path: root/net
2014-10-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "A quick batch of bug fixes: 1) Fix build with IPV6 disabled, from Eric Dumazet. 2) Several more cases of caching SKB data pointers across calls to pskb_may_pull(), thus referencing potentially free'd memory. From Li RongQing. 3) DSA phy code tests operation presence improperly, instead of going: if (x->ops->foo) r = x->ops->foo(args); it was going: if (x->ops->foo(args)) r = x->ops->foo(args); Fix from Andew Lunn" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: Net: DSA: Fix checking for get_phy_flags function ipv6: fix a potential use after free in sit.c ipv6: fix a potential use after free in ip6_offload.c ipv4: fix a potential use after free in gre_offload.c tcp: fix build error if IPv6 is not enabled
2014-10-19Net: DSA: Fix checking for get_phy_flags functionAndrew Lunn
The check for the presence or not of the optional switch function get_phy_flags() called the function, rather than checked to see if it is a NULL pointer. This causes a derefernce of a NULL pointer on all switch chips except the sf2, the only switch to implement this call. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Fixes: 6819563e646a ("net: dsa: allow switch drivers to specify phy_device::dev_flags") Cc: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-18Merge tag 'virtio-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull virtio updates from Rusty Russell: "One cc: stable commit, the rest are a series of minor cleanups which have been sitting in MST's tree during my vacation. I changed a function name and made one trivial change, then they spent two days in linux-next" * tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (25 commits) virtio-rng: refactor probe error handling virtio_scsi: drop scan callback virtio_balloon: enable VQs early on restore virtio_scsi: fix race on device removal virito_scsi: use freezable WQ for events virtio_net: enable VQs early on restore virtio_console: enable VQs early on restore virtio_scsi: enable VQs early on restore virtio_blk: enable VQs early on restore virtio_scsi: move kick event out from virtscsi_init virtio_net: fix use after free on allocation failure 9p/trans_virtio: enable VQs early virtio_console: enable VQs early virtio_blk: enable VQs early virtio_net: enable VQs early virtio: add API to enable VQs early virtio_net: minor cleanup virtio-net: drop config_mutex virtio_net: drop config_enable virtio-blk: drop config_mutex ...
2014-10-18ipv6: fix a potential use after free in sit.cLi RongQing
pskb_may_pull() maybe change skb->data and make iph pointer oboslete, fix it by geting ip header length directly. Fixes: ca15a078 (sit: generate icmpv6 error when receiving icmpv4 error) Cc: Oussama Ghorbel <ghorbel@pivasoftware.com> Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-18ipv6: fix a potential use after free in ip6_offload.cLi RongQing
pskb_may_pull() maybe change skb->data and make opth pointer oboslete, so set the opth again Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-18ipv4: fix a potential use after free in gre_offload.cLi RongQing
pskb_may_pull() may change skb->data and make greh pointer oboslete; so need to reassign greh; but since first calling pskb_may_pull already ensured that skb->data has enough space for greh, so move the reference of greh before second calling pskb_may_pull(), to avoid reassign greh. Fixes: 7a7ffbabf9("ipv4: fix tunneled VM traffic over hw VXLAN/GRE GSO NIC") Cc: Wei-Chun Chao <weichunc@plumgrid.com> Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Include fixes for netrom and dsa (Fabian Frederick and Florian Fainelli) 2) Fix FIXED_PHY support in stmmac, from Giuseppe CAVALLARO. 3) Several SKB use after free fixes (vxlan, openvswitch, vxlan, ip_tunnel, fou), from Li ROngQing. 4) fec driver PTP support fixes from Luwei Zhou and Nimrod Andy. 5) Use after free in virtio_net, from Michael S Tsirkin. 6) Fix flow mask handling for megaflows in openvswitch, from Pravin B Shelar. 7) ISDN gigaset and capi bug fixes from Tilman Schmidt. 8) Fix route leak in ip_send_unicast_reply(), from Vasily Averin. 9) Fix two eBPF JIT bugs on x86, from Alexei Starovoitov. 10) TCP_SKB_CB() reorganization caused a few regressions, fixed by Cong Wang and Eric Dumazet. 11) Don't overwrite end of SKB when parsing malformed sctp ASCONF chunks, from Daniel Borkmann. 12) Don't call sock_kfree_s() with NULL pointers, this function also has the side effect of adjusting the socket memory usage. From Cong Wang. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (90 commits) bna: fix skb->truesize underestimation net: dsa: add includes for ethtool and phy_fixed definitions openvswitch: Set flow-key members. netrom: use linux/uaccess.h dsa: Fix conversion from host device to mii bus tipc: fix bug in bundled buffer reception ipv6: introduce tcp_v6_iif() sfc: add support for skb->xmit_more r8152: return -EBUSY for runtime suspend ipv4: fix a potential use after free in fou.c ipv4: fix a potential use after free in ip_tunnel_core.c hyperv: Add handling of IP header with option field in netvsc_set_hash() openvswitch: Create right mask with disabled megaflows vxlan: fix a free after use openvswitch: fix a use after free ipv4: dst_entry leak in ip_send_unicast_reply() ipv4: clean up cookie_v4_check() ipv4: share tcp_v4_save_options() with cookie_v4_check() ipv4: call __ip_options_echo() in cookie_v4_check() atm: simplify lanai.c by using module_pci_driver ...
