memcpy() should take into account size of pointers,
not only number of pointers to copy.
Acked-by: Pavel Emelyanov <xemul@openvz.org>
If arp_format_neigh_entry() can be called with n->dev->addr_len == 0, then a
write to hbuffer[-1] occurs.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
The test on map4 should be a test on map6.
The semantic match that finds this problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
expression *x;
identifier f;
constant char *C;
x = \(kmalloc\|kcalloc\|kzalloc\)(...);
... when != x == NULL
when != x != NULL
when != (x || ...)
kfree(x)
f(...,C,...,x,...)
*f(...,x,...)
*x->f
// </smpl>
Acked-by: Paul Moore <paul.moore@hp.com>
The DCCP protocol tries to allocate some large hash tables during
initialisation using the largest size possible. This can be larger than
what the page allocator can provide so it prints a warning. However, the
caller is able to handle the situation so this patch suppresses the
warning.
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Jan reported that his b43-based laptop hangs during suspend.
The problem turned out to be mac80211 asking the driver to
stop the hardware before removing interfaces, and interface
removal caused b43 to touch the hardware (while down, which
causes the hang).
This patch fixes mac80211 to do reorder these operations to
have them in the correct order -- first remove interfaces
and then stop the hardware. Some more code is necessary to
be able to do so in a race-free manner, in particular it is
necessary to not process frames received during quiescing.
Fixes http://bugzilla.kernel.org/show_bug.cgi?id=13337.
Reported-by: Jan Scholz <scholz@fias.uni-frankfurt.de>
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (45 commits)
cnic: Fix ISCSI_KEVENT_IF_DOWN message handling.
net: irda: init spinlock after memcpy
ixgbe: fix for 82599 errata marking UDP checksum errors
r8169: WakeOnLan fix for the 8168
netxen: reset ring consumer during cleanup
net/bridge: use kobject_put to release kobject in br_add_if error path
smc91x.h: add config for Nomadik evaluation kit
NET: ROSE: Don't use static buffer.
eepro: Read buffer overflow
tokenring: Read buffer overflow
at1700: Read buffer overflow
fealnx: Write outside array bounds
ixgbe: remove unnecessary call to device_init_wakeup
ixgbe: Don't priority tag control frames in DCB mode
ixgbe: Enable FCoE offload when DCB is enabled for 82599
net: Rework mdio-ofgpio driver to use of_mdio infrastructure
register at91_ether using platform_driver_probe
skge: Enable WoL by default if supported
net: KS8851 needs to depend on MII
be2net: Bug fix in the non-lro path. Size of received packet was not updated in statistics properly.
Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
irttp_dup() copies a tsap_cb struct, but does not initialize the
spinlock in the new structure, which confuses lockdep.
Signed-off-by: Deepak Saxena <dsaxena@mvista.com>
kobject_init_and_add will alloc memory for kobj->name, so in br_add_if
error path, simply use kobject_del will not free memory for kobj->name.
Fix by using kobject_put instead, kobject_put will internally calls
kobject_del and frees memory for kobj->name.
Signed-off-by: Xiaotian Feng <dfeng@redhat.com>
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
The use of a static buffer in rose2asc() to return its result is not
threadproof and can result in corruption if multiple threads are trying
to use one of the procfs files based on rose2asc().
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (37 commits)
sky2: Avoid races in sky2_down
drivers/net/mlx4: Adjust constant
drivers/net: Move a dereference below a NULL test
connector: maintainer/mail update.
