commit 8417da6f2128008c431c7d130af6cd3d9079922e upstream.
Starting with 4.4, gcc will happily accept -Wno-<anything> in the
cc-option test and complain later when compiling a file that has some
other warning. This rather unexpected behavior is intentional as per
http://gcc.gnu.org/PR28322, so work around it by testing for support of
the opposite option (without the no-). Introduce a new Makefile function
cc-disable-warning that does this and update two uses of cc-option in
the toplevel Makefile.
Reported-and-tested-by: Stephen Rothwell <sfr@canb.auug.org.au>
To make it easier for module-init-tools and scripts like mkinitrd to
distinguish builtin and missing modules, install a modules.builtin file
listing all builtin modules. This is done by generating an additional
config file (tristate.conf) with tristate options set to uppercase 'Y'
or 'M'. If we source that config file, the builtin modules appear in
obj-Y.
Alek reported that on Ubuntu, where dash is used, 'echo -e'
can't work, so let's use non-builtin echo in this case.
Reported-by: Alek Du <alek.du@intel.com>
Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
The arch/*/boot/Makefile use cc-options to check for GCC command options
and cc-options use the hardened specs when checking for GCC command
options. When -fPIE is pass to cc1 it can't use -ffreestanding or
-fno-toplevel-reorder. Then it fail to build stuff with -ffreestanding
and -fno-toplevel-reorder.
Thanks to Fredric Johansson for finding the main problem behind a failed
build using a hardened toolchain.
Signed-off-by: Magnus Granberg <zorry@ume.nu>
Signed-off-by: Jory A. Pratt <anarchy@gentoo.org>
Cc: Fredric Johansson <johansson_fredric@hotmail.com>
Cc: <stable@kernel.org>
ld-option is used to check if $(LD) supports a specific option.
Based on patch from Andi Kleen.
First use is to check if option -X is supported (upcoming patch).
Theis is ne
ld-option is misnamed as it test options to gcc, not to ld.
Renamed it to reflect this.
Cc: Roland McGrath <roland@redhat.com>
Convert a few echos in the build system to new $(kecho) so we get correct
output according to build verbosity.
[sam: added kecho in a few more places for O=... builds]
There is a bunch of places in the build system where we do 'echo' to show
some nice status lines. This means we still get output when running in
silent mode. So declare a new KECHO variable that only does 'echo' when we
are in a suitable verbose build mode.
[sam: added Documentation]
When adding extra -I options with O=... we could
end up in a situation where there were no parameters to -I.
So we had a commandline that looked like this:
... -I -Wall ...
This had the undesired side effect that gcc assumed "-Wall"
was a path to look for include files so this options was
effectively ignored.
This happens only when we build the generated module.mod.c files
as part of the final modules builds and is as such harmless
with current kbuild.
This bug was exposed when we rearranged the options to gcc.
David Sanders wrote:
> I'm getting this error:
> as: unrecognized option `-mtune=generic32'
> I have binutils 2.17.
Use -c instead of -S in cc-option and cc-option-yn, so we can probe
options related to the assembler.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Cc: kbuild devel <kbuild-devel@lists.sourceforge.net>
When make -s support were added to filechk to
combination created with make V=1 were not
covered.
Fix it by explicitly cover this case too.
Cc: Mike Frysinger <vapier@gentoo.org>
cc-cross-prefix is useful for the architecture that like
to provide a default CROSS_COMPILE value,
but may have several to select between.
Sample usage:
ifneq ($(SUBARCH),$(ARCH))
ifeq ($(CROSS_COMPILE),)
CROSS_COMPILE := $(call cc-cross-prefix, m68k-linux-gnu- m68k-linux-)
endif
endif
Actual usage by the different archs will taken care of later.
The variable AFLAGS is a wellknown variable and the usage by
kbuild may result in unexpected behaviour.
On top of that several people over time has asked for a way to
pass in additional flags to gcc.
This patch replace use of AFLAGS with KBUILD_AFLAGS all over
the tree.
Patch was tested on following architectures:
alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k, s390
The variable CFLAGS is a wellknown variable and the usage by
This patch replace use of CFLAGS with KBUILD_CFLAGS all over the
tree and enabling one to use:
make CFLAGS=...
to specify additional gcc commandline options.
One usecase is when trying to find gcc bugs but other
use cases has been requested too.
Test was simple to do a defconfig build, apply the patch and check
that nothing got rebuild.
Prints a six-digit string including the GCC patchlevel. Also fix
the 'usage' comment for cc-version.
Signed-off-by: Segher Boessenkool <segher@kernel.crashing.org>
This adds the remaining changes which should have been part of the
review process.
