path: root/net
2015-11-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix list tests in netfilter ingress support, from Florian Westphal. 2) Fix reversal of input and output interfaces in ingress hook invocation, from Pablo Neira Ayuso. 3) We have a use after free in r8169, caught by Dave Jones, fixed by Francois Romieu. 4) Splice use-after-free fix in AF_UNIX frmo Hannes Frederic Sowa. 5) Three ipv6 route handling bug fixes from Martin KaFai Lau: a) Don't create clone routes not managed by the fib6 tree b) Don't forget to check expiration of DST_NOCACHE routes. c) Handle rt->dst.from == NULL properly. 6) Several AF_PACKET fixes wrt transport header setting and SKB protocol setting, from Daniel Borkmann. 7) Fix thunder driver crash on shutdown, from Pavel Fedin. 8) Several Mellanox driver fixes (max MTU calculations, use of correct DMA unmap in TX path, etc.) from Saeed Mahameed, Tariq Toukan, Doron Tsur, Achiad Shochat, Eran Ben Elisha, and Noa Osherovich. 9) Several mv88e6060 DSA driver fixes (wrong bit definitions for certain registers, etc.) from Neil Armstrong. 10) Make sure to disable preemption while updating per-cpu stats of ip tunnels, from Jason A. Donenfeld. 11) Various ARM64 bpf JIT fixes, from Yang Shi. 12) Flush icache properly in ARM JITs, from Daniel Borkmann. 13) Fix masking of RX and TX interrupts in ravb driver, from Masaru Nagai. 14) Fix netdev feature propagation for devices not implementing ->ndo_set_features(). From Nikolay Aleksandrov. 15) Big endian fix in vmxnet3 driver, from Shrikrishna Khare. 16) RAW socket code increments incorrect SNMP counters, fix from Ben Cartwright-Cox. 17) IPv6 multicast SNMP counters are bumped twice, fix from Neil Horman. 18) Fix handling of VLAN headers on stacked devices when REORDER is disabled. From Vlad Yasevich. 19) Fix SKB leaks and use-after-free in ipvlan and macvlan drivers, from Sabrina Dubroca. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (83 commits) MAINTAINERS: Update Mellanox's Eth NIC driver entries net/core: revert "net: fix __netdev_update_features return.." and add comment af_unix: take receive queue lock while appending new skb rtnetlink: fix frame size warning in rtnl_fill_ifinfo net: use skb_clone to avoid alloc_pages failure. packet: Use PAGE_ALIGNED macro packet: Don't check frames_per_block against negative values net: phy: Use interrupts when available in NOLINK state phy: marvell: Add support for 88E1540 PHY arm64: bpf: make BPF prologue and epilogue align with ARM64 AAPCS macvlan: fix leak in macvlan_handle_frame ipvlan: fix use after free of skb ipvlan: fix leak in ipvlan_rcv_frame vlan: Do not put vlan headers back on bridge and macvlan ports vlan: Fix untag operations of stacked vlans with REORDER_HEADER off via-velocity: unconditionally drop frames with bad l2 length ipg: Remove ipg driver dl2k: Add support for IP1000A-based cards snmp: Remove duplicate OUTMCAST stat increment net: thunder: Check for driver data in nicvf_remove() ...
2015-11-17net/core: revert "net: fix __netdev_update_features return.." and add commentNikolay Aleksandrov
This reverts commit 00ee59271777 ("net: fix __netdev_update_features return on ndo_set_features failure") and adds a comment explaining why it's okay to return a value other than 0 upon error. Some drivers might actually change flags and return an error so it's better to fire a spurious notification rather than miss these. CC: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-17af_unix: take receive queue lock while appending new skbHannes Frederic Sowa
While possibly in future we don't necessarily need to use sk_buff_head.lock this is a rather larger change, as it affects the af_unix fd garbage collector, diag and socket cleanups. This is too much for a stable patch. For the time being grab sk_buff_head.lock without disabling bh and irqs, so don't use locked skb_queue_tail. Fixes: 869e7c62486e ("net: af_unix: implement stream sendpage support") Cc: Eric Dumazet <edumazet@google.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Reported-by: Eric Dumazet <edumazet@google.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-17rtnetlink: fix frame size warning in rtnl_fill_ifinfoHannes Frederic Sowa
Fix the following warning: CC net/core/rtnetlink.o net/core/rtnetlink.c: In function ‘rtnl_fill_ifinfo’: net/core/rtnetlink.c:1308:1: warning: the frame size of 2864 bytes is larger than 2048 bytes [-Wframe-larger-than=] } ^ by splitting up the huge rtnl_fill_ifinfo into some smaller ones, so we don't have the huge frame allocations at the same time. Cc: Eric Dumazet <edumazet@google.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-17net: use skb_clone to avoid alloc_pages failure.Martin Zhang
1. new skb only need dst and ip address(v4 or v6). 2. skb_copy may need high order pages, which is very rare on long running server. Signed-off-by: Junwei Zhang <linggao.zjw@alibaba-inc.com> Signed-off-by: Martin Zhang <martinbj2008@gmail.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-17packet: Use PAGE_ALIGNED macroTobias Klauser
Use PAGE_ALIGNED(...) instead of open-coding it. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-17packet: Don't check frames_per_block against negative valuesTobias Klauser
