While the recent change to also escape # symbols when storing C-file
compilation command lines was helpful, it should be in effect for all
command lines, as much as the dollar escaping should be in effect for
C-source compilation commands. Additionally, for better readability and
maintenance, consolidating all the escaping (single quotes, dollars,
and now sharps) was also desirable.
Signed-Off-By: Jan Beulich <jbeulich@novell.com>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Move $(CC) support functions to Kbuild.include so they are available
in the kbuild files.
In addition the following was done:
o as-option documented in Documentation/kbuild/makefiles.txt
o Moved documentation to new section to match
new scope of functions
o added cc-ifversion used to conditionally select a text string
dependent on actual $(CC) version
o documented cc-ifversion
o change so Kbuild.include is read before the kbuild file
This makes things a little bit more reader friendly and gvim is less
confused.
kbuild failed to locate Makefile for external modules.
This brought to my attention how the variables for directories
have different values in different usage scenarios.
Different kbuild usage scenarios:
make - plain make in same directory where kernel source lives
make O= - kbuild is told to store output files in another directory
make M= - building an external module
make O= M= - building an external module with kernel output seperate from src
Value assigned to the different variables:
|$(src) |$(obj) |$(srctree) |$(objtree)
make |reldir to k src |as src |abs path to k src |abs path to k src
make O= |reldir to k src |as src |abs path to k src |abs path to output dir
make M= |abs path to src |as src |abs path to k src |abs path to k src
make O= M= |abs path to src |as src |abs path to k src |abs path to k output
path to kbuild file:
make | $(srctree)/$(src), $(src)
make O= | $(srctree)/$(src)
make M= | $(src)
make O= M= | $(src)
From the table above it can be seen that the only good way to find the
home directory of the kbuild file is to locate the one of the two variants
that is an absolute path. If $(src) is an absolute path (starts with /)
then use it, otherwise prefix $(src) with $(srctree).
kbuild failed to locate Kbuild.include.
Teach kbuild how to find Kbuild files when using make O=...
Kbuild.include is a placeholder for definitions originally present in
both the top-level Makefile and scripts/Makefile.build.
There were a slight difference in the filechk definition, so the most videly
used version was kept and usr/Makefile was adopted for this syntax.
I inadvertently built a tree as root and then rebuilt it as a user. I
got a lot of prompts ...
mv: overwrite `drivers/char/drm/drm_auth.o', overriding mode 0644?
Using mv -f fixes that.
Signed-off-by: Matthew Wilcox <matthew@wil.cx>
Adding quotation handling to rule_cc_o_c in scripts/Makefile.build as used
elsewhere.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
infrastructure for it.
Let it rip!
