[ Upstream commit f4dea9689c5fea3d07170c2cb0703e216f1a0922 ]
Using sizeof(nv) or strlen(nv)+1 is correct.
Fixes: c890063e4404 ("bpf: sample BPF_SOCKET_OPS_BASE_RTT program")
Signed-off-by: Pengcheng Yang <yangpc@wangsu.com>
Link: https://lore.kernel.org/r/1683276658-2860-1-git-send-email-yangpc@wangsu.com
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
[ Upstream commit 23acb14af1914010dd0aae1bbb7fab28bf518b8e ]
Fix fout being fopen'ed but then not subsequently fclose'd. In the affected
branch, fout is otherwise going out of scope.
Signed-off-by: Hao Zeng <zenghao@kylinos.cn>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Link: https://lore.kernel.org/bpf/20230411084349.1999628-1-zenghao@kylinos.cn
[ Upstream commit d1f0f50fbbbbca1e3e8157e51934613bf88f6d44 ]
Add missing pci_disable_device() in fail path of mdpy_fb_probe().
Besides, fix missing release functions in mdpy_fb_remove().
Fixes: cacade1946a4 ("sample: vfio mdev display - guest driver")
Signed-off-by: Shang XiaoJing <shangxiaojing@huawei.com>
Link: https://lore.kernel.org/r/20221208013341.3999-1-shangxiaojing@huawei.com
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
[ Upstream commit f76fbbbb5061fe14824ba5807c44bd7400a6b4e1 ]
Use the actual return value instead of always -1 if register_kretprobe()
failed.
E.g. without this patch:
# insmod samples/kprobes/kretprobe_example.ko func=no_such_func
insmod: ERROR: could not insert module samples/kprobes/kretprobe_example.ko: Operation not permitted
With this patch:
insmod: ERROR: could not insert module samples/kprobes/kretprobe_example.ko: Unknown symbol in module
Link: https://lkml.kernel.org/r/1635213091-24387-2-git-send-email-yangtiezhu@loongson.cn
Fixes: 804defea1c02 ("Kprobes: move kprobe examples to samples/")
Signed-off-by: Tiezhu Yang <yangtiezhu@loongson.cn>
Acked-by: Masami Hiramatsu <mhiramat@kernel.org>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
[ Upstream commit 7d07006f05922b95518be403f08ef8437b67aa32 ]
The current behavior of 'tracex7' doesn't consist with other bpf samples
tracex{1..6}. Other samples do not require any argument to run with, but
tracex7 should be run with btrfs device argument. (it should be executed
with test_override_return.sh)
Currently, tracex7 doesn't have any description about how to run this
program and raises an unexpected error. And this result might be
confusing since users might not have a hunch about how to run this
program.
// Current behavior
# ./tracex7
sh: 1: Syntax error: word unexpected (expecting ")")
// Fixed behavior
# ./tracex7
ERROR: Run with the btrfs device argument!
In order to fix this error, this commit adds logic to report a message
and exit when running this program with a missing argument.
Additionally in test_override_return.sh, there is a problem with
multiple directory(tmpmnt) creation. So in this commit adds a line with
removing the directory with every execution.
Signed-off-by: Juhee Kang <claudiajkang@gmail.com>
Signed-off-by: Andrii Nakryiko <andrii@kernel.org>
Acked-by: Yonghong Song <yhs@fb.com>
Link: https://lore.kernel.org/bpf/20210727041056.23455-1-claudiajkang@gmail.com
[ Upstream commit 7c6090ee2a7b3315410cfc83a94c3eb057407b25 ]
Fix to return a negative error code from the error handling
case instead of 0, as done elsewhere in this function.
If bpf_map_update_elem() failed, main() should return a negative error.
Fixes: 832622e6bd18 ("xdp: sample program for new bpf_redirect helper")
Signed-off-by: Wang Hai <wanghai38@huawei.com>
Link: https://lore.kernel.org/bpf/20210616042534.315097-1-wanghai38@huawei.com
[ Upstream commit 752774ce7793a1f8baa55aae31f3b4caac49cbe4 ]
Fix to return a negative error code from the framebuffer_alloc() error
handling case instead of 0, also release regions in some error handing
cases.
