commit 26d99834f89e76514076d9cd06f61e56e6a509b8 upstream.
When a 9p request is successfully flushed, the server is expected to just
mark it as used without sending a 9p reply (ie, without writing data into
the buffer). In this case, virtqueue_get_buf() will return len == 0 and
we must not report a REQ_STATUS_RCVD status to the client, otherwise the
client will erroneously assume the request has not been flushed.
Cc: stable@vger.kernel.org
Signed-off-by: Greg Kurz <groug@kaod.org>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
commit 69c64866ce072dea1d1e59a0d61e0f66c0dffb76 upstream.
Whenever the sock object is in DCCP_CLOSED state,
dccp_disconnect() must free dccps_hc_tx_ccid and
dccps_hc_rx_ccid and set to NULL.
Signed-off-by: Mohamed Ghannam <simo.ghannam@gmail.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
(cherry picked from commit 259d8c1e984318497c84eef547bbb6b1d9f4eb05)
Wireless drivers rely on parse_txq_params to validate that txq_params->ac
is less than NL80211_NUM_ACS by the time the low-level driver's ->conf_tx()
handler is called. Use a new helper, array_index_nospec(), to sanitize
txq_params->ac with respect to speculation. I.e. ensure that any
speculation into ->conf_tx() handlers is done with a value of
txq_params->ac that is within the bounds of [0, NL80211_NUM_ACS).
Reported-by: Christian Lamparter <chunkeey@gmail.com>
Reported-by: Elena Reshetova <elena.reshetova@intel.com>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
Cc: kernel-hardening@lists.openwall.com
Cc: gregkh@linuxfoundation.org
Cc: linux-wireless@vger.kernel.org
Cc: torvalds@linux-foundation.org
Cc: alan@linux.intel.com
Link: https://lkml.kernel.org/r/151727419584.33451.7700736761686184303.stgit@dwillia2-desk3.amr.corp.intel.com
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
[ Upstream commit 4db428a7c9ab07e08783e0fcdc4ca0f555da0567 ]
reuseport_add_sock() needs to deal with attaching a socket having
its own sk_reuseport_cb, after a prior
setsockopt(SO_ATTACH_REUSEPORT_?BPF)
Without this fix, not only a WARN_ONCE() was issued, but we were also
leaking memory.
Thanks to sysbot and Eric Biggers for providing us nice C repros.
socket already in reuseport group
WARNING: CPU: 0 PID: 3496 at net/core/sock_reuseport.c:119
reuseport_add_sock+0x742/0x9b0 net/core/sock_reuseport.c:117
Kernel panic - not syncing: panic_on_warn set ...
CPU: 0 PID: 3496 Comm: syzkaller869503 Not tainted 4.15.0-rc6+ #245
Hardware name: Google Google Compute Engine/Google Compute Engine,
BIOS
Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:17 [inline]
dump_stack+0x194/0x257 lib/dump_stack.c:53
panic+0x1e4/0x41c kernel/panic.c:183
__warn+0x1dc/0x200 kernel/panic.c:547
report_bug+0x211/0x2d0 lib/bug.c:184
fixup_bug.part.11+0x37/0x80 arch/x86/kernel/traps.c:178
fixup_bug arch/x86/kernel/traps.c:247 [inline]
do_error_trap+0x2d7/0x3e0 arch/x86/kernel/traps.c:296
do_invalid_op+0x1b/0x20 arch/x86/kernel/traps.c:315
invalid_op+0x22/0x40 arch/x86/entry/entry_64.S:1079
Fixes: ef456144da8e ("soreuseport: define reuseport groups")
Reported-by: syzbot+c0ea2226f77a42936bf7@syzkaller.appspotmail.com
Acked-by: Craig Gallek <kraig@google.com>
[ Upstream commit 7ece54a60ee2ba7a386308cae73c790bd580589c ]
If a sk_v6_rcv_saddr is !IPV6_ADDR_ANY and !IPV6_ADDR_MAPPED, it
implicitly implies it is an ipv6only socket. However, in inet6_bind(),
this addr_type checking and setting sk->sk_ipv6only to 1 are only done
after sk->sk_prot->get_port(sk, snum) has been completed successfully.
This inconsistency between sk_v6_rcv_saddr and sk_ipv6only confuses
the 'get_port()'.
In particular, when binding SO_REUSEPORT UDP sockets,
udp_reuseport_add_sock(sk,...) is called. udp_reuseport_add_sock()
checks "ipv6_only_sock(sk2) == ipv6_only_sock(sk)" before adding sk to
sk2->sk_reuseport_cb. In this case, ipv6_only_sock(sk2) could be
1 while ipv6_only_sock(sk) is still 0 here. The end result is,
reuseport_alloc(sk) is called instead of adding sk to the existing
It can be reproduced by binding two SO_REUSEPORT UDP sockets on an
IPv6 address (!ANY and !MAPPED). Only one of the socket will
receive packet.
The fix is to set the implicit sk_ipv6only before calling get_port().
The original sk_ipv6only has to be saved such that it can be restored
in case get_port() failed. The situation is similar to the
inet_reset_saddr(sk) after get_port() has failed.
Thanks to Calvin Owens <calvinowens@fb.com> who created an easy
reproduction which leads to a fix.
Fixes: e32ea7e74727 ("soreuseport: fast reuseport UDP socket selection")
Signed-off-by: Martin KaFai Lau <kafai@fb.com>
[ Upstream commit 058a6c033488494a6b1477b05fe8e1a16e344462 ]
In a couple of points of the control path, n->ht_down is currently
accessed without the required RCU annotation. The accesses are
safe, but sparse complaints. Since we already held the
rtnl lock, let use rtnl_dereference().
