path: root/net
2010-06-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (52 commits) phylib: Add autoload support for the LXT973 phy. ISDN: hysdn, fix potential NULL dereference vxge: fix memory leak in vxge_alloc_msix() error path isdn/gigaset: correct CAPI connection state storage isdn/gigaset: encode HLC and BC together isdn/gigaset: correct CAPI DATA_B3 Delivery Confirmation isdn/gigaset: correct CAPI voice connection encoding isdn/gigaset: honor CAPI application's buffer size request cpmac: do not leak struct net_device on phy_connect errors smc91c92_cs: fix the problem that lan & modem does not work simultaneously ipv6: fix NULL reference in proxy neighbor discovery Bluetooth: Bring back var 'i' increment xfrm: check bundle policy existance before dereferencing it sky2: enable rx/tx in sky2_phy_reinit() cnic: Disable statistics initialization for eth clients that do not support statistics net: add dependency on fw class module to qlcnic and netxen_nic snmp: fix SNMP_ADD_STATS() hso: remove setting of low_latency flag udp: Fix bogus UFO packet generation lasi82596: fix netdev_mc_count conversion ...
2010-06-25ipv6: fix NULL reference in proxy neighbor discoverystephen hemminger
The addition of TLLAO option created a kernel OOPS regression for the case where neighbor advertisement is being sent via proxy path. When using proxy, ipv6_get_ifaddr() returns NULL causing the NULL dereference. Change causing the bug was: commit f7734fdf61ec6bb848e0bafc1fb8bad2c124bb50 Author: Octavian Purdila <opurdila@ixiacom.com> Date: Fri Oct 2 11:39:15 2009 +0000 make TLLAO option for NA packets configurable Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-24Bluetooth: Bring back var 'i' incrementGustavo F. Padovan
commit ff6e2163f28a1094fb5ca5950fe2b43c3cf6bc7a accidentally added a regression on the bnep code. Fixing it. Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-24xfrm: check bundle policy existance before dereferencing itTimo Teräs
Fix the bundle validation code to not assume having a valid policy. When we have multiple transformations for a xfrm policy, the bundle instance will be a chain of bundles with only the first one having the policy reference. When policy_genid is bumped it will expire the first bundle in the chain which is equivalent of expiring the whole chain. Reported-bisected-and-tested-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Timo Teräs <timo.teras@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-22SUNRPC: Fix a re-entrancy bug in xs_tcp_read_calldir()Trond Myklebust
If the attempt to read the calldir fails, then instead of storing the read bytes, we currently discard them. This leads to a garbage final result when upon re-entry to the same routine, we read the remaining bytes. Fixes the regression in bugzilla number 16213. Please see https://bugzilla.kernel.org/show_bug.cgi?id=16213 Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@kernel.org
2010-06-21udp: Fix bogus UFO packet generationHerbert Xu
It has been reported that the new UFO software fallback path fails under certain conditions with NFS. I tracked the problem down to the generation of UFO packets that are smaller than the MTU. The software fallback path simply discards these packets. This patch fixes the problem by not generating such packets on the UFO path. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Reviewed-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-17bridge: fdb cleanup runs too oftenstephen hemminger
It is common in end-node, non STP bridges to set forwarding delay to zero; which causes the forwarding database cleanup to run every clock tick. Change to run only as soon as needed or at next ageing timer interval which ever is sooner. Use round_jiffies_up macro rather than attempting round up by changing value. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-16Clear IFF_XMIT_DST_RELEASE for teql interfacesTom Hughes
https://bugzilla.kernel.org/show_bug.cgi?id=16183 The sch_teql module, which can be used to load balance over a set of underlying interfaces, stopped working after 2.6.30 and has been broken in all kernels since then for any underlying interface which requires the addition of link level headers. The problem is that the transmit routine relies on being able to access the destination address in the skb in order to do address resolution once it has decided which underlying interface it is going to transmit through. In 2.6.31 the IFF_XMIT_DST_RELEASE flag was introduced, and set by default for all interfaces, which causes the destination address to be released before the transmit routine for the interface is called. The solution is to clear that flag for teql interfaces. Signed-off-by: Tom Hughes <tom@compton.nu> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-16Merge branch 'master' of ↵David S. Miller