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
Message-Id: <20210520133641.1421378-1-weiyongjun1@huawei.com>
[ Upstream commit 137733d08f4ab14a354dacaa9a8fc35217747605 ]
>From commit c0bbbdc32feb ("__netif_receive_skb_core: pass skb by
reference"), the first argument passed into __netif_receive_skb_core
has changed to reference of a skb pointer.
This commit fixes by using bpf_probe_read_kernel.
Signed-off-by: Yaqi Chen <chendotjs@gmail.com>
Link: https://lore.kernel.org/bpf/20210416154803.37157-1-chendotjs@gmail.com
[ Upstream commit 926ee00ea24320052b46745ef4b00d91c05bd03d ]
The intent with this code was to return negative error codes but instead
it returns positives.
The problem is how type promotion works with ternary operations. These
functions return long, "ret" is an int and "copied" is a u32. The
negative error code is first cast to u32 so it becomes a high positive and
then cast to long where it's still a positive.
We could fix this by declaring "ret" as a ssize_t but let's just get rid
of the ternaries instead.
Link: https://lkml.kernel.org/r/YIE+/cK1tBzSuQPU@mwanda
Fixes: 5bf2b19320ec ("kfifo: add example files to the kernel sample directory")
Cc: Stefani Seibold <stefani@seibold.net>
commit 6bc6699881012b5bd5d49fa861a69a37fc01b49c upstream.
We mmap the umem region, but we never munmap it.
Add the missing call at the end of the cleanup.
Fixes: 3945b37a975d ("samples/bpf: use hugepages in xdpsock app")
Signed-off-by: Maciej Fijalkowski <maciej.fijalkowski@intel.com>
Acked-by: Björn Töpel <bjorn.topel@intel.com>
Link: https://lore.kernel.org/bpf/20210303185636.18070-3-maciej.fijalkowski@intel.com
[ Upstream commit 0afe0a998c40085a6342e1aeb4c510cccba46caf ]
Currently, lwt_len_hist's map lwt_len_hist_map is uses pinning, and the
map isn't cleared on test end. This leds to reuse of that map for
each test, which prevents the results of the test from being accurate.
This commit fixes the problem by removing of pinned map from bpffs.
Also, this commit add the executable permission to shell script
files.
Fixes: f74599f7c5309 ("bpf: Add tests and samples for LWT-BPF")
Signed-off-by: Daniel T. Lee <danieltimlee@gmail.com>
Link: https://lore.kernel.org/bpf/20201124090310.24374-7-danieltimlee@gmail.com
[ Upstream commit 5a2a0dd88f0f267ac5953acd81050ae43a82201f ]
Fix a possible deadlock in the l2fwd application in xdpsock that can
occur when there is no space in the Tx ring. There are two ways to get
the kernel to consume entries in the Tx ring: calling sendto() to make
it send packets and freeing entries from the completion ring, as the
kernel will not send a packet if there is no space for it to add a
completion entry in the completion ring. The Tx loop in l2fwd only
used to call sendto(). This patches adds cleaning the completion ring
in that loop.
Signed-off-by: Magnus Karlsson <magnus.karlsson@intel.com>
Link: https://lore.kernel.org/bpf/1599726666-8431-3-git-send-email-magnus.karlsson@gmail.com
[ Upstream commit cc1a2679865a94b83804822996eed010a50a7c1d ]
Since struct _mic_vring_info and vring are allocated together and follow
vring, if the vring_size() is not four bytes aligned, which will cause
the start address of struct _mic_vring_info is not four byte aligned.
For example, when vring entries is 128, the vring_size() will be 5126
bytes. The _mic_vring_info struct layout in ddr looks like:
0x90002400: 00000000 00390000 EE010000 0000C0FF
Here 0x39 is the avail_idx member, and 0xC0FFEE01 is the magic member.
When EP use ioread32(magic) to reads the magic in RC's share memory, it
will cause kernel panic on ARM64 platform due to the cross-byte io read.
Here read magic in user space use le32toh(vr0->info->magic) will meet
the same issue.
So add round_up(x,4) for vring_size, then the struct _mic_vring_info
will store in this way:
0x90002400: 00000000 00000000 00000039 C0FFEE01
Which will avoid kernel panic when read magic in struct _mic_vring_info.
Signed-off-by: Sherry Sun <sherry.sun@nxp.com>
Signed-off-by: Joakim Zhang <qiangqing.zhang@nxp.com>
Link: https://lore.kernel.org/r/20200929091106.24624-4-sherry.sun@nxp.com
[ Upstream commit eef8a42d6ce087d1c81c960ae0d14f955b742feb ]
The `BPF_LOG_BUF_SIZE`'s value is `UINT32_MAX >> 8`, so define an array
with it on stack caused an overflow.
