path: root/samples
2018-08-24samples/bpf: Check the error of write() and read()Taeung Song
[ Upstream commit 02a2f000a3629274bfad60bfc4de9edec49e63e7 ] test_task_rename() and test_urandom_read() can be failed during write() and read(), So check the result of them. Reviewed-by: David Laight <David.Laight@ACULAB.COM> Signed-off-by: Taeung Song <treeze.taeung@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-24samples/bpf: add missing <linux/if_vlan.h>Taeung Song
[ Upstream commit 4d5d33a085335ef469c9a87792bcaaaa8e64d8c4 ] This fixes build error regarding redefinition: CLANG-bpf samples/bpf/parse_varlen.o samples/bpf/parse_varlen.c:111:8: error: redefinition of 'vlan_hdr' struct vlan_hdr { ^ ./include/linux/if_vlan.h:38:8: note: previous definition is here So remove duplicate 'struct vlan_hdr' in sample code and include if_vlan.h Signed-off-by: Taeung Song <treeze.taeung@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-08Fix tracing sample code warning.Linus Torvalds
commit a0cb2b5c390151837b08e5f7bca4a6ecddbcd39c upstream. Commit 6575257c60e1 ("tracing/samples: Fix creation and deletion of simple_thread_fn creation") introduced a new warning due to using a boolean as a counter. Just make it "int". Fixes: 6575257c60e1 ("tracing/samples: Fix creation and deletion of simple_thread_fn creation") Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-08tracing/samples: Fix creation and deletion of simple_thread_fn creationSteven Rostedt (VMware)
commit 6575257c60e1a26a5319ccf2b5ce5b6449001017 upstream. Commit 7496946a8 ("tracing: Add samples of DECLARE_EVENT_CLASS() and DEFINE_EVENT()") added template examples for all the events. It created a DEFINE_EVENT_FN() example which reused the foo_bar_reg and foo_bar_unreg functions. Enabling both the TRACE_EVENT_FN() and DEFINE_EVENT_FN() example trace events caused the foo_bar_reg to be called twice, creating the test thread twice. The foo_bar_unreg would remove it only once, even if it was called multiple times, leaving a thread existing when the module is unloaded, causing an oops. Add a ref count and allow foo_bar_reg() and foo_bar_unreg() be called by multiple trace events. Fixes: 7496946a8 ("tracing: Add samples of DECLARE_EVENT_CLASS() and DEFINE_EVENT()") Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-14bpf: enhance verifier to understand stack pointer arithmeticYonghong Song
[ Upstream commit 332270fdc8b6fba07d059a9ad44df9e1a2ad4529 ] llvm 4.0 and above generates the code like below: .... 440: (b7) r1 = 15 441: (05) goto pc+73 515: (79) r6 = *(u64 *)(r10 -152) 516: (bf) r7 = r10 517: (07) r7 += -112 518: (bf) r2 = r7 519: (0f) r2 += r1 520: (71) r1 = *(u8 *)(r8 +0) 521: (73) *(u8 *)(r2 +45) = r1 .... and the verifier complains "R2 invalid mem access 'inv'" for insn #521. This is because verifier marks register r2 as unknown value after #519 where r2 is a stack pointer and r1 holds a constant value. Teach verifier to recognize "stack_ptr + imm" and "stack_ptr + reg with const val" as valid stack_ptr with new offset. Signed-off-by: Yonghong Song <yhs@fb.com> Acked-by: Martin KaFai Lau <kafai@fb.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-12samples/seccomp: fix 64-bit comparison macrosMathias Svensson
commit 916cafdc95843fb9af5fd5f83ca499d75473d107 upstream. There were some bugs in the JNE64 and JLT64 comparision macros. This fixes them, improves comments, and cleans up the file while we are at it. Reported-by: Stephen Röttger <sroettger@google.com> Signed-off-by: Mathias Svensson <idolf@google.com> Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-28bpf/samples: Fix PT_REGS_IP on s390x and use itMichael Holzheu
The files "sampleip_kern.c" and "trace_event_kern.c" directly access "ctx->regs.ip" which is not available on s390x. Fix this and use the PT_REGS_IP() macro instead. Also fix the macro for s390x and use "psw.addr" from "pt_regs". Reported-by: Zvonko Kosic <zvonko.kosic@de.ibm.com> Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-11-12bpf: Add test for bpf_redirect to ipip/ip6tnlMartin KaFai Lau
The test creates two netns, ns1 and ns2. The host (the default netns) has an ipip or ip6tnl dev configured for tunneling traffic to the ns2. ping VIPS from ns1 <----> host <--tunnel--> ns2 (VIPs at loopback) The test is to have ns1 pinging VIPs configured at the loopback interface in ns2. The VIPs are 10.10.1.102 and 2401:face::66 (which are configured at lo@ns2). [Note: 0x66 => 102]. At ns1, the VIPs are routed _via_ the host. At the host, bpf programs are installed at the veth to redirect packets from a veth to the ipip/ip6tnl. The test is configured in a way so that both ingress and egress can be tested. At ns2, the ipip/ip6tnl dev is configured with the local and remote address specified. The return path is routed to the dev ipip/ip6tnl. During egress test, the host also locally tests pinging the VIPs to ensure that bpf_redirect at egress also works for the direct egress (i.e. not forwarding from dev ve1 to ve2). Acked-by: Alexei Starovoitov <ast@fb.com> Signed-off-by: Martin KaFai Lau <kafai@fb.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-10-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "Lots of fixes, mostly drivers as is usually the case. 1) Don't treat zero DMA address as invalid in vmxnet3, from Alexey Khoroshilov. 2) Fix element timeouts in netfilter's nft_dynset, from Anders K. Pedersen. 3) Don't put aead_req crypto struct on the stack in mac80211, from Ard Biesheuvel. 4) Several uninitialized variable warning fixes from Arnd Bergmann. 