[ Upstream commit 9026c4927254f5bea695cc3ef2e255280e6a3011 ]
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
[ Upstream commit 29cd8ae0e1a39e239a3a7b67da1986add1199fc0 ]
The dcb netlink interface leaks stack memory in various places:
* perm_addr[] buffer is only filled at max with 12 of the 32 bytes but
copied completely,
* no in-kernel driver fills all fields of an IEEE 802.1Qaz subcommand,
so we're leaking up to 58 bytes for ieee_ets structs, up to 136 bytes
for ieee_pfc structs, etc.,
* the same is true for CEE -- no in-kernel driver fills the whole
struct,
Prevent all of the above stack info leaks by properly initializing the
buffers/structures involved.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
[ Upstream commit 84d73cd3fb142bf1298a8c13fd4ca50fd2432372 ]
Initialize the mac address buffer with 0 as the driver specific function
will probably not fill the whole buffer. In fact, all in-kernel drivers
fill only ETH_ALEN of the MAX_ADDR_LEN bytes, i.e. 6 of the 32 possible
bytes. Therefore we currently leak 26 bytes of stack memory to userland
via the netlink interface.
[ Upstream commit c085c49920b2f900ba716b4ca1c1a55ece9872cc ]
The bridging code discloses heap and stack bytes via the RTM_GETMDB
netlink interface and via the notify messages send to group RTNLGRP_MDB
afer a successful add/del.
Fix both cases by initializing all unset members/padding bytes with
memset(0).
Cc: Stephen Hemminger <stephen@networkplumber.org>
[ Upstream commit ddf64354af4a702ee0b85d0a285ba74c7278a460 ]
v2:
a) used struct ipv6_addr_props
v3:
a) reverted changes for ipv6_addr_props
v4:
a) do not use __ipv6_addr_needs_scope_id
Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
[ Upstream commit 3bc1b1add7a8484cc4a261c3e128dbe1528ce01f ]
The frames for which rx_handlers return RX_HANDLER_CONSUMED are no longer
counted as dropped. They are counted as successfully received by
'netif_receive_skb'.
This allows network interface drivers to correctly update their RX-OK and
RX-DRP counters based on the result of 'netif_receive_skb'.
Signed-off-by: Cristian Bercaru <B43982@freescale.com>
[ Upstream commits 0c1233aba1e948c37f6dc7620cb7c253fcd71ce9 and
a6a8fe950e1b8596bb06f2c89c3a1a4bf2011ba9 ]
When we have a large number of static label mappings that spill across
the netlink message boundary we fail to properly save our state in the
netlink_callback struct which causes us to repeat the same listings.
This patch fixes this problem by saving the state correctly between
calls to the NetLabel static label netlink "dumpit" routines.
Signed-off-by: Paul Moore <pmoore@redhat.com>
[ Upstream commit aab2b4bf224ef8358d262f95b568b8ad0cecf0a0 ]
We should not update ts_recent and call tcp_rcv_rtt_measure_ts() both
before and after going to step5. That wastes CPU and double-counts the
receiver-side RTT sample.
Signed-off-by: Neal Cardwell <ncardwell@google.com>
[ Upstream commit 3e8b0ac3e41e3c882222a5522d5df7212438ab51 ]
Setting net.ipv6.conf.<interface>.accept_ra=2 causes the kernel
to accept RAs even when forwarding is enabled. However, enabling
forwarding purges all default routes on the system, breaking
connectivity until the next RA is received. Fix this by not
purging default routes on interfaces that have accept_ra=2.
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
[ Upstream commit ece6b0a2b25652d684a7ced4ae680a863af041e0 ]
Dave Jones reported the following bug:
"When fed mangled socket data, rds will trust what userspace gives it,
and tries to allocate enormous amounts of memory larger than what
kmalloc can satisfy."