2010-06-16mac80211: fix warn, enum may be used uninitializedChristoph Fritz
regression introduced by b8d92c9c141ee3dc9b3537b1f0ffb4a54ea8d9b2 In function ‘ieee80211_work_rx_queued_mgmt’: warning: ‘rma’ may be used uninitialized in this function this re-adds default value WORK_ACT_NONE back to rma Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-15bridge: Fix OOM crash in deliver_cloneHerbert Xu
The bridge multicast patches introduced an OOM crash in the forward path, when deliver_clone fails to clone the skb. Reported-by: Mark Wagner <mwagner@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-15Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-2.6
2010-06-13net: rxhash already set in __copy_skb_headerEric Dumazet
No need to copy rxhash again in __skb_clone() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-13net: fix deliver_no_wcard regression on loopback deviceJohn Fastabend
deliver_no_wcard is not being set in skb_copy_header. In the skb_cloned case it is not being cleared and may cause the skb to be dropped when the loopback device pushes it back up the stack. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Tested-by: Markus Trippelsdorf <markus@trippelsdorf.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-10pktgen: Fix accuracy of inter-packet delay.Daniel Turull
This patch correct a bug in the delay of pktgen. It makes sure the inter-packet interval is accurate. Signed-off-by: Daniel Turull <daniel.turull@gmail.com> Signed-off-by: Robert Olsson <robert.olsson@its.uu.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-10pkt_sched: gen_estimator: add a new lockEric Dumazet
gen_kill_estimator() / gen_new_estimator() is not always called with RTNL held. net/netfilter/xt_RATEEST.c is one user of these API that do not hold RTNL, so random corruptions can occur between "tc" and "iptables". Add a new fine grained lock instead of trying to use RTNL in netfilter. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-10net: deliver skbs on inactive slaves to exact matchesJohn Fastabend
Currently, the accelerated receive path for VLAN's will drop packets if the real device is an inactive slave and is not one of the special pkts tested for in skb_bond_should_drop(). This behavior is different then the non-accelerated path and for pkts over a bonded vlan. For example, vlanx -> bond0 -> ethx will be dropped in the vlan path and not delivered to any packet handlers at all. However, bond0 -> vlanx -> ethx and bond0 -> ethx will be delivered to handlers that match the exact dev, because the VLAN path checks the real_dev which is not a slave and netif_recv_skb() doesn't drop frames but only delivers them to exact matches. This patch adds a sk_buff flag which is used for tagging skbs that would previously been dropped and allows the skb to continue to skb_netif_recv(). Here we add logic to check for the deliver_no_wcard flag and if it is set only deliver to handlers that match exactly. This makes both paths above consistent and gives pkt handlers a way to identify skbs that come from inactive slaves. Without this patch in some configurations skbs will be delivered to handlers with exact matches and in others be dropped out right in the vlan path. I have tested the following 4 configurations in failover modes and load balancing modes. # bond0 -> ethx # vlanx -> bond0 -> ethx # bond0 -> vlanx -> ethx # bond0 -> ethx | vlanx -> -- Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-09ipv6: fix ICMP6_MIB_OUTERRORSEric Dumazet
In commit 1f8438a85366 (icmp: Account for ICMP out errors), I did a typo on IPV6 side, using ICMP6_MIB_OUTMSGS instead of ICMP6_MIB_OUTERRORS Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-09Merge branch 'num_rx_queues' of git://kernel.ubuntu.com/rtg/net-2.6David S. Miller
2010-06-09caif: fix a couple range checksDan Carpenter
The extra ! character means that these conditions are always false. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-09net: Print num_rx_queues imbalance warning only when there are allocated queuesTim Gardner
BugLink: http://bugs.launchpad.net/bugs/591416 There are a number of network drivers (bridge, bonding, etc) that are not yet receive multi-queue enabled and use alloc_netdev(), so don't print a num_rx_queues imbalance warning in that case. Also, only print the warning once for those drivers that _are_ multi-queue enabled. Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com>
2010-06-09Merge branch 'master' of ↵David S. Miller
2010-06-09ipvs: Add missing locking during connection table hashing and unhashingSven Wegener
