nf_ct_frag6_gather()
upstream commit: b9c698964614f71b9c8afeca163a945b4c2e2d20
[ 63.531438] =================================
[ 63.531520] [ INFO: inconsistent lock state ]
[ 63.531520] 2.6.26-rc4 #7
[ 63.531520] ---------------------------------
[ 63.531520] inconsistent {softirq-on-W} -> {in-softirq-W} usage.
[ 63.531520] tcpsic6/3864 [HC0[0]:SC1[1]:HE1:SE0] takes:
[ 63.531520] (&q->lock#2){-+..}, at: [<c07175b0>] ipv6_frag_rcv+0xd0/0xbd0
[ 63.531520] {softirq-on-W} state was registered at:
[ 63.531520] [<c0143bba>] __lock_acquire+0x3aa/0x1080
[ 63.531520] [<c0144906>] lock_acquire+0x76/0xa0
[ 63.531520] [<c07a8f0b>] _spin_lock+0x2b/0x40
[ 63.531520] [<c0727636>] nf_ct_frag6_gather+0x3f6/0x910
According to this and another similar lockdep report inet_fragment
locks are taken from nf_ct_frag6_gather() with softirqs enabled, but
these locks are mainly used in softirq context, so disabling BHs is
necessary.
Reported-and-tested-by: Eric Sesterhenn <snakebyte@gmx.de>
Signed-off-by: Jarek Poplawski <jarkao2@gmail.com>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
ESTABLISHED state
upstream commit: d2ee3f2c4b1db1320c1efb4dcaceeaf6c7e6c2d3
In xt_connlimit match module, the counter of an IP is decreased when
the TCP packet is go through the chain with ip_conntrack state TW.
Well, it's very natural that the server and client close the socket
with FIN packet. But when the client/server close the socket with RST
packet(using so_linger), the counter for this connection still exsit.
The following patch can fix it which is based on linux-2.6.25.4
Signed-off-by: Dong Wei <dwei.zh@gmail.com>
Acked-by: Jan Engelhardt <jengelh@medozas.de>
nf_conntrack_expect_init()
upstream commit: 12293bf91126ad253a25e2840b307fdc7c2754c3
Signed-off-by: Alexey Dobriyan <adobriyan@parallels.com>
upstream commit: 01b7a314291b2ef56ad718ee1374a1bac4768b29
Using iptables 1.3.8 with kernel 2.6.25, rules which include '-m
iprange' don't automatically pull in xt_iprange module. Below patch
adds module aliases to fix that. Patch against latest -git, but seems
like a good candidate for -stable also.
Signed-off-by: Phil Oester <kernel@linuxace.com>
upstream commit: ddb2c43594f22843e9f3153da151deaba1a834c5
- Don't trust a length which is greater than the working buffer.
An invalid length could cause overflow when calculating buffer size
for decoding oid.
- An oid length of zero is invalid and allows for an off-by-one error when
decoding oid because the first subid actually encodes first 2 subids.
- A primitive encoding may not have an indefinite length.
Thanks to Wei Wang from McAfee for report.