USB host CDC Phonet network interface driver
macsonic, jazzsonic: fix oops on module unload
macsonic: move probe function to .devinit.text
can: switch carrier on if device was stopped while in bus-off state
can: restart device even if dev_alloc_skb() fails
can: sja1000: remove duplicated includes
New device ID for sc92031 [1088:2031]
3c589_cs: re-initialize the multicast in the tc589_reset
Fix error return for setsockopt(SO_TIMESTAMPING)
netxen: fix thermal check and shutdown
netxen: fix deadlock on dev close
netxen: fix context deletion sequence
net: Micrel KS8851 SPI network driver
tcp: Use correct peer adr when copying MD5 keys
tcp: Fix MD5 signature checking on IPv4 mapped sockets
This patch fixes a double free corruption in __cfg80211_scan_done:
BUG kmalloc-512: Object already free
INFO: Allocated in load_elf_binary+0x18b/0x19af age=6
INFO: Freed in load_elf_binary+0x104e/0x19af age=5
INFO: Slab 0xffffea0001bae4c0 objects=14 used=7
INFO: Object 0xffff88007e8a9918 @offset=6424 fp=0xffff88007e8a9488
Bytes b4 0xffff88007e8a9908: 00 00 00 00 00 00 00 00 5a 5a
Pid: 28705, comm: rmmod Tainted: P C 2.6.31-rc2-wl #1
Call Trace:
[<ffffffff810da9f4>] print_trailer+0x14e/0x16e
[<ffffffff810daa56>] object_err+0x42/0x61
[<ffffffff810dbcd9>] __slab_free+0x2af/0x396
[<ffffffffa0ec9694>] ? wiphy_unregister+0x92/0x142 [cfg80211]
[<ffffffff810dd5e3>] kfree+0x13c/0x17a
[<ffffffffa0ec9694>] wiphy_unregister+0x92/0x142 [cfg80211]
[<ffffffffa0eed163>] ieee80211_unregister_hw+0xc8/0xff [mac80211]
[<ffffffffa0f3fbc8>] p54_unregister_common+0x31/0x66 [p54common]
FIX kmalloc-512: Object at 0xffff88007e8a9918 not freed
The code path which leads to the *funny* double free:
request = rdev->scan_req;
dev = dev_get_by_index(&init_net, request->ifidx);
* the driver was unloaded recently and
* therefore dev_get_by_index will return NULL!
if (!dev)
goto out;
rdev->scan_req = NULL; /* not executed... */
out:
kfree(request);
Signed-off-by: Christian Lamparter <chunkeey@web.de>
Potential memory leak via msg pointer in nl80211_get_key() function.
Signed-off-by: Niko Jokinen <ext-niko.k.jokinen@nokia.com>
Signed-off-by: Luciano Coelho <luciano.coelho@nokia.com>
For forwarded frames, we save the precursor address in addr1 in case it
needs to be used to send a Path Error. mesh_path_discard_frame,
however, was using addr2 instead of addr1 to send Path Error frames, so
correct that and also make the comment regarding this more clear.
Signed-off-by: Andrey Yurovsky <andrey@cozybit.com>
The point of this function is to set the software and hardware state at
the same time. When I tried to use it, I found it was only setting the
software state.
Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk>
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
The location of the 802.11 header is calculated incorrectly due to a
wrong placement of parentheses. Found by kmemcheck.
Signed-off-by: Pavel Roskin <proski@gnu.org>
Apparently there actually _are_ tools that try to set
this in sysfs even though it wasn't supposed to be used
this way without claiming first. Guess what: now that
I've cleaned it all up it doesn't matter and we can
simply allow setting the soft-block state in sysfs.
Tested-By: Darren Salt <linux@youmustbejoking.demon.co.uk>
My kvm instance was complaining a lot about sleeping
in atomic contexts in the mesh code, and it turns out
that both mesh_path_add() and mpp_path_add() need to
be able to sleep (they even use synchronize_rcu()!).
I put in a might_sleep() to annotate that, but I see
no way, at least right now, of actually making sure
those functions are only called from process context
since they are both called during TX and RX and the
mesh code itself even calls them with rcu_read_lock()
"held".
Therefore, let's disable it completely for now.
It's possible that I'm only seeing this because the
hwsim's beaconing is broken and thus the peers aren't
discovered right away, but it is possible that this
happens even if beaconing is working, for a peer that
doesn't exist or so.
It should be possible to solve this by deferring the
freeing of the tables to call_rcu() instead of using
synchronize_rcu(), and also using atomic allocations,
but maybe it makes more sense to rework the code to
not call these from atomic contexts and defer more of
the work to the workqueue. Right now, I can't work on
either of those solutions though.
I guess it should be -EINVAL rather than EINVAL. I have not checked
when the bug came in. Perhaps a candidate for -stable?
Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com>
When the TCP connection handshake completes on the passive
side, a variety of state must be set up in the "child" sock,
including the key if MD5 authentication is being used. Fix TCP
for both address families to label the key with the peer's
destination address, rather than the address from the listening
sock, which is usually the wildcard.