WARNING: at mm/page_alloc.c:2393 __alloc_pages_nodemask+0xa0d/0xbe0()
Hardware name: GA-MA78GM-S2H
Modules linked in: vmw_vsock_vmci_transport vmw_vmci vsock fuse bnep dlci bridge 8021q garp stp mrp binfmt_misc l2tp_ppp l2tp_core rfcomm s
Pid: 24652, comm: trinity-child2 Not tainted 3.8.0+ #65
Call Trace:
[<ffffffff81044155>] warn_slowpath_common+0x75/0xa0
[<ffffffff8104419a>] warn_slowpath_null+0x1a/0x20
[<ffffffff811444ad>] __alloc_pages_nodemask+0xa0d/0xbe0
[<ffffffff8100a196>] ? native_sched_clock+0x26/0x90
[<ffffffff810b2128>] ? trace_hardirqs_off_caller+0x28/0xc0
[<ffffffff810b21cd>] ? trace_hardirqs_off+0xd/0x10
[<ffffffff811861f8>] alloc_pages_current+0xb8/0x180
[<ffffffff8113eaaa>] __get_free_pages+0x2a/0x80
[<ffffffff811934fe>] kmalloc_order_trace+0x3e/0x1a0
[<ffffffff81193955>] __kmalloc+0x2f5/0x3a0
[<ffffffff8104df0c>] ? local_bh_enable_ip+0x7c/0xf0
[<ffffffffa0401ab3>] rds_message_alloc+0x23/0xb0 [rds]
[<ffffffffa04043a1>] rds_sendmsg+0x2b1/0x990 [rds]
[<ffffffff81564620>] sock_sendmsg+0xb0/0xe0
[<ffffffff810b2052>] ? get_lock_stats+0x22/0x70
[<ffffffff810b24be>] ? put_lock_stats.isra.23+0xe/0x40
[<ffffffff81567f30>] sys_sendto+0x130/0x180
[<ffffffff810b872d>] ? trace_hardirqs_on+0xd/0x10
[<ffffffff816c547b>] ? _raw_spin_unlock_irq+0x3b/0x60
[<ffffffff816cd767>] ? sysret_check+0x1b/0x56
[<ffffffff810b8695>] ? trace_hardirqs_on_caller+0x115/0x1a0
[<ffffffff81341d8e>] ? trace_hardirqs_on_thunk+0x3a/0x3f
[<ffffffff816cd742>] system_call_fastpath+0x16/0x1b
---[ end trace eed6ae990d018c8b ]---
Reported-by: Dave Jones <davej@redhat.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Venkat Venkatsubra <venkat.x.venkatsubra@oracle.com>
Signed-off-by: Cong Wang <amwang@redhat.com>
Acked-by: Venkat Venkatsubra <venkat.x.venkatsubra@oracle.com>
[ Upstream commit 8b82547e33e85fc24d4d172a93c796de1fefa81a ]
The sendmsg() syscall handler for PPPoL2TP doesn't decrease the socket
reference counter after successful transmissions. Any successful
sendmsg() call from userspace will then increase the reference counter
forever, thus preventing the kernel's session and tunnel data from
being freed later on.
The problem only happens when writing directly on L2TP sockets.
PPP sockets attached to L2TP are unaffected as the PPP subsystem
uses pppol2tp_xmit() which symmetrically increase/decrease reference
counters.
This patch adds the missing call to sock_put() before returning from
pppol2tp_sendmsg().
Signed-off-by: Guillaume Nault <g.nault@alphalink.fr>
commit 726bc6b092da4c093eb74d13c07184b18c1af0f1 upstream.
Building sctp may fail with:
In function ‘copy_from_user’,
inlined from ‘sctp_getsockopt_assoc_stats’ at
net/sctp/socket.c:5656:20:
arch/x86/include/asm/uaccess_32.h:211:26: error: call to
‘copy_from_user_overflow’ declared with attribute error: copy_from_user()
buffer size is not provably correct
if built with W=1 due to a missing parameter size validation
before the call to copy_from_user.
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
commit a07fdceccf9d9f1b87f781e9a87662182e590d70 upstream.
It's called from both __init and __exit code, so neither
tag is appropriate.
commit 499218595a2e8296b7492af32fcca141b7b8184a upstream.
Some mlme work structs are not cancelled on disassociation
nor interface deletion, which leads to them running after
the memory has been freed
There is not a clean way to cancel these in the disassociation
logic because they must be canceled outside of the ifmgd->mtx
lock, so just cancel them in mgd_stop logic that tears down
the station.