Cc: Steven French <sfrench@us.ibm.com>
Cc: stable@kernel.org
Acked-by: Patrick McHardy <kaber@trash.net>
[NETFILTER]: {nfnetlink,ip,ip6}_queue: fix skb_over_panic when enlarging packets
Upstream commit 9a732ed6d:
While reinjecting *bigger* modified versions of IPv6 packets using
libnetfilter_queue, things work fine on a 2.6.24 kernel (2.6.22 too)
but I get the following on recents kernels (2.6.25, trace below is
against today's net-2.6 git tree):
skb_over_panic: text:c04fddb0 len:696 put:632 head:f7592c00 data:f7592c00 tail:0xf7592eb8 end:0xf7592e80 dev:eth0
invalid opcode: 0000 [#1] PREEMPT
Process sendd (pid: 3657, ti=f6014000 task=f77c31d0 task.ti=f6014000)
Stack: c071e638 c04fddb0 000002b8 00000278 f7592c00 f7592c00 f7592eb8 f7592e80
f763c000 f6bc5200 f7592c40 f6015c34 c04cdbfc f6bc5200 00000278 f6015c60
c04fddb0 00000020 f72a10c0 f751b420 00000001 0000000a 000002b8 c065582c
Call Trace:
[<c04fddb0>] ? nfqnl_recv_verdict+0x1c0/0x2e0
[<c04cdbfc>] ? skb_put+0x3c/0x40
[<c04fd115>] ? nfnetlink_rcv_msg+0xf5/0x160
[<c04fd03e>] ? nfnetlink_rcv_msg+0x1e/0x160
[<c04fd020>] ? nfnetlink_rcv_msg+0x0/0x160
[<c04f8ed7>] ? netlink_rcv_skb+0x77/0xa0
[<c04fcefc>] ? nfnetlink_rcv+0x1c/0x30
[<c04f8c73>] ? netlink_unicast+0x243/0x2b0
[<c04cfaba>] ? memcpy_fromiovec+0x4a/0x70
[<c04f9406>] ? netlink_sendmsg+0x1c6/0x270
[<c04c8244>] ? sock_sendmsg+0xc4/0xf0
[<c011970d>] ? set_next_entity+0x1d/0x50
[<c0133a80>] ? autoremove_wake_function+0x0/0x40
[<c0118f9e>] ? __wake_up_common+0x3e/0x70
[<c0342fbf>] ? n_tty_receive_buf+0x34f/0x1280
[<c011d308>] ? __wake_up+0x68/0x70
[<c02cea47>] ? copy_from_user+0x37/0x70
[<c04cfd7c>] ? verify_iovec+0x2c/0x90
[<c04c837a>] ? sys_sendmsg+0x10a/0x230
[<c011967a>] ? __dequeue_entity+0x2a/0xa0
[<c0345397>] ? pty_write+0x47/0x60
[<c033d59b>] ? tty_default_put_char+0x1b/0x20
[<c011d2e9>] ? __wake_up+0x49/0x70
[<c033df99>] ? tty_ldisc_deref+0x39/0x90
[<c033ff20>] ? tty_write+0x1a0/0x1b0
[<c04c93af>] ? sys_socketcall+0x7f/0x260
[<c0102ff9>] ? sysenter_past_esp+0x6a/0x91
[<c05f0000>] ? snd_intel8x0m_probe+0x270/0x6e0
Code: 00 00 89 5c 24 14 8b 98 9c 00 00 00 89 54 24 0c 89 5c 24 10 8b 40 50 89 4c 24 04 c7 04 24 38 e6 71 c0 89 44 24 08 e8 c4 46 c5 ff <0f> 0b eb fe 55 89 e5 56 89 d6 53 89 c3 83 ec 0c 8b 40 50 39 d0
EIP: [<c04ccdfc>] skb_over_panic+0x5c/0x60 SS:ESP 0068:f6015bf8
Looking at the code, I ended up in nfq_mangle() function (called by
nfqnl_recv_verdict()) which performs a call to skb_copy_expand() due to
the increased size of data passed to the function. AFAICT, it should ask
for 'diff' instead of 'diff - skb_tailroom(e->skb)'. Because the
resulting sk_buff has not enough space to support the skb_put(skb, diff)
call a few lines later, this results in the call to skb_over_panic().
The patch below asks for allocation of a copy with enough space for
mangled packet and the same amount of headroom as old sk_buff. While
looking at how the regression appeared (e2b58a67), I noticed the same
pattern in ipq_mangle_ipv6() and ipq_mangle_ipv4(). The patch corrects
those locations too.
Tested with bigger reinjected IPv6 packets (nfqnl_mangle() path), things
are ok (2.6.25 and today's net-2.6 git tree).
Signed-off-by: Arnaud Ebalard <arno@natisbad.org>
[NETFILTER]: nf_conntrack: padding breaks conntrack hash on ARM
Upstream commit 443a70d50:
commit 0794935e "[NETFILTER]: nf_conntrack: optimize hash_conntrack()"
results in ARM platforms hashing uninitialised padding. This padding
doesn't exist on other architectures.
