81980fc47e64ffac26a073139813d3f697b64 ] In the very unlikely case __tcp_retransmit_skb() can not use the cloning done in tcp_transmit_skb(), we need to refresh skb_mstamp before doing the copy and transmit, otherwise TCP TS val will be an exact copy of original transmit. Fixes: 7faee5c0d514 ("tcp: remove TCP_SKB_CB(skb)->when") Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Yuchung Cheng <ycheng@google.com> Acked-by: Yuchung Cheng <ycheng@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-18net: fix a kernel infoleak in x25 moduleKangjie Lu
[ Upstream commit 79e48650320e6fba48369fccf13fd045315b19b8 ] Stack object "dte_facilities" is allocated in x25_rx_call_request(), which is supposed to be initialized in x25_negotiate_facilities. However, 5 fields (8 bytes in total) are not initialized. This object is then copied to userland via copy_to_user, thus infoleak occurs. Signed-off-by: Kangjie Lu <kjlu@gatech.edu> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-18bridge: fix igmp / mld query parsingLinus Lüssing
[ Upstream commit 856ce5d083e14571d051301fe3c65b32b8cbe321 ] With the newly introduced helper functions the skb pulling is hidden in the checksumming function - and undone before returning to the caller. The IGMP and MLD query parsing functions in the bridge still assumed that the skb is pointing to the beginning of the IGMP/MLD message while it is now kept at the beginning of the IPv4/6 header. If there is a querier somewhere else, then this either causes the multicast snooping to stay disabled even though it could be enabled. Or, if we have the querier enabled too, then this can create unnecessary IGMP / MLD query messages on the link. Fixing this by taking the offset between IP and IGMP/MLD header into account, too. Fixes: 9afd85c9e455 ("net: Export IGMP/MLD message validation code") Reported-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-18net: bridge: fix old ioctl unlocked net device walkNikolay Aleksandrov
[ Upstream commit 31ca0458a61a502adb7ed192bf9716c6d05791a5 ] get_bridge_ifindices() is used from the old "deviceless" bridge ioctl calls which aren't called with rtnl held. The comment above says that it is called with rtnl but that is not really the case. Here's a sample output from a test ASSERT_RTNL() which I put in get_bridge_ifindices and executed "brctl show": [ 957.422726] RTNL: assertion failed at net/bridge//br_ioctl.c (30) [ 957.422925] CPU: 0 PID: 1862 Comm: brctl Tainted: G W O 4.6.0-rc4+ #157 [ 957.423009] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.8.1-20150318_183358- 04/01/2014 [ 957.423009] 0000000000000000 ffff880058adfdf0 ffffffff8138dec5 0000000000000400 [ 957.423009] ffffffff81ce8380 ffff880058adfe58 ffffffffa05ead32 0000000000000001 [ 957.423009] 00007ffec1a444b0 0000000000000400 ffff880053c19130 0000000000008940 [ 957.423009] Call Trace: [ 957.423009] [<ffffffff8138dec5>] dump_stack+0x85/0xc0 [ 957.423009] [<ffffffffa05ead32>] br_ioctl_deviceless_stub+0x212/0x2e0 [bridge] [ 957.423009] [<ffffffff81515beb>] sock_ioctl+0x22b/0x290 [ 957.423009] [<ffffffff8126ba75>] do_vfs_ioctl+0x95/0x700 [ 957.423009] [<ffffffff8126c159>] SyS_ioctl+0x79/0x90 [ 957.423009] [<ffffffff8163a4c0>] entry_SYSCALL_64_fastpath+0x23/0xc1 Since it only reads bridge ifindices, we can use rcu to safely walk the net device list. Also remove the wrong rtnl comment above. Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-18VSOCK: do not disconnect socket when peer has shutdown SEND onlyIan Campbell
[ Upstream commit dedc58e067d8c379a15a8a183c5db318201295bb ] The peer may be expecting a reply having sent a request and then done a shutdown(SHUT_WR), so tearing down the whole socket at this point seems wrong and breaks for me with a client which does a SHUT_WR. Looking at other socket family's stream_recvmsg callbacks doing a shutdown here does not seem to be the norm and removing it does not seem to have had any adverse effects that I can see. I'm using Stefan's RFC virtio transport patches, I'm unsure of the impact on the vmci transport. Signed-off-by: Ian Campbell <ian.campbell@docker.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Stefan Hajnoczi <stefanha@redhat.com> Cc: Claudio Imbrenda <imbrenda@linux.vnet.ibm.com> Cc: Andy King <acking@vmware.com> Cc: Dmitry Torokhov <dtor@vmware.com> Cc: Jorgen Hansen <jhansen@vmware.com> Cc: Adit Ranadive <aditr@vmware.com> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-18net: fix infoleak in rtnetlinkKangjie Lu
[ Upstream commit 5f8e44741f9f216e33736ea4ec65ca9ac03036e6 ] The stack object “map” has a total size of 32 bytes. Its last 4 bytes are padding generated by compiler. These padding bytes are not initialized and sent out via “nla_put”. Signed-off-by: Kangjie Lu <kjlu@gatech.edu> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-18net: fix infoleak in llcKangjie Lu
[ Upstream commit b8670c09f37bdf2847cc44f36511a53afc6161fd ] The stack object “info” has a total size of 12 bytes. Its last byte is padding which is not initialized and leaked via “put_cmsg”. Signed-off-by: Kangjie Lu <kjlu@gatech.edu> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-18netem: Segment GSO packets on enqueueNeil Horman