This fixes the crashes we see in 3.7.9+. The crash stack
trace itself isn't so helpful, but this warning gives
more useful info:
WARNING: at /home/greearb/git/linux-3.7.dev.y/lib/debugobjects.c:261 debug_print_object+0x7c/0x8d()
ODEBUG: free active (active state 0) object type: work_struct hint: ieee80211_sta_monitor_work+0x0/0x14 [mac80211]
Modules linked in: [...]
Pid: 14743, comm: iw Tainted: G C O 3.7.9+ #11
Call Trace:
[<ffffffff81087ef8>] warn_slowpath_common+0x80/0x98
[<ffffffff81087fa4>] warn_slowpath_fmt+0x41/0x43
[<ffffffff812a2608>] debug_print_object+0x7c/0x8d
[<ffffffff812a2bca>] debug_check_no_obj_freed+0x95/0x1c3
[<ffffffff8114cc69>] slab_free_hook+0x70/0x79
[<ffffffff8114ea3e>] kfree+0x62/0xb7
[<ffffffff8149f465>] netdev_release+0x39/0x3e
[<ffffffff8136ad67>] device_release+0x52/0x8a
[<ffffffff812937db>] kobject_release+0x121/0x158
[<ffffffff81293612>] kobject_put+0x4c/0x50
[<ffffffff8148f0d7>] netdev_run_todo+0x25c/0x27e
Signed-off-by: Ben Greear <greearb@candelatech.com>
commit a9a6b52ee1baa865283a91eb8d443ee91adfca56 upstream.
If the socket is full, we're better off just waiting until it empties,
or until the connection is broken. The reason why we generally don't
want to time out is that the call to xprt->ops->release_xprt() will
trigger a connection reset, which isn't helpful...
Let's make an exception for soft RPC calls, since they have to provide
timeout guarantees.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit cc630d9f476445927fca599f81182c7f06f79058 upstream.
Rewrite server shutdown to remove the assumption that there are no
longer any threads running (no longer true, for example, when shutting
down the service in one network namespace while it's still running in
others).
Do that by doing what we'd do in normal circumstances: just CLOSE each
socket, then enqueue it.
Since there may not be threads to handle the resulting queued xprts,
also run a simplified version of the svc_recv() loop run by a server to
clean up any closed xprts afterwards.
Tested-by: Jason Tibbitts <tibbs@math.uh.edu>
Tested-by: Paweł Sikora <pawel.sikora@agmk.net>
Acked-by: Stanislav Kinsbursky <skinsbursky@parallels.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit e75bafbff2270993926abcc31358361db74a9bc2 upstream.
svc_age_temp_xprts expires xprts in a two-step process: first it takes
the sv_lock and moves the xprts to expire off their server-wide list
(sv_tempsocks or sv_permsocks) to a local list. Then it drops the
sv_lock and enqueues and puts each one.
I see no reason for this: svc_xprt_enqueue() will take sp_lock, but the
sv_lock and sp_lock are not otherwise nested anywhere (and documentation
at the top of this file claims it's correct to nest these with sp_lock
inside.)
Commit 5b36ebd8249f403c7edf7cf68d68e9a0d0f55243 upstream.
In some cases when disconnecting after (or during?) CSA
the queues might not recover, and then the only way to
recover is reloading the module.
Fix this by always unblocking the queue CSA reason when
disconnecting.
Reported-by: Jan-Michael Brummer <jan.brummer@tabos.org>
[ Upstream commit 6e601a53566d84e1ffd25e7b6fe0b6894ffd79c0 ]
Userland can send a netlink message requesting SOCK_DIAG_BY_FAMILY
with a family greater or equal then AF_MAX -- the array size of
sock_diag_handlers[]. The current code does not test for this
condition therefore is vulnerable to an out-of-bound access opening
doors for a privilege escalation.
[ Upstream commit 1b63edd6ecc55c3a61b40297b49e2323783bddfd ]
In fast open the sender unncessarily reduces the space available
for data in SYN by 12 bytes. This is because in the sender
incorrectly reserves space for TS option twice in tcp_send_syn_data():
tcp_mtu_to_mss() already accounts for TS option space. But it further
reserves MAX_TCP_OPTION_SPACE when computing the payload space.