Fixes: a1b7c5fd7fe9 ("net: sched: add cls_u32 offload hooks for netdevs")
Fixes: de5df63228fc ("net: sched: cls_u32 changes to knode must appear atomic to readers")
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
Acked-by: Cong Wang <xiyou.wangcong@gmail.com>
[ Upstream commit 3aff3b4b986e51bcf4ab249e5d48d39596e0df6a ]
This commit fixes the pacing_gain to remain at BBR_UNIT (1.0) when
using lt_bw and returning from the PROBE_RTT state to PROBE_BW.
Previously, when using lt_bw, upon exiting PROBE_RTT and entering
PROBE_BW the bbr_reset_probe_bw_mode() code could sometimes randomly
end up with a cycle_idx of 0 and hence have bbr_advance_cycle_phase()
set a pacing gain above 1.0. In such cases this would result in a
pacing rate that is 1.25x higher than intended, potentially resulting
in a high loss rate for a little while until we stop using the lt_bw a
bit later.
This commit is a stable candidate for kernels back as far as 4.9.
Fixes: 0f8782ea1497 ("tcp_bbr: add BBR congestion control")
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Signed-off-by: Soheil Hassas Yeganeh <soheil@google.com>
Reported-by: Beyers Cronje <bcronje@gmail.com>
[ Upstream commit 9b42d55a66d388e4dd5550107df051a9637564fc ]
socket can be disconnected and gets transformed back to a listening
socket, if sk_frag.page is not released, which will be cloned into
a new socket by sk_clone_lock, but the reference count of this page
is increased, lead to a use after free or double free issue
Signed-off-by: Li RongQing <lirongqing@baidu.com>
Cc: Eric Dumazet <edumazet@google.com>
[ Upstream commit e7aadb27a5415e8125834b84a74477bfbee4eff5 ]
Newly added igmpv3_get_srcaddr() needs to be called under rcu lock.
Timer callbacks do not ensure this locking.
WARNING: suspicious RCU usage
4.15.0+ #200 Not tainted
./include/linux/inetdevice.h:216 suspicious rcu_dereference_check() usage!
rcu_scheduler_active = 2, debug_locks = 1
3 locks held by syzkaller616973/4074:
#0: (&mm->mmap_sem){++++}, at: [<00000000bfce669e>] __do_page_fault+0x32d/0xc90 arch/x86/mm/fault.c:1355
#1: ((&im->timer)){+.-.}, at: [<00000000619d2f71>] lockdep_copy_map include/linux/lockdep.h:178 [inline]
#1: ((&im->timer)){+.-.}, at: [<00000000619d2f71>] call_timer_fn+0x1c6/0x820 kernel/time/timer.c:1316
#2: (&(&im->lock)->rlock){+.-.}, at: [<000000005f833c5c>] spin_lock_bh include/linux/spinlock.h:315 [inline]
#2: (&(&im->lock)->rlock){+.-.}, at: [<000000005f833c5c>] igmpv3_send_report+0x98/0x5b0 net/ipv4/igmp.c:600
stack backtrace:
CPU: 0 PID: 4074 Comm: syzkaller616973 Not tainted 4.15.0+ #200
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
<IRQ>
lockdep_rcu_suspicious+0x123/0x170 kernel/locking/lockdep.c:4592
__in_dev_get_rcu include/linux/inetdevice.h:216 [inline]
igmpv3_get_srcaddr net/ipv4/igmp.c:329 [inline]
igmpv3_newpack+0xeef/0x12e0 net/ipv4/igmp.c:389
add_grhead.isra.27+0x235/0x300 net/ipv4/igmp.c:432
add_grec+0xbd3/0x1170 net/ipv4/igmp.c:565
igmpv3_send_report+0xd5/0x5b0 net/ipv4/igmp.c:605
igmp_send_report+0xc43/0x1050 net/ipv4/igmp.c:722
igmp_timer_expire+0x322/0x5c0 net/ipv4/igmp.c:831
call_timer_fn+0x228/0x820 kernel/time/timer.c:1326
expire_timers kernel/time/timer.c:1363 [inline]
__run_timers+0x7ee/0xb70 kernel/time/timer.c:1666
run_timer_softirq+0x4c/0x70 kernel/time/timer.c:1692
__do_softirq+0x2d7/0xb85 kernel/softirq.c:285
invoke_softirq kernel/softirq.c:365 [inline]
irq_exit+0x1cc/0x200 kernel/softirq.c:405
exiting_irq arch/x86/include/asm/apic.h:541 [inline]
smp_apic_timer_interrupt+0x16b/0x700 arch/x86/kernel/apic/apic.c:1052
apic_timer_interrupt+0xa9/0xb0 arch/x86/entry/entry_64.S:938
Fixes: a46182b00290 ("net: igmp: Use correct source address on IGMPv3 reports")
Reported-by: syzbot <syzkaller@googlegroups.com>
[ Upstream commit 4adfa79fc254efb7b0eb3cd58f62c2c3f805f1ba ]
When we dump the ip6mr mfc entries via proc, we initialize an iterator
with the table to dump but we don't clear the cache pointer which might
be initialized from a prior read on the same descriptor that ended. This
can result in lock imbalance (an unnecessary unlock) leading to other
crashes and hangs. Clear the cache pointer like ipmr does to fix the issue.
Thanks for the reliable reproducer.
Here's syzbot's trace:
WARNING: bad unlock balance detected!
4.15.0-rc3+ #128 Not tainted
syzkaller971460/3195 is trying to release lock (mrt_lock) at:
[<000000006898068d>] ipmr_mfc_seq_stop+0xe1/0x130 net/ipv6/ip6mr.c:553
but there are no more locks to release!