[ Upstream commit 6071bd1aa13ed9e41824bafad845b7b7f4df5cfd ] This was recently reported to me, and reproduced on the latest net kernel, when attempting to run netperf from a host that had a netem qdisc attached to the egress interface: [ 788.073771] ---------------------[ cut here ]--------------------------- [ 788.096716] WARNING: at net/core/dev.c:2253 skb_warn_bad_offload+0xcd/0xda() [ 788.129521] bnx2: caps=(0x00000001801949b3, 0x0000000000000000) len=2962 data_len=0 gso_size=1448 gso_type=1 ip_summed=3 [ 788.182150] Modules linked in: sch_netem kvm_amd kvm crc32_pclmul ipmi_ssif ghash_clmulni_intel sp5100_tco amd64_edac_mod aesni_intel lrw gf128mul glue_helper ablk_helper edac_mce_amd cryptd pcspkr sg edac_core hpilo ipmi_si i2c_piix4 k10temp fam15h_power hpwdt ipmi_msghandler shpchp acpi_power_meter pcc_cpufreq nfsd auth_rpcgss nfs_acl lockd grace sunrpc ip_tables xfs libcrc32c sd_mod crc_t10dif crct10dif_generic mgag200 syscopyarea sysfillrect sysimgblt i2c_algo_bit drm_kms_helper ahci ata_generic pata_acpi ttm libahci crct10dif_pclmul pata_atiixp tg3 libata crct10dif_common drm crc32c_intel ptp serio_raw bnx2 r8169 hpsa pps_core i2c_core mii dm_mirror dm_region_hash dm_log dm_mod [ 788.465294] CPU: 16 PID: 0 Comm: swapper/16 Tainted: G W ------------ 3.10.0-327.el7.x86_64 #1 [ 788.511521] Hardware name: HP ProLiant DL385p Gen8, BIOS A28 12/17/2012 [ 788.542260] ffff880437c036b8 f7afc56532a53db9 ffff880437c03670 ffffffff816351f1 [ 788.576332] ffff880437c036a8 ffffffff8107b200 ffff880633e74200 ffff880231674000 [ 788.611943] 0000000000000001 0000000000000003 0000000000000000 ffff880437c03710 [ 788.647241] Call Trace: [ 788.658817] <IRQ> [<ffffffff816351f1>] dump_stack+0x19/0x1b [ 788.686193] [<ffffffff8107b200>] warn_slowpath_common+0x70/0xb0 [ 788.713803] [<ffffffff8107b29c>] warn_slowpath_fmt+0x5c/0x80 [ 788.741314] [<ffffffff812f92f3>] ? ___ratelimit+0x93/0x100 [ 788.767018] [<ffffffff81637f49>] skb_warn_bad_offload+0xcd/0xda [ 788.796117] [<ffffffff8152950c>] skb_checksum_help+0x17c/0x190 [ 788.823392] [<ffffffffa01463a1>] netem_enqueue+0x741/0x7c0 [sch_netem] [ 788.854487] [<ffffffff8152cb58>] dev_queue_xmit+0x2a8/0x570 [ 788.880870] [<ffffffff8156ae1d>] ip_finish_output+0x53d/0x7d0 ... The problem occurs because netem is not prepared to handle GSO packets (as it uses skb_checksum_help in its enqueue path, which cannot manipulate these frames). The solution I think is to simply segment the skb in a simmilar fashion to the way we do in __dev_queue_xmit (via validate_xmit_skb), with some minor changes. When we decide to corrupt an skb, if the frame is GSO, we segment it, corrupt the first segment, and enqueue the remaining ones. tested successfully by myself on the latest net kernel, to which this applies Signed-off-by: Neil Horman <nhorman@tuxdriver.com> CC: Jamal Hadi Salim <jhs@mojatatu.com> CC: "David S. Miller" <davem@davemloft.net> CC: netem@lists.linux-foundation.org CC: eric.dumazet@gmail.com CC: stephen@networkplumber.org Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-18sch_dsmark: update backlog as wellWANG Cong
[ Upstream commit bdf17661f63a79c3cb4209b970b1cc39e34f7543 ] Similarly, we need to update backlog too when we update qlen. Cc: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-18sch_htb: update backlog as wellWANG Cong
[ Upstream commit 431e3a8e36a05a37126f34b41aa3a5a6456af04e ] We saw qlen!=0 but backlog==0 on our production machine: qdisc htb 1: dev eth0 root refcnt 2 r2q 10 default 1 direct_packets_stat 0 ver 3.17 Sent 172680457356 bytes 222469449 pkt (dropped 0, overlimits 123575834 requeues 0) backlog 0b 72p requeues 0 The problem is we only count qlen for HTB qdisc but not backlog. We need to update backlog too when we update qlen, so that we can at least know the average packet length. Cc: Jamal Hadi Salim <jhs@mojatatu.com> Acked-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-18net_sched: update hierarchical backlog tooWANG Cong
[ Upstream commit 2ccccf5fb43ff62b2b96cc58d95fc0b3596516e4 ] When the bottom qdisc decides to, for example, drop some packet, it calls qdisc_tree_decrease_qlen() to update the queue length for all its ancestors, we need to update the backlog too to keep the stats on root qdisc accurate. Cc: Jamal Hadi Salim <jhs@mojatatu.com> Acked-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-18net_sched: introduce qdisc_replace() helperWANG Cong
[ Upstream commit 86a7996cc8a078793670d82ed97d5a99bb4e8496 ] Remove nearly duplicated code and prepare for the following patch. Cc: Jamal Hadi Salim <jhs@mojatatu.com> Acked-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-18gre: do not pull header in ICMP error processingJiri Benc
[ Upstream commit b7f8fe251e4609e2a437bd2c2dea01e61db6849c ] iptunnel_pull_header expects that IP header was already pulled; with this expectation, it pulls the tunnel header. This is not true in gre_err. Furthermore, ipv4_update_pmtu and ipv4_redirect expect that skb->data points to the IP header. We cannot pull the tunnel header in this path. It's just a matter of not calling iptunnel_pull_header - we don't need any of its effects. Fixes: bda7bb463436 ("gre: Allow multiple protocol listener for gre protocol.") Signed-off-by: Jiri Benc <jbenc@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-18ipv4/fib: don't warn when primary address is missing if in_dev is deadPaolo Abeni
[ Upstream commit 391a20333b8393ef2e13014e6e59d192c5594471 ] After commit fbd40ea0180a ("ipv4: Don't do expensive useless work during inetdev destroy.") when deleting an interface, fib_del_ifaddr() can be executed without any primary address present on the dead interface. The above is safe, but triggers some "bug: prim == NULL" warnings. This commit avoids warning if the in_dev is dead Signed-off-by: Paolo Abeni <pabeni@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-18openvswitch: use flow protocol when recalculating ipv6 checksumsSimon Horman