2014-10-17net: dsa: add includes for ethtool and phy_fixed definitionsFlorian Fainelli
net/dsa/slave.c uses functions and structures declared in phy_fixed.h but does not explicitely include it, while dsa.h needs structure declarations for 'struct ethtool_wolinfo' and 'struct ethtool_eee', fix those by including the correct header files. Fixes: ec9436baedb6 ("net: dsa: allow drivers to do link adjustment") Fixes: ce31b31c68e7 ("net: dsa: allow updating fixed PHY link information") Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-17openvswitch: Set flow-key members.Pravin B Shelar
This patch adds missing memset which are required to initialize flow key member. For example for IP flow we need to initialize ip.frag for all cases. Found by inspection. This bug is introduced by commit 0714812134d7dcadeb7ecfbfeb18788aa7e1eaac ("openvswitch: Eliminate memset() from flow_extract"). Signed-off-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-17netrom: use linux/uaccess.hFabian Frederick
replace asm/uaccess.h by linux/uaccess.h Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-17tipc: fix bug in bundled buffer receptionJon Paul Maloy
In commit ec8a2e5621db2da24badb3969eda7fd359e1869f ("tipc: same receive code path for connection protocol and data messages") we omitted the the possiblilty that an arriving message extracted from a bundle buffer may be a multicast message. Such messages need to be to be delivered to the socket via a separate function, tipc_sk_mcast_rcv(). As a result, small multicast messages arriving as members of a bundle buffer will be silently dropped. This commit corrects the error by considering this case in the function tipc_link_bundle_rcv(). Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-17ipv6: introduce tcp_v6_iif()Eric Dumazet
Commit 971f10eca186 ("tcp: better TCP_SKB_CB layout to reduce cache line misses") added a regression for SO_BINDTODEVICE on IPv6. This is because we still use inet6_iif() which expects that IP6 control block is still at the beginning of skb->cb[] This patch adds tcp_v6_iif() helper and uses it where necessary. Because __inet6_lookup_skb() is used by TCP and DCCP, we add an iif parameter to it. Signed-off-by: Eric Dumazet <edumazet@google.com> Fixes: 971f10eca186 ("tcp: better TCP_SKB_CB layout to reduce cache line misses") Acked-by: Cong Wang <cwang@twopensource.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-17ipv4: fix a potential use after free in fou.cLi RongQing
pskb_may_pull() maybe change skb->data and make uh pointer oboslete, so reload uh and guehdr Fixes: 37dd0247 ("gue: Receive side for Generic UDP Encapsulation") Cc: Tom Herbert <therbert@google.com> Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-17ipv4: fix a potential use after free in ip_tunnel_core.cLi RongQing
pskb_may_pull() maybe change skb->data and make eth pointer oboslete, so set eth after pskb_may_pull() Fixes:3d7b46cd("ip_tunnel: push generic protocol handling to ip_tunnel module") Cc: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Acked-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-17openvswitch: Create right mask with disabled megaflowsPravin B Shelar
If megaflows are disabled, the userspace does not send the netlink attribute OVS_FLOW_ATTR_MASK, and the kernel must create an exact match mask. sw_flow_mask_set() sets every bytes (in 'range') of the mask to 0xff, even the bytes that represent padding for struct sw_flow, or the bytes that represent fields that may not be set during ovs_flow_extract(). This is a problem, because when we extract a flow from a packet, we do not memset() anymore the struct sw_flow to 0. This commit gets rid of sw_flow_mask_set() and introduces mask_set_nlattr(), which operates on the netlink attributes rather than on the mask key. Using this approach we are sure that only the bytes that the user provided in the flow are matched. Also, if the parse_flow_mask_nlattrs() for the mask ENCAP attribute fails, we now return with an error. This bug is introduced by commit 0714812134d7dcadeb7ecfbfeb18788aa7e1eaac ("openvswitch: Eliminate memset() from flow_extract"). Reported-by: Alex Wang <alexw@nicira.com> Signed-off-by: Daniele Di Proietto <ddiproietto@vmware.com> Signed-off-by: Andy Zhou <azhou@nicira.com> Signed-off-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-17openvswitch: fix a use after freeLi RongQing
pskb_may_pull() called by arphdr_ok can change skb->data, so put the arp setting after arphdr_ok to avoid the use the freed memory Fixes: 0714812134d7d ("openvswitch: Eliminate memset() from flow_extract.") Cc: Jesse Gross <jesse@nicira.com> Cc: Eric Dumazet <edumazet@google.com> Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Acked-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-17ipv4: dst_entry leak in ip_send_unicast_reply()Vasily Averin
