path: root/net
2005-06-02[IPV6]: Kill export of fl6_sock_lookup.Adrian Bunk
There is no usage of this EXPORT_SYMBOL in the kernel. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-02[IPVS]: remove net/ipv4/ipvs/ip_vs_proto_icmp.cAdrian Bunk
ip_vs_proto_icmp.c was never finished. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-31[IPSEC]: Fix esp_decap_data size verification in esp4.Edgar E Iglesias
Signed-off-by: Edgar E Iglesias <edgar@axis.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-31[PKT_SCHED]: Disable dsmark debugging messages by defaultThomas Graf
Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-31[PKT_SCHED]: make dsmark try using pfifo instead of noop while graftingThomas Graf
2005-05-31[PKT_SCHED]: Fix dsmark to count ignored indices while walkingThomas Graf
Unused indices which are ignored while walking must still be counted to avoid dumping the same index twice. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-30[IPV4]: Fix BUG() in 2.6.x, udp_poll(), fragments + CONFIG_HIGHMEMHerbert Xu
Steven Hand <Steven.Hand@cl.cam.ac.uk> wrote: > > Reconstructed forward trace: > > net/ipv4/udp.c:1334 spin_lock_irq() > net/ipv4/udp.c:1336 udp_checksum_complete() > net/core/skbuff.c:1069 skb_shinfo(skb)->nr_frags > 1 > net/core/skbuff.c:1086 kunmap_skb_frag() > net/core/skbuff.h:1087 local_bh_enable() > kernel/softirq.c:0140 WARN_ON(irqs_disabled()); The receive queue lock is never taken in IRQs (and should never be) so we can simply substitute bh for irq. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-30[NETFILTER]: Fix deadlock with ip_queue and tcp local input path.Harald Welte
When we have ip_queue being used from LOCAL_IN, then we end up with a situation where the verdicts coming back from userspace traverse the TCP input path from syscall context. While this seems to work most of the time, there's an ugly deadlock: syscall context is interrupted by the timer interrupt. When the timer interrupt leaves, the timer softirq get's scheduled and calls tcp_delack_timer() and alike. They themselves do bh_lock_sock(sk), which is already held from somewhere else -> boom. I've now tested the suggested solution by Patrick McHardy and Herbert Xu to simply use local_bh_{en,dis}able(). Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-29[NET]: Use %lx for netdev->features sysfs formatting.David S. Miller
2005-05-29[IPV6]: Clear up user copy warning in flowlabel code.David S. Miller
We are intentionally ignoring the copy_to_user() value, make it clear to the compiler too. Noted by Jeff Garzik. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-29[NET]: Add ethtool support for NETIF_F_HW_CSUM.Jon Mason
Signed-off-by: Jon Mason <jdmason@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-29[IPV4]: Kill MULTIPATHHOLDROUTE flag.Pravin B. Shelar
It cannot work properly, so just ignore it in drr and rr multipath algorithms just like the random multipath algorithm does. Suggested by Herbert Xu. Signed-off by: Pravin B. Shelar <pravins@calsoftinc.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-29[IPV4]: Primary and secondary addressesHarald Welte
Add an option to make secondary IP addresses get promoted when primary IP addresses are removed from the device. It defaults to off to preserve existing behavior. Signed-off-by: Harald Welte <laforge@gnumonks.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-29[BRIDGE]: receive path optimizationStephen Hemminger
This improves the bridge local receive path by avoiding going through another softirq. The bridge receive path is already being called from a netif_receive_skb() there is no point in going through another receiveq round trip. Recursion is limited because bridge can never be a port of a bridge so handle_bridge() always returns. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-29[BRIDGE]: prevent bad forwarding table updatesStephen Hemminger
Avoid poisoning of the bridge forwarding table by frames that have been dropped by filtering. This prevents spoofed source addresses on hostile side of bridge from causing packet leakage, a small but possible security risk. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-29[BRIDGE]: set features based on enslaved devicesStephen Hemminger
Make features of the bridge pseudo-device be a subset of the underlying devices. Motivated by Xen and others who use bridging to do failover. Signed-off-by: Catalin BOIE <catab at umrella.ro> Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-29[BRIDGE]: make dev->features unsignedStephen Hemminger
The features field in netdevice is really a bitmask, and bitmask's should be unsigned. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-29[BRIDGE]: features change notificationStephen Hemminger
Resend of earlier patch (no changes) from Catalin used to provide device feature change notification. Signed-off-by: Catalin BOIE <catab at umbrella.ro> Acked-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-26[TOKENRING]: net/802/tr.c: s/struct rif_cache_s/struct rif_cache/Alexey Dobriyan
"_s" suffix is certainly of hungarian origin. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-26[TOKENRING]: be'ify trh_hdr, trllc, rif_cache_sAlexey Dobriyan
2005-05-26From: Kazunori Miyazawa <kazunori@miyazawa.org>Hideaki YOSHIFUJI
[XFRM] Call dst_check() with appropriate cookie This fixes infinite loop issue with IPv6 tunnel mode. Signed-off-by: Kazunori Miyazawa <kazunori@miyazawa.org> Signed-off-by: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-26[PKT_SCHED] netem: allow random reordering (with fix)Stephen Hemminger