- the define command is inappropriate (it's primarily for rule
definitions)
- execute commands in the current dir as all other commands
- .*.tmp (but not .*.null) files are also removed up by "make clean"
- printf has other side effects, just use "echo -e"
- proper quoting
- proper indentation
Signed-off-by: Roman Zippel <zippel@linux-m68k.org>
Michal Ostrowski points out what the real problem was: the spaces at the
start of the definition of the 'checker-shell' make function.
Cc: Michal Ostrowski <mostrows@watson.ibm.com>
Acked-by: David Miller <davem@davemloft.net>
Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Acked-by: Oleg Verych <olecom@flower.upol.cz>
It looks like GNU make version 3.80 (but apparently not 3.81) adds
leading whitespace to the result of the checker-shell execution. This
strips them off explicitly.
Also, don't bother symlinking the output file to /dev/null. It's likely
as expensive as just writing the temp-file, and we need to remove it
anyway afterwards.
Do not use whitespace in arguments of functions in makefiles, as they
propagate further without notice. Thus we get
+ echo ' y'
instead of
+ echo y
Fix misleading comments.
Signed-off-by: Oleg Verych <olecom@flower.upol.cz>
GNU binutils, root users, tmpfiles, external modules ro builds must
be fixed to do the right thing now.
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Horst Schirmeier <horst@schirmeier.com>
Cc: Jan Beulich <jbeulich@novell.com>
Cc: Daniel Drake <dsd@gentoo.org>
Cc: Andi Kleen <ak@suse.de>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
The as-instr/ld-option need to create temporary files, but create them in the
output directory, when compiling external modules. Reformat them a bit and
use $(CC) instead of $(AS) as the former is used by kbuild to assemble files.
Cc: <jpdenheijer@gmail.com>
Current gcc generates calls not jumps to noreturn functions. When that happens the
return address can point to the next function, which confuses the unwinder.
This patch works around it by marking asynchronous exception
frames in contrast normal call frames in the unwind information. Then teach
the unwinder to decode this.
For normal call frames the unwinder now subtracts one from the address which avoids
this problem. The standard libgcc unwinder uses the same trick.
It doesn't include adjustment of the printed address (i.e. for the original
example, it'd still be kernel_math_error+0 that gets displayed, but the
unwinder wouldn't get confused anymore.
This only works with binutils 2.6.17+ and some versions of H.J.Lu's 2.6.16
unfortunately because earlier binutils don't support .cfi_signal_frame
[AK: added automatic detection of the new binutils and wrote description]
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Signed-off-by: Andi Kleen <ak@suse.de>
... instead of using a CONFIG option. The config option still controls
if the resulting executable actually has unwind information.
This is useful to prevent compilation errors when users select
CONFIG_STACK_UNWIND on old binutils and also allows to use
CFI in the future for non kernel debugging applications.
Cc: jbeulich@novell.com
Cc: sam@ravnborg.org
tell why a a target got build
enabled by make V=2
Output (listed in the order they are checked):
(1) - due to target is PHONY
(2) - due to target missing
(3) - due to: file1.h file2.h
(4) - due to command line change
(5) - due to missing .cmd file
(6) - due to target not in $(targets)
(1) We always build PHONY targets
(2) No target, so we better build it
(3) Prerequisite is newer than target
(4) The command line stored in the file named dir/.target.cmd
differed from actual command line. This happens when compiler
options changes
(5) No dir/.target.cmd file (used to store command line)
(6) No dir/.target.cmd file and target not listed in $(targets)
This is a good hint that there is a bug in the kbuild file
This patch is inspired by a patch from: Milton Miller <miltonm@bga.com>
Cc: Milton Miller <miltonm@bga.com>
Consistently decide when to rebuild a target across all of
if_changed, if_changed_dep, if_changed_rule.
PHONY targets are now treated alike (ignored) for all targets
While add it make Kbuild.include almost readable by factoring out a few
bits to some common variables and reuse this in Makefile.build.
The possibility to specify an optional parameter did not work out as
expected and it was not used - so remove the possibility.
The latest toolchains can produce a new ELF section in DSOs and
dynamically-linked executables. The new section ".gnu.hash" replaces
".hash", and allows for more efficient runtime symbol lookups by the
dynamic linker. The new ld option --hash-style={sysv|gnu|both} controls
whether to produce the old ".hash", the new ".gnu.hash", or both. In some
new systems such as Fedora Core 6, gcc by default passes --hash-style=gnu
to the linker, so that a standard invocation of "gcc -shared" results in
producing a DSO with only ".gnu.hash". The new ".gnu.hash" sections need
to be dealt with the same way as ".hash" sections in all respects; only the
dynamic linker cares about their contents. To work with older dynamic
linkers (i.e. preexisting releases of glibc), a binary must have the old
".hash" section. The --hash-style=both option produces binaries that a new
dynamic linker can use more efficiently, but an old dynamic linker can
still handle.