ip_setup_cork() called inside ip_append_data() steals dst entry from rt to cork and in case errors in __ip_append_data() nobody frees stolen dst entry Fixes: 2e77d89b2fa8 ("net: avoid a pair of dst_hold()/dst_release() in ip_append_data()") Signed-off-by: Vasily Averin <vvs@parallels.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-17ipv4: clean up cookie_v4_check()Cong Wang
We can retrieve opt from skb, no need to pass it as a parameter. And opt should always be non-NULL, no need to check. Cc: Krzysztof Kolasa <kkolasa@winsoft.pl> Cc: Eric Dumazet <edumazet@google.com> Tested-by: Krzysztof Kolasa <kkolasa@winsoft.pl> Signed-off-by: Cong Wang <cwang@twopensource.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-17ipv4: share tcp_v4_save_options() with cookie_v4_check()Cong Wang
cookie_v4_check() allocates ip_options_rcu in the same way with tcp_v4_save_options(), we can just make it a helper function. Cc: Krzysztof Kolasa <kkolasa@winsoft.pl> Cc: Eric Dumazet <edumazet@google.com> Signed-off-by: Cong Wang <cwang@twopensource.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-17ipv4: call __ip_options_echo() in cookie_v4_check()Cong Wang
commit 971f10eca186cab238c49da ("tcp: better TCP_SKB_CB layout to reduce cache line misses") missed that cookie_v4_check() still calls ip_options_echo() which uses IPCB(). It should use TCPCB() at TCP layer, so call __ip_options_echo() instead. Fixes: commit 971f10eca186cab238c49da ("tcp: better TCP_SKB_CB layout to reduce cache line misses") Cc: Krzysztof Kolasa <kkolasa@winsoft.pl> Cc: Eric Dumazet <edumazet@google.com> Reported-by: Krzysztof Kolasa <kkolasa@winsoft.pl> Tested-by: Krzysztof Kolasa <kkolasa@winsoft.pl> Signed-off-by: Cong Wang <cwang@twopensource.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-15openvswitch: use vport instead of pFabian Frederick
All functions used struct vport *vport except ovs_vport_find_upcall_portid. This fixes 1 kerneldoc warning Signed-off-by: Fabian Frederick <fabf@skynet.be> Acked-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-15openvswitch: kerneldoc warning fixFabian Frederick
s/sock/gs Signed-off-by: Fabian Frederick <fabf@skynet.be> Acked-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-15net: Add ndo_gso_checkTom Herbert
Add ndo_gso_check which a device can define to indicate whether is is capable of doing GSO on a packet. This funciton would be called from the stack to determine whether software GSO is needed to be done. A driver should populate this function if it advertises GSO types for which there are combinations that it wouldn't be able to handle. For instance a device that performs UDP tunneling might only implement support for transparent Ethernet bridging type of inner packets or might have limitations on lengths of inner headers. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-15Merge branch 'for-3.18-consistent-ops' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu Pull percpu consistent-ops changes from Tejun Heo: "Way back, before the current percpu allocator was implemented, static and dynamic percpu memory areas were allocated and handled separately and had their own accessors. The distinction has been gone for many years now; however, the now duplicate two sets of accessors remained with the pointer based ones - this_cpu_*() - evolving various other operations over time. During the process, we also accumulated other inconsistent operations. This pull request contains Christoph's patches to clean up the duplicate accessor situation. __get_cpu_var() uses are replaced with with this_cpu_ptr() and __this_cpu_ptr() with raw_cpu_ptr(). Unfortunately, the former sometimes is tricky thanks to C being a bit messy with the distinction between lvalues and pointers, which led to a rather ugly solution for cpumask_var_t involving the introduction of this_cpu_cpumask_var_ptr(). This converts most of the uses but not all. Christoph will follow up with the remaining conversions in this merge window and hopefully remove the obsolete accessors" * 'for-3.18-consistent-ops' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (38 commits) irqchip: Properly fetch the per cpu offset percpu: Resolve ambiguities in __get_cpu_var/cpumask_var_t -fix ia64: sn_nodepda cannot be assigned to after this_cpu conversion. Use __this_cpu_write. percpu: Resolve ambiguities in __get_cpu_var/cpumask_var_t Revert "powerpc: Replace __get_cpu_var uses" percpu: Remove __this_cpu_ptr clocksource: Replace __this_cpu_ptr with raw_cpu_ptr sparc: Replace __get_cpu_var uses avr32: Replace __get_cpu_var with __this_cpu_write blackfin: Replace __get_cpu_var uses tile: Use this_cpu_ptr() for hardware counters tile: Replace __get_cpu_var uses powerpc: Replace __get_cpu_var uses alpha: Replace __get_cpu_var ia64: Replace __get_cpu_var uses s390: cio driver &__get_cpu_var replacements s390: Replace __get_cpu_var uses mips: Replace __get_cpu_var uses MIPS: Replace __get_cpu_var uses in FPU emulator. arm: Replace __this_cpu_ptr with raw_cpu_ptr ...
