Back when the original NetLabel patches were being changed to use Netlink
attributes correctly some code was accidentially dropped which set all of the
undefined CIPSOv4 level and category mappings to a sentinel value. The result
is the mappings data in the kernel contains bogus mappings which always map to
zero. Having level and category mappings that map to zero could result in the
kernel assigning incorrect security attributes to packets.
This patch restores the old/correct behavior by initializing the mapping
data to the correct sentinel value.
Signed-off-by: Paul Moore <paul.moore@hp.com>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
It is important that we only assign dev->ip{,6}_ptr
only after all portions of the inet{,6} are setup.
Otherwise we can receive packets before the multicast
spinlocks et al. are initialized.
Signed-off-by: David L Stevens <dlstevens@us.ibm.com>
We cannot compute the gap until we know we have a 'struct ebt_entry'
and not 'struct ebt_entries'. Failure to check can cause crash.
Tested-by: Santiago Garcia Mantinan <manty@manty.net>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Acked-by: Patrick McHardy <kaber@trash.net>
Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com>
In 2.6.19 a deauthentication from the AP doesn't start a
reassociation by the softmac code. It appears that
mac->associnfo.associating must be set and the
ieee80211softmac_assoc_work function must be scheduled. This patch
fixes that.
Signed-off-by: Ulrich Kunitz <kune@deine-taler.de>
When this code was converted to use sk_for_each() the
logic for the "best hash chain length" code was reversed,
breaking everything.
The original code was of the form:
size = 0;
do {
if (++size >= best_size_so_far)
goto next;
} while ((sk = sk->next) != NULL);
best_size_so_far = size;
best = result;
next:;
and this got converted into:
sk_for_each(sk2, node, head)
if (++size < best_size_so_far) {
best = result;
Which does something very very different from the original.
With malformed packets it might be possible to overwrite internal
CMTP and CAPI data structures. This patch adds additional length
checks to prevent these kinds of remote attacks.
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
ieee80211softmac_wx_get_genie locks the associnfo mutex at
function exit. This patch fixes it. The patch is against Linus'
tree (commit af1713e0).
Signed-off-by: Michael Buesch <mb@bu3sch.de>
We must reserve SAR + MAX_HEADER bytes for IrLMP to fit in.
This fixes an oops reported (and fixed) by Jeet Chaudhuri, when max_sdu_size
is greater than 0.
Signed-off-by: Samuel Ortiz <samuel@sortiz.org>
We grab a reference to the route's inetpeer entry but
forget to release it in xfrm4_dst_destroy().
Bug discovered by Kazunori MIYAZAWA <kazunori@miyazawa.org>
Currently the behaviour of disable_xfrm is inconsistent between
locally generated and forwarded packets. For locally generated
packets disable_xfrm disables the policy lookup if it is set on
the output device, for forwarded traffic however it looks at the
input device. This makes it impossible to disable xfrm on all
devices but a dummy device and use normal routing to direct
traffic to that device.
Always use the output device when checking disable_xfrm.
ieee80211softmac_wx_set_mlme
Routine ieee80211softmac_wx_set_mlme has one return that fails
to release a mutex acquired at entry.
Signed-off-by: Maxime Austruy <maxime@tralhalla.org>
The attached patch resolves an issue where a IP DNATed packet with a
martian source is forwarded while it's better to drop it. It also
resolves messages complaining about ip forwarding being disabled while
it's actually enabled. Thanks to lepton <ytht.net@gmail.com> for
reporting this problem.
This is probably a candidate for the -stable release.
Signed-off-by: Bart De Schuymer <bdschuym@pandora.be>
In compat mode, matches and targets valid hooks checks always successful due
to not initialized e->comefrom field yet. This patch separates this checks from
translation code and moves them after mark_source_chains() call, where these
marks are initialized.
Signed-off-by: Dmitry Mishin <dim@openvz.org>
Signed-off-by; Patrick McHardy <kaber@trash.net>
Commit 590bdf7fd2292b47c428111cb1360e312eff207e introduced a regression
in match/target hook validation. mark_source_chains builds a bitmask
for each rule representing the hooks it can be reached from, which is
then used by the matches and targets to make sure they are only called
from valid hooks. The patch moved the match/target specific validation
before the mark_source_chains call, at which point the mask is always zero.
