path: root/samples/bpf
2015-08-12bpf: fix build warnings and add function read_trace_pipe()Kaixu Xia
There are two improvements in this patch: 1. Fix the build warnings; 2. Add function read_trace_pipe() to print the result on the screen; Before this patch, we can get the result through /sys/kernel/de bug/tracing/trace_pipe and get nothing on the screen. By applying this patch, the result can be printed on the screen. $ ./tracex6 ... tracex6-705 [003] d..1 131.428593: : CPU-3 19981414 sshd-683 [000] d..1 131.428727: : CPU-0 221682321 sshd-683 [000] d..1 131.428821: : CPU-0 221808766 sshd-683 [000] d..1 131.428950: : CPU-0 221982984 sshd-683 [000] d..1 131.429045: : CPU-0 222111851 tracex6-705 [003] d..1 131.429168: : CPU-3 20757551 sshd-683 [000] d..1 131.429170: : CPU-0 222281240 sshd-683 [000] d..1 131.429261: : CPU-0 222403340 sshd-683 [000] d..1 131.429378: : CPU-0 222561024 ... Signed-off-by: Kaixu Xia <xiakaixu@huawei.com> Acked-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-08-09samples/bpf: example of get selected PMU counter valueKaixu Xia
This is a simple example and shows how to use the new ability to get the selected Hardware PMU counter value. Signed-off-by: Kaixu Xia <xiakaixu@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-27ebpf: Allow dereferences of PTR_TO_STACK registersAlex Gartrell
mov %rsp, %r1 ; r1 = rsp add $-8, %r1 ; r1 = rsp - 8 store_q $123, -8(%rsp) ; *(u64*)r1 = 123 <- valid store_q $123, (%r1) ; *(u64*)r1 = 123 <- previously invalid mov $0, %r0 exit ; Always need to exit And we'd get the following error: 0: (bf) r1 = r10 1: (07) r1 += -8 2: (7a) *(u64 *)(r10 -8) = 999 3: (7a) *(u64 *)(r1 +0) = 999 R1 invalid mem access 'fp' Unable to load program We already know that a register is a stack address and the appropriate offset, so we should be able to validate those references as well. Signed-off-by: Alex Gartrell <agartrell@fb.com> Acked-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-08samples: bpf: enable trace samples for s390xMichael Holzheu
The trace bpf samples do not compile on s390x because they use x86 specific fields from the "pt_regs" structure. Fix this and access the fields via new PT_REGS macros. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Acked-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-23bpf: BPF based latency tracingDaniel Wagner
BPF offers another way to generate latency histograms. We attach kprobes at trace_preempt_off and trace_preempt_on and calculate the time it takes to from seeing the off/on transition. The first array is used to store the start time stamp. The key is the CPU id. The second array stores the log2(time diff). We need to use static allocation here (array and not hash tables). The kprobes hooking into trace_preempt_on|off should not calling any dynamic memory allocation or free path. We need to avoid recursivly getting called. Besides that, it reduces jitter in the measurement. CPU 0 latency : count distribution 1 -> 1 : 0 | | 2 -> 3 : 0 | | 4 -> 7 : 0 | | 8 -> 15 : 0 | | 16 -> 31 : 0 | | 32 -> 63 : 0 | | 64 -> 127 : 0 | | 128 -> 255 : 0 | | 256 -> 511 : 0 | | 512 -> 1023 : 0 | | 1024 -> 2047 : 0 | | 2048 -> 4095 : 166723 |*************************************** | 4096 -> 8191 : 19870 |*** | 8192 -> 16383 : 6324 | | 16384 -> 32767 : 1098 | | 32768 -> 65535 : 190 | | 65536 -> 131071 : 179 | | 131072 -> 262143 : 18 | | 262144 -> 524287 : 4 | | 524288 -> 1048575 : 1363 | | CPU 1 latency : count distribution 1 -> 1 : 0 | | 2 -> 3 : 0 | | 4 -> 7 : 0 | | 8 -> 15 : 0 | | 16 -> 31 : 0 | | 32 -> 63 : 0 | | 64 -> 127 : 0 | | 128 -> 255 : 0 | | 256 -> 511 : 0 | | 512 -> 1023 : 0 | | 1024 -> 2047 : 0 | | 2048 -> 4095 : 114042 |*************************************** | 4096 -> 8191 : 9587 |** | 8192 -> 16383 : 4140 | | 16384 -> 32767 : 673 | | 32768 -> 65535 : 179 | | 65536 -> 131071 : 29 | | 131072 -> 262143 : 4 | | 262144 -> 524287 : 1 | | 