Fix this by replacing NF_CT_TUPLE_U_BLANK() with memset() to ensure
everything is initialised. There were only 4 bytes that
NF_CT_TUPLE_U_BLANK() wasn't clearing anyway (or 12 bytes on ARM).
Signed-off-by: Philip Craig <philipc@snapgear.com>
[ Upstream commit: c2ab7ac225e29006b7117d6a9fe8f3be8d98b0c2 ]
The tx packet counting and the local loopback of CAN frames should
only happen in the case that the CAN frame has been enqueued to the
netdevice tx queue successfully.
Thanks to Andre Naujoks <nautsch@gmail.com> for reporting this issue.
Signed-off-by: Oliver Hartkopp <oliver@hartkopp.net>
Signed-off-by: Urs Thuermann <urs@isnogud.escape.de>
[ Upstream commit: 19443178fbfbf40db15c86012fc37df1a44ab857 ]
dccp_feat_change() validates length and on error is returning 1.
This happens to work since call chain is checking for 0 == success,
but this is returned to userspace, so make it a real error value.
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
[ Upstream commit: 2ad17defd596ca7e8ba782d5fc6950ee0e99513c ]
Fixes bug http://bugzilla.kernel.org/show_bug.cgi?id=10556
where conn templates with protocol=IPPROTO_IP can oops backup box.
Result from ip_vs_proto_get() should be checked because
protocol value can be invalid or unsupported in backup. But
for valid message we should not fail for templates which use
IPPROTO_IP. Also, add checks to validate message limits and
connection state. Show state NONE for templates using IPPROTO_IP.
Fix tested and confirmed by L0op8ack <l0op8ack@hotmail.com>
Signed-off-by: Julian Anastasov <ja@ssi.bg>
[ Upstream commit: 3ba08b00e0d8413d79be9cab8ec085ceb6ae6fd6 ]
There is lack of removing a class from the event queue while changing
from parent to leaf which can cause corruption of this rb tree. This
patch fixes a bug introduced by my patch: "sch_htb: turn intermediate
classes into leaves" commit: 160d5e10f87b1dc88fd9b84b31b1718e0fd76398.
Many thanks to Jan 'yanek' Bortl for finding a way to reproduce this
rare bug and narrowing the test case, which made possible proper
diagnosing.
This patch is recommended for all kernels starting from 2.6.20.
Reported-and-tested-by: Jan 'yanek' Bortl <yanek@ya.bofh.cz>
[ Upstream commit: 27a27a2158f4fe56a29458449e880a52ddee3dc4 ]
Flowlabel text format was not correct and thus ambiguous.
For example, 0x00123 or 0x01203 are formatted as 0x123.
This is not what audit tools want.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
[ Upstream commit: 36ca34cc3b8335eb1fe8bd9a1d0a2592980c3f02 ]
Noticed by Paul Marks <paul@pmarks.net>.
[ Upstream commit: c5d18e984a313adf5a1a4ae69e0b1d93cf410229 ]
As it stands it's impossible to use any authentication algorithms
with an ID above 31 portably. It just happens to work on x86 but
fails miserably on ppc64.
The reason is that we're using a bit mask to check the algorithm
ID but the mask is only 32 bits wide.
After looking at how this is used in the field, I have concluded
that in the long term we should phase out state matching by IDs
because this is made superfluous by the reqid feature. For current
applications, the best solution IMHO is to allow all algorithms when
the bit masks are all ~0.
The following patch does exactly that.
This bug was identified by IBM when testing on the ppc64 platform
using the NULL authentication algorithm which has an ID of 251.
[ Upstream commit: 653252c2302cdf2dfbca66a7e177f7db783f9efa ]
I found some places, that erroneously return the value obtained from
the copy_to_user() call: if some amount of bytes were not able to get
to the user (this is what this one returns) the proper behavior is to
return the -EFAULT error, not that number itself.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
[ Upstream commit: 43837b1e6c5aef803d57009a68db18df13e64892 ]
[ BUG: lock held when returning to user space! ]
xfbbd/3683 is leaving the kernel with locks still held!