rb->frames_per_block is an unsigned int, thus can never be negative. Also fix spacing in the calculation of frames_per_block. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-17vlan: Do not put vlan headers back on bridge and macvlan portsVlad Yasevich
When a vlan is configured with REORDER_HEADER set to 0, the vlan header is put back into the packet and makes it appear that the vlan header is still there even after it's been processed. This posses a problem for bridge and macvlan ports. The packets passed to those device may be forwarded and at the time of the forward, vlan headers end up being unexpectedly present. With the patch, we make sure that we do not put the vlan header back (when REORDER_HEADER is 0) if a bridge or macvlan has been configured on top of the vlan device. Signed-off-by: Vladislav Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-17vlan: Fix untag operations of stacked vlans with REORDER_HEADER offVlad Yasevich
When we have multiple stacked vlan devices all of which have turned off REORDER_HEADER flag, the untag operation does not locate the ethernet addresses correctly for nested vlans. The reason is that in case of REORDER_HEADER flag being off, the outer vlan headers are put back and the mac_len is adjusted to account for the presense of the header. Then, the subsequent untag operation, for the next level vlan, always use VLAN_ETH_HLEN to locate the begining of the ethernet header and that ends up being a multiple of 4 bytes short of the actuall beginning of the mac header (the multiple depending on the how many vlan encapsulations ethere are). As a reslult, if there are multiple levles of vlan devices with REODER_HEADER being off, the recevied packets end up being dropped. To solve this, we use skb->mac_len as the offset. The value is always set on receive path and starts out as a ETH_HLEN. The value is also updated when the vlan header manupations occur so we know it will be correct. Signed-off-by: Vladislav Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-16snmp: Remove duplicate OUTMCAST stat incrementNeil Horman
the OUTMCAST stat is double incremented, getting bumped once in the mcast code itself, and again in the common ip output path. Remove the mcast bump, as its not needed Validated by the reporter, with good results Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Reported-by: Claus Jensen <claus.jensen@microsemi.com> CC: Claus Jensen <claus.jensen@microsemi.com> CC: David Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-16net/core: use netdev name in warning if no parentBjørn Mork
A recent flaw in the netdev feature setting resulted in warnings like this one from VLAN interfaces: WARNING: CPU: 1 PID: 4975 at net/core/dev.c:2419 skb_warn_bad_offload+0xbc/0xcb() : caps=(0x00000000001b5820, 0x00000000001b5829) len=2782 data_len=0 gso_size=1348 gso_type=16 ip_summed=3 The ":" is supposed to be preceded by a driver name, but in this case it is an empty string since the device has no parent. There are many types of network devices without a parent. The anonymous warnings for these devices can be hard to debug. Log the network device name instead in these cases to assist further debugging. This is mostly similar to how __netdev_printk() handles orphan devices. Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-16af_unix: don't append consumed skbs to sk_receive_queueHannes Frederic Sowa
In case multiple writes to a unix stream socket race we could end up in a situation where we pre-allocate a new skb for use in unix_stream_sendpage but have to free it again in the locked section because another skb has been appended meanwhile, which we must use. Accidentally we didn't clear the pointer after consuming it and so we touched freed memory while appending it to the sk_receive_queue. So, clear the pointer after consuming the skb. This bug has been found with syzkaller (http://github.com/google/syzkaller) by Dmitry Vyukov. Fixes: 869e7c62486e ("net: af_unix: implement stream sendpage support") Reported-by: Dmitry Vyukov <dvyukov@google.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-16raw: increment correct SNMP counters for ICMP messagesBen Cartwright-Cox
Sending ICMP packets with raw sockets ends up in the SNMP counters logging the type as the first byte of the IPv4 header rather than the ICMP header. This is fixed by adding the IP Header Length to the casting into a icmphdr struct. Signed-off-by: Ben Cartwright-Cox <ben@benjojo.co.uk> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-16net: fix __netdev_update_features return on ndo_set_features failureNikolay Aleksandrov
If ndo_set_features fails __netdev_update_features() will return -1 but this is wrong because it is expected to return 0 if no features were changed (see netdev_update_features()), which will cause a netdev notifier to be called without any actual changes. Fix this by returning 0 if ndo_set_features fails. Fixes: 6cb6a27c45ce ("net: Call netdev_features_change() from netdev_update_features()") CC: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-16net: fix feature changes on devices without ndo_set_featuresNikolay Aleksandrov