524288 -> 1048575 : 364 | | CPU 2 latency : count distribution 1 -> 1 : 0 | | 2 -> 3 : 0 | | 4 -> 7 : 0 | | 8 -> 15 : 0 | | 16 -> 31 : 0 | | 32 -> 63 : 0 | | 64 -> 127 : 0 | | 128 -> 255 : 0 | | 256 -> 511 : 0 | | 512 -> 1023 : 0 | | 1024 -> 2047 : 0 | | 2048 -> 4095 : 40147 |*************************************** | 4096 -> 8191 : 2300 |* | 8192 -> 16383 : 828 | | 16384 -> 32767 : 178 | | 32768 -> 65535 : 59 | | 65536 -> 131071 : 2 | | 131072 -> 262143 : 0 | | 262144 -> 524287 : 1 | | 524288 -> 1048575 : 174 | | CPU 3 latency : count distribution 1 -> 1 : 0 | | 2 -> 3 : 0 | | 4 -> 7 : 0 | | 8 -> 15 : 0 | | 16 -> 31 : 0 | | 32 -> 63 : 0 | | 64 -> 127 : 0 | | 128 -> 255 : 0 | | 256 -> 511 : 0 | | 512 -> 1023 : 0 | | 1024 -> 2047 : 0 | | 2048 -> 4095 : 29626 |*************************************** | 4096 -> 8191 : 2704 |** | 8192 -> 16383 : 1090 | | 16384 -> 32767 : 160 | | 32768 -> 65535 : 72 | | 65536 -> 131071 : 32 | | 131072 -> 262143 : 26 | | 262144 -> 524287 : 12 | | 524288 -> 1048575 : 298 | | All this is based on the trace3 examples written by Alexei Starovoitov <ast@plumgrid.com>. Signed-off-by: Daniel Wagner <daniel.wagner@bmw-carit.de> Cc: Alexei Starovoitov <ast@plumgrid.com> Cc: Alexei Starovoitov <ast@plumgrid.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Daniel Borkmann <daniel@iogearbox.net> Cc: Ingo Molnar <mingo@kernel.org> Cc: linux-kernel@vger.kernel.org Cc: netdev@vger.kernel.org Acked-by: Alexei Starovoitov <ast@plumgrid.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-15bpf: introduce current->pid, tgid, uid, gid, comm accessorsAlexei Starovoitov
eBPF programs attached to kprobes need to filter based on current->pid, uid and other fields, so introduce helper functions: u64 bpf_get_current_pid_tgid(void) Return: current->tgid << 32 | current->pid u64 bpf_get_current_uid_gid(void) Return: current_gid << 32 | current_uid bpf_get_current_comm(char *buf, int size_of_buf) stores current->comm into buf They can be used from the programs attached to TC as well to classify packets based on current task fields. Update tracex2 example to print histogram of write syscalls for each process instead of aggregated for all. Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-07bpf: allow programs to write to certain skb fieldsAlexei Starovoitov
allow programs read/write skb->mark, tc_index fields and ((struct qdisc_skb_cb *)cb)->data. mark and tc_index are generically useful in TC. cb[0]-cb[4] are primarily used to pass arguments from one program to another called via bpf_tail_call() which can be seen in sockex3_kern.c example. All fields of 'struct __sk_buff' are readable to socket and tc_cls_act progs. mark, tc_index are writeable from tc_cls_act only. cb[0]-cb[4] are writeable by both sockets and tc_cls_act. Add verifier tests and improve sample code. Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-07bpf: make programs see skb->data == L2 for ingress and egressAlexei Starovoitov
eBPF programs attached to ingress and egress qdiscs see inconsistent skb->data. For ingress L2 header is already pulled, whereas for egress it's present. This is known to program writers which are currently forced to use BPF_LL_OFF workaround. Since programs don't change skb internal pointers it is safe to do pull/push right around invocation of the program and earlier taps and later pt->func() will not be affected. Multiple taps via packet_rcv(), tpacket_rcv() are doing the same trick around run_filter/BPF_PROG_RUN even if skb_shared. This fix finally allows programs to use optimized LD_ABS/IND instructions without BPF_LL_OFF for higher performance. tc ingress + cls_bpf + samples/bpf/tcbpf1_kern.o w/o JIT w/JIT before 20.5 23.6 Mpps after 21.8 26.6 Mpps Old programs with BPF_LL_OFF will still work as-is. We can now undo most of the earlier workaround commit: a166151cbe33 ("bpf: fix bpf helpers to use skb->mac_header relative offsets") Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Acked-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-21samples/bpf: bpf_tail_call example for networkingAlexei Starovoitov
