path: root/scripts/Makefile.build
2008-04-25kbuild: fix some minor typoesRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: introduce new option to enhance section mismatch analysisSam Ravnborg
Setting the option DEBUG_SECTION_MISMATCH will report additional section mismatch'es but this should in the end makes it possible to get rid of all of them. See help text in lib/Kconfig.debug for details. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: implement modules.orderTejun Heo
When multiple built-in modules (especially drivers) provide the same capability, they're prioritized by link order specified by the order listed in Makefile. This implicit ordering is lost for loadable modules. When driver modules are loaded by udev, what comes first in modules.alias file is selected. However, the order in this file is indeterministic (depends on filesystem listing order of installed modules). This causes confusion. The solution is two-parted. This patch updates kbuild such that it generates and installs modules.order which contains the name of modules ordered according to Makefile. The second part is update to depmod such that it generates output files according to this file. Note that both obj-y and obj-m subdirs can contain modules and ordering information between those two are lost from beginning. Currently obj-y subdirs are put before obj-m subdirs. Sam Ravnborg cleaned up Makefile modifications and suggested using awk to remove duplicate lines from modules.order instead of using separate C program. Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Bill Nottingham <notting@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Jon Masters <jonathan@jonmasters.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-15kbuild: introduce ccflags-y, asflags-y and ldflags-ySam Ravnborg
Introduce ccflags-y, asflags-y and ldflags-y so we soon can deprecate use of EXTRA_CFLAGS, EXTRA_AFLAGS and EXTRA_LDFLAGS. This patch does not touch any in-tree users - thats next round. Lets get this committed first and then fix the users of the soon to be deprecated variants next. The rationale behind this change is to introduce support for makefile fragments like: ccflags-$(CONFIG_WHATEVER_DEBUG) := -DDEBUG As a replacement for the uglier: ifeq ($(CONFIG_WHATEVER_DEBUG),y) EXTRA_CFLAGS := -DDEBUG endif Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-14kbuild: check for wrong use of CFLAGSSam Ravnborg
External modules have in a few cases modifed gcc option by modifying CFLAGS. This has never been documented and was a bad practice. With the check to use KBUILD_CFLAGS it will no longer work so we better error out and tell what was wrong as a service to the external module users. This check can be overruled if KBUILD_NOPEDANTIC is set to something. Addid this possibility may allow older external module to build without any code modifications but potentially only loosing some un-important gcc options. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: kill backward compatibility checksSam Ravnborg
These checks has been present for several kernel releases (> 5). So lets just get rid of them. With this we no longer check for use of: EXTRA_TARGETS, O_TARGET, L_TARGET, list-multi, export-objs There were three remaining in-tree users of O_TARGET in some unmaintained sh64 code - mail sent to the maintainer + list. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: kill EXTRA_ARFLAGSSam Ravnborg
EXTRA_ARFLAGS have never been used so no need to carry around on this. A google search did not reveal any external module using this either. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-25kbuild: use LDFLAGS_MODULE only for .ko linksRoland McGrath
Sam Ravnborg pointed out that Documentation/kbuild/makefiles.txt already says this is what it's for. This patch makes the reality live up to the documentation. This fixes the problem of LDFLAGS_BUILD_ID getting into too many places. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-16kbuild: avoid environment to set variables used by kbuildSam Ravnborg
A few of the variables used by kbuild has fixed naming. Make sure we do not pick up random values from the environment. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-06kbuild: enable use of code from a different dirSam Ravnborg
To introduce support for source in one directory but output files in another directory during a non O= build prefix all paths with $(src) repsectively $(obj). Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-25kbuild: consistently decide when to rebuild a targetSam Ravnborg
Consistently decide when to rebuild a target across all of if_changed, if_changed_dep, if_changed_rule. PHONY targets are now treated alike (ignored) for all targets While add it make Kbuild.include almost readable by factoring out a few bits to some common variables and reuse this in Makefile.build. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-07-01kbuild: fix ia64 breakage after introducing make -rRSam Ravnborg