1 lock held by syzkaller971460/3195:
#0: (&p->lock){+.+.}, at: [<00000000744a6565>] seq_read+0xd5/0x13d0
fs/seq_file.c:165
stack backtrace:
CPU: 1 PID: 3195 Comm: syzkaller971460 Not tainted 4.15.0-rc3+ #128
Google 01/01/2011
Call Trace:
print_unlock_imbalance_bug+0x12f/0x140 kernel/locking/lockdep.c:3561
__lock_release kernel/locking/lockdep.c:3775 [inline]
lock_release+0x5f9/0xda0 kernel/locking/lockdep.c:4023
__raw_read_unlock include/linux/rwlock_api_smp.h:225 [inline]
_raw_read_unlock+0x1a/0x30 kernel/locking/spinlock.c:255
traverse+0x3bc/0xa00 fs/seq_file.c:135
seq_read+0x96a/0x13d0 fs/seq_file.c:189
proc_reg_read+0xef/0x170 fs/proc/inode.c:217
do_loop_readv_writev fs/read_write.c:673 [inline]
do_iter_read+0x3db/0x5b0 fs/read_write.c:897
compat_readv+0x1bf/0x270 fs/read_write.c:1140
do_compat_preadv64+0xdc/0x100 fs/read_write.c:1189
C_SYSC_preadv fs/read_write.c:1209 [inline]
compat_SyS_preadv+0x3b/0x50 fs/read_write.c:1203
do_syscall_32_irqs_on arch/x86/entry/common.c:327 [inline]
do_fast_syscall_32+0x3ee/0xf9d arch/x86/entry/common.c:389
entry_SYSENTER_compat+0x51/0x60 arch/x86/entry/entry_64_compat.S:125
RIP: 0023:0xf7f73c79
RSP: 002b:00000000e574a15c EFLAGS: 00000292 ORIG_RAX: 000000000000014d
RAX: ffffffffffffffda RBX: 000000000000000f RCX: 0000000020a3afb0
RDX: 0000000000000001 RSI: 0000000000000067 RDI: 0000000000000000
RBP: 0000000000000000 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
BUG: sleeping function called from invalid context at lib/usercopy.c:25
in_atomic(): 1, irqs_disabled(): 0, pid: 3195, name: syzkaller971460
INFO: lockdep is turned off.
Google 01/01/2011
Call Trace:
___might_sleep+0x2b2/0x470 kernel/sched/core.c:6060
__might_sleep+0x95/0x190 kernel/sched/core.c:6013
__might_fault+0xab/0x1d0 mm/memory.c:4525
_copy_to_user+0x2c/0xc0 lib/usercopy.c:25
copy_to_user include/linux/uaccess.h:155 [inline]
seq_read+0xcb4/0x13d0 fs/seq_file.c:279
WARNING: CPU: 1 PID: 3195 at lib/usercopy.c:26 _copy_to_user+0xb5/0xc0
lib/usercopy.c:26
Reported-by: syzbot <bot+eceb3204562c41a438fa1f2335e0fe4f6886d669@syzkaller.appspotmail.com>
Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
[ Upstream commit 4ba161a793d5f43757c35feff258d9f20a082940 ]
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
Tested-by: Dmitry Vyukov <dvyukov@google.com>
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
[ Upstream commit fbbdad5edf0bb59786a51b94a9d006bc8c2da9a2 ]
The previous path metric update from RANN frame has not considered
the own link metric toward the transmitting mesh STA. Fix this.
Reported-by: Michael65535
Signed-off-by: Chun-Yeow Yeoh <yeohchunyeow@gmail.com>
[ Upstream commit 67c8d22a73128ff910e2287567132530abcf5b71 ]
If we want to add a datapath flow, which has more than 500 vxlan outputs'
action, we will get the following error reports:
openvswitch: netlink: Flow action size 32832 bytes exceeds max
openvswitch: netlink: Actions may not be safe on all matching packets
It seems that we can simply enlarge the MAX_ACTIONS_BUFSIZE to fix it, but
this is not the root cause. For example, for a vxlan output action, we need
about 60 bytes for the nlattr, but after it is converted to the flow
action, it only occupies 24 bytes. This means that we can still support
more than 1000 vxlan output actions for a single datapath flow under the
the current 32k max limitation.
So even if the nla_len(attr) is larger than MAX_ACTIONS_BUFSIZE, we
shouldn't report EINVAL and keep it move on, as the judgement can be
done by the reserve_sfa_size.
Signed-off-by: zhangliping <zhangliping02@baidu.com>
Acked-by: Pravin B Shelar <pshelar@ovn.org>
[ upstream commit 68fda450a7df51cff9e5a4d4a4d9d0d5f2589153 ]
due to some JITs doing if (src_reg == 0) check in 64-bit mode
for div/mod operations mask upper 32-bits of src register
before doing the check
Fixes: 622582786c9e ("net: filter: x86: internal BPF JIT")
Fixes: 7a12b5031c6b ("sparc64: Add eBPF JIT.")
Reported-by: syzbot+48340bb518e88849e2e3@syzkaller.appspotmail.com
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
[ upstream commit 290af86629b25ffd1ed6232c4e9107da031705cb ]
The BPF interpreter has been used as part of the spectre 2 attack CVE-2017-5715.
A quote from goolge project zero blog:
"At this point, it would normally be necessary to locate gadgets in
the host kernel code that can be used to actually leak data by reading
from an attacker-controlled location, shifting and masking the result
appropriately and then using the result of that as offset to an
attacker-controlled address for a load. But piecing gadgets together
and figuring out which ones work in a speculation context seems annoying.
So instead, we decided to use the eBPF interpreter, which is built into
the host kernel - while there is no legitimate way to invoke it from inside
a VM, the presence of the code in the host kernel's text section is sufficient
to make it usable for the attack, just like with ordinary ROP gadgets."
To make attacker job harder introduce BPF_JIT_ALWAYS_ON config
option that removes interpreter from the kernel in favor of JIT-only mode.
So far eBPF JIT is supported by:
x64, arm64, arm32, sparc64, s390, powerpc64, mips64
The start of JITed program is randomized and code page is marked as read-only.