This patch returns back to the old order and moves the standard checks
to mark_source_chains. This allows to get rid of a special case for
standard targets as a nice side-effect.
Not returning -EINVAL, because someone might want to use the value
zero in some future gact_prob algorithm?
Signed-off-by: Kim Nordlund <kim.nordlund@nokia.com>
The tc actions increased the size of struct tc_police, which broke
compatibility with old iproute binaries since both the act_police
and the old NET_CLS_POLICE code check for an exact size match.
Since the new members are not even used, the simple fix is to also
accept the size of the old structure. Dumping is not affected since
old userspace will receive a bigger structure, which is handled fine.
Acked-by: Jamal Hadi Salim <hadi@cyberus.ca>
No need to revisit a chain we'd already finished with during
the check for current hook. It's either instant loop (which
we'd just detected) or a duplicate work.
We need that for iterator to work; existing check had been too weak.
We need to verify that
a) we are not too close to the end of buffer to dereference
b) next entry we'll be checking won't be _before_ our
While we are at it, don't subtract unrelated pointers...
In the scan section of ieee80211softmac, network transmits are disabled.
When SoftMAC re-enables transmits, it may override the wishes of a driver
that may have very good reasons for disabling transmits. At least one failure
in bcm43xx can be traced to this problem. In addition, several unexplained
problems may arise from the unexpected enabling of transmits.
MAX_HEADER does not include the ipv6 header length in it,
so we need to add it in explicitly.
With help from YOSHIFUJI Hideaki.
On devices with hard_header_len > LL_MAX_HEADER ip_route_me_harder()
reallocates the skb, leading to memory corruption when using the stale
tcph pointer to update the checksum.
All users of __{ip,nf}_conntrack_expect_find() don't expect that
it increments the reference count of expectation.
Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp>
When NFA_NEST exceeds the skb size the protocol reference is leaked.
The found helper cannot be assigned to conntrack after unlocking
nf_conntrack_lock. This tries to find helper to assign again.
This fixes the bug which doesn't assign helper to newly created
conntrack via nf_conntrack_netlink.
Make sure to properly clamp maxnum to avoid overflow
Acked-by: Eugene Teo <eteo@redhat.com>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
When application uses XFRM_MSG_GETSA to get state entry through
netlink socket and kernel has no matching one, the application expects
reply message with error status by kernel.
Kernel doesn't send the message back in the case of Mobile IPv6 route
optimization protocols (i.e. routing header or destination options
header). This is caused by incorrect return code "0" from
net/xfrm/xfrm_user.c(xfrm_user_state_lookup) and it makes kernel skip
to acknowledge at net/netlink/af_netlink.c(netlink_rcv_skb).
This patch fix to reply ESRCH to application.
Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org>
Signed-off-by: TAKAMIYA Noriaki <takamiya@po.ntts.co.jp>
The return value of kfifo_alloc() should be checked by IS_ERR().
Make udp_encap_rcv use pskb_may_pull
IPsec with NAT-T breaks on some notebooks using the latest e1000 chipset,
when header split is enabled. When receiving sufficiently large packets, the
driver puts everything up to and including the UDP header into the header
portion of the skb, and the rest goes into the paged part. udp_encap_rcv
forgets to use pskb_may_pull, and fails to decapsulate it. Instead, it
passes it up it to the IKE daemon.
Signed-off-by: Olaf Kirch <okir@suse.de>
Signed-off-by: Jean Delvare <jdelvare@suse.de>
H.323 connection tracking code calls ip_ct_refresh_acct() when
processing RCFs and URQs but passes NULL as the skb.
When CONFIG_IP_NF_CT_ACCT is enabled, the connection tracking core tries
to derefence the skb, which results in an obvious panic.
A similar fix was applied on the SIP connection tracking code some time
ago.
Signed-off-by: Faidon Liambotis <paravoid@debian.org>
scoping architecture.