1 lock held by xfbbd/3683:
#0: (sk_lock-AF_ROSE){--..}, at: [<c8cd1eb3>] rose_connect+0x73/0x420 [rose]
INFO: task xfbbd:3683 blocked for more than 120 seconds.
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
xfbbd D 00000246 0 3683 3669
c6965ee0 00000092 c02c5c40 00000246 c0f6b5f0 c0f6b5c0 c0f6b5f0 c0f6b5c0
c0f6b614 c6965f18 c024b74b ffffffff c06ba070 00000000 00000000 00000001
c6ab07c0 c012d450 c0f6b634 c0f6b634 c7b5bf10 c0d6004c c7b5bf10 c6965f40
Call Trace:
[<c024b74b>] lock_sock_nested+0x6b/0xd0
[<c012d450>] ? autoremove_wake_function+0x0/0x40
[<c02488f1>] sock_fasync+0x41/0x150
[<c0249e69>] sock_close+0x19/0x40
[<c0175d54>] __fput+0xb4/0x170
[<c0176018>] fput+0x18/0x20
[<c017300e>] filp_close+0x3e/0x70
[<c01744e9>] sys_close+0x69/0xb0
[<c0103bda>] sysenter_past_esp+0x5f/0xa5
INFO: lockdep is turned off.
Signed-off-by: Bernard Pidoux <f6bvp@amsat.org>
[ Upstream commit: c9c1014b2bd014c7ec037bbb6f58818162fdb265 ]
ASSERT_RTNL uses mutex_trylock to test whether the rtnl_mutex is
held. This bogus warnings when running in atomic context, which
f.e. happens when adding secondary unicast addresses through
macvlan or vlan or when synchronizing multicast addresses from
wireless devices.
Mid-term we might want to consider moving all address updates
to process context since the locking seems overly complicated,
for now just fix the bogus warning by changing ASSERT_RTNL to
use mutex_is_locked().
[ Upstream commit: 8d390efd903485923419584275fd0c2aa4c94183 ]
tcp_probe has a bounds-checking bug that causes many programs (less,
python) to crash reading /proc/net/tcp_probe. When it outputs a log
line to the reader, it only checks if that line alone will fit in the
reader's buffer, rather than that line and all the previous lines it
has already written.
tcpprobe_read also returns the wrong value if copy_to_user fails--it
just passes on the return value of copy_to_user (number of bytes not
copied), which makes a failure look like a success.
This patch fixes the buffer overflow and sets the return value to
-EFAULT if copy_to_user fails.
Patch is against latest net-2.6; tested briefly and seems to fix the
crashes in less and python.
Signed-off-by: Tom Quetchenbach <virtualphtn@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
[TCP]: Add return value indication to tcp_prune_ofo_queue().
PS3: gelic: fix the oops on the broken IE returned from the hypervisor
b43legacy: fix DMA mapping leakage
mac80211: remove message on receiving unexpected unencrypted frames
Update rt2x00 MAINTAINERS entry
Add rfkill to MAINTAINERS file
rfkill: Fix device type check when toggling states
b43legacy: Fix usage of struct device used for DMAing
ssb: Fix usage of struct device used for DMAing
MAINTAINERS: move to generic repository for iwlwifi
b43legacy: fix initvals loading on bcm4303
rtl8187: Add missing priv->vif assignments
netconsole: only set CON_PRINTBUFFER if the user specifies a netconsole
[CAN]: Update documentation of struct sockaddr_can
MAINTAINERS: isdn4linux@listserv.isdn4linux.de is subscribers-only
[TCP]: Fix never pruned tcp out-of-order queue.
[NET_SCHED] sch_api: fix qdisc_tree_decrease_qlen() loop
Describe debug parameters with their names (and not their values).
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Returns non-zero if tp->out_of_order_queue was seen non-empty.
This allows tcp_try_rmem_schedule() to return early.
Signed-off-by: Vitaliy Gusev <vgusev@openvz.org>
Some people are getting this message a lot, and we have traced it to
broken access points that much too often send completely empty frames
(all bytes zeroed, which they shouldn't do at all.)