kbuild used $ยค(*F to get filename of target without extension. This was used in several places all over kbuild, but introducing make -rR broke his for all cases where we specified full path to target/prerequsite. It is assumed that make -rR disables old style suffix-rules which is why is suddenly failed. ia64 was impacted by this change because several div* routines in arch/ia64/lib are build using explicit paths and then kbuild failed. Thanks to David Mosberger-Tang <David.Mosberger@acm.org> for an explanation what was the root-cause and for testing on ia64. This patch also fixes two uses of $(*F) in arch/um Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-06-26Revert "kbuild: fix make -rR breakage"Linus Torvalds
This reverts commit e5c44fd88c146755da6941d047de4d97651404a9. Thanks to Daniel Ritz and Michal Piotrowski for noticing the problem. Daniel says: "[The] reason is a recent change that made modules always shows as module.mod. it breaks modprobe and probably many scripts..besides lsmod looking horrible stuff like this in modprobe.conf: install pcmcia_core /sbin/modprobe --ignore-install pcmcia_core; /sbin/modprobe pcmcia makes modprobe fork/exec endlessly calling itself...until oom interrupts it" Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-24kbuild: support for %.symtypes filesAndreas Gruenbacher
Here is a patch that adds a new -T option to genksyms for generating dumps of the type definition that makes up the symbol version hashes. This allows to trace modversion changes back to what caused them. The dump format is the name of the type defined, followed by its definition (which is almost C): s#list_head struct list_head { s#list_head * next , * prev ; } The s#, u#, e#, and t# prefixes stand for struct, union, enum, and typedef. The exported symbols do not define types, and thus do not have an x# prefix: nfs4_acl_get_whotype int nfs4_acl_get_whotype ( char * , t#u32 ) The symbol type defintion of a single file can be generated with: make fs/jbd/journal.symtypes If KBUILD_SYMTYPES is defined, all the *.symtypes of all object files that export symbols are generated. The single *.symtypes files can be combined into a single file after a kernel build with a script like the following: for f in $(find -name '*.symtypes' | sort); do f=${f#./} echo "/* ${f%.symtypes}.o */" cat $f echo done \ | sed -e '\:UNKNOWN:d' \ -e 's:[,;] }:}:g' \ -e 's:\([[({]\) :\1:g' \ -e 's: \([])},;]\):\1:g' \ -e 's: $::' \ $f \ | awk ' /^.#/ { if (defined[$1] == $0) { print $1 next } defined[$1] = $0 } { print } ' When the kernel ABI changes, diffing individual *.symtype files, or the combined files, against each other will show which symbol changes caused the ABI changes. This can save a tremendous amount of time. Dump the types that make up modversions Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-06-24kbuild: fix make -rR breakageSam Ravnborg
make failed to supply the filename when using make -rR and using $(*F) to get target filename without extension. This bug was not reproduceable in small scale but using: $(basename $(notdir $@)) fixes it with same functionality. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-06-09kconfig: fix .config dependenciesRoman Zippel
This fixes one of the worst kbuild warts left - the broken dependencies used to check and regenerate the .config file. This was done via an indirect dependency and the .config itself had an empty command, which can cause make not to reread the changed .config file. Instead of this we generate now a new file include/config/auto.conf from .config, which is used for kbuild and has the proper dependencies. It's also the main make target now for all files generated during this step (and thus replaces include/linux/autoconf.h). This also means we can now relax the syntax requirements for the .config file and we don't have to rewrite it all the time, i.e. silentoldconfig only writes .config now when it's necessary to keep it in sync with the Kconfig files and even this can be suppressed by setting the environment variable KCONFIG_NOSILENTUPDATE, so the update can (and must) be done manually. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-03-12kbuild: add -fverbose-asm to i386 MakefileChuck Ebbert
Add -fverbose-asm to i386 Makefile rule for building .s files. This makes the assembler output much more readable for humans. Suggested by Der Herr Hofrat <der.herr@hofr.at> Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-03-12kbuild: fix genksyms build errorSam Ravnborg