2014-10-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client Pull Ceph updates from Sage Weil: "There is the long-awaited discard support for RBD (Guangliang Zhao, Josh Durgin), a pile of RBD bug fixes that didn't belong in late -rc's (Ilya Dryomov, Li RongQing), a pile of fs/ceph bug fixes and performance and debugging improvements (Yan, Zheng, John Spray), and a smattering of cleanups (Chao Yu, Fabian Frederick, Joe Perches)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (40 commits) ceph: fix divide-by-zero in __validate_layout() rbd: rbd workqueues need a resque worker libceph: ceph-msgr workqueue needs a resque worker ceph: fix bool assignments libceph: separate multiple ops with commas in debugfs output libceph: sync osd op definitions in rados.h libceph: remove redundant declaration ceph: additional debugfs output ceph: export ceph_session_state_name function ceph: include the initial ACL in create/mkdir/mknod MDS requests ceph: use pagelist to present MDS request data libceph: reference counting pagelist ceph: fix llistxattr on symlink ceph: send client metadata to MDS ceph: remove redundant code for max file size verification ceph: remove redundant io_iter_advance() ceph: move ceph_find_inode() outside the s_mutex ceph: request xattrs if xattr_version is zero rbd: set the remaining discard properties to enable support rbd: use helpers to handle discard for layered images correctly ...
2014-10-159p/trans_virtio: enable VQs earlyMichael S. Tsirkin
virtio spec requires drivers to set DRIVER_OK before using VQs. This is set automatically after probe returns, but virtio 9p device adds self to channel list within probe, at which point VQ can be used in violation of the spec. To fix, call virtio_device_ready before using VQs. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2014-10-14tcp: TCP Small Queues and strange attractorsEric Dumazet
TCP Small queues tries to keep number of packets in qdisc as small as possible, and depends on a tasklet to feed following packets at TX completion time. Choice of tasklet was driven by latencies requirements. Then, TCP stack tries to avoid reorders, by locking flows with outstanding packets in qdisc in a given TX queue. What can happen is that many flows get attracted by a low performing TX queue, and cpu servicing TX completion has to feed packets for all of them, making this cpu 100% busy in softirq mode. This became particularly visible with latest skb->xmit_more support Strategy adopted in this patch is to detect when tcp_wfree() is called from ksoftirqd and let the outstanding queue for this flow being drained before feeding additional packets, so that skb->ooo_okay can be set to allow select_queue() to select the optimal queue : Incoming ACKS are normally handled by different cpus, so this patch gives more chance for these cpus to take over the burden of feeding qdisc with future packets. Tested: lpaa23:~# ./super_netperf 1400 --google-pacing-rate 3028000 -H lpaa24 -l 3600 & lpaa23:~# sar -n DEV 1 10 | grep eth1 06:16:18 AM eth1 595448.00 1190564.00 38381.09 1760253.12 0.00 0.00 1.00 06:16:19 AM eth1 594858.00 1189686.00 38340.76 1758952.72 0.00 0.00 0.00 06:16:20 AM eth1 597017.00 1194019.00 38480.79 1765370.29 0.00 0.00 1.00 06:16:21 AM eth1 595450.00 1190936.00 38380.19 1760805.05 0.00 0.00 0.00 06:16:22 AM eth1 596385.00 1193096.00 38442.56 1763976.29 0.00 0.00 1.00 06:16:23 AM eth1 598155.00 1195978.00 38552.97 1768264.60 0.00 0.00 0.00 06:16:24 AM eth1 594405.00 1188643.00 38312.57 1757414.89 0.00 0.00 1.00 06:16:25 AM eth1 593366.00 1187154.00 38252.16 1755195.83 0.00 0.00 0.00 06:16:26 AM eth1 593188.00 1186118.00 38232.88 1753682.57 0.00 0.00 1.00 06:16:27 AM eth1 596301.00 1192241.00 38440.94 1762733.09 0.00 0.00 0.00 Average: eth1 595457.30 1190843.50 38381.69 1760664.84 0.00 0.00 0.50 lpaa23:~# ./tc -s -d qd sh dev eth1 | grep backlog backlog 7606336b 2513p requeues 167982 backlog 224072b 74p requeues 566 backlog 581376b 192p requeues 5598 backlog 181680b 60p requeues 1070 backlog 5305056b 1753p requeues 110166 // Here, this TX queue is attracting flows backlog 157456b 52p requeues 1758 backlog 672216b 222p requeues 3025 backlog 60560b 20p requeues 24541 backlog 448144b 148p requeues 21258 lpaa23:~# echo 1 >/proc/sys/net/ipv4/tcp_tsq_enable_tcp_wfree_ksoftirqd_detect Immediate jump to full bandwidth, and traffic is properly shard on all tx queues. lpaa23:~# sar -n DEV 1 10 | grep eth1 06:16:46 AM eth1 1397632.00 2795397.00 90081.87 4133031.26 0.00 0.00 1.00 06:16:47 AM eth1 1396874.00 2793614.00 90032.99 4130385.46 0.00 0.00 0.00 06:16:48 AM eth1 1395842.00 2791600.00 89966.46 4127409.67 0.00 0.00 1.00 