[ Upstream commit 757efd32d5ce31f67193cc0e6a56e4dffcc42fb1 ]
Dave reported following splat, caused by improper use of
IP_INC_STATS_BH() in process context.
BUG: using __this_cpu_add() in preemptible [00000000] code: trinity-c117/14551
caller is __this_cpu_preempt_check+0x13/0x20
CPU: 3 PID: 14551 Comm: trinity-c117 Not tainted 3.16.0+ #33
ffffffff9ec898f0 0000000047ea7e23 ffff88022d32f7f0 ffffffff9e7ee207
0000000000000003 ffff88022d32f818 ffffffff9e397eaa ffff88023ee70b40
ffff88022d32f970 ffff8801c026d580 ffff88022d32f828 ffffffff9e397ee3
Call Trace:
[<ffffffff9e7ee207>] dump_stack+0x4e/0x7a
[<ffffffff9e397eaa>] check_preemption_disabled+0xfa/0x100
[<ffffffff9e397ee3>] __this_cpu_preempt_check+0x13/0x20
[<ffffffffc0839872>] sctp_packet_transmit+0x692/0x710 [sctp]
[<ffffffffc082a7f2>] sctp_outq_flush+0x2a2/0xc30 [sctp]
[<ffffffff9e0d985c>] ? mark_held_locks+0x7c/0xb0
[<ffffffff9e7f8c6d>] ? _raw_spin_unlock_irqrestore+0x5d/0x80
[<ffffffffc082b99a>] sctp_outq_uncork+0x1a/0x20 [sctp]
[<ffffffffc081e112>] sctp_cmd_interpreter.isra.23+0x1142/0x13f0 [sctp]
[<ffffffffc081c86b>] sctp_do_sm+0xdb/0x330 [sctp]
[<ffffffff9e0b8f1b>] ? preempt_count_sub+0xab/0x100
[<ffffffffc083b350>] ? sctp_cname+0x70/0x70 [sctp]
[<ffffffffc08389ca>] sctp_primitive_ASSOCIATE+0x3a/0x50 [sctp]
[<ffffffffc083358f>] sctp_sendmsg+0x88f/0xe30 [sctp]
[<ffffffff9e0d673a>] ? lock_release_holdtime.part.28+0x9a/0x160
[<ffffffff9e0d62ce>] ? put_lock_stats.isra.27+0xe/0x30
[<ffffffff9e73b624>] inet_sendmsg+0x104/0x220
[<ffffffff9e73b525>] ? inet_sendmsg+0x5/0x220
[<ffffffff9e68ac4e>] sock_sendmsg+0x9e/0xe0
[<ffffffff9e1c0c09>] ? might_fault+0xb9/0xc0
[<ffffffff9e1c0bae>] ? might_fault+0x5e/0xc0
[<ffffffff9e68b234>] SYSC_sendto+0x124/0x1c0
[<ffffffff9e0136b0>] ? syscall_trace_enter+0x250/0x330
[<ffffffff9e68c3ce>] SyS_sendto+0xe/0x10
[<ffffffff9e7f9be4>] tracesys+0xdd/0xe2
This is a followup of commits f1d8cba61c3c4b ("inet: fix possible
seqlock deadlocks") and 7f88c6b23afbd315 ("ipv6: fix possible seqlock
deadlock in ip6_finish_output2")
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Reported-by: Dave Jones <davej@redhat.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
[ Upstream commit d9124268d84a836f14a6ead54ff9d8eee4c43be5 ]
batadv_frag_insert_packet was unable to handle out-of-order packets because it
dropped them directly. This is caused by the way the fragmentation lists is
checked for the correct place to insert a fragmentation entry.
The fragmentation code keeps the fragments in lists. The fragmentation entries
are kept in descending order of sequence number. The list is traversed and each
entry is compared with the new fragment. If the current entry has a smaller
sequence number than the new fragment then the new one has to be inserted
before the current entry. This ensures that the list is still in descending
order.
An out-of-order packet with a smaller sequence number than all entries in the
list still has to be added to the end of the list. The used hlist has no
information about the last entry in the list inside hlist_head and thus the
last entry has to be calculated differently. Currently the code assumes that
the iterator variable of hlist_for_each_entry can be used for this purpose
after the hlist_for_each_entry finished. This is obviously wrong because the
iterator variable is always NULL when the list was completely traversed.
Instead the information about the last entry has to be stored in a different
variable.
This problem was introduced in 610bfc6bc99bc83680d190ebc69359a05fc7f605
("batman-adv: Receive fragmented packets and merge").
Signed-off-by: Sven Eckelmann <sven@narfation.org>
Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
[ Upstream commit 06ebb06d49486676272a3c030bfeef4bd969a8e6 ]
Check for cases when the caller requests 0 bytes instead of running off
and dereferencing potentially invalid iovecs.
[ Upstream commit fcdfe3a7fa4cb74391d42b6a26dc07c20dab1d82 ]
When performing segmentation, the mac_len value is copied right
out of the original skb. However, this value is not always set correctly
(like when the packet is VLAN-tagged) and we'll end up copying a bad
value.
One way to demonstrate this is to configure a VM which tags
packets internally and turn off VLAN acceleration on the forwarding
bridge port. The packets show up corrupt like this:
16:18:24.985548 52:54:00:ab:be:25 > 52:54:00:26:ce:a3, ethertype 802.1Q
(0x8100), length 1518: vlan 100, p 0, ethertype 0x05e0,
0x0000: 8cdb 1c7c 8cdb 0064 4006 b59d 0a00 6402 ...|...d@.....d.
0x0010: 0a00 6401 9e0d b441 0a5e 64ec 0330 14fa ..d....A.^d..0..
0x0020: 29e3 01c9 f871 0000 0101 080a 000a e833)....q.........3
0x0030: 000f 8c75 6e65 7470 6572 6600 6e65 7470 ...unetperf.netp
0x0040: 6572 6600 6e65 7470 6572 6600 6e65 7470 erf.netperf.netp
0x0050: 6572 6600 6e65 7470 6572 6600 6e65 7470 erf.netperf.netp
0x0060: 6572 6600 6e65 7470 6572 6600 6e65 7470 erf.netperf.netp
This also leads to awful throughput as GSO packets are dropped and
cause retransmissions.
The solution is to set the mac_len using the values already available
in then new skb. We've already adjusted all of the header offset, so we
might as well correctly figure out the mac_len using skb_reset_mac_len().
After this change, packets are segmented correctly and performance
is restored.
CC: Eric Dumazet <edumazet@google.com>
Signed-off-by: Vlad Yasevich <vyasevic@redhat.com>
[ Upstream commit 1be9a950c646c9092fb3618197f7b6bfb50e82aa ]
Jason reported an oops caused by SCTP on his ARM machine with
SCTP authentication enabled:
Internal error: Oops: 17 [#1] ARM
CPU: 0 PID: 104 Comm: sctp-test Not tainted 3.13.0-68744-g3632f30c9b20-dirty #1
task: c6eefa40 ti: c6f52000 task.ti: c6f52000
PC is at sctp_auth_calculate_hmac+0xc4/0x10c
LR is at sg_init_table+0x20/0x38
pc : [<c024bb80>] lr : [<c00f32dc>] psr: 40000013
sp : c6f538e8 ip : 00000000 fp : c6f53924
r10: c6f50d80 r9 : 00000000 r8 : 00010000
r7 : 00000000 r6 : c7be4000 r5 : 00000000 r4 : c6f56254
r3 : c00c8170 r2 : 00000001 r1 : 00000008 r0 : c6f1e660
Flags: nZcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Control: 0005397f Table: 06f28000 DAC: 00000015
Process sctp-test (pid: 104, stack limit = 0xc6f521c0)
Stack: (0xc6f538e8 to 0xc6f54000)
Backtrace:
[<c024babc>] (sctp_auth_calculate_hmac+0x0/0x10c) from [<c0249af8>] (sctp_packet_transmit+0x33c/0x5c8)
[<c02497bc>] (sctp_packet_transmit+0x0/0x5c8) from [<c023e96c>] (sctp_outq_flush+0x7fc/0x844)
[<c023e170>] (sctp_outq_flush+0x0/0x844) from [<c023ef78>] (sctp_outq_uncork+0x24/0x28)
[<c023ef54>] (sctp_outq_uncork+0x0/0x28) from [<c0234364>] (sctp_side_effects+0x1134/0x1220)
[<c0233230>] (sctp_side_effects+0x0/0x1220) from [<c02330b0>] (sctp_do_sm+0xac/0xd4)
[<c0233004>] (sctp_do_sm+0x0/0xd4) from [<c023675c>] (sctp_assoc_bh_rcv+0x118/0x160)
[<c0236644>] (sctp_assoc_bh_rcv+0x0/0x160) from [<c023d5bc>] (sctp_inq_push+0x6c/0x74)
[<c023d550>] (sctp_inq_push+0x0/0x74) from [<c024a6b0>] (sctp_rcv+0x7d8/0x888)
While we already had various kind of bugs in that area
ec0223ec48a9 ("net: sctp: fix sctp_sf_do_5_1D_ce to verify if
we/peer is AUTH capable") and b14878ccb7fa ("net: sctp: cache
auth_enable per endpoint"), this one is a bit of a different
kind.