[ Upstream commit b4f70527f052b0c00be4d7cac562baa75b212df5 ] When using masked actions the ipv6_proto field of an action to set IPv6 fields may be zero rather than the prevailing protocol which will result in skipping checksum recalculation. This patch resolves the problem by relying on the protocol in the flow key rather than that in the set field action. Fixes: 83d2b9ba1abc ("net: openvswitch: Support masked set actions.") Cc: Jarno Rajahalme <jrajahalme@nicira.com> Signed-off-by: Simon Horman <simon.horman@netronome.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-18vlan: pull on __vlan_insert_tag error path and fix csum correctionDaniel Borkmann
[ Upstream commit 9241e2df4fbc648a92ea0752918e05c26255649e ] When __vlan_insert_tag() fails from skb_vlan_push() path due to the skb_cow_head(), we need to undo the __skb_push() in the error path as well that was done earlier to move skb->data pointer to mac header. Moreover, I noticed that when in the non-error path the __skb_pull() is done and the original offset to mac header was non-zero, we fixup from a wrong skb->data offset in the checksum complete processing. So the skb_postpush_rcsum() really needs to be done before __skb_pull() where skb->data still points to the mac header start and thus operates under the same conditions as in __vlan_insert_tag(). Fixes: 93515d53b133 ("net: move vlan pop/push functions into common code") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Reviewed-by: Jiri Pirko <jiri@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-18net: use skb_postpush_rcsum instead of own implementationsDaniel Borkmann
[ Upstream commit 6b83d28a55a891a9d70fc61ccb1c138e47dcbe74 ] Replace individual implementations with the recently introduced skb_postpush_rcsum() helper. Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Tom Herbert <tom@herbertland.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-18net: sched: do not requeue a NULL skbLars Persson
[ Upstream commit 3dcd493fbebfd631913df6e2773cc295d3bf7d22 ] A failure in validate_xmit_skb_list() triggered an unconditional call to dev_requeue_skb with skb=NULL. This slowly grows the queue discipline's qlen count until all traffic through the queue stops. We take the optimistic approach and continue running the queue after a failure since it is unknown if later packets also will fail in the validate path. Fixes: 55a93b3ea780 ("qdisc: validate skb without holding lock") Signed-off-by: Lars Persson <larper@axis.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-18packet: fix heap info leak in PACKET_DIAG_MCLIST sock_diag interfaceMathias Krause
[ Upstream commit 309cf37fe2a781279b7675d4bb7173198e532867 ] Because we miss to wipe the remainder of i->addr[] in packet_mc_add(), pdiag_put_mclist() leaks uninitialized heap bytes via the PACKET_DIAG_MCLIST netlink attribute. Fix this by explicitly memset(0)ing the remaining bytes in i->addr[]. Fixes: eea68e2f1a00 ("packet: Report socket mclist info via diag module") Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@parallels.com> Acked-by: Pavel Emelyanov <xemul@virtuozzo.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-18route: do not cache fib route info on local routes with oifChris Friesen
[ Upstream commit d6d5e999e5df67f8ec20b6be45e2229455ee3699 ] For local routes that require a particular output interface we do not want to cache the result. Caching the result causes incorrect behaviour when there are multiple source addresses on the interface. The end result being that if the intended recipient is waiting on that interface for the packet he won't receive it because it will be delivered on the loopback interface and the IP_PKTINFO ipi_ifindex will be set to the loopback interface as well. This can be tested by running a program such as "dhcp_release" which attempts to inject a packet on a particular interface so that it is received by another program on the same board. The receiving process should see an IP_PKTINFO ipi_ifndex value of the source interface (e.g., eth1) instead of the loopback interface (e.g., lo). The packet will still appear on the loopback interface in tcpdump but the important aspect is that the CMSG info is correct. Sample dhcp_release command line: dhcp_release eth1 192.168.204.222 02:11:33:22:44:66 Signed-off-by: Allain Legacy <allain.legacy@windriver.com> Signed off-by: Chris Friesen <chris.friesen@windriver.com> Reviewed-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-18decnet: Do not build routes to devices without decnet private data.David S. Miller
[ Upstream commit a36a0d4008488fa545c74445d69eaf56377d5d4e ] In particular, make sure we check for decnet private presence for loopback devices. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11batman-adv: Reduce refcnt of removed router when updating routeSven Eckelmann