Reported-by: Stephen Hemminger <shemminger@vyatta.com>
Signed-off-by: John Dykstra <john.dykstra1@gmail.com>
Fix MD5 signature checking so that an IPv4 active open
to an IPv6 socket can succeed. In particular, use the
correct address family's signature generation function
for the SYN/ACK.
Commit e912b1142be8f1e2c71c71001dc992c6e5eb2ec1
(net: sk_prot_alloc() should not blindly overwrite memory)
took care of not zeroing whole new socket at allocation time.
sock_copy() is another spot where we should be very careful.
We should not set refcnt to a non null value, until
we are sure other fields are correctly setup, or
a lockless reader could catch this socket by mistake,
while not fully (re)initialized.
This patch puts sk_node & sk_refcnt to the very beginning
of struct sock to ease sock_copy() & sk_prot_alloc() job.
We add appropriate smp_wmb() before sk_refcnt initializations
to match our RCU requirements (changes to sock keys should
be committed to memory before sk_refcnt setting)
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-2.6
When a slab cache uses SLAB_DESTROY_BY_RCU, we must be careful when allocating
objects, since slab allocator could give a freed object still used by lockless
readers.
In particular, nf_conntrack RCU lookups rely on ct->tuplehash[xxx].hnnode.next
being always valid (ie containing a valid 'nulls' value, or a valid pointer to next
object in hash chain.)
kmem_cache_zalloc() setups object with NULL values, but a NULL value is not valid
for ct->tuplehash[xxx].hnnode.next.
Fix is to call kmem_cache_alloc() and do the zeroing ourself.
As spotted by Patrick, we also need to make sure lookup keys are committed to
memory before setting refcount to 1, or a lockless reader could get a reference
on the old version of the object. Its key re-check could then pass the barrier.
The first argument is the address family, the second one the hook
number.
Add appropriate MODULE_ALIAS() to facilitate autoloading of can protocol drivers
Signed-off-by: Lothar Wassmann <LW@KARO-electronics.de>
Acked-by: Oliver Hartkopp <oliver@hartkopp.net>
Fix a use after free bug in can protocol drivers
The release functions of the can protocol drivers lack a call to
sock_orphan() which leads to referencing freed memory under certain
circumstances.
This patch fixes a bug reported here:
https://lists.berlios.de/pipermail/socketcan-users/2009-July/000985.html
Fix a possible regression with p9_client_stat where it can try to kfree
an ERR_PTR after an erroneous p9pdu_readf. Also remove an unnecessary data
buffer increment in p9_client_read.
Signed-off-by: Abhishek Kulkarni <adkulkar@umail.iu.edu>
Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
The default 9p transport module is not chosen unless an option parameter (any)
is passed to mount, which thus returns a ENOPROTOSUPPORT. This fix moves the
check out of parse_opts into p9_client_create.
Revert "NET: Fix locking issues in PPP, 6pack, mkiss and strip line disciplines."
skbuff.h: Fix comment for NET_IP_ALIGN
drivers/net: using spin_lock_irqsave() in net_send_packet()
NET: phy_device, fix lock imbalance
gre: fix ToS/DiffServ inherit bug
igb: gcc-3.4.6 fix
atlx: duplicate testing of MCAST flag
netdev: restore MTU change operation
netdev: restore MAC address set and validate operations
sit: fix regression: do not release skb->dst before xmit
net: ip_push_pending_frames() fix
Fixes two bugs:
- ToS/DiffServ inheritance was unintentionally activated when using impair fixed ToS values
- ECN bit was lost during ToS/DiffServ inheritance
Signed-off-by: Andreas Jaggi <aj@open.ch>
* Remove smp_lock.h from files which don't need it (including some headers!)
* Add smp_lock.h to files which do need it
* Make smp_lock.h include conditional in hardirq.h
It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT
This will make hardirq.h inclusion cheaper for every PREEMPT=n config
(which includes allmodconfig/allyesconfig, BTW)
The sit module makes use of skb->dst in it's xmit function, so since
93f154b594fe47 ("net: release dst entry in dev_hard_start_xmit()") sit
tunnels are broken, because the flag IFF_XMIT_DST_RELEASE is not
unset.
This patch unsets that flag for sit devices to fix this
regression.
Signed-off-by: Sascha Hlusiak <contact@saschahlusiak.de>
After commit 2b85a34e911bf483c27cfdd124aeb1605145dc80
(net: No more expensive sock_hold()/sock_put() on each tx)
we do not take any more references on sk->sk_refcnt on outgoing packets.