Giving a bit more background on why SCTP authentication is
needed can be found in RFC4895:
SCTP uses 32-bit verification tags to protect itself against
blind attackers. These values are not changed during the
lifetime of an SCTP association.
Looking at new SCTP extensions, there is the need to have a
method of proving that an SCTP chunk(s) was really sent by
the original peer that started the association and not by a
malicious attacker.
To cause this bug, we're triggering an INIT collision between
peers; normal SCTP handshake where both sides intent to
authenticate packets contains RANDOM; CHUNKS; HMAC-ALGO
parameters that are being negotiated among peers:
---------- INIT[RANDOM; CHUNKS; HMAC-ALGO] ---------->
<------- INIT-ACK[RANDOM; CHUNKS; HMAC-ALGO] ---------
-------------------- COOKIE-ECHO -------------------->
<-------------------- COOKIE-ACK ---------------------
RFC4895 says that each endpoint therefore knows its own random
number and the peer's random number *after* the association
has been established. The local and peer's random number along
with the shared key are then part of the secret used for
calculating the HMAC in the AUTH chunk.
Now, in our scenario, we have 2 threads with 1 non-blocking
SEQ_PACKET socket each, setting up common shared SCTP_AUTH_KEY
and SCTP_AUTH_ACTIVE_KEY properly, and each of them calling
sctp_bindx(3), listen(2) and connect(2) against each other,
thus the handshake looks similar to this, e.g.:
<--------- INIT[RANDOM; CHUNKS; HMAC-ALGO] -----------
-------- INIT-ACK[RANDOM; CHUNKS; HMAC-ALGO] -------->
Since such collisions can also happen with verification tags,
the RFC4895 for AUTH rather vaguely says under section 6.1:
In case of INIT collision, the rules governing the handling
of this Random Number follow the same pattern as those for
the Verification Tag, as explained in Section 5.2.4 of
RFC 2960 [5]. Therefore, each endpoint knows its own Random
Number and the peer's Random Number after the association
In RFC2960, section 5.2.4, we're eventually hitting Action B:
B) In this case, both sides may be attempting to start an
association at about the same time but the peer endpoint
started its INIT after responding to the local endpoint's
INIT. Thus it may have picked a new Verification Tag not
being aware of the previous Tag it had sent this endpoint.
The endpoint should stay in or enter the ESTABLISHED
state but it MUST update its peer's Verification Tag from
the State Cookie, stop any init or cookie timers that may
running and send a COOKIE ACK.
In other words, the handling of the Random parameter is the
same as behavior for the Verification Tag as described in
Action B of section 5.2.4.
Looking at the code, we exactly hit the sctp_sf_do_dupcook_b()
case which triggers an SCTP_CMD_UPDATE_ASSOC command to the
side effect interpreter, and in fact it properly copies over
peer_{random, hmacs, chunks} parameters from the newly created
association to update the existing one.
Also, the old asoc_shared_key is being released and based on
the new params, sctp_auth_asoc_init_active_key() updated.
However, the issue observed in this case is that the previous
asoc->peer.auth_capable was 0, and has *not* been updated, so
that instead of creating a new secret, we're doing an early
return from the function sctp_auth_asoc_init_active_key()
leaving asoc->asoc_shared_key as NULL. However, we now have to
authenticate chunks from the updated chunk list (e.g. COOKIE-ACK).
That in fact causes the server side when responding with ...
<------------------ AUTH; COOKIE-ACK -----------------
... to trigger a NULL pointer dereference, since in
sctp_packet_transmit(), it discovers that an AUTH chunk is
being queued for xmit, and thus it calls sctp_auth_calculate_hmac().
Since the asoc->active_key_id is still inherited from the
endpoint, and the same as encoded into the chunk, it uses
asoc->asoc_shared_key, which is still NULL, as an asoc_key
and dereferences it in ...
crypto_hash_setkey(desc.tfm, &asoc_key->data[0], asoc_key->len)
... causing an oops. All this happens because sctp_make_cookie_ack()
called with the *new* association has the peer.auth_capable=1
and therefore marks the chunk with auth=1 after checking
sctp_auth_send_cid(), but it is *actually* sent later on over
the then *updated* association's transport that didn't initialize
its shared key due to peer.auth_capable=0. Since control chunks
in that case are not sent by the temporary association which
are scheduled for deletion, they are issued for xmit via
SCTP_CMD_REPLY in the interpreter with the context of the
*updated* association. peer.auth_capable was 0 in the updated
association (which went from COOKIE_WAIT into ESTABLISHED state),
since all previous processing that performed sctp_process_init()
was being done on temporary associations, that we eventually
throw away each time.
The correct fix is to update to the new peer.auth_capable
value as well in the collision case via sctp_assoc_update(),
so that in case the collision migrated from 0 -> 1,
sctp_auth_asoc_init_active_key() can properly recalculate
the secret. This therefore fixes the observed server panic.
Fixes: 730fc3d05cd4 ("[SCTP]: Implete SCTP-AUTH parameter processing")
Reported-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Tested-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Cc: Vlad Yasevich <vyasevich@gmail.com>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit 1f74e613ded11517db90b2bd57e9464d9e0fb161 ]
In vegas we do a multiplication of the cwnd and the rtt. This
may overflow and thus their result is stored in a u64. However, we first
need to cast the cwnd so that actually 64-bit arithmetic is done.
Then, we need to do do_div to allow this to be used on 32-bit arches.
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Neal Cardwell <ncardwell@google.com>
Cc: David Laight <David.Laight@ACULAB.COM>
Cc: Doug Leith <doug.leith@nuim.ie>
Fixes: 8d3a564da34e (tcp: tcp_vegas cong avoid fix)
Signed-off-by: Christoph Paasch <christoph.paasch@uclouvain.be>
[ Upstream commit 45a07695bc64b3ab5d6d2215f9677e5b8c05a7d0 ]
In veno we do a multiplication of the cwnd and the rtt. This
A first attempt at fixing 76f1017757aa0 ([TCP]: TCP Veno congestion
control) was made by 159131149c2 (tcp: Overflow bug in Vegas), but it
failed to add the required cast in tcp_veno_cong_avoid().
Fixes: 76f1017757aa0 ([TCP]: TCP Veno congestion control)
[ Upstream commit 95cb5745983c222867cc9ac593aebb2ad67d72c0 ]
Ipv4 tunnels created with "local any remote $ip" didn't work properly since
7d442fab0 (ipv4: Cache dst in tunnels). 99% of packets sent via those tunnels
had src addr = 0.0.0.0. That was because only dst_entry was cached, although
fl4.saddr has to be cached too. Every time ip_tunnel_xmit used cached dst_entry
(tunnel_rtable_get returned non-NULL), fl4.saddr was initialized with
tnl_params->saddr (= 0 in our case), and wasn't changed until iptunnel_xmit().
This patch adds saddr to ip_tunnel->dst_cache, fixing this issue.