Signed-off-by: Yuchung Cheng <ycheng@google.com>
[ Upstream commit 5b0520425e5ea81ba95ec486dd6bbb59a09fff0e ]
Now we handle icmp errors in each transport protocol's err_handler,
for icmp protocols, that is ping_err. Since this handler only care
of those icmp errors triggered by echo request, errors triggered
by echo reply(which sent by kernel) are sliently ignored.
So wrap ping_err() with icmp_err() to deal with those icmp errors.
Signed-off-by: Li Wei <lw@cn.fujitsu.com>
[ Upstream commit 08dcdbf6a7b9d14c2302c5bd0c5390ddf122f664 ]
It looks like its possible to open thousands of TCP IPv6
sessions on a server, all landing in a single slot of TCP hash
table. Incoming packets have to lookup sockets in a very
long list.
We should hash all bits from foreign IPv6 addresses, using
a salt and hash mix, not a simple XOR.
inet6_ehashfn() can also separately use the ports, instead
of xoring them.
Reported-by: Neal Cardwell <ncardwell@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
[ Upstream commit b531ed61a2a2a77eeb2f7c88b49aa5ec7d9880d8 ]
We should get 'type' and 'code' from the outer ICMP header.
[ Upstream commit ecd9883724b78cc72ed92c98bcb1a46c764fff21 ]
Eric Dumazet wrote:
| Some strange crashes happen in rt6_check_expired(), with access
| to random addresses.
| At first glance, it looks like the RTF_EXPIRES and
| stuff added in commit 1716a96101c49186b
| (ipv6: fix problem with expired dst cache)
| are racy : same dst could be manipulated at the same time
| on different cpus.
| At some point, our stack believes rt->dst.from contains a dst pointer,
| while its really a jiffie value (as rt->dst.expires shares the same area
| of memory)
| rt6_update_expires() should be fixed, or am I missing something ?
| CC Neil because of https://bugzilla.redhat.com/show_bug.cgi?id=892060
Because we do not have any locks for dst_entry, we cannot change
essential structure in the entry; e.g., we cannot change reference
to other entity.
To fix this issue, split 'from' and 'expires' field in dst_entry
out of union. Once it is 'from' is assigned in the constructor,
keep the reference until the very last stage of the life time of
the object.
Of course, it is unsafe to change 'from', so make rt6_set_from simple
just for fresh entries.
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
Reported-by: Neil Horman <nhorman@tuxdriver.com>
CC: Gao Feng <gaofeng@cn.fujitsu.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
Reported-by: Steinar H. Gunderson <sesse@google.com>
Reviewed-by: Neil Horman <nhorman@tuxdriver.com>
[ Upstream commit 18cf0d0784b4a634472ed24d0d7ca1c721d93e90 ]
Neighbor is cloned in xfrm6_fill_dst but seems to never be released.
Neighbor entry should be released when XFRM6 dst entry is destroyed
in xfrm6_dst_destroy, otherwise references may be kept forever on
the device pointed by the neighbor entry.
I may not have understood all the subtleties of XFRM & dst so I would
be happy to receive comments on this patch.
Signed-off-by: Romain Kuntz <r.kuntz@ipflavors.com>
This config item has not carried much meaning for a while now and is
almost always enabled by default. As agreed during the Linux kernel
summit, remove it.
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
Signed-off-by: David Rientjes <rientjes@google.com>
We walk through the bind address list and try to get the best source
address for a given destination. However, currently, we take the
'continue' path of the loop when an entry is invalid (!laddr->valid)
*and* the entry state does not equal SCTP_ADDR_SRC (laddr->state !=
SCTP_ADDR_SRC).
Thus, still, invalid entries with SCTP_ADDR_SRC might not 'continue'
as well as valid entries with SCTP_ADDR_{NEW, SRC, DEL}, with a possible
false baddr and matchlen as a result, causing in worst case dst route
to be false or possibly NULL.
This test should actually be a '||' instead of '&&'. But lets fix it
and make this a bit easier to read by having the condition the same way
as similarly done in sctp_v4_get_dst.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
An entry in DAT with the hashed position of 0 can cause a NULL pointer
dereference when the first entry is checked by batadv_choose_next_candidate.