I forgot to delete two __sock_put() from ip_push_pending_frames()
and ip6_push_pending_frames().
Reported-by: Emil S Tantilov <emils.tantilov@gmail.com>
Tested-by: Emil S Tantilov <emils.tantilov@gmail.com>
Some sockets use SLAB_DESTROY_BY_RCU, and our RCU code correctness
depends on sk->sk_nulls_node.next being always valid. A NULL
value is not allowed as it might fault a lockless reader.
Current sk_prot_alloc() implementation doesnt respect this hypothesis,
calling kmem_cache_alloc() with __GFP_ZERO. Just call memset() around
the forbidden field.
Adding memory barrier after the poll_wait function, paired with
receive callbacks. Adding fuctions sock_poll_wait and sk_has_sleeper
to wrap the memory barrier.
Without the memory barrier, following race can happen.
The race fires, when following code paths meet, and the tp->rcv_nxt
and __add_wait_queue updates stay in CPU caches.
CPU1 CPU2
sys_select receive packet
__add_wait_queue update tp->rcv_nxt
tp->rcv_nxt check sock_def_readable
schedule ...
if (sk->sk_sleep && waitqueue_active(sk->sk_sleep))
wake_up_interruptible(sk->sk_sleep)
If there was no cache the code would work ok, since the wait_queue and
rcv_nxt are opposit to each other.
Meaning that once tp->rcv_nxt is updated by CPU2, the CPU1 either already
passed the tp->rcv_nxt check and sleeps, or will get the new value for
tp->rcv_nxt and will return with new data mask.
In both cases the process (CPU1) is being added to the wait queue, so the
waitqueue_active (CPU2) call cannot miss and will wake up CPU1.
The bad case is when the __add_wait_queue changes done by CPU1 stay in its
cache, and so does the tp->rcv_nxt update on CPU2 side. The CPU1 will then
endup calling schedule and sleep forever if there are no more data on the
socket.
Calls to poll_wait in following modules were ommited:
net/bluetooth/af_bluetooth.c
net/irda/af_irda.c
net/irda/irnet/irnet_ppp.c
net/mac80211/rc80211_pid_debugfs.c
net/phonet/socket.c
net/rds/af_rds.c
net/rfkill/core.c
net/sunrpc/cache.c
net/sunrpc/rpc_pipe.c
net/tipc/socket.c
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Using early netconsole and gianfar driver this error pops up:
netconsole: timeout waiting for carrier
It appears that net/core/netpoll.c:netpoll_setup() is using
cond_resched() in a loop waiting for a carrier.
The thing is that cond_resched() is a no-op when system_state !=
SYSTEM_RUNNING, and so drivers/net/phy/phy.c's state_queue is never
scheduled, therefore link detection doesn't work.
I belive that the main problem is in cond_resched()[1], but despite
how the cond_resched() story ends, it might be a good idea to call
msleep(1) instead of cond_resched(), as suggested by Andrew Morton.
[1] http://lkml.org/lkml/2009/7/7/463
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Pawel Staszewski wrote:
<blockquote>
Some time ago i report this:
http://bugzilla.kernel.org/show_bug.cgi?id=6648
and now with 2.6.29 / 2.6.29.1 / 2.6.29.3 and 2.6.30 it back
dmesg output:
oprofile: using NMI interrupt.
Fix inflate_threshold_root. Now=15 size=11 bits
cat /proc/net/fib_triestat
Basic info: size of leaf: 40 bytes, size of tnode: 56 bytes.
Main:
Aver depth: 2.28
Max depth: 6
Leaves: 276539
Prefixes: 289922
Internal nodes: 66762
1: 35046 2: 13824 3: 9508 4: 4897 5: 2331 6: 1149 7: 5
9: 1 18: 1
Pointers: 691228
Null ptrs: 347928
Total size: 35709 kB
</blockquote>
It seems, the current threshold for root resizing is too aggressive,
and it causes misleading warnings during big updates, but it might be
also responsible for memory problems, especially with non-preempt
configs, when RCU freeing is delayed long after call_rcu.
It should be also mentioned that because of non-atomic changes during
resizing/rebalancing the current lookup algorithm can miss valid leaves
so it's additional argument to shorten these activities even at a cost
of a minimally longer searching.