When __netdev_update_features() was updated to ensure some features are disabled on new lower devices, an error was introduced for devices which don't have the ndo_set_features() method set. Before we'll just set the new features, but now we return an error and don't set them. Fix this by returning the old behaviour and setting err to 0 when ndo_set_features is not present. Fixes: e7868a85e1b2 ("net/core: ensure features get disabled on new lower devs") CC: Jarod Wilson <jarod@redhat.com> CC: Jiri Pirko <jiri@resnulli.us> CC: Ido Schimmel <idosch@mellanox.com> CC: Sander Eikelenboom <linux@eikelenboom.it> CC: Andy Gospodarek <gospo@cumulusnetworks.com> CC: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com> Reviewed-by: Jiri Pirko <jiri@mellanox.com> Reviewed-by: Andy Gospodarek <gospo@cumulusnetworks.com> Reviewed-by: Jarod Wilson <jarod@redhat.com> Tested-by: Florian Fainelli <f.fainelli@gmail.com> Tested-by: Dave Young <dyoung@redhat.com> Tested-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-16switchdev: bridge: Check return code is not EOPNOTSUPPIdo Schimmel
When NET_SWITCHDEV=n, switchdev_port_attr_set simply returns EOPNOTSUPP. In this case we should not emit errors and warnings to the kernel log. Reported-by: Sander Eikelenboom <linux@eikelenboom.it> Tested-by: Christian Borntraeger <borntraeger@de.ibm.com> Fixes: 0bc05d585d38 ("switchdev: allow caller to explicitly request attr_set as deferred") Fixes: 6ac311ae8bfb ("Adding switchdev ageing notification on port bridged") Signed-off-by: Ido Schimmel <idosch@mellanox.com> Signed-off-by: Jiri Pirko <jiri@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-15ipvs: use skb_to_full_sk() helperEric Dumazet
SYNACK packets might be attached to request sockets. Use skb_to_full_sk() helper to avoid illegal accesses to inet_sk(skb->sk) Fixes: ca6fb0651883 ("tcp: attach SYNACK messages to request sockets instead of listener") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Sander Eikelenboom <linux@eikelenboom.it> Acked-by: Julian Anastasov <ja@ssi.bg> Acked-by: Simon Horman <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-15tcp: ensure proper barriers in lockless contextsEric Dumazet
Some functions access TCP sockets without holding a lock and might output non consistent data, depending on compiler and or architecture. tcp_diag_get_info(), tcp_get_info(), tcp_poll(), get_tcp4_sock() ... Introduce sk_state_load() and sk_state_store() to fix the issues, and more clearly document where this lack of locking is happening. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-15sctp: translate host order to network order when setting a hmacidlucien
now sctp auth cannot work well when setting a hmacid manually, which is caused by that we didn't use the network order for hmacid, so fix it by adding the transformation in sctp_auth_ep_set_hmacs. even we set hmacid with the network order in userspace, it still can't work, because of this condition in sctp_auth_ep_set_hmacs(): if (id > SCTP_AUTH_HMAC_ID_MAX) return -EOPNOTSUPP; so this wasn't working before and thus it won't break compatibility. Fixes: 65b07e5d0d09 ("[SCTP]: API updates to suport SCTP-AUTH extensions.") Signed-off-by: Xin Long <lucien.xin@gmail.com> Signed-off-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-15packet: fix tpacket_snd max frame lenDaniel Borkmann
Since it's introduction in commit 69e3c75f4d54 ("net: TX_RING and packet mmap"), TX_RING could be used from SOCK_DGRAM and SOCK_RAW side. When used with SOCK_DGRAM only, the size_max > dev->mtu + reserve check should have reserve as 0, but currently, this is unconditionally set (in it's original form as dev->hard_header_len). I think this is not correct since tpacket_fill_skb() would then take dev->mtu and dev->hard_header_len into account for SOCK_DGRAM, the extra VLAN_HLEN could be possible in both cases. Presumably, the reserve code was copied from packet_snd(), but later on missed the check. Make it similar as we have it in packet_snd(). Fixes: 69e3c75f4d54 ("net: TX_RING and packet mmap") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-15packet: infer protocol from ethernet header if unsetDaniel Borkmann
In case no struct sockaddr_ll has been passed to packet socket's sendmsg() when doing a TX_RING flush run, then skb->protocol is set to po->num instead, which is the protocol passed via socket(2)/bind(2). Applications only xmitting can go the path of allocating the socket as socket(PF_PACKET, <mode>, 0) and do a bind(2) on the TX_RING with sll_protocol of 0. That way, register_prot_hook() is neither called on creation nor on bind time, which saves cycles when there's no interest in capturing anyway. That leaves us however with po->num 0 instead and therefore the TX_RING flush run sets skb->protocol to 0 as well. Eric reported that this leads to problems when using tools like trafgen over bonding device. I.e. the bonding's hash function could invoke the kernel's flow dissector, which depends on skb->protocol being properly set. In the current situation, all the traffic is then directed to a single slave. Fix it up by inferring skb->protocol from the Ethernet header when not set and we have ARPHRD_ETHER device type. This is only done in case of SOCK_RAW and where we have a dev->hard_header_len length. In case of ARPHRD_ETHER devices, this is guaranteed to cover ETH_HLEN, and therefore being accessed on the skb after the skb_store_bits(). Reported-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-15packet: only allow extra vlan len on ethernet devicesDaniel Borkmann
