packet
commit 3a7b21eaf4fb3c971bdb47a98f570550ddfe4471 upstream.
Some Cisco phones create huge messages that are spread over multiple packets.
After calculating the offset of the SIP body, it is validated to be within
the packet and the packet is dropped otherwise. This breaks operation of
these phones. Since connection tracking is supposed to be passive, just let
those packets pass unmodified and untracked.
Cc: William Roberts <bill.c.roberts@gmail.com>
[ Upstream commit 6f092343855a71e03b8d209815d8c45bf3a27fcd ]
We don't validate iph->ihl which may lead a dead loop if we meet a IPIP
skb whose iph->ihl is zero. Fix this by failing immediately when iph->ihl
is evil (less than 5).
This issue were introduced by commit ec5efe7946280d1e84603389a1030ccec0a767ae
(rps: support IPIP encapsulation).
Signed-off-by: Jason Wang <jasowang@redhat.com>
Cc: Eric Dumazet <edumazet@google.com>
Cc: Petr Matousek <pmatouse@redhat.com>
Cc: Michael S. Tsirkin <mst@redhat.com>
Cc: Daniel Borkmann <dborkman@redhat.com>
commit 0c5b93290b2f3c7a376567c03ae8d385b0e99851 upstream.
When clients are idle for too long, hostapd sends nullfunc frames for
probing. When those are acked by the client, the idle time needs to be
updated.
To make this work (and to avoid unnecessary probing), update sta->last_rx
whenever an ACK was received for a tx packet. Only do this if the flag
IEEE80211_HW_REPORTS_TX_ACK_STATUS is set.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
commit a754055a1296fcbe6f32de3a5eaca6efb2fd1865 upstream.
__ieee80211_scan_completed is called from a worker. This
means that the following flow is possible.
* driver calls ieee80211_scan_completed
* mac80211 cancels the scan (that is already complete)
* __ieee80211_scan_completed runs
When scan_work will finally run, it will see that the scan
hasn't been aborted and might even trigger another scan on
another band. This leads to a situation where cfg80211's
scan is not done and no further scan can be issued.
Fix this by setting a new flag when a HW scan is being
cancelled so that no other scan will be triggered.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
commit f5563318ff1bde15b10e736e97ffce13be08bc1a upstream.
When parsing an invalid radiotap header, the parser can overrun
the buffer that is passed in because it doesn't correctly check
1) the minimum radiotap header size
2) the space for extended bitmaps
The first issue doesn't affect any in-kernel user as they all
check the minimum size before calling the radiotap function.
The second issue could potentially affect the kernel if an skb
is passed in that consists only of the radiotap header with a
lot of extended bitmaps that extend past the SKB. In that case
a read-only buffer overrun by at most 4 bytes is possible.
Fix this by adding the appropriate checks to the parser.
Reported-by: Evan Huus <eapache@gmail.com>
[ This is a simplified -stable version of a set of upstream commits. ]
This is a replacement patch only for stable which does fix the problems
handled by the following two commits in -net:
"ip_output: do skb ufo init for peeked non ufo skb as well" (e93b7d748be887cd7639b113ba7d7ef792a7efb9)
"ip6_output: do skb ufo init for peeked non ufo skb as well" (c547dbf55d5f8cf615ccc0e7265e98db27d3fb8b)
Three frames are written on a corked udp socket for which the output
netdevice has UFO enabled. If the first and third frame are smaller than
the mtu and the second one is bigger, we enqueue the second frame with
skb_append_datato_frags without initializing the gso fields. This leads
to the third frame appended regulary and thus constructing an invalid skb.
This fixes the problem by always using skb_append_datato_frags as soon
as the first frag got enqueued to the skb without marking the packet
as SKB_GSO_UDP.
The problem with only two frames for ipv6 was fixed by "ipv6: udp
packets following an UFO enqueued packet need also be handled by UFO"
(2811ebac2521ceac84f2bdae402455baa6a7fb47).
Cc: Jiri Pirko <jiri@resnulli.us>
[ Upstream commit 90c6bd34f884cd9cee21f1d152baf6c18bcac949 ]
In the case of credentials passing in unix stream sockets (dgram
sockets seem not affected), we get a rather sparse race after
commit 16e5726 ("af_unix: dont send SCM_CREDENTIALS by default").
We have a stream server on receiver side that requests credential
passing from senders (e.g. nc -U). Since we need to set SO_PASSCRED
on each spawned/accepted socket on server side to 1 first (as it's
not inherited), it can happen that in the time between accept() and
setsockopt() we get interrupted, the sender is being scheduled and
continues with passing data to our receiver. At that time SO_PASSCRED
is neither set on sender nor receiver side, hence in cmsg's
SCM_CREDENTIALS we get eventually pid:0, uid:65534, gid:65534
(== overflow{u,g}id) instead of what we actually would like to see.
On the sender side, here nc -U, the tests in maybe_add_creds()
invoked through unix_stream_sendmsg() would fail, as at that exact
time, as mentioned, the sender has neither SO_PASSCRED on his side
nor sees it on the server side, and we have a valid 'other' socket
in place. Thus, sender believes it would just look like a normal
connection, not needing/requesting SO_PASSCRED at that time.
As reverting 16e5726 would not be an option due to the significant
performance regression reported when having creds always passed,
one way/trade-off to prevent that would be to set SO_PASSCRED on
the listener socket and allow inheriting these flags to the spawned
socket on server side in accept(). It seems also logical to do so
if we'd tell the listener socket to pass those flags onwards, and
would fix the race.
Before, strace:
recvmsg(4, {msg_name(0)=NULL, msg_iov(1)=[{"blub\n", 4096}],
msg_controllen=32, {cmsg_len=28, cmsg_level=SOL_SOCKET,
cmsg_type=SCM_CREDENTIALS{pid=0, uid=65534, gid=65534}},
msg_flags=0}, 0) = 5
After, strace:
cmsg_type=SCM_CREDENTIALS{pid=11580, uid=1000, gid=1000}},
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
[ Upstream commit d2dbbba77e95dff4b4f901fee236fef6d9552072 ]
IP/IPv6 fragmentation knows how to compute only TCP/UDP checksum.
This causes problems if SCTP packets has to be fragmented and
ipsummed has been set to PARTIAL due to checksum offload support.
This condition can happen when retransmitting after MTU discover,
or when INIT or other control chunks are larger then MTU.
Check for the rare fragmentation condition in SCTP and use software
checksum calculation in this case.