This patch restores values before the patch "[IPV4]: fib_trie root
node settings", commit: 965ffea43d4ebe8cd7b9fee78d651268dd7d23c5 from
v2.6.22.
Pawel's report:
<blockquote>
I dont see any big change of (cpu load or faster/slower
routing/propagating routes from bgpd or something else) - in avg there
is from 2% to 3% more of CPU load i dont know why but it is - i change
from "preempt" to "no preempt" 3 times and check this my "mpstat -P ALL
1 30"
always avg cpu load was from 2 to 3% more compared to "no preempt"
Basic info: size of leaf: 20 bytes, size of tnode: 36 bytes.
Main:
Aver depth: 2.44
Max depth: 6
Leaves: 277814
Prefixes: 291306
Internal nodes: 66420
1: 32737 2: 14850 3: 10332 4: 4871 5: 2313 6: 942 7: 371 8: 3 17: 1
Pointers: 599098
Null ptrs: 254865
Total size: 18067 kB
</blockquote>
According to this and other similar reports average depth is slightly
increased (~0.2), and root nodes are shorter (log 17 vs. 18), but
there is no visible performance decrease. So, until memory handling is
improved or added parameters for changing this individually, this
patch resets to safer defaults.
Reported-by: Pawel Staszewski <pstaszewski@itcare.pl>
Reported-by: Jorge Boncompte [DTI2] <jorge@dti2.net>
Signed-off-by: Jarek Poplawski <jarkao2@gmail.com>
Tested-by: Pawel Staszewski <pstaszewski@itcare.pl>
If rix is not found in mi->r[], i will become -1 after the loop. This value
is eventually used to access arrays, so we were accessing arrays with a
negative index, which is obviously not what we want to do. This patch fixes
this potential problem.
Acked-by: Felix Fietkau <nbd@openwrt.org>
The code in cfg80211's cfg80211_bss_update erroneously
grabs a reference to the BSS, which means that it will
never be freed.
Cc: stable@kernel.org [2.6.29, 2.6.30]
We allocate a PREQ queue node in mesh_queue_preq, however the allocation
may cause us to sleep. Use GFP_ATOMIC to prevent this.
[ 1869.126498] BUG: scheduling while atomic: ping/1859/0x10000100
[ 1869.127164] Modules linked in: ath5k mac80211 ath
[ 1869.128310] Pid: 1859, comm: ping Not tainted 2.6.30-wl #1
[ 1869.128754] Call Trace:
[ 1869.129293] [<c1023a2b>] __schedule_bug+0x48/0x4d
[ 1869.129866] [<c13b5533>] __schedule+0x77/0x67a
[ 1869.130544] [<c1026f2e>] ? release_console_sem+0x17d/0x185
[ 1869.131568] [<c807cf47>] ? mesh_queue_preq+0x2b/0x165 [mac80211]
[ 1869.132318] [<c13b5b3e>] schedule+0x8/0x1f
[ 1869.132807] [<c1023c12>] __cond_resched+0x16/0x2f
[ 1869.133478] [<c13b5bf0>] _cond_resched+0x27/0x32
[ 1869.134191] [<c108a370>] kmem_cache_alloc+0x1c/0xcf
[ 1869.134714] [<c10273ae>] ? printk+0x15/0x17
[ 1869.135670] [<c807cf47>] mesh_queue_preq+0x2b/0x165 [mac80211]
[ 1869.136731] [<c807d1f8>] mesh_nexthop_lookup+0xee/0x12d [mac80211]
[ 1869.138130] [<c807417e>] ieee80211_xmit+0xe6/0x2b2 [mac80211]
[ 1869.138935] [<c80be46d>] ? ath5k_hw_setup_rx_desc+0x0/0x66 [ath5k]
[ 1869.139831] [<c80c97bc>] ? ath5k_tasklet_rx+0xba/0x506 [ath5k]
[ 1869.140863] [<c8075191>] ieee80211_subif_start_xmit+0x6c9/0x6e4
[mac80211]
[ 1869.141665] [<c105cf1c>] ? handle_level_irq+0x78/0x9d
[ 1869.142390] [<c12e3f93>] dev_hard_start_xmit+0x168/0x1c7
[ 1869.143092] [<c12f1f17>] __qdisc_run+0xe1/0x1b7
[ 1869.143612] [<c12e25ff>] qdisc_run+0x18/0x1a
[ 1869.144248] [<c12e62f4>] dev_queue_xmit+0x16a/0x25a
[ 1869.144785] [<c13b6dcc>] ? _read_unlock_bh+0xe/0x10
[ 1869.145465] [<c12eacdb>] neigh_resolve_output+0x19c/0x1c7
[ 1869.146182] [<c130e2da>] ? ip_finish_output+0x0/0x51
[ 1869.146697] [<c130e2a0>] ip_finish_output2+0x182/0x1bc
[ 1869.147358] [<c130e327>] ip_finish_output+0x4d/0x51
[ 1869.147863] [<c130e9d5>] ip_output+0x80/0x85
[ 1869.148515] [<c130cc49>] dst_output+0x9/0xb
[ 1869.149141] [<c130dec6>] ip_local_out+0x17/0x1a
[ 1869.149632] [<c130e0bc>] ip_push_pending_frames+0x1f3/0x255
[ 1869.150343] [<c13247ff>] raw_sendmsg+0x5e6/0x667
[ 1869.150883] [<c1033c55>] ? insert_work+0x6a/0x73
[ 1869.151834] [<c8071e00>] ?