Here is a fixed up version of the reorder feature of netem. It is the same as the earlier patch plus with the bugfix from Julio merged in. Has expected backwards compatibility behaviour. Go ahead and merge this one, the TCP strangeness I was seeing was due to the reordering bug, and previous version of TSO patch. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-26[PKT_SCHED] netem: use only inner qdisc -- no private skbuff queueStephen Hemminger
Netem works better if there if packets are just queued in the inner discipline rather than having a separate delayed queue. Change to use the dequeue/requeue to peek like TBF does. By doing this potential qlen problems with the old method are avoided. The problems happened when the netem_run that moved packets from the inner discipline to the nested discipline failed (because inner queue was full). This happened in dequeue, so the effective qlen of the netem would be decreased (because of the drop), but there was no way to keep the outer qdisc (caller of netem dequeue) in sync. The problem window is still there since this patch doesn't address the issue of requeue failing in netem_dequeue, but that shouldn't happen since the sequence dequeue/requeue should always work. Long term correct fix is to implement qdisc->peek in all the qdisc's to allow for this (needed by several other qdisc's as well). Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-26[PKT_SCHED]: netem: reinsert for duplicationStephen Hemminger
Handle duplication of packets in netem by re-inserting at top of qdisc tree. This avoid problems with qlen accounting with nested qdisc. This recursion requires no additional locking but will potentially increase stack depth. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-23[IPV6]: Fix xfrm tunnel oops with large packetsHerbert Xu
Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-23[TCP]: Fix stretch ACK performance killer when doing ucopy.David S. Miller
When we are doing ucopy, we try to defer the ACK generation to cleanup_rbuf(). This works most of the time very well, but if the ucopy prequeue is large, this ACKing behavior kills performance. With TSO, it is possible to fill the prequeue so large that by the time the ACK is sent and gets back to the sender, most of the window has emptied of data and performance suffers significantly. This behavior does help in some cases, so we should think about re-enabling this trick in the future, using some kind of limit in order to avoid the bug case. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-19[NETLINK]: Defer socket destruction a bitTommy S. Christensen
In netlink_broadcast() we're sending shared skb's to netlink listeners when possible (saves some copying). This is OK, since we hold the only other reference to the skb. However, this implies that we must drop our reference on the skb, before allowing a receiving socket to disappear. Otherwise, the socket buffer accounting is disrupted. Signed-off-by: Tommy S. Christensen <tommy.christensen@tpack.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-19[NETLINK]: Move broadcast skb_orphan to the skb_get path.Tommy S. Christensen
Cloned packets don't need the orphan call. Signed-off-by: Tommy S. Christensen <tommy.christensen@tpack.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-19[NETLINK]: Fix race with recvmsg().Tommy S. Christensen
This bug causes: assertion (!atomic_read(&sk->sk_rmem_alloc)) failed at net/netlink/af_netlink.c (122) What's happening is that: 1) The skb is sent to socket 1. 2) Someone does a recvmsg on socket 1 and drops the ref on the skb. Note that the rmalloc is not returned at this point since the skb is still referenced. 3) The same skb is now sent to socket 2. This version of the fix resurrects the skb_orphan call that was moved out, last time we had 'shared-skb troubles'. It is practically a no-op in the common case, but still prevents the possible race with recvmsg. Signed-off-by: Tommy S. Christensen <tommy.christensen@tpack.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-19[IPSEC]: Verify key payload in verify_one_algoHerbert Xu
We need to verify that the payload contains enough data so that attach_one_algo can copy alg_key_len bits from the payload. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-19[IPSEC]: Fixed alg_key_len usage in attach_one_algoHerbert Xu
The variable alg_key_len is in bits and not bytes. The function attach_one_algo is currently using it as if it were in bytes. This causes it to read memory which may not be there. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-19[NETFILTER]: Do not be clever about SKB ownership in ip_ct_gather_frags().David S. Miller
Just do an skb_orphan() and be done with it. Based upon discussions with Herbert Xu on netdev. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-19[IP_VS]: Remove extra __ip_vs_conn_put() for incoming ICMP.Julian Anastasov
Remove extra __ip_vs_conn_put for incoming ICMP in direct routing mode. Mark de Vries reports that IPVS connections are not leaked anymore. Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-19[AF_UNIX]: Use lookup_create().Christoph Hellwig
currently it opencodes it, but that's in the way of chaning the lookup_hash interface. I'd prefer to disallow modular af_unix over exporting lookup_create, but I'll leave that to you. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-18[IPV4/IPV6] Ensure all frag_list members have NULL skHerbert Xu