CC: Fan Du <fan.du@windriver.com>
Signed-off-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit 27127a82561a2a3ed955ce207048e1b066a80a2a ]
igb/ixgbe have hardware sctp checksum support, when this feature is enabled
and also IPsec is armed to protect sctp traffic, ugly things happened as
xfrm_output checks CHECKSUM_PARTIAL to do checksum operation(sum every thing
up and pack the 16bits result in the checksum field). The result is fail
establishment of sctp communication.
Signed-off-by: Fan Du <fan.du@windriver.com>
Cc: Neil Horman <nhorman@tuxdriver.com>
Cc: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit 6865d1e834be84ddd5808d93d5035b492346c64a ]
When filling the netlink message we miss to wipe the pad field,
therefore leak one byte of heap memory to userland. Fix this by
setting pad to 0.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
[ Upstream commit 455cc32bf128e114455d11ad919321ab89a2c312 ]
François Cachereul made a very nice bug report and suspected
the bh_lock_sock() / bh_unlok_sock() pair used in l2tp_xmit_skb() from
process context was not good.
This problem was added by commit 6af88da14ee284aaad6e4326da09a89191ab6165
("l2tp: Fix locking in l2tp_core.c").
l2tp_eth_dev_xmit() runs from BH context, so we must disable BH
from other l2tp_xmit_skb() users.
[ 452.060011] BUG: soft lockup - CPU#1 stuck for 23s! [accel-pppd:6662]
[ 452.061757] Modules linked in: l2tp_ppp l2tp_netlink l2tp_core pppoe pppox
ppp_generic slhc ipv6 ext3 mbcache jbd virtio_balloon xfs exportfs dm_mod
virtio_blk ata_generic virtio_net floppy ata_piix libata virtio_pci virtio_ring virtio [last unloaded: scsi_wait_scan]
[ 452.064012] CPU 1
[ 452.080015] BUG: soft lockup - CPU#2 stuck for 23s! [accel-pppd:6643]
[ 452.080015] CPU 2
[ 452.080015]
[ 452.080015] Pid: 6643, comm: accel-pppd Not tainted 3.2.46.mini #1 Bochs Bochs
[ 452.080015] RIP: 0010:[<ffffffff81059f6c>] [<ffffffff81059f6c>] do_raw_spin_lock+0x17/0x1f
[ 452.080015] RSP: 0018:ffff88007125fc18 EFLAGS: 00000293
[ 452.080015] RAX: 000000000000aba9 RBX: ffffffff811d0703 RCX: 0000000000000000
[ 452.080015] RDX: 00000000000000ab RSI: ffff8800711f6896 RDI: ffff8800745c8110
[ 452.080015] RBP: ffff88007125fc18 R08: 0000000000000020 R09: 0000000000000000
[ 452.080015] R10: 0000000000000000 R11: 0000000000000280 R12: 0000000000000286
[ 452.080015] R13: 0000000000000020 R14: 0000000000000240 R15: 0000000000000000
[ 452.080015] FS: 00007fdc0cc24700(0000) GS:ffff8800b6f00000(0000) knlGS:0000000000000000
[ 452.080015] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 452.080015] CR2: 00007fdb054899b8 CR3: 0000000074404000 CR4: 00000000000006a0
[ 452.080015] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 452.080015] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 452.080015] Process accel-pppd (pid: 6643, threadinfo ffff88007125e000, task ffff8800b27e6dd0)
[ 452.080015] Stack:
[ 452.080015] ffff88007125fc28 ffffffff81256559 ffff88007125fc98 ffffffffa01b2bd1
[ 452.080015] ffff88007125fc58 000000000000000c 00000000029490d0 0000009c71dbe25e
[ 452.080015] 000000000000005c 000000080000000e 0000000000000000 ffff880071170600
[ 452.080015] Call Trace:
[ 452.080015] [<ffffffff81256559>] _raw_spin_lock+0xe/0x10
[ 452.080015] [<ffffffffa01b2bd1>] l2tp_xmit_skb+0x189/0x4ac [l2tp_core]
[ 452.080015] [<ffffffffa01c2d36>] pppol2tp_sendmsg+0x15e/0x19c [l2tp_ppp]
[ 452.080015] [<ffffffff811c7872>] __sock_sendmsg_nosec+0x22/0x24
[ 452.080015] [<ffffffff811c83bd>] sock_sendmsg+0xa1/0xb6
[ 452.080015] [<ffffffff81254e88>] ? __schedule+0x5c1/0x616
[ 452.080015] [<ffffffff8103c7c6>] ? __dequeue_signal+0xb7/0x10c
[ 452.080015] [<ffffffff810bbd21>] ? fget_light+0x75/0x89
[ 452.080015] [<ffffffff811c8444>] ? sockfd_lookup_light+0x20/0x56
[ 452.080015] [<ffffffff811c9b34>] sys_sendto+0x10c/0x13b
[ 452.080015] [<ffffffff8125cac2>] system_call_fastpath+0x16/0x1b
[ 452.080015] Code: 81 48 89 e5 72 0c 31 c0 48 81 ff 45 66 25 81 0f 92 c0 5d c3 55 b8 00 01 00 00 48 89 e5 f0 66 0f c1 07 0f b6 d4 38 d0 74 06 f3 90 <8a> 07 eb f6 5d c3 90 90 55 48 89 e5 9c 58 0f 1f 44 00 00 5d c3
[ 452.064012]
[ 452.064012] Pid: 6662, comm: accel-pppd Not tainted 3.2.46.mini #1 Bochs Bochs
[ 452.064012] RIP: 0010:[<ffffffff81059f6e>] [<ffffffff81059f6e>] do_raw_spin_lock+0x19/0x1f
[ 452.064012] RSP: 0018:ffff8800b6e83ba0 EFLAGS: 00000297
[ 452.064012] RAX: 000000000000aaa9 RBX: ffff8800b6e83b40 RCX: 0000000000000002
[ 452.064012] RDX: 00000000000000aa RSI: 000000000000000a RDI: ffff8800745c8110
[ 452.064012] RBP: ffff8800b6e83ba0 R08: 000000000000c802 R09: 000000000000001c
[ 452.064012] R10: ffff880071096c4e R11: 0000000000000006 R12: ffff8800b6e83b18
[ 452.064012] R13: ffffffff8125d51e R14: ffff8800b6e83ba0 R15: ffff880072a589c0
[ 452.064012] FS: 00007fdc0b81e700(0000) GS:ffff8800b6e80000(0000) knlGS:0000000000000000
[ 452.064012] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 452.064012] CR2: 0000000000625208 CR3: 0000000074404000 CR4: 00000000000006a0