5) Fix memory leak in cxgb4, from Colin Ian King. 6) Fix bpf handling of VLAN header push/pop, from Daniel Borkmann. 7) Several VRF semantic fixes from David Ahern. 8) Set skb->protocol properly in ip6_tnl_xmit(), from Eli Cooper. 9) Socket needs to be locked in udp_disconnect(), from Eric Dumazet. 10) Div-by-zero on 32-bit fix in mlx4 driver, from Eugenia Emantayev. 11) Fix stale link state during failover in NCSCI driver, from Gavin Shan. 12) Fix netdev lower adjacency list traversal, from Ido Schimmel. 13) Propvide proper handle when emitting notifications of filter deletes, from Jamal Hadi Salim. 14) Memory leaks and big-endian issues in rtl8xxxu, from Jes Sorensen. 15) Fix DESYNC_FACTOR handling in ipv6, from Jiri Bohac. 16) Several routing offload fixes in mlxsw driver, from Jiri Pirko. 17) Fix broadcast sync problem in TIPC, from Jon Paul Maloy. 18) Validate chunk len before using it in SCTP, from Marcelo Ricardo Leitner. 19) Revert a netns locking change that causes regressions, from Paul Moore. 20) Add recursion limit to GRO handling, from Sabrina Dubroca. 21) GFP_KERNEL in irq context fix in ibmvnic, from Thomas Falcon. 22) Avoid accessing stale vxlan/geneve socket in data path, from Pravin Shelar" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (189 commits) geneve: avoid using stale geneve socket. vxlan: avoid using stale vxlan socket. qede: Fix out-of-bound fastpath memory access net: phy: dp83848: add dp83822 PHY support enic: fix rq disable tipc: fix broadcast link synchronization problem ibmvnic: Fix missing brackets in init_sub_crq_irqs ibmvnic: Fix releasing of sub-CRQ IRQs in interrupt context Revert "ibmvnic: Fix releasing of sub-CRQ IRQs in interrupt context" arch/powerpc: Update parameters for csum_tcpudp_magic & csum_tcpudp_nofold net/mlx4_en: Save slave ethtool stats command net/mlx4_en: Fix potential deadlock in port statistics flow net/mlx4: Fix firmware command timeout during interrupt test net/mlx4_core: Do not access comm channel if it has not yet been initialized net/mlx4_en: Fix panic during reboot net/mlx4_en: Process all completions in RX rings after port goes up net/mlx4_en: Resolve dividing by zero in 32-bit system net/mlx4_core: Change the default value of enable_qos net/mlx4_core: Avoid setting ports to auto when only one port type is supported net/mlx4_core: Fix the resource-type enum in res tracker to conform to FW spec ...
2016-10-29bpf: fix samples to add fake KBUILD_MODNAMEDaniel Borkmann
Some of the sample files are causing issues when they are loaded with tc and cls_bpf, meaning tc bails out while trying to parse the resulting ELF file as program/map/etc sections are not present, which can be easily spotted with readelf(1). Currently, BPF samples are including some of the kernel headers and mid term we should change them to refrain from this, really. When dynamic debugging is enabled, we bail out due to undeclared KBUILD_MODNAME, which is easily overlooked in the build as clang spills this along with other noisy warnings from various header includes, and llc still generates an ELF file with mentioned characteristics. For just playing around with BPF examples, this can be a bit of a hurdle to take. Just add a fake KBUILD_MODNAME as a band-aid to fix the issue, same is done in xdp*_kern samples already. Fixes: 65d472fb007d ("samples/bpf: add 'pointer to packet' tests") Fixes: 6afb1e28b859 ("samples/bpf: Add tunnel set/get tests.") Fixes: a3f74617340b ("cgroup: bpf: Add an example to do cgroup checking in BPF") Reported-by: Chandrasekar Kannan <ckannan@console.to> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-10-14Merge tag 'linux-kselftest-4.9-rc1-update' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest Pull kselftest updates from Shuah Khan: "This update consists of: - Fixes and improvements to existing tests - Moving code from Documentation to selftests, samples, and tools: * Moves dnotify_test, prctl, ptp, vDSO, ia64, watchdog, and networking tests from Documentation to selftests. * Moves mic/mpssd, misc-devices/mei, timers, watchdog, auxdisplay, and blackfin examples from Documentation to samples. * Moves accounting, laptops/dslm, and pcmcia/crc32hash tools from Documentation to tools. * Deletes BUILD_DOCSRC and its dependencies" * tag 'linux-kselftest-4.9-rc1-update' of git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest: (21 commits) selftests/futex: Check ANSI terminal color support Doc: update 00-INDEX files to reflect the runnable code move samples: move blackfin gptimers-example from Documentation tools: move pcmcia crc32hash tool from Documentation tools: move laptops dslm tool from Documentation tools: move accounting tool from Documentation samples: move auxdisplay example code from Documentation samples: move watchdog example code from Documentation samples: move timers example code from Documentation samples: move misc-devices/mei example code from Documentation samples: move mic/mpssd example code from Documentation selftests: Move networking/timestamping from Documentation selftests: move watchdog tests from Documentation/watchdog selftests: move ia64 tests from Documentation/ia64 selftests: move vDSO tests from Documentation/vDSO selftests: move ptp tests from Documentation/ptp selftests: move prctl tests from Documentation/prctl selftests: move dnotify_test from Documentation/filesystems selftests/timers: Add missing error code assignment before test selftests/zram: replace ZRAM_LZ4_COMPRESS ...