ieee80211_invoke_rx_handlers+0x17da/0x1ae8 [mac80211]
[ 1869.152630] [<c132bd68>] inet_sendmsg+0x3b/0x48
[ 1869.153232] [<c12d7deb>] __sock_sendmsg+0x45/0x4e
[ 1869.153740] [<c12d8537>] sock_sendmsg+0xb8/0xce
[ 1869.154519] [<c80be46d>] ? ath5k_hw_setup_rx_desc+0x0/0x66 [ath5k]
[ 1869.155289] [<c1036b25>] ? autoremove_wake_function+0x0/0x30
[ 1869.155859] [<c115992b>] ? __copy_from_user_ll+0x11/0xce
[ 1869.156573] [<c1159d99>] ? copy_from_user+0x31/0x54
[ 1869.157235] [<c12df646>] ? verify_iovec+0x40/0x6e
[ 1869.157778] [<c12d869a>] sys_sendmsg+0x14d/0x1a5
[ 1869.158714] [<c8072c40>] ? __ieee80211_rx+0x49e/0x4ee [mac80211]
[ 1869.159641] [<c80c83fe>] ? ath5k_rxbuf_setup+0x6d/0x8d [ath5k]
[ 1869.160543] [<c80be46d>] ? ath5k_hw_setup_rx_desc+0x0/0x66 [ath5k]
[ 1869.161434] [<c80beba4>] ? ath5k_hw_get_rxdp+0xe/0x10 [ath5k]
[ 1869.162319] [<c80c97bc>] ? ath5k_tasklet_rx+0xba/0x506 [ath5k]
[ 1869.163063] [<c1005627>] ? enable_8259A_irq+0x40/0x43
[ 1869.163594] [<c101edb8>] ? __dequeue_entity+0x23/0x27
[ 1869.164793] [<c100187a>] ? __switch_to+0x2b/0x105
[ 1869.165442] [<c1021d5f>] ? finish_task_switch+0x5b/0x74
[ 1869.166129] [<c12d963a>] sys_socketcall+0x14b/0x17b
[ 1869.166612] [<c1002b95>] syscall_call+0x7/0xb
Don't forget to unlock cfg80211_mutex in one fail path of
nl80211_set_wiphy.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Commit 'net: Move rx skb_orphan call to where needed' broken sctp protocol
with warning at inet_sock_destruct(). Actually, sctp can do this right with
sctp_sock_rfree_frag() and sctp_skb_set_owner_r_frag() pair.
sctp_sock_rfree_frag(skb);
sctp_skb_set_owner_r_frag(skb, newsk);
This patch not revert the commit d55d87fdff8252d0e2f7c28c2d443aee17e9d70f,
instead remove the sctp_sock_rfree_frag() function.