06:16:49 AM eth1 1395528.00 2791017.00 89946.17 4126551.24 0.00 0.00 0.00 06:16:50 AM eth1 1397891.00 2795716.00 90098.74 4133497.39 0.00 0.00 1.00 06:16:51 AM eth1 1394951.00 2789984.00 89908.96 4125022.51 0.00 0.00 0.00 06:16:52 AM eth1 1394608.00 2789190.00 89886.90 4123851.36 0.00 0.00 1.00 06:16:53 AM eth1 1395314.00 2790653.00 89934.33 4125983.09 0.00 0.00 0.00 06:16:54 AM eth1 1396115.00 2792276.00 89984.25 4128411.21 0.00 0.00 1.00 06:16:55 AM eth1 1396829.00 2793523.00 90030.19 4130250.28 0.00 0.00 0.00 Average: eth1 1396158.40 2792297.00 89987.09 4128439.35 0.00 0.00 0.50 lpaa23:~# tc -s -d qd sh dev eth1 | grep backlog backlog 7900052b 2609p requeues 173287 backlog 878120b 290p requeues 589 backlog 1068884b 354p requeues 5621 backlog 996212b 329p requeues 1088 backlog 984100b 325p requeues 115316 backlog 956848b 316p requeues 1781 backlog 1080996b 357p requeues 3047 backlog 975016b 322p requeues 24571 backlog 990156b 327p requeues 21274 (All 8 TX queues get a fair share of the traffic) Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-14net: Trap attempts to call sock_kfree_s() with a NULL pointer.David S. Miller
Unlike normal kfree() it is never right to call sock_kfree_s() with a NULL pointer, because sock_kfree_s() also has the side effect of discharging the memory from the sockets quota. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-14rds: avoid calling sock_kfree_s() on allocation failureCong Wang
It is okay to free a NULL pointer but not okay to mischarge the socket optmem accounting. Compile test only. Reported-by: rucsoftsec@gmail.com Cc: Chien Yen <chien.yen@oracle.com> Cc: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: Cong Wang <cwang@twopensource.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-14caif_usb: use target structure member in memsetFabian Frederick
parent cfusbl was used instead of first structure member 'layer' Suggested-by: Joe Perches <joe@perches.com> Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-14caif_usb: remove redundant memory messageFabian Frederick
Let MM subsystem display out of memory messages. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-14caif: replace kmalloc/memset 0 by kzallocFabian Frederick
Also add blank line after declaration Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-14ipv4: fix nexthop attlen check in fib_nh_matchJiri Pirko
fib_nh_match does not match nexthops correctly. Example: ip route add 172.16.10/24 nexthop via 192.168.122.12 dev eth0 \ nexthop via 192.168.122.13 dev eth0 ip route del 172.16.10/24 nexthop via 192.168.122.14 dev eth0 \ nexthop via 192.168.122.15 dev eth0 Del command is successful and route is removed. After this patch applied, the route is correctly matched and result is: RTNETLINK answers: No such process Please consider this for stable trees as well. Fixes: 4e902c57417c4 ("[IPv4]: FIB configuration using struct fib_config") Signed-off-by: Jiri Pirko <jiri@resnulli.us> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-14tcp: fix tcp_ack() performance problemEric Dumazet
We worked hard to improve tcp_ack() performance, by not accessing skb_shinfo() in fast path (cd7d8498c9a5 tcp: change tcp_skb_pcount() location) We still have one spurious access because of ACK timestamping, added in commit e1c8a607b281 ("net-timestamp: ACK timestamp for bytestreams") By checking if sk_tsflags has SOF_TIMESTAMPING_TX_ACK set, we can avoid two cache line misses for the common case. While we are at it, add two prefetchw() : One in tcp_ack() to bring skb at the head of write queue. One in tcp_clean_rtx_queue() loop to bring following skb, as we will delete skb from the write queue and dirty skb->next->prev. Add a couple of [un]likely() clauses. After this patch, tcp_ack() is no longer the most consuming function in tcp stack. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Willem de Bruijn <willemb@google.com> Cc: Neal Cardwell <ncardwell@google.com> Cc: Yuchung Cheng <ycheng@google.com> Cc: Van Jacobson <vanj@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-14libceph: ceph-msgr workqueue needs a resque workerIlya Dryomov
Commit f363e45fd118 ("net/ceph: make ceph_msgr_wq non-reentrant") effectively removed WQ_MEM_RECLAIM flag from ceph_msgr_wq. This is wrong - libceph is very much a memory reclaim path, so restore it. Cc: stable@vger.kernel.org # needs backporting for < 3.12 Signed-off-by: Ilya Dryomov <idryomov@redhat.com> Tested-by: Micha Krause <micha@krausam.de> Reviewed-by: Sage Weil <sage@redhat.com>
2014-10-14libceph: separate multiple ops with commas in debugfs outputIlya Dryomov