[ 452.064012] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 452.064012] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 452.064012] Process accel-pppd (pid: 6662, threadinfo ffff88007129a000, task ffff8800744f7410)
[ 452.064012] Stack:
[ 452.064012] ffff8800b6e83bb0 ffffffff81256559 ffff8800b6e83bc0 ffffffff8121c64a
[ 452.064012] ffff8800b6e83bf0 ffffffff8121ec7a ffff880072a589c0 ffff880071096c62
[ 452.064012] 0000000000000011 ffffffff81430024 ffff8800b6e83c80 ffffffff8121f276
[ 452.064012] Call Trace:
[ 452.064012] <IRQ>
[ 452.064012] [<ffffffff81256559>] _raw_spin_lock+0xe/0x10
[ 452.064012] [<ffffffff8121c64a>] spin_lock+0x9/0xb
[ 452.064012] [<ffffffff8121ec7a>] udp_queue_rcv_skb+0x186/0x269
[ 452.064012] [<ffffffff8121f276>] __udp4_lib_rcv+0x297/0x4ae
[ 452.064012] [<ffffffff8121c178>] ? raw_rcv+0xe9/0xf0
[ 452.064012] [<ffffffff8121f4a7>] udp_rcv+0x1a/0x1c
[ 452.064012] [<ffffffff811fe385>] ip_local_deliver_finish+0x12b/0x1a5
[ 452.064012] [<ffffffff811fe54e>] ip_local_deliver+0x53/0x84
[ 452.064012] [<ffffffff811fe1d0>] ip_rcv_finish+0x2bc/0x2f3
[ 452.064012] [<ffffffff811fe78f>] ip_rcv+0x210/0x269
[ 452.064012] [<ffffffff8101911e>] ? kvm_clock_get_cycles+0x9/0xb
[ 452.064012] [<ffffffff811d88cd>] __netif_receive_skb+0x3a5/0x3f7
[ 452.064012] [<ffffffff811d8eba>] netif_receive_skb+0x57/0x5e
[ 452.064012] [<ffffffff811cf30f>] ? __netdev_alloc_skb+0x1f/0x3b
[ 452.064012] [<ffffffffa0049126>] virtnet_poll+0x4ba/0x5a4 [virtio_net]
[ 452.064012] [<ffffffff811d9417>] net_rx_action+0x73/0x184
[ 452.064012] [<ffffffffa01b2cc2>] ? l2tp_xmit_skb+0x27a/0x4ac [l2tp_core]
[ 452.064012] [<ffffffff810343b9>] __do_softirq+0xc3/0x1a8
[ 452.064012] [<ffffffff81013b56>] ? ack_APIC_irq+0x10/0x12
[ 452.064012] [<ffffffff81256559>] ? _raw_spin_lock+0xe/0x10
[ 452.064012] [<ffffffff8125e0ac>] call_softirq+0x1c/0x26
[ 452.064012] [<ffffffff81003587>] do_softirq+0x45/0x82
[ 452.064012] [<ffffffff81034667>] irq_exit+0x42/0x9c
[ 452.064012] [<ffffffff8125e146>] do_IRQ+0x8e/0xa5
[ 452.064012] [<ffffffff8125676e>] common_interrupt+0x6e/0x6e
[ 452.064012] <EOI>
[ 452.064012] [<ffffffff810b82a1>] ? kfree+0x8a/0xa3
[ 452.064012] [<ffffffffa01b2c25>] ? l2tp_xmit_skb+0x1dd/0x4ac [l2tp_core]
[ 452.064012] [<ffffffffa01c2d36>] pppol2tp_sendmsg+0x15e/0x19c [l2tp_ppp]
[ 452.064012] [<ffffffff811c7872>] __sock_sendmsg_nosec+0x22/0x24
[ 452.064012] [<ffffffff811c83bd>] sock_sendmsg+0xa1/0xb6
[ 452.064012] [<ffffffff81254e88>] ? __schedule+0x5c1/0x616
[ 452.064012] [<ffffffff8103c7c6>] ? __dequeue_signal+0xb7/0x10c
[ 452.064012] [<ffffffff810bbd21>] ? fget_light+0x75/0x89
[ 452.064012] [<ffffffff811c8444>] ? sockfd_lookup_light+0x20/0x56
[ 452.064012] [<ffffffff811c9b34>] sys_sendto+0x10c/0x13b
[ 452.064012] [<ffffffff8125cac2>] system_call_fastpath+0x16/0x1b
[ 452.064012] Code: 89 e5 72 0c 31 c0 48 81 ff 45 66 25 81 0f 92 c0 5d c3 55 b8 00 01 00 00 48 89 e5 f0 66 0f c1 07 0f b6 d4 38 d0 74 06 f3 90 8a 07 <eb> f6 5d c3 90 90 55 48 89 e5 9c 58 0f 1f 44 00 00 5d c3 55 48
[ 452.064012] <IRQ> [<ffffffff81256559>] _raw_spin_lock+0xe/0x10
[ 452.064012] <EOI> [<ffffffff810b82a1>] ? kfree+0x8a/0xa3
Reported-by: François Cachereul <f.cachereul@alphalink.fr>
Tested-by: François Cachereul <f.cachereul@alphalink.fr>
Cc: James Chapman <jchapman@katalix.com>
[ Upstream commit c33a39c575068c2ea9bffb22fd6de2df19c74b89 ]
This patch fixes the calculation of the nlmsg size, by adding the missing
nla_total_size().
Cc: Patrick McHardy <kaber@trash.net>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
[ Upstream commit 4b6c7879d84ad06a2ac5b964808ed599187a188d ]
Commit be4f154d5ef0ca147ab6bcd38857a774133f5450
bridge: Clamp forward_delay when enabling STP
had a typo when attempting to clamp maximum forward delay.
It is possible to set bridge_forward_delay to be higher then
permitted maximum when STP is off. When turning STP on, the
higher then allowed delay has to be clamed down to max value.
Signed-off-by: Vlad Yasevich <vyasevic@redhat.com>
CC: Herbert Xu <herbert@gondor.apana.org.au>
CC: Stephen Hemminger <shemminger@vyatta.com>
Reviewed-by: Veaceslav Falico <vfalico@redhat.com>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
This patch is based on 3.2.y branch, the one used by reporter. Please let me
know if it should be different. Thanks.
The patch which introduced the regression was applied on stables:
3.0.64 3.4.31 3.7.8 3.2.39
The patch which introduced the regression was for stable trees only.
---8<---
Commit 0d6a77079c475033cb622c07c5a880b392ef664e "ipv6: do not create
neighbor entries for local delivery" introduced a regression on
which routes to local delivery would not work anymore. Like this:
$ ip -6 route add local 2001::/64 dev lo
$ ping6 -c1 2001::9
PING 2001::9(2001::9) 56 data bytes
ping: sendmsg: Invalid argument
As this is a local delivery, that commit would not allow the creation of a
neighbor entry and thus the packet cannot be sent.