2016-10-10samples: move blackfin gptimers-example from DocumentationShuah Khan
Move blackfin gptimers-example to samples and remove it from Documentation Makefile. Update samples Kconfig and Makefile to build gptimers-example. blackfin is the last CONFIG_BUILD_DOCSRC target in Documentation/Makefile. Hence this patch also includes changes to remove CONFIG_BUILD_DOCSRC from Makefile and lib/Kconfig.debug and updates VIDEO_PCI_SKELETON dependency on BUILD_DOCSRC. Documentation/Makefile is not deleted to avoid braking make htmldocs and make distclean. Acked-by: Michal Marek <mmarek@suse.com> Acked-by: Jonathan Corbet <corbet@lwn.net> Reviewed-by: Kees Cook <keescook@chromium.org> Reported-by: Valentin Rothberg <valentinrothberg@gmail.com> Reported-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
2016-10-06Merge tag 'rpmsg-v4.9' of git://github.com/andersson/remoteprocLinus Torvalds
Pull rpmsg updates from Bjorn Andersson: "The bulk of these patches involve splitting the rpmsg implementation into a framework/API part and a virtio specific backend part. It then adds the Qualcomm Shared Memory Device (SMD) as an additional supported wire format. Also included is a set of code style cleanups that have been lingering for a while" * tag 'rpmsg-v4.9' of git://github.com/andersson/remoteproc: (26 commits) rpmsg: smd: fix dependency on QCOM_SMD=n rpmsg: Introduce Qualcomm SMD backend rpmsg: Allow callback to return errors rpmsg: Move virtio specifics from public header rpmsg: virtio: Hide vrp pointer from the public API rpmsg: Hide rpmsg indirection tables rpmsg: Split rpmsg core and virtio backend rpmsg: Split off generic tail of create_channel() rpmsg: Move helper for finding rpmsg devices to core rpmsg: Move endpoint related interface to rpmsg core rpmsg: Indirection table for rpmsg_endpoint operations rpmsg: Move rpmsg_device API to new file rpmsg: Introduce indirection table for rpmsg_device operations rpmsg: Clean up rpmsg device vs channel naming rpmsg: Make rpmsg_create_ept() take channel_info struct rpmsg: rpmsg_send() operations takes rpmsg_endpoint rpmsg: Name rpmsg devices based on channel id rpmsg: Enable matching devices with drivers based on DT rpmsg: Drop prototypes for non-existing functions samples/rpmsg: add support for multiple instances ...
2016-09-29bpf: allow access into map value arraysJosef Bacik
Suppose you have a map array value that is something like this struct foo { unsigned iter; int array[SOME_CONSTANT]; }; You can easily insert this into an array, but you cannot modify the contents of foo->array[] after the fact. This is because we have no way to verify we won't go off the end of the array at verification time. This patch provides a start for this work. We accomplish this by keeping track of a minimum and maximum value a register could be while we're checking the code. Then at the time we try to do an access into a MAP_VALUE we verify that the maximum offset into that region is a valid access into that memory region. So in practice, code such as this unsigned index = 0; if (foo->iter >= SOME_CONSTANT) foo->iter = index; else index = foo->iter++; foo->array[index] = bar; would be allowed, as we can verify that index will always be between 0 and SOME_CONSTANT-1. If you wish to use signed values you'll have to have an extra check to make sure the index isn't less than 0, or do something like index %= SOME_CONSTANT. Signed-off-by: Josef Bacik <jbacik@fb.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-27bpf samples: update tracex5 sample to use __seccomp_filterNaveen N. Rao
seccomp_phase1() does not exist anymore. Instead, update sample to use __seccomp_filter(). While at it, set max locked memory to unlimited. Signed-off-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-27bpf samples: fix compiler errors with sockex2 and sockex3Naveen N. Rao
These samples fail to compile as 'struct flow_keys' conflicts with definition in net/flow_dissector.h. Fix the same by renaming the structure used in the sample. Signed-off-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-23samples: move auxdisplay example code from DocumentationShuah Khan
Move auxdisplay examples to samples and remove it from Documentation Makefile. Create a new Makefile to build auxdisplay. It can be built from top level directory or from auxdisplay directory: Run make -C samples/auxdisplay or cd samples/auxdisplay; make Acked-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
2016-09-23samples: move watchdog example code from DocumentationShuah Khan
Move watchdog examples to samples and remove it from Documentation Makefile. Create a new Makefile to build watchdog. It can be built from top level directory or from watchdog directory: Run make -C samples/watchdog or cd samples/watchdog; make Acked-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
2016-09-23samples: move timers example code from DocumentationShuah Khan
Move timers examples to samples and remove it from Documentation Makefile. Create a new Makefile to build timers. It can be built from top level directory or from timers directory: Run make -C samples/timers or cd samples/timers; make Acked-by: Jonathan Corbet <corbet@lwn.net> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