TCP and RAW do not have this issue. Closes Bug #7432.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
On Sat, 2006-11-18 at 16:12 +0300, Andrey Borzenkov wrote:
> [ INFO: possible recursive locking detected ]
> 2.6.19-rc5-2avb #2
> pppd/26425 is trying to acquire lock:
> (&hashbin->hb_spinlock){....}, at: [<dfdea87a>] irlmp_slsap_inuse+0x5a/0x170
> [irda]
> but task is already holding lock:
> (&hashbin->hb_spinlock){....}, at: [<dfdea857>] irlmp_slsap_inuse+0x37/0x170
> [irda]
> other info that might help us debug this:
> 1 lock held by pppd/26425:
> #0: (&hashbin->hb_spinlock){....}, at: [<dfdea857>]
> irlmp_slsap_inuse+0x37/0x170 [irda]
> stack backtrace:
> [<c010413c>] dump_trace+0x1cc/0x200
> [<c010418a>] show_trace_log_lvl+0x1a/0x30
> [<c01047f2>] show_trace+0x12/0x20
> [<c01048c9>] dump_stack+0x19/0x20
> [<c01346ca>] __lock_acquire+0x8fa/0xc20
> [<c0134d2d>] lock_acquire+0x5d/0x80
> [<c02a851c>] _spin_lock+0x2c/0x40
> [<dfdea87a>] irlmp_slsap_inuse+0x5a/0x170 [irda]
> [<dfdebab2>] irlmp_open_lsap+0x62/0x180 [irda]
> [<dfdf35d1>] irttp_open_tsap+0x181/0x230 [irda]
> [<dfdc0c3d>] ircomm_open_tsap+0x5d/0xa0 [ircomm]
> [<dfdc05d8>] ircomm_open+0xb8/0xd0 [ircomm]
> [<dfdd0477>] ircomm_tty_open+0x4f7/0x570 [ircomm_tty]
> [<c020bbe4>] tty_open+0x174/0x340
> [<c016bd69>] chrdev_open+0x89/0x170
> [<c0167bd6>] __dentry_open+0xa6/0x1d0
> [<c0167da5>] nameidata_to_filp+0x35/0x40
> [<c0167df9>] do_filp_open+0x49/0x50
> [<c0167e47>] do_sys_open+0x47/0xd0
> [<c0167f0c>] sys_open+0x1c/0x20
> [<c010307d>] sysenter_past_esp+0x56/0x8d
> [<b7f86410>] 0xb7f86410
The comment at the nesting lock says:
/* Careful for priority inversions here !
* irlmp->links is never taken while another IrDA
* spinlock is held, so we are safe. Jean II */
So, under the assumption the author was right, it just needs a lockdep
annotation.
The "u16 *" derefs of skb->data need to be wrapped inside of
a get_unaligned().
Thanks to Gustavo Zacarias for the bug report.
I actually dont have a test case for these; i just found them by
inspection. Refer to patch "[XFRM]: Sub-policies broke policy events"
for more info
Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca>
Acked-by: Masahide NAKAMURA <nakam@linux-ipv6.org>
XFRM policy events are broken when sub-policy feature is turned on.
A simple test to verify this:
run ip xfrm mon on one window and add then delete a policy on another
window ..
Any L2CAP connection in disconnecting state shall not response
to any further config requests from the remote side. So in case
such a request is received, ignore it.
Signed-off-by: Ville Tervo <ville.tervo@nokia.com>
When sending a positive config response it shall include the actual
MTU to be used on this channel. This differs from the Bluetooth 1.1
specification where it was enough to acknowledge the config request.
If the RFCOMM session is no longer attached to the TTY device, then it
makes no sense to go through with changing the termios settings.
After an inquiry completed or got canceled the Bluetooth core should
check for any pending connect attempts.
To receive uvents for the low-level ACL and SCO links, they must be
assigned to a subsystem. It is enough to attach them to the already
established Bluetooth bus.
RFC4191 explicitly states that the procedures are applicable to
hosts only. We should not have changed behavior of routers.
Only routers in "FAILED" state should be considered unreachable.
Otherwise, we do not try to use speicific routes unless all least specific
routers are considered unreachable.
Fix up tcp_mem initial settings to take into account the size of the
hash entries (different on SMP and non-SMP systems).
Signed-off-by: John Heffner <jheffner@psc.edu>
nexthdr is NEXTHDR_FRAGMENT, the nexthdr value from the fragment header
is hp->nexthdr.
