path: root/net
2006-04-18[NET]: Remove redundant NULL checks before [kv]freeJesper Juhl
Redundant NULL check before kfree removal from net/ Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-18unaligned access in sk_run_filter()Dmitry Mishin
This patch fixes unaligned access warnings noticed on IA64 in sk_run_filter(). 'ptr' can be unaligned. Signed-off-By: Dmitry Mishin <dim@openvz.org> Signed-off-By: Kirill Korotaev <dev@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-18[IPV6]: Clean up hop-by-hop options handler.YOSHIFUJI Hideaki
- Removed unused argument (nhoff) for ipv6_parse_hopopts(). - Make ipv6_parse_hopopts() to align with other extension header handlers. - Removed pointless assignment (hdr), which is not used afterwards. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-18[IPV6] XFRM: Fix decoding session with preceding extension header(s).YOSHIFUJI Hideaki
We did not correctly decode session with preceding extension header(s). This was because we had already pulled preceding headers, skb->nh.raw + 40 + 1 - skb->data was minus, and pskb_may_pull() failed. We now have IP6CB(skb)->nhoff and skb->h.raw, and we can start parsing / decoding upper layer protocol from current position. Tracked down by Noriaki TAKAMIYA <takamiya@po.ntts.co.jp> and tested by Kazunori Miyazawa <kazunori@miyazawa.org>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-18[IPV6] XFRM: Don't use old copy of pointer after pskb_may_pull().YOSHIFUJI Hideaki
2006-04-18[IPV6]: Ensure to have hop-by-hop options in our header of &sk_buff.YOSHIFUJI Hideaki
2006-04-18[TCP]: Fix truesize underflowHerbert Xu
There is a problem with the TSO packet trimming code. The cause of this lies in the tcp_fragment() function. When we allocate a fragment for a completely non-linear packet the truesize is calculated for a payload length of zero. This means that truesize could in fact be less than the real payload length. When that happens the TSO packet trimming can cause truesize to become negative. This in turn can cause sk_forward_alloc to be -n * PAGE_SIZE which would trigger the warning. I've copied the code DaveM used in tso_fragment which should work here. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-17[IPV4]: ip_route_input panic fixStephen Hemminger
This fixes http://bugzilla.kernel.org/show_bug.cgi?id=6388 The bug is caused by ip_route_input dereferencing skb->nh.protocol of the dummy skb passed dow from inet_rtm_getroute (Thanks Thomas for seeing it). It only happens if the route requested is for a multicast IP address. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-14[PATCH] ip_output: account for fraggap when checking to add trailer_lenZach Brown
During other work I noticed that ip_append_data() seemed to be forgetting to include the frag gap in its calculation of a fragment that consumes the rest of the payload. Herbert confirmed that this was a bug that snuck in during a previous rework. Signed-off-by: Zach Brown <zach.brown@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-14[ATM] clip: add module infoStephen Hemminger
Add module information Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-14[ATM] clip: notifier related cleanupsStephen Hemminger
Cleanup some code around notifier. Don't need (void) casts to ignore return values, and use C90 style initializer. Just ignore unused device events. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-14[ATM] clip: get rid of PROC_FS ifdefStephen Hemminger
Don't need the ifdef here since create_proc_entry() is stubbed to always return NULL. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-14[ATM] clip: run through LindentStephen Hemminger
Run CLIP driver through Lindent script to fix formatting. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-14[ATM]: Clip timer race.Stephen Hemminger
By inspection, the clip idle timer code is racy on SMP. Here is a safe version of timer management. Untested, I don't have ATM hardware. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-14[ATM]: clip causes unregister hangStephen Hemminger
If Classical IP over ATM module is loaded, its neighbor table gets populated when permanent neighbor entries are created; but these entries are not flushed when the device is removed. Since the entry never gets flushed the unregister of the network device never completes. This version of the patch also adds locking around the reference to the atm arp daemon to avoid races with events and daemon state changes. (Note: barrier() was never really safe) Bug-reference: http://bugzilla.kernel.org/show_bug.cgi?id=6295 Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-14[XFRM]: Fix aevent timer.Jamal Hadi Salim
Send aevent immediately if we have sent nothing since last timer and this is the first packet. Fixes a corner case when packet threshold is very high, the timer low and a very low packet rate input which is bursty. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-14[IPV4]: Possible cleanups.Adrian Bunk
This patch contains the following possible cleanups: - make the following needlessly global function static: - arp.c: arp_rcv() - remove the following unused EXPORT_SYMBOL's: - devinet.c: devinet_ioctl - fib_frontend.c: ip_rt_ioctl - inet_hashtables.c: inet_bind_bucket_create - inet_hashtables.c: inet_bind_hash - tcp_input.c: sysctl_tcp_abc - tcp_ipv4.c: sysctl_tcp_tw_reuse - tcp_output.c: sysctl_tcp_mtu_probing - tcp_output.c: sysctl_tcp_base_mss Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-11[WAN]: Remove broken and unmaintained Sangoma drivers.Adrian Bunk
