path: root/samples
2020-01-12samples: bpf: fix syscall_tp due to unused syscallDaniel T. Lee
[ Upstream commit fe3300897cbfd76c6cb825776e5ac0ca50a91ca4 ] Currently, open() is called from the user program and it calls the syscall 'sys_openat', not the 'sys_open'. This leads to an error of the program of user side, due to the fact that the counter maps are zero since no function such 'sys_open' is called. This commit adds the kernel bpf program which are attached to the tracepoint 'sys_enter_openat' and 'sys_enter_openat'. Fixes: 1da236b6be963 ("bpf: add a test case for syscalls/sys_{enter|exit}_* tracepoints") Signed-off-by: Daniel T. Lee <danieltimlee@gmail.com> Signed-off-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-01-12samples: bpf: Replace symbol compare of trace_eventDaniel T. Lee
[ Upstream commit bba1b2a890253528c45aa66cf856f289a215bfbc ] Previously, when this sample is added, commit 1c47910ef8013 ("samples/bpf: add perf_event+bpf example"), a symbol 'sys_read' and 'sys_write' has been used without no prefixes. But currently there are no exact symbols with these under kallsyms and this leads to failure. This commit changes exact compare to substring compare to keep compatible with exact symbol or prefixed symbol. Fixes: 1c47910ef8013 ("samples/bpf: add perf_event+bpf example") Signed-off-by: Daniel T. Lee <danieltimlee@gmail.com> Signed-off-by: Alexei Starovoitov <ast@kernel.org> Link: https://lore.kernel.org/bpf/20191205080114.19766-2-danieltimlee@gmail.com Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-31samples: pktgen: fix proc_cmd command result check logicDaniel T. Lee
[ Upstream commit 3cad8f911575191fb3b81d8ed0e061e30f922223 ] Currently, proc_cmd is used to dispatch command to 'pg_ctrl', 'pg_thread', 'pg_set'. proc_cmd is designed to check command result with grep the "Result:", but this might fail since this string is only shown in 'pg_thread' and 'pg_set'. This commit fixes this logic by grep-ing the "Result:" string only when the command is not for 'pg_ctrl'. For clarity of an execution flow, 'errexit' flag has been set. To cleanup pktgen on exit, trap has been added for EXIT signal. Signed-off-by: Daniel T. Lee <danieltimlee@gmail.com> Acked-by: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-31selftests/bpf: Correct path to include msg + pathIvan Khoronzhuk
[ Upstream commit c588146378962786ddeec817f7736a53298a7b01 ] The "path" buf is supposed to contain path + printf msg up to 24 bytes. It will be cut anyway, but compiler generates truncation warns like: " samples/bpf/../../tools/testing/selftests/bpf/cgroup_helpers.c: In function ‘setup_cgroup_environment’: samples/bpf/../../tools/testing/selftests/bpf/cgroup_helpers.c:52:34: warning: ‘/cgroup.controllers’ directive output may be truncated writing 19 bytes into a region of size between 1 and 4097 [-Wformat-truncation=] snprintf(path, sizeof(path), "%s/cgroup.controllers", cgroup_path); ^~~~~~~~~~~~~~~~~~~ samples/bpf/../../tools/testing/selftests/bpf/cgroup_helpers.c:52:2: note: ‘snprintf’ output between 20 and 4116 bytes into a destination of size 4097 snprintf(path, sizeof(path), "%s/cgroup.controllers", cgroup_path); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ samples/bpf/../../tools/testing/selftests/bpf/cgroup_helpers.c:72:34: warning: ‘/cgroup.subtree_control’ directive output may be truncated writing 23 bytes into a region of size between 1 and 4097 [-Wformat-truncation=] snprintf(path, sizeof(path), "%s/cgroup.subtree_control", ^~~~~~~~~~~~~~~~~~~~~~~ cgroup_path); samples/bpf/../../tools/testing/selftests/bpf/cgroup_helpers.c:72:2: note: ‘snprintf’ output between 24 and 4120 bytes into a destination of size 4097 snprintf(path, sizeof(path), "%s/cgroup.subtree_control", cgroup_path); " In order to avoid warns, lets decrease buf size for cgroup workdir on 24 bytes with assumption to include also "/cgroup.subtree_control" to the address. The cut will never happen anyway. Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@linaro.org> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Song Liu <songliubraving@fb.com> Link: https://lore.kernel.org/bpf/20191002120404.26962-3-ivan.khoronzhuk@linaro.org Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-05vfio-mdev/samples: Use u8 instead of char for handle functionsNathan Chancellor