This first candidate automatically has the max value of 0 and the max_orig_node
of NULL. Not checking max_orig_node for NULL in batadv_is_orig_node_eligible
will lead to a NULL pointer dereference when checking for the lowest address.
This problem was added in 785ea1144182c341b8b85b0f8180291839d176a8
("batman-adv: Distributed ARP Table - create DHT helper functions").
Signed-off-by: Pau Koning <paukoning@gmail.com>
in htb_change_class() cl->buffer and cl->buffer are stored in ns.
So in dump, convert them back to psched ticks.
Note this was introduced by:
commit 56b765b79e9a78dc7d3f8850ba5e5567205a3ecd
htb: improved accuracy at high rates
Please consider this for -net/-stable.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
John W. Linville says:
Here is another handful of late-breaking fixes intended for the 3.8
stream... Hopefully the will still make it! :-)
There are three mac80211 fixes pulled from Johannes:
"Here are three fixes still for the 3.8 stream, the fix from Cong Ding
for the bad sizeof (Stephen Hemminger had pointed it out before but I'd
promptly forgotten), a mac80211 managed-mode channel context usage fix
where a downgrade would never stop until reaching non-HT and a bug in
the channel determination that could cause invalid channels like HT40+
on channel 11 to be used."
Also included is a mwl8k fix that avoids an oops when using mwl8k
devices that only support the 5 GHz band.
Please let me know if there are problems!
Tommi was fuzzing with trinity and reported the following problem :
commit 3f518bf745 (datagram: Add offset argument to __skb_recv_datagram)
missed that a raw socket receive queue can contain skbs with no payload.
We can loop in __skb_recv_datagram() with MSG_PEEK mode, because
wait_for_packet() is not prepared to skip these skbs.
[ 83.541011] INFO: rcu_sched detected stalls on CPUs/tasks: {}
(detected by 0, t=26002 jiffies, g=27673, c=27672, q=75)
[ 83.541011] INFO: Stall ended before state dump start
[ 108.067010] BUG: soft lockup - CPU#0 stuck for 22s! [trinity-child31:2847]
[ 108.067010] Call Trace:
[ 108.067010] [<ffffffff818cc103>] __skb_recv_datagram+0x1a3/0x3b0
[ 108.067010] [<ffffffff818cc33d>] skb_recv_datagram+0x2d/0x30
[ 108.067010] [<ffffffff819ed43d>] rawv6_recvmsg+0xad/0x240
[ 108.067010] [<ffffffff818c4b04>] sock_common_recvmsg+0x34/0x50
[ 108.067010] [<ffffffff818bc8ec>] sock_recvmsg+0xbc/0xf0
[ 108.067010] [<ffffffff818bf31e>] sys_recvfrom+0xde/0x150
[ 108.067010] [<ffffffff81ca4329>] system_call_fastpath+0x16/0x1b
Reported-by: Tommi Rantala <tt.rantala@gmail.com>
Tested-by: Tommi Rantala <tt.rantala@gmail.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Acked-by: Pavel Emelyanov <xemul@parallels.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211
Spanning Tree Protocol packets should have always been marked as
control packets, this causes them to get queued in the high prirority
FIFO. As Radia Perlman mentioned in her LCA talk, STP dies if bridge
gets overloaded and can't communicate. This is a long-standing bug back
to the first versions of Linux bridge.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
When trying to connect to an AP that advertises HT but not
VHT, the mac80211 code erroneously uses the configuration
from the AP as is instead of checking it against regulatory
and local capabilities. This can lead to using an invalid
or even inexistent channel (like 11/HT40+).
Additionally, the return flags from downgrading must be
ORed together, to collect them from all of the downgrades.
Also clarify the message.
Pablo Neira Ayuso says:
The following patchset contains Netfilter/IPVS fixes for 3.8-rc7, they are:
* Fix oops in IPVS state-sync due to releasing a random memory area due
to unitialized pointer, from Dan Carpenter.
* Fix SCTP flow establishment due to bad checksumming mangling in IPVS,
from Daniel Borkmann.