The code that hashes and unhashes connections from the connection table is missing locking of the connection being modified, which opens up a race condition and results in memory corruption when this race condition is hit. Here is what happens in pretty verbose form: CPU 0 CPU 1 ------------ ------------ An active connection is terminated and we schedule ip_vs_conn_expire() on this CPU to expire this connection. IRQ assignment is changed to this CPU, but the expire timer stays scheduled on the other CPU. New connection from same ip:port comes in right before the timer expires, we find the inactive connection in our connection table and get a reference to it. We proper lock the connection in tcp_state_transition() and read the connection flags in set_tcp_state(). ip_vs_conn_expire() gets called, we unhash the connection from our connection table and remove the hashed flag in ip_vs_conn_unhash(), without proper locking! While still holding proper locks we write the connection flags in set_tcp_state() and this sets the hashed flag again. ip_vs_conn_expire() fails to expire the connection, because the other CPU has incremented the reference count. We try to re-insert the connection into our connection table, but this fails in ip_vs_conn_hash(), because the hashed flag has been set by the other CPU. We re-schedule execution of ip_vs_conn_expire(). Now this connection has the hashed flag set, but isn't actually hashed in our connection table and has a dangling list_head. We drop the reference we held on the connection and schedule the expire timer for timeouting the connection on this CPU. Further packets won't be able to find this connection in our connection table. ip_vs_conn_expire() gets called again, we think it's already hashed, but the list_head is dangling and while removing the connection from our connection table we write to the memory location where this list_head points to. The result will probably be a kernel oops at some other point in time. This race condition is pretty subtle, but it can be triggered remotely. It needs the IRQ assignment change or another circumstance where packets coming from the same ip:port for the same service are being processed on different CPUs. And it involves hitting the exact time at which ip_vs_conn_expire() gets called. It can be avoided by making sure that all packets from one connection are always processed on the same CPU and can be made harder to exploit by changing the connection timeouts to some custom values. Signed-off-by: Sven Wegener <sven.wegener@stealer.net> Cc: stable@kernel.org Acked-by: Simon Horman <horms@verge.net.au> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-06-08mac80211: fix deauth before assocJohannes Berg
When we receive a deauthentication frame before having successfully associated, we neither print a message nor abort assocation. The former makes it hard to debug, while the latter later causes a warning in cfg80211 when, as will typically be the case, association timed out. This warning was reported by many, e.g. in https://bugzilla.kernel.org/show_bug.cgi?id=15981, but I couldn't initially pinpoint it. I verified the fix by hacking hostapd to send a deauth frame instead of an association response. Cc: stable@kernel.org Signed-off-by: Johannes Berg <johannes.berg@intel.com> Tested-by: Miles Lane <miles.lane@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-07mac80211: fix function pointer checkHolger Schurig
This makes "iw wlan0 dump survey" work again with mac80211-based drivers that support it, e.g. ath5k. Signed-off-by: Holger Schurig <holgerschurig@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-07ipmr: dont corrupt listsEric Dumazet
ipmr_rules_exit() and ip6mr_rules_exit() free a list of items, but forget to properly remove these items from list. List head is not changed and still points to freed memory. This can trigger a fault later when icmpv6_sk_exit() is called. Fix is to either reinit list, or use list_del() to properly remove items from list before freeing them. bugzilla report : https://bugzilla.kernel.org/show_bug.cgi?id=16120 Introduced by commit d1db275dd3f6e4 (ipv6: ip6mr: support multiple tables) and commit f0ad0860d01e (ipv4: ipmr: support multiple tables) Reported-by: Alex Zhavnerchik <alex.vizor@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-06ip6mr: fix a typo in ip6mr_for_each_table()Eric Dumazet
2010-06-05ipv6: avoid high order allocationsEric Dumazet
With mtu=9000, mld_newpack() use order-2 GFP_ATOMIC allocations, that are very unreliable, on machines where PAGE_SIZE=4K Limit allocated skbs to be at most one page. (order-0 allocations) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-04tcp: use correct net ns in cookie_v4_check()Eric Dumazet