[ Upstream commit 8ba35b3a0046d6573c98f00461d9bd1b86250d35 ] Clang warns: samples/vfio-mdev/mtty.c:592:39: warning: implicit conversion from 'int' to 'char' changes value from 162 to -94 [-Wconstant-conversion] *buf = UART_MSR_DSR | UART_MSR_DDSR | UART_MSR_DCD; ~ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~ 1 warning generated. Turns out that all uses of buf in this function ultimately end up stored or cast to an unsigned type. Just use u8, which has the same number of bits but can store this larger number so Clang no longer warns. Signed-off-by: Nathan Chancellor <natechancellor@gmail.com> Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-11-24mei: samples: fix a signedness bug in amt_host_if_call()Dan Carpenter
[ Upstream commit 185647813cac080453cb73a2e034a8821049f2a7 ] "out_buf_sz" needs to be signed for the error handling to work. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-11-20samples/bpf: fix compilation failurePrashant Bhole
[ Upstream commit 32c009798385ce21080beaa87a9b95faad3acd1e ] following commit: commit d58e468b1112 ("flow_dissector: implements flow dissector BPF hook") added struct bpf_flow_keys which conflicts with the struct with same name in sockex2_kern.c and sockex3_kern.c similar to commit: commit 534e0e52bc23 ("samples/bpf: fix a compilation failure") we tried the rename it "flow_keys" but it also conflicted with struct having same name in include/net/flow_dissector.h. Hence renaming the struct to "flow_key_record". Also, this commit doesn't fix the compilation error completely because the similar struct is present in sockex3_kern.c. Hence renaming it in both files sockex3_user.c and sockex3_kern.c Signed-off-by: Prashant Bhole <bhole_prashant_q7@lab.ntt.co.jp> Acked-by: Song Liu <songliubraving@fb.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-11-20samples/bpf: fix a compilation failureYonghong Song
[ Upstream commit 534e0e52bc23de588e81b5a6f75e10c8c4b189fc ] samples/bpf build failed with the following errors: $ make samples/bpf/ ... HOSTCC samples/bpf/sockex3_user.o /data/users/yhs/work/net-next/samples/bpf/sockex3_user.c:16:8: error: redefinition of ‘struct bpf_flow_keys’ struct bpf_flow_keys { ^ In file included from /data/users/yhs/work/net-next/samples/bpf/sockex3_user.c:4:0: ./usr/include/linux/bpf.h:2338:9: note: originally defined here struct bpf_flow_keys *flow_keys; ^ make[3]: *** [samples/bpf/sockex3_user.o] Error 1 Commit d58e468b1112d ("flow_dissector: implements flow dissector BPF hook") introduced struct bpf_flow_keys in include/uapi/linux/bpf.h and hence caused the naming conflict with samples/bpf/sockex3_user.c. The fix is to rename struct bpf_flow_keys in samples/bpf/sockex3_user.c to flow_keys to avoid the conflict. Signed-off-by: Yonghong Song <yhs@fb.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-07-21samples, bpf: fix to change the buffer size for read()Chang-Hsien Tsai
[ Upstream commit f7c2d64bac1be2ff32f8e4f500c6e5429c1003e0 ] If the trace for read is larger than 4096, the return value sz will be 4096. This results in off-by-one error on buf: static char buf[4096]; ssize_t sz; sz = read(trace_fd, buf, sizeof(buf)); if (sz > 0) { buf[sz] = 0; puts(buf); } Signed-off-by: Chang-Hsien Tsai <luke.tw@gmail.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-02-15samples: mei: use /dev/mei0 instead of /dev/meiTomas Winkler