* Three fixes for the recently added IPv6 NPT, all from YOSHIFUJI Hideaki,
with an amendment collapsed into those patches from Ulrich Weber. They
fiix adjustment calculation, fix prefix mangling and ensure LSB of
prefixes are zeroes (as required by RFC).
Specifically, it took me a while to validate the 1's complement arithmetics/
checksumming approach in the IPv6 NPT code.
We should call skb_share_check() before pskb_may_pull(), or we
can crash in pskb_expand_head()
Pull networking fixes from David Miller:
1) Revert iwlwifi reclaimed packet tracking, it causes problems for a
bunch of folks. From Emmanuel Grumbach.
2) Work limiting code in brcmsmac wifi driver can clear tx status
without processing the event. From Arend van Spriel.
3) rtlwifi USB driver processes wrong SKB, fix from Larry Finger.
4) l2tp tunnel delete can race with close, fix from Tom Parkin.
5) pktgen_add_device() failures are not checked at all, fix from Cong
Wang.
6) Fix unintentional removal of carrier off from tun_detach(),
otherwise we confuse userspace, from Michael S. Tsirkin.
7) Don't leak socket reference counts and ubufs in vhost-net driver,
from Jason Wang.
8) vmxnet3 driver gets it's initial carrier state wrong, fix from Neil
Horman.
9) Protect against USB networking devices which spam the host with 0
length frames, from Bjørn Mork.
10) Prevent neighbour overflows in ipv6 for locally destined routes,
from Marcelo Ricardo. This is the best short-term fix for this, a
longer term fix has been implemented in net-next.
11) L2TP uses ipv4 datagram routines in it's ipv6 code, whoops. This
mistake is largely because the ipv6 functions don't even have some
kind of prefix in their names to suggest they are ipv6 specific.
From Tom Parkin.
12) Check SYN packet drops properly in tcp_rcv_fastopen_synack(), from
Yuchung Cheng.
13) Fix races and TX skb freeing bugs in via-rhine's NAPI support, from
Francois Romieu and your's truly.
14) Fix infinite loops and divides by zero in TCP congestion window
handling, from Eric Dumazet, Neal Cardwell, and Ilpo Järvinen.
15) AF_PACKET tx ring handling can leak kernel memory to userspace, fix
from Phil Sutter.
16) Fix error handling in ipv6 GRE tunnel transmit, from Tommi Rantala.
17) Protect XEN netback driver against hostile frontend putting garbage
into the rings, don't leak pages in TX GOP checking, and add proper
resource releasing in error path of xen_netbk_get_requests(). From
Ian Campbell.
18) SCTP authentication keys should be cleared out and released with
kzfree(), from Daniel Borkmann.
19) L2TP is a bit too clever trying to maintain skb->truesize, and ends
up corrupting socket memory accounting to the point where packet
sending is halted indefinitely. Just remove the adjustments
entirely, they aren't really needed. From Eric Dumazet.
20) ATM Iphase driver uses a data type with the same name as the S390
headers, rename to fix the build. From Heiko Carstens.
21) Fix a typo in copying the inner network header offset from one SKB
to another, from Pravin B Shelar.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (56 commits)
net: sctp: sctp_endpoint_free: zero out secret key data
net: sctp: sctp_setsockopt_auth_key: use kzfree instead of kfree
atm/iphase: rename fregt_t -> ffreg_t
net: usb: fix regression from FLAG_NOARP code
l2tp: dont play with skb->truesize
net: sctp: sctp_auth_key_put: use kzfree instead of kfree
netback: correct netbk_tx_err to handle wrap around.
xen/netback: free already allocated memory on failure in xen_netbk_get_requests
xen/netback: don't leak pages on failure in xen_netbk_tx_check_gop.
xen/netback: shutdown the ring if it contains garbage.
net: qmi_wwan: add more Huawei devices, including E320
net: cdc_ncm: add another Huawei vendor specific device
ipv6/ip6_gre: fix error case handling in ip6gre_tunnel_xmit()
tcp: fix for zero packets_in_flight was too broad
brcmsmac: rework of mac80211 .flush() callback operation
ssb: unregister gpios before unloading ssb
bcma: unregister gpios before unloading bcma
rtlwifi: Fix scheduling while atomic bug
net: usbnet: fix tx_dropped statistics
tcp: ipv6: Update MIB counters for drops
On sctp_endpoint_destroy, previously used sensitive keying material
should be zeroed out before the memory is returned, as we already do
with e.g. auth keys when released.