Its better to make a route lookup in appropriate namespace. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-04rps: tcp: fix rps_sock_flow_table table updatesEric Dumazet
I believe a moderate SYN flood attack can corrupt RFS flow table (rps_sock_flow_table), making RPS/RFS much less effective. Even in a normal situation, server handling short lived sessions suffer from bad steering for the first data packet of a session, if another SYN packet is received for another session. We do following action in tcp_v4_rcv() : sock_rps_save_rxhash(sk, skb->rxhash); We should _not_ do this if sk is a LISTEN socket, as about each packet received on a LISTEN socket has a different rxhash than previous one. -> RPS_NO_CPU markers are spread all over rps_sock_flow_table. Also, it makes sense to protect sk->rxhash field changes with socket lock (We currently can change it even if user thread owns the lock and might use rxhash) This patch moves sock_rps_save_rxhash() to a sock locked section, and only for non LISTEN sockets. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-04syncookies: remove Kconfig text line about disabled-by-defaultFlorian Westphal
syncookies default to on since e994b7c901ded7200b525a707c6da71f2cf6d4bb (tcp: Don't make syn cookies initial setting depend on CONFIG_SYSCTL). Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-04net: check for refcount if pop a stacked dst_entrySteffen Klassert
xfrm triggers a warning if dst_pop() drops a refcount on a noref dst. This patch changes dst_pop() to skb_dst_pop(). skb_dst_pop() drops the refcnt only on a refcounted dst. Also we don't clone the child dst_entry, so it is not refcounted and we can use skb_dst_set_noref() in xfrm_output_one(). Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-04mac80211: process station blockack action frames from workJohannes Berg
Processing an association response could take a bit of time while we set up the hardware etc. During that time, the AP might already send a blockack request. If this happens very quickly on a fairly slow machine, we can end up processing the blockack request before the association processing has finished. Since the blockack processing cannot sleep right now, we also cannot make it wait in the driver. As a result, sometimes on slow machines the iwlagn driver gets totally confused, and no traffic can pass when the aggregation setup was done before the assoc setup completed. I'm working on a proper fix for this, which involves queuing all blockack category action frames from a work struct, and also allowing the ampdu_action driver callback to sleep, which will generally clean up the code and make things easier. However, this is a very involved and complex change. To fix the problem at hand in a way that can also be backported to stable, I've come up with this patch. Here, I simply process all aggregation action frames from the managed interface skb queue, which means their processing will be serialized with processing the association response, thereby fixing the problem. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Cc: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-03Merge branch 'master' of ↵David S. Miller
2010-06-03act_pedit: access skb->data safelyChangli Gao
access skb->data safely we should use skb_header_pointer() and skb_store_bits() to access skb->data to handle small or non-linear skbs. Signed-off-by: Changli Gao <xiaosuo@gmail.com> ---- net/sched/act_pedit.c | 24 ++++++++++++++---------- 1 file changed, 14 insertions(+), 10 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-02cls_u32: use skb_header_pointer() to dereference data safelyChangli Gao
use skb_header_pointer() to dereference data safely the original skb->data dereference isn't safe, as there isn't any skb->len or skb_is_nonlinear() check. skb_header_pointer() is used instead in this patch. And when the skb isn't long enough, we terminate the function u32_classify() immediately with -1. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-02TCP: tcp_hybla: Fix integer overflow in slow start incrementDaniele Lacamera
For large values of rtt, 2^rho operation may overflow u32. Clamp down the increment to 2^16. Signed-off-by: Daniele Lacamera <root@danielinux.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-02act_nat: fix the wrong checksum when addr isn't in old_addr/maskChangli Gao
fix the wrong checksum when addr isn't in old_addr/mask For TCP and UDP packets, when addr isn't in old_addr/mask we don't do SNAT or DNAT, and we should not update layer 4 checksum. Signed-off-by: Changli Gao <xiaosuo@gmail.com> ---- net/sched/act_nat.c | 4 ++++ 1 file changed, 4 insertions(+) Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-02net: fix conflict between null_or_orig and null_or_bondJohn Fastabend