The new section runs afoul of the custom linker scripts used to build vDSO
images for the kernel. On ia64, the failure mode for this is a boot-time
panic because the vDSO's PT_IA_64_UNWIND segment winds up ill-formed.
This patch addresses the problem in two ways.
First, it mentions ".gnu.hash" in all the linker scripts alongside ".hash".
This produces correct vDSO images with --hash-style=sysv (or old tools),
with --hash-style=gnu, or with --hash-style=both.
Second, it passes the --hash-style=sysv option when building the vDSO
images, so that ".gnu.hash" is not actually produced. This is the most
conservative choice for compatibility with any old userland. There is some
concern that some ancient glibc builds (though not any known old production
system) might choke on --hash-style=both binaries. The optimizations
provided by the new style of hash section do not really matter for a DSO
with a tiny number of symbols, as the vDSO has. If someone wants to use
=gnu or =both for their vDSO builds and worry less about that
compatibility, just change the option and the linker script changes will
make any choice work fine.
Signed-off-by: Roland McGrath <roland@redhat.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Andi Kleen <ak@muc.de>
kbuild used $ยค(*F to get filename of target without extension.
This was used in several places all over kbuild, but introducing
make -rR broke his for all cases where we specified full path to
target/prerequsite. It is assumed that make -rR disables old style
suffix-rules which is why is suddenly failed.
ia64 was impacted by this change because several div* routines in
arch/ia64/lib are build using explicit paths and then kbuild failed.
Thanks to David Mosberger-Tang <David.Mosberger@acm.org> for an explanation
what was the root-cause and for testing on ia64.
This patch also fixes two uses of $(*F) in arch/um
This reverts commit e5c44fd88c146755da6941d047de4d97651404a9.
Thanks to Daniel Ritz and Michal Piotrowski for noticing the problem.
Daniel says:
"[The] reason is a recent change that made modules always shows as
module.mod. it breaks modprobe and probably many scripts..besides
lsmod looking horrible
stuff like this in modprobe.conf:
install pcmcia_core /sbin/modprobe --ignore-install pcmcia_core; /sbin/modprobe pcmcia
makes modprobe fork/exec endlessly calling itself...until oom
interrupts it"
make failed to supply the filename when using make -rR and using $(*F)
to get target filename without extension.
This bug was not reproduceable in small scale but using:
$(basename $(notdir $@)) fixes it with same functionality.
This fix a longstanding bug where proper options was not
passed to hostcc in case of a make O=.. build.
This bug showed up in (not yet merged) klibc, and is not known
to have any counterpart in-kernel.
Fixed by moving the flags macro to Kbuild.include so it can be used
by both Makefile.lib and Makefile.host.
The kbuild system takes advantage of an incorrect behavior in GNU make.
Once this behavior is fixed, all files in the kernel rebuild every time,
even if nothing has changed. This patch ensures kbuild works with both
the incorrect and correct behaviors of GNU make.
For more details on the incorrect behavior, see:
http://lists.gnu.org/archive/html/bug-make/2006-03/msg00003.html
Changes in this patch:
- Keep all targets that are to be marked .PHONY in a variable, PHONY.
- Add .PHONY: $(PHONY) to mark them properly.
- Remove any $(PHONY) files from the $? list when determining whether
targets are up-to-date or not.
Signed-off-by: Paul Smith <psmith@gnu.org>
Noted by Olaf Hering <olh@suse.de>
While the recent change to also escape # symbols when storing C-file
compilation command lines was helpful, it should be in effect for all
command lines, as much as the dollar escaping should be in effect for
C-source compilation commands. Additionally, for better readability and
maintenance, consolidating all the escaping (single quotes, dollars,
and now sharps) was also desirable.
Signed-Off-By: Jan Beulich <jbeulich@novell.com>
Move $(CC) support functions to Kbuild.include so they are available
in the kbuild files.
In addition the following was done:
o as-option documented in Documentation/kbuild/makefiles.txt
o Moved documentation to new section to match
new scope of functions
o added cc-ifversion used to conditionally select a text string
dependent on actual $(CC) version
o documented cc-ifversion
o change so Kbuild.include is read before the kbuild file
This makes things a little bit more reader friendly and gvim is less
confused.
Use foo := $(call objectify, $(foo)) to prefix $(foo) with $(obj)/ unless
$(foo) is an absolute path.
For now no in-tree users - soon to come.
Kbuild.include is a placeholder for definitions originally present in
both the top-level Makefile and scripts/Makefile.build.
There were a slight difference in the filechk definition, so the most videly
used version was kept and usr/Makefile was adopted for this syntax.