Packet sockets can be used by various net devices and are not really restricted to ARPHRD_ETHER device types. However, when currently checking for the extra 4 bytes that can be transmitted in VLAN case, our assumption is that we generally probe on ARPHRD_ETHER devices. Therefore, before looking into Ethernet header, check the device type first. This also fixes the issue where non-ARPHRD_ETHER devices could have no dev->hard_header_len in TX_RING SOCK_RAW case, and thus the check would test unfilled linear part of the skb (instead of non-linear). Fixes: 57f89bfa2140 ("network: Allow af_packet to transmit +4 bytes for VLAN packets.") Fixes: 52f1454f629f ("packet: allow to transmit +4 byte in TX_RING slot for VLAN case") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-15packet: always probe for transport headerDaniel Borkmann
We concluded that the skb_probe_transport_header() should better be called unconditionally. Avoiding the call into the flow dissector has also not really much to do with the direct xmit mode. While it seems that only virtio_net code makes use of GSO from non RX/TX ring packet socket paths, we should probe for a transport header nevertheless before they hit devices. Reference: http://thread.gmane.org/gmane.linux.network/386173/ Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Jason Wang <jasowang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-15packet: do skb_probe_transport_header when we actually have dataDaniel Borkmann
In tpacket_fill_skb() commit c1aad275b029 ("packet: set transport header before doing xmit") and later on 40893fd0fd4e ("net: switch to use skb_probe_transport_header()") was probing for a transport header on the skb from a ring buffer slot, but at a time, where the skb has _not even_ been filled with data yet. So that call into the flow dissector is pretty useless. Lets do it after we've set up the skb frags. Fixes: c1aad275b029 ("packet: set transport header before doing xmit") Reported-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Jason Wang <jasowang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-15ipv6: Check rt->dst.from for the DST_NOCACHE routeMartin KaFai Lau
All DST_NOCACHE rt6_info used to have rt->dst.from set to its parent. After commit 8e3d5be73681 ("ipv6: Avoid double dst_free"), DST_NOCACHE is also set to rt6_info which does not have a parent (i.e. rt->dst.from is NULL). This patch catches the rt->dst.from == NULL case. Fixes: 8e3d5be73681 ("ipv6: Avoid double dst_free") Signed-off-by: Martin KaFai Lau <kafai@fb.com> Cc: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-15ipv6: Check expire on DST_NOCACHE routeMartin KaFai Lau
Since the expires of the DST_NOCACHE rt can be set during the ip6_rt_update_pmtu(), we also need to consider the expires value when doing ip6_dst_check(). This patches creates __rt6_check_expired() to only check the expire value (if one exists) of the current rt. In rt6_dst_from_check(), it adds __rt6_check_expired() as one of the condition check. Signed-off-by: Martin KaFai Lau <kafai@fb.com> Cc: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-15ipv6: Avoid creating RTF_CACHE from a rt that is not managed by fib6 treeMartin KaFai Lau
The original bug report: https://bugzilla.redhat.com/show_bug.cgi?id=1272571 The setup has a IPv4 GRE tunnel running in a IPSec. The bug happens when ndisc starts sending router solicitation at the gre interface. The simplified oops stack is like: __lock_acquire+0x1b2/0x1c30 lock_acquire+0xb9/0x140 _raw_write_lock_bh+0x3f/0x50 __ip6_ins_rt+0x2e/0x60 ip6_ins_rt+0x49/0x50 ~~~~~~~~ __ip6_rt_update_pmtu.part.54+0x145/0x250 ip6_rt_update_pmtu+0x2e/0x40 ~~~~~~~~ ip_tunnel_xmit+0x1f1/0xf40 __gre_xmit+0x7a/0x90 ipgre_xmit+0x15a/0x220 dev_hard_start_xmit+0x2bd/0x480 __dev_queue_xmit+0x696/0x730 dev_queue_xmit+0x10/0x20 neigh_direct_output+0x11/0x20 ip6_finish_output2+0x21f/0x770 ip6_finish_output+0xa7/0x1d0 ip6_output+0x56/0x190 ~~~~~~~~ ndisc_send_skb+0x1d9/0x400 ndisc_send_rs+0x88/0xc0 ~~~~~~~~ The rt passed to ip6_rt_update_pmtu() is created by icmp6_dst_alloc() and it is not managed by the fib6 tree, so its rt6i_table == NULL. When __ip6_rt_update_pmtu() creates a RTF_CACHE clone, the newly created clone also has rt6i_table == NULL and it causes the ip6_ins_rt() oops. During pmtu update, we only want to create a RTF_CACHE clone from a rt which is currently managed (or owned) by the fib6 tree. It means either rt->rt6i_node != NULL or rt is a RTF_PCPU clone. It is worth to note that rt6i_table may not be NULL even it is not (yet) managed by the fib6 tree (e.g. addrconf_dst_alloc()). Hence, rt6i_node is a better check instead of rt6i_table. Fixes: 45e4fd26683c ("ipv6: Only create RTF_CACHE routes after encountering pmtu") Signed-off-by: Martin KaFai Lau <kafai@fb.com> Reported-by: Chris Siebenmann <cks-rhbugzilla@cs.toronto.edu> Cc: Chris Siebenmann <cks-rhbugzilla@cs.toronto.edu> Cc: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-15af-unix: fix use-after-free with concurrent readers while splicingHannes Frederic Sowa
