path: root/net
2008-08-19pkt_sched: Prevent livelock in TX queue running.David S. Miller
If dev_deactivate() is trying to quiesce the queue, it is theoretically possible for another cpu to livelock trying to process that queue. This happens because dev_deactivate() grabs the queue spinlock as it checks the queue state, whereas net_tx_action() does a trylock and reschedules the qdisc if it hits the lock. This breaks the livelock by adding a check on __QDISC_STATE_DEACTIVATED to net_tx_action() when the trylock fails. Based upon feedback from Herbert Xu and Jarek Poplawski. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-19Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/holtmann/bluetooth-2.6
2008-08-18Revert "pkt_sched: Add BH protection for qdisc_stab_lock."David S. Miller
This reverts commit 1cfa26661a85549063e369e2b40275eeaa7b923c. qdisc_destroy() runs fully under RTNL again and not from softint any longer, so this change is no longer needed. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-18Revert "pkt_sched: Protect gen estimators under est_lock."David S. Miller
This reverts commit d4766692e72422f3b0f0e9ac6773d92baad07d51. qdisc_destroy() now runs in RTNL fully again, so this change is no longer needed. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-18pkt_sched: remove bogus block (cleanup)Ilpo Järvinen
...Last block local var got just deleted. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-18nf_nat: use secure_ipv4_port_ephemeral() for NAT port randomizationStephen Hemminger
Use incoming network tuple as seed for NAT port randomization. This avoids concerns of leaking net_random() bits, and also gives better port distribution. Don't have NAT server, compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> [ added missing EXPORT_SYMBOL_GPL ] Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-18netfilter: ctnetlink: sleepable allocation with spin lock bhPablo Neira Ayuso
This patch removes a GFP_KERNEL allocation while holding a spin lock with bottom halves disabled in ctnetlink_change_helper(). This problem was introduced in 2.6.23 with the netfilter extension infrastructure. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-18netfilter: ctnetlink: fix sleep in read-side lock sectionPablo Neira Ayuso
Fix allocation with GFP_KERNEL in ctnetlink_create_conntrack() under read-side lock sections. This problem was introduced in 2.6.25. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-18netfilter: ctnetlink: fix double helper assignation for NAT'ed conntracksPablo Neira Ayuso
If we create a conntrack that has NAT handlings and a helper, the helper is assigned twice. This happens because nf_nat_setup_info() - via nf_conntrack_alter_reply() - sets the helper before ctnetlink, which indeed does not check if the conntrack already has a helper as it thinks that it is a brand new conntrack. The fix moves the helper assignation before the set of the status flags. This avoids a bogus assertion in __nf_ct_ext_add (if netfilter assertions are enabled) which checks that the conntrack must not be confirmed. This problem was introduced in 2.6.23 with the netfilter extension infrastructure. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-08-18netfilter: ipt_addrtype: Fix matching of inverted destination address typeAnders Grafström
This patch fixes matching of inverted destination address type. Signed-off-by: Anders Grafström <grfstrm@users.sourceforge.net> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-18Merge branch 'master' of ↵David S. Miller
2008-08-18dccp: Fix panic caused by too early termination of retransmission mechanismGerrit Renker
Thanks is due to Wei Yongjun for the detailed analysis and description of this bug at http://marc.info/?l=dccp&m=121739364909199&w=2 The problem is that invalid packets received by a client in state REQUEST cause the retransmission timer for the DCCP-Request to be reset. This includes freeing the Request-skb ( in dccp_rcv_request_sent_state_process() ). As a consequence, * the arrival of further packets cause a double-free, triggering a panic(), * the connection then may hang, since further retransmissions are blocked. This patch changes the order of statements so that the retransmission timer is reset, and the pending Request freed, only if a valid Response has arrived (or the number of sysctl-retries has been exhausted). Further changes: ---------------- To be on the safe side, replaced __kfree_skb with kfree_skb so that if due to unexpected circumstances the sk_send_head is NULL the WARN_ON is used instead. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-18pkt_sched: Don't hold qdisc lock over qdisc_destroy().David S. Miller