In addition "constant blinding" can be turned on with net.core.bpf_jit_harden
v2->v3:
- move __bpf_prog_ret0 under ifdef (Daniel)
v1->v2:
- fix init order, test_bpf and cBPF (Daniel's feedback)
- fix offloaded bpf (Jakub's feedback)
- add 'return 0' dummy in case something can invoke prog->bpf_func
- retarget bpf tree. For bpf-next the patch would need one extra hunk.
It will be sent when the trees are merged back to net-next
Considered doing:
int bpf_jit_enable __read_mostly = BPF_EBPF_JIT_DEFAULT;
but it seems better to land the patch as-is and in bpf-next remove
bpf_jit_enable global variable from all JITs, consolidate in one place
and remove this jit_init() function.
[ Upstream commit d0c081b49137cd3200f2023c0875723be66e7ce5 ]
syzbot reported yet another crash [1] that is caused by
insufficient validation of DODGY packets.
Two bugs are happening here to trigger the crash.
1) Flow dissection leaves with incorrect thoff field.
2) skb_probe_transport_header() sets transport header to this invalid
thoff, even if pointing after skb valid data.
3) qdisc_pkt_len_init() reads out-of-bound data because it
trusts tcp_hdrlen(skb)
Possible fixes :
- Full flow dissector validation before injecting bad DODGY packets in
the stack.
This approach was attempted here : https://patchwork.ozlabs.org/patch/
861874/
- Have more robust functions in the core.
This might be needed anyway for stable versions.
This patch fixes the flow dissection issue.
[1]
CPU: 1 PID: 3144 Comm: syzkaller271204 Not tainted 4.15.0-rc4-mm1+ #49
Call Trace:
print_address_description+0x73/0x250 mm/kasan/report.c:256
kasan_report_error mm/kasan/report.c:355 [inline]
kasan_report+0x23b/0x360 mm/kasan/report.c:413
__asan_report_load2_noabort+0x14/0x20 mm/kasan/report.c:432
__tcp_hdrlen include/linux/tcp.h:35 [inline]
tcp_hdrlen include/linux/tcp.h:40 [inline]
qdisc_pkt_len_init net/core/dev.c:3160 [inline]
__dev_queue_xmit+0x20d3/0x2200 net/core/dev.c:3465
dev_queue_xmit+0x17/0x20 net/core/dev.c:3554
packet_snd net/packet/af_packet.c:2943 [inline]
packet_sendmsg+0x3ad5/0x60a0 net/packet/af_packet.c:2968
sock_sendmsg_nosec net/socket.c:628 [inline]
sock_sendmsg+0xca/0x110 net/socket.c:638
sock_write_iter+0x31a/0x5d0 net/socket.c:907
call_write_iter include/linux/fs.h:1776 [inline]
new_sync_write fs/read_write.c:469 [inline]
__vfs_write+0x684/0x970 fs/read_write.c:482
vfs_write+0x189/0x510 fs/read_write.c:544
SYSC_write fs/read_write.c:589 [inline]
SyS_write+0xef/0x220 fs/read_write.c:581
entry_SYSCALL_64_fastpath+0x1f/0x96
Fixes: 34fad54c2537 ("net: __skb_flow_dissect() must cap its return value")
Fixes: a6e544b0a88b ("flow_dissector: Jump to exit code in __skb_flow_dissect")
Cc: Willem de Bruijn <willemb@google.com>
Acked-by: Jason Wang <jasowang@redhat.com>
[ Upstream commit 121d57af308d0cf943f08f4738d24d3966c38cd9 ]
Validate gso_type during segmentation as SKB_GSO_DODGY sources
may pass packets where the gso_type does not match the contents.
Syzkaller was able to enter the SCTP gso handler with a packet of
gso_type SKB_GSO_TCPV4.
On entry of transport layer gso handlers, verify that the gso_type
matches the transport protocol.
Fixes: 90017accff61 ("sctp: Add GSO support")
Link: http://lkml.kernel.org/r/<001a1137452496ffc305617e5fe0@google.com>
Reported-by: syzbot+fee64147a25aecd48055@syzkaller.appspotmail.com
Signed-off-by: Willem de Bruijn <willemb@google.com>
Reviewed-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
[ Upstream commit 128bb975dc3c25d00de04e503e2fe0a780d04459 ]
Commit b05229f44228 ("gre6: Cleanup GREv6 transmit path,
call common GRE functions") moved dev->mtu initialization
from ip6gre_tunnel_setup() to ip6gre_tunnel_init(), as a
result, the previously set values, before ndo_init(), are
reset in the following cases:
* rtnl_create_link() can update dev->mtu from IFLA_MTU
parameter.
* ip6gre_tnl_link_config() is invoked before ndo_init() in
netlink and ioctl setup, so ndo_init() can reset MTU
adjustments with the lower device MTU as well, dev->mtu
and dev->hard_header_len.
Not applicable for ip6gretap because it has one more call
to ip6gre_tnl_link_config(tunnel, 1) in ip6gre_tap_init().
Fix the first case by updating dev->mtu with 'tb[IFLA_MTU]'
parameter if a user sets it manually on a device creation,
and fix the second one by moving ip6gre_tnl_link_config()
call after register_netdevice().
Fixes: b05229f44228 ("gre6: Cleanup GREv6 transmit path, call common GRE functions")
Fixes: db2ec95d1ba4 ("ip6_gre: Fix MTU setting")
Signed-off-by: Alexey Kodanev <alexey.kodanev@oracle.com>
[ Upstream commit cd9ff4de0107c65d69d02253bb25d6db93c3dbc1 ]
Map all lookup neigh keys to INADDR_ANY for loopback/point-to-point devices
to avoid making an entry for every remote ip the device needs to talk to.
This used the be the old behavior but became broken in a263b3093641f
(ipv4: Make neigh lookups directly in output packet path) and later removed
in 0bb4087cbec0 (ipv4: Fix neigh lookup keying over loopback/point-to-point
devices) because it was broken.