Reported-by: Sergey Popov <pinkbyte@gentoo.org>
Signed-off-by: Dmitry Popov <ixaphire@qrator.net>
[ Upstream commit 40eea803c6b2cfaab092f053248cbeab3f368412 ]
Sasha's report:
> While fuzzing with trinity inside a KVM tools guest running the latest -next
> kernel with the KASAN patchset, I've stumbled on the following spew:
> [ 4448.949424] ==================================================================
> [ 4448.951737] AddressSanitizer: user-memory-access on address 0
> [ 4448.952988] Read of size 2 by thread T19638:
> [ 4448.954510] CPU: 28 PID: 19638 Comm: trinity-c76 Not tainted 3.16.0-rc4-next-20140711-sasha-00046-g07d3099-dirty #813
> [ 4448.956823] ffff88046d86ca40 0000000000000000 ffff880082f37e78 ffff880082f37a40
> [ 4448.958233] ffffffffb6e47068 ffff880082f37a68 ffff880082f37a58 ffffffffb242708d
> [ 4448.959552] 0000000000000000 ffff880082f37a88 ffffffffb24255b1 0000000000000000
> [ 4448.961266] Call Trace:
> [ 4448.963158] dump_stack (lib/dump_stack.c:52)
> [ 4448.964244] kasan_report_user_access (mm/kasan/report.c:184)
> [ 4448.965507] __asan_load2 (mm/kasan/kasan.c:352)
> [ 4448.966482] ? netlink_sendmsg (net/netlink/af_netlink.c:2339)
> [ 4448.967541] netlink_sendmsg (net/netlink/af_netlink.c:2339)
> [ 4448.968537] ? get_parent_ip (kernel/sched/core.c:2555)
> [ 4448.970103] sock_sendmsg (net/socket.c:654)
> [ 4448.971584] ? might_fault (mm/memory.c:3741)
> [ 4448.972526] ? might_fault (./arch/x86/include/asm/current.h:14 mm/memory.c:3740)
> [ 4448.973596] ? verify_iovec (net/core/iovec.c:64)
> [ 4448.974522] ___sys_sendmsg (net/socket.c:2096)
> [ 4448.975797] ? put_lock_stats.isra.13 (./arch/x86/include/asm/preempt.h:98 kernel/locking/lockdep.c:254)
> [ 4448.977030] ? lock_release_holdtime (kernel/locking/lockdep.c:273)
> [ 4448.978197] ? lock_release_non_nested (kernel/locking/lockdep.c:3434 (discriminator 1))
> [ 4448.979346] ? check_chain_key (kernel/locking/lockdep.c:2188)
> [ 4448.980535] __sys_sendmmsg (net/socket.c:2181)
> [ 4448.981592] ? trace_hardirqs_on_caller (kernel/locking/lockdep.c:2600)
> [ 4448.982773] ? trace_hardirqs_on (kernel/locking/lockdep.c:2607)
> [ 4448.984458] ? syscall_trace_enter (arch/x86/kernel/ptrace.c:1500 (discriminator 2))
> [ 4448.985621] ? trace_hardirqs_on_caller (kernel/locking/lockdep.c:2600)
> [ 4448.986754] SyS_sendmmsg (net/socket.c:2201)
> [ 4448.987708] tracesys (arch/x86/kernel/entry_64.S:542)
> [ 4448.988929] ==================================================================
This reports means that we've come to netlink_sendmsg() with msg->msg_name == NULL and msg->msg_namelen > 0.
After this report there was no usual "Unable to handle kernel NULL pointer dereference"
and this gave me a clue that address 0 is mapped and contains valid socket address structure in it.
This bug was introduced in f3d3342602f8bcbf37d7c46641cb9bca7618eb1c
(net: rework recvmsg handler msg_name and msg_namelen logic).
Commit message states that:
"Set msg->msg_name = NULL if user specified a NULL in msg_name but had a
non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't
affect sendto as it would bail out earlier while trying to copy-in the
address."
But in fact this affects sendto when address 0 is mapped and contains
socket address structure in it. In such case copy-in address will succeed,
verify_iovec() function will successfully exit with msg->msg_namelen > 0
and msg->msg_name == NULL.
This patch fixes it by setting msg_namelen to 0 if msg_name == NULL.
Cc: Eric Dumazet <edumazet@google.com>
Cc: <stable@vger.kernel.org>
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
[ Upstream commit 04ca6973f7c1a0d8537f2d9906a0cf8e69886d75 ]
In "Counting Packets Sent Between Arbitrary Internet Hosts", Jeffrey and
Jedidiah describe ways exploiting linux IP identifier generation to
infer whether two machines are exchanging packets.
With commit 73f156a6e8c1 ("inetpeer: get rid of ip_id_count"), we
changed IP id generation, but this does not really prevent this
side-channel technique.
This patch adds a random amount of perturbation so that IP identifiers
for a given destination [1] are no longer monotonically increasing after
an idle period.
Note that prandom_u32_max(1) returns 0, so if generator is used at most
once per jiffy, this patch inserts no hole in the ID suite and do not
increase collision probability.
This is jiffies based, so in the worst case (HZ=1000), the id can
rollover after ~65 seconds of idle time, which should be fine.
We also change the hash used in __ip_select_ident() to not only hash
on daddr, but also saddr and protocol, so that ICMP probes can not be
used to infer information for other protocols.
For IPv6, adds saddr into the hash as well, but not nexthdr.
If I ping the patched target, we can see ID are now hard to predict.
21:57:11.008086 IP (...)
A > target: ICMP echo request, seq 1, length 64
21:57:11.010752 IP (... id 2081 ...)
target > A: ICMP echo reply, seq 1, length 64
21:57:12.013133 IP (...)
A > target: ICMP echo request, seq 2, length 64
21:57:12.015737 IP (... id 3039 ...)
target > A: ICMP echo reply, seq 2, length 64
21:57:13.016580 IP (...)
A > target: ICMP echo request, seq 3, length 64
21:57:13.019251 IP (... id 3437 ...)
target > A: ICMP echo reply, seq 3, length 64
[1] TCP sessions uses a per flow ID generator not changed by this patch.
Reported-by: Jeffrey Knockel <jeffk@cs.unm.edu>
Reported-by: Jedidiah R. Crandall <crandall@cs.unm.edu>
Cc: Willy Tarreau <w@1wt.eu>
Cc: Hannes Frederic Sowa <hannes@redhat.com>
[ Upstream commit 73f156a6e8c1074ac6327e0abd1169e95eb66463 ]
Ideally, we would need to generate IP ID using a per destination IP
generator.
linux kernels used inet_peer cache for this purpose, but this had a huge
cost on servers disabling MTU discovery.
1) each inet_peer struct consumes 192 bytes
2) inetpeer cache uses a binary tree of inet_peer structs,
with a nominal size of ~66000 elements under load.
3) lookups in this tree are hitting a lot of cache lines, as tree depth
is about 20.
4) If server deals with many tcp flows, we have a high probability of
not finding the inet_peer, allocating a fresh one, inserting it in
the tree with same initial ip_id_count, (cf secure_ip_id())
5) We garbage collect inet_peer aggressively.
IP ID generation do not have to be 'perfect'
Goal is trying to avoid duplicates in a short period of time,
so that reassembly units have a chance to complete reassembly of
fragments belonging to one message before receiving other fragments
with a recycled ID.
We simply use an array of generators, and a Jenkin hash using the dst IP
as a key.
ipv6_select_ident() is put back into net/ipv6/ip6_output.c where it
belongs (it is only used from this file)
secure_ip_id() and secure_ipv6_id() no longer are needed.
Rename ip_select_ident_more() to ip_select_ident_segs() to avoid
unnecessary decrement/increment of the number of segments.
[ Upstream commit a0e5ef53aac8e5049f9344857d8ec5237d31e58b ]
The SPI check introduced in ea9884b3acf3311c8a11db67bfab21773f6f82ba
was intended for IPComp SAs but actually prevented AH SAs from getting
installed (depending on the SPI).
Fixes: ea9884b3acf3 ("xfrm: check user specified spi for IPComp")
Cc: Fan Du <fan.du@windriver.com>
Signed-off-by: Tobias Brunner <tobias@strongswan.org>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
commit 3cf521f7dc87c031617fd47e4b7aa2593c2f3daf upstream.
The l2tp [get|set]sockopt() code has fallen back to the UDP functions
for socket option levels != SOL_PPPOL2TP since day one, but that has
never actually worked, since the l2tp socket isn't an inet socket.
As David Miller points out:
"If we wanted this to work, it'd have to look up the tunnel and then
use tunnel->sk, but I wonder how useful that would be"
Since this can never have worked so nobody could possibly have depended
on that functionality, just remove the broken code and return -EINVAL.
Acked-by: James Chapman <jchapman@katalix.com>
Acked-by: David Miller <davem@davemloft.net>
Cc: Phil Turnbull <phil.turnbull@oracle.com>
Cc: Vegard Nossum <vegard.nossum@oracle.com>
commit 08b9939997df30e42a228e1ecb97f99e9c8ea84e upstream.
This reverts commit 277d916fc2e959c3f106904116bb4f7b1148d47a as it was
at least breaking iwlwifi by setting the IEEE80211_TX_CTL_NO_PS_BUFFER
flag in all kinds of interface modes, not only for AP mode where it is
appropriate.