Based upon reports by Denys Fedoryshchenko, and feedback and help from Jarek Poplawski and Herbert Xu. We always either: 1) Never made an external reference to this qdisc. or 2) Did a dev_deactivate() which purged all asynchronous references. So do not lock the qdisc when we call qdisc_destroy(), it's illegal anyways as when we drop the lock this is free'd memory. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-18pkt_sched: Add lockdep annotation for qdisc locksJarek Poplawski
Qdisc locks are initialized in the same function, qdisc_alloc(), so lockdep can't distinguish tx qdisc lock from rx and reports "possible recursive locking detected" when both these locks are taken eg. while using act_mirred with ifb. This looks like a false positive. Anyway, after this patch these locks will be reported more exactly. Reported-by: Denys Fedoryshchenko <denys@visp.net.lb> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-18pkt_sched: Never schedule non-root qdiscs.David S. Miller
Based upon initial discovery and patch by Jarek Poplawski. The qdisc watchdogs can be attached to any qdisc, not just the root, so make sure we schedule the correct one. CBQ has a similar bug. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-18mac80211: update new sta's rx timestampRon Rindjunsky
This patch fixes needless probe request caused by zero value in sta->last_rx inside ieee80211_associated flow Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-18rfkill: protect suspended rfkill controllersHenrique de Moraes Holschuh
Guard rfkill controllers attached to a rfkill class against state changes after class suspend has been issued. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Acked-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-18[Bluetooth] Consolidate maintainers informationMarcel Holtmann
The Bluetooth entries for the MAINTAINERS file are a little bit too much. Consolidate them into two entries. One for Bluetooth drivers and another one for the Bluetooth subsystem. Also the MODULE_AUTHOR should indicate the current maintainer of the module and actually not the original author. Fix all Bluetooth modules to provide current maintainer information. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2008-08-18[Bluetooth] Fix userspace breakage due missing class linksMarcel Holtmann
The Bluetooth adapters and connections are best presented via a class in sysfs. The removal of the links inside the Bluetooth class broke assumptions by userspace programs on how to find attached adapters. This patch creates adapters and connections as part of the Bluetooth class, but it uses different device types to distinguish them. The userspace programs can now easily navigate in the sysfs device tree. The unused platform device and bus have been removed to keep the code simple and clean. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2008-08-18pkt_sched: Fix return value corruption in HTB and TBF.David S. Miller
Based upon a bug report by Josip Rodin. Packet schedulers should only return NET_XMIT_DROP iff the packet really was dropped. If the packet does reach the device after we return NET_XMIT_DROP then TCP can crash because it depends upon the enqueue path return values being accurate. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-17pkt_sched: Fix missed RCU unlock in dev_queue_xmit()David S. Miller
Noticed by Jarek Poplawski. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-17ipv6: Fix the return interface index when get it while no message is received.Yang Hongyang
When get receiving interface index while no message is received, the bounded device's index of the socket should be returned. RFC 3542: Issuing getsockopt() for the above options will return the sticky option value i.e., the value set with setsockopt(). If no sticky option value has been set getsockopt() will return the following values: - For the IPV6_PKTINFO option, it will return an in6_pktinfo structure with ipi6_addr being in6addr_any and ipi6_ifindex being zero. Signed-off-by: Yang Hongyang <yanghy@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-17sch_prio: Use NET_XMIT_SUCCESS instead of "0" constant.David S. Miller
2008-08-17sch_prio: Use return value from inner qdisc requeueJussi Kivilinna