commit d1a65f1741bfd9c69f9e4e2ad447a89b6810427d upstream. _batadv_update_route rcu_derefences orig_ifinfo->router outside of a spinlock protected region to print some information messages to the debug log. But this pointer is not checked again when the new pointer is assigned in the spinlock protected region. Thus is can happen that the value of orig_ifinfo->router changed in the meantime and thus the reference counter of the wrong router gets reduced after the spinlock protected region. Just rcu_dereferencing the value of orig_ifinfo->router inside the spinlock protected region (which also set the new pointer) is enough to get the correct old router object. Fixes: e1a5382f978b ("batman-adv: Make orig_node->router an rcu protected pointer") Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <a@unstable.cc> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11batman-adv: Fix broadcast/ogm queue limit on a removed interfaceLinus Lüssing
commit c4fdb6cff2aa0ae740c5f19b6f745cbbe786d42f upstream. When removing a single interface while a broadcast or ogm packet is still pending then we will free the forward packet without releasing the queue slots again. This patch is supposed to fix this issue. Fixes: 6d5808d4ae1b ("batman-adv: Add missing hardif_free_ref in forw_packet_free") Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue> [sven@narfation.org: fix conflicts with current version] Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <a@unstable.cc> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11batman-adv: Check skb size before using encapsulated ETH+VLAN headerSven Eckelmann
commit c78296665c3d81f040117432ab9e1cb125521b0c upstream. The encapsulated ethernet and VLAN header may be outside the received ethernet frame. Thus the skb buffer size has to be checked before it can be parsed to find out if it encapsulates another batman-adv packet. Fixes: 420193573f11 ("batman-adv: softif bridge loop avoidance") Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <a@unstable.cc> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11batman-adv: fix DAT candidate selection (must use vid)Antonio Quartulli
commit 2871734e85e920503d49b3a8bc0afbe0773b6036 upstream. Now that DAT is VLAN aware, it must use the VID when computing the DHT address of the candidate nodes where an entry is going to be stored/retrieved. Fixes: be1db4f6615b ("batman-adv: make the Distributed ARP Table vlan aware") Signed-off-by: Antonio Quartulli <a@unstable.cc> [sven@narfation.org: fix conflicts with current version] Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11mac80211: fix statistics leak if dev_alloc_name() failsJohannes Berg
commit e6436be21e77e3659b4ff7e357ab5a8342d132d2 upstream. In the case that dev_alloc_name() fails, e.g. because the name was given by the user and already exists, we need to clean up properly and free the per-CPU statistics. Fix that. Fixes: 5a490510ba5f ("mac80211: use per-CPU TX/RX statistics") Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11ipvs: drop first packet to redirect conntrackJulian Anastasov
commit f719e3754ee2f7275437e61a6afd520181fdd43b upstream. Jiri Bohac is reporting for a problem where the attempt to reschedule existing connection to another real server needs proper redirect for the conntrack used by the IPVS connection. For example, when IPVS connection is created to NAT-ed real server we alter the reply direction of conntrack. If we later decide to select different real server we can not alter again the conntrack. And if we expire the old connection, the new connection is left without conntrack. So, the only way to redirect both the IPVS connection and the Netfilter's conntrack is to drop the SYN packet that hits existing connection, to wait for the next jiffie to expire the old connection and its conntrack and to rely on client's retransmission to create new connection as usually. Jiri Bohac provided a fix that drops all SYNs on rescheduling, I extended his patch to do such drops only for connections that use conntrack. Here is the original report from Jiri Bohac: Since commit dc7b3eb900aa ("ipvs: Fix reuse connection if real server is dead"), new connections to dead servers are redistributed immediately to new servers. The old connection is expired using ip_vs_conn_expire_now() which sets the connection timer to expire immediately. However, before the timer callback, ip_vs_conn_expire(), is run to clean the connection's conntrack entry, the new redistributed connection may already be established and its conntrack removed instead. Fix this by dropping the first packet of the new connection instead, like we do when the destination server is not available. The timer will have deleted the old conntrack entry long before the first packet of the new connection is retransmitted. Fixes: dc7b3eb900aa ("ipvs: Fix reuse connection if real server is dead") Signed-off-by: Jiri Bohac <jbohac@suse.cz> Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11ipvs: correct initial offset of Call-ID header search in SIP persistence engineMarco Angaroni
commit 7617a24f83b5d67f4dab1844956be1cebc44aec8 upstream. The IPVS SIP persistence engine is not able to parse the SIP header "Call-ID" when such header is inserted in the first positions of the SIP message. When IPVS is configured with "--pe sip" option, like for example: ipvsadm -A -u 1.2.3.4:5060 -s rr --pe sip -p 120 -o some particular messages (see below for details) do not create entries in the connection template table, which can be listed with: ipvsadm -Lcn --persistent-conn Problematic SIP messages are SIP responses having "Call-ID" header positioned just after message first line: SIP/2.0 200 OK [Call-ID header here] [rest of the headers] When "Call-ID" header is positioned down (after a few other headers) it is correctly recognized. This is due to the data offset used in get_callid function call inside ip_vs_pe_sip.c file: since dptr already points to the start of the SIP message, the value of dataoff should be initially 0. Otherwise the header is searched starting from some bytes after the first character of the SIP message. Fixes: 758ff0338722 ("IPVS: sip persistence engine") Signed-off-by: Marco Angaroni <marcoangaroni@gmail.com> Acked-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11ipvs: handle ip_vs_fill_iph_skb_off failureArnd Bergmann