To avoid reintroducing the original problem, explicitly check for probe
request frames in the multicast buffering code.
Fixes: 277d916fc2e9 ("mac80211: move "bufferable MMPDU" check to fix AP mode scan")
commit 8c26d458394be44e135d1c6bd4557e1c4e1a0535 upstream.
tsc can be NULL (mac80211 currently always passes NULL),
resulting in NULL-dereference. check before copying it.
Signed-off-by: Eliad Peller <eliadx.peller@intel.com>
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
commit 02df00eb0019e7d15a1fcddebe4d020226c1ccda upstream.
The non-split wiphy state shouldn't be increased in size
so move the new set_qos_map command into the split if
statement.
Fixes: fa9ffc745610 ("cfg80211: Add support for QoS mapping")
Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
[ Upstream commit 10ec9472f05b45c94db3c854d22581a20b97db41 ]
There is a benign buffer overflow in ip_options_compile spotted by
AddressSanitizer[1] :
Its benign because we always can access one extra byte in skb->head
(because header is followed by struct skb_shared_info), and in this case
this byte is not even used.
[28504.910798] ==================================================================
[28504.912046] AddressSanitizer: heap-buffer-overflow in ip_options_compile
[28504.913170] Read of size 1 by thread T15843:
[28504.914026] [<ffffffff81802f91>] ip_options_compile+0x121/0x9c0
[28504.915394] [<ffffffff81804a0d>] ip_options_get_from_user+0xad/0x120
[28504.916843] [<ffffffff8180dedf>] do_ip_setsockopt.isra.15+0x8df/0x1630
[28504.918175] [<ffffffff8180ec60>] ip_setsockopt+0x30/0xa0
[28504.919490] [<ffffffff8181e59b>] tcp_setsockopt+0x5b/0x90
[28504.920835] [<ffffffff8177462f>] sock_common_setsockopt+0x5f/0x70
[28504.922208] [<ffffffff817729c2>] SyS_setsockopt+0xa2/0x140
[28504.923459] [<ffffffff818cfb69>] system_call_fastpath+0x16/0x1b
[28504.924722]
[28504.925106] Allocated by thread T15843:
[28504.925815] [<ffffffff81804995>] ip_options_get_from_user+0x35/0x120
[28504.926884] [<ffffffff8180dedf>] do_ip_setsockopt.isra.15+0x8df/0x1630
[28504.927975] [<ffffffff8180ec60>] ip_setsockopt+0x30/0xa0
[28504.929175] [<ffffffff8181e59b>] tcp_setsockopt+0x5b/0x90
[28504.930400] [<ffffffff8177462f>] sock_common_setsockopt+0x5f/0x70
[28504.931677] [<ffffffff817729c2>] SyS_setsockopt+0xa2/0x140
[28504.932851] [<ffffffff818cfb69>] system_call_fastpath+0x16/0x1b
[28504.934018]
[28504.934377] The buggy address ffff880026382828 is located 0 bytes to the right
[28504.934377] of 40-byte region [ffff880026382800, ffff880026382828)
[28504.937144]
[28504.937474] Memory state around the buggy address:
[28504.938430] ffff880026382300: ........ rrrrrrrr rrrrrrrr rrrrrrrr
[28504.939884] ffff880026382400: ffffffff rrrrrrrr rrrrrrrr rrrrrrrr
[28504.941294] ffff880026382500: .....rrr rrrrrrrr rrrrrrrr rrrrrrrr
[28504.942504] ffff880026382600: ffffffff rrrrrrrr rrrrrrrr rrrrrrrr
[28504.943483] ffff880026382700: ffffffff rrrrrrrr rrrrrrrr rrrrrrrr
[28504.944511] >ffff880026382800: .....rrr rrrrrrrr rrrrrrrr rrrrrrrr
[28504.945573] ^
[28504.946277] ffff880026382900: ffffffff rrrrrrrr rrrrrrrr rrrrrrrr
[28505.094949] ffff880026382a00: ffffffff rrrrrrrr rrrrrrrr rrrrrrrr
[28505.096114] ffff880026382b00: ffffffff rrrrrrrr rrrrrrrr rrrrrrrr
[28505.097116] ffff880026382c00: ffffffff rrrrrrrr rrrrrrrr rrrrrrrr
[28505.098472] ffff880026382d00: ffffffff rrrrrrrr rrrrrrrr rrrrrrrr
[28505.099804] Legend:
[28505.100269] f - 8 freed bytes
[28505.100884] r - 8 redzone bytes
[28505.101649] . - 8 allocated bytes
[28505.102406] x=1..7 - x allocated bytes + (8-x) redzone bytes
[28505.103637] ==================================================================
[1] https://code.google.com/p/address-sanitizer/wiki/AddressSanitizerForKernel
[ Upstream commit 640d7efe4c08f06c4ae5d31b79bd8740e7f6790a ]
*_result[len] is parsed as *(_result[len]) which is not at all what we
want to touch here.
Fixes: 84a7c0b1db1c ("dns_resolver: assure that dns_query() result is null-terminated")
[ Upstream commit 84a7c0b1db1c17d5ded8d3800228a608e1070b40 ]
dns_query() credulously assumes that keys are null-terminated and
returns a copy of a memory block that is off by one.
Signed-off-by: Manuel Schölling <manuel.schoelling@gmx.de>
[ Upstream commit c3caf1192f904de2f1381211f564537235d50de3 ]
Fixed a bug that was introduced by my GRE-GRO patch
(bf5a755f5e9186406bbf50f4087100af5bd68e40 net-gre-gro: Add GRE
support to the GRO stack) that breaks the forwarding path
because various GSO related fields were not set. The bug will
cause on the egress path either the GSO code to fail, or a
GRE-TSO capable (NETIF_F_GSO_GRE) NICs to choke. The following
fix has been tested for both cases.
Signed-off-by: H.K. Jerry Chu <hkchu@google.com>
[ Upstream commit 8f2e5ae40ec193bc0a0ed99e95315c3eebca84ea ]
While working on some other SCTP code, I noticed that some
structures shared with user space are leaking uninitialized
stack or heap buffer. In particular, struct sctp_sndrcvinfo
has a 2 bytes hole between .sinfo_flags and .sinfo_ppid that
remains unfilled by us in sctp_ulpevent_read_sndrcvinfo() when
putting this into cmsg. But also struct sctp_remote_error
contains a 2 bytes hole that we don't fill but place into a skb
through skb_copy_expand() via sctp_ulpevent_make_remote_error().
Both structures are defined by the IETF in RFC6458:
* Section 5.3.2. SCTP Header Information Structure:
The sctp_sndrcvinfo structure is defined below:
struct sctp_sndrcvinfo {
uint16_t sinfo_stream;
uint16_t sinfo_ssn;
uint16_t sinfo_flags;
<-- 2 bytes hole -->
uint32_t sinfo_ppid;
uint32_t sinfo_context;
uint32_t sinfo_timetolive;
uint32_t sinfo_tsn;
uint32_t sinfo_cumtsn;
sctp_assoc_t sinfo_assoc_id;
* 6.1.3. SCTP_REMOTE_ERROR:
A remote peer may send an Operation Error message to its peer.
This message indicates a variety of error conditions on an
association. The entire ERROR chunk as it appears on the wire
is included in an SCTP_REMOTE_ERROR event. Please refer to the
SCTP specification [RFC4960] and any extensions for a list of
possible error formats. An SCTP error notification has the
following format:
struct sctp_remote_error {
uint16_t sre_type;
uint16_t sre_flags;
uint32_t sre_length;
uint16_t sre_error;
sctp_assoc_t sre_assoc_id;
uint8_t sre_data[];
Fix this by setting both to 0 before filling them out. We also
have other structures shared between user and kernel space in
SCTP that contains holes (e.g. struct sctp_paddrthlds), but we
copy that buffer over from user space first and thus don't need
to care about it in that cases.
While at it, we can also remove lengthy comments copied from
the draft, instead, we update the comment with the correct RFC
number where one can look it up.
[ Upstream commit 999417549c16dd0e3a382aa9f6ae61688db03181 ]
If the 'next' pointer of the last fragment buffer in a message is not
zeroed before reassembly, we risk ending up with a corrupt message,
since the reassembly function itself isn't doing this.
Currently, when a buffer is retrieved from the deferred queue of the
broadcast link, the next pointer is not cleared, with the result as
described above.