Having frag_list members which holds wmem of an sk leads to nightmares with partially cloned frag skb's. The reason is that once you unleash a skb with a frag_list that has individual sk ownerships into the stack you can never undo those ownerships safely as they may have been cloned by things like netfilter. Since we have to undo them in order to make skb_linearize happy this approach leads to a dead-end. So let's go the other way and make this an invariant: For any skb on a frag_list, skb->sk must be NULL. That is, the socket ownership always belongs to the head skb. It turns out that the implementation is actually pretty simple. The above invariant is actually violated in the following patch for a short duration inside ip_fragment. This is OK because the offending frag_list member is either destroyed at the end of the slow path without being sent anywhere, or it is detached from the frag_list before being sent. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-18[XFRM]: skb_cow_data() does not set proper owner for new skbs.Evgeniy Polyakov
It looks like skb_cow_data() does not set proper owner for newly created skb. If we have several fragments for skb and some of them are shared(?) or cloned (like in async IPsec) there might be a situation when we require recreating skb and thus using skb_copy() for it. Newly created skb has neither a destructor nor a socket assotiated with it, which must be copied from the old skb. As far as I can see, current code sets destructor and socket for the first one skb only and uses truesize of the first skb only to increment sk_wmem_alloc value. If above "analysis" is correct then attached patch fixes that. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-05[PATCH] update Ross Biro bouncing email addressJesper Juhl
Ross moved. Remove the bad email address so people will find the correct one in ./CREDITS. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[IPV4]: multipath_wrandom.c GPF fixesPatrick McHardy
multipath_wrandom needs to use GFP_ATOMIC. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-05[ATALK]: Add alloc_ltalkdev().Christoph Hellwig
this matches the API used by other link layer like ethernet or token ring. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-05[IPV6]: Fix OOPS when using IPV6_ADDRFORMArnaldo Carvalho de Melo
This causes sk->sk_prot to change, which makes the socket release free the sock into the wrong SLAB cache. Fix this by introducing sk_prot_creator so that we always remember where the sock came from. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-05[DECNET]: Fix build after C99 netlink initializer change.Rafael J. Wysocki
Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-05Merge with master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6.gitDavid Woodhouse
2005-05-04[PATCH] ISA DMA Kconfig fixes - part 4 (irda)Al Viro
* net/irda/irda_device.c::irda_setup_dma() made conditional on ISA_DMA_API (it uses helpers in question and irda is usable on platforms that don't have them at all - think of USB IRDA, for example). * irda drivers that depend on ISA DMA marked as dependent on ISA_DMA_API Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-03[PKT_SCHED]: Action repeatJ Hadi Salim
Long standing bug. Policy to repeat an action never worked. Signed-off-by: J Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-03[IPSEC]: Store idev entriesHerbert Xu
I found a bug that stopped IPsec/IPv6 from working. About a month ago IPv6 started using rt6i_idev->dev on the cached socket dst entries. If the cached socket dst entry is IPsec, then rt6i_idev will be NULL. Since we want to look at the rt6i_idev of the original route in this case, the easiest fix is to store rt6i_idev in the IPsec dst entry just as we do for a number of other IPv6 route attributes. Unfortunately this means that we need some new code to handle the references to rt6i_idev. That's why this patch is bigger than it would otherwise be. I've also done the same thing for IPv4 since it is conceivable that once these idev attributes start getting used for accounting, we probably need to dereference them for IPv4 IPsec entries too. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-03[PKT_SCHED]: netetm: adjust parent qlen when duplicatingStephen Hemminger
Fix qlen underrun when doing duplication with netem. If netem is used as leaf discipline, then the parent needs to be tweaked when packets are duplicated. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-03[PKT_SCHED]: netetm: make qdisc friendly to outer disciplinesStephen Hemminger
Netem currently dumps packets into the queue when timer expires. This patch makes work by self-clocking (more like TBF). It fixes a bug when 0 delay is requested (only doing loss or duplication). Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-03[PKT_SCHED]: netetm: trap infinite loop hange on qlen underflowStephen Hemminger
Due to bugs in netem (fixed by later patches), it is possible to get qdisc qlen to go negative. If this happens the CPU ends up spinning forever in qdisc_run(). So add a BUG_ON() to trap it. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-03[NETFILTER]: Drop conntrack reference in ip_dev_loopback_xmit()Patrick McHardy
2005-05-03[NETFILTER]: Fix nf_debug_ip_local_deliver()Patrick McHardy