WARNING: at net/ipv4/af_inet.c:151 inet_sock_destruct+0xe0/0x142()
Modules linked in: sctp ipv6 dm_mirror dm_region_hash dm_log dm_multipath
scsi_mod ext3 jbd uhci_hcd ohci_hcd ehci_hcd [last unloaded: scsi_wait_scan]
Pid: 1808, comm: sctp_test Not tainted 2.6.31-rc2 #40
Call Trace:
[<c042dd06>] warn_slowpath_common+0x6a/0x81
[<c064a39a>] ? inet_sock_destruct+0xe0/0x142
[<c042dd2f>] warn_slowpath_null+0x12/0x15
[<c064a39a>] inet_sock_destruct+0xe0/0x142
[<c05fde44>] __sk_free+0x19/0xcc
[<c05fdf50>] sk_free+0x18/0x1a
[<ca0d14ad>] sctp_close+0x192/0x1a1 [sctp]
[<c0649f7f>] inet_release+0x47/0x4d
[<c05fba4d>] sock_release+0x19/0x5e
[<c05fbab3>] sock_close+0x21/0x25
[<c049c31b>] __fput+0xde/0x189
[<c049c3de>] fput+0x18/0x1a
[<c049988f>] filp_close+0x56/0x60
[<c042f422>] put_files_struct+0x5d/0xa1
[<c042f49f>] exit_files+0x39/0x3d
[<c043086a>] do_exit+0x1a5/0x5dd
[<c04a86c2>] ? d_kill+0x35/0x3b
[<c0438fa4>] ? dequeue_signal+0xa6/0x115
[<c0430d05>] do_group_exit+0x63/0x8a
[<c0439504>] get_signal_to_deliver+0x2e1/0x2f9
[<c0401d9e>] do_notify_resume+0x7c/0x6b5
[<c043f601>] ? autoremove_wake_function+0x0/0x34
[<c04a864e>] ? __d_free+0x3d/0x40
[<c04a867b>] ? d_free+0x2a/0x3c
[<c049ba7e>] ? vfs_write+0x103/0x117
[<c05fc8fa>] ? sys_socketcall+0x178/0x182
[<c0402a56>] work_notifysig+0x13/0x19
---[ end trace 9db92c463e789fba ]---
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com>
The bit that tells us whether a statistics counter snapshot operation
has completed is located in the GLOBAL register block, not in the
GLOBAL2 register block, so fix up mv88e6xxx_stats_wait() to poll the
right register address.
Signed-off-by: Stephane Contri <Stephane.Contri@grassvalley.com>
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
There's a bug in addrconf_prefix_rcv() where it won't update the
preferred lifetime of an IPv6 address if the current valid lifetime
of the address is less than 2 hours (the minimum value in the RA).
For example, If I send a router advertisement with a prefix that
has valid lifetime = preferred lifetime = 2 hours we'll build
this address:
3: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qlen 1000
inet6 2001:1890:1109:a20:217:8ff:fe7d:4718/64 scope global dynamic
valid_lft 7175sec preferred_lft 7175sec
If I then send the same prefix with valid lifetime = preferred
lifetime = 0 it will be ignored since the minimum valid lifetime
is 2 hours:
valid_lft 7161sec preferred_lft 7161sec
But according to RFC 4862 we should always reset the preferred lifetime
even if the valid lifetime is invalid, which would cause the address
to immediately get deprecated. So with this patch we'd see this:
5: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qlen 1000
inet6 2001:1890:1109:a20:21f:29ff:fe5a:ef04/64 scope global deprecated dynamic
valid_lft 7163sec preferred_lft 0sec
The comment winds-up being 5x the size of the code to fix the problem.
Update the preferred lifetime of IPv6 addresses derived from a prefix
info option in a router advertisement even if the valid lifetime in
the option is invalid, as specified in RFC 4862 Section 5.5.3e. Fixes
an issue where an address will not immediately become deprecated.
Reported by Jens Rosenboom.
Signed-off-by: Brian Haley <brian.haley@hp.com>
The SCTP pushed the skb above the sctp chunk header, so the
check of pskb_may_pull(skb, nh + offset + 1 - skb->data) in
_decode_session6() will never return 0 and the ports decode
of sctp will always fail. (nh + offset + 1 - skb->data < 0)
The SCTP pushed the skb data above the sctp chunk header, so the check
of pskb_may_pull(skb, xprth + 4 - skb->data) in _decode_session4() will
never return 0 because xprth + 4 - skb->data < 0, the ports decode of
It is not safe to use match_int without checking the token type returned
by match_token (especially when the token type returned is Opt_err and
args is empty). Fix it.