But as TPROXY scenario actually needs to avoid the neighbor entry creation only
for input flow, this patch now limits previous patch to input flow, keeping
output as before that patch.
Reported-by: Debabrata Banerjee <dbavatar@gmail.com>
Signed-off-by: Marcelo Ricardo Leitner <mleitner@redhat.com>
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
CC: Hannes Frederic Sowa <hannes@stressinduktion.org>
[ Upstream commit 0a7e22609067ff524fc7bbd45c6951dd08561667 ]
When sending out multicast messages, the source address in inet->mc_addr is
ignored and rewritten by an autoselected one. This is caused by a typo in
commit 813b3b5db831 ("ipv4: Use caller's on-stack flowi as-is in output
route lookups").
Signed-off-by: Jiri Benc <jbenc@redhat.com>
[ Upstream commit 1661bf364ae9c506bc8795fef70d1532931be1e8 ]
We need to cap ->msg_namelen or it leads to a buffer overflow when we
to the memcpy() in __audit_sockaddr(). It requires CAP_AUDIT_CONTROL to
exploit this bug.
The call tree is:
___sys_recvmsg()
move_addr_to_user()
audit_sockaddr()
__audit_sockaddr()
Reported-by: Jüri Aedla <juri.aedla@gmail.com>
[ Upstream commit 80ad1d61e72d626e30ebe8529a0455e660ca4693 ]
commit 3ab5aee7fe84 ("net: Convert TCP & DCCP hash tables to use RCU /
hlist_nulls") incorrectly used sock_put() on TIMEWAIT sockets.
We should instead use inet_twsk_put()
[ Upstream commit 5e8a402f831dbe7ee831340a91439e46f0d38acd ]
Yuchung found following problem :
There are bugs in the SACK processing code, merging part in
tcp_shift_skb_data(), that incorrectly resets or ignores the sacked
skbs FIN flag. When a receiver first SACK the FIN sequence, and later
throw away ofo queue (e.g., sack-reneging), the sender will stop
retransmitting the FIN flag, and hangs forever.
Following packetdrill test can be used to reproduce the bug.
$ cat sack-merge-bug.pkt
`sysctl -q net.ipv4.tcp_fack=0`
// Establish a connection and send 10 MSS.
0.000 socket(..., SOCK_STREAM, IPPROTO_TCP) = 3
+.000 setsockopt(3, SOL_SOCKET, SO_REUSEADDR, [1], 4) = 0
+.000 bind(3, ..., ...) = 0
+.000 listen(3, 1) = 0
+.050 < S 0:0(0) win 32792 <mss 1000,sackOK,nop,nop,nop,wscale 7>
+.000 > S. 0:0(0) ack 1 <mss 1460,nop,nop,sackOK,nop,wscale 6>
+.001 < . 1:1(0) ack 1 win 1024
+.000 accept(3, ..., ...) = 4
+.100 write(4, ..., 12000) = 12000
+.000 shutdown(4, SHUT_WR) = 0
+.000 > . 1:10001(10000) ack 1
+.050 < . 1:1(0) ack 2001 win 257
+.000 > FP. 10001:12001(2000) ack 1
+.050 < . 1:1(0) ack 2001 win 257 <sack 10001:11001,nop,nop>
+.050 < . 1:1(0) ack 2001 win 257 <sack 10001:12002,nop,nop>
// SACK reneg
+.050 < . 1:1(0) ack 12001 win 257
+0 %{ print "unacked: ",tcpi_unacked }%
+5 %{ print "" }%
First, a typo inverted left/right of one OR operation, then
code forgot to advance end_seq if the merged skb carried FIN.
Bug was added in 2.6.29 by commit 832d11c5cd076ab
("tcp: Try to restore large SKBs while SACK processing")
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
Cc: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Acked-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
[ Upstream commit c52e2421f7368fd36cbe330d2cf41b10452e39a9 ]
TCP stack should make sure it owns skbs before mangling them.
We had various crashes using bnx2x, and it turned out gso_size
was cleared right before bnx2x driver was populating TC descriptor
of the _previous_ packet send. TCP stack can sometime retransmit
packets that are still in Qdisc.
Of course we could make bnx2x driver more robust (using
ACCESS_ONCE(shinfo->gso_size) for example), but the bug is TCP stack.
We have identified two points where skb_unclone() was needed.
This patch adds a WARN_ON_ONCE() to warn us if we missed another
fix of this kind.
Kudos to Neal for finding the root cause of this bug. Its visible
using small MSS.
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
commit 89cbb4da0abee2f39d75f67f9fd57f7410c8b65c upstream.
This patch fixes the connection encryption key size information when
the host is playing the peripheral role. We should set conn->enc_key_
size in hci_le_ltk_request_evt, otherwise it is left uninitialized.
Signed-off-by: Andre Guedes <andre.guedes@openbossa.org>
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
commit f8776218e8546397be64ad2bc0ebf4748522d6e3 upstream.
While playing the peripheral role, the host gets a LE Long Term Key
Request Event from the controller when a connection is established
with a bonded device. The host then informs the LTK which should be
used for the connection. Once the link is encrypted, the host gets
an Encryption Change Event.
Therefore we should set conn->pending_sec_level instead of conn->
sec_level in hci_le_ltk_request_evt. This way, conn->sec_level is
properly updated in hci_encrypt_change_evt.
Moreover, since we have a LTK associated to the device, we have at
least BT_SECURITY_MEDIUM security level.
[ Upstream commit 9260d3e1013701aa814d10c8fc6a9f92bd17d643 ]
It is possible for the timer handlers to run after the call to
ipv6_mc_down so use in6_dev_put instead of __in6_dev_put in the
handler function in order to do proper cleanup when the refcnt
reaches 0. Otherwise, the refcnt can reach zero without the
inet6_dev being destroyed and we end up leaking a reference to
the net_device and see messages like the following,
unregister_netdevice: waiting for eth0 to become free. Usage count = 1
Tested on linux-3.4.43.
Signed-off-by: Salam Noureddine <noureddine@aristanetworks.com>
[ Upstream commit e2401654dd0f5f3fb7a8d80dad9554d73d7ca394 ]
ip_mc_down so use in_dev_put instead of __in_dev_put in the handler
function in order to do proper cleanup when the refcnt reaches 0.
Otherwise, the refcnt can reach zero without the in_device being
destroyed and we end up leaking a reference to the net_device and
[ Upstream commit 2811ebac2521ceac84f2bdae402455baa6a7fb47 ]
In the following scenario the socket is corked:
If the first UDP packet is larger then the mtu we try to append it to the
write queue via ip6_ufo_append_data. A following packet, which is smaller
than the mtu would be appended to the already queued up gso-skb via
plain ip6_append_data. This causes random memory corruptions.