Signed-off-by: Wenbo Zhang <ethercflow@gmail.com>
Acked-by: Andrii Nakryiko <andriin@fb.com>
Link: https://lore.kernel.org/bpf/20200710092035.28919-1-ethercflow@gmail.com
[ Upstream commit c3eeaae9fd736b7f2afbda8d3cbb1cbae06decf3 ]
Something changed recently to uncover this warning:
samples/vfs/test-statx.c:24:15: warning: `struct foo' declared inside parameter list will not be visible outside of this definition or declaration
24 | #define statx foo
Which is due the use of "struct statx" (here, "struct foo") in a function
prototype argument list before it has been defined:
int
# 56 "/usr/include/x86_64-linux-gnu/bits/statx-generic.h"
foo
# 56 "/usr/include/x86_64-linux-gnu/bits/statx-generic.h" 3 4
(int __dirfd, const char *__restrict __path, int __flags,
unsigned int __mask, struct
# 57 "/usr/include/x86_64-linux-gnu/bits/statx-generic.h"
foo
# 57 "/usr/include/x86_64-linux-gnu/bits/statx-generic.h" 3 4
*__restrict __buf)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 5)));
Add explicit struct before #include to avoid warning.
Fixes: f1b5618e013a ("vfs: Add a sample program for the new mount API")
Cc: Miklos Szeredi <mszeredi@redhat.com>
Link: http://lkml.kernel.org/r/202006282213.C516EA6@keescook
[ Upstream commit 6903cdae9f9f08d61e49c16cbef11c293e33a615 ]
Memset on the pointer right after malloc can cause a NULL pointer
deference if it failed to allocate memory. A simple fix is to
replace malloc()/memset() pair with a simple call to calloc().
Fixes: 0fca931a6f21 ("samples/bpf: program demonstrating access to xdp_rxq_info")
Signed-off-by: Gaurav Singh <gaurav1086@gmail.com>
Acked-by: Jesper Dangaard Brouer <brouer@redhat.com>
Acked-by: John Fastabend <john.fastabend@gmail.com>
[ Upstream commit 6a09815428547657f3ffd2f5c31ac2a191e7fdf3 ]
xdp_redirect_cpu is currently failing in bpf_prog_load_xattr()
allocating cpu_map map if CONFIG_NR_CPUS is less than 64 since
cpu_map_alloc() requires max_entries to be less than NR_CPUS.
Set cpu_map max_entries according to NR_CPUS in xdp_redirect_cpu_kern.c
and get currently running cpus in xdp_redirect_cpu_user.c
Signed-off-by: Lorenzo Bianconi <lorenzo@kernel.org>
Link: https://lore.kernel.org/bpf/374472755001c260158c4e4b22f193bdd3c56fb7.1589300442.git.lorenzo@kernel.org
[ Upstream commit 23ad04669f81f958e9a4121b0266228d2eb3c357 ]
GCC 10 is very strict about symbol clash, and lwt_len_hist_user contains
a symbol which clashes with libbpf:
/usr/bin/ld: samples/bpf/lwt_len_hist_user.o:(.bss+0x0): multiple definition of `bpf_log_buf'; samples/bpf/bpf_load.o:(.bss+0x8c0): first defined here
collect2: error: ld returned 1 exit status
bpf_log_buf here seems to be a leftover, so removing it.
Signed-off-by: Matteo Croce <mcroce@redhat.com>
Link: https://lore.kernel.org/bpf/20200511113234.80722-1-mcroce@redhat.com
commit bdebd6a2831b6fab69eb85cee74a8ba77f1a1cc2 upstream.
remap_vmalloc_range() has had various issues with the bounds checks it
promises to perform ("This function checks that addr is a valid
vmalloc'ed area, and that it is big enough to cover the vma") over time,
e.g.:
- not detecting pgoff<<PAGE_SHIFT overflow
- not detecting (pgoff<<PAGE_SHIFT)+usize overflow
- not checking whether addr and addr+(pgoff<<PAGE_SHIFT) are the same
vmalloc allocation
- comparing a potentially wildly out-of-bounds pointer with the end of
the vmalloc region
In particular, since commit fc9702273e2e ("bpf: Add mmap() support for
BPF_MAP_TYPE_ARRAY"), unprivileged users can cause kernel null pointer
dereferences by calling mmap() on a BPF map with a size that is bigger
than the distance from the start of the BPF map to the end of the
address space.