commit 3f20efba41916ee17ce82f0fdd02581ada2872b2 upstream. ip_vs_fill_iph_skb_off() may not find an IP header, and gcc has determined that ip_vs_sip_fill_param() then incorrectly accesses the protocol fields: net/netfilter/ipvs/ip_vs_pe_sip.c: In function 'ip_vs_sip_fill_param': net/netfilter/ipvs/ip_vs_pe_sip.c:76:5: error: 'iph.protocol' may be used uninitialized in this function [-Werror=maybe-uninitialized] if (iph.protocol != IPPROTO_UDP) ^ net/netfilter/ipvs/ip_vs_pe_sip.c:81:10: error: 'iph.len' may be used uninitialized in this function [-Werror=maybe-uninitialized] dataoff = iph.len + sizeof(struct udphdr); ^ This adds a check for the ip_vs_fill_iph_skb_off() return code before looking at the ip header data returned from it. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Fixes: b0e010c527de ("ipvs: replace ip_vs_fill_ip4hdr with ip_vs_fill_iph_skb_off") Acked-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-04sunrpc/cache: drop reference when sunrpc_cache_pipe_upcall() detects a raceNeilBrown
commit a6ab1e8126d205238defbb55d23661a3a5c6a0d8 upstream. sunrpc_cache_pipe_upcall() can detect a race if CACHE_PENDING is no longer set. In this case it aborts the queuing of the upcall. However it has already taken a new counted reference on "h" and doesn't "put" it, even though it frees the data structure holding the reference. So let's delay the "cache_get" until we know we need it. Fixes: f9e1aedc6c79 ("sunrpc/cache: remove races with queuing an upcall.") Signed-off-by: NeilBrown <neilb@suse.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-04netlink: don't send NETLINK_URELEASE for unbound socketsDmitry Ivanov
commit e27260203912b40751fa353d009eaa5a642c739f upstream. All existing users of NETLINK_URELEASE use it to clean up resources that were previously allocated to a socket via some command. As a result, no users require getting this notification for unbound sockets. Sending it for unbound sockets, however, is a problem because any user (including unprivileged users) can create a socket that uses the same ID as an existing socket. Binding this new socket will fail, but if the NETLINK_URELEASE notification is generated for such sockets, the users thereof will be tricked into thinking the socket that they allocated the resources for is closed. In the nl80211 case, this will cause destruction of virtual interfaces that still belong to an existing hostapd process; this is the case that Dmitry noticed. In the NFC case, it will cause a poll abort. In the case of netlink log/queue it will cause them to stop reporting events, as if NFULNL_CFG_CMD_UNBIND/NFQNL_CFG_CMD_UNBIND had been called. Fix this problem by checking that the socket is bound before generating the NETLINK_URELEASE notification. Signed-off-by: Dmitry Ivanov <dima@ubnt.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-04nl80211: check netlink protocol in socket release notificationDmitry Ivanov
commit 8f815cdde3e550e10c2736990d791f60c2ce43eb upstream. A non-privileged user can create a netlink socket with the same port_id as used by an existing open nl80211 netlink socket (e.g. as used by a hostapd process) with a different protocol number. Closing this socket will then lead to the notification going to nl80211's socket release notification handler, and possibly cause an action such as removing a virtual interface. Fix this issue by checking that the netlink protocol is NETLINK_GENERIC. Since generic netlink has no notifier chain of its own, we can't fix the problem more generically. Fixes: 026331c4d9b5 ("cfg80211/mac80211: allow registering for and sending action frames") Signed-off-by: Dmitry Ivanov <dima@ubnt.com> [rewrite commit message] Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-20mac80211: fix txq queue related crashesMichal Kazior
commit 2a58d42c1e018ad514d4e23fd33fb2ded95d3ee6 upstream. The driver can access the queue simultanously while mac80211 tears down the interface. Without spinlock protection this could lead to corrupting sk_buff_head and subsequently to an invalid pointer dereference. Fixes: ba8c3d6f16a1 ("mac80211: add an intermediate software queue implementation") Signed-off-by: Michal Kazior <michal.kazior@tieto.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-20mac80211: fix unnecessary frame drops in mesh fwdingMichal Kazior
commit cf44012810ccdd8fd947518e965cb04b7b8498be upstream. The ieee80211_queue_stopped() expects hw queue number but it was given raw WMM AC number instead. This could cause frame drops and problems with traffic in some cases - most notably if driver doesn't map AC numbers to queue numbers 1:1 and uses ieee80211_stop_queues() and ieee80211_wake_queue() only without ever calling ieee80211_wake_queues(). On ath10k it was possible to hit this problem in the following case: 1. wlan0 uses queue 0 (ath10k maps queues per vif) 2. offchannel uses queue 15 3. queues 1-14 are unused 4. ieee80211_stop_queues() 5. ieee80211_wake_queue(q=0) 6. ieee80211_wake_queue(q=15) (other queues are not woken up because both driver and mac80211 know other queues are unused) 7. ieee80211_rx_h_mesh_fwding() 8. ieee80211_select_queue_80211() returns 2 9. ieee80211_queue_stopped(q=2) returns true 10. frame is dropped (oops!) Fixes: d3c1597b8d1b ("mac80211: fix forwarded mesh frame queue mapping") Signed-off-by: Michal Kazior <michal.kazior@tieto.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-20mac80211: fix ibss scan parametersSara Sharon