Signed-off-by: Jim Westfall <jwestfall@surrealistic.net>
[ Upstream commit 096b9854c04df86f03b38a97d40b6506e5730919 ]
Use n->primary_key instead of pkey to account for the possibility that a neigh
constructor function may have modified the primary_key value.
[ Upstream commit 59b36613e85fb16ebf9feaf914570879cd5c2a21 ]
When tipc_node_find_by_name() fails, the nlmsg is not
freed.
While on it, switch to a goto label to properly
free it.
Fixes: be9c086715c ("tipc: narrow down exposure of struct tipc_node")
Cc: Jon Maloy <jon.maloy@ericsson.com>
Cc: Ying Xue <ying.xue@windriver.com>
Acked-by: Ying Xue <ying.xue@windriver.com>
[ Upstream commit a0ff660058b88d12625a783ce9e5c1371c87951f ]
After commit cea0cc80a677 ("sctp: use the right sk after waking up from
wait_buf sleep"), it may change to lock another sk if the asoc has been
peeled off in sctp_wait_for_sndbuf.
However, the asoc's new sk could be already closed elsewhere, as it's in
the sendmsg context of the old sk that can't avoid the new sk's closing.
If the sk's last one refcnt is held by this asoc, later on after putting
this asoc, the new sk will be freed, while under it's own lock.
This patch is to revert that commit, but fix the old issue by returning
error under the old sk's lock.
Fixes: cea0cc80a677 ("sctp: use the right sk after waking up from wait_buf sleep")
Reported-by: syzbot+ac6ea7baa4432811eb50@syzkaller.appspotmail.com
Signed-off-by: Xin Long <lucien.xin@gmail.com>
[ Upstream commit c5006b8aa74599ce19104b31d322d2ea9ff887cc ]
The check in sctp_sockaddr_af is not robust enough to forbid binding a
v4mapped v6 addr on a v4 socket.
The worse thing is that v4 socket's bind_verify would not convert this
v4mapped v6 addr to a v4 addr. syzbot even reported a crash as the v4
socket bound a v6 addr.
This patch is to fix it by doing the common sa.sa_family check first,
then AF_INET check for v4mapped v6 addrs.
Fixes: 7dab83de50c7 ("sctp: Support ipv6only AF_INET6 sockets.")
Reported-by: syzbot+7b7b518b1228d2743963@syzkaller.appspotmail.com
Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
[ Upstream commit 4ee806d51176ba7b8ff1efd81f271d7252e03a1d ]
When a tcp socket is closed, if it detects that its net namespace is
exiting, close immediately and do not wait for FIN sequence.
For normal sockets, a reference is taken to their net namespace, so it will
never exit while the socket is open. However, kernel sockets do not take a
reference to their net namespace, so it may begin exiting while the kernel
socket is still open. In this case if the kernel socket is a tcp socket,
it will stay open trying to complete its close sequence. The sock's dst(s)
hold a reference to their interface, which are all transferred to the
namespace's loopback interface when the real interfaces are taken down.
When the namespace tries to take down its loopback interface, it hangs
waiting for all references to the loopback interface to release, which
results in messages like:
unregister_netdevice: waiting for lo to become free. Usage count = 1
These messages continue until the socket finally times out and closes.
Since the net namespace cleanup holds the net_mutex while calling its
registered pernet callbacks, any new net namespace initialization is
blocked until the current net namespace finishes exiting.
After this change, the tcp socket notices the exiting net namespace, and
closes immediately, releasing its dst(s) and their reference to the
loopback interface, which lets the net namespace continue exiting.
Link: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1711407
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=97811
Signed-off-by: Dan Streetman <ddstreet@canonical.com>
[ Upstream commit 7c68d1a6b4db9012790af7ac0f0fdc0d2083422a ]
Without proper validation of DODGY packets, we might very well
feed qdisc_pkt_len_init() with invalid GSO packets.
tcp_hdrlen() might access out-of-bound data, so let's use
skb_header_pointer() and proper checks.
Whole story is described in commit d0c081b49137 ("flow_dissector:
properly cap thoff field")
We have the goal of validating DODGY packets earlier in the stack,
so we might very well revert this fix in the future.
Cc: Jason Wang <jasowang@redhat.com>
Reported-by: syzbot+9da69ebac7dddd804552@syzkaller.appspotmail.com
[ Upstream commit ad23b750933ea7bf962678972a286c78a8fa36aa ]
Commit "net: igmp: Use correct source address on IGMPv3 reports"
introduced a check to validate the source address of locally generated
IGMPv3 packets.
Instead of checking the local interface address directly, it uses
inet_ifa_match(fl4->saddr, ifa), which checks if the address is on the
local subnet (or equal to the point-to-point address if used).
This breaks for point-to-point interfaces, so check against
ifa->ifa_local directly.
Cc: Kevin Cernekee <cernekee@chromium.org>
Reported-by: Sebastian Gottschall <s.gottschall@dd-wrt.com>
Signed-off-by: Felix Fietkau <nbd@nbd.name>
[ Upstream commit 95ef498d977bf44ac094778fd448b98af158a3e6 ]
In my last patch, I missed fact that cork.base.dst was not initialized
in ip6_make_skb() :
If ip6_setup_cork() returns an error, we might attempt a dst_release()
on some random pointer.
Fixes: 862c03ee1deb ("ipv6: fix possible mem leaks in ipv6_make_skb()")
[ Upstream commit 749439bfac6e1a2932c582e2699f91d329658196 ]
The logic in __ip6_append_data() assumes that the MTU is at least large
enough for the headers. A device's MTU may be adjusted after being
added while sendmsg() is processing data, resulting in
__ip6_append_data() seeing any MTU. For an mtu smaller than the size of
the fragmentation header, the math results in a negative 'maxfraglen',
which causes problems when refragmenting any previous skb in the
skb_write_queue, leaving it possibly malformed.