commit c4a46acf1db3ce547d290c29e55b3476c78dd76c upstream. The device was moved from misc device to character devices to support multiple mei devices. Cc: <stable@vger.kernel.org> #v4.9+ Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-24samples/bpf: Check the error of write() and read()Taeung Song
[ Upstream commit 02a2f000a3629274bfad60bfc4de9edec49e63e7 ] test_task_rename() and test_urandom_read() can be failed during write() and read(), So check the result of them. Reviewed-by: David Laight <David.Laight@ACULAB.COM> Signed-off-by: Taeung Song <treeze.taeung@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-24samples/bpf: Check the result of system()Taeung Song
[ Upstream commit 492b7e894587c151be681f86d4d1d086375f7b45 ] To avoid the below build warning message, use new generate_load() checking the return value. ignoring return value of ‘system’, declared with attribute warn_unused_result And it also refactors the duplicate code of both test_perf_event_all_cpu() and test_perf_event_task() Cc: Teng Qin <qinteng@fb.com> Signed-off-by: Taeung Song <treeze.taeung@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-24samples/bpf: add missing <linux/if_vlan.h>Taeung Song
[ Upstream commit 4d5d33a085335ef469c9a87792bcaaaa8e64d8c4 ] This fixes build error regarding redefinition: CLANG-bpf samples/bpf/parse_varlen.o samples/bpf/parse_varlen.c:111:8: error: redefinition of 'vlan_hdr' struct vlan_hdr { ^ ./include/linux/if_vlan.h:38:8: note: previous definition is here So remove duplicate 'struct vlan_hdr' in sample code and include if_vlan.h Signed-off-by: Taeung Song <treeze.taeung@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-26samples/bpf: Partially fixes the bpf.o buildMickaël Salaün
[ Upstream commit c25ef6a5e62fa212d298ce24995ce239f29b5f96 ] Do not build lib/bpf/bpf.o with this Makefile but use the one from the library directory. This avoid making a buggy bpf.o file (e.g. missing symbols). This patch is useful if some code (e.g. Landlock tests) needs both the bpf.o (from tools/lib/bpf) and the bpf_load.o (from samples/bpf). Signed-off-by: Mickaël Salaün <mic@digikod.net> Cc: Alexei Starovoitov <ast@kernel.org> Cc: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20samples/bpf: adjust rlimit RLIMIT_MEMLOCK for xdp1Tushar Dave
[ Upstream commit 6dfca831c03ef654b1f7bff1b8d487d330e9f76b ] Default rlimit RLIMIT_MEMLOCK is 64KB, causes bpf map failure. e.g. [root@lab bpf]#./xdp1 -N $(</sys/class/net/eth2/ifindex) failed to create a map: 1 Operation not permitted Fix it. Signed-off-by: Tushar Dave <tushar.n.dave@oracle.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-02Merge tag 'spdx_identifiers-4.14-rc8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull initial SPDX identifiers from Greg KH: "License cleanup: add SPDX license identifiers to some files Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'spdx_identifiers-4.14-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: License cleanup: add SPDX license identifier to uapi header files with a license License cleanup: add SPDX license identifier to uapi header files with no license License cleanup: add SPDX GPL-2.0 license identifier to files with no license
2017-10-27Fix tracing sample code warning.Linus Torvalds
Commit 6575257c60e1 ("tracing/samples: Fix creation and deletion of simple_thread_fn creation") introduced a new warning due to using a boolean as a counter. Just make it "int". Fixes: 6575257c60e1 ("tracing/samples: Fix creation and deletion of simple_thread_fn creation") Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-10-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "A little more than usual this time around. Been travelling, so that is part of it. Anyways, here are the highlights: 1) Deal with memcontrol races wrt. listener dismantle, from Eric Dumazet. 2) Handle page allocation failures properly in nfp driver, from Jaku Kicinski. 3) Fix memory leaks in macsec, from Sabrina Dubroca. 