path: root/scripts/Makefile.fwinst
2014-05-14firmware: Simplify directory creationMichal Marek
When building the firmware blobs, use a simple loop to create directories in $(objtree), like in Makefile.build. This simplifies the rules and also makes it possible to set $(objtree) to '.' later. Before this change, a dependency on $(objtree)/<dir> would be satisfied by <dir> in $(srctree). When installing the firmware blobs, call mkdir like in Makefile.modinst. Cc: David Woodhouse <dwmw2@infradead.org> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-04-30kbuild: trivial - remove trailing spacesMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-10-15kbuild: Fix accidental revert in commit fe04ddfMichal Marek
Commit fe04ddf7c291 ("kbuild: Do not package /boot and /lib in make tar-pkg") accidentally reverted two previous kbuild commits. I don't know what I was thinking. This brings back changes made by commits 24cc7fb69a5b ("x86/kbuild: archscripts depends on scripts_basic") and c1c1a59e37da ("firmware: fix directory creation rule matching with make 3.80") Reported-by: Jan Beulich <JBeulich@suse.com> Cc: <stable@vger.kernel.org> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-09-27kbuild: Do not package /boot and /lib in make tar-pkgMichal Marek
There were reports of users destroying their Fedora installs by a kernel tarball that replaces the /lib -> /usr/lib symlink. Let's remove the toplevel directories from the tarball to prevent this from happening. Reported-by: Andi Kleen <andi@firstfloor.org> Suggested-by: Ben Hutchings <ben@decadent.org.uk> Cc: <stable@kernel.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-09-21firmware: fix directory creation rule matching with make 3.80Mark Asselstine
Since make 3.80 doesn't support secondary expansion it uses a fallback rule to create firmware directories which is matched after primary expansion of the $(installed-fw) rule's prerequisite. Commit 6c7080a61fc7 [firmware: fix directory creation rule matching with make 3.82] changed the expression generated after primary expansion such that the fallback was not matched. Updating the fallback rule to match the new look primary expansion is not an option for various reasons. The trailing slash added here to $(INSTALL_FW_PATH)/. while defining installed-fw-dirs fixes builds with make 3.82 since this will provide a matching rule for $(INSTALL_FW_PATH)/$$(dir %) when % is in the base firmware directory (ie. $(dir %) gives './'). Versions of make prior to 3.82 will strip this trailing slash along with the one generated by $(dir %) when % is in the base firmware directory and as such continue to function as before. Signed-off-by: Mark Asselstine <mark.asselstine@windriver.com> Tested-by: Jan Beulich <jbeulich@suse.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-08-30firmware: fix directory creation rule matching with make 3.82Mark Asselstine
Attempting to run 'firmware_install' with CONFIG_USB_SERIAL_TI=y when using make 3.82 results in an error make[2]: *** No rule to make target `/lib/firmware/./', needed by `/lib/firmware/ti_3410.fw'. Stop. It turns out make 3.82 is picky when matching directory names with trailing slashes as a result, where make 3.81 would handle this correctly make 3.82 does not find the rule needed to create the directory. The './' seen in the error is added by $(dir) for firmware which resides in the base firmware src directory, such as ti_3410.fw.ihex. By performing $(dir) after we prepend the $(INSTALL_FW_PATH) we can ensure we don't end up with a './' in the middle of the path and the directory will be properly created. This change works with make 3.81 and should work with previous versions as well. Signed-off-by: Mark Asselstine <mark.asselstine@windriver.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2008-08-02firmware: silence __fw_modbuild and __fw_modinst 'Nothing to be done' messagesDavid Woodhouse
People don't like them and think they're errors. Leave the __fw_install one though; when 'make firmware_install' does nothing, it's best to have a 'Nothing to be done for...' message rather than just doing nothing. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-25firmware: create firmware binaries during 'make modules'.David Woodhouse
This means that we no longer need write access to the source tree while doing 'make modules_install'. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-17Update scripts/Makefile.fwinst to cope with older makeDavid Woodhouse
Also fix unwanted rebuilds of the firmware/ihex2fw tool by including the .ihex2fw.cmd file when present. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Reported-and-tested-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-10ihex: add ihex2fw tool for converting HEX files into firmware imagesDavid Woodhouse
Not the straight conversion to binary which objcopy can do for us, but actually representing each record with its original {addr, length}, because some drivers need that information preserved. Fix up 'firmware_install' to be able to build $(hostprogs-y) too. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-07-10firmware: Add firmware installation to modules_install, add firmware_installDavid Woodhouse
For 'make modules_install', install any firmware required by the modules which are being installed. Also add a 'make firmware_install' target which doesn't depend on the configuration, but installs _all_ available in-kernel-tree firmware into $(INSTALL_FW_PATH), which defaults to /lib/firmware. This is intended for distributors to make arch-independent (and config-independent) packages containing firmware. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