Usage: $ sudo ./sockex3 IP src.port -> dst.port bytes packets 127.0.0.1.42010 -> 127.0.0.1.12865 1568 8 127.0.0.1.59526 -> 127.0.0.1.33778 11422636 173070 127.0.0.1.33778 -> 127.0.0.1.59526 11260224828 341974 127.0.0.1.12865 -> 127.0.0.1.42010 1832 12 IP src.port -> dst.port bytes packets 127.0.0.1.42010 -> 127.0.0.1.12865 1568 8 127.0.0.1.59526 -> 127.0.0.1.33778 23198092 351486 127.0.0.1.33778 -> 127.0.0.1.59526 22972698518 698616 127.0.0.1.12865 -> 127.0.0.1.42010 1832 12 this example is similar to sockex2 in a way that it accumulates per-flow statistics, but it does packet parsing differently. sockex2 inlines full packet parser routine into single bpf program. This sockex3 example have 4 independent programs that parse vlan, mpls, ip, ipv6 and one main program that starts the process. bpf_tail_call() mechanism allows each program to be small and be called on demand potentially multiple times, so that many vlan, mpls, ip in ip, gre encapsulations can be parsed. These and other protocol parsers can be added or removed at runtime. TLVs can be parsed in similar manner. Note, tail_call_cnt dynamic check limits the number of tail calls to 32. Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-21samples/bpf: bpf_tail_call example for tracingAlexei Starovoitov
kprobe example that demonstrates how future seccomp programs may look like. It attaches to seccomp_phase1() function and tail-calls other BPF programs depending on syscall number. Existing optimized classic BPF seccomp programs generated by Chrome look like: if (sd.nr < 121) { if (sd.nr < 57) { if (sd.nr < 22) { if (sd.nr < 7) { if (sd.nr < 4) { if (sd.nr < 1) { check sys_read } else { if (sd.nr < 3) { check sys_write and sys_open } else { check sys_close } } } else { } else { } else { } else { } else { } the future seccomp using native eBPF may look like: bpf_tail_call(&sd, &syscall_jmp_table, sd.nr); which is simpler, faster and leaves more room for per-syscall checks. Usage: $ sudo ./tracex5 <...>-366 [001] d... 4.870033: : read(fd=1, buf=00007f6d5bebf000, size=771) <...>-369 [003] d... 4.870066: : mmap <...>-369 [003] d... 4.870077: : syscall=110 (one of get/set uid/pid/gid) <...>-369 [003] d... 4.870089: : syscall=107 (one of get/set uid/pid/gid) sh-369 [000] d... 4.891740: : read(fd=0, buf=00000000023d1000, size=512) sh-369 [000] d... 4.891747: : write(fd=1, buf=00000000023d3000, size=512) sh-369 [000] d... 4.891747: : read(fd=1, buf=00000000023d3000, size=512) Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-12samples/bpf: fix in-source build of samples with clangBrenden Blanco
in-source build of 'make samples/bpf/' was incorrectly using default compiler instead of invoking clang/llvm. out-of-source build was ok. Fixes: a80857822b0c ("samples: bpf: trivial eBPF program in C") Signed-off-by: Brenden Blanco <bblanco@plumgrid.com> Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-16bpf: fix two bugs in verification logic when accessing 'ctx' pointerAlexei Starovoitov
1. first bug is a silly mistake. It broke tracing examples and prevented simple bpf programs from loading. In the following code: if (insn->imm == 0 && BPF_SIZE(insn->code) == BPF_W) { } else if (...) { // this part should have been executed when // insn->code == BPF_W and insn->imm != 0 } Obviously it's not doing that. So simple instructions like: r2 = *(u64 *)(r1 + 8) will be rejected. Note the comments in the code around these branches were and still valid and indicate the true intent. Replace it with: if (BPF_SIZE(insn->code) != BPF_W) continue; if (insn->imm == 0) { } else if (...) { // now this code will be executed when // insn->code == BPF_W and insn->imm != 0 } 2. second bug is more subtle. If malicious