This commit corrects this, and thereby fixes a bug that may occur when
long broadcast messages are transmitted across dual interfaces. The bug
has been present since 40ba3cdf542a469aaa9083fa041656e59b109b90 ("tipc:
message reassembly using fragment chain")
This commit should be applied to both net and net-next.
Signed-off-by: Jon Maloy <jon.maloy@ericsson.com>
[ Upstream commit ac30ef832e6af0505b6f0251a6659adcfa74975e ]
netlink_dump() returns a negative errno value on error. Until now,
netlink_recvmsg() directly recorded that negative value in sk->sk_err, but
that's wrong since sk_err takes positive errno values. (This manifests as
userspace receiving a positive return value from the recv() system call,
falsely indicating success.) This bug was introduced in the commit that
started checking the netlink_dump() return value, commit b44d211 (netlink:
handle errors from netlink_dump()).
Multithreaded Netlink dumps are one way to trigger this behavior in
practice, as described in the commit message for the userspace workaround
posted here:
http://openvswitch.org/pipermail/dev/2014-June/042339.html
This commit also fixes the same bug in netlink_poll(), introduced in commit
cd1df525d (netlink: add flow control for memory mapped I/O).
Signed-off-by: Ben Pfaff <blp@nicira.com>
[ Upstream commit 36beddc272c111689f3042bf3d10a64d8a805f93 ]
Setting just skb->sk without taking its reference and setting a
destructor is invalid. However, in the places where this was done, skb
is used in a way not requiring skb->sk setting. So dropping the setting
of skb->sk.
Thanks to Eric Dumazet <eric.dumazet@gmail.com> for correct solution.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=79441
Reported-by: Ed Martin <edman007@edman007.com>
Signed-off-by: Andrey Utkin <andrey.krieger.utkin@gmail.com>
[ Upstream commit 6e08d5e3c8236e7484229e46fdf92006e1dd4c49 ]
The undo code assumes that, upon entering loss recovery, TCP
1) always retransmit something
2) the retransmission never fails locally (e.g., qdisc drop)
so undo_marker is set in tcp_enter_recovery() and undo_retrans is
incremented only when tcp_retransmit_skb() is successful.
When the assumption is broken because TCP's cwnd is too small to
retransmit or the retransmit fails locally. The next (DUP)ACK
would incorrectly revert the cwnd and the congestion state in
tcp_try_undo_dsack() or tcp_may_undo(). Subsequent (DUP)ACKs
may enter the recovery state. The sender repeatedly enter and
(incorrectly) exit recovery states if the retransmits continue to
fail locally while receiving (DUP)ACKs.
The fix is to initialize undo_retrans to -1 and start counting on
the first retransmission. Always increment undo_retrans even if the
retransmissions fail locally because they couldn't cause DSACKs to
undo the cwnd reduction.
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Signed-off-by: Neal Cardwell <ncardwell@google.com>
[ Upstream commit 52ad353a5344f1f700c5b777175bdfa41d3cd65a ]
The problem was triggered by these steps:
1) create socket, bind and then setsockopt for add mc group.
mreq.imr_multiaddr.s_addr = inet_addr("255.0.0.37");
mreq.imr_interface.s_addr = inet_addr("192.168.1.2");
setsockopt(sockfd, IPPROTO_IP, IP_ADD_MEMBERSHIP, &mreq, sizeof(mreq));
2) drop the mc group for this socket.
mreq.imr_interface.s_addr = inet_addr("0.0.0.0");
setsockopt(sockfd, IPPROTO_IP, IP_DROP_MEMBERSHIP, &mreq, sizeof(mreq));
3) and then drop the socket, I found the mc group was still used by the dev:
netstat -g
Interface RefCnt Group
eth2 1 255.0.0.37
Normally even though the IP_DROP_MEMBERSHIP return error, the mc group still need
to be released for the netdev when drop the socket, but this process was broken when
route default is NULL, the reason is that:
The ip_mc_leave_group() will choose the in_dev by the imr_interface.s_addr, if input addr
is NULL, the default route dev will be chosen, then the ifindex is got from the dev,
then polling the inet->mc_list and return -ENODEV, but if the default route dev is NULL,
the in_dev and ifIndex is both NULL, when polling the inet->mc_list, the mc group will be
released from the mc_list, but the dev didn't dec the refcnt for this mc group, so
when dropping the socket, the mc_list is NULL and the dev still keep this group.
v1->v2: According Hideaki's suggestion, we should align with IPv6 (RFC3493) and BSDs,
so I add the checking for the in_dev before polling the mc_list, make sure when
we remove the mc group, dec the refcnt to the real dev which was using the mc address.
The problem would never happened again.
Signed-off-by: Ding Tianhong <dingtianhong@huawei.com>
[ Upstream commit 54951194656e4853e441266fd095f880bc0398f3 ]
A bug was introduced in NETDEV_CHANGE notifier sequence causing the
arp table to be sometimes spuriously cleared (including manual arp
entries marked permanent), upon network link carrier changes.
The changed argument for the notifier was applied only to a single
caller of NETDEV_CHANGE, missing among others netdev_state_change().
So upon net_carrier events induced by the network, which are
triggering a call to netdev_state_change(), arp_netdev_event() would
decide whether to clear or not arp cache based on random/junk stack
values (a kind of read buffer overflow).
Fixes: be9efd365328 ("net: pass changed flags along with NETDEV_CHANGE event")
Fixes: 6c8b4e3ff81b ("arp: flush arp cache on IFF_NOARP change")
Signed-off-by: Loic Prylli <loicp@google.com>
[ Upstream commit 68b7107b62983f2cff0948292429d5f5999df096 ]
Some older router implementations still send Fragmentation Needed
errors with the Next-Hop MTU field set to zero. This is explicitly
described as an eventuality that hosts must deal with by the
standard (RFC 1191) since older standards specified that those
bits must be zero.
Linux had a generic (for all of IPv4) implementation of the algorithm
described in the RFC for searching a list of MTU plateaus for a good
value. Commit 46517008e116 ("ipv4: Kill ip_rt_frag_needed().")
removed this as part of the changes to remove the routing cache.
Subsequently any Fragmentation Needed packet with a zero Next-Hop
MTU has been discarded without being passed to the per-protocol
handlers or notifying userspace for raw sockets.
When there is a router which does not implement RFC 1191 on an
MTU limited path then this results in stalled connections since
large packets are discarded and the local protocols are not
notified so they never attempt to lower the pMTU.
One example I have seen is an OpenBSD router terminating IPSec
tunnels. It's worth pointing out that this case is distinct from
the BSD 4.2 bug which incorrectly calculated the Next-Hop MTU
since the commit in question dismissed that as a valid concern.
All of the per-protocols handlers implement the simple approach from
RFC 1191 of immediately falling back to the minimum value. Although
this is sub-optimal it is vastly preferable to connections hanging
indefinitely.
Remove the Next-Hop MTU != 0 check and allow such packets
to follow the normal path.
Fixes: 46517008e116 ("ipv4: Kill ip_rt_frag_needed().")