Use return value from inner qdisc requeue when value returned isn't NET_XMIT_SUCCESS, instead of always returning NET_XMIT_DROP. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-17pkt_sched: No longer destroy qdiscs from RCU.David S. Miller
We can now kill them synchronously with all of the previous dev_deactivate() cures. This makes netdev destruction and shutdown saner as the qdiscs hold references to the device. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-17pkt_sched: Grab correct lock in notify_and_destroy().Jarek Poplawski
From: Jarek Poplawski <jarkao2@gmail.com> When we are destroying non-root qdiscs, we need to lock the root of the qdisc tree not the the qdisc itself. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-17pkt_sched: Simplify dev_deactivate() polling loop.David S. Miller
The condition under which the previous qdisc has no more references after we've attached &noop_qdisc is that both RUNNING and SCHED are both seen clear while holding the root lock. So just make specifically that check in the polling loop, instead of this overly complex "check without then check with lock held" sequence. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-17net: Change handling of the __QDISC_STATE_SCHED flag in net_tx_action().Jarek Poplawski
Change handling of the __QDISC_STATE_SCHED flag in net_tx_action() to enable proper control in dev_deactivate(). Now, if this flag is seen as unset under root_lock means a qdisc can't be netif_scheduled. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-17pkt_sched: Add 'deactivated' state.David S. Miller
This new state lets dev_deactivate() mark a qdisc as having been deactivated. dev_queue_xmit() and ing_filter() check for this bit and do not try to process the qdisc if the bit is set. dev_deactivate() polls the qdisc after setting the bit, waiting for both __QDISC_STATE_RUNNING and __QDISC_STATE_SCHED to clear. This isn't perfect yet, but subsequent changesets will make it so. This part is just one piece of the puzzle. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-15net: skb_copy_datagram_from_iovec()Rusty Russell
There's an skb_copy_datagram_iovec() to copy out of a paged skb, but nothing the other way around (because we don't do that). We want to allocate big skbs in tun.c, so let's add the function. It's a carbon copy of skb_copy_datagram_iovec() with enough changes to be annoying. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-15net: Preserve netfilter attributes in skb_gso_segment using __copy_skb_headerHerbert Xu
skb_gso_segment didn't preserve some attributes in the original skb such as the netfilter fields. This was harmless until they were used which is the case for packets going through lo. This patch makes it call __copy_skb_header which also picks up some other missing attributes. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-15bridge: show offload settingsStephen Hemminger
Add more ethtool generic operations to dump the bridge offload settings. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-15ipv4: Disable route secret interval on zero intervalHerbert Xu
Let me first state that disabling the route cache hash rebuild should not be done without extensive analysis on the risk profile and careful deliberation. However, there are times when this can be done safely or for testing. For example, when you have mechanisms for ensuring that offending parties do not exist in your network. This patch lets the user disable the rebuild if the interval is set to zero. This also incidentally fixes a divide-by-zero error with name-spaces. In addition, this patch makes the effect of an interval change immediate rather than it taking effect at the next rebuild as is currently the case. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-14pkt_sched: Fix unlocking in tc_ctl_tfilter()Jarek Poplawski
Fix a bug with spin_lock_bh() inserted instead of spin_unlock_bh() by some recent patch. Reported-by: Denys Fedoryshchenko <denys@visp.net.lb> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-14netns: Add network namespace argument to rt6_fill_node() and ↵Brian Haley
ipv6_dev_get_saddr() ipv6_dev_get_saddr() blindly de-references dst_dev to get the network namespace, but some callers might pass NULL. Change callers to pass a namespace pointer instead. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-13netns: Fix crash by making igmp per namespaceDaniel Lezcano