2016-09-23samples: move misc-devices/mei example code from DocumentationShuah Khan
Move misc-devices/mei examples to samples/mei and remove it from Documentation Makefile. Delete misc-devices/Makefile. Create a new Makefile to build samples/mei. It can be built from top level directory or from mei directory: Run make -C samples/mei or cd samples/mei; make Acked-by: Jonathan Corbet <corbet@lwn.net> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
2016-09-20bpf: add test cases for direct packet accessDaniel Borkmann
Add couple of test cases for direct write and the negative size issue, and also adjust the direct packet access test4 since it asserts that writes are not possible, but since we've just added support for writes, we need to invert the verdict to ACCEPT, of course. Summary: 133 PASSED, 0 FAILED. Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-20samples: move mic/mpssd example code from DocumentationShuah Khan
Move mic/mpssd examples to samples and remove it from Documentation Makefile. Create a new Makefile to build mic/mpssd. It can be built from top level directory or from mic/mpssd directory: Run make -C samples/mic/mpssd or cd samples/mic/mpssd; make Acked-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
2016-09-17samples/bpf: add comprehensive ipip, ipip6, ip6ip6 testAlexei Starovoitov
the test creates 3 namespaces with veth connected via bridge. First two namespaces simulate two different hosts with the same IPv4 and IPv6 addresses configured on the tunnel interface and they communicate with outside world via standard tunnels. Third namespace creates collect_md tunnel that is driven by BPF program which selects different remote host (either first or second namespace) based on tcp dest port number while tcp dst ip is the same. This scenario is rough approximation of load balancer use case. The tests check both traditional tunnel configuration and collect_md mode. Signed-off-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-17samples/bpf: extend test_tunnel_bpf.sh with IPIP testAlexei Starovoitov
extend existing tests for vxlan, geneve, gre to include IPIP tunnel. It tests both traditional tunnel configuration and dynamic via bpf helpers. Signed-off-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-08rpmsg: Allow callback to return errorsBjorn Andersson
Some rpmsg backends support holding on to and redelivering messages upon failed handling of them, so provide a way for the callback to report and error and allow the backends to handle this. Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2016-09-08rpmsg: Clean up rpmsg device vs channel namingBjorn Andersson
The rpmsg device representing struct is called rpmsg_channel and the variable name used throughout is rpdev, with the communication happening on endpoints it's clearer to just call this a "device" in a public API. Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2016-09-08rpmsg: rpmsg_send() operations takes rpmsg_endpointBjorn Andersson
The rpmsg_send() operations has been taking a rpmsg_device, but this forces users of secondary rpmsg_endpoints to use the rpmsg_sendto() interface - by extracting source and destination from the given data structures. If we instead pass the rpmsg_endpoint to these functions a service can use rpmsg_sendto() to respond to messages, even on secondary endpoints. In addition this would allow us to support operations on multiple channels in future backends that does not support off-channel operations. Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2016-09-08bpf: fix range propagation on direct packet accessDaniel Borkmann
LLVM can generate code that tests for direct packet access via skb->data/data_end in a way that currently gets rejected by the verifier, example: [...] 7: (61) r3 = *(u32 *)(r6 +80) 8: (61) r9 = *(u32 *)(r6 +76) 9: (bf) r2 = r9 10: (07) r2 += 54 11: (3d) if r3 >= r2 goto pc+12 R1=inv R2=pkt(id=0,off=54,r=0) R3=pkt_end R4=inv R6=ctx R9=pkt(id=0,off=0,r=0) R10=fp 12: (18) r4 = 0xffffff7a 14: (05) goto pc+430 [...] from 11 to 24: R1=inv R2=pkt(id=0,off=54,r=0) R3=pkt_end R4=inv R6=ctx R9=pkt(id=0,off=0,r=0) R10=fp 24: (7b) *(u64 *)(r10 -40) = r1 25: (b7) r1 = 0 26: (63) *(u32 *)(r6 +56) = r1 27: (b7) r2 = 40 28: (71) r8 = *(u8 *)(r9 +20) invalid access to packet, off=20 size=1, R9(id=0,off=0,r=0) The reason why this gets rejected despite a proper test is that we currently call find_good_pkt_pointers() only in case where we detect tests like rX > pkt_end, where rX is of type pkt(id=Y,off=Z,r=0) and derived, for example, from a register of type pkt(id=Y,off=0,r=0) pointing to skb->data. find_good_pkt_pointers() then fills the range in the current branch to pkt(id=Y,off=0,r=Z) on success. For above case, we need to extend that to recognize pkt_end >= rX pattern and mark the other branch that is taken on success with the appropriate pkt(id=Y,off=0,r=Z) type via find_good_pkt_pointers(). Since eBPF operates on BPF_JGT (>) and BPF_JGE (>=), these are the only two practical options to test for from what LLVM could have generated, since there's no such thing as BPF_JLT (<) or BPF_JLE (<=) that we would need to take into account as well. After the fix: [...] 