The in-kernel Sangoma drivers are both not compiling and marked as BROKEN since at least kernel 2.6.0. Sangoma offers out-of-tree drivers, and David Mandelstam told me Sangoma does no longer maintain the in-kernel drivers and prefers to provide them as a separate installation package. This patch therefore removes these drivers. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-11[BRIDGE] ebtables: fix allocation in net/bridge/netfilter/ebtables.cJayachandran C
Allocate an array of 'struct ebt_chainstack *', the current code allocates array of 'struct ebt_chainstack'. akpm: converted to use the foo = alloc(sizeof(*foo)) form. Which would have prevented this from happening in the first place. akpm: also removed unneeded typecast. akpm: what on earth is this code doing anyway? cpu_possible_map can be sparse.. Signed-off-by: Jayachandran C. <c.jayachandran@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-11[DCCP]: Fix leak in net/dccp/ipv4.cEric Sesterhenn
we dont free req if we cant parse the options. This fixes coverity bug id #1046 Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-11[BRIDGE]: receive link-local on disabled ports.Stephen Hemminger
This change allows link local packets (like 802.3ad and Spanning Tree Protocol) to be processed even when the bridge is not using the port. It fixes the chicken-egg problem for bridging a bonded device, and may also fix problems with spanning tree failover. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-11[IPv6] reassembly: Always compute hash under the fragment lock.Zach Brown
This closes a race where an ipq6hashfn() caller could get a hash value and race with the cycling of the random seed. By the time they got to the read_lock they'd have a stale hash value and might not find previous fragments of their datagram. This matches the previous patch to IPv4. Signed-off-by: Zach Brown <zach.brown@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-11Merge branch 'splice' of git://brick.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
* 'splice' of git://brick.kernel.dk/data/git/linux-2.6-block: [PATCH] vfs: add splice_write and splice_read to documentation [PATCH] Remove sys_ prefix of new syscalls from __NR_sys_* [PATCH] splice: warning fix [PATCH] another round of fs/pipe.c cleanups [PATCH] splice: comment styles [PATCH] splice: add Ingo as addition copyright holder [PATCH] splice: unlikely() optimizations [PATCH] splice: speedups and optimizations [PATCH] pipe.c/fifo.c code cleanups [PATCH] get rid of the PIPE_*() macros [PATCH] splice: speedup __generic_file_splice_read [PATCH] splice: add direct fd <-> fd splicing support [PATCH] splice: add optional input and output offsets [PATCH] introduce a "kernel-internal pipe object" abstraction [PATCH] splice: be smarter about calling do_page_cache_readahead() [PATCH] splice: optimize the splice buffer mapping [PATCH] splice: cleanup __generic_file_splice_read() [PATCH] splice: only call wake_up_interruptible() when we really have to [PATCH] splice: potential !page dereference [PATCH] splice: mark the io page as accessed
2006-04-11[PATCH] knfsd: svcrpc: gss: don't call svc_take_page unnecessarilyNeilBrown
We're using svc_take_page here to get another page for the tail in case one wasn't already allocated. But there isn't always guaranteed to be another page available. Also fix a typo that made us check the tail buffer for space when we meant to be checking the head buffer. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] for_each_possible_cpu: network codesKAMEZAWA Hiroyuki
for_each_cpu() actually iterates across all possible CPUs. We've had mistakes in the past where people were using for_each_cpu() where they should have been iterating across only online or present CPUs. This is inefficient and possibly buggy. We're renaming for_each_cpu() to for_each_possible_cpu() to avoid this in the future. This patch replaces for_each_cpu with for_each_possible_cpu under /net Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] splice: warning fixAndrew Morton
From: Andrew Morton <akpm@osdl.org> net/socket.c:148: warning: initialization from incompatible pointer type extern declarations in .c files! Bad boy. Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-04-09[IPV6]: Deinline few large functions in inet6 codeDenis Vlasenko
Deinline a few functions which produce 200+ bytes of code. Size Uses Wasted Name and definition ===== ==== ====== ================================================ 429 3 818 __inet6_lookup include/net/inet6_hashtables.h 404 2 384 __inet6_lookup_established include/net/inet6_hashtables.h 206 3 372 __inet6_hash include/net/inet6_hashtables.h Signed-off-by: Denis Vlasenko <vda@ilport.com.ua> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[IPV4] ip_fragment: Always compute hash with ipfrag_lock held.David S. Miller
Otherwise we could compute an inaccurate hash due to the random seed changing. Noticed by Zach Brown and patch is based upon some feedback from Herbert Xu. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[NETFILTER]: Fix DNAT in LOCAL_OUTPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[NET]: Fix hotplug race during device registration.Sergey Vlasov
From: Thomas de Grenier de Latour <degrenier@easyconnect.fr> On Sun, 9 Apr 2006 21:56:59 +0400, Sergey Vlasov <vsu@altlinux.ru> wrote: > However, show_address() does not output anything unless > dev->reg_state == NETREG_REGISTERED - and this state is set by > netdev_run_todo() only after netdev_register_sysfs() returns, so in > the meantime (while netdev_register_sysfs() is busy adding the > "statistics" attribute group) some process may see an empty "address" > attribute. I've tried the attached patch, suggested by Sergey Vlasov on hotplug-devel@, and as far as i can test it works just fine. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[NETFILTER]: Fix build with CONFIG_NETFILTER=y/m on IA64Brian Haley