Since we cannot do anything about such frames in any case except the
special case where we're debugging an AP, just remove the message.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
rfkill_switch_all() is supposed to only switch all the interfaces of a
given type, but does not actually do this; instead, it just switches
everything currently in the same state.
Add the necessary type check in.
(This fixes a bug I've been seeing while developing an rfkill laptop
driver, with both bluetooth and wireless simultaneously changing state
after only pressing either KEY_WLAN or KEY_BLUETOOTH).
Signed-off-by: Carlos Corbacho <carlos@strangeworlds.co.uk>
tcp_prune_queue() doesn't prune an out-of-order queue at all.
Therefore sk_rmem_schedule() can fail but the out-of-order queue isn't
pruned . This can lead to tcp deadlock state if the next two
conditions are held:
1. There are a sequence hole between last received in
order segment and segments enqueued to the out-of-order queue.
2. Size of all segments in the out-of-order queue is more than tcp_mem[2].
TC_H_MAJ(parentid) for root classes is the same as for ingress, and if
ingress qdisc is created qdisc_lookup() returns its pointer (without
ingress NULL is returned). After this all qdisc_lookups give the same,
and we get endless loop. (I don't know how this could hide for so long
- it should trigger with every leaf class deleted if it's qdisc isn't
empty.)
After this fix qdisc_lookup() is omitted both for ingress and root
parents, but looking for root is only wasting a little time here...
Many thanks to Enrico Demarin for finding a test for catching this
bug, which probably bothered quite a lot of admins.
Reported-by: Enrico Demarin <enrico@superclick.com>,
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (31 commits)
[BRIDGE]: Fix crash in __ip_route_output_key with bridge netfilter
[NETFILTER]: ipt_CLUSTERIP: fix race between clusterip_config_find_get and _entry_put
[IPV6] ADDRCONF: Don't generate temporary address for ip6-ip6 interface.
[IPV6] ADDRCONF: Ensure disabling multicast RS even if privacy extensions are disabled.
[IPV6]: Use appropriate sock tclass setting for routing lookup.
[IPV6]: IPv6 extension header structures need to be packed.
[IPV6]: Fix ipv6 address fetching in raw6_icmp_error().
[NET]: Return more appropriate error from eth_validate_addr().
[ISDN]: Do not validate ISDN net device address prior to interface-up
[NET]: Fix kernel-doc for skb_segment
[SOCK] sk_stamp: should be initialized to ktime_set(-1L, 0)
net: check for underlength tap writes
net: make struct tun_struct private to tun.c
[SCTP]: IPv4 vs IPv6 addresses mess in sctp_inet[6]addr_event.
[SCTP]: Fix compiler warning about const qualifiers
[SCTP]: Fix protocol violation when receiving an error lenght INIT-ACK
[SCTP]: Add check for hmac_algo parameter in sctp_verify_param()
[NET_SCHED] cls_u32: refcounting fix for u32_delete()
[DCCP]: Fix skb->cb conflicts with IP
[AX25]: Potential ax25_uid_assoc-s leaks on module unload.
The bridge netfilter code attaches a fake dst_entry with a pointer to a
fake net_device structure to skbs it passes up to IPv4 netfilter. This
leads to crashes when the skb is passed to __ip_route_output_key when
dereferencing the namespace pointer.
Since bridging can currently only operate in the init_net namespace,
the easiest fix for now is to initialize the nd_net pointer of the
fake net_device struct to &init_net.
Should fix bugzilla 10323: http://bugzilla.kernel.org/show_bug.cgi?id=10323
_entry_put
Consider we are putting a clusterip_config entry with the "entries"
count == 1, and on the other CPU there's a clusterip_config_find_get
in progress:
CPU1: CPU2:
clusterip_config_entry_put: clusterip_config_find_get:
if (atomic_dec_and_test(&c->entries)) {
/* true */
read_lock_bh(&clusterip_lock);
c = __clusterip_config_find(clusterip);
/* found - it's still in list */
atomic_inc(&c->entries);
read_unlock_bh(&clusterip_lock);
write_lock_bh(&clusterip_lock);
list_del(&c->list);
write_unlock_bh(&clusterip_lock);
dev_put(c->dev);
Oops! We have an entry returned by the clusterip_config_find_get,
which is a) not in list b) has a stale dev pointer.