This could theoretically be used as a kernel ASLR bypass, by using
whether mmap() with a given offset oopses or returns an error code to
perform a binary search over the possible address range.
To allow remap_vmalloc_range_partial() to verify that addr and
addr+(pgoff<<PAGE_SHIFT) are in the same vmalloc region, pass the offset
to remap_vmalloc_range_partial() instead of adding it to the pointer in
remap_vmalloc_range().
In remap_vmalloc_range_partial(), fix the check against
get_vm_area_size() by using size comparisons instead of pointer
comparisons, and add checks for pgoff.
Fixes: 833423143c3a ("[PATCH] mm: introduce remap_vmalloc_range()")
Signed-off-by: Jann Horn <jannh@google.com>
Cc: stable@vger.kernel.org
Cc: Alexei Starovoitov <ast@kernel.org>
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: Martin KaFai Lau <kafai@fb.com>
Cc: Song Liu <songliubraving@fb.com>
Cc: Yonghong Song <yhs@fb.com>
Cc: Andrii Nakryiko <andriin@fb.com>
Cc: John Fastabend <john.fastabend@gmail.com>
Cc: KP Singh <kpsingh@chromium.org>
Link: http://lkml.kernel.org/r/20200415222312.236431-1-jannh@google.com
[ Upstream commit 450278977acbf494a20367c22fbb38729772d1fc ]
It seems Clang can in some cases turn on stack protection by default, which
doesn't work with BPF. This was reported once before[0], but it seems the
flag to explicitly turn off the stack protector wasn't added to the
Makefile, so do that now.
The symptom of this is compile errors like the following:
error: <unknown>:0:0: in function bpf_prog1 i32 (%struct.__sk_buff*): A call to built-in function '__stack_chk_fail' is not supported.
[0] https://www.spinics.net/lists/netdev/msg556400.html
Signed-off-by: Toke Høiland-Jørgensen <toke@redhat.com>
Link: https://lore.kernel.org/bpf/20191216103819.359535-1-toke@redhat.com
commit f9e6bfdbaf0cf304d72c70a05d81acac01a04f48 upstream.
When sample xdp_redirect_cpu was converted to use libbpf, the
tracepoints used by this sample were not getting attached automatically
like with bpf_load.c. The BPF-maps was still getting loaded, thus
nobody notice that the tracepoints were not updating these maps.
This fix doesn't use the new skeleton code, as this bug was introduced
in v5.1 and stable might want to backport this. E.g. Red Hat QA uses
this sample as part of their testing.
Fixes: bbaf6029c49c ("samples/bpf: Convert XDP samples to libbpf usage")
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
Link: https://lore.kernel.org/bpf/157685877642.26195.2798780195186786841.stgit@firesoul
commit b2e5e93ae8af6a34bca536cdc4b453ab1e707b8b upstream.
The 'clean' rule in the samples/bpf Makefile tries to remove backup
files (ending in ~). However, if no such files exist, it will instead try
to remove the user's home directory. While the attempt is mostly harmless,
it does lead to a somewhat scary warning like this:
rm: cannot remove '~': Is a directory
Fix this by using find instead of shell expansion to locate any actual
backup files that need to be removed.
Fixes: b62a796c109c ("samples/bpf: allow make to be run from samples/bpf/ directory")
Link: https://lore.kernel.org/bpf/157952560126.1683545.7273054725976032511.stgit@toke.dk
commit edbca120a8cdfa5a5793707e33497aa5185875ca upstream.
In the days of using bpf_load.c the order in which the 'maps' sections
were defines in BPF side (*_kern.c) file, were used by userspace side
to identify the map via using the map order as an index. In effect the
order-index is created based on the order the maps sections are stored
in the ELF-object file, by the LLVM compiler.
This have also carried over in libbpf via API bpf_map__next(NULL, obj)
to extract maps in the order libbpf parsed the ELF-object file.
When BTF based maps were introduced a new section type ".maps" were
created. I found that the LLVM compiler doesn't create the ".maps"
sections in the order they are defined in the C-file. The order in the
ELF file is based on the order the map pointer is referenced in the code.