Instead sendmsg returns EINVAL when the mtu is calculated to be less
than IPV6_MIN_MTU.
Found by syzkaller:
kernel BUG at ./include/linux/skbuff.h:2064!
invalid opcode: 0000 [#1] SMP KASAN
Dumping ftrace buffer:
(ftrace buffer empty)
Modules linked in:
CPU: 1 PID: 14216 Comm: syz-executor5 Not tainted 4.13.0-rc4+ #2
task: ffff8801d0b68580 task.stack: ffff8801ac6b8000
RIP: 0010:__skb_pull include/linux/skbuff.h:2064 [inline]
RIP: 0010:__ip6_make_skb+0x18cf/0x1f70 net/ipv6/ip6_output.c:1617
RSP: 0018:ffff8801ac6bf570 EFLAGS: 00010216
RAX: 0000000000010000 RBX: 0000000000000028 RCX: ffffc90003cce000
RDX: 00000000000001b8 RSI: ffffffff839df06f RDI: ffff8801d9478ca0
RBP: ffff8801ac6bf780 R08: ffff8801cc3f1dbc R09: 0000000000000000
R10: ffff8801ac6bf7a0 R11: 43cb4b7b1948a9e7 R12: ffff8801cc3f1dc8
R13: ffff8801cc3f1d40 R14: 0000000000001036 R15: dffffc0000000000
FS: 00007f43d740c700(0000) GS:ffff8801dc100000(0000) knlGS:0000000000000000
CR2: 00007f7834984000 CR3: 00000001d79b9000 CR4: 00000000001406e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
ip6_finish_skb include/net/ipv6.h:911 [inline]
udp_v6_push_pending_frames+0x255/0x390 net/ipv6/udp.c:1093
udpv6_sendmsg+0x280d/0x31a0 net/ipv6/udp.c:1363
inet_sendmsg+0x11f/0x5e0 net/ipv4/af_inet.c:762
sock_sendmsg_nosec net/socket.c:633 [inline]
sock_sendmsg+0xca/0x110 net/socket.c:643
SYSC_sendto+0x352/0x5a0 net/socket.c:1750
SyS_sendto+0x40/0x50 net/socket.c:1718
entry_SYSCALL_64_fastpath+0x1f/0xbe
RIP: 0033:0x4512e9
RSP: 002b:00007f43d740bc08 EFLAGS: 00000216 ORIG_RAX: 000000000000002c
RAX: ffffffffffffffda RBX: 00000000007180a8 RCX: 00000000004512e9
RDX: 000000000000002e RSI: 0000000020d08000 RDI: 0000000000000005
RBP: 0000000000000086 R08: 00000000209c1000 R09: 000000000000001c
R10: 0000000000040800 R11: 0000000000000216 R12: 00000000004b9c69
R13: 00000000ffffffff R14: 0000000000000005 R15: 00000000202c2000
Code: 9e 01 fe e9 c5 e8 ff ff e8 7f 9e 01 fe e9 4a ea ff ff 48 89 f7 e8 52 9e 01 fe e9 aa eb ff ff e8 a8 b6 cf fd 0f 0b e8 a1 b6 cf fd <0f> 0b 49 8d 45 78 4d 8d 45 7c 48 89 85 78 fe ff ff 49 8d 85 ba
RIP: __skb_pull include/linux/skbuff.h:2064 [inline] RSP: ffff8801ac6bf570
RIP: __ip6_make_skb+0x18cf/0x1f70 net/ipv6/ip6_output.c:1617 RSP: ffff8801ac6bf570
Signed-off-by: Mike Maloney <maloney@google.com>
[ Upstream commit e9191ffb65d8e159680ce0ad2224e1acbde6985c ]
Commit 513674b5a2c9 ("net: reevalulate autoflowlabel setting after
sysctl setting") removed the initialisation of
ipv6_pinfo::autoflowlabel and added a second flag to indicate
whether this field or the net namespace default should be used.
The getsockopt() handling for this case was not updated, so it
currently returns 0 for all sockets for which IPV6_AUTOFLOWLABEL is
not explicitly enabled. Fix it to return the effective value, whether
that has been set at the socket or net namespace level.
Fixes: 513674b5a2c9 ("net: reevalulate autoflowlabel setting after sysctl ...")
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
[ Upstream commit dd5684ecae3bd8e44b644f50e2c12c7e57fdfef5 ]
ccid2_hc_tx_rto_expire() timer callback always restarts the timer
again and can run indefinitely (unless it is stopped outside), and after
commit 120e9dabaf55 ("dccp: defer ccid_hc_tx_delete() at dismantle time"),
which moved ccid_hc_tx_delete() (also includes sk_stop_timer()) from
dccp_destroy_sock() to sk_destruct(), this started to happen quite often.
The timer prevents releasing the socket, as a result, sk_destruct() won't
be called.
Found with LTP/dccp_ipsec tests running on the bonding device,
which later couldn't be unloaded after the tests were completed:
unregister_netdevice: waiting for bond0 to become free. Usage count = 148
Fixes: 2a91aa396739 ("[DCCP] CCID2: Initial CCID2 (TCP-Like) implementation")
commit 916a27901de01446bcf57ecca4783f6cff493309 upstream.
The capability check in nfnetlink_rcv() verifies that the caller
has CAP_NET_ADMIN in the namespace that "owns" the netlink socket.
However, xt_osf_fingers is shared by all net namespaces on the
system. An unprivileged user can create user and net namespaces
in which he holds CAP_NET_ADMIN to bypass the netlink_net_capable()
check:
vpnns -- nfnl_osf -f /tmp/pf.os
vpnns -- nfnl_osf -f /tmp/pf.os -d
These non-root operations successfully modify the systemwide OS
fingerprint list. Add new capable() checks so that they can't.