Signed-off-by: Edward Allcutt <edward.allcutt@openmarket.com>
[ Upstream commit 5924f17a8a30c2ae18d034a86ee7581b34accef6 ]
When in repair-mode and TCP_RECV_QUEUE is set, we end up calling
tcp_push with mss_now being 0. If data is in the send-queue and
tcp_set_skb_tso_segs gets called, we crash because it will divide by
mss_now:
[ 347.151939] divide error: 0000 [#1] SMP
[ 347.152907] Modules linked in:
[ 347.152907] CPU: 1 PID: 1123 Comm: packetdrill Not tainted 3.16.0-rc2 #4
[ 347.152907] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2007
[ 347.152907] task: f5b88540 ti: f3c82000 task.ti: f3c82000
[ 347.152907] EIP: 0060:[<c1601359>] EFLAGS: 00210246 CPU: 1
[ 347.152907] EIP is at tcp_set_skb_tso_segs+0x49/0xa0
[ 347.152907] EAX: 00000b67 EBX: f5acd080 ECX: 00000000 EDX: 00000000
[ 347.152907] ESI: f5a28f40 EDI: f3c88f00 EBP: f3c83d10 ESP: f3c83d00
[ 347.152907] DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
[ 347.152907] CR0: 80050033 CR2: 083158b0 CR3: 35146000 CR4: 000006b0
[ 347.152907] Stack:
[ 347.152907] c167f9d9 f5acd080 000005b4 00000002 f3c83d20 c16013e6 f3c88f00 f5acd080
[ 347.152907] f3c83da0 c1603b5a f3c83d38 c10a0188 00000000 00000000 f3c83d84 c10acc85
[ 347.152907] c1ad5ec0 00000000 00000000 c1ad679c 010003e0 00000000 00000000 f3c88fc8
[ 347.152907] Call Trace:
[ 347.152907] [<c167f9d9>] ? apic_timer_interrupt+0x2d/0x34
[ 347.152907] [<c16013e6>] tcp_init_tso_segs+0x36/0x50
[ 347.152907] [<c1603b5a>] tcp_write_xmit+0x7a/0xbf0
[ 347.152907] [<c10a0188>] ? up+0x28/0x40
[ 347.152907] [<c10acc85>] ? console_unlock+0x295/0x480
[ 347.152907] [<c10ad24f>] ? vprintk_emit+0x1ef/0x4b0
[ 347.152907] [<c1605716>] __tcp_push_pending_frames+0x36/0xd0
[ 347.152907] [<c15f4860>] tcp_push+0xf0/0x120
[ 347.152907] [<c15f7641>] tcp_sendmsg+0xf1/0xbf0
[ 347.152907] [<c116d920>] ? kmem_cache_free+0xf0/0x120
[ 347.152907] [<c106a682>] ? __sigqueue_free+0x32/0x40
[ 347.152907] [<c114f0f0>] ? do_wp_page+0x3e0/0x850
[ 347.152907] [<c161c36a>] inet_sendmsg+0x4a/0xb0
[ 347.152907] [<c1150269>] ? handle_mm_fault+0x709/0xfb0
[ 347.152907] [<c15a006b>] sock_aio_write+0xbb/0xd0
[ 347.152907] [<c1180b79>] do_sync_write+0x69/0xa0
[ 347.152907] [<c1181023>] vfs_write+0x123/0x160
[ 347.152907] [<c1181d55>] SyS_write+0x55/0xb0
[ 347.152907] [<c167f0d8>] sysenter_do_call+0x12/0x28
This can easily be reproduced with the following packetdrill-script (the
"magic" with netem, sk_pacing and limit_output_bytes is done to prevent
the kernel from pushing all segments, because hitting the limit without
doing this is not so easy with packetdrill):
0 socket(..., SOCK_STREAM, IPPROTO_TCP) = 3
+0 setsockopt(3, SOL_SOCKET, SO_REUSEADDR, [1], 4) = 0
+0 bind(3, ..., ...) = 0
+0 listen(3, 1) = 0
+0 < S 0:0(0) win 32792 <mss 1460>
+0 > S. 0:0(0) ack 1 <mss 1460>
+0.1 < . 1:1(0) ack 1 win 65000
+0 accept(3, ..., ...) = 4
// This forces that not all segments of the snd-queue will be pushed
+0 `tc qdisc add dev tun0 root netem delay 10ms`
+0 `sysctl -w net.ipv4.tcp_limit_output_bytes=2`
+0 setsockopt(4, SOL_SOCKET, 47, [2], 4) = 0
+0 write(4,...,10000) = 10000
// Set tcp-repair stuff, particularly TCP_RECV_QUEUE
+0 setsockopt(4, SOL_TCP, 19, [1], 4) = 0
+0 setsockopt(4, SOL_TCP, 20, [1], 4) = 0
// This now will make the write push the remaining segments
+0 setsockopt(4, SOL_SOCKET, 47, [20000], 4) = 0
+0 `sysctl -w net.ipv4.tcp_limit_output_bytes=130000`
// Now we will crash
+0 write(4,...,1000) = 1000
This happens since ec3423257508 (tcp: fix retransmission in repair
mode). Prior to that, the call to tcp_push was prevented by a check for
tp->repair.
The patch fixes it, by adding the new goto-label out_nopush. When exiting
tcp_sendmsg and a push is not required, which is the case for tp->repair,
we go to this label.
When repairing and calling send() with TCP_RECV_QUEUE, the data is
actually put in the receive-queue. So, no push is required because no
data has been added to the send-queue.
Cc: Andrew Vagin <avagin@openvz.org>
Cc: Pavel Emelyanov <xemul@parallels.com>
Fixes: ec3423257508 (tcp: fix retransmission in repair mode)
Acked-by: Andrew Vagin <avagin@openvz.org>
Acked-by: Pavel Emelyanov <xemul@parallels.com>
[ Upstream commit a48e5fafecfb9c0c807d7e7284b5ff884dfb7a3a ]
Madalin-Cristian reported crashs happening after a recent commit
(5a4ae5f6e7d4 "vlan: unnecessary to check if vlan_pcpu_stats is NULL")
root@p5040ds:~# vconfig add eth8 1
root@p5040ds:~# vconfig rem eth8.1
Unable to handle kernel paging request for data at address 0x2bc88028
Faulting instruction address: 0xc058e950
Oops: Kernel access of bad area, sig: 11 [#1]
SMP NR_CPUS=8 CoreNet Generic
Modules linked in:
CPU: 3 PID: 2167 Comm: vconfig Tainted: G W 3.16.0-rc3-00346-g65e85bf #2
task: e7264d90 ti: e2c2c000 task.ti: e2c2c000
NIP: c058e950 LR: c058ea30 CTR: c058e900
REGS: e2c2db20 TRAP: 0300 Tainted: G W (3.16.0-rc3-00346-g65e85bf)
MSR: 00029002 <CE,EE,ME> CR: 48000428 XER: 20000000
DEAR: 2bc88028 ESR: 00000000
GPR00: c047299c e2c2dbd0 e7264d90 00000000 2bc88000 00000000 ffffffff 00000000
GPR08: 0000000f 00000000 000000ff 00000000 28000422 10121928 10100000 10100000
GPR16: 10100000 00000000 c07c5968 00000000 00000000 00000000 e2c2dc48 e7838000
GPR24: c07c5bac c07c58a8 e77290cc c07b0000 00000000 c05de6c0 e7838000 e2c2dc48
NIP [c058e950] vlan_dev_get_stats64+0x50/0x170
LR [c058ea30] vlan_dev_get_stats64+0x130/0x170
Call Trace:
[e2c2dbd0] [ffffffea] 0xffffffea (unreliable)
[e2c2dc20] [c047299c] dev_get_stats+0x4c/0x140
[e2c2dc40] [c0488ca8] rtnl_fill_ifinfo+0x3d8/0x960
[e2c2dd70] [c0489f4c] rtmsg_ifinfo+0x6c/0x110
[e2c2dd90] [c04731d4] rollback_registered_many+0x344/0x3b0
[e2c2ddd0] [c047332c] rollback_registered+0x2c/0x50
[e2c2ddf0] [c0476058] unregister_netdevice_queue+0x78/0xf0
[e2c2de00] [c058d800] unregister_vlan_dev+0xc0/0x160
[e2c2de20] [c058e360] vlan_ioctl_handler+0x1c0/0x550
[e2c2de90] [c045d11c] sock_ioctl+0x28c/0x2f0
[e2c2deb0] [c010d070] do_vfs_ioctl+0x90/0x7b0
[e2c2df20] [c010d7d0] SyS_ioctl+0x40/0x80
[e2c2df40] [c000f924] ret_from_syscall+0x0/0x3c
Fix this problem by freeing percpu stats from dev->destructor() instead
of ndo_uninit()
Reported-by: Madalin-Cristian Bucur <madalin.bucur@freescale.com>
Tested-by: Madalin-Cristian Bucur <madalin.bucur@freescale.com>
Fixes: 5a4ae5f6e7d4 ("vlan: unnecessary to check if vlan_pcpu_stats is NULL")
Cc: Li RongQing <roy.qing.li@gmail.com>
[ Upstream commit 7f502361531e9eecb396cf99bdc9e9a59f7ebd7f ]
We have two different ways to handle changes to sk->sk_dst
First way (used by TCP) assumes socket lock is owned by caller, and use
no extra lock : __sk_dst_set() & __sk_dst_reset()
Another way (used by UDP) uses sk_dst_lock because socket lock is not
always taken. Note that sk_dst_lock is not softirq safe.
These ways are not inter changeable for a given socket type.
ipv4_sk_update_pmtu(), added in linux-3.8, added a race, as it used
the socket lock as synchronization, but users might be UDP sockets.