4) Fix crashes in pppol2tp_session_ioctl(), from Guillaume Nault. 5) Several fixes in bnxt_en driver, including preventing potential NVRAM parameter corruption from Michael Chan. 6) Fix for KRACK attacks in wireless, from Johannes Berg. 7) rtnetlink event generation fixes from Xin Long. 8) Deadlock in mlxsw driver, from Ido Schimmel. 9) Disallow arithmetic operations on context pointers in bpf, from Jakub Kicinski. 10) Missing sock_owned_by_user() check in sctp_icmp_redirect(), from Xin Long. 11) Only TCP is supported for sockmap, make that explicit with a check, from John Fastabend. 12) Fix IP options state races in DCCP and TCP, from Eric Dumazet. 13) Fix panic in packet_getsockopt(), also from Eric Dumazet. 14) Add missing locked in hv_sock layer, from Dexuan Cui. 15) Various aquantia bug fixes, including several statistics handling cures. From Igor Russkikh et al. 16) Fix arithmetic overflow in devmap code, from John Fastabend. 17) Fix busted socket memory accounting when we get a fault in the tcp zero copy paths. From Willem de Bruijn. 18) Don't leave opt->tot_len uninitialized in ipv6, from Eric Dumazet" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (106 commits) stmmac: Don't access tx_q->dirty_tx before netif_tx_lock ipv6: flowlabel: do not leave opt->tot_len with garbage of_mdio: Fix broken PHY IRQ in case of probe deferral textsearch: fix typos in library helpers rxrpc: Don't release call mutex on error pointer net: stmmac: Prevent infinite loop in get_rx_timestamp_status() net: stmmac: Fix stmmac_get_rx_hwtstamp() net: stmmac: Add missing call to dev_kfree_skb() mlxsw: spectrum_router: Configure TIGCR on init mlxsw: reg: Add Tunneling IPinIP General Configuration Register net: ethtool: remove error check for legacy setting transceiver type soreuseport: fix initialization race net: bridge: fix returning of vlan range op errors sock: correct sk_wmem_queued accounting on efault in tcp zerocopy bpf: add test cases to bpf selftests to cover all access tests bpf: fix pattern matches for direct packet access bpf: fix off by one for range markings with L{T, E} patterns bpf: devmap fix arithmetic overflow in bitmap_size calculation net: aquantia: Bad udp rate on default interrupt coalescing net: aquantia: Enable coalescing management via ethtool interface ...
2017-10-20bpf: avoid preempt enable/disable in sockmap using tcp_skb_cb regionJohn Fastabend
SK_SKB BPF programs are run from the socket/tcp context but early in the stack before much of the TCP metadata is needed in tcp_skb_cb. So we can use some unused fields to place BPF metadata needed for SK_SKB programs when implementing the redirect function. This allows us to drop the preempt disable logic. It does however require an API change so sk_redirect_map() has been updated to additionally provide ctx_ptr to skb. Note, we do however continue to disable/enable preemption around actual BPF program running to account for map updates. Signed-off-by: John Fastabend <john.fastabend@gmail.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-10-18Merge tag 'trace-v4.14-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing fix from Steven Rostedt: "Testing a new trace event format, I triggered a bug by doing: # modprobe trace-events-sample # echo 1 > /sys/kernel/debug/tracing/events/sample-trace/enable # rmmod trace-events-sample This would cause an oops. The issue is that I added another trace event sample that reused a reg function of another trace event to create a thread to call the tracepoints. The problem was that the reg function couldn't handle nested calls (reg; reg; unreg; unreg;) and created two threads (instead of one) and only removed one on exit. This isn't a critical bug as the bug is only in sample code. But sample code should be free of known bugs to prevent others from copying it. This is why this is also marked for stable" * tag 'trace-v4.14-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: tracing/samples: Fix creation and deletion of simple_thread_fn creation