In ip6_ufo_append_data we also have to be careful to not queue up the
same skb multiple times. So setup the gso frame only when no first skb
is available.
This also fixes a shortcoming where we add the current packet's length to
cork->length but return early because of a packet > mtu with dontfrag set
(instead of sutracting it again).
Found with trinity.
Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
[ Upstream commit 703133de331a7a7df47f31fb9de51dc6f68a9de8 ]
If local fragmentation is allowed, then ip_select_ident() and
ip_select_ident_more() need to generate unique IDs to ensure
correct defragmentation on the peer.
For example, if IPsec (tunnel mode) has to encrypt large skbs
that have local_df bit set, then all IP fragments that belonged
to different ESP datagrams would have used the same identificator.
If one of these IP fragments would get lost or reordered, then
peer could possibly stitch together wrong IP fragments that did
not belong to the same datagram. This would lead to a packet loss
or data corruption.
Signed-off-by: Ansis Atteka <aatteka@nicira.com>
[ Upstream commit 749154aa56b57652a282cbde57a57abc278d1205 ]
skb->data already points to IP header, but for the sake of
consistency we can also use ip_hdr() to retrieve it.
[ Upstream commit be4f154d5ef0ca147ab6bcd38857a774133f5450 ]
At some point limits were added to forward_delay. However, the
limits are only enforced when STP is enabled. This created a
scenario where you could have a value outside the allowed range
while STP is disabled, which then stuck around even after STP
is enabled.
This patch fixes this by clamping the value when we enable STP.
I had to move the locking around a bit to ensure that there is
no window where someone could insert a value outside the range
while we're in the middle of enabling STP.
[ Upstream commit 9a0620133ccce9dd35c00a96405c8d80938c2cc0 ]
This changes the message_age_timer calculation to use the BPDU's max age as
opposed to the local bridge's max age. This is in accordance with section
8.6.2.3.2 Step 2 of the 802.1D-1998 sprecification.
With the current implementation, when running with very large bridge
diameters, convergance will not always occur even if a root bridge is
configured to have a longer max age.
Tested successfully on bridge diameters of ~200.
Signed-off-by: Chris Healy <cphealy@gmail.com>
[ Upstream commit 95ee62083cb6453e056562d91f597552021e6ae7 ]
Alan Chester reported an issue with IPv6 on SCTP that IPsec traffic is not
being encrypted, whereas on IPv4 it is. Setting up an AH + ESP transport
does not seem to have the desired effect:
SCTP + IPv4:
22:14:20.809645 IP (tos 0x2,ECT(0), ttl 64, id 0, offset 0, flags [DF], proto AH (51), length 116)
192.168.0.2 > 192.168.0.5: AH(spi=0x00000042,sumlen=16,seq=0x1): ESP(spi=0x00000044,seq=0x1), length 72
22:14:20.813270 IP (tos 0x2,ECT(0), ttl 64, id 0, offset 0, flags [DF], proto AH (51), length 340)
192.168.0.5 > 192.168.0.2: AH(spi=0x00000043,sumlen=16,seq=0x1):
SCTP + IPv6:
22:31:19.215029 IP6 (class 0x02, hlim 64, next-header SCTP (132) payload length: 364)
fe80::222:15ff:fe87:7fc.3333 > fe80::92e6:baff:fe0d:5a54.36767: sctp
1) [INIT ACK] [init tag: 747759530] [rwnd: 62464] [OS: 10] [MIS: 10]
Moreover, Alan says:
This problem was seen with both Racoon and Racoon2. Other people have seen
this with OpenSwan. When IPsec is configured to encrypt all upper layer
protocols the SCTP connection does not initialize. After using Wireshark to
follow packets, this is because the SCTP packet leaves Box A unencrypted and
Box B believes all upper layer protocols are to be encrypted so it drops
this packet, causing the SCTP connection to fail to initialize. When IPsec
is configured to encrypt just SCTP, the SCTP packets are observed unencrypted.
In fact, using `socat sctp6-listen:3333 -` on one end and transferring "plaintext"
string on the other end, results in cleartext on the wire where SCTP eventually
does not report any errors, thus in the latter case that Alan reports, the
non-paranoid user might think he's communicating over an encrypted transport on
SCTP although he's not (tcpdump ... -X):
0x0030: 5d70 8e1a 0003 001a 177d eb6c 0000 0000 ]p.......}.l....
0x0040: 0000 0000 706c 6169 6e74 6578 740a 0000 ....plaintext...
Only in /proc/net/xfrm_stat we can see XfrmInTmplMismatch increasing on the
receiver side. Initial follow-up analysis from Alan's bug report was done by
Alexey Dobriyan. Also thanks to Vlad Yasevich for feedback on this.
SCTP has its own implementation of sctp_v6_xmit() not calling inet6_csk_xmit().
This has the implication that it probably never really got updated along with
changes in inet6_csk_xmit() and therefore does not seem to invoke xfrm handlers.
SCTP's IPv4 xmit however, properly calls ip_queue_xmit() to do the work. Since
a call to inet6_csk_xmit() would solve this problem, but result in unecessary
route lookups, let us just use the cached flowi6 instead that we got through
sctp_v6_get_dst(). Since all SCTP packets are being sent through sctp_packet_transmit(),
we do the route lookup / flow caching in sctp_transport_route(), hold it in
tp->dst and skb_dst_set() right after that. If we would alter fl6->daddr in
sctp_v6_xmit() to np->opt->srcrt, we possibly could run into the same effect
of not having xfrm layer pick it up, hence, use fl6_update_dst() in sctp_v6_get_dst()
instead to get the correct source routed dst entry, which we assign to the skb.
Also source address routing example from 625034113 ("sctp: fix sctp to work with
ipv6 source address routing") still works with this patch! Nevertheless, in RFC5095
it is actually 'recommended' to not use that anyway due to traffic amplification [1].
So it seems we're not supposed to do that anyway in sctp_v6_xmit(). Moreover, if
we overwrite the flow destination here, the lower IPv6 layer will be unable to
put the correct destination address into IP header, as routing header is added in
ipv6_push_nfrag_opts() but then probably with wrong final destination. Things aside,
result of this patch is that we do not have any XfrmInTmplMismatch increase plus on
the wire with this patch it now looks like:
SCTP + IPv6:
08:17:47.074080 IP6 2620:52:0:102f:7a2b:cbff:fe27:1b0a > 2620:52:0:102f:213:72ff:fe32:7eba:
AH(spi=0x00005fb4,seq=0x1): ESP(spi=0x00005fb5,seq=0x1), length 72
08:17:47.074264 IP6 2620:52:0:102f:213:72ff:fe32:7eba > 2620:52:0:102f:7a2b:cbff:fe27:1b0a:
AH(spi=0x00003d54,seq=0x1): ESP(spi=0x00003d55,seq=0x1), length 296
This fixes Kernel Bugzilla 24412. This security issue seems to be present since
2.6.18 kernels. Lets just hope some big passive adversary in the wild didn't have
its fun with that. lksctp-tools IPv6 regression test suite passes as well with
this patch.