7: (61) r3 = *(u32 *)(r6 +80) 8: (61) r9 = *(u32 *)(r6 +76) 9: (bf) r2 = r9 10: (07) r2 += 54 11: (3d) if r3 >= r2 goto pc+12 R1=inv R2=pkt(id=0,off=54,r=0) R3=pkt_end R4=inv R6=ctx R9=pkt(id=0,off=0,r=0) R10=fp 12: (18) r4 = 0xffffff7a 14: (05) goto pc+430 [...] from 11 to 24: R1=inv R2=pkt(id=0,off=54,r=54) R3=pkt_end R4=inv R6=ctx R9=pkt(id=0,off=0,r=54) R10=fp 24: (7b) *(u64 *)(r10 -40) = r1 25: (b7) r1 = 0 26: (63) *(u32 *)(r6 +56) = r1 27: (b7) r2 = 40 28: (71) r8 = *(u8 *)(r9 +20) 29: (bf) r1 = r8 30: (25) if r8 > 0x3c goto pc+47 R1=inv56 R2=imm40 R3=pkt_end R4=inv R6=ctx R8=inv56 R9=pkt(id=0,off=0,r=54) R10=fp 31: (b7) r1 = 1 [...] Verifier test cases are also added in this work, one that demonstrates the mentioned example here and one that tries a bad packet access for the current/fall-through branch (the one with types pkt(id=X,off=Y,r=0), pkt(id=X,off=0,r=0)), then a case with good and bad accesses, and two with both test variants (>, >=). Fixes: 969bf05eb3ce ("bpf: direct packet access") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-02samples/bpf: add sampleip exampleBrendan Gregg
sample instruction pointer and frequency count in a BPF map Signed-off-by: Brendan Gregg <bgregg@netflix.com> Signed-off-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-02samples/bpf: add perf_event+bpf exampleAlexei Starovoitov
The bpf program is called 50 times a second and does hashmap[kern&user_stackid]++ It's primary purpose to check that key bpf helpers like map lookup, update, get_stackid, trace_printk and ctx access are all working. It checks: - PERF_COUNT_HW_CPU_CYCLES on all cpus - PERF_COUNT_HW_CPU_CYCLES for current process and inherited perf_events to children - PERF_COUNT_SW_CPU_CLOCK on all cpus - PERF_COUNT_SW_CPU_CLOCK for current process Signed-off-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-08-19samples/bpf: Add tunnel set/get tests.William Tu
The patch creates sample code exercising bpf_skb_{set,get}_tunnel_key, and bpf_skb_{set,get}_tunnel_opt for GRE, VXLAN, and GENEVE. A native tunnel device is created in a namespace to interact with a lwtunnel device out of the namespace, with metadata enabled. The bpf_skb_set_* program is attached to tc egress and bpf_skb_get_* is attached to egress qdisc. A ping between two tunnels is used to verify correctness and the result of bpf_skb_get_* printed by bpf_trace_printk. Signed-off-by: William Tu <u9012063@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-08-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Minor overlapping changes for both merge conflicts. Resolution work done by Stephen Rothwell was used as a reference. Signed-off-by: David S. Miller <davem@davemloft.net>
2016-08-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Buffers powersave frame test is reversed in cfg80211, fix from Felix Fietkau. 2) Remove bogus WARN_ON in openvswitch, from Jarno Rajahalme. 3) Fix some tg3 ethtool logic bugs, and one that would cause no interrupts to be generated when rx-coalescing is set to 0. From Satish Baddipadige and Siva Reddy Kallam. 4) QLCNIC mailbox corruption and napi budget handling fix from Manish Chopra. 5) Fix fib_trie logic when walking the trie during /proc/net/route output than can access a stale node pointer. From David Forster. 6) Several sctp_diag fixes from Phil Sutter. 7) PAUSE frame handling fixes in mlxsw driver from Ido Schimmel. 8) Checksum fixup fixes in bpf from Daniel Borkmann. 9) Memork leaks in nfnetlink, from Liping Zhang. 10) Use after free in rxrpc, from David Howells. 11) Use after free in new skb_array code of macvtap driver, from Jason Wang. 12) Calipso resource leak, from Colin Ian King. 13) mediatek bug fixes (missing stats sync init, etc.) from Sean Wang. 14) Fix bpf non-linear packet write helpers, from Daniel Borkmann. 15) Fix lockdep splats in macsec, from Sabrina Dubroca. 16) hv_netvsc bug fixes from Vitaly Kuznetsov, mostly to do with VF handling. 17) Various tc-action bug fixes, from CONG Wang. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (116 commits) net_sched: allow flushing tc police actions net_sched: unify the init logic for act_police net_sched: convert tcf_exts from list to pointer array net_sched: move tc offload macros to pkt_cls.h net_sched: fix a typo in tc_for_each_action() net_sched: remove an unnecessary list_del() net_sched: remove the leftover cleanup_a() mlxsw: spectrum: Allow packets to be trapped from any PG mlxsw: spectrum: Unmap 802.1Q FID before destroying it mlxsw: spectrum: Add missing rollbacks in error path mlxsw: reg: Fix missing op field fill-up mlxsw: spectrum: Trap loop-backed packets mlxsw: spectrum: Add missing packet traps mlxsw: spectrum: Mark port as active before registering it mlxsw: spectrum: Create PVID vPort before registering netdevice mlxsw: spectrum: Remove redundant errors from the code mlxsw: spectrum: Don't return upon error in removal path i40e: check for and deal with non-contiguous TCs ixgbe: Re-enable ability to toggle VLAN filtering ixgbe: Force VLNCTRL.VFE to be set in all VMDq paths ...