2017-10-17tracing/samples: Fix creation and deletion of simple_thread_fn creationSteven Rostedt (VMware)
Commit 7496946a8 ("tracing: Add samples of DECLARE_EVENT_CLASS() and DEFINE_EVENT()") added template examples for all the events. It created a DEFINE_EVENT_FN() example which reused the foo_bar_reg and foo_bar_unreg functions. Enabling both the TRACE_EVENT_FN() and DEFINE_EVENT_FN() example trace events caused the foo_bar_reg to be called twice, creating the test thread twice. The foo_bar_unreg would remove it only once, even if it was called multiple times, leaving a thread existing when the module is unloaded, causing an oops. Add a ref count and allow foo_bar_reg() and foo_bar_unreg() be called by multiple trace events. Cc: stable@vger.kernel.org Fixes: 7496946a8 ("tracing: Add samples of DECLARE_EVENT_CLASS() and DEFINE_EVENT()") Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
2017-09-07Merge tag 'media/v4.14-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: "Brazil's Independence Day pull request :-) This is one of the biggest media pull requests, with 625 patches affecting almost all parts of media (RC, DVB, V4L2, CEC, docs). This contains: - A lot of new drivers: * DVB frontends: mxl5xx, stv0910, stv6111; * camera flash: as3645a led driver; * HDMI receiver: adv748X; * camera sensor: Omnivision 6650 5M driver (ov6650); * HDMI CEC: ao-cec meson driver; * V4L2: Qualcom camss driver; * Remote controller: gpio-ir-tx, pwm-ir-tx and zx-irdec drivers. - The DDbridge DVB driver got a massive update, with makes it in sync with modern hardware from that vendor; - There's an important milestone on this series: the DVB documentation was written in 2003, but only started to be updated in 2007. It also used to contain several gaps from the time it was kept out of tree, mentioning error codes and device nodes that never existed upstream. On this series, it received a massive update: all non-deprecated digital TV APIs are now in sync with the current implementation; - Some DVB APIs that aren't used by any upstream driver got removed; - Other parts of the media documentation algo got updated, fixing some bugs on its PDF output and making it compatible with Sphinx version 1.6. As the number of hacks required to build PDF output reduced, I hope we'll have less troubles as newer versions of our documentation toolchain are released (famous last words); - As usual, lots of driver cleanups and improvements" * tag 'media/v4.14-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (624 commits) media: leds: as3645a: add V4L2_FLASH_LED_CLASS dependency media: get rid of removed DMX_GET_CAPS and DMX_SET_SOURCE leftovers media: Revert "[media] v4l: async: make v4l2 coexist with devicetree nodes in a dt overlay" media: staging: atomisp: sh_css_calloc shall return a pointer to the allocated space media: Revert "[media] lirc_dev: remove superfluous get/put_device() calls" media: add qcom_camss.rst to v4l-drivers rst file media: dvb headers: make checkpatch happier media: dvb uapi: move frontend legacy API to another part of the book media: pixfmt-srggb12p.rst: better format the table for PDF output media: docs-rst: media: Don't use \small for V4L2_PIX_FMT_SRGGB10 documentation media: index.rst: don't write "Contents:" on PDF output media: pixfmt*.rst: replace a two dots by a comma media: vidioc-g-fmt.rst: adjust table format media: vivid.rst: add a blank line to correct ReST format media: v4l2 uapi book: get rid of driver programming's chapter media: format.rst: use the right markup for important notes media: docs-rst: cardlists: change their format to flat-tables media: em28xx-cardlist.rst: update to reflect last changes media: v4l2-event.rst: adjust table to fit on PDF output media: docs: don't show ToC for each part on PDF output ...