code is using the same dest register as source register, the checks designed to prevent the same instruction to be used with different pointer types will fail to trigger, since we were assigning src_reg_type when it was already overwritten by check_mem_access(). The fix is trivial. Just move line: src_reg_type = regs[insn->src_reg].type; before check_mem_access(). Add new 'access skb fields bad4' test to check this case. Fixes: 9bac3d6d548e ("bpf: allow extended BPF programs access skb fields") Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-16bpf: fix bpf helpers to use skb->mac_header relative offsetsAlexei Starovoitov
For the short-term solution, lets fix bpf helper functions to use skb->mac_header relative offsets instead of skb->data in order to get the same eBPF programs with cls_bpf and act_bpf work on ingress and egress qdisc path. We need to ensure that mac_header is set before calling into programs. This is effectively the first option from below referenced discussion. More long term solution for LD_ABS|LD_IND instructions will be more intrusive but also more beneficial than this, and implemented later as it's too risky at this point in time. I.e., we plan to look into the option of moving skb_pull() out of eth_type_trans() and into netif_receive_skb() as has been suggested as second option. Meanwhile, this solution ensures ingress can be used with eBPF, too, and that we won't run into ABI troubles later. For dealing with negative offsets inside eBPF helper functions, we've implemented bpf_skb_clone_unwritable() to test for unwriteable headers. Reference: http://thread.gmane.org/gmane.linux.network/359129/focus=359694 Fixes: 608cd71a9c7c ("tc: bpf: generalize pedit action") Fixes: 91bc4822c3d6 ("tc: bpf: add checksum helpers") Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) Add BQL support to via-rhine, from Tino Reichardt. 2) Integrate SWITCHDEV layer support into the DSA layer, so DSA drivers can support hw switch offloading. From Floria Fainelli. 3) Allow 'ip address' commands to initiate multicast group join/leave, from Madhu Challa. 4) Many ipv4 FIB lookup optimizations from Alexander Duyck. 5) Support EBPF in cls_bpf classifier and act_bpf action, from Daniel Borkmann. 6) Remove the ugly compat support in ARP for ugly layers like ax25, rose, etc. And use this to clean up the neigh layer, then use it to implement MPLS support. All from Eric Biederman. 7) Support L3 forwarding offloading in switches, from Scott Feldman. 8) Collapse the LOCAL and MAIN ipv4 FIB tables when possible, to speed up route lookups even further. From Alexander Duyck. 9) Many improvements and bug fixes to the rhashtable implementation, from Herbert Xu and Thomas Graf. In particular, in the case where an rhashtable user bulk adds a large number of items into an empty table, we expand the table much more sanely. 10) Don't make the tcp_metrics hash table per-namespace, from Eric Biederman. 11) Extend EBPF to access SKB fields, from Alexei Starovoitov. 12) Split out new connection request sockets so that they can be established in the main hash table. Much less false sharing since hash lookups go direct to the request sockets instead of having to go first to the listener then to the request socks hashed underneath. From Eric Dumazet. 13) Add async I/O support for crytpo AF_ALG sockets, from Tadeusz Struk. 14) Support stable privacy address generation for RFC7217 in IPV6. From Hannes Frederic Sowa. 15) Hash network namespace into IP frag IDs, also from Hannes Frederic Sowa. 16) Convert PTP get/set methods to use 64-bit time, from Richard Cochran. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1816 commits) fm10k: Bump driver version to 0.15.2 fm10k: corrected VF multicast update fm10k: mbx_update_max_size does not drop all oversized messages fm10k: reset head instead of calling update_max_size fm10k: renamed mbx_tx_dropped to mbx_tx_oversized fm10k: update xcast mode before synchronizing multicast addresses fm10k: start service timer on probe fm10k: fix function header comment fm10k: comment next_vf_mbx flow fm10k: don't handle mailbox events in iov_event path and always process mailbox fm10k: use separate workqueue for fm10k driver fm10k: Set PF queues to unlimited bandwidth during virtualization fm10k: expose tx_timeout_count as an ethtool stat fm10k: only increment tx_timeout_count in Tx hang path fm10k: remove extraneous "Reset interface" message fm10k: separate PF only stats so that VF does not display them fm10k: use hw->mac.max_queues for stats fm10k: only show actual queues, not the maximum in hardware fm10k: allow creation of VLAN on default vid fm10k: fix unused warnings ...
2015-04-06tc: bpf: add checksum helpersAlexei Starovoitov
Commit 608cd71a9c7c ("tc: bpf: generalize pedit action") has added the possibility to mangle packet data to BPF programs in the tc pipeline. This patch adds two helpers bpf_l3_csum_replace() and bpf_l4_csum_replace() for fixing up the protocol checksums after the packet mangling. It also adds 'flags' argument to bpf_skb_store_bytes() helper to avoid unnecessary checksum recomputations when BPF programs adjusting l3/l4 checksums and documents all three helpers in uapi header. Moreover, a sample program is added to show how BPF programs can make use of the mangle and csum helpers. Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-02samples/bpf: Add kmem_alloc()/free() tracker toolAlexei Starovoitov
One BPF program attaches to kmem_cache_alloc_node() and remembers all allocated objects in the map. Another program attaches to kmem_cache_free() and deletes corresponding object from the map. User space walks the map every second and prints any objects which are older than 1 second. Usage: $ sudo tracex4 Then start few long living processes. The 'tracex4' will print something like this: obj 0xffff880465928000 is 13sec old was allocated at ip ffffffff8105dc32 obj 0xffff88043181c280 is 13sec old was allocated at ip ffffffff8105dc32 obj 0xffff880465848000 is 8sec old was allocated at ip ffffffff8105dc32 obj 0xffff8804338bc280 is 15sec old was allocated at ip ffffffff8105dc32 $ addr2line -fispe vmlinux ffffffff8105dc32 do_fork at fork.c:1665 As soon as processes exit the memory is reclaimed and 'tracex4' prints nothing. Similar experiment can be done with the __kmalloc()/kfree() pair. Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Arnaldo Carvalho de Melo <acme@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Daniel Borkmann <daniel@iogearbox.net> Cc: David S. Miller <davem@davemloft.net> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1427312966-8434-10-git-send-email-ast@plumgrid.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-04-02samples/bpf: Add IO latency analysis (iosnoop/heatmap) toolAlexei Starovoitov
BPF C program attaches to blk_mq_start_request()/blk_update_request() kprobe events to calculate IO latency. For every completed block IO event it computes the time delta in nsec and records in a histogram map: map[log10(delta)*10]++ User space reads this histogram map every 2 seconds and prints it as a 'heatmap' using gray shades of text terminal. Black spaces have many events and white spaces have very few events. Left most space is the smallest latency, right most space is the largest latency in the range. Usage: $ sudo ./tracex3 and do 'sudo dd if=/dev/sda of=/dev/null' in other terminal. Observe IO latencies and how different activity (like 'make kernel') affects it. Similar experiments can be done for network transmit latencies, syscalls, etc. '-t' flag prints the heatmap using normal ascii characters: $ sudo ./tracex3 -t heatmap of IO latency # - many events with this latency - few events |1us |10us |100us |1ms |10ms |100ms |1s |10s *ooo. *O.#. # 221 . *# . # 125 .. .o#*.. # 55 . . . . .#O # 37 .