Instead of converting sk_dst_lock to a softirq safe version, use xchg()
as we did for sk_rx_dst in commit e47eb5dfb296b ("udp: ipv4: do not use
sk_dst_lock from softirq context")
In a follow up patch, we probably can remove sk_dst_lock, as it is
only used in IPv6.
Cc: Steffen Klassert <steffen.klassert@secunet.com>
Fixes: 9cb3a50c5f63e ("ipv4: Invalidate the socket cached route on pmtu events if possible")
[ Upstream commit f88649721268999bdff09777847080a52004f691 ]
When IP route cache had been removed in linux-3.6, we broke assumption
that dst entries were all freed after rcu grace period. DST_NOCACHE
dst were supposed to be freed from dst_release(). But it appears
we want to keep such dst around, either in UDP sockets or tunnels.
In sk_dst_get() we need to make sure dst refcount is not 0
before incrementing it, or else we might end up freeing a dst
twice.
DST_NOCACHE set on a dst does not mean this dst can not be attached
to a socket or a tunnel.
Then, before actual freeing, we need to observe a rcu grace period
to make sure all other cpus can catch the fact the dst is no longer
usable.
Reported-by: Dormando <dormando@rydia.net>
[ Upstream commit 5882a07c72093dc3a18e2d2b129fb200686bb6ee ]
This patch fixes a kernel BUG_ON in skb_segment. It is hit when
testing two VMs on openvswitch with one VM acting as VXLAN gateway.
During VXLAN packet GSO, skb_segment is called with skb->data
pointing to inner TCP payload. skb_segment calls skb_network_protocol
to retrieve the inner protocol. skb_network_protocol actually expects
skb->data to point to MAC and it calls pskb_may_pull with ETH_HLEN.
This ends up pulling in ETH_HLEN data from header tail. As a result,
pskb_trim logic is skipped and BUG_ON is hit later.
Move skb_push in front of skb_network_protocol so that skb->data
lines up properly.
kernel BUG at net/core/skbuff.c:2999!
Call Trace:
[<ffffffff816ac412>] tcp_gso_segment+0x122/0x410
[<ffffffff816bc74c>] inet_gso_segment+0x13c/0x390
[<ffffffff8164b39b>] skb_mac_gso_segment+0x9b/0x170
[<ffffffff816b3658>] skb_udp_tunnel_segment+0xd8/0x390
[<ffffffff816b3c00>] udp4_ufo_fragment+0x120/0x140
[<ffffffff8109d742>] ? default_wake_function+0x12/0x20
[<ffffffff8164b4d0>] __skb_gso_segment+0x60/0xc0
[<ffffffff8164b6b3>] dev_hard_start_xmit+0x183/0x550
[<ffffffff8166c91e>] sch_direct_xmit+0xfe/0x1d0
[<ffffffff8164bc94>] __dev_queue_xmit+0x214/0x4f0
[<ffffffff8164bf90>] dev_queue_xmit+0x10/0x20
[<ffffffff81687edb>] ip_finish_output+0x66b/0x890
[<ffffffff81688a58>] ip_output+0x58/0x90
[<ffffffff816c628f>] ? fib_table_lookup+0x29f/0x350
[<ffffffff816881c9>] ip_local_out_sk+0x39/0x50
[<ffffffff816cbfad>] iptunnel_xmit+0x10d/0x130
[<ffffffffa0212200>] vxlan_xmit_skb+0x1d0/0x330 [vxlan]
[<ffffffffa02a3919>] vxlan_tnl_send+0x129/0x1a0 [openvswitch]
[<ffffffffa02a2cd6>] ovs_vport_send+0x26/0xa0 [openvswitch]
[<ffffffffa029931e>] do_output+0x2e/0x50 [openvswitch]
Signed-off-by: Wei-Chun Chao <weichunc@plumgrid.com>
[ Upstream commit 916c1689a09bc1ca81f2d7a34876f8d35aadd11b ]
skb_cow called in vlan_reorder_header does not free the skb when it failed,
and vlan_reorder_header returns NULL to reset original skb when it is called
in vlan_untag, lead to a memory leak.
Signed-off-by: Li RongQing <roy.qing.li@gmail.com>
[ Upstream commit 24599e61b7552673dd85971cf5a35369cd8c119e ]
When writing to the sysctl field net.sctp.auth_enable, it can well
be that the user buffer we handed over to proc_dointvec() via
proc_sctp_do_auth() handler contains something other than integers.
In that case, we would set an uninitialized 4-byte value from the
stack to net->sctp.auth_enable that can be leaked back when reading
the sysctl variable, and it can unintentionally turn auth_enable
on/off based on the stack content since auth_enable is interpreted
as a boolean.
Fix it up by making sure proc_dointvec() returned sucessfully.
Fixes: b14878ccb7fa ("net: sctp: cache auth_enable per endpoint")
Reported-by: Florian Westphal <fwestpha@redhat.com>
[ Upstream commit 2cd0d743b05e87445c54ca124a9916f22f16742e ]
If there is an MSS change (or misbehaving receiver) that causes a SACK
to arrive that covers the end of an skb but is less than one MSS, then
tcp_match_skb_to_sack() was rounding up pkt_len to the full length of
the skb ("Round if necessary..."), then chopping all bytes off the skb
and creating a zero-byte skb in the write queue.
This was visible now because the recently simplified TLP logic in
bef1909ee3ed1c ("tcp: fixing TLP's FIN recovery") could find that 0-byte
skb at the end of the write queue, and now that we do not check that
skb's length we could send it as a TLP probe.
Consider the following example scenario:
mss: 1000
skb: seq: 0 end_seq: 4000 len: 4000
SACK: start_seq: 3999 end_seq: 4000
The tcp_match_skb_to_sack() code will compute:
in_sack = false
pkt_len = start_seq - TCP_SKB_CB(skb)->seq = 3999 - 0 = 3999
new_len = (pkt_len / mss) * mss = (3999/1000)*1000 = 3000
new_len += mss = 4000
Previously we would find the new_len > skb->len check failing, so we
would fall through and set pkt_len = new_len = 4000 and chop off
pkt_len of 4000 from the 4000-byte skb, leaving a 0-byte segment
afterward in the write queue.
With this new commit, we notice that the new new_len >= skb->len check
succeeds, so that we return without trying to fragment.
Fixes: adb92db857ee ("tcp: Make SACK code to split only at mss boundaries")
Reported-by: Eric Dumazet <edumazet@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Cc: Ilpo Jarvinen <ilpo.jarvinen@helsinki.fi>
[ Upstream commit ff5e92c1affe7166b3f6e7073e648ed65a6e2e59 ]
sysctl handler proc_sctp_do_hmac_alg(), proc_sctp_do_rto_min() and
proc_sctp_do_rto_max() do not properly reflect some error cases
when writing values via sysctl from internal proc functions such
as proc_dointvec() and proc_dostring().
In all these cases we pass the test for write != 0 and partially
do additional work just to notice that additional sanity checks
fail and we return with hard-coded -EINVAL while proc_do*
functions might also return different errors. So fix this up by
simply testing a successful return of proc_do* right after
calling it.
This also allows to propagate its return value onwards to the user.
While touching this, also fix up some minor style issues.
Fixes: 4f3fdf3bc59c ("sctp: add check rto_min and rto_max in sysctl")
Fixes: 3c68198e7511 ("sctp: Make hmac algorithm selection for cookie generation dynamic")
[ Upstream commit e0056593b61253f1a8a9941dacda22e73b963cdc ]
This patch fixes 3 similar bugs where incoming packets might be routed into
wrong non-wildcard tunnels:
1) Consider the following setup:
ip address add 1.1.1.1/24 dev eth0
ip address add 1.1.1.2/24 dev eth0
ip tunnel add ipip1 remote 2.2.2.2 local 1.1.1.1 mode ipip dev eth0
ip link set ipip1 up
Incoming ipip packets from 2.2.2.2 were routed into ipip1 even if it has dst =
1.1.1.2. Moreover even if there was wildcard tunnel like
ip tunnel add ipip0 remote 2.2.2.2 local any mode ipip dev eth0
but it was created before explicit one (with local 1.1.1.1), incoming ipip
packets with src = 2.2.2.2 and dst = 1.1.1.2 were still routed into ipip1.
Same issue existed with all tunnels that use ip_tunnel_lookup (gre, vti)
2) ip address add 1.1.1.1/24 dev eth0
ip tunnel add ipip1 remote 2.2.146.85 local 1.1.1.1 mode ipip dev eth0
Incoming ipip packets with dst = 1.1.1.1 were routed into ipip1, no matter what
src address is. Any remote ip address which has ip_tunnel_hash = 0 raised this
issue, 2.2.146.85 is just an example, there are more than 4 million of them.