2017-09-01bpf: Add lru_hash_lookup performance testMartin KaFai Lau
Create a new case to test the LRU lookup performance. At the beginning, the LRU map is fully loaded (i.e. the number of keys is equal to map->max_entries). The lookup is done through key 0 to num_map_entries and then repeats from 0 again. This patch also creates an anonymous struct to properly name the test params in stress_lru_hmap_alloc() in map_perf_test_kern.c. Signed-off-by: Martin KaFai Lau <kafai@fb.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-09-01samples/bpf: Update cgroup socket examples to use uid gid helperDavid Ahern
Signed-off-by: David Ahern <dsahern@gmail.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-09-01samples/bpf: Update cgrp2 socket testsDavid Ahern
Update cgrp2 bpf sock tests to check that device, mark and priority can all be set on a socket via bpf programs attached to a cgroup. Signed-off-by: David Ahern <dsahern@gmail.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-09-01samples/bpf: Add option to dump socket settingsDavid Ahern
Add option to dump socket settings. Will be used in the next patch to verify bpf programs are correctly setting mark, priority and device based on the cgroup attachment for the program run. Signed-off-by: David Ahern <dsahern@gmail.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-09-01samples/bpf: Add detach option to test_cgrp2_sockDavid Ahern
Add option to detach programs from a cgroup. Signed-off-by: David Ahern <dsahern@gmail.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-09-01samples/bpf: Update sock test to allow setting mark and priorityDavid Ahern
Update sock test to set mark and priority on socket create. Signed-off-by: David Ahern <dsahern@gmail.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-08-31samples/bpf: Fix compilation issue in redirect dummy programTariq Toukan
Fix compilation error below: $ make samples/bpf/ LLVM ERROR: 'xdp_redirect_dummy' label emitted multiple times to assembly file make[1]: *** [samples/bpf/xdp_redirect_kern.o] Error 1 make: *** [samples/bpf/] Error 2 Fixes: 306da4e685b4 ("samples/bpf: xdp_redirect load XDP dummy prog on TX device") Signed-off-by: Tariq Toukan <tariqt@mellanox.com> Acked-by: Jesper Dangaard Brouer <brouer@redhat.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-08-29samples/bpf: xdp_monitor tool based on tracepointsJesper Dangaard Brouer
This tool xdp_monitor demonstrate how to use the different xdp_redirect tracepoints xdp_redirect{,_map}{,_err} from a BPF program. The default mode is to only monitor the error counters, to avoid affecting the per packet performance. Tracepoints comes with a base overhead of 25 nanosec for an attached bpf_prog, and 48 nanosec for using a full perf record (with non-matching filter). Thus, default loading the --stats mode could affect the maximum performance. This version of the tool is very simple and count all types of errors as one. It will be natural to extend this later with the different types of errors that can occur, which should help users quickly identify common mistakes. Because the TP_STRUCT was kept in sync all the tracepoints loads the same BPF code. It would also be natural to extend the map version to demonstrate how the map information could be used. Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-08-29samples/bpf: xdp_redirect load XDP dummy prog on TX deviceJesper Dangaard Brouer
For supporting XDP_REDIRECT, a device driver must (obviously) implement the "TX" function ndo_xdp_xmit(). An additional requirement is you cannot TX out a device, unless it also have a xdp bpf program attached. This dependency is caused by the driver code need to setup XDP resources before it can ndo_xdp_xmit. Update bpf samples xdp_redirect and xdp_redirect_map to automatically attach a dummy XDP program to the configured ifindex_out device. Use the XDP flag XDP_FLAGS_UPDATE_IF_NOEXIST on the dummy load, to avoid overriding an existing XDP prog on the device. Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-08-28samples/bpf: extend test_tunnel_bpf.sh with ERSPANWilliam Tu
Extend existing tests for vxlan, gre, geneve, ipip to include ERSPAN tunnel. Signed-off-by: William Tu <u9012063@gmail.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-08-28bpf: convert sockmap field attach_bpf_fd2 to typeJohn Fastabend
In the initial sockmap API we provided strparser and verdict programs using a single attach command by extending the attach API with a the attach_bpf_fd2 field. However, if we add other programs in the future we will be adding a field for every new possible type, attach_bpf_fd(3,4,..). This seems a bit clumsy for an API. So lets push the programs using two new type fields. BPF_SK_SKB_STREAM_PARSER BPF_SK_SKB_STREAM_VERDICT This has the advantage of having a readable name and can easily be extended in the future. Updates to samples and sockmap included here also generalize tests slightly to support upcoming patch for multiple map support. Signed-off-by: John Fastabend <john.fastabend@gmail.com> Fixes: 174a79ff9515 ("bpf: sockmap with sk redirect support") Suggested-by: Alexei Starovoitov <ast@kernel.org> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-08-20media: v4l2-pci-skeleton: constify vb2_ops structuresJulia Lawall