During splicing an af-unix socket to a pipe we have to drop all af-unix socket locks. While doing so we allow another reader to enter unix_stream_read_generic which can read, copy and finally free another skb. If exactly this skb is just in process of being spliced we get a use-after-free report by kasan. First, we must make sure to not have a free while the skb is used during the splice operation. We simply increment its use counter before unlocking the reader lock. Stream sockets have the nice characteristic that we don't care about zero length writes and they never reach the peer socket's queue. That said, we can take the UNIXCB.consumed field as the indicator if the skb was already freed from the socket's receive queue. If the skb was fully consumed after we locked the reader side again we know it has been dropped by a second reader. We indicate a short read to user space and abort the current splice operation. This bug has been found with syzkaller (http://github.com/google/syzkaller) by Dmitry Vyukov. Fixes: 2b514574f7e8 ("net: af_unix: implement splice for stream af_unix sockets") Reported-by: Dmitry Vyukov <dvyukov@google.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client Pull Ceph updates from Sage Weil: "There are several patches from Ilya fixing RBD allocation lifecycle issues, a series adding a nocephx_sign_messages option (and associated bug fixes/cleanups), several patches from Zheng improving the (directory) fsync behavior, a big improvement in IO for direct-io requests when striping is enabled from Caifeng, and several other small fixes and cleanups" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: libceph: clear msg->con in ceph_msg_release() only libceph: add nocephx_sign_messages option libceph: stop duplicating client fields in messenger libceph: drop authorizer check from cephx msg signing routines libceph: msg signing callouts don't need con argument libceph: evaluate osd_req_op_data() arguments only once ceph: make fsync() wait unsafe requests that created/modified inode ceph: add request to i_unsafe_dirops when getting unsafe reply libceph: introduce ceph_x_authorizer_cleanup() ceph: don't invalidate page cache when inode is no longer used rbd: remove duplicate calls to rbd_dev_mapping_clear() rbd: set device_type::release instead of device::release rbd: don't free rbd_dev outside of the release callback rbd: return -ENOMEM instead of pool id if rbd_dev_create() fails libceph: use local variable cursor instead of &msg->cursor libceph: remove con argument in handle_reply() ceph: combine as many iovec as possile into one OSD request ceph: fix message length computation ceph: fix a comment typo rbd: drop null test before destroy functions
2015-11-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nfDavid S. Miller
Pablo Neira Ayuso: ==================== Netfilter fixes for net The following patchset contains Netfilter fixes for your net tree. This large batch that includes fixes for ipset, netfilter ingress, nf_tables dynamic set instantiation and a longstanding Kconfig dependency problem. More specifically, they are: 1) Add missing check for empty hook list at the ingress hook, from Florian Westphal. 2) Input and output interface are swapped at the ingress hook, reported by Patrick McHardy. 3) Resolve ipset extension alignment issues on ARM, patch from Jozsef Kadlecsik. 4) Fix bit check on bitmap in ipset hash type, also from Jozsef. 5) Release buckets when all entries have expired in ipset hash type, again from Jozsef. 6) Oneliner to initialize conntrack tuple object in the PPTP helper, otherwise the conntrack lookup may fail due to random bits in the structure holes, patch from Anthony Lineham. 7) Silence a bogus gcc warning in nfnetlink_log, from Arnd Bergmann. 8) Fix Kconfig dependency problems with TPROXY, socket and dup, also from Arnd. 9) Add __netdev_alloc_pcpu_stats() to allow creating percpu counters from atomic context, this is required by the follow up fix for nf_tables. 10) Fix crash from the dynamic set expression, we have to add new clone operation that should be defined when a simple memcpy is not enough. This resolves a crash when using per-cpu counters with new Patrick McHardy's flow table nft support. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-11Merge tag 'nfsd-4.4' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd updates from Bruce Fields: "Apologies for coming a little late in the merge window. Fortunately this is another fairly quiet one: Mainly smaller bugfixes and cleanup. We're still finding some bugs from the breakup of the big NFSv4 state lock in 3.17 -- thanks especially to Andrew Elble and Jeff Layton for tracking down some of the remaining races" * tag 'nfsd-4.4' of git://linux-nfs.org/~bfields/linux: svcrpc: document lack of some memory barriers nfsd: fix race with open / open upgrade stateids nfsd: eliminate sending duplicate and repeated delegations nfsd: remove recurring workqueue job to clean DRC SUNRPC: drop stale comment in svc_setup_socket() nfsd: ensure that seqid morphing operations are atomic wrt to copies nfsd: serialize layout stateid morphing operations nfsd: improve client_has_state to check for unused openowners nfsd: fix clid_inuse on mount with security change sunrpc/cache: make cache flushing more reliable. nfsd: move include of state.h from trace.c to trace.h sunrpc: avoid warning in gss_key_timeout lockd: get rid of reference-counted NSM RPC clients SUNRPC: Use MSG_SENDPAGE_NOTLAST when calling sendpage() lockd: create NSM handles per net namespace nfsd: switch unsigned char flags in svc_fh to bools nfsd: move svc_fh->fh_maxsize to just after fh_handle nfsd: drop null test before destroy functions nfsd: serialize state seqid morphing operations