This combination of changes lead to xdp_rxq_info mixing up the map
file-descriptors in userspace, resulting in very broken behaviour, but
without warning the user.
This patch fix issue by instead using bpf_object__find_map_by_name()
to find maps via their names. (Note, this is the ELF name, which can
be longer than the name the kernel retains).
Fixes: be5bca44aa6b ("samples: bpf: convert some XDP samples from bpf_load to libbpf")
Fixes: 451d1dc886b5 ("samples: bpf: update map definition to new syntax BTF-defined map")
Acked-by: Toke Høiland-Jørgensen <toke@redhat.com>
Link: https://lore.kernel.org/bpf/157529025128.29832.5953245340679936909.stgit@firesoul
commit 451d1dc886b548d6e18c933adca326c1307023c9 upstream.
Since, the new syntax of BTF-defined map has been introduced,
the syntax for using maps under samples directory are mixed up.
For example, some are already using the new syntax, and some are using
existing syntax by calling them as 'legacy'.
As stated at commit abd29c931459 ("libbpf: allow specifying map
definitions using BTF"), the BTF-defined map has more compatablility
with extending supported map definition features.
The commit doesn't replace all of the map to new BTF-defined map,
because some of the samples still use bpf_load instead of libbpf, which
can't properly create BTF-defined map.
This will only updates the samples which uses libbpf API for loading bpf
program. (ex. bpf_prog_load_xattr)
[ Upstream commit fe3300897cbfd76c6cb825776e5ac0ca50a91ca4 ]
Currently, open() is called from the user program and it calls the syscall
'sys_openat', not the 'sys_open'. This leads to an error of the program
of user side, due to the fact that the counter maps are zero since no
function such 'sys_open' is called.
This commit adds the kernel bpf program which are attached to the
tracepoint 'sys_enter_openat' and 'sys_enter_openat'.
Fixes: 1da236b6be963 ("bpf: add a test case for syscalls/sys_{enter|exit}_* tracepoints")
[ Upstream commit bba1b2a890253528c45aa66cf856f289a215bfbc ]
Previously, when this sample is added, commit 1c47910ef8013
("samples/bpf: add perf_event+bpf example"), a symbol 'sys_read' and
'sys_write' has been used without no prefixes. But currently there are
no exact symbols with these under kallsyms and this leads to failure.
This commit changes exact compare to substring compare to keep compatible
with exact symbol or prefixed symbol.
Fixes: 1c47910ef8013 ("samples/bpf: add perf_event+bpf example")
Link: https://lore.kernel.org/bpf/20191205080114.19766-2-danieltimlee@gmail.com
commit 01f36a554e3ef32f9fc4b81a4437cf08fd0e4742 upstream.
trace_printk schedules work via irq_work_queue(), but doesn't
wait until it was processed. The kprobe_module.tc testcase does:
:;: "Load module again, which means the event1 should be recorded";:
modprobe trace-printk
grep "event1:" trace
so the grep which checks the trace file might run before the irq work
was processed. Fix this by adding a irq_work_sync().
Link: http://lore.kernel.org/linux-trace-devel/20191218074427.96184-3-svens@linux.ibm.com
Fixes: af2a0750f3749 ("selftests/ftrace: Improve kprobe on module testcase to load/unload module")
Signed-off-by: Sven Schnelle <svens@linux.ibm.com>
commit 771b894f2f3dfedc2ba5561731fffa0e39b1bbb6 upstream.
The sizes by which seccomp_notif and seccomp_notif_resp are allocated are
based on the SECCOMP_GET_NOTIF_SIZES ioctl. This allows for graceful
extension of these datastructures. If userspace zeroes out the
datastructure based on its version, and it is lagging behind the kernel's
version, it will end up sending trailing garbage. On the other hand,
if it is ahead of the kernel version, it will write extra zero space,
and potentially cause corruption.
Signed-off-by: Sargun Dhillon <sargun@sargun.me>
Suggested-by: Tycho Andersen <tycho@tycho.ws>
Link: https://lore.kernel.org/r/20191230203503.4925-1-sargun@sargun.me
Fixes: fec7b6690541 ("samples: add an example of seccomp user trap")
[ Upstream commit 3cad8f911575191fb3b81d8ed0e061e30f922223 ]
Currently, proc_cmd is used to dispatch command to 'pg_ctrl', 'pg_thread',
'pg_set'. proc_cmd is designed to check command result with grep the
"Result:", but this might fail since this string is only shown in
'pg_thread' and 'pg_set'.
