[ Upstream commit 8ba35b3a0046d6573c98f00461d9bd1b86250d35 ]
Clang warns:
samples/vfio-mdev/mtty.c:592:39: warning: implicit conversion from 'int'
to 'char' changes value from 162 to -94 [-Wconstant-conversion]
*buf = UART_MSR_DSR | UART_MSR_DDSR | UART_MSR_DCD;
1 warning generated.
Turns out that all uses of buf in this function ultimately end up stored
or cast to an unsigned type. Just use u8, which has the same number of
bits but can store this larger number so Clang no longer warns.
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
We set info.count to 1 in mtty_get_irq_info() so static checkers
complain that, "Why do we have impossible conditions?" The answer is
that it seems to be left over dead code that can be safely removed.
Reviewed-by: Kirti Wankhede <kwankhede@nvidia.com>
This is a sample driver for documentation so the impact is probably
pretty low. But we should check that bar_index is valid so we
don't write beyond the end of the mdev_state->region_info[] array.
Fixes: 9d1a546c53b4 ("docs: Sample driver to demonstrate how to use Mediated device framework.")
The copy_to_user() function returns the number of bytes which it wasn't
able to copy but we want to return a negative error code.
This is just sample code. We forget to set the error codes in a couple
places.
Reported-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
Abstract access to mdev_device so that we can define which interfaces
are public rather than relying on comments in the structure.
Cc: Zhenyu Wang <zhenyuw@linux.intel.com>
Cc: Zhi Wang <zhi.a.wang@intel.com>
Reviewed-by: Jike Song <jike.song@intel.com>
Reviewed by: Kirti Wankhede <kwankhede@nvidia.com>
Rather than hoping for good behavior by marking some elements
internal, enforce it by making the entire structure private and
creating an accessor function for the one useful external field.
Cc: Jike Song <jike.song@intel.com>
Add an mdev_ prefix so we're not poluting the namespace so much.
This sample driver was originally under Documentation/ and was moved
to samples, but build support was never adjusted for the new location.
Reviewed-by: Eric Auger <eric.auger@redhat.com>
Tested-by: Eric Auger <eric.auger@redhat.com>
The Sample driver creates mdev device that simulates serial port over PCI
card.
Signed-off-by: Kirti Wankhede <kwankhede@nvidia.com>
Signed-off-by: Neo Jia <cjia@nvidia.com>