Can't build with CONFIG_NETFILTER=y/m on IA64, there's a missing #include in net/ipv6/netfilter.c net/ipv6/netfilter.c: In function `nf_ip6_checksum': net/ipv6/netfilter.c:92: warning: implicit declaration of function `csum_ipv6_magic' Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[NET]: More kzalloc conversions.Andrew Morton
2006-04-09[NET] kzalloc: use in alloc_netdevPaolo 'Blaisorblade' Giarrusso
Noticed this use, fixed it. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[PKT_SCHED] act_police: Rename methods.Jamal Hadi Salim
Rename policer specific _generic_ methods to be specific to _act_police_ Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[NETFILTER]: H.323 helper: remove changelogPatrick McHardy
2006-04-09[NETFILTER]: Convert conntrack/ipt_REJECT to new checksumming functionsPatrick McHardy
Besides removing lots of duplicate code, all converted users benefit from improved HW checksum error handling. Tested with and without HW checksums in almost all combinations. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[NETFILTER]: Add address family specific checksum helpersPatrick McHardy
Add checksum operation which takes care of verifying the checksum and dealing with HW checksum errors and avoids multiple checksum operations by setting ip_summed to CHECKSUM_UNNECESSARY after successful verification. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[NETFILTER]: Introduce infrastructure for address family specific operationsPatrick McHardy
Change the queue rerouter intrastructure to a generic usable infrastructure for address family specific operations as a base for some cleanups. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[NETFILTER]: Fix IP_NF_CONNTRACK_NETLINK dependencyPatrick McHardy
When NAT is built as a module, ip_conntrack_netlink can not be linked statically. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[NETFILTER]: H.323 helper: add parameter 'default_rrq_ttl'Jing Min Zhao
default_rrq_ttl is used when no TTL is included in the RRQ. Signed-off-by: Jing Min Zhao <zhaojingmin@users.sourceforge.net> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[NETFILTER]: H.323 helper: make get_h245_addr() staticJing Min Zhao
2006-04-09[NETFILTER]: H.323 helper: change EXPORT_SYMBOL to EXPORT_SYMBOL_GPLJing Min Zhao
2006-04-09[NETFILTER]: H.323 helper: move some function prototypes to ip_conntrack_h323.hJing Min Zhao
Move prototypes of NAT callbacks to ip_conntrack_h323.h. Because the use of typedefs as arguments, some header files need to be moved as well. Signed-off-by: Jing Min Zhao <zhaojingmin@users.sourceforge.net> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[NETFILTER]: Fix section mismatch warningsPatrick McHardy
Fix section mismatch warnings caused by netfilter's init_or_cleanup functions used in many places by splitting the init from the cleanup parts. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[NETFILTER]: Clean up hook registrationPatrick McHardy
Clean up hook registration by makeing use of the new mass registration and unregistration helpers. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[NETFILTER]: Add helper functions for mass hook registration/unregistrationPatrick McHardy
2006-04-09[INET]: Use port unreachable instead of proto for tunnelsHerbert Xu
This patch changes GRE and SIT to generate port unreachable instead of protocol unreachable errors when we can't find a matching tunnel for a packet. This removes the ambiguity as to whether the error is caused by no tunnel being found or by the lack of support for the given tunnel type. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[BLUETOOTH] sco: Possible double free.Eric Sesterhenn
this fixes coverity bug id #1068. hci_send_sco() frees skb if (skb->len > hdev->sco_mtu). Since it returns a negative error value only in this case, we can directly return here. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[NET]: Fix an off-by-21-or-49 error.Adrian Bunk
This patch fixes an off-by-21-or-49 error ;-) spotted by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[INET]: Move no-tunnel ICMP error to tunnel4/tunnel6Herbert Xu
This patch moves the sending of ICMP messages when there are no IPv4/IPv6 tunnels present to tunnel4/tunnel6 respectively. Please note that for now if xfrm4_tunnel/xfrm6_tunnel is loaded then no ICMP messages will ever be sent. This is similar to how we handle AH/ESP/IPCOMP. This move fixes the bug where we always send an ICMP message when there is no ip6_tunnel device present for a given packet even if it is later handled by IPsec. It also causes ICMP messages to be sent when no IPIP tunnel is present. I've decided to use the "port unreachable" ICMP message over the current value of "address unreachable" (and "protocol unreachable" by GRE) because it is not ambiguous unlike the other ones which can be triggered by other conditions. There seems to be no standard specifying what value must be used so this change should be OK. In fact we should change GRE to use this value as well. Incidentally, this patch also fixes a fairly serious bug in xfrm6_tunnel where we don't check whether the embedded IPv6 header is present before dereferencing it for the inside source address. This patch is inspired by a previous patch by Hugo Santos <hsantos@av.it.pt>. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