This patch makes the multicast socket to be per namespace. When a network namespace is created, other than the init_net and a multicast packet is received, the kernel goes to a hang or a kernel panic. How to reproduce ? * create a child network namespace * create a pair virtual device veth * ip link add type veth * move one side to the pair network device to the child namespace * ip link set netns <childpid> dev veth1 * ping -I veth0 224.0.0.1 The bug appears because the function ip_mc_init_dev does not initialize the different multicast fields as it exits because it is not the init_net. BUG: soft lockup - CPU#0 stuck for 61s! [avahi-daemon:2695] Modules linked in: irq event stamp: 50350 hardirqs last enabled at (50349): [<c03ee949>] _spin_unlock_irqrestore+0x34/0x39 hardirqs last disabled at (50350): [<c03ec639>] schedule+0x9f/0x5ff softirqs last enabled at (45712): [<c0374d4b>] ip_setsockopt+0x8e7/0x909 softirqs last disabled at (45710): [<c03ee682>] _spin_lock_bh+0x8/0x27 Pid: 2695, comm: avahi-daemon Not tainted (2.6.27-rc2-00029-g0872073 #3) EIP: 0060:[<c03ee47c>] EFLAGS: 00000297 CPU: 0 EIP is at __read_lock_failed+0x8/0x10 EAX: c4f38810 EBX: c4f38810 ECX: 00000000 EDX: c04cc22e ESI: fb0000e0 EDI: 00000011 EBP: 0f02000a ESP: c4e3faa0 DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 CR0: 8005003b CR2: 44618a40 CR3: 04e37000 CR4: 000006d0 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 DR6: ffff0ff0 DR7: 00000400 [<c02311f8>] ? _raw_read_lock+0x23/0x25 [<c0390666>] ? ip_check_mc+0x1c/0x83 [<c036d478>] ? ip_route_input+0x229/0xe92 [<c022e2e4>] ? trace_hardirqs_on_thunk+0xc/0x10 [<c0104c9c>] ? do_IRQ+0x69/0x7d [<c0102e64>] ? restore_nocheck_notrace+0x0/0xe [<c036fdba>] ? ip_rcv+0x227/0x505 [<c0358764>] ? netif_receive_skb+0xfe/0x2b3 [<c03588d2>] ? netif_receive_skb+0x26c/0x2b3 [<c035af31>] ? process_backlog+0x73/0xbd [<c035a8cd>] ? net_rx_action+0xc1/0x1ae [<c01218a8>] ? __do_softirq+0x7b/0xef [<c0121953>] ? do_softirq+0x37/0x4d [<c035b50d>] ? dev_queue_xmit+0x3d4/0x40b [<c0122037>] ? local_bh_enable+0x96/0xab [<c035b50d>] ? dev_queue_xmit+0x3d4/0x40b [<c012181e>] ? _local_bh_enable+0x79/0x88 [<c035fcb8>] ? neigh_resolve_output+0x20f/0x239 [<c0373118>] ? ip_finish_output+0x1df/0x209 [<c0373364>] ? ip_dev_loopback_xmit+0x62/0x66 [<c0371db5>] ? ip_local_out+0x15/0x17 [<c0372013>] ? ip_push_pending_frames+0x25c/0x2bb [<c03891b8>] ? udp_push_pending_frames+0x2bb/0x30e [<c038a189>] ? udp_sendmsg+0x413/0x51d [<c038a1a9>] ? udp_sendmsg+0x433/0x51d [<c038f927>] ? inet_sendmsg+0x35/0x3f [<c034f092>] ? sock_sendmsg+0xb8/0xd1 [<c012d554>] ? autoremove_wake_function+0x0/0x2b [<c022e6de>] ? copy_from_user+0x32/0x5e [<c022e6de>] ? copy_from_user+0x32/0x5e [<c034f238>] ? sys_sendmsg+0x18d/0x1f0 [<c0175e90>] ? pipe_write+0x3cb/0x3d7 [<c0170347>] ? do_sync_write+0xbe/0x105 [<c012d554>] ? autoremove_wake_function+0x0/0x2b [<c03503b2>] ? sys_socketcall+0x176/0x1b0 [<c01085ea>] ? syscall_trace_enter+0x6c/0x7b [<c0102e1a>] ? syscall_call+0x7/0xb Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-13pkt_sched: Protect gen estimators under est_lock.Jarek Poplawski
gen_kill_estimator() required rtnl_lock() protection, but since it is moved to an RCU callback __qdisc_destroy() let's use est_lock instead. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-13pkt_sched: Fix queue quiescence testing in dev_deactivate().David S. Miller
Based upon discussions with Jarek P. and Herbert Xu. First, we're testing the wrong qdisc. We just reset the device queue qdiscs to &noop_qdisc and checking it's state is completely pointless here. We want to wait until the previous qdisc that was sitting at the ->qdisc pointer is not busy any more. And that would be ->qdisc_sleeping. Because of how we propagate the samples qdisc pointer down into qdisc_run and friends via per-cpu ->output_queue and netif_schedule, we have to wait also for the __QDISC_STATE_SCHED bit to clear as well. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-13pkt_sched: Fix oops in htb_delete.Jarek Poplawski
Recent changes introduced a bug in htb_delete(): cl->parent->children counter update misses checking cl->parent for NULL, which is used for root classes, so deleting them causes an oops. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-13pktgen: prevent pktgen from using bad tx queueAndrew Gallatin