These vb2_ops structures are only stored in the ops field of a vb2_queue structure, which is declared as const. Thus the vb2_ops structures themselves can be const. Done with the help of Coccinelle. // <smpl> @r disable optional_qualifier@ identifier i; position p; @@ static struct vb2_ops i@p = { ... }; @ok@ identifier r.i; struct vb2_queue e; position p; @@ e.ops = &i@p; @bad@ position p != {r.p,ok.p}; identifier r.i; struct vb2_ops e; @@ e@i@p @depends on !bad disable optional_qualifier@ identifier r.i; @@ static +const struct vb2_ops i = { ... }; // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-08-19bpf: Allow numa selection in INNER_LRU_HASH_PREALLOC test of map_perf_testMartin KaFai Lau
This patch makes the needed changes to allow each process of the INNER_LRU_HASH_PREALLOC test to provide its numa node id when creating the lru map. Signed-off-by: Martin KaFai Lau <kafai@fb.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@fb.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-08-16bpf: sockmap sample programJohn Fastabend
This program binds a program to a cgroup and then matches hard coded IP addresses and adds these to a sockmap. This will receive messages from the backend and send them to the client. client:X <---> frontend:10000 client:X <---> backend:10001 To keep things simple this is only designed for 1:1 connections using hard coded values. A more complete example would allow many backends and clients. To run, # sockmap <cgroup2_dir> Signed-off-by: John Fastabend <john.fastabend@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-08-07bpf: add a test case for syscalls/sys_{enter|exit}_* tracepointsYonghong Song
Signed-off-by: Yonghong Song <yhs@fb.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-08-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Two minor conflicts in virtio_net driver (bug fix overlapping addition of a helper) and MAINTAINERS (new driver edit overlapping revamp of PHY entry). Signed-off-by: David S. Miller <davem@davemloft.net>
2017-07-31samples/bpf: fix bpf tunnel cleanupWilliam Tu
test_tunnel_bpf.sh fails to remove the vxlan11 tunnel device, causing the next geneve tunnelling test case fails. In addition, the geneve reserved bit in tcbpf2_kern.c should be zero, according to the RFC. Signed-off-by: William Tu <u9012063@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-07-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2017-07-17samples/bpf: add option for native and skb mode for redirect appsAndy Gospodarek
When testing with a driver that has both native and generic redirect support: $ sudo ./samples/bpf/xdp_redirect -N 5 6 input: 5 output: 6 ifindex 6: 4961879 pkt/s ifindex 6: 6391319 pkt/s ifindex 6: 6419468 pkt/s $ sudo ./samples/bpf/xdp_redirect -S 5 6 input: 5 output: 6 ifindex 6: 1845435 pkt/s ifindex 6: 3882850 pkt/s ifindex 6: 3893974 pkt/s $ sudo ./samples/bpf/xdp_redirect_map -N 5 6 input: 5 output: 6 map[0] (vports) = 4, map[1] (map) = 5, map[2] (count) = 0 ifindex 6: 2207374 pkt/s ifindex 6: 6212869 pkt/s ifindex 6: 6286515 pkt/s $ sudo ./samples/bpf/xdp_redirect_map -S 5 6 input: 5 output: 6 map[0] (vports) = 4, map[1] (map) = 5, map[2] (count) = 0 ifindex 6: 5052528 pkt/s ifindex 6: 5736631 pkt/s ifindex 6: 5739962 pkt/s Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Acked-by: John Fastabend <john.fastabend@gmail.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-07-17xdp: bpf redirect with map sample programJohn Fastabend
Signed-off-by: John Fastabend <john.fastabend@gmail.com> Tested-by: Andy Gospodarek <andy@greyhouse.net> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-07-17xdp: sample program for new bpf_redirect helperJohn Fastabend
This implements a sample program for testing bpf_redirect. It reports the number of packets redirected per second and as input takes the ifindex of the device to run the xdp program on and the ifindex of the interface to redirect packets to. Signed-off-by: John Fastabend <john.fastabend@gmail.com> Tested-by: Andy Gospodarek <andy@greyhouse.net> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-07-13Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge yet more updates from Andrew Morton: - various misc things - kexec updates - sysctl core updates - scripts/gdb udpates - checkpoint-restart updates - ipc updates - kernel/watchdog updates - Kees's "rough equivalent to the glibc _FORTIFY_SOURCE=1 feature" - "stackprotector: ascii armor the stack canary" - more MM bits - checkpatch updates * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (96 commits) writeback: rework wb_[dec|inc]_stat family of functions ARM: samsung: usb-ohci: move inline before return type video: fbdev: omap: move inline before return type video: fbdev: intelfb: move inline before return type USB: serial: safe_serial: move __inline__ before return type drivers: tty: serial: move inline before return type drivers: s390: move static and inline before return type x86/efi: move asmlinkage before return type sh: move inline before return type MIPS: SMP: move asmlinkage before return type m68k: coldfire: move inline before return type ia64: sn: pci: move inline before type ia64: move inline before return type FRV: tlbflush: move asmlinkage before return type CRIS: gpio: move inline before return type ARM: HP Jornada 7XX: move inline before return type ARM: KVM: move asmlinkage before type checkpatch: improve the STORAGE_CLASS test mm, migration: do not trigger OOM killer when migrating memory drm/i915: use __GFP_RETRY_MAYFAIL ...