The problems will happen when the CPU2 will release the entry - it
will remove it from the list for the 2nd time, thus spoiling it, and
will put a stale dev pointer.
The fix is to make atomic_dec_and_test under the clusterip_lock.
As far as I can remember, I was going to disable privacy extensions
on all "tunnel" interfaces. Disable it on ip6-ip6 interface as well.
Also, just remove ifdefs for SIT for simplicity.
are disabled.
Fixes kernel bugzilla 10437
Based almost entirely upon a patch by Dmitry Butskoy.
When deciding what raw sockets to deliver the ICMPv6
to, we should use the addresses in the ICMPv6 quoted
IPV6 header, not the top-level one.
Paul Bolle wrote:
> http://bugzilla.kernel.org/show_bug.cgi?id=9923 would have been much easier to
> track down if eth_validate_addr() would somehow complain aloud if an address
> is invalid. Shouldn't it make at least some noise?
I guess it should return -EADDRNOTAVAIL similar to eth_mac_addr()
when validation fails.
The kernel-doc comment for skb_segment is clearly wrong. This states
what it actually does.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Problem spotted by Andrew Brampton
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
All IP addresses that are present in a system are duplicated on
struct sctp_sockaddr_entry. They are linked in the global list
called sctp_local_addr_list. And this struct unions IPv4 and IPv6
addresses.
So, there can be rare case, when a sockaddr_in.sin_addr coincides
with the corresponding part of the sockaddr_in6 and the notifier
for IPv4 will carry away an IPv6 entry.
The fix is to check the family before comparing the addresses.
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
Fix 3 warnings about discarding const qualifiers:
net/sctp/ulpevent.c:862: warning: passing argument 1 of 'sctp_event2skb' discards qualifiers from pointer target type
net/sctp/sm_statefuns.c:4393: warning: passing argument 1 of 'SCTP_ASOC' discards qualifiers from pointer target type
net/sctp/socket.c:5874: warning: passing argument 1 of 'cmsg_nxthdr' discards qualifiers from pointer target type
When receiving an error length INIT-ACK during COOKIE-WAIT,
a 0-vtag ABORT will be responsed. This action violates the
protocol apparently. This patch achieves the following things.
1 If the INIT-ACK contains all the fixed parameters, use init-tag
recorded from INIT-ACK as vtag.
2 If the INIT-ACK doesn't contain all the fixed parameters,
just reflect its vtag.
Signed-off-by: Gui Jianfeng <guijianfeng@cn.fujitsu.com>
RFC 4890 has the following text:
The HMAC algorithm based on SHA-1 MUST be supported and
included in the HMAC-ALGO parameter.
As a result, we need to check in sctp_verify_param() that HMAC_SHA1 is
present in the list. If not, we should probably treat this as a
protocol violation.
It should also be a protocol violation if the HMAC parameter is empty.
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
Deleting of nonroot hnodes mostly doesn't work in u32_delete():
refcnt == 1 is expected, but such hnodes' refcnts are initialized
with 0 and charged only with "link" nodes. Now they'll start with
1 like usual. Thanks to Patrick McHardy for an improving suggestion.
Acked-by: Jamal Hadi Salim <hadi@cyberus.ca>
dev_queue_xmit() and the other IP output functions expect to get a skb
with clear or properly initialized skb->cb. Unlike TCP and UDP, the
dccp_skb_cb doesn't contain a struct inet_skb_parm at the beginning,
so the DCCP-specific data is interpreted by the IP output functions.
This can cause false negatives for the conditional POST_ROUTING hook
invocation, making the packet bypass the hook.
Add a inet_skb_parm/inet6_skb_parm union to the beginning of
dccp_skb_cb to avoid clashes. Also add a BUILD_BUG_ON to make
sure it fits in the cb.