genksyms needs to know when a symbol must have a "_" prefex as is true for a few architectures. Pass $(ARCH) as commandline argument and hardcode what architectures that needs this info. Previous attemt to take it from elfconfig.h was br0ken since elfconfig.h is a generated file. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-03-06kbuild: change kbuild to not rely on incorrect GNU make behaviorPaul Smith
The kbuild system takes advantage of an incorrect behavior in GNU make. Once this behavior is fixed, all files in the kernel rebuild every time, even if nothing has changed. This patch ensures kbuild works with both the incorrect and correct behaviors of GNU make. For more details on the incorrect behavior, see: http://lists.gnu.org/archive/html/bug-make/2006-03/msg00003.html Changes in this patch: - Keep all targets that are to be marked .PHONY in a variable, PHONY. - Add .PHONY: $(PHONY) to mark them properly. - Remove any $(PHONY) files from the $? list when determining whether targets are up-to-date or not. Signed-off-by: Paul Smith <psmith@gnu.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-02-19kbuild: consolidate command line escapingJan Beulich
While the recent change to also escape # symbols when storing C-file compilation command lines was helpful, it should be in effect for all command lines, as much as the dollar escaping should be in effect for C-source compilation commands. Additionally, for better readability and maintenance, consolidating all the escaping (single quotes, dollars, and now sharps) was also desirable. Signed-Off-By: Jan Beulich <jbeulich@novell.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-02-19kbuild: make cc-version available in kbuild filesSam Ravnborg
Move $(CC) support functions to Kbuild.include so they are available in the kbuild files. In addition the following was done: o as-option documented in Documentation/kbuild/makefiles.txt o Moved documentation to new section to match new scope of functions o added cc-ifversion used to conditionally select a text string dependent on actual $(CC) version o documented cc-ifversion o change so Kbuild.include is read before the kbuild file Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-01-06kbuild: introduce escsq to escapre single quotesSam Ravnborg
This makes things a little bit more reader friendly and gvim is less confused. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-07-27kbuild: fix building external modulesSam Ravnborg
kbuild failed to locate Makefile for external modules. This brought to my attention how the variables for directories have different values in different usage scenarios. Different kbuild usage scenarios: make - plain make in same directory where kernel source lives make O= - kbuild is told to store output files in another directory make M= - building an external module make O= M= - building an external module with kernel output seperate from src Value assigned to the different variables: |$(src) |$(obj) |$(srctree) |$(objtree) make |reldir to k src |as src |abs path to k src |abs path to k src make O= |reldir to k src |as src |abs path to k src |abs path to output dir make M= |abs path to src |as src |abs path to k src |abs path to k src make O= M= |abs path to src |as src |abs path to k src |abs path to k output path to kbuild file: make | $(srctree)/$(src), $(src) make O= | $(srctree)/$(src) make M= | $(src) make O= M= | $(src) From the table above it can be seen that the only good way to find the home directory of the kbuild file is to locate the one of the two variants that is an absolute path. If $(src) is an absolute path (starts with /) then use it, otherwise prefix $(src) with $(srctree). Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-07-25kbuild: fix make O=...Sam Ravnborg
kbuild failed to locate Kbuild.include. Teach kbuild how to find Kbuild files when using make O=... Signed-off-by: Sam Ravnborg <sam@ravnborg.org> ---
2005-07-25kbuild: introduce Kbuild.includeSam Ravnborg
Kbuild.include is a placeholder for definitions originally present in both the top-level Makefile and scripts/Makefile.build. There were a slight difference in the filechk definition, so the most videly used version was kept and usr/Makefile was adopted for this syntax. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> ---
2005-07-14kbuild: Fix build as root then userSam Ravnborg
From: Matthew Wilcox <matthew@wil.cx> I inadvertently built a tree as root and then rebuilt it as a user. I got a lot of prompts ... mv: overwrite `drivers/char/drm/drm_auth.o', overriding mode 0644? Using mv -f fixes that. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-06-23[PATCH] apply quotation handling to Makefile.buildJan Beulich
Adding quotation handling to rule_cc_o_c in scripts/Makefile.build as used elsewhere. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