With the new multi-queue transmit code, it is possible to accidentally make pktgen pick a non-existing tx queue simply by using a stale script to drive pktgen. Access to this non-existing tx queue will then trigger a bad memory access and kill the machine. For example, setting "queue_map_max 2" will cause my machine to die when accessing a garbage spinlock in the non-existing tx queue: BUG: spinlock bad magic on CPU#0, kpktgend_0/564 lock: ffff88001ddf6718, .magic: ffffffff, .owner: /-1, .owner_cpu: 0 Pid: 564, comm: kpktgend_0 Not tainted 2.6.27-rc3 #35 Call Trace: [<ffffffff803a1228>] spin_bug+0xa4/0xac [<ffffffff803a1253>] _raw_spin_lock+0x23/0x123 [<ffffffff8055b06f>] _spin_lock_bh+0x17/0x1b [<ffffffff804cb57d>] pktgen_thread_worker+0xa97/0x1002 [<ffffffff8022874d>] ? finish_task_switch+0x38/0x97 [<ffffffff80242077>] ? autoremove_wake_function+0x0/0x36 [<ffffffff80242077>] ? autoremove_wake_function+0x0/0x36 [<ffffffff804caae6>] ? pktgen_thread_worker+0x0/0x1002 [<ffffffff80241a40>] kthread+0x44/0x6d [<ffffffff8020c399>] child_rip+0xa/0x11 [<ffffffff802419fc>] ? kthread+0x0/0x6d [<ffffffff8020c38f>] ? child_rip+0x0/0x11 The attached patch adds some sanity checking to prevent these sorts of configuration errors. Signed-off-by: Andrew Gallatin <gallatin@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-13dccp: change L/R must have at least one byte in the dccpsf_val fieldArnaldo Carvalho de Melo
Thanks to Eugene Teo for reporting this problem. Signed-off-by: Eugene Teo <eugenete@kernel.sg> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-13xfrm: remove unnecessary variable in xfrm_output_resume() 2nd tryJean-Christophe DUBOIS
Small fix removing an unnecessary intermediate variable. Signed-off-by: Jean-Christophe DUBOIS <jcd@tribudubois.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-13net-sched: fix Action flushing return codeJamal Hadi Salim
Flushing must consistently return ENOMEM on failure of any allocation Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-13net-sched: Fix actions flushingJamal Hadi Salim
Flushing of actions has been broken since we changed the semantics of netlink parsed tb[X] to mean X is an attribute type. This makes the flushing work. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-13net/rxrpc: Use an IS_ERR test rather than a NULL testJulien Brunel
In case of error, the function rxrpc_get_transport returns an ERR pointer, but never returns a NULL pointer. So after a call to this function, a NULL test should be replaced by an IS_ERR test. A simplified version of the semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @correct_null_test@ expression x,E; statement S1, S2; @@ x = rxrpc_get_transport(...) <... when != x = E if ( ( - x@p2 != NULL + ! IS_ERR ( x ) | - x@p2 == NULL + IS_ERR( x ) ) ) S1 else S2 ...> ? x = E; // </smpl> Signed-off-by: Julien Brunel <brunel@diku.dk> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-13wext: Send name on eventsJamal Hadi Salim
In the minimal the wireless extensions oughta send at least the name in addition to the ifindex. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-13net/tipc/subscr.c: don't use ___constant_swab32Andrew Morton
It's an internal implementation detail which we _should_ be free to change. So we did, and it promptly broke. The compiler shold be able to work out when to use the __constant version anyway. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-13ipv6: Fix OOPS, ip -f inet6 route get fec0::1, linux-2.6.26, ↵Brian Haley
ip6_route_output, rt6_fill_node+0x175 Alexey Dobriyan wrote: > On Thu, Aug 07, 2008 at 07:00:56PM +0200, John Gumb wrote: >> Scenario: no ipv6 default route set. > >> # ip -f inet6 route get fec0::1 >> >> BUG: unable to handle kernel NULL pointer dereference at 00000000 >> IP: [<c0369b85>] rt6_fill_node+0x175/0x3b0 >> EIP is at rt6_fill_node+0x175/0x3b0 > > 0xffffffff80424dd3 is in rt6_fill_node (net/ipv6/route.c:2191). > 2186 } else > 2187 #endif > 2188 NLA_PUT_U32(skb, RTA_IIF, iif); > 2189 } else if (dst) { > 2190 struct in6_addr saddr_buf; > 2191 ====> if (ipv6_dev_get_saddr(ip6_dst_idev(&rt->u.dst)->dev, > ^^^^^^^^^^^^^^^^^^^^^^^^ > NULL > > 2192 dst, 0, &saddr_buf) == 0) > 2193 NLA_PUT(skb, RTA_PREFSRC, 16, &saddr_buf); > 2194 } The commit that changed this can't be reverted easily, but the patch below works for me. Fix NULL de-reference in rt6_fill_node() when there's no IPv6 input device present in the dst entry. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-11pkt_sched: Add BH protection for qdisc_stab_lock.Jarek Poplawski
Since qdisc_stab_lock is used in qdisc_put_stab(), which is called in BH context from __qdisc_destroy() RCU callback, softirq safe locking is needed. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-11Merge branch 'stealer/ipvs/for-davem' of git://git.stealer.net/linux-2.6David S. Miller