This commit fixes this logic by grep-ing the "Result:" string only when
the command is not for 'pg_ctrl'.
For clarity of an execution flow, 'errexit' flag has been set.
To cleanup pktgen on exit, trap has been added for EXIT signal.
To remove that test_attr__{enabled/open} are used by perf-sys.h, we
set HAVE_ATTR_TEST to zero.
Signed-off-by: Björn Töpel <bjorn.topel@intel.com>
Tested-by: KP Singh <kpsingh@google.com>
Acked-by: Song Liu <songliubraving@fb.com>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: bpf@vger.kernel.org
Cc: netdev@vger.kernel.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Link: http://lore.kernel.org/bpf/20191001113307.27796-3-bjorn.topel@gmail.com
This was added in commit eb111869301e ("compiler-types.h: add asm_inline
definition") and breaks samples/bpf as clang does not support asm __inline.
Fixes: eb111869301e ("compiler-types.h: add asm_inline definition")
Co-developed-by: Florent Revest <revest@google.com>
Signed-off-by: Florent Revest <revest@google.com>
Signed-off-by: KP Singh <kpsingh@google.com>
Link: https://lore.kernel.org/bpf/20191002191652.11432-1-kpsingh@chromium.org
Add missing include for <linux/perf_event.h> which was removed from
perf-sys.h in commit 91854f9a077e ("perf tools: Move everything
related to sys_perf_event_open() to perf-sys.h").
Fixes: 91854f9a077e ("perf tools: Move everything related to sys_perf_event_open() to perf-sys.h")
Reported-by: KP Singh <kpsingh@google.com>
Reported-by: Florent Revest <revest@google.com>
Link: https://lore.kernel.org/bpf/20191001112249.27341-1-bjorn.topel@gmail.com
git://git.kernel.org/pub/scm/linux/kernel/git/andersson/remoteproc
Pull rpmsg updates from Bjorn Andersson:
"This contains updates to make the rpmsg sample driver more useful,
fixes the naming of GLINK devices to avoid naming collisions and a few
minor bug fixes. It also updates MAINTAINERS to reflect the move to
kernel.org"
* tag 'rpmsg-v5.4' of git://git.kernel.org/pub/scm/linux/kernel/git/andersson/remoteproc:
rpmsg: glink-smem: Name the edge based on parent remoteproc
rpmsg: glink: Use struct_size() helper
rpmsg: virtio_rpmsg_bus: replace "%p" with "%pK"
MAINTAINERS: rpmsg: fix git tree location
rpmsg: core: fix comments
samples/rpmsg: Introduce a module parameter for message count
samples/rpmsg: Replace print_hex_dump() with print_hex_dump_debug()
Pull VFIO updates from Alex Williamson:
- Fix spapr iommu error case case (Alexey Kardashevskiy)
- Consolidate region type definitions (Cornelia Huck)
- Restore saved original PCI state on release (hexin)
- Simplify mtty sample driver interrupt path (Parav Pandit)
- Support for reporting valid IOVA regions to user (Shameer Kolothum)
* tag 'vfio-v5.4-rc1' of git://github.com/awilliam/linux-vfio:
vfio_pci: Restore original state on release
vfio/type1: remove duplicate retrieval of reserved regions
vfio/type1: Add IOVA range capability support
vfio/type1: check dma map request is within a valid iova range
vfio/spapr_tce: Fix incorrect tce_iommu_group memory free
vfio-mdev/mtty: Simplify interrupt generation
vfio: re-arrange vfio region definitions
vfio/type1: Update iova list on detach
vfio/type1: Check reserved region conflict and update iova list
vfio/type1: Introduce iova list and add iommu aperture validity check
Preserve the offset of the address of the received descriptor, and include
it in the address set for the tx descriptor, so the kernel can correctly
locate the start of the packet data.
Fixes: 03895e63ff97 ("samples/bpf: add buffer recycling for unaligned chunks to xdpsock")
Signed-off-by: Ciara Loftus <ciara.loftus@intel.com>
Daniel Borkmann says:
The following pull-request contains BPF updates for your *net-next* tree.