For requests with multiple ops, separate ops with commas instead of \t, which is a field separator here. Signed-off-by: Ilya Dryomov <idryomov@redhat.com> Reviewed-by: Sage Weil <sage@redhat.com>
2014-10-14libceph: sync osd op definitions in rados.hIlya Dryomov
Bring in missing osd ops and strings, use macros to eliminate multiple points of maintenance. Signed-off-by: Ilya Dryomov <idryomov@redhat.com> Reviewed-by: Sage Weil <sage@redhat.com>
2014-10-14libceph: reference counting pagelistYan, Zheng
this allow pagelist to present data that may be sent multiple times. Signed-off-by: Yan, Zheng <zyan@redhat.com> Reviewed-by: Sage Weil <sage@redhat.com>
2014-10-14ipv6: remove aca_lock spinlock from struct ifacaddr6Li RongQing
no user uses this lock. Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-14tcp: fix ooo_okay setting vs Small QueuesEric Dumazet
TCP Small Queues (tcp_tsq_handler()) can hold one reference on sk->sk_wmem_alloc, preventing skb->ooo_okay being set. We should relax test done to set skb->ooo_okay to take care of this extra reference. Minimal truesize of skb containing one byte of payload is SKB_TRUESIZE(1) Without this fix, we have more chance locking flows into the wrong transmit queue. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-14libceph: don't try checking queue_work() return valueIlya Dryomov
queue_work() doesn't "fail to queue", it returns false if work was already on a queue, which can't happen here since we allocate event_work right before we queue it. So don't bother at all. Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com> Reviewed-by: Alex Elder <elder@linaro.org>
2014-10-14libceph: Convert pr_warning to pr_warnJoe Perches
Use the more common pr_warn. Other miscellanea: o Coalesce formats o Realign arguments Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com>
2014-10-14libceph: fix a use after free issue in osdmap_set_max_osdLi RongQing
If the state variable is krealloced successfully, map->osd_state will be freed, once following two reallocation failed, and exit the function without resetting map->osd_state, map->osd_state become a wild pointer. fix it by resetting them after krealloc successfully. Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com>
2014-10-14libceph: select CRYPTO_CBC in addition to CRYPTO_AESIlya Dryomov
We want "cbc(aes)" algorithm, so select CRYPTO_CBC too, not just CRYPTO_AES. Otherwise on !CRYPTO_CBC kernels we fail rbd map/mount with libceph: error -2 building auth method x request Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com>
2014-10-14libceph: resend lingering requests with a new tidIlya Dryomov
Both not yet registered (r_linger && list_empty(&r_linger_item)) and registered linger requests should use the new tid on resend to avoid the dup op detection logic on the OSDs, yet we were doing this only for "registered" case. Factor out and simplify the "registered" logic and use the new helper for "not registered" case as well. Fixes: http://tracker.ceph.com/issues/8806 Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com> Reviewed-by: Alex Elder <elder@linaro.org>
2014-10-14libceph: abstract out ceph_osd_request enqueue logicIlya Dryomov
Introduce __enqueue_request() and switch to it. Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com> Reviewed-by: Alex Elder <elder@linaro.org>
2014-10-14net: sctp: fix remote memory pressure from excessive queueingDaniel Borkmann
This scenario is not limited to ASCONF, just taken as one example triggering the issue. When receiving ASCONF probes in the form of ... -------------- INIT[ASCONF; ASCONF_ACK] -------------> <----------- INIT-ACK[ASCONF; ASCONF_ACK] ------------ -------------------- COOKIE-ECHO --------------------> <-------------------- COOKIE-ACK --------------------- ---- ASCONF_a; [ASCONF_b; ...; ASCONF_n;] JUNK ------> [...] ---- ASCONF_m; [ASCONF_o; ...; ASCONF_z;] JUNK ------> ... where ASCONF_a, ASCONF_b, ..., ASCONF_z are good-formed ASCONFs and have increasing serial numbers, we process such ASCONF chunk(s) marked with !end_of_packet and !singleton, since we have not yet reached the SCTP packet end. SCTP does only do verification on a chunk by chunk basis, as an SCTP packet is nothing more than just a container of a stream of chunks which it eats up one by one. We could run into the case that we receive a packet with a malformed tail, above marked as trailing JUNK. All previous chunks are here goodformed, so the stack will eat up all previous chunks up to this point. In case JUNK does not fit into a chunk header and there are no more other chunks in the input queue, or in case JUNK contains a garbage chunk header, but the encoded chunk length would exceed the skb tail, or we came here from an