2015-11-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix null deref in xt_TEE netfilter module, from Eric Dumazet. 2) Several spots need to get to the original listner for SYN-ACK packets, most spots got this ok but some were not. Whilst covering the remaining cases, create a helper to do this. From Eric Dumazet. 3) Missiing check of return value from alloc_netdev() in CAIF SPI code, from Rasmus Villemoes. 4) Don't sleep while != TASK_RUNNING in macvtap, from Vlad Yasevich. 5) Use after free in mvneta driver, from Justin Maggard. 6) Fix race on dst->flags access in dst_release(), from Eric Dumazet. 7) Add missing ZLIB_INFLATE dependency for new qed driver. From Arnd Bergmann. 8) Fix multicast getsockopt deadlock, from WANG Cong. 9) Fix deadlock in btusb, from Kuba Pawlak. 10) Some ipv6_add_dev() failure paths were not cleaning up the SNMP6 counter state. From Sabrina Dubroca. 11) Fix packet_bind() race, which can cause lost notifications, from Francesco Ruggeri. 12) Fix MAC restoration in qlcnic driver during bonding mode changes, from Jarod Wilson. 13) Revert bridging forward delay change which broke libvirt and other userspace things, from Vlad Yasevich. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (65 commits) Revert "bridge: Allow forward delay to be cfgd when STP enabled" bpf_trace: Make dependent on PERF_EVENTS qed: select ZLIB_INFLATE net: fix a race in dst_release() net: mvneta: Fix memory use after free. net: Documentation: Fix default value tcp_limit_output_bytes macvtap: Resolve possible __might_sleep warning in macvtap_do_read() mvneta: add FIXED_PHY dependency net: caif: check return value of alloc_netdev net: hisilicon: NET_VENDOR_HISILICON should depend on HAS_DMA drivers: net: xgene: fix RGMII 10/100Mb mode netfilter: nft_meta: use skb_to_full_sk() helper net_sched: em_meta: use skb_to_full_sk() helper sched: cls_flow: use skb_to_full_sk() helper netfilter: xt_owner: use skb_to_full_sk() helper smack: use skb_to_full_sk() helper net: add skb_to_full_sk() helper and use it in selinux_netlbl_skbuff_setsid() bpf: doc: correct arch list for supported eBPF JIT dwc_eth_qos: Delete an unnecessary check before the function call "of_node_put" bonding: fix panic on non-ARPHRD_ETHER enslave failure ...
2015-11-10netfilter: nf_tables: add clone interface to expression operationsPablo Neira Ayuso
With the conversion of the counter expressions to make it percpu, we need to clone the percpu memory area, otherwise we crash when using counters from flow tables. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-11-10netfilter: fix xt_TEE and xt_TPROXY dependenciesArnd Bergmann
Kconfig is too smart for its own good: a Kconfig line that states select NF_DEFRAG_IPV6 if IP6_NF_IPTABLES means that if IP6_NF_IPTABLES is set to 'm', then NF_DEFRAG_IPV6 will also be set to 'm', regardless of the state of the symbol from which it is selected. When the xt_TEE driver is built-in and nothing else forces NF_DEFRAG_IPV6 to be built-in, this causes a link-time error: net/built-in.o: In function `tee_tg6': net/netfilter/xt_TEE.c:46: undefined reference to `nf_dup_ipv6' This works around that behavior by changing the dependency to 'if IP6_NF_IPTABLES != n', which is interpreted as boolean expression rather than a tristate and causes the NF_DEFRAG_IPV6 symbol to be built-in as well. The bug only occurs once in thousands of 'randconfig' builds and does not really impact real users. From inspecting the other surrounding Kconfig symbols, I am guessing that NETFILTER_XT_TARGET_TPROXY and NETFILTER_XT_MATCH_SOCKET have the same issue. If not, this change should still be harmless. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-11-10netfilter: nfnetlink_log: work around uninitialized variable warningArnd Bergmann
After a recent (correct) change, gcc started warning about the use of the 'flags' variable in nfulnl_recv_config() net/netfilter/nfnetlink_log.c: In function 'nfulnl_recv_config': net/netfilter/nfnetlink_log.c:320:14: warning: 'flags' may be used uninitialized in this function [-Wmaybe-uninitialized] net/netfilter/nfnetlink_log.c:828:6: note: 'flags' was declared here The warning first shows up in ARM s3c2410_defconfig with gcc-4.3 or higher (including 5.2.1, which is the latest version I checked) I tried working around it by rearranging the code but had no success with that. As a last resort, this initializes the variable to zero, which shuts up the warning, but means that we don't get a warning if the code is ever changed in a way that actually causes the variable to be used without first being written. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Fixes: 8cbc870829ec ("netfilter: nfnetlink_log: validate dependencies to avoid breaking atomicity") Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-11-10svcrpc: document lack of some memory barriersJ. Bruce Fields