The main changes are:
1) Add the ability to use unaligned chunks in the AF_XDP umem. By
relaxing where the chunks can be placed, it allows to use an
arbitrary buffer size and place whenever there is a free
address in the umem. Helps more seamless DPDK AF_XDP driver
integration. Support for i40e, ixgbe and mlx5e, from Kevin and
Maxim.
2) Addition of a wakeup flag for AF_XDP tx and fill rings so the
application can wake up the kernel for rx/tx processing which
avoids busy-spinning of the latter, useful when app and driver
is located on the same core. Support for i40e, ixgbe and mlx5e,
from Magnus and Maxim.
3) bpftool fixes for printf()-like functions so compiler can actually
enforce checks, bpftool build system improvements for custom output
directories, and addition of 'bpftool map freeze' command, from Quentin.
4) Support attaching/detaching XDP programs from 'bpftool net' command,
from Daniel.
5) Automatic xskmap cleanup when AF_XDP socket is released, and several
barrier/{read,write}_once fixes in AF_XDP code, from Björn.
6) Relicense of bpf_helpers.h/bpf_endian.h for future libbpf
inclusion as well as libbpf versioning improvements, from Andrii.
7) Several new BPF kselftests for verifier precision tracking, from Alexei.
8) Several BPF kselftest fixes wrt endianess to run on s390x, from Ilya.
9) And more BPF kselftest improvements all over the place, from Stanislav.
10) Add simple BPF map op cache for nfp driver to batch dumps, from Jakub.
11) AF_XDP socket umem mapping improvements for 32bit archs, from Ivan.
12) Add BPF-to-BPF call and BTF line info support for s390x JIT, from Yauheni.
13) Small optimization in arm64 JIT to spare 1 insns for BPF_MOD, from Jerin.
14) Fix an error check in bpf_tcp_gen_syncookie() helper, from Petar.
15) Various minor fixes and cleanups, from Nathan, Masahiro, Masanari,
Peter, Wei, Yue.
This patch modifies xdpsock to use mmap instead of posix_memalign. With
this change, we can use hugepages when running the application in unaligned
chunks mode. Using hugepages makes it more likely that we have physically
contiguous memory, which supports the unaligned chunk mode better.
Signed-off-by: Kevin Laatz <kevin.laatz@intel.com>
Acked-by: Jonathan Lemon <jonathan.lemon@gmail.com>
This patch adds buffer recycling support for unaligned buffers. Since we
don't mask the addr to 2k at umem_reg in unaligned mode, we need to make
sure we give back the correct (original) addr to the fill queue. We achieve
this using the new descriptor format and associated masks. The new format
uses the upper 16-bits for the offset and the lower 48-bits for the addr.
Since we have a field for the offset, we no longer need to modify the
actual address. As such, all we have to do to get back the original address
is mask for the lower 48 bits (i.e. strip the offset and we get the address
on it's own).
Signed-off-by: Bruce Richardson <bruce.richardson@intel.com>
This patch adds support for the unaligned chunks mode. The addition of the
unaligned chunks option will allow users to run the application with more
relaxed chunk placement in the XDP umem.
Unaligned chunks mode can be used with the '-u' or '--unaligned' command
line options.
The current rpmsg_client_sample uses a fixed number of messages to
be sent to each instance. This is currently set at 100. Introduce
an optional module parameter 'count' so that the number of messages
to be exchanged can be made flexible.
Signed-off-by: Suman Anna <s-anna@ti.com>
Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Replace the raw print_hex_dump() call in the rpmsg_sample_cb() function
with the equivalent print_hex_dump_debug() better suited for dynamic
debug. This switch allows flexibility of controlling this trace through
dynamic debug when enabled.
For arm32 xdp sockets mmap2 is preferred, so use it if it's defined.
Declaration of __NR_mmap can be skipped and it breaks build.
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@linaro.org>
While generating interrupt, mdev_state is already available for which
interrupt is generated.
Instead of doing indirect way from state->device->uuid-> to searching
state linearly in linked list on every interrupt generation,
directly use the available state.
Hence, simplify the code to use mdev_state and remove unused helper
function with that.
Reviewed-by: Cornelia Huck <cohuck@redhat.com>
Signed-off-by: Parav Pandit <parav@mellanox.com>
Merge conflict of mlx5 resolved using instructions in merge
commit 9566e650bf7fdf58384bb06df634f7531ca3a97e.