commit d321cd014e51baab475efbdec468255b9e0ec822 upstream. When joining IBSS a full scan should be initiated in order to search for existing cell, unless the fixed_channel parameter was set. A default channel to create the IBSS on if no cell was found is provided as well. However - a scan is initiated only on the default channel provided regardless of whether ifibss->fixed_channel is set or not, with the obvious result of the cell not joining existing IBSS cell that is on another channel. Fixes: 76bed0f43b27 ("mac80211: IBSS fix scan request") Signed-off-by: Sara Sharon <sara.sharon@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-20mac80211: avoid excessive stack usage in sta_infoArnd Bergmann
commit 0ef049dc1167fe834d0ad5d63f89eddc5c70f6e4 upstream. When CONFIG_OPTIMIZE_INLINING is set, the sta_info_insert_finish function consumes more stack than normally, exceeding the 1024 byte limit on ARM: net/mac80211/sta_info.c: In function 'sta_info_insert_finish': net/mac80211/sta_info.c:561:1: error: the frame size of 1080 bytes is larger than 1024 bytes [-Werror=frame-larger-than=] It turns out that there are two functions that put a 'struct station_info' on the stack: __sta_info_destroy_part2 and sta_info_insert_finish, and this structure alone requires up to 792 bytes. Hoping that both are called rarely enough, this replaces the on-stack structure with a dynamic allocation, which unfortunately requires some suboptimal error handling for out-of-memory. The __sta_info_destroy_part2 function is actually affected by the stack usage twice because it calls cfg80211_del_sta_sinfo(), which has another instance of struct station_info on its stack. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Fixes: 98b6218388e3 ("mac80211/cfg80211: add station events") Fixes: 6f7a8d26e266 ("mac80211: send statistics with delete station event") Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-20mac80211: properly deal with station hashtable insert errorsJohannes Berg
commit 62b14b241ca6f790a17ccd9dd9f62ce1b006d406 upstream. The original hand-implemented hash-table in mac80211 couldn't result in insertion errors, and while converting to rhashtable I evidently forgot to check the errors. This surfaced now only because Ben is adding many identical keys and that resulted in hidden insertion errors. Fixes: 7bedd0cfad4e1 ("mac80211: use rhashtable for station table") Reported-by: Ben Greear <greearb@candelatech.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-20mpls: find_outdev: check for err ptr in addition to NULL checkRoopa Prabhu
[ Upstream commit 94a57f1f8a9de90ab4b0f8748361ff8be706c80c ] find_outdev calls inet{,6}_fib_lookup_dev() or dev_get_by_index() to find the output device. In case of an error, inet{,6}_fib_lookup_dev() returns error pointer and dev_get_by_index() returns NULL. But the function only checks for NULL and thus can end up calling dev_put on an ERR_PTR. This patch adds an additional check for err ptr after the NULL check. Before: Trying to add an mpls route with no oif from user, no available path to 10.1.1.8 and no default route: $ip -f mpls route add 100 as 200 via inet 10.1.1.8 [ 822.337195] BUG: unable to handle kernel NULL pointer dereference at 00000000000003a3 [ 822.340033] IP: [<ffffffff8148781e>] mpls_nh_assign_dev+0x10b/0x182 [ 822.340033] PGD 1db38067 PUD 1de9e067 PMD 0 [ 822.340033] Oops: 0000 [#1] SMP [ 822.340033] Modules linked in: [ 822.340033] CPU: 0 PID: 11148 Comm: ip Not tainted 4.5.0-rc7+ #54 [ 822.340033] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.7.5.1-0-g8936dbb-20141113_115728-nilsson.home.kraxel.org 04/01/2014 [ 822.340033] task: ffff88001db82580 ti: ffff88001dad4000 task.ti: ffff88001dad4000 [ 822.340033] RIP: 0010:[<ffffffff8148781e>] [<ffffffff8148781e>] mpls_nh_assign_dev+0x10b/0x182 [ 822.340033] RSP: 0018:ffff88001dad7a88 EFLAGS: 00010282 [ 822.340033] RAX: ffffffffffffff9b RBX: ffffffffffffff9b RCX: 0000000000000002 [ 822.340033] RDX: 00000000ffffff9b RSI: 0000000000000008 RDI: 0000000000000000 [ 822.340033] RBP: ffff88001ddc9ea0 R08: ffff88001e9f1768 R09: 0000000000000000 [ 822.340033] R10: ffff88001d9c1100 R11: ffff88001e3c89f0 R12: ffffffff8187e0c0 [ 822.340033] R13: ffffffff8187e0c0 R14: ffff88001ddc9e80 R15: 0000000000000004 [ 822.340033] FS: 00007ff9ed798700(0000) GS:ffff88001fc00000(0000) knlGS:0000000000000000 [ 822.340033] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 822.340033] CR2: 00000000000003a3 CR3: 000000001de89000 CR4: 00000000000006f0 [ 822.340033] Stack: [ 822.340033] 0000000000000000 0000000100000000 0000000000000000 0000000000000000 [ 822.340033] 0000000000000000 0801010a00000000 0000000000000000 0000000000000000 [ 822.340033] 0000000000000004 ffffffff8148749b ffffffff8187e0c0 000000000000001c [ 822.340033] Call Trace: [ 822.340033] [<ffffffff8148749b>] ? mpls_rt_alloc+0x2b/0x3e [ 822.340033] [<ffffffff81488e66>] ? mpls_rtm_newroute+0x358/0x3e2 [ 822.340033] [<ffffffff810e7bbc>] ? get_page+0x5/0xa [ 822.340033] [<ffffffff813b7d94>] ? rtnetlink_rcv_msg+0x17e/0x191 [ 822.340033] [<ffffffff8111794e>] ? __kmalloc_track_caller+0x8c/0x9e [ 822.340033] [<ffffffff813c9393>] ? rht_key_hashfn.isra.20.constprop.57+0x14/0x1f [ 822.340033] [<ffffffff813b7c16>] ? __rtnl_unlock+0xc/0xc [ 822.340033] [<ffffffff813cb794>] ? netlink_rcv_skb+0x36/0x82 [ 822.340033] [<ffffffff813b4507>] ? rtnetlink_rcv+0x1f/0x28 [ 822.340033] [<ffffffff813cb2b1>] ? netlink_unicast+0x106/0x189 [ 822.340033] [<ffffffff813cb5b3>] ? netlink_sendmsg+0x27f/0x2c8 [ 822.340033] [<ffffffff81392ede>] ? sock_sendmsg_nosec+0x10/0x1b [ 822.340033] [<ffffffff81393df1>] ? ___sys_sendmsg+0x182/0x1e3 [ 822.340033] [<ffffffff810e4f35>] ? __alloc_pages_nodemask+0x11c/0x1e4 [ 822.340033] [<ffffffff8110619c>] ? PageAnon+0x5/0xd [ 822.340033] [<ffffffff811062fe>] ? __page_set_anon_rmap+0x45/0x52 [ 822.340033] [<ffffffff810e7bbc>] ? get_page+0x5/0xa [ 822.340033] [<ffffffff810e85ab>] ? __lru_cache_add+0x1a/0x3a [ 822.340033] [<ffffffff81087ea9>] ? current_kernel_time64+0x9/0x30 [ 822.340033] [<ffffffff813940c4>] ? __sys_sendmsg+0x3c/0x5a [ 822.340033] [<ffffffff8148f597>] ? entry_SYSCALL_64_fastpath+0x12/0x6a [ 822.340033] Code: 83 08 04 00 00 65 ff 00 48 8b 3c 24 e8 40 7c f2 ff eb 13 48 c7 c3 9f ff ff ff eb 0f 89 ce e8 f1 ae f1 ff 48 89 c3 48 85 db 74 15 <48> 8b 83 08 04 00 00 65 ff 08 48 81 fb 00 f0 ff ff 76 0d eb 07 [ 822.340033] RIP [<ffffffff8148781e>] mpls_nh_assign_dev+0x10b/0x182 [ 822.340033] RSP <ffff88001dad7a88> [ 822.340033] CR2: 00000000000003a3 [ 822.435363] ---[ end trace 98cc65e6f6b8bf11 ]--- After patch: $ip -f mpls route add 100 as 200 via inet 10.1.1.8 RTNETLINK answers: Network is unreachable Signed-off-by: Roopa Prabhu <roopa@cumulusnetworks.com> Reported-by: David Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-20ipv6: Count in extension headers in skb->network_headerJakub Sitnicki
[ Upstream commit 3ba3458fb9c050718b95275a3310b74415e767e2 ] When sending a UDPv6 message longer than MTU, account for the length of fragmentable IPv6 extension headers in skb->network_header offset. Same as we do in alloc_new_skb path in __ip6_append_data(). This ensures that later on __ip6_make_skb() will make space in headroom for fragmentable extension headers: /* move skb->data to ip header from ext header */ if (skb->data < skb_network_header(skb)) __skb_pull(skb, skb_network_offset(skb)); Prevents a splat due to skb_under_panic: skbuff: skb_under_panic: text:ffffffff8143397b len:2126 put:14 \ head:ffff880005bacf50 data:ffff880005bacf4a tail:0x48 end:0xc0 dev:lo ------------[ cut here ]------------ kernel BUG at net/core/skbuff.c:104! invalid opcode: 0000 [#1] KASAN CPU: 0 PID: 160 Comm: reproducer Not tainted 4.6.0-rc2 #65 [...] Call Trace: [<ffffffff813eb7b9>] skb_push+0x79/0x80 [<ffffffff8143397b>] eth_header+0x2b/0x100 [<ffffffff8141e0d0>] neigh_resolve_output+0x210/0x310 [<ffffffff814eab77>] ip6_finish_output2+0x4a7/0x7c0 [<ffffffff814efe3a>] ip6_output+0x16a/0x280 [<ffffffff815440c1>] ip6_local_out+0xb1/0xf0 [<ffffffff814f1115>] ip6_send_skb+0x45/0xd0 [<ffffffff81518836>] udp_v6_send_skb+0x246/0x5d0 [<ffffffff8151985e>] udpv6_sendmsg+0xa6e/0x1090 [...] Reported-by: Ji Jianwen <jiji@redhat.com> Signed-off-by: Jakub Sitnicki <jkbs@redhat.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-20ip6_tunnel: set rtnl_link_ops before calling register_netdeviceThadeu Lima de Souza Cascardo
[ Upstream commit b6ee376cb0b7fb4e7e07d6cd248bd40436fb9ba6 ] When creating an ip6tnl tunnel with ip tunnel, rtnl_link_ops is not set before ip6_tnl_create2 is called. When register_netdevice is called, there is no linkinfo attribute in the NEWLINK message because of that. Setting rtnl_link_ops before calling register_netdevice fixes that. Fixes: 0b112457229d ("ip6tnl: add support of link creation via rtnl") Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@redhat.com> Acked-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-20ipv6: l2tp: fix a potential issue in l2tp_ip6_recvHaishuang Yan
[ Upstream commit be447f305494e019dfc37ea4cdf3b0e4200b4eba ] pskb_may_pull() can change skb->data, so we have to load ptr/optr at the right place. Signed-off-by: Haishuang Yan <yanhaishuang@cmss.chinamobile.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-20ipv4: l2tp: fix a potential issue in l2tp_ip_recvHaishuang Yan
[ Upstream commit 5745b8232e942abd5e16e85fa9b27cc21324acf0 ] pskb_may_pull() can change skb->data, so we have to load ptr/optr at the right place. Signed-off-by: Haishuang Yan <yanhaishuang@cmss.chinamobile.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-20tun, bpf: fix suspicious RCU usage in tun_{attach, detach}_filterDaniel Borkmann
[ Upstream commit 5a5abb1fa3b05dd6aa821525832644c1e7d2905f ] Sasha Levin reported a suspicious rcu_dereference_protected() warning found while fuzzing with trinity that is similar to this one: [ 52.765684] net/core/filter.c:2262 suspicious rcu_dereference_protected() usage! [ 52.765688] other info that might help us debug this: [ 52.765695] rcu_scheduler_active = 1, debug_locks = 1 [ 52.765701] 1 lock held by a.out/1525: [ 52.765704] #0: (rtnl_mutex){+.+.+.