2017-07-12kfifo: clean up example to not use page_linkLogan Gunthorpe
This is a layering violation so we replace the uses with calls to sg_page(). This is a prep patch for replacing page_link and this is one of the very few uses outside of scatterlist.h. Link: http://lkml.kernel.org/r/1495663199-22234-1-git-send-email-logang@deltatee.com Signed-off-by: Logan Gunthorpe <logang@deltatee.com> Signed-off-by: Stephen Bates <sbates@raithlin.com> Acked-by: Stefani Seibold <stefani@seibold.net> Cc: Stefani Seibold <stefani@seibold.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-07-11samples/bpf: fix a build issueYonghong Song
With latest net-next: ==== clang -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/6.3.1/include -I./arch/x86/include -I./arch/x86/include/generated/uapi -I./arch/x86/include/generated -I./include -I./arch/x86/include/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/kconfig.h -Isamples/bpf \ -D__KERNEL__ -D__ASM_SYSREG_H -Wno-unused-value -Wno-pointer-sign \ -Wno-compare-distinct-pointer-types \ -Wno-gnu-variable-sized-type-not-at-end \ -Wno-address-of-packed-member -Wno-tautological-compare \ -Wno-unknown-warning-option \ -O2 -emit-llvm -c samples/bpf/tcp_synrto_kern.c -o -| llc -march=bpf -filetype=obj -o samples/bpf/tcp_synrto_kern.o samples/bpf/tcp_synrto_kern.c:20:10: fatal error: 'bpf_endian.h' file not found ^~~~~~~~~~~~~~ 1 error generated. ==== net has the same issue. Add support for ntohl and htonl in tools/testing/selftests/bpf/bpf_endian.h. Also move bpf_helpers.h from samples/bpf to selftests/bpf and change compiler include logic so that programs in samples/bpf can access the headers in selftests/bpf, but not the other way around. Signed-off-by: Yonghong Song <yhs@fb.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Lawrence Brakmo <brakmo@fb.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-07-05bpf: fix return in load_bpf_fileLawrence Brakmo
The function load_bpf_file ignores the return value of load_and_attach(), so even if load_and_attach() returns an error, load_bpf_file() will return 0. Now, load_bpf_file() can call load_and_attach() multiple times and some can succeed and some could fail. I think the correct behavor is to return error on the first failed load_and_attach(). v2: Added missing SOB Signed-off-by: Lawrence Brakmo <brakmo@fb.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-07-01bpf: Sample bpf program to set sndcwnd clampLawrence Brakmo
Sample BPF program, tcp_clamp_kern.c, to demostrate the use of setting the sndcwnd clamp. This program assumes that if the first 5.5 bytes of the host's IPv6 addresses are the same, then the hosts are in the same datacenter and sets sndcwnd clamp to 100 packets, SYN and SYN-ACK RTOs to 10ms and send/receive buffer sizes to 150KB. Signed-off-by: Lawrence Brakmo <brakmo@fb.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-07-01bpf: Sample BPF program to set initial cwndLawrence Brakmo
Sample BPF program that assumes hosts are far away (i.e. large RTTs) and sets initial cwnd and initial receive window to 40 packets, send and receive buffers to 1.5MB. In practice there would be a test to insure the hosts are actually far enough away. Signed-off-by: Lawrence Brakmo <brakmo@fb.com> Signed-off-by: David S. Miller <davem@davemloft.net>