This commit adds using the need_wakeup flag to the xdpsock sample
application. It is turned on by default as we think it is a feature
that seems to always produce a performance benefit, if the application
has been written taking advantage of it. It can be turned off in the
sample app by using the '-m' command line option.
The txpush and l2fwd sub applications have also been updated to
support poll() with multiple sockets.
There is a small merge conflict in libbpf (Cc Andrii so he's in the loop
as well):
for (i = 1; i <= btf__get_nr_types(btf); i++) {
t = (struct btf_type *)btf__type_by_id(btf, i);
if (!has_datasec && btf_is_var(t)) {
/* replace VAR with INT */
t->info = BTF_INFO_ENC(BTF_KIND_INT, 0, 0);
<<<<<<< HEAD
* using size = 1 is the safest choice, 4 will be too
* big and cause kernel BTF validation failure if
* original variable took less than 4 bytes
t->size = 1;
*(int *)(t+1) = BTF_INT_ENC(0, 0, 8);
} else if (!has_datasec && kind == BTF_KIND_DATASEC) {
t->size = sizeof(int);
*(int *)(t + 1) = BTF_INT_ENC(0, 0, 32);
} else if (!has_datasec && btf_is_datasec(t)) {
>>>>>>> 72ef80b5ee131e96172f19e74b4f98fa3404efe8
/* replace DATASEC with STRUCT */
Conflict is between the two commits 1d4126c4e119 ("libbpf: sanitize VAR to
conservative 1-byte INT") and b03bc6853c0e ("libbpf: convert libbpf code to
use new btf helpers"), so we need to pick the sanitation fixup as well as
use the new btf_is_datasec() helper and the whitespace cleanup. Looks like
the following:
t->size = 1;
*(int *)(t + 1) = BTF_INT_ENC(0, 0, 8);
1) Addition of core parts of compile once - run everywhere (co-re) effort,
that is, relocation of fields offsets in libbpf as well as exposure of
kernel's own BTF via sysfs and loading through libbpf, from Andrii.
More info on co-re: http://vger.kernel.org/bpfconf2019.html#session-2
and http://vger.kernel.org/lpc-bpf2018.html#session-2
2) Enable passing input flags to the BPF flow dissector to customize parsing
and allowing it to stop early similar to the C based one, from Stanislav.
3) Add a BPF helper function that allows generating SYN cookies from XDP and
tc BPF, from Petar.
4) Add devmap hash-based map type for more flexibility in device lookup for
redirects, from Toke.
5) Improvements to XDP forwarding sample code now utilizing recently enabled
devmap lookups, from Jesper.
6) Add support for reporting the effective cgroup progs in bpftool, from Jakub
and Takshak.
7) Fix reading kernel config from bpftool via /proc/config.gz, from Peter.
8) Fix AF_XDP umem pages mapping for 32 bit architectures, from Ivan.
9) Follow-up to add two more BPF loop tests for the selftest suite, from Alexei.
10) Add perf event output helper also for other skb-based program types, from Allan.
11) Fix a co-re related compilation error in selftests, from Yonghong.
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
Make it clear that this XDP program depend on the network
stack to do the ARP resolution. This is connected with the
BPF_FIB_LKUP_RET_NO_NEIGH return code from bpf_fib_lookup().
Another common mistake (seen via XDP-tutorial) is that users
don't realize that sysctl net.ipv{4,6}.conf.all.forwarding
setting is honored by bpf_fib_lookup.
Reported-by: Anton Protopopov <a.s.protopopov@gmail.com>
Reviewed-by: David Ahern <dsahern@gmail.com>
Reviewed-by: Toke Høiland-Jørgensen <toke@redhat.com>
This address the TODO in samples/bpf/xdp_fwd_kern.c, which points out
that the chosen egress index should be checked for existence in the
devmap. This can now be done via taking advantage of Toke's work in
commit 0cdbb4b09a06 ("devmap: Allow map lookups from eBPF").
This change makes xdp_fwd more practically usable, as this allows for
a mixed environment, where IP-forwarding fallback to network stack, if
the egress device isn't configured to use XDP.
The devmap name 'tx_port' came from a copy-paste from xdp_redirect_map
which only have a single TX port. Change name to xdp_tx_ports
to make it more descriptive.
This patch fix a spelling typo in cfag12864b-example.c
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Signed-off-by: Miguel Ojeda <miguel.ojeda.sandonis@gmail.com>