[1] http://www.secdev.org/conf/IPv6_RH_security-csw07.pdf
Reported-by: Alan Chester <alan.chester@tekelec.com>
Reported-by: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit d0fe8c888b1fd1a2f84b9962cabcb98a70988aec ]
I've been hitting a NULL ptr deref while using netconsole because the
np->dev check and the pointer manipulation in netpoll_cleanup are done
without rtnl and the following sequence happens when having a netconsole
over a vlan and we remove the vlan while disabling the netconsole:
CPU 1 CPU2
removes vlan and calls the notifier
enters store_enabled(), calls
netdev_cleanup which checks np->dev
and then waits for rtnl
executes the netconsole netdev
release notifier making np->dev
== NULL and releases rtnl
continues to dereference a member of
np->dev which at this point is == NULL
Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com>
[ Upstream commit b86783587b3d1d552326d955acee37eac48800f1 ]
In commit 8ed781668dd49 ("flow_keys: include thoff into flow_keys for
later usage"), we missed that existing code was using nhoff as a
temporary variable that could not always contain transport header
offset.
This is not a problem for TCP/UDP because port offset (@poff)
is 0 for these protocols.
Cc: Nikolay Aleksandrov <nikolay@redhat.com>
Acked-by: Nikolay Aleksandrov <nikolay@redhat.com>
Acked-by: Daniel Borkmann <dborkman@redhat.com>
[ Upstream commit 88362ad8f9a6cea787420b57cc27ccacef000dbe ]
This was originally reported in [1] and posted by Neil Horman [2], he said:
Fix up a missed null pointer check in the asconf code. If we don't find
a local address, but we pass in an address length of more than 1, we may
dereference a NULL laddr pointer. Currently this can't happen, as the only
users of the function pass in the value 1 as the addrcnt parameter, but
its not hot path, and it doesn't hurt to check for NULL should that ever
be the case.
The callpath from sctp_asconf_mgmt() looks okay. But this could be triggered
from sctp_setsockopt_bindx() call with SCTP_BINDX_REM_ADDR and addrcnt > 1
while passing all possible addresses from the bind list to SCTP_BINDX_REM_ADDR
so that we do *not* find a single address in the association's bind address
list that is not in the packed array of addresses. If this happens when we
have an established association with ASCONF-capable peers, then we could get
a NULL pointer dereference as we only check for laddr == NULL && addrcnt == 1
and call later sctp_make_asconf_update_ip() with NULL laddr.
BUT: this actually won't happen as sctp_bindx_rem() will catch such a case
and return with an error earlier. As this is incredably unintuitive and error
prone, add a check to catch at least future bugs here. As Neil says, its not
hot path. Introduced by 8a07eb0a5 ("sctp: Add ASCONF operation on the
single-homed host").
[1] http://www.spinics.net/lists/linux-sctp/msg02132.html
[2] http://www.spinics.net/lists/linux-sctp/msg02133.html
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Cc: Michio Honda <micchie@sfc.wide.ad.jp>
Acked-By: Neil Horman <nhorman@tuxdriver.com>
[ Upstream commit 0c1db731bfcf3a9fd6c58132134f8b0f423552f0 ]
The indentation here implies this was meant to be a multi-line if.
Introduced several years back in commit c85c2951d4da1236e32f1858db418221e624aba5
("caif: Handle dev_queue_xmit errors.")
Signed-off-by: Dave Jones <davej@fedoraproject.org>
This reverts commit c2f5b7507ac5d808f29287d77ee6148358d7fbfe which is
commit f6e80abeab928b7c47cc1fbf53df13b4398a2bec.
Michal writes:
Mainline commit f6e80abe was introduced in v3.7-rc2 as a
follow-up fix to commit
edfee033 sctp: check src addr when processing SACK to update transport state
(from v3.7-rc1) which changed the interpretation of third
argument to sctp_cmd_process_sack() and sctp_outq_sack(). But as
commit edfee033 has never been backported to stable branches,
backport of commit f6e80abe actually breaks the code rather than
fixing it.
Reported-by: Michal Kubecek <mkubecek@suse.cz>
Cc: Zijie Pan <zijie.pan@6wind.com>
Cc: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Cc: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit 4225a398c1352a7a5c14dc07277cb5cc4473983b ]
When the lockdep validator is enabled, it will report the below
warning when we enable a TIPC bearer:
[ INFO: possible irq lock inversion dependency detected ]
Possible interrupt unsafe locking scenario:
CPU0 CPU1
lock(ptype_lock);
local_irq_disable();
lock(tipc_net_lock);
lock(ptype_lock);
<Interrupt>
*** DEADLOCK ***
the shortest dependencies between 2nd lock and 1st lock:
-> (ptype_lock){+.+...} ops: 10 {
SOFTIRQ-ON-W at:
[<c1089418>] __lock_acquire+0x528/0x13e0
[<c108a360>] lock_acquire+0x90/0x100
[<c1553c38>] _raw_spin_lock+0x38/0x50
[<c14651ca>] dev_add_pack+0x3a/0x60
[<c182da75>] arp_init+0x1a/0x48
[<c182dce5>] inet_init+0x181/0x27e
[<c1001114>] do_one_initcall+0x34/0x170
[<c17f7329>] kernel_init+0x110/0x1b2
[<c155b6a2>] kernel_thread_helper+0x6/0x10
... key at: [<c17e4b10>] ptype_lock+0x10/0x20
... acquired at:
[<c8bc18d2>] enable_bearer+0xf2/0x140 [tipc]
[<c8bb283a>] tipc_enable_bearer+0x1ba/0x450 [tipc]
[<c8bb3a04>] tipc_cfg_do_cmd+0x5c4/0x830 [tipc]
[<c8bbc032>] handle_cmd+0x42/0xd0 [tipc]
[<c148e802>] genl_rcv_msg+0x232/0x280
[<c148d3f6>] netlink_rcv_skb+0x86/0xb0
[<c148e5bc>] genl_rcv+0x1c/0x30
[<c148d144>] netlink_unicast+0x174/0x1f0
[<c148ddab>] netlink_sendmsg+0x1eb/0x2d0
[<c1456bc1>] sock_aio_write+0x161/0x170
[<c1135a7c>] do_sync_write+0xac/0xf0
[<c11360f6>] vfs_write+0x156/0x170
[<c11361e2>] sys_write+0x42/0x70
[<c155b0df>] sysenter_do_call+0x12/0x38
-> (tipc_net_lock){+..-..} ops: 4 {
IN-SOFTIRQ-R at:
[<c108953a>] __lock_acquire+0x64a/0x13e0
[<c15541cd>] _raw_read_lock_bh+0x3d/0x50
[<c8bb874d>] tipc_recv_msg+0x1d/0x830 [tipc]
[<c8bc195f>] recv_msg+0x3f/0x50 [tipc]
[<c146a5fa>] __netif_receive_skb+0x22a/0x590
[<c146ab0b>] netif_receive_skb+0x2b/0xf0
[<c13c43d2>] pcnet32_poll+0x292/0x780
[<c146b00a>] net_rx_action+0xfa/0x1e0
[<c103a4be>] __do_softirq+0xae/0x1e0
>From the log, we can see three different call chains between
CPU0 and CPU1:
Time 0 on CPU0:
kernel_init()->inet_init()->dev_add_pack()
At time 0, the ptype_lock is held by CPU0 in dev_add_pack();
Time 1 on CPU1:
tipc_enable_bearer()->enable_bearer()->dev_add_pack()
At time 1, tipc_enable_bearer() first holds tipc_net_lock, and then
wants to take ptype_lock to register TIPC protocol handler into the
networking stack. But the ptype_lock has been taken by dev_add_pack()
on CPU0, so at this time the dev_add_pack() running on CPU1 has to be
busy looping.