}, at: [<ffffffff816a64b7>] rtnl_lock+0x17/0x20 [ 52.765721] stack backtrace: [ 52.765728] CPU: 1 PID: 1525 Comm: a.out Not tainted 4.5.0+ #264 [...] [ 52.765768] Call Trace: [ 52.765775] [<ffffffff813e488d>] dump_stack+0x85/0xc8 [ 52.765784] [<ffffffff810f2fa5>] lockdep_rcu_suspicious+0xd5/0x110 [ 52.765792] [<ffffffff816afdc2>] sk_detach_filter+0x82/0x90 [ 52.765801] [<ffffffffa0883425>] tun_detach_filter+0x35/0x90 [tun] [ 52.765810] [<ffffffffa0884ed4>] __tun_chr_ioctl+0x354/0x1130 [tun] [ 52.765818] [<ffffffff8136fed0>] ? selinux_file_ioctl+0x130/0x210 [ 52.765827] [<ffffffffa0885ce3>] tun_chr_ioctl+0x13/0x20 [tun] [ 52.765834] [<ffffffff81260ea6>] do_vfs_ioctl+0x96/0x690 [ 52.765843] [<ffffffff81364af3>] ? security_file_ioctl+0x43/0x60 [ 52.765850] [<ffffffff81261519>] SyS_ioctl+0x79/0x90 [ 52.765858] [<ffffffff81003ba2>] do_syscall_64+0x62/0x140 [ 52.765866] [<ffffffff817d563f>] entry_SYSCALL64_slow_path+0x25/0x25 Same can be triggered with PROVE_RCU (+ PROVE_RCU_REPEATEDLY) enabled from tun_attach_filter() when user space calls ioctl(tun_fd, TUN{ATTACH, DETACH}FILTER, ...) for adding/removing a BPF filter on tap devices. Since the fix in f91ff5b9ff52 ("net: sk_{detach|attach}_filter() rcu fixes") sk_attach_filter()/sk_detach_filter() now dereferences the filter with rcu_dereference_protected(), checking whether socket lock is held in control path. Since its introduction in 994051625981 ("tun: socket filter support"), tap filters are managed under RTNL lock from __tun_chr_ioctl(). Thus the sock_owned_by_user(sk) doesn't apply in this specific case and therefore triggers the false positive. Extend the BPF API with __sk_attach_filter()/__sk_detach_filter() pair that is used by tap filters and pass in lockdep_rtnl_is_held() for the rcu_dereference_protected() checks instead. Reported-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-20rtnl: fix msg size calculation in if_nlmsg_size()Nicolas Dichtel
[ Upstream commit c57c7a95da842807b475b823ed2e5435c42cb3b0 ] Size of the attribute IFLA_PHYS_PORT_NAME was missing. Fixes: db24a9044ee1 ("net: add support for phys_port_name") CC: David Ahern <dsahern@gmail.com> Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: David Ahern <dsahern@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-20bridge: Allow set bridge ageing time when switchdev disabledHaishuang Yan
[ Upstream commit 5e263f712691615fb802f06c98d7638c378f5d11 ] When NET_SWITCHDEV=n, switchdev_port_attr_set will return -EOPNOTSUPP, we should ignore this error code and continue to set the ageing time. Fixes: c62987bbd8a1 ("bridge: push bridge setting ageing_time down to switchdev") Signed-off-by: Haishuang Yan <yanhaishuang@cmss.chinamobile.com> Acked-by: Ido Schimmel <idosch@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-20ipv6: udp: fix UDP_MIB_IGNOREDMULTI updatesEric Dumazet
[ Upstream commit 2d4212261fdf13e29728ddb5ea9d60c342cc92b5 ] IPv6 counters updates use a different macro than IPv4. Fixes: 36cbb2452cbaf ("udp: Increment UDP_MIB_IGNOREDMULTI for arriving unmatched multicasts") Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Rick Jones <rick.jones2@hp.com> Cc: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-20xfrm: Fix crash observed during device unregistration and decryptionsubashab@codeaurora.org
[ Upstream commit 071d36bf21bcc837be00cea55bcef8d129e7f609 ] A crash is observed when a decrypted packet is processed in receive path. get_rps_cpus() tries to dereference the skb->dev fields but it appears that the device is freed from the poison pattern. [<ffffffc000af58ec>] get_rps_cpu+0x94/0x2f0 [<ffffffc000af5f94>] netif_rx_internal+0x140/0x1cc [<ffffffc000af6094>] netif_rx+0x74/0x94 [<ffffffc000bc0b6c>] xfrm_input+0x754/0x7d0 [<ffffffc000bc0bf8>] xfrm_input_resume+0x10/0x1c [<ffffffc000ba6eb8>] esp_input_done+0x20/0x30 [<ffffffc0000b64c8>] process_one_work+0x244/0x3fc [<ffffffc0000b7324>] worker_thread+0x2f8/0x418 [<ffffffc0000bb40c>] kthread+0xe0/0xec -013|get_rps_cpu( | dev = 0xFFFFFFC08B688000, | skb = 0xFFFFFFC0C76AAC00 -> ( | dev = 0xFFFFFFC08B688000 -> ( | name = "...................................................... | name_hlist = (next = 0xAAAAAAAAAAAAAAAA, pprev = 0xAAAAAAAAAAA Following are the sequence of events observed - - Encrypted packet in receive path from netdevice is queued - Encrypted packet queued for decryption (asynchronous) - Netdevice brought down and freed - Packet is decrypted and returned through callback in esp_input_done - Packet is queued again for process in network stack using netif_rx Since the device appears to have been freed, the dereference of skb->dev in get_rps_cpus() leads to an unhandled page fault exception. Fix this by holding on to device reference when queueing packets asynchronously and releasing the reference on call back return. v2: Make the change generic to xfrm as mentioned by Steffen and update the title to xfrm Suggested-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Jerome Stanislaus <jeromes@codeaurora.org> Signed-off-by: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-20ipv4: initialize flowi4_flags before calling fib_lookup()Lance Richardson
[ Upstream commit 4cfc86f3dae6ca38ed49cdd78f458a03d4d87992 ] Field fl4.flowi4_flags is not initialized in fib_compute_spec_dst() before calling fib_lookup(), which means fib_table_lookup() is using non-deterministic data at this line: if (!(flp->flowi4_flags & FLOWI_FLAG_SKIP_NH_OIF)) { Fix by initializing the entire fl4 structure, which will prevent similar issues as fields are added in the future by ensuring that all fields are initialized to zero unless explicitly initialized to another value. Fixes: 58189ca7b2741 ("net: Fix vti use case with oif in dst lookups") Suggested-by: David Ahern <dsa@cumulusnetworks.com> Signed-off-by: Lance Richardson <lrichard@redhat.com> Acked-by: David Ahern <dsa@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