Signed-off-by: Kevin Cernekee <cernekee@chromium.org>
Acked-by: Michal Kubecek <mkubecek@suse.cz>
commit 4b380c42f7d00a395feede754f0bc2292eebe6e5 upstream.
However, nfnl_cthelper_list is shared by all net namespaces on the
check:
$ nfct helper list
nfct v1.4.4: netlink error: Operation not permitted
$ vpnns -- nfct helper list
.name = ftp,
.queuenum = 0,
.l3protonum = 2,
.l4protonum = 6,
.priv_data_len = 24,
.status = enabled,
Add capable() checks in nfnetlink_cthelper, as this is cleaner than
trying to generalize the solution.
commit d4689846881d160a4d12a514e991a740bcb5d65a upstream.
If an invalid CANFD frame is received, from a driver or from a tun
interface, a Kernel warning is generated.
This patch replaces the WARN_ONCE by a simple pr_warn_once, so that a
kernel, bootet with panic_on_warn, does not panic. A printk seems to be
more appropriate here.
Reported-by: syzbot+e3b775f40babeff6e68b@syzkaller.appspotmail.com
Suggested-by: Dmitry Vyukov <dvyukov@google.com>
Acked-by: Oliver Hartkopp <socketcan@hartkopp.net>
Cc: linux-stable <stable@vger.kernel.org>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
commit 8cb68751c115d176ec851ca56ecfbb411568c9e8 upstream.
If an invalid CAN frame is received, from a driver or from a tun
Reported-by: syzbot+4386709c0c1284dca827@syzkaller.appspotmail.com
commit 4e765b4972af7b07adcb1feb16e7a525ce1f6b28 upstream.
If a message sent to a PF_KEY socket ended with an incomplete extension
header (fewer than 4 bytes remaining), then parse_exthdrs() read past
the end of the message, into uninitialized memory. Fix it by returning
-EINVAL in this case.
Reproducer:
#include <linux/pfkeyv2.h>
#include <sys/socket.h>
#include <unistd.h>
int main()
int sock = socket(PF_KEY, SOCK_RAW, PF_KEY_V2);
char buf[17] = { 0 };
struct sadb_msg *msg = (void *)buf;
msg->sadb_msg_version = PF_KEY_V2;
msg->sadb_msg_type = SADB_DELETE;
msg->sadb_msg_len = 2;
write(sock, buf, 17);
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
commit 06b335cb51af018d5feeff5dd4fd53847ddb675a upstream.
If a message sent to a PF_KEY socket ended with one of the extensions
that takes a 'struct sadb_address' but there were not enough bytes
remaining in the message for the ->sa_family member of the 'struct
sockaddr' which is supposed to follow, then verify_address_len() read
past the end of the message, into uninitialized memory. Fix it by
returning -EINVAL in this case.
This bug was found using syzkaller with KMSAN.
Reproducer:
#include <unistd.h>
int main()
char buf[24] = { 0 };
struct sadb_address *addr = (void *)(msg + 1);
msg->sadb_msg_len = 3;
addr->sadb_address_len = 1;
addr->sadb_address_exttype = SADB_EXT_ADDRESS_SRC;
write(sock, buf, 24);
Reported-by: Alexander Potapenko <glider@google.com>
commit 06e7e776ca4d36547e503279aeff996cbb292c16 upstream.
In the function l2cap_parse_conf_rsp and in the function
l2cap_parse_conf_req the following variable is declared without
initialization:
struct l2cap_conf_efs efs;
In addition, when parsing input configuration parameters in both of
these functions, the switch case for handling EFS elements may skip the
memcpy call that will write to the efs variable:
case L2CAP_CONF_EFS:
if (olen == sizeof(efs))
memcpy(&efs, (void *)val, olen);
The olen in the above if is attacker controlled, and regardless of that
if, in both of these functions the efs variable would eventually be
added to the outgoing configuration request that is being built:
l2cap_add_conf_opt(&ptr, L2CAP_CONF_EFS, sizeof(efs), (unsigned long) &efs);
So by sending a configuration request, or response, that contains an
L2CAP_CONF_EFS element, but with an element length that is not
sizeof(efs) - the memcpy to the uninitialized efs variable can be
avoided, and the uninitialized variable would be returned to the
attacker (16 bytes).
This issue has been assigned CVE-2017-1000410
Cc: Marcel Holtmann <marcel@holtmann.org>
Cc: Gustavo Padovan <gustavo@padovan.org>
Cc: Johan Hedberg <johan.hedberg@gmail.com>
Signed-off-by: Ben Seri <ben@armis.com>
[ Upstream commit 3bb23421a504f01551b7cb9dff0e41dbf16656b0 ]
We need to update lastuse to to the most updated value between what
is already set and the new value.
If HW matching fails, i.e. because of an issue, the stats are not updated
but it could be that software did match and updated lastuse.
Fixes: 5712bf9c5c30 ("net/sched: act_mirred: Use passed lastuse argument")
Fixes: 9fea47d93bcc ("net/sched: act_gact: Update statistics when offloaded to hardware")
Signed-off-by: Roi Dayan <roid@mellanox.com>
Reviewed-by: Paul Blakey <paulb@mellanox.com>
Acked-by: Jiri Pirko <jiri@mellanox.com>
[ Upstream commit 71891e2dab6b55a870f8f7735e44a2963860b5c6 ]
In kernel log ths message appears on every boot:
"warning: `NetworkChangeNo' uses legacy ethtool link settings API,
link modes are only partially reported"
When ethtool link settings API changed, it started complaining about
usages of old API. Ironically, the original patch was from google but
the application using the legacy API is chrome.
Linux ABI is fixed as much as possible. The kernel must not break it
and should not complain about applications using legacy API's.
This patch just removes the warning since using legacy API's
in Linux is perfectly acceptable.