We're missing memory barriers in net/sunrpc/svcsock.c in some spots we'd expect them. But it doesn't appear they're necessary in our case, and this is likely a hot path--for now just document the odd behavior. Kosuke Tatsukawa found this issue while looking through the linux source code for places calling waitqueue_active() before wake_up*(), but without preceding memory barriers, after sending a patch to fix a similar issue in drivers/tty/n_tty.c (Details about the original issue can be found here: https://lkml.org/lkml/2015/9/28/849). Reported-by: Kosuke Tatsukawa <tatsu@ab.jp.nec.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2015-11-10Revert "bridge: Allow forward delay to be cfgd when STP enabled"Vlad Yasevich
This reverts commit 34c2d9fb0498c066afbe610b15e18995fd8be792. There are 2 reasons for this revert: 1) The commit in question doesn't do what it says it does. The description reads: "Allow bridge forward delay to be configured when Spanning Tree is enabled." This was already the case before the commit was made. What the commit actually do was disallow invalid values or 'forward_delay' when STP was turned off. 2) The above change was actually a change in the user observed behavior and broke things like libvirt and other network configs that set 'forward_delay' to 0 without enabling STP. The value of 0 is actually used when STP is turned off to immediately mark the bridge as forwarding. Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-10SUNRPC: drop stale comment in svc_setup_socket()Stefan Hajnoczi
The svc_setup_socket() function does set the send and receive buffer sizes, so the comment is out-of-date: Signed-off-by: Stefan Hajnoczi <stefanha@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2015-11-09Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge third patch-bomb from Andrew Morton: "We're pretty much done over here - I'm still waiting for a nouveau merge so I can cleanly finish up Christoph's dma-mapping rework. - bunch of small misc stuff - fold abs64() into abs(), remove abs64() - new_valid_dev() cleanups - binfmt_elf_fdpic feature work" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (24 commits) fs/binfmt_elf_fdpic.c: provide NOMMU loader for regular ELF binaries fs/stat.c: remove unnecessary new_valid_dev() check fs/reiserfs/namei.c: remove unnecessary new_valid_dev() check fs/nilfs2/namei.c: remove unnecessary new_valid_dev() check fs/ncpfs/dir.c: remove unnecessary new_valid_dev() check fs/jfs: remove unnecessary new_valid_dev() checks fs/hpfs/namei.c: remove unnecessary new_valid_dev() check fs/f2fs/namei.c: remove unnecessary new_valid_dev() check fs/ext2/namei.c: remove unnecessary new_valid_dev() check fs/exofs/namei.c: remove unnecessary new_valid_dev() check fs/btrfs/inode.c: remove unnecessary new_valid_dev() check fs/9p: remove unnecessary new_valid_dev() checks include/linux/kdev_t.h: old/new_valid_dev() can return bool include/linux/kdev_t.h: remove unused huge_valid_dev() kmap_atomic_to_page() has no users, remove it drivers/scsi/cxgbi: fix build with EXTRA_CFLAGS dma: remove external references to dma_supported Documentation/sysctl/vm.txt: fix misleading code reference of overcommit_memory remove abs64() kernel.h: make abs() work with 64-bit types ...
2015-11-09net: fix a race in dst_release()Eric Dumazet
Only cpu seeing dst refcount going to 0 can safely dereference dst->flags. Otherwise an other cpu might already have freed the dst. Fixes: 27b75c95f10d ("net: avoid RCU for NOCACHE dst") Reported-by: Greg Thelen <gthelen@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-09Merge tag 'nfs-for-4.4-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client updates from Trond Myklebust: "Highlights include: New features: - RDMA client backchannel from Chuck - Support for NFSv4.2 file CLONE using the btrfs ioctl Bugfixes + cleanups: - Move socket data receive out of the bottom halves and into a workqueue - Refactor NFSv4 error handling so synchronous and asynchronous RPC handles errors identically. - Fix a panic when blocks or object layouts reads return a bad data length - Fix nfsroot so it can handle a 1024 byte long path. - Fix bad usage of page offset in bl_read_pagelist - Various NFSv4 callback cleanups+fixes - Fix GETATTR bitmap verification - Support hexadecimal number for sunrpc debug sysctl files" * tag 'nfs-for-4.4-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (53 commits) Sunrpc: Supports hexadecimal number for sysctl files of sunrpc debug nfs: Fix GETATTR bitmap verification nfs: Remove unused xdr page offsets in getacl/setacl arguments fs/nfs: remove unnecessary new_valid_dev check SUNRPC: fix variable type NFS: Enable client side NFSv4.1 backchannel to use other transports pNFS/flexfiles: Add support for FF_FLAGS_NO_IO_THRU_MDS pNFS/flexfiles: When mirrored, retry failed reads by switching mirrors SUNRPC: Remove the TCP-only restriction in bc_svc_process() svcrdma: Add backward direction service for RPC/RDMA transport xprtrdma: Handle incoming backward direction RPC calls xprtrdma: Add support for sending backward direction RPC replies xprtrdma: Pre-allocate Work Requests for backchannel xprtrdma: Pre-allocate backward rpc_rqst and send/receive buffers SUNRPC: Abstract backchannel operations xprtrdma: Saving IRQs no longer needed for rb_lock xprtrdma: Remove reply tasklet xprtrdma: Use workqueue to process RPC/RDMA replies xprtrdma: Replace send and receive arrays xprtrdma: Refactor reply handler error handling ...