2016-08-12samples/bpf: add verifier tests for the helper access to the packetAaron Yue
test various corner cases of the helper function access to the packet via crafted XDP programs. Signed-off-by: Aaron Yue <haoxuany@fb.com> Signed-off-by: Alexei Starovoitov <ast@kernel.org> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-08-12bpf: fix bpf_skb_in_cgroup helper namingDaniel Borkmann
While hashing out BPF's current_task_under_cgroup helper bits, it came to discussion that the skb_in_cgroup helper name was suboptimally chosen. Tejun says: So, I think in_cgroup should mean that the object is in that particular cgroup while under_cgroup in the subhierarchy of that cgroup. Let's rename the other subhierarchy test to under too. I think that'd be a lot less confusing going forward. [...] It's more intuitive and gives us the room to implement the real "in" test if ever necessary in the future. Since this touches uapi bits, we need to change this as long as v4.8 is not yet officially released. Thus, change the helper enum and rename related bits. Fixes: 4a482f34afcc ("cgroup: bpf: Add bpf_skb_in_cgroup_proto") Reference: http://patchwork.ozlabs.org/patch/658500/ Suggested-by: Sargun Dhillon <sargun@sargun.me> Suggested-by: Tejun Heo <tj@kernel.org> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@kernel.org>
2016-08-12samples/bpf: Add test_current_task_under_cgroup testSargun Dhillon
This test has a BPF program which writes the last known pid to call the sync syscall within a given cgroup to a map. The user mode program creates its own mount namespace, and mounts the cgroupsv2 hierarchy in there, as on all current test systems (Ubuntu 16.04, Debian), the cgroupsv2 vfs is unmounted by default. Once it does this, it proceeds to test. The test checks for positive and negative condition. It ensures that when it's part of a given cgroup, its pid is captured in the map, and that when it leaves the cgroup, this doesn't happen. It populate a cgroups arraymap prior to execution in userspace. This means that the program must be run in the same cgroups namespace as the programs that are being traced. Signed-off-by: Sargun Dhillon <sargun@sargun.me> Cc: Alexei Starovoitov <ast@kernel.org> Cc: Daniel Borkmann <daniel@iogearbox.net> Cc: Tejun Heo <tj@kernel.org> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-08-12samples/rpmsg: add support for multiple instancesAnna, Suman
The current rpmsg_client_sample is a very simple example and is not designed to handle multiple instances. Add support for multiple instances, so that the same number of pings are sent to each instance. The instances can be on one or multiple remote processors. Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2016-08-10samples/bpf: fix bpf_perf_event_output prototypeAdam Barth
The commit 555c8a8623a3 ("bpf: avoid stack copy and use skb ctx for event output") started using 20 of initially reserved upper 32-bits of 'flags' argument in bpf_perf_event_output(). Adjust corresponding prototype in samples/bpf/bpf_helpers.h Signed-off-by: Adam Barth <arb@fb.com> Signed-off-by: Alexei Starovoitov <ast@kernel.org> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-08-06samples/bpf: add bpf_map_update_elem() testsAlexei Starovoitov
increase test coverage to check previously missing 'update when full' Signed-off-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-08-04samples/kretprobe: fix the wrong typeHuang Shijie
The regs_return_value() returns "unsigned long" or "long" value. But the retval is int type now, it may cause overflow, the log may becomes: [ 2911.078869] do_brk returned -2003877888 and took 4620 ns to execute This patch converts the retval to "unsigned long" type, and fixes the overflow issue. Link: http://lkml.kernel.org/r/1464143083-3877-4-git-send-email-shijie.huang@arm.com Signed-off-by: Huang Shijie <shijie.huang@arm.com> Cc: Petr Mladek <pmladek@suse.com> Cc: Steve Capper <steve.capper@arm.com> Cc: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: Masami Hiramatsu <mhiramat@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-04samples/kretprobe: convert the printk to pr_info/pr_errHuang Shijie
We prefer to use the pr_* to print out the log now, this patch converts the printk to pr_info. In the error path, use the pr_err to replace the printk. Link: http://lkml.kernel.org/r/1464143083-3877-3-git-send-email-shijie.huang@arm.com Signed-off-by: Huang Shijie <shijie.huang@arm.com> Cc: Petr Mladek <pmladek@suse.com> Cc: Steve Capper <steve.capper@arm.com> Cc: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: Masami Hiramatsu <mhiramat@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-04samples/jprobe: convert the printk to pr_info/pr_errHuang Shijie
We prefer to use the pr_* to print out the log now, this patch converts the printk to pr_info. In the error path, use the pr_err to replace the printk. Link: http://lkml.kernel.org/r/1464143083-3877-2-git-send-email-shijie.huang@arm.com Signed-off-by: Huang Shijie <shijie.huang@arm.com> Cc: Petr Mladek <pmladek@suse.com> Cc: Steve Capper <steve.capper@arm.com> Cc: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: Masami Hiramatsu <mhiramat@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-04samples/kprobe: convert the printk to pr_info/pr_errHuang Shijie