Time 2 on CPU0:
netif_receive_skb()->recv_msg()->tipc_recv_msg()
At time 2, an incoming TIPC packet arrives at CPU0, hence
tipc_recv_msg() will be invoked. In tipc_recv_msg(), it first wants
to hold tipc_net_lock. At the moment, below scenario happens:
On CPU0, below is our sequence of taking locks:
lock(ptype_lock)->lock(tipc_net_lock)
On CPU1, our sequence of taking locks looks like:
lock(tipc_net_lock)->lock(ptype_lock)
Obviously deadlock may happen in this case.
But please note the deadlock possibly doesn't occur at all when the
first TIPC bearer is enabled. Before enable_bearer() -- running on
CPU1 does not hold ptype_lock, so the TIPC receive handler (i.e.
recv_msg()) is not registered successfully via dev_add_pack(), so
the tipc_recv_msg() cannot be called by recv_msg() even if a TIPC
message comes to CPU0. But when the second TIPC bearer is
registered, the deadlock can perhaps really happen.
To fix it, we will push the work of registering TIPC protocol
handler into workqueue context. After the change, both paths taking
ptype_lock are always in process contexts, thus, the deadlock should
never occur.
Signed-off-by: Ying Xue <ying.xue@windriver.com>
Signed-off-by: Jon Maloy <jon.maloy@ericsson.com>
[ Upstream commit 3a1c756590633c0e86df606e5c618c190926a0df ]
In tcp_v6_do_rcv() code, when processing pkt options, we soley work
on our skb clone opt_skb that we've created earlier before entering
tcp_rcv_established() on our way. However, only in condition ...
if (np->rxopt.bits.rxtclass)
np->rcv_tclass = ipv6_get_dsfield(ipv6_hdr(skb));
... we work on skb itself. As we extract every other information out
of opt_skb in ipv6_pktoptions path, this seems wrong, since skb can
already be released by tcp_rcv_established() earlier on. When we try
to access it in ipv6_hdr(), we will dereference freed skb.
[ Bug added by commit 4c507d2897bd9b ("net: implement IP_RECVTOS for
IP_PKTOPTIONS") ]
Acked-by: Jiri Benc <jbenc@redhat.com>
[ Upstream commit 61e76b178dbe7145e8d6afa84bb4ccea71918994 ]
RFC 4443 has defined two additional codes for ICMPv6 type 1 (destination
unreachable) messages:
5 - Source address failed ingress/egress policy
6 - Reject route to destination
Now they are treated as protocol error and icmpv6_err_convert() converts them
to EPROTO.
RFC 4443 says:
"Codes 5 and 6 are more informative subsets of code 1."
Treat codes 5 and 6 as code 1 (EACCES)
Btw, connect() returning -EPROTO confuses firefox, so that fallback to
other/IPv4 addresses does not work:
https://bugzilla.mozilla.org/show_bug.cgi?id=910773
Signed-off-by: Jiri Bohac <jbohac@suse.cz>
[ Upstream commit 2d98c29b6fb3de44d9eaa73c09f9cf7209346383 ]
While looking into MLDv1/v2 code, I noticed that bridging code does
not convert it's max delay into jiffies for MLDv2 messages as we do
in core IPv6' multicast code.
RFC3810, 5.1.3. Maximum Response Code says:
The Maximum Response Code field specifies the maximum time allowed
before sending a responding Report. The actual time allowed, called
the Maximum Response Delay, is represented in units of milliseconds,
and is derived from the Maximum Response Code as follows: [...]
As we update timers that work with jiffies, we need to convert it.
Cc: Linus Lüssing <linus.luessing@web.de>
[ Upstream commit 25a6e6b84fba601eff7c28d30da8ad7cfbef0d43 ]
Allocating skbs when sending out neighbour discovery messages
currently uses sock_alloc_send_skb() based on a per net namespace
socket and thus share a socket wmem buffer space.
If a netdevice is temporarily unable to transmit due to carrier
loss or for other reasons, the queued up ndisc messages will cosnume
all of the wmem space and will thus prevent from any more skbs to
be allocated even for netdevices that are able to transmit packets.
The number of neighbour discovery messages sent is very limited,
use of alloc_skb() bypasses the socket wmem buffer size enforcement
while the manual call to skb_set_owner_w() maintains the socket
reference needed for the IPv6 output path.
This patch has orginally been posted by Eric Dumazet in a modified
form.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Fabio Estevam <festevam@gmail.com>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
[ Upstream commit f46078cfcd77fa5165bf849f5e568a7ac5fa569c ]
It is not allowed for an ipv6 packet to contain multiple fragmentation
headers. So discard packets which were already reassembled by
fragmentation logic and send back a parameter problem icmp.
The updates for RFC 6980 will come in later, I have to do a bit more
research here.
[ Upstream commit 4b08a8f1bd8cb4541c93ec170027b4d0782dab52 ]
Because of the max_addresses check attackers were able to disable privacy
extensions on an interface by creating enough autoconfigured addresses:
<http://seclists.org/oss-sec/2012/q4/292>
But the check is not actually needed: max_addresses protects the
kernel to install too many ipv6 addresses on an interface and guards
addrconf_prefix_rcv to install further addresses as soon as this limit
is reached. We only generate temporary addresses in direct response of
a new address showing up. As soon as we filled up the maximum number of
addresses of an interface, we stop installing more addresses and thus
also stop generating more temp addresses.