If a skb is received on an inactive bond that does not meet the special cases checked for by skb_bond_should_drop it should only be delivered to exact matches as the comment in netif_receive_skb() says. However because null_or_bond could also be null this is not always true. This patch renames null_or_bond to orig_or_bond and initializes it to orig_dev. This keeps the intent of null_or_bond to pass frames received on VLAN interfaces stacked on bonding interfaces without invalidating the statement for null_or_orig. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-02net: init_vlan should not copy slave or master flagsJohn Fastabend
The vlan device should not copy the slave or master flags from the real device. It is not in the bond until added nor is it a master. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-02xfrm: force a dst reference in __xfrm_route_forward()Eric Dumazet
Packets going through __xfrm_route_forward() have a not refcounted dst entry, since we enabled a noref forwarding path. xfrm_lookup() might incorrectly release this dst entry. It's a bit late to make invasive changes in xfrm_lookup(), so lets force a refcount in this path. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-01mac80211: fix dialog token allocatorJohannes Berg
The dialog token allocator has apparently been broken since b83f4e15 ("mac80211: fix deadlock in sta->lock") because it got moved out under the spinlock. Fix it. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-01mac80211: fix blockack-req processingJohannes Berg
Daniel reported that the paged RX changes had broken blockack request frame processing due to using data that wasn't really part of the skb data. Fix this using skb_copy_bits() for the needed data. As a side effect, this adds a check on processing too short frames, which previously this code could do. Reported-by: Daniel Halperin <dhalperi@cs.washington.edu> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Daniel Halperin <dhalperi@cs.washington.edu> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-05-31net/ipv4/tcp_input.c: fix compilation breakage when FASTRETRANS_DEBUG > 1Joe Perches
Commit: c720c7e8383aff1cb219bddf474ed89d850336e3 missed these. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-31Merge branch 'master' of ↵David S. Miller
2010-05-31net: sock_queue_err_skb() dont mess with sk_forward_allocEric Dumazet
Correct sk_forward_alloc handling for error_queue would need to use a backlog of frames that softirq handler could not deliver because socket is owned by user thread. Or extend backlog processing to be able to process normal and error packets. Another possibility is to not use mem charge for error queue, this is what I implemented in this patch. Note: this reverts commit 29030374 (net: fix sk_forward_alloc corruptions), since we dont need to lock socket anymore. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-31netfilter: xtables: stackptr should be percpuEric Dumazet
commit f3c5c1bfd4 (netfilter: xtables: make ip_tables reentrant) introduced a performance regression, because stackptr array is shared by all cpus, adding cache line ping pongs. (16 cpus share a 64 bytes cache line) Fix this using alloc_percpu() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-By: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-05-31netfilter: don't xt_jumpstack_alloc twice in xt_register_tableXiaotian Feng
In xt_register_table, xt_jumpstack_alloc is called first, later xt_replace_table is used. But in xt_replace_table, xt_jumpstack_alloc will be used again. Then the memory allocated by previous xt_jumpstack_alloc will be leaked. We can simply remove the previous xt_jumpstack_alloc because there aren't any users of newinfo between xt_jumpstack_alloc and xt_replace_table. Signed-off-by: Xiaotian Feng <dfeng@redhat.com> Cc: Patrick McHardy <kaber@trash.net> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jan Engelhardt <jengelh@medozas.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Alexey Dobriyan <adobriyan@gmail.com> Acked-By: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-05-31Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2010-05-29net: fix sk_forward_alloc corruptionsEric Dumazet
As David found out, sock_queue_err_skb() should be called with socket lock hold, or we risk sk_forward_alloc corruption, since we use non atomic operations to update this field. This patch adds bh_lock_sock()/bh_unlock_sock() pair to three spots. (BH already disabled) 1) skb_tstamp_tx() 2) Before calling ip_icmp_error(), in __udp4_lib_err() 3) Before calling ipv6_icmp_error(), in __udp6_lib_err() Reported-by: Anton Blanchard <anton@samba.org> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