# # 175 .#*. # 37 # # 199 . . *#*. # 55 *#..* # 42 # # 266 ...***Oo#*OO**o#* . # 629 # # 271 . .#o* o.*o* # 221 . . o* *#O.. # 50 Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Cc: Arnaldo Carvalho de Melo <acme@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Daniel Borkmann <daniel@iogearbox.net> Cc: David S. Miller <davem@davemloft.net> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1427312966-8434-9-git-send-email-ast@plumgrid.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-04-02samples/bpf: Add counting example for kfree_skb() function calls and the ↵Alexei Starovoitov
write() syscall this example has two probes in one C file that attach to different kprove events and use two different maps. 1st probe is x64 specific equivalent of dropmon. It attaches to kfree_skb, retrevies 'ip' address of kfree_skb() caller and counts number of packet drops at that 'ip' address. User space prints 'location - count' map every second. 2nd probe attaches to kprobe:sys_write and computes a histogram of different write sizes Usage: $ sudo tracex2 location 0xffffffff81695995 count 1 location 0xffffffff816d0da9 count 2 location 0xffffffff81695995 count 2 location 0xffffffff816d0da9 count 2 location 0xffffffff81695995 count 3 location 0xffffffff816d0da9 count 2 557145+0 records in 557145+0 records out 285258240 bytes (285 MB) copied, 1.02379 s, 279 MB/s syscall write() stats byte_size : count distribution 1 -> 1 : 3 | | 2 -> 3 : 0 | | 4 -> 7 : 0 | | 8 -> 15 : 0 | | 16 -> 31 : 2 | | 32 -> 63 : 3 | | 64 -> 127 : 1 | | 128 -> 255 : 1 | | 256 -> 511 : 0 | | 512 -> 1023 : 1118968 |************************************* | Ctrl-C at any time. Kernel will auto cleanup maps and programs $ addr2line -ape ./bld_x64/vmlinux 0xffffffff81695995 0xffffffff816d0da9 0xffffffff81695995: ./bld_x64/../net/ipv4/icmp.c:1038 0xffffffff816d0da9: ./bld_x64/../net/unix/af_unix.c:1231 Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Cc: Arnaldo Carvalho de Melo <acme@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Daniel Borkmann <daniel@iogearbox.net> Cc: David S. Miller <davem@davemloft.net> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1427312966-8434-8-git-send-email-ast@plumgrid.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-04-02samples/bpf: Add simple non-portable kprobe filter exampleAlexei Starovoitov
tracex1_kern.c - C program compiled into BPF. It attaches to kprobe:netif_receive_skb() When skb->dev->name == "lo", it prints sample debug message into trace_pipe via bpf_trace_printk() helper function. tracex1_user.c - corresponding user space component that: - loads BPF program via bpf() syscall - opens kprobes:netif_receive_skb event via perf_event_open() syscall - attaches the program to event via ioctl(event_fd, PERF_EVENT_IOC_SET_BPF, prog_fd); - prints from trace_pipe Note, this BPF program is non-portable. It must be recompiled with current kernel headers. kprobe is not a stable ABI and BPF+kprobe scripts may no longer be meaningful when kernel internals change. No matter in what way the kernel changes, neither the kprobe, nor the BPF program can ever crash or corrupt the kernel, assuming the kprobes, perf and BPF subsystem has no bugs. The verifier will detect that the program is using bpf_trace_printk() and the kernel will print 'this is a DEBUG kernel' warning banner, which means that bpf_trace_printk() should be used for debugging of the BPF program only. Usage: $ sudo tracex1 ping-19826 [000] d.s2 63103.382648: : skb ffff880466b1ca00 len 84 ping-19826 [000] d.s2 63103.382684: : skb ffff880466b1d300 len 84 ping-19826 [000] d.s2 63104.382533: : skb ffff880466b1ca00 len 84 ping-19826 [000] d.s2 63104.382594: : skb ffff880466b1d300 len 84 Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Cc: Arnaldo Carvalho de Melo <acme@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Daniel Borkmann <daniel@iogearbox.net> Cc: David S. Miller <davem@davemloft.net> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1427312966-8434-7-git-send-email-ast@plumgrid.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-03-17bpf: allow BPF programs access 'protocol' and 'vlan_tci' fieldsAlexei Starovoitov