Acked-by: Vlad Yasevich <vyasevic@redhat.com>
In sctp_setsockopt_auth_key, we create a temporary copy of the user
passed shared auth key for the endpoint or association and after
internal setup, we free it right away. Since it's sensitive data, we
should zero out the key before returning the memory back to the
allocator. Thus, use kzfree instead of kfree, just as we do in
sctp_auth_key_put().
Andrew Savchenko reported a DNS failure and we diagnosed that
some UDP sockets were unable to send more packets because their
sk_wmem_alloc was corrupted after a while (tx_queue column in
following trace)
$ cat /proc/net/udp
sl local_address rem_address st tx_queue rx_queue tr tm->when retrnsmt uid timeout inode ref pointer drops
459: 00000000:0270 00000000:0000 07 00000000:00000000 00:00000000 00000000 0 0 4507 2 ffff88003d612380 0
466: 00000000:0277 00000000:0000 07 00000000:00000000 00:00000000 00000000 0 0 4802 2 ffff88003d613180 0
470: 076A070A:007B 00000000:0000 07 FFFF4600:00000000 00:00000000 00000000 123 0 5552 2 ffff880039974380 0
470: 010213AC:007B 00000000:0000 07 00000000:00000000 00:00000000 00000000 0 0 4986 2 ffff88003dbd3180 0
470: 010013AC:007B 00000000:0000 07 00000000:00000000 00:00000000 00000000 0 0 4985 2 ffff88003dbd2e00 0
470: 00FCA8C0:007B 00000000:0000 07 FFFFFB00:00000000 00:00000000 00000000 0 0 4984 2 ffff88003dbd2a80 0
Playing with skb->truesize is tricky, especially when
skb is attached to a socket, as we can fool memory charging.
Just remove this code, its not worth trying to be ultra
precise in xmit path.
Reported-by: Andrew Savchenko <bircoph@gmail.com>
Tested-by: Andrew Savchenko <bircoph@gmail.com>
Cc: James Chapman <jchapman@katalix.com>
For sensitive data like keying material, it is common practice to zero
out keys before returning the memory back to the allocator. Thus, use
kzfree instead of kfree.
git://git.kernel.org/pub/scm/linux/kernel/git/jesse/openvswitch into openvswitch
Jesse Gross says:
One bug fix for net/3.8 for a long standing problem that was reported a few
times recently.
My commit f2d9d270c15ae0139b54a7e7466d738327e97e03
("mac80211: support VHT association") introduced a
very stupid bug: the loop to downgrade the channel
width never attempted to actually use it again so
it would downgrade all the way to 20_NOHT. Fix it.
RFC 6296 points that address bits that are not part of the prefix
has to be zeroed.
Make sure only the bits that are part of the prefix are mangled.
Cast __wsum from/to __sum16 is wrong. Instead, apply appropriate
conversion function: csum_unfold() or csum_fold().
[ The original patch has been modified to undo the final ~ that
csum_fold returns. We only need to fold the 32-bit word that
results from the checksum calculation into a 16-bit to ensure
that the original subnet is restored appropriately. Spotted by
Ulrich Weber. ]
ip6gre_tunnel_xmit() is leaking the skb when we hit this error branch,
and the -1 return value from this function is bogus. Use the error
handling we already have in place in ip6gre_tunnel_xmit() for this error
case to fix this.
Signed-off-by: Tommi Rantala <tt.rantala@gmail.com>
There are transients during normal FRTO procedure during which
the packets_in_flight can go to zero between write_queue state
updates and firing the resulting segments out. As FRTO processing
occurs during that window the check must be more precise to
not match "spuriously" :-). More specificly, e.g., when
packets_in_flight is zero but FLAG_DATA_ACKED is true the problematic
branch that set cwnd into zero would not be taken and new segments
might be sent out later.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Tested-by: Eric Dumazet <edumazet@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