[ Combined with patch from Gerrit Renker to remove two now unnecessary
memsets of IPCB(skb)->opt ]
The ax25_uid_free call walks the ax25_uid_list and releases entries
from it. The problem is that after the fisrt call to hlist_del_init
the hlist_for_each_entry (which hides behind the ax25_uid_for_each)
will consider the current position to be the last and will return.
Thus, the whole list will be left not freed.
* 'docs' of git://git.lwn.net/linux-2.6:
Add additional examples in Documentation/spinlocks.txt
Move sched-rt-group.txt to scheduler/
Documentation: move rpc-cache.txt to filesystems/
Documentation: move nfsroot.txt to filesystems/
Spell out behavior of atomic_dec_and_lock() in kerneldoc
Fix a typo in highres.txt
Fixes to the seq_file document
Fill out information on patch tags in SubmittingPatches
Add the seq_file documentation
Documentation/ is a little large, and filesystems/ seems an obvious
place for this file.
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
[NETNS][IPV6] tcp - assign the netns for timewait sockets
[IPV4]: Fix byte value boundary check in do_ip_getsockopt().
BNX2X: Correct bringing chip out of reset
[NETFILTER]: nf_nat: autoload IPv4 connection tracking
[NETFILTER]: xt_hashlimit: fix mask calculation
[XFRM]: xfrm_user: fix selector family initialization
rt61pci: rt61pci_beacon_update do not free skb twice
ssb-mipscore: Fix interrupt vectors
ssb-pcicore: Fix IRQ TPS flag handling
mac80211: use short_preamble mode from capability if ERP IE not present
[NET]: Undo code bloat in hot paths due to print_mac().
[TCP]: Don't allow FRTO to take place while MTU is being probed
[TCP]: tcp_simple_retransmit can cause S+L
[TCP]: Fix NewReno's fast rexmit/recovery problems with GSOed skb
[TCP]: Restore 2.6.24 mark_head_lost behavior for newreno/fack
nl80211: fix STA AID bug
b43legacy: fix bcm4303 crash
iwlwifi: fix n-band association problem
ipw2200: set MAC address on radiotap interface
libertas: fix mode initialization problem
Copy the network namespace from the socket to the timewait socket.
Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com>
Acked-by: Mark Lord <mlord@pobox.com>
This fixes kernel bugzilla 10371.
As reported by M.Piechaczek@osmosys.tv, if we try to grab a
char sized socket option value, as in:
unsigned char ttl = 255;
socklen_t len = sizeof(ttl);
setsockopt(socket, IPPROTO_IP, IP_MULTICAST_TTL, &ttl, &len);
getsockopt(socket, IPPROTO_IP, IP_MULTICAST_TTL, &ttl, &len);
The ttl returned will be wrong on big-endian, and on both little-
endian and big-endian the next three bytes in userspace are written
with garbage.
It's because of this test in do_ip_getsockopt():
if (len < sizeof(int) && len > 0 && val>=0 && val<255) {
It should allow a 'val' of 255 to pass here, but it doesn't so it
copies a full 'int' back to userspace.
On little-endian that will write the correct value into the location
but it spams on the next three bytes in userspace. On big endian it
writes the wrong value into the location and spams the next three
bytes.
Without this patch, the generic L3 tracker would kick in
if nf_conntrack_ipv4 was not loaded before nf_nat, which
would lead to translation problems with ICMP errors.
NAT does not make sense without IPv4 connection tracking
anyway, so just add a call to need_ipv4_conntrack().
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
Shifts larger than the data type are undefined, don't try to shift
an u32 by 32. Also remove some special-casing of bitmasks divisible
by 32.
Based on patch by Jan Engelhardt <jengelh@computergmbh.de>.
Commit df9dcb45 ([IPSEC]: Fix inter address family IPsec tunnel handling)
broke openswan by removing the selector initialization for tunnel mode
in case it is uninitialized.
This patch restores the initialization, fixing openswan, but probably
breaking inter-family tunnels again (unknown since the patch author
disappeared). The correct thing for inter-family tunnels is probably
to simply initialize the selector family explicitly.