And again, wildcard tunnel like
ip tunnel add ipip0 remote any local 1.1.1.1 mode ipip dev eth0
wouldn't be ever matched if it was created before explicit tunnel like above.
Gre & vti tunnels had the same issue.
3) ip address add 1.1.1.1/24 dev eth0
ip tunnel add gre1 remote 2.2.146.84 local 1.1.1.1 key 1 mode gre dev eth0
ip link set gre1 up
Any incoming gre packet with key = 1 were routed into gre1, no matter what
src/dst addresses are. Any remote ip address which has ip_tunnel_hash = 0 raised
the issue, 2.2.146.84 is just an example, there are more than 4 million of them.
Wildcard tunnel like
ip tunnel add gre2 remote any local any key 1 mode gre dev eth0
All this stuff happened because while looking for a wildcard tunnel we didn't
check that matched tunnel is a wildcard one. Fixed.
commit 945b2b2d259d1a4364a2799e80e8ff32f8c6ee6f upstream.
Quoting Samu Kallio:
Basically what's happening is, during netns cleanup,
nf_nat_net_exit gets called before ipv4_net_exit. As I understand
it, nf_nat_net_exit is supposed to kill any conntrack entries which
have NAT context (through nf_ct_iterate_cleanup), but for some
reason this doesn't happen (perhaps something else is still holding
refs to those entries?).
When ipv4_net_exit is called, conntrack entries (including those
with NAT context) are cleaned up, but the
nat_bysource hashtable is long gone - freed in nf_nat_net_exit. The
bug happens when attempting to free a conntrack entry whose NAT hash
'prev' field points to a slot in the freed hash table (head for that
bin).
We ignore conntracks with null nat bindings. But this is wrong,
as these are in bysource hash table as well.
Restore nat-cleaning for the netns-is-being-removed case.
bug:
https://bugzilla.kernel.org/show_bug.cgi?id=65191
Fixes: c2d421e1718 ('netfilter: nf_nat: fix race when unloading protocol modules')
Reported-by: Samu Kallio <samu.kallio@aberdeencloud.com>
Debugged-by: Samu Kallio <samu.kallio@aberdeencloud.com>
Tested-by: Samu Kallio <samu.kallio@aberdeencloud.com>
commit 53d045258ee2e38b1e882617cb0799a04d05f5fa upstream.
If the rate control algorithm uses a selection table, it
is leaked when the station is destroyed - fix that.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Reported-by: Christophe Prévotaux <cprevotaux@nltinc.com>
Fixes: 0d528d85c519 ("mac80211: improve the rate control API")
[add commit log entry, remove pointless NULL check]
commit 923eaf367206e01f22c97aee22300e332d071916 upstream.
Doing so will lead to an oops for a p2p-dev interface, since it has
no netdev.
Signed-off-by: Arik Nemtsov <arikx.nemtsov@intel.com>
commit c7d37a66e345df2fdf1aa7b2c9a6d3d53846ca5b upstream.
Without this fix, freshly rebooted Linux creates a new IBSS
instead of joining an existing one. Only when jiffies counter
overflows after 5 minutes the IBSS can be successfully joined.
Signed-off-by: Krzysztof Hałasa <khalasa@piap.pl>
[edit commit message slightly]
commit 92d1372e1a9fec00e146b74e8b9ad7a385b9b37f upstream.
Kernel supports SMP Security Request so don't block increasing security
when we are slave.
Signed-off-by: Marcin Kraglak <marcin.kraglak@tieto.com>
Acked-by: Johan Hedberg <johan.hedberg@intel.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit c73f94b8c093a615ce80eabbde0ac6eb9abfe31a upstream.
The SMP code expects hdev to be unlocked since e.g. crypto functions
will try to (re)lock it. Therefore, we need to release the lock before
calling into smp.c from mgmt.c. Without this we risk a deadlock whenever
the smp_user_confirm_reply() function is called.
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
Tested-by: Lukasz Rymanowski <lukasz.rymanowski@tieto.com>
commit 50143a433b70e3145bcf8a4a4e54f0c11bdee32b upstream.
When inquiry is canceled through the HCI_Cancel_Inquiry command there is
no Inquiry Complete event generated. Instead, all we get is the command
complete for the HCI_Inquiry_Cancel command. This means that we must
call the hci_discovery_set_state() function from the respective command
complete handler in order to ensure that user space knows the correct
discovery state.
commit e694788d73efe139b24f78b036deb97fe57fa8cb upstream.
The conn->link_key variable tracks the type of link key in use. It is
set whenever we respond to a link key request as well as when we get a
link key notification event.
These two events do not however always guarantee that encryption is
enabled: getting a link key request and responding to it may only mean
that the remote side has requested authentication but not encryption. On
the other hand, the encrypt change event is a certain guarantee that
encryption is enabled. The real encryption state is already tracked in
the conn->link_mode variable through the HCI_LM_ENCRYPT bit.
This patch fixes a check for encryption in the hci_conn_auth function to
use the proper conn->link_mode value and thereby eliminates the chance
of a false positive result.
commit ba15a58b179ed76a7e887177f2b06de12c58ec8f upstream.
From the Bluetooth Core Specification 4.1 page 1958:
"if both devices have set the Authentication_Requirements parameter to
one of the MITM Protection Not Required options, authentication stage 1
shall function as if both devices set their IO capabilities to
DisplayOnly (e.g., Numeric comparison with automatic confirmation on
both devices)"
So far our implementation has done user confirmation for all just-works
cases regardless of the MITM requirements, however following the
specification to the word means that we should not be doing confirmation
when neither side has the MITM flag set.
Tested-by: Szymon Janc <szymon.janc@tieto.com>
commit f44a5f45f544561302e855e7bd104e5f506ec01b upstream.
Receiving a ICMP response to an IPIP packet in a non-linear skb could
cause a kernel panic in __skb_pull.
The problem was introduced in
commit f2edb9f7706dcb2c0d9a362b2ba849efe3a97f5e ("ipvs: implement
passive PMTUD for IPIP packets").
Signed-off-by: Peter Christensen <pch@ordbogen.com>
Acked-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Simon Horman <horms@verge.net.au>
commit c789102c20bbbdda6831a273e046715be9d6af79 upstream.
If the accept() call fails, we need to put the module reference.
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 8a96f3cd22878fc0bb564a8478a6e17c0b8dca73 upstream.
-[0x01 Introduction
We have found a programming error causing a deadlock in Bluetooth subsystem
of Linux kernel. The problem is caused by missing release_sock() call when
L2CAP connection creation fails due full accept queue.
The issue can be reproduced with 3.15-rc5 kernel and is also present in
earlier kernels.
-[0x02 Details
The problem occurs when multiple L2CAP connections are created to a PSM which
contains listening socket (like SDP) and left pending, for example,
configuration (the underlying ACL link is not disconnected between
connections).
When L2CAP connection request is received and listening socket is found the
l2cap_sock_new_connection_cb() function (net/bluetooth/l2cap_sock.c) is called.
This function locks the 'parent' socket and then checks if the accept queue
is full.
1178 lock_sock(parent);
1179
1180 /* Check for backlog size */
1181 if (sk_acceptq_is_full(parent)) {
1182 BT_DBG("backlog full %d", parent->sk_ack_backlog);
1183 return NULL;
1184 }
If case the accept queue is full NULL is returned, but the 'parent' socket
is not released. Thus when next L2CAP connection request is received the code
blocks on lock_sock() since the parent is still locked.
Also note that for connections already established and waiting for
configuration to complete a timeout will occur and l2cap_chan_timeout()
(net/bluetooth/l2cap_core.c) will be called. All threads calling this
function will also be blocked waiting for the channel mutex since the thread
which is waiting on lock_sock() alread holds the channel mutex.
We were able to reproduce this by sending continuously L2CAP connection
request followed by disconnection request containing invalid CID. This left
the created connections pending configuration.
After the deadlock occurs it is impossible to kill bluetoothd, btmon will not
get any more data etc. requiring reboot to recover.
-[0x03 Fix
Releasing the 'parent' socket when l2cap_sock_new_connection_cb() returns NULL
seems to fix the issue.
Signed-off-by: Jukka Taimisto <jtt@codenomicon.com>
Reported-by: Tommi Mäkilä <tmakila@codenomicon.com>