entirely different scenario and the chunk has pdiscard=1 mark (without having had a flush point), it will happen, that we will excessively queue up the association's output queue (a correct final chunk may then turn it into a response flood when flushing the queue ;)): I ran a simple script with incremental ASCONF serial numbers and could see the server side consuming excessive amount of RAM [before/after: up to 2GB and more]. The issue at heart is that the chunk train basically ends with !end_of_packet and !singleton markers and since commit 2e3216cd54b1 ("sctp: Follow security requirement of responding with 1 packet") therefore preventing an output queue flush point in sctp_do_sm() -> sctp_cmd_interpreter() on the input chunk (chunk = event_arg) even though local_cork is set, but its precedence has changed since then. In the normal case, the last chunk with end_of_packet=1 would trigger the queue flush to accommodate possible outgoing bundling. In the input queue, sctp_inq_pop() seems to do the right thing in terms of discarding invalid chunks. So, above JUNK will not enter the state machine and instead be released and exit the sctp_assoc_bh_rcv() chunk processing loop. It's simply the flush point being missing at loop exit. Adding a try-flush approach on the output queue might not work as the underlying infrastructure might be long gone at this point due to the side-effect interpreter run. One possibility, albeit a bit of a kludge, would be to defer invalid chunk freeing into the state machine in order to possibly trigger packet discards and thus indirectly a queue flush on error. It would surely be better to discard chunks as in the current, perhaps better controlled environment, but going back and forth, it's simply architecturally not possible. I tried various trailing JUNK attack cases and it seems to look good now. Joint work with Vlad Yasevich. Fixes: 2e3216cd54b1 ("sctp: Follow security requirement of responding with 1 packet") Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-14net: sctp: fix panic on duplicate ASCONF chunksDaniel Borkmann
When receiving a e.g. semi-good formed connection scan in the form of ... -------------- INIT[ASCONF; ASCONF_ACK] -------------> <----------- INIT-ACK[ASCONF; ASCONF_ACK] ------------ -------------------- COOKIE-ECHO --------------------> <-------------------- COOKIE-ACK --------------------- ---------------- ASCONF_a; ASCONF_b -----------------> ... where ASCONF_a equals ASCONF_b chunk (at least both serials need to be equal), we panic an SCTP server! The problem is that good-formed ASCONF chunks that we reply with ASCONF_ACK chunks are cached per serial. Thus, when we receive a same ASCONF chunk twice (e.g. through a lost ASCONF_ACK), we do not need to process them again on the server side (that was the idea, also proposed in the RFC). Instead, we know it was cached and we just resend the cached chunk instead. So far, so good. Where things get nasty is in SCTP's side effect interpreter, that is, sctp_cmd_interpreter(): While incoming ASCONF_a (chunk = event_arg) is being marked !end_of_packet and !singleton, and we have an association context, we do not flush the outqueue the first time after processing the ASCONF_ACK singleton chunk via SCTP_CMD_REPLY. Instead, we keep it queued up, although we set local_cork to 1. Commit 2e3216cd54b1 changed the precedence, so that as long as we get bundled, incoming chunks we try possible bundling on outgoing queue as well. Before this commit, we would just flush the output queue. Now, while ASCONF_a's ASCONF_ACK sits in the corked outq, we continue to process the same ASCONF_b chunk from the packet. As we have cached the previous ASCONF_ACK, we find it, grab it and do another SCTP_CMD_REPLY command on it. So, effectively, we rip the chunk->list pointers and requeue the same ASCONF_ACK chunk another time. Since we process ASCONF_b, it's correctly marked with end_of_packet and we enforce an uncork, and thus flush, thus crashing the kernel. Fix it by testing if the ASCONF_ACK is currently pending and if that is the case, do not requeue it. When flushing the output queue we may relink the chunk for preparing an outgoing packet, but eventually unlink it when it's copied into the skb right before transmission. Joint work with Vlad Yasevich. Fixes: 2e3216cd54b1 ("sctp: Follow security requirement of responding with 1 packet") Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-14net: sctp: fix skb_over_panic when receiving malformed ASCONF chunksDaniel Borkmann