We prefer to use the pr_* to print out the log now, this patch converts the printk to pr_info. In the error path, use the pr_err to replace the printk. Link: http://lkml.kernel.org/r/1464143083-3877-1-git-send-email-shijie.huang@arm.com Signed-off-by: Huang Shijie <shijie.huang@arm.com> Cc: Petr Mladek <pmladek@suse.com> Cc: Steve Capper <steve.capper@arm.com> Cc: Ananth N Mavinakayanahalli <ananth@linux.vnet.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: Masami Hiramatsu <mhiramat@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-29Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "Highlights: - TPM core and driver updates/fixes - IPv6 security labeling (CALIPSO) - Lots of Apparmor fixes - Seccomp: remove 2-phase API, close hole where ptrace can change syscall #" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (156 commits) apparmor: fix SECURITY_APPARMOR_HASH_DEFAULT parameter handling tpm: Add TPM 2.0 support to the Nuvoton i2c driver (NPCT6xx family) tpm: Factor out common startup code tpm: use devm_add_action_or_reset tpm2_i2c_nuvoton: add irq validity check tpm: read burstcount from TPM_STS in one 32-bit transaction tpm: fix byte-order for the value read by tpm2_get_tpm_pt tpm_tis_core: convert max timeouts from msec to jiffies apparmor: fix arg_size computation for when setprocattr is null terminated apparmor: fix oops, validate buffer size in apparmor_setprocattr() apparmor: do not expose kernel stack apparmor: fix module parameters can be changed after policy is locked apparmor: fix oops in profile_unpack() when policy_db is not present apparmor: don't check for vmalloc_addr if kvzalloc() failed apparmor: add missing id bounds check on dfa verification apparmor: allow SYS_CAP_RESOURCE to be sufficient to prlimit another task apparmor: use list_next_entry instead of list_entry_next apparmor: fix refcount race when finding a child profile apparmor: fix ref count leak when profile sha1 hash is read apparmor: check that xindex is in trans_table bounds ...
2016-07-28Merge tag 'trace-v4.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing updates from Steven Rostedt: "This is mostly clean ups and small fixes. Some of the more visible changes are: - The function pid code uses the event pid filtering logic - [ku]probe events have access to current->comm - trace_printk now has sample code - PCI devices now trace physical addresses - stack tracing has less unnessary functions traced" * tag 'trace-v4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: printk, tracing: Avoiding unneeded blank lines tracing: Use __get_str() when manipulating strings tracing, RAS: Cleanup on __get_str() usage tracing: Use outer () on __get_str() definition ftrace: Reduce size of function graph entries tracing: Have HIST_TRIGGERS select TRACING tracing: Using for_each_set_bit() to simplify trace_pid_write() ftrace: Move toplevel init out of ftrace_init_tracefs() tracing/function_graph: Fix filters for function_graph threshold tracing: Skip more functions when doing stack tracing of events tracing: Expose CPU physical addresses (resource values) for PCI devices tracing: Show the preempt count of when the event was called tracing: Add trace_printk sample code tracing: Choose static tp_printk buffer by explicit nesting count tracing: expose current->comm to [ku]probe events ftrace: Have set_ftrace_pid use the bitmap like events do tracing: Move pid_list write processing into its own function tracing: Move the pid_list seq_file functions to be global tracing: Move filtered_pid helper functions into trace.c tracing: Make the pid filtering helper functions global
2016-07-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) Unified UDP encapsulation offload methods for drivers, from Alexander Duyck. 2) Make DSA binding more sane, from Andrew Lunn. 3) Support QCA9888 chips in ath10k, from Anilkumar Kolli. 4) Several workqueue usage cleanups, from Bhaktipriya Shridhar. 5) Add XDP (eXpress Data Path), essentially running BPF programs on RX packets as soon as the device sees them, with the option to mirror the packet on TX via the same interface. From Brenden Blanco and others. 6) Allow qdisc/class stats dumps to run lockless, from Eric Dumazet. 7) Add VLAN support to b53 and bcm_sf2, from Florian Fainelli. 8) Simplify netlink conntrack entry layout, from Florian Westphal. 9) Add ipv4 forwarding support to mlxsw spectrum driver, from Ido Schimmel, Yotam Gigi, and Jiri Pirko. 10) Add SKB array infrastructure and convert tun and macvtap over to it. From Michael S Tsirkin and Jason Wang. 11) Support qdisc packet injection in pktgen, from John Fastabend. 12) Add neighbour monitoring framework to TIPC, from Jon Paul Maloy. 13) Add NV congestion control support to TCP, from Lawrence Brakmo. 14) Add GSO support to SCTP, from Marcelo Ricardo Leitner. 15) Allow GRO and RPS to function on macsec devices, from Paolo Abeni. 16) Support MPLS over IPV4, from Simon Horman. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1622 commits) xgene: Fix build warning with ACPI disabled. be2net: perform temperature query in adapter regardless of its interface state l2tp: Correctly return -EBADF from pppol2tp_getname. net/mlx5_core/health: Remove deprecated create_singlethread_workqueue net: ipmr/ip6mr: update lastuse on entry change macsec: ensure rx_sa is set when validation is disabled tipc: dump monitor attributes tipc: add a function to get the bearer name tipc: get monitor threshold for the cluster tipc: make cluster size threshold for monitoring configurable tipc: introduce constants for tipc address validation net: neigh: disallow transition to NUD_STALE if lladdr is unchanged in neigh_update() MAINTAINERS: xgene: Add driver and documentation path Documentation: dtb: xgene: Add MDIO node dtb: xgene: Add MDIO node drivers: net: xgene: ethtool: Use phy_ethtool_gset and sset drivers: net: xgene: Use exported functions drivers: net: xgene: Enable MDIO driver drivers: net: xgene: Add backward compatibility drivers: net: phy: xgene: Add MDIO driver ...