as a follow on to patch 70006af95515 ("bpf: allow eBPF access skb fields") this patch allows 'protocol' and 'vlan_tci' fields to be accessible from extended BPF programs. The usage of 'protocol', 'vlan_present' and 'vlan_tci' fields is the same as corresponding SKF_AD_PROTOCOL, SKF_AD_VLAN_TAG_PRESENT and SKF_AD_VLAN_TAG accesses in classic BPF. Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-15samples: bpf: add skb->field examples and testsAlexei Starovoitov
- modify sockex1 example to count number of bytes in outgoing packets - modify sockex2 example to count number of bytes and packets per flow - add 4 stress tests that exercise 'skb->field' code path of verifier Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-01ebpf: export BPF_PSEUDO_MAP_FD to uapiDaniel Borkmann
We need to export BPF_PSEUDO_MAP_FD to user space, as it's used in the ELF BPF loader where instructions are being loaded that need map fixups. An initial stage loads all maps into the kernel, and later on replaces related instructions in the eBPF blob with BPF_PSEUDO_MAP_FD as source register and the actual fd as immediate value. The kernel verifier recognizes this keyword and replaces the map fd with a real pointer internally. Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-01ebpf: remove kernel test stubsDaniel Borkmann
Now that we have BPF_PROG_TYPE_SOCKET_FILTER up and running, we can remove the test stubs which were added to get the verifier suite up. We can just let the test cases probe under socket filter type instead. In the fill/spill test case, we cannot (yet) access fields from the context (skb), but we may adapt that test case in future. Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-26samples: bpf: relax test_maps checkAlexei Starovoitov
hash map is unordered, so get_next_key() iterator shouldn't rely on particular order of elements. So relax this test. Fixes: ffb65f27a155 ("bpf: add a testsuite for eBPF maps") Reported-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Acked-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-05samples: bpf: large eBPF program in CAlexei Starovoitov
sockex2_kern.c is purposefully large eBPF program in C. llvm compiles ~200 lines of C code into ~300 eBPF instructions. It's similar to __skb_flow_dissect() to demonstrate that complex packet parsing can be done by eBPF. Then it uses (struct flow_keys)->dst IP address (or hash of ipv6 dst) to keep stats of number of packets per IP. User space loads eBPF program, attaches it to loopback interface and prints dest_ip->#packets stats every second. Usage: $sudo samples/bpf/sockex2 ip 127.0.0.1 count 19 ip 127.0.0.1 count 178115 ip 127.0.0.1 count 369437 ip 127.0.0.1 count 559841 ip 127.0.0.1 count 750539 Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-05samples: bpf: trivial eBPF program in CAlexei Starovoitov
this example does the same task as previous socket example in assembler, but this one does it in C. eBPF program in kernel does: /* assume that packet is IPv4, load one byte of IP->proto */ int index = load_byte(skb, ETH_HLEN + offsetof(struct iphdr, protocol)); long *value; value = bpf_map_lookup_elem(&my_map, &index); if (value) __sync_fetch_and_add(value, 1); Corresponding user space reads map[tcp], map[udp], map[icmp] and prints protocol stats every second Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-05samples: bpf: elf_bpf file loaderAlexei Starovoitov