2015-11-09remove abs64()Andrew Morton
Switch everything to the new and more capable implementation of abs(). Mainly to give the new abs() a bit of a workout. Cc: Michal Nazarewicz <mina86@mina86.com> Cc: John Stultz <john.stultz@linaro.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-09netfilter: Fix removal of GRE expectation entries created by PPTPAnthony Lineham
The uninitialized tuple structure caused incorrect hash calculation and the lookup failed. Link: https://bugzilla.kernel.org/show_bug.cgi?id=106441 Signed-off-by: Anthony Lineham <anthony.lineham@alliedtelesis.co.nz> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-11-08netfilter: nft_meta: use skb_to_full_sk() helperEric Dumazet
SYNACK packets might be attached to request sockets. Fixes: ca6fb0651883 ("tcp: attach SYNACK messages to request sockets instead of listener") Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-08net_sched: em_meta: use skb_to_full_sk() helperEric Dumazet
2015-11-08sched: cls_flow: use skb_to_full_sk() helperEric Dumazet
2015-11-08netfilter: xt_owner: use skb_to_full_sk() helperEric Dumazet
SYNACK packets might be attached to a request socket, xt_owner wants to gte the listener in this case. Fixes: ca6fb0651883 ("tcp: attach SYNACK messages to request sockets instead of listener") Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-07Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge second patch-bomb from Andrew Morton: - most of the rest of MM - procfs - lib/ updates - printk updates - bitops infrastructure tweaks - checkpatch updates - nilfs2 update - signals - various other misc bits: coredump, seqfile, kexec, pidns, zlib, ipc, dma-debug, dma-mapping, ... * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (102 commits) ipc,msg: drop dst nil validation in copy_msg include/linux/zutil.h: fix usage example of zlib_adler32() panic: release stale console lock to always get the logbuf printed out dma-debug: check nents in dma_sync_sg* dma-mapping: tidy up dma_parms default handling pidns: fix set/getpriority and ioprio_set/get in PRIO_USER mode kexec: use file name as the output message prefix fs, seqfile: always allow oom killer seq_file: reuse string_escape_str() fs/seq_file: use seq_* helpers in seq_hex_dump() coredump: change zap_threads() and zap_process() to use for_each_thread() coredump: ensure all coredumping tasks have SIGNAL_GROUP_COREDUMP signal: remove jffs2_garbage_collect_thread()->allow_signal(SIGCONT) signal: introduce kernel_signal_stop() to fix jffs2_garbage_collect_thread() signal: turn dequeue_signal_lock() into kernel_dequeue_signal() signals: kill block_all_signals() and unblock_all_signals() nilfs2: fix gcc uninitialized-variable warnings in powerpc build nilfs2: fix gcc unused-but-set-variable warnings MAINTAINERS: nilfs2: add header file for tracing nilfs2: add tracepoints for analyzing reading and writing metadata files ...
2015-11-07Merge tag 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma Pull rdma updates from Doug Ledford: "This is my initial round of 4.4 merge window patches. There are a few other things I wish to get in for 4.4 that aren't in this pull, as this represents what has gone through merge/build/run testing and not what is the last few items for which testing is not yet complete. - "Checksum offload support in user space" enablement - Misc cxgb4 fixes, add T6 support - Misc usnic fixes - 32 bit build warning fixes - Misc ocrdma fixes - Multicast loopback prevention extension - Extend the GID cache to store and return attributes of GIDs - Misc iSER updates - iSER clustering update - Network NameSpace support for rdma CM - Work Request cleanup series - New Memory Registration API" * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (76 commits) IB/core, cma: Make __attribute_const__ declarations sparse-friendly IB/core: Remove old fast registration API IB/ipath: Remove fast registration from the code IB/hfi1: Remove fast registration from the code RDMA/nes: Remove old FRWR API IB/qib: Remove old FRWR API iw_cxgb4: Remove old FRWR API RDMA/cxgb3: Remove old FRWR API RDMA/ocrdma: Remove old FRWR API IB/mlx4: Remove old FRWR API support IB/mlx5: Remove old FRWR API support IB/srp: Dont allocate a page vector when using fast_reg IB/srp: Remove srp_finish_mapping IB/srp: Convert to new registration API IB/srp: Split srp_map_sg RDS/IW: Convert to new memory registration API svcrdma: Port to new memory registration API xprtrdma: Port to new memory registration API iser-target: Port to new memory registration API IB/iser: Port to new fast registration API ...
2015-11-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial updates from Jiri Kosina: "Trivial stuff from trivial tree that can be trivially summed up as: - treewide drop of spurious unlikely() before IS_ERR() from Viresh Kumar - cosmetic fixes (that don't really affect basic functionality of the driver) for pktcdvd and bcache, from Julia Lawall and Petr Mladek - various comment / printk fixes and updates all over the place" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: bcache: Really show state of work pending bit hwmon: applesmc: fix comment typos Kconfig: remove comment about scsi_wait_scan module class_find_device: fix reference to argument "match" debugfs: document that debugfs_remove*() accepts NULL and error values net: Drop unlikely before IS_ERR(_OR_NULL) mm: Drop unlikely before IS_ERR(_OR_NULL) fs: Drop unlikely before IS_ERR(_OR_NULL) drivers: net: Drop unlikely before IS_ERR(_OR_NULL) drivers: misc: Drop unlikely before IS_ERR(_OR_NULL) UBI: Update comments to reflect UBI_METAONLY flag pktcdvd: drop null test before destroy functions