2016-07-27Merge tag 'arm64-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 updates from Catalin Marinas: - Kexec support for arm64 - Kprobes support - Expose MIDR_EL1 and REVIDR_EL1 CPU identification registers to sysfs - Trapping of user space cache maintenance operations and emulation in the kernel (CPU errata workaround) - Clean-up of the early page tables creation (kernel linear mapping, EFI run-time maps) to avoid splitting larger blocks (e.g. pmds) into smaller ones (e.g. ptes) - VDSO support for CLOCK_MONOTONIC_RAW in clock_gettime() - ARCH_HAS_KCOV enabled for arm64 - Optimise IP checksum helpers - SWIOTLB optimisation to only allocate/initialise the buffer if the available RAM is beyond the 32-bit mask - Properly handle the "nosmp" command line argument - Fix for the initialisation of the CPU debug state during early boot - vdso-offsets.h build dependency workaround - Build fix when RANDOMIZE_BASE is enabled with MODULES off * tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (64 commits) arm64: arm: Fix-up the removal of the arm64 regs_query_register_name() prototype arm64: Only select ARM64_MODULE_PLTS if MODULES=y arm64: mm: run pgtable_page_ctor() on non-swapper translation table pages arm64: mm: make create_mapping_late() non-allocating arm64: Honor nosmp kernel command line option arm64: Fix incorrect per-cpu usage for boot CPU arm64: kprobes: Add KASAN instrumentation around stack accesses arm64: kprobes: Cleanup jprobe_return arm64: kprobes: Fix overflow when saving stack arm64: kprobes: WARN if attempting to step with PSTATE.D=1 arm64: debug: remove unused local_dbg_{enable, disable} macros arm64: debug: remove redundant spsr manipulation arm64: debug: unmask PSTATE.D earlier arm64: localise Image objcopy flags arm64: ptrace: remove extra define for CPSR's E bit kprobes: Add arm64 case in kprobe example module arm64: Add kernel return probes support (kretprobes) arm64: Add trampoline code for kretprobes arm64: kprobes instruction simulation support arm64: Treat all entry code as non-kprobe-able ...
2016-07-25samples/bpf: Add test/example of using bpf_probe_write_user bpf helperSargun Dhillon
This example shows using a kprobe to act as a dnat mechanism to divert traffic for arbitrary endpoints. It rewrite the arguments to a syscall while they're still in userspace, and before the syscall has a chance to copy the argument into kernel space. Although this is an example, it also acts as a test because the mapped address is 255.255.255.255:555 -> real address, and that's not a legal address to connect to. If the helper is broken, the example will fail on the intermediate steps, as well as the final step to verify the rewrite of userspace memory succeeded. Signed-off-by: Sargun Dhillon <sargun@sargun.me> Cc: Alexei Starovoitov <ast@kernel.org> Cc: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-07-25bpf: Add bpf_probe_write_user BPF helper to be called in tracersSargun Dhillon
This allows user memory to be written to during the course of a kprobe. It shouldn't be used to implement any kind of security mechanism because of TOC-TOU attacks, but rather to debug, divert, and manipulate execution of semi-cooperative processes. Although it uses probe_kernel_write, we limit the address space the probe can write into by checking the space with access_ok. We do this as opposed to calling copy_to_user directly, in order to avoid sleeping. In addition we ensure the threads's current fs / segment is USER_DS and the thread isn't exiting nor a kernel thread. Given this feature is meant for experiments, and it has a risk of crashing the system, and running programs, we print a warning on when a proglet that attempts to use this helper is installed, along with the pid and process name. Signed-off-by: Sargun Dhillon <sargun@sargun.me> Cc: Alexei Starovoitov <ast@kernel.org> Cc: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-07-20samples: Add an IPv6 '-6' option to the pktgen scriptsMartin KaFai Lau
Add a '-6' option to the sample pktgen scripts for sending out IPv6 packets. [root@kerneldev010.prn1 ~/pktgen]# ./pktgen_sample03_burst_single_flow.sh -i eth0 -s 64 -d fe80::f652:14ff:fec2:a14c -m f4:52:14:c2:a1:4c -b 32 -6 [root@kerneldev011.prn1 ~]# tcpdump -i eth0 -nn -c3 port 9 tcpdump: WARNING: eth0: no IPv4 address assigned tcpdump: verbose output suppressed, use -v or -vv for full protocol decode listening on eth0, link-type EN10MB (Ethernet), capture size 65535 bytes 14:38:51.815297 IP6 fe80::f652:14ff:fec2:2ad2.9 > fe80::f652:14ff:fec2:a14c.9: UDP, length 16 14:38:51.815311 IP6 fe80::f652:14ff:fec2:2ad2.9 > fe80::f652:14ff:fec2:a14c.9: UDP, length 16 14:38:51.815313 IP6 fe80::f652:14ff:fec2:2ad2.9 > fe80::f652:14ff:fec2:a14c.9: UDP, length 16 Signed-off-by: Martin KaFai Lau <kafai@fb.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
