Currently, kernel pktgen has the feature to specify udp destination port
for sending packet. (e.g. pgset "udp_dst_min 9")
But on samples, each of the scripts doesn't have any option to achieve this.
This commit adds the DST_PORT option to specify the target port(s) in the script.
-p : ($DST_PORT) destination PORT range (e.g. 433-444) is also allowed
Signed-off-by: Daniel T. Lee <danieltimlee@gmail.com>
Acked-by: Jesper Dangaard Brouer <brouer@redhat.com>
Files removed in 'net-next' had their license header updated
in 'net'. We take the remove from 'net-next'.
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Like sample05, don't use pktgen clone_skb feature when using 'burst' feature,
it is not really needed. This brings the burst users in sync.
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
Use "-f <num>", to specify the index of the first
sender thread.
In default first thread is #0.
Signed-off-by: Tariq Toukan <tariqt@mellanox.com>
Cc: Jesper Dangaard Brouer <brouer@redhat.com>
Use -n <num>, to specify the number of packets every
thread sends.
Zero means indefinitely.
Add a '-6' option to the sample pktgen scripts for sending out
IPv6 packets.
[root@kerneldev010.prn1 ~/pktgen]# ./pktgen_sample03_burst_single_flow.sh -i eth0 -s 64 -d fe80::f652:14ff:fec2:a14c -m f4:52:14:c2:a1:4c -b 32 -6
[root@kerneldev011.prn1 ~]# tcpdump -i eth0 -nn -c3 port 9
tcpdump: WARNING: eth0: no IPv4 address assigned
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0, link-type EN10MB (Ethernet), capture size 65535 bytes
14:38:51.815297 IP6 fe80::f652:14ff:fec2:2ad2.9 > fe80::f652:14ff:fec2:a14c.9: UDP, length 16
14:38:51.815311 IP6 fe80::f652:14ff:fec2:2ad2.9 > fe80::f652:14ff:fec2:a14c.9: UDP, length 16
14:38:51.815313 IP6 fe80::f652:14ff:fec2:2ad2.9 > fe80::f652:14ff:fec2:a14c.9: UDP, length 16
Signed-off-by: Martin KaFai Lau <kafai@fb.com>
Acked-by: Alexei Starovoitov <ast@kernel.org>
Add the pktgen samples script pktgen_sample03_burst_single_flow.sh
that demonstrates how to acheive maximum performance.
If correctly tuned[1] single CPU 10Gbit/s wirespeed small pkts is
possible[2] which is 14.88Mpps. The trick is to take advantage of the
"burst" feature introduced in commit 38b2cf2982dc73 ("net: pktgen:
packet bursting via skb->xmit_more").
[1] http://netoptimizer.blogspot.dk/2014/06/pktgen-for-network-overload-testing.html
[2] http://netoptimizer.blogspot.dk/2014/10/unlocked-10gbps-tx-wirespeed-smallest.html