Commit 6f4c618ddb0 ("SCTP : Add paramters validity check for ASCONF chunk") added basic verification of ASCONF chunks, however, it is still possible to remotely crash a server by sending a special crafted ASCONF chunk, even up to pre 2.6.12 kernels: skb_over_panic: text:ffffffffa01ea1c3 len:31056 put:30768 head:ffff88011bd81800 data:ffff88011bd81800 tail:0x7950 end:0x440 dev:<NULL> ------------[ cut here ]------------ kernel BUG at net/core/skbuff.c:129! [...] Call Trace: <IRQ> [<ffffffff8144fb1c>] skb_put+0x5c/0x70 [<ffffffffa01ea1c3>] sctp_addto_chunk+0x63/0xd0 [sctp] [<ffffffffa01eadaf>] sctp_process_asconf+0x1af/0x540 [sctp] [<ffffffff8152d025>] ? _read_unlock_bh+0x15/0x20 [<ffffffffa01e0038>] sctp_sf_do_asconf+0x168/0x240 [sctp] [<ffffffffa01e3751>] sctp_do_sm+0x71/0x1210 [sctp] [<ffffffff8147645d>] ? fib_rules_lookup+0xad/0xf0 [<ffffffffa01e6b22>] ? sctp_cmp_addr_exact+0x32/0x40 [sctp] [<ffffffffa01e8393>] sctp_assoc_bh_rcv+0xd3/0x180 [sctp] [<ffffffffa01ee986>] sctp_inq_push+0x56/0x80 [sctp] [<ffffffffa01fcc42>] sctp_rcv+0x982/0xa10 [sctp] [<ffffffffa01d5123>] ? ipt_local_in_hook+0x23/0x28 [iptable_filter] [<ffffffff8148bdc9>] ? nf_iterate+0x69/0xb0 [<ffffffff81496d10>] ? ip_local_deliver_finish+0x0/0x2d0 [<ffffffff8148bf86>] ? nf_hook_slow+0x76/0x120 [<ffffffff81496d10>] ? ip_local_deliver_finish+0x0/0x2d0 [<ffffffff81496ded>] ip_local_deliver_finish+0xdd/0x2d0 [<ffffffff81497078>] ip_local_deliver+0x98/0xa0 [<ffffffff8149653d>] ip_rcv_finish+0x12d/0x440 [<ffffffff81496ac5>] ip_rcv+0x275/0x350 [<ffffffff8145c88b>] __netif_receive_skb+0x4ab/0x750 [<ffffffff81460588>] netif_receive_skb+0x58/0x60 This can be triggered e.g., through a simple scripted nmap connection scan injecting the chunk after the handshake, for example, ... -------------- INIT[ASCONF; ASCONF_ACK] -------------> <----------- INIT-ACK[ASCONF; ASCONF_ACK] ------------ -------------------- COOKIE-ECHO --------------------> <-------------------- COOKIE-ACK --------------------- ------------------ ASCONF; UNKNOWN ------------------> ... where ASCONF chunk of length 280 contains 2 parameters ... 1) Add IP address parameter (param length: 16) 2) Add/del IP address parameter (param length: 255) ... followed by an UNKNOWN chunk of e.g. 4 bytes. Here, the Address Parameter in the ASCONF chunk is even missing, too. This is just an example and similarly-crafted ASCONF chunks could be used just as well. The ASCONF chunk passes through sctp_verify_asconf() as all parameters passed sanity checks, and after walking, we ended up successfully at the chunk end boundary, and thus may invoke sctp_process_asconf(). Parameter walking is done with WORD_ROUND() to take padding into account. In sctp_process_asconf()'s TLV processing, we may fail in sctp_process_asconf_param() e.g., due to removal of the IP address that is also the source address of the packet containing the ASCONF chunk, and thus we need to add all TLVs after the failure to our ASCONF response to remote via helper function sctp_add_asconf_response(), which basically invokes a sctp_addto_chunk() adding the error parameters to the given skb. When walking to the next parameter this time, we proceed with ... length = ntohs(asconf_param->param_hdr.length); asconf_param = (void *)asconf_param + length; ... instead of the WORD_ROUND()'ed length, thus resulting here in an off-by-one that leads to reading the follow-up garbage parameter length of 12336, and thus throwing an skb_over_panic for the reply when trying to sctp_addto_chunk() next time, which implicitly calls the skb_put() with that length. Fix it by using sctp_walk_params() [ which is also used in INIT parameter processing ] macro in the verification *and* in ASCONF processing: it will make sure we don't spill over, that we walk parameters WORD_ROUND()'ed. Moreover, we're being more defensive and guard against unknown parameter types and missized addresses. Joint work with Vlad Yasevich. Fixes: b896b82be4ae ("[SCTP] ADDIP: Support for processing incoming ASCONF_ACK chunks.") Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: Vlad Yasevich <vyasevich@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-14lib80211: remove unused print_ssid()Andy Shevchenko
In kernel we have %*pE specifier to print an escaped buffer. All users now switched to that approach. This fixes a bug as well. The current implementation wrongly prints octal numbers: only two first digits are used in case when 3 are required and the rest of the string ends up cut off. Additionally by default the \f, \v, \a, and \e are escaped to their alphabetic representation. It's safe to do since it is currently used for messaging only. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: "John W . Linville" <linville@tuxdriver.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