Even if the attacker tries to generate a lot of temporary addresses
by announcing a prefix and removing it again (lifetime == 0) we won't
install more temp addresses, because the temporary addresses do count
to the maximum number of addresses, thus we would stop installing new
autoconfigured addresses when the limit is reached.
This patch fixes CVE-2013-0343 (but other layer-2 attacks are still
possible).
Thanks to Ding Tianhong to bring this topic up again.
Cc: Ding Tianhong <dingtianhong@huawei.com>
Cc: George Kargiotakis <kargig@void.gr>
Cc: P J P <ppandit@redhat.com>
Acked-by: Ding Tianhong <dingtianhong@huawei.com>
[ Upstream commit 3e3be275851bc6fc90bfdcd732cd95563acd982b ]
In case a subtree did not match we currently stop backtracking and return
NULL (root table from fib_lookup). This could yield in invalid routing
table lookups when using subtrees.
Instead continue to backtrack until a valid subtree or node is found
and return this match.
Also remove unneeded NULL check.
Reported-by: Teco Boot <teco@inf-net.nl>
Cc: David Lamparter <equinox@diac24.net>
Cc: <boutier@pps.univ-paris-diderot.fr>
[ Upstream commit cd6b423afd3c08b27e1fed52db828ade0addbc6b ]
While investigating about strange increase of retransmit rates
on hosts ~24 days after boot, Van found hystart was disabled
if ca->epoch_start was 0, as following condition is true
when tcp_time_stamp high order bit is set.
(s32)(tcp_time_stamp - ca->epoch_start) < HZ
Quoting Van :
At initialization & after every loss ca->epoch_start is set to zero so
I believe that the above line will turn off hystart as soon as the 2^31
bit is set in tcp_time_stamp & hystart will stay off for 24 days.
I think we've observed that cubic's restart is too aggressive without
hystart so this might account for the higher drop rate we observe.
Diagnosed-by: Van Jacobson <vanj@google.com>
Cc: Neal Cardwell <ncardwell@google.com>
[ Upstream commit 2ed0edf9090bf4afa2c6fc4f38575a85a80d4b20 ]
commit 17a6e9f1aa9 ("tcp_cubic: fix clock dependency") added an
overflow error in bictcp_update() in following code :
/* change the unit from HZ to bictcp_HZ */
t = ((tcp_time_stamp + msecs_to_jiffies(ca->delay_min>>3) -
ca->epoch_start) << BICTCP_HZ) / HZ;
Because msecs_to_jiffies() being unsigned long, compiler does
implicit type promotion.
We really want to constrain (tcp_time_stamp - ca->epoch_start)
to a signed 32bit value, or else 't' has unexpected high values.
This bugs triggers an increase of retransmit rates ~24 days after
boot [1], as the high order bit of tcp_time_stamp flips.
[1] for hosts with HZ=1000
Big thanks to Van Jacobson for spotting this problem.
Cc: Stephen Hemminger <stephen@networkplumber.org>
[ Upstream commit aab515d7c32a34300312416c50314e755ea6f765 ]
AddressSanitizer [1] dynamic checker pointed a potential
out of bound access in leaf_walk_rcu()
We could allocate one more slot in tnode_new() to leave the prefetch()
in-place but it looks not worth the pain.
Bug added in commit 82cfbb008572b ("[IPV4] fib_trie: iterator recode")
[1] :
https://code.google.com/p/address-sanitizer/wiki/AddressSanitizerForKernel
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
[ Upstream commit 63134803a6369dcf7dddf7f0d5e37b9566b308d2 ]
dev->ndo_neigh_setup() might need some of the values of neigh_parms, so
populate them before calling it.
Signed-off-by: Veaceslav Falico <vfalico@redhat.com>
[ Upstream commit 5f671d6b4ec3e6d66c2a868738af2cdea09e7509 ]
It's possible to assign an invalid value to the net.core.somaxconn
sysctl variable, because there is no checks at all.
The sk_max_ack_backlog field of the sock structure is defined as
unsigned short. Therefore, the backlog argument in inet_listen()
shouldn't exceed USHRT_MAX. The backlog argument in the listen() syscall
is truncated to the somaxconn value. So, the somaxconn value shouldn't
exceed 65535 (USHRT_MAX).
Also, negative values of somaxconn are meaningless.
before:
$ sysctl -w net.core.somaxconn=256
net.core.somaxconn = 256
$ sysctl -w net.core.somaxconn=65536
net.core.somaxconn = 65536
$ sysctl -w net.core.somaxconn=-100
net.core.somaxconn = -100
after:
error: "Invalid argument" setting key "net.core.somaxconn"
Based on a prior patch from Changli Gao.
Signed-off-by: Roman Gushchin <klamm@yandex-team.ru>
Reported-by: Changli Gao <xiaosuo@gmail.com>
Suggested-by: Eric Dumazet <edumazet@google.com>
[ Upstream commit cbd375567f7e4811b1c721f75ec519828ac6583f ]
When userspace passes a large priority value
the assignment of the unsigned value hopt->prio
to signed int cl->prio causes cl->prio to become negative and the
comparison is with TC_HTB_NUMPRIO is always false.
The result is that HTB crashes by referencing outside
the array when processing packets. With this patch the large value
wraps around like other values outside the normal range.
See: https://bugzilla.kernel.org/show_bug.cgi?id=60669
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
commit 347e2233b7667e336d9f671f1a52dfa3f0416e2c upstream.
Some architectures, such as ARM-32 do not return the same base address
when you call kmap_atomic() twice on the same page.
This causes problems for the memmove() call in the XDR helper routine
"_shift_data_right_pages()", since it defeats the detection of
overlapping memory ranges, and has been seen to corrupt memory.
The fix is to distinguish between the case where we're doing an
inter-page copy or not. In the former case of we know that the memory
ranges cannot possibly overlap, so we can additionally micro-optimise
by replacing memmove() with memcpy().
Reported-by: Mark Young <MYoung@nvidia.com>
Reported-by: Matt Craighead <mcraighead@nvidia.com>
Cc: Bruce Fields <bfields@fieldses.org>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Tested-by: Matt Craighead <mcraighead@nvidia.com>
commit 85dfb745ee40232876663ae206cba35f24ab2a40 upstream.
This field was left uninitialized. Some user daemons perform check against this
field.
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
Cc: Luis Henriques <luis.henriques@canonical.com>