simple .o parser and loader using BPF syscall. .o is a standard ELF generated by LLVM backend It parses elf file compiled by llvm .c->.o - parses 'maps' section and creates maps via BPF syscall - parses 'license' section and passes it to syscall - parses elf relocations for BPF maps and adjusts BPF_LD_IMM64 insns by storing map_fd into insn->imm and marking such insns as BPF_PSEUDO_MAP_FD - loads eBPF programs via BPF syscall One ELF file can contain multiple BPF programs. int load_bpf_file(char *path); populates prog_fd[] and map_fd[] with FDs received from bpf syscall bpf_helpers.h - helper functions available to eBPF programs written in C Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-05samples: bpf: example of stateful socket filteringAlexei Starovoitov
this socket filter example does: - creates arraymap in kernel with key 4 bytes and value 8 bytes - loads eBPF program which assumes that packet is IPv4 and loads one byte of IP->proto from the packet and uses it as a key in a map r0 = skb->data[ETH_HLEN + offsetof(struct iphdr, protocol)]; *(u32*)(fp - 4) = r0; value = bpf_map_lookup_elem(map_fd, fp - 4); if (value) (*(u64*)value) += 1; - attaches this program to raw socket - every second user space reads map[IPPROTO_TCP], map[IPPROTO_UDP], map[IPPROTO_ICMP] to see how many packets of given protocol were seen on loopback interface Usage: $sudo samples/bpf/sock_example TCP 0 UDP 0 ICMP 0 packets TCP 187600 UDP 0 ICMP 4 packets TCP 376504 UDP 0 ICMP 8 packets TCP 563116 UDP 0 ICMP 12 packets TCP 753144 UDP 0 ICMP 16 packets Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-18bpf: remove test map scaffolding and user proper typesAlexei Starovoitov
proper types and function helpers are ready. Use them in verifier testsuite. Remove temporary stubs Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-18bpf: add a testsuite for eBPF mapsAlexei Starovoitov
. check error conditions and sanity of hash and array map APIs . check large maps (that kernel gracefully switches to vmalloc from kmalloc) . check multi-process parallel access and stress test Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-30samples: bpf: add a verifier test and summary lineAlexei Starovoitov
- add a test specifically targeting verifier state pruning. It checks state propagation between registers, storing that state into stack and state pruning algorithm recognizing equivalent stack and register states. - add summary line to spot failures easier Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-21bpf: fix bug in eBPF verifierAlexei Starovoitov
while comparing for verifier state equivalency the comparison was missing a check for uninitialized register. Make sure it does so and add a testcase. Fixes: f1bca824dabb ("bpf: add search pruning optimization to verifier") Cc: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-01bpf: add tests to verifier testsuiteAlexei Starovoitov
add 4 extra tests to cover jump verification better Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-26bpf: mini eBPF library, test stubs and verifier testsuiteAlexei Starovoitov
1. the library includes a trivial set of BPF syscall wrappers: int bpf_create_map(int key_size, int value_size, int max_entries); int bpf_update_elem(int fd, void *key, void *value); int bpf_lookup_elem(int fd, void *key, void *value); int bpf_delete_elem(int fd, void *key); int bpf_get_next_key(int fd, void *key, void *next_key); int bpf_prog_load(enum bpf_prog_type prog_type, const struct sock_filter_int *insns, int insn_len, const char *license); bpf_prog_load() stores verifier log into global bpf_log_buf[] array and BPF_*() macros to build instructions 2. test stubs configure eBPF infra with 'unspec' map and program types. These are fake types used by user space testsuite only. 3. verifier tests valid and invalid programs and expects predefined error log messages from kernel. 40 tests so far. $ sudo ./test_verifier #0 add+sub+mul OK #1 unreachable OK #2 unreachable2 OK #3 out of range jump OK #4 out of range jump2 OK #5 test1 ld_imm64 OK ... Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
