path: root/scripts/.gitignore
2009-10-07kconfig: simplification of scripts/extract-ikconfigDick Streefland
I've rewritten the extract-ikconfig script to extract the kernel configuration from a kernel compiled with CONFIG_IKCONFIG. The main motivation for the rewrite was to remove the dependency on the external C program binoffset.c, which is compiled on the initial run. The binoffset executable is invoked with a relative path, which means that the old script can only be run from the top of the kernel tree, and only when you have write permission in the scripts directory. The new script uses tr/grep/tail/zcat only, and can be invoked from anywhere. The binoffset.c program has been removed. This script requires GNU grep 2.5 (released 2002-03-13) or higher, because the -o option was introduced in that version. Signed-off-by: Dick Streefland <dick@streefland.net> LKML-Reference: <20091006203540.GA14634@streefland.net> Tested-by: Steven Rostedt <rostedt@goodmis.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-06-27gitignore: ignore scripts/ihex2fwJaswinder Singh Rajput
scripts/ihex2fw is a generated binary and should be ignored Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-04-06Revert "fix modules_install via NFS"David Woodhouse
This reverts commit 8b249b6856f16f09b0e5b79ce5f4d435e439b9d6. This 'fix' is not necessary; we just need to undo the damage caused accidentally by Igor/Mauro in 4b29631db33292d416dc395c56122ea865e7635c ("V4L/DVB (9533): cx88: Add support for TurboSight TBS8910 DVB-S PCI card") Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-01-07fix modules_install via NFSSam Ravnborg
Rafael reported: I get the following error from 'make modules_install' on my test boxes: HOSTCC firmware/ihex2fw /home/rafael/src/linux-2.6/firmware/ihex2fw.c:268: fatal error: opening dependency file firmware/.ihex2fw.d: Read-only file system compilation terminated. make[3]: *** [firmware/ihex2fw] Error 1 make[2]: *** [_modinst_post] Error 2 make[1]: *** [sub-make] Error 2 make: *** [all] Error 2 where the configuration is that the kernel is compiled on a build box with 'make O=<destdir> -j5' and then <destdir> is mounted over NFS read-only by each test box (full path to this directory is the same on the build box and on the test boxes). Then, I cd into <destdir>, run 'make modules_install' and get the error above. The issue turns out to be that we when we install firmware pick up the list of firmware blobs from firmware/Makefile. And this triggers the Makefile rules to update ihex2fw. There were two solutions for this issue: 1) Move the list of firmware blobs to a separate file 2) Avoid ihex2fw rebuild by moving it to scripts As I seriously beleive that the list of firmware blobs should be done in a fundamental different way solution 2) was selected. Reported-and-tested-by: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: David Woodhouse <dwmw2@infradead.org>
2008-02-09Add binoffset to gitignoreUwe Kleine-König
Signed-off-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-10-02[PATCH] Add unifdef to gitignorePaul Mundt
This seems to have been missed when unifdef went in via Sam's tree.. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03gitignore: ignore more generated files
2005-10-18Add some basic .gitignore filesLinus Torvalds
This still leaves driver and architecture-specific subdirectories alone, but gets rid of the bulk of the "generic" generated files that we should ignore. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