Fixes: 3f1ac7a700d0 ("net: ethtool: add new ETHTOOL_xLINKSETTINGS API")
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
Signed-off-by: David Decotigny <decot@googlers.com>
[ Upstream commit 862c03ee1deb7e19e0f9931682e0294ecd1fcaf9 ]
ip6_setup_cork() might return an error, while memory allocations have
been done and must be rolled back.
Fixes: 6422398c2ab0 ("ipv6: introduce ipv6_make_skb")
Cc: Vlad Yasevich <vyasevich@gmail.com>
Reported-by: Mike Maloney <maloney@google.com>
Acked-by: Mike Maloney <maloney@google.com>
[ Upstream commit 7d11f77f84b27cef452cee332f4e469503084737 ]
set rm->atomic.op_active to 0 when rds_pin_pages() fails
or the user supplied address is invalid,
this prevents a NULL pointer usage in rds_atomic_free_op()
Acked-by: Santosh Shilimkar <santosh.shilimkar@oracle.com>
[ Upstream commit c095508770aebf1b9218e77026e48345d719b17c ]
When args->nr_local is 0, nr_pages gets also 0 due some size
calculation via rds_rm_size(), which is later used to allocate
pages for DMA, this bug produces a heap Out-Of-Bound write access
to a specific memory region.
[ Upstream commit b8fd0823e0770c2d5fdbd865bccf0d5e058e5287 ]
Use AF_INET6 instead of AF_INET in IPv6-related code path
Signed-off-by: Andrii Vladyka <tulup@mail.ru>
[ Upstream commit 23263ec86a5f44312d2899323872468752324107 ]
When an ip6_tunnel is in mode 'any', where the transport layer
protocol can be either 4 or 41, dst_cache must be disabled.
This is because xfrm policies might apply to only one of the two
protocols. Caching dst would cause xfrm policies for one protocol
incorrectly used for the other.
Signed-off-by: Eli Cooper <elicooper@gmx.com>
[ Upstream commit 78bbb15f2239bc8e663aa20bbe1987c91a0b75f6 ]
A vlan device with vid 0 is allow to creat by not able to be fully
cleaned up by unregister_vlan_dev() which checks for vlan_id!=0.
Also, VLAN 0 is probably not a valid number and it is kinda
"reserved" for HW accelerating devices, but it is probably too
late to reject it from creation even if makes sense. Instead,
just remove the check in unregister_vlan_dev().
Fixes: ad1afb003939 ("vlan_dev: VLAN 0 should be treated as "no vlan tag" (802.1p packet)")
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit cef0acd4d7d4811d2d19cd0195031bf0dfe41249 upstream.
Add a flag that indicates that the WEP ICV was stripped from an
RX packet, allowing the device to not transfer that if it's
already checked.
Signed-off-by: David Spinadel <david.spinadel@intel.com>
Cc: Kalle Valo <kvalo@codeaurora.org>
commit bdcf0a423ea1c40bbb40e7ee483b50fc8aa3d758 upstream.
In testing, we found that nfsd threads may call set_groups in parallel
for the same entry cached in auth.unix.gid, racing in the call of
groups_sort, corrupting the groups for that entry and leading to
permission denials for the client.
This patch:
- Make groups_sort globally visible.
- Move the call to groups_sort to the modifiers of group_info
- Remove the call to groups_sort from set_groups
Link: http://lkml.kernel.org/r/20171211151420.18655-1-thiago.becker@gmail.com
Signed-off-by: Thiago Rafael Becker <thiago.becker@gmail.com>
Reviewed-by: Matthew Wilcox <mawilcox@microsoft.com>
Reviewed-by: NeilBrown <neilb@suse.com>
Acked-by: "J. Bruce Fields" <bfields@fieldses.org>
commit 600647d467c6d04b3954b41a6ee1795b5ae00550 upstream.
Fix BBR so that upon notification of a loss recovery undo BBR resets
long-term bandwidth sampling.
Under high reordering, reordering events can be interpreted as loss.
If the reordering and spurious loss estimates are high enough, this
can cause BBR to spuriously estimate that we are seeing loss rates
high enough to trigger long-term bandwidth estimation. To avoid that
problem, this commit resets long-term bandwidth sampling on loss
recovery undo events.
Reviewed-by: Yuchung Cheng <ycheng@google.com>
Acked-by: Soheil Hassas Yeganeh <soheil@google.com>
commit 2f6c498e4f15d27852c04ed46d804a39137ba364 upstream.
the full pipe detection (STARTUP exit) state machine.
could previously cause BBR to spuriously estimate that the pipe is
full.
Since spurious loss recovery means that our overall sending will have
slowed down spuriously, this commit gives a flow more time to probe
robustly for bandwidth and decide the pipe is really full.
[ Upstream commit d4761754b4fb2ef8d9a1e9d121c4bec84e1fe292 ]
Mark tcp_sock during a SACK reneging event and invalidate rate samples
while marked. Such rate samples may overestimate bw by including packets
that were SACKed before reneging.
< ack 6001 win 10000 sack 7001:38001
< ack 7001 win 0 sack 8001:38001 // Reneg detected
> seq 7001:8001 // RTO, SACK cleared.
< ack 38001 win 10000
In above example the rate sample taken after the last ack will count
7001-38001 as delivered while the actual delivery rate likely could
be much lower i.e. 7001-8001.
This patch adds a new field tcp_sock.sack_reneg and marks it when we
declare SACK reneging and entering TCP_CA_Loss, and unmarks it after
the last rate sample was taken before moving back to TCP_CA_Open. This
patch also invalidates rate samples taken while tcp_sock.is_sack_reneg
is set.
Fixes: b9f64820fb22 ("tcp: track data delivery rate for a TCP connection")
Signed-off-by: Yousuk Seung <ysseung@google.com>
Acked-by: Priyaranjan Jha <priyarjha@google.com>
