commit e7c52b84fb18f08ce49b6067ae6285aca79084a8 upstream.
We get a lot of very large stack frames using gcc-7.0.1 with the default
-fsanitize-address-use-after-scope --param asan-stack=1 options, which can
easily cause an overflow of the kernel stack, e.g.
drivers/gpu/drm/i915/gvt/handlers.c:2434:1: warning: the frame size of 46176 bytes is larger than 3072 bytes
drivers/net/wireless/ralink/rt2x00/rt2800lib.c:5650:1: warning: the frame size of 23632 bytes is larger than 3072 bytes
lib/atomic64_test.c:250:1: warning: the frame size of 11200 bytes is larger than 3072 bytes
drivers/gpu/drm/i915/gvt/handlers.c:2621:1: warning: the frame size of 9208 bytes is larger than 3072 bytes
drivers/media/dvb-frontends/stv090x.c:3431:1: warning: the frame size of 6816 bytes is larger than 3072 bytes
fs/fscache/stats.c:287:1: warning: the frame size of 6536 bytes is larger than 3072 bytes
To reduce this risk, -fsanitize-address-use-after-scope is now split out
into a separate CONFIG_KASAN_EXTRA Kconfig option, leading to stack
frames that are smaller than 2 kilobytes most of the time on x86_64. An
earlier version of this patch also prevented combining KASAN_EXTRA with
KASAN_INLINE, but that is no longer necessary with gcc-7.0.1.
All patches to get the frame size below 2048 bytes with CONFIG_KASAN=y
and CONFIG_KASAN_EXTRA=n have been merged by maintainers now, so we can
bring back that default now. KASAN_EXTRA=y still causes lots of
warnings but now defaults to !COMPILE_TEST to disable it in
allmodconfig, and it remains disabled in all other defconfigs since it
is a new option. I arbitrarily raise the warning limit for KASAN_EXTRA
to 3072 to reduce the noise, but an allmodconfig kernel still has around
50 warnings on gcc-7.
I experimented a bit more with smaller stack frames and have another
follow-up series that reduces the warning limit for 64-bit architectures
to 1280 bytes (without CONFIG_KASAN).
With earlier versions of this patch series, I also had patches to address
the warnings we get with KASAN and/or KASAN_EXTRA, using a
"noinline_if_stackbloat" annotation.
That annotation now got replaced with a gcc-8 bugfix (see
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=81715) and a workaround for
older compilers, which means that KASAN_EXTRA is now just as bad as
before and will lead to an instant stack overflow in a few extreme
cases.
This reverts parts of commit 3f181b4d8652 ("lib/Kconfig.debug: disable
-Wframe-larger-than warnings with KASAN=y"). Two patches in linux-next
should be merged first to avoid introducing warnings in an allmodconfig
build:
3cd890dbe2a4 ("media: dvb-frontends: fix i2c access helpers for KASAN")
16c3ada89cff ("media: r820t: fix r820t_write_reg for KASAN")
Do we really need to backport this?
I think we do: without this patch, enabling KASAN will lead to
unavoidable kernel stack overflow in certain device drivers when built
with gcc-7 or higher on linux-4.10+ or any version that contains a
backport of commit c5caf21ab0cf8. Most people are probably still on
older compilers, but it will get worse over time as they upgrade their
distros.
The warnings we get on kernels older than this should all be for code
that uses dangerously large stack frames, though most of them do not
cause an actual stack overflow by themselves.The asan-stack option was
added in linux-4.0, and commit 3f181b4d8652 ("lib/Kconfig.debug:
disable -Wframe-larger-than warnings with KASAN=y") effectively turned
off the warning for allmodconfig kernels, so I would like to see this
fix backported to any kernels later than 4.0.
I have done dozens of fixes for individual functions with stack frames
larger than 2048 bytes with asan-stack, and I plan to make sure that
all those fixes make it into the stable kernels as well (most are
already there).
Part of the complication here is that asan-stack (from 4.0) was
originally assumed to always require much larger stacks, but that
turned out to be a combination of multiple gcc bugs that we have now
worked around and fixed, but sanitize-address-use-after-scope (from
v4.10) has a much higher inherent stack usage and also suffers from at
least three other problems that we have analyzed but not yet fixed
upstream, each of them makes the stack usage more severe than it should
be.
Link: http://lkml.kernel.org/r/20171221134744.2295529-1-arnd@arndb.de
Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Mauro Carvalho Chehab <mchehab@kernel.org>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Andrey Konovalov <andreyknvl@google.com>
commit 0e410e158e5baa1300bdf678cea4f4e0cf9d8b94 upstream.
With KASAN enabled the kernel has two different memset() functions, one
with KASAN checks (memset) and one without (__memset). KASAN uses some
macro tricks to use the proper version where required. For example
memset() calls in mm/slub.c are without KASAN checks, since they operate
on poisoned slab object metadata.
The issue is that clang emits memset() calls even when there is no
memset() in the source code. They get linked with improper memset()
implementation and the kernel fails to boot due to a huge amount of KASAN
reports during early boot stages.
The solution is to add -fno-builtin flag for files with KASAN_SANITIZE :=
n marker.
Link: http://lkml.kernel.org/r/8ffecfffe04088c52c42b92739c2bd8a0bcb3f5e.1516384594.git.andreyknvl@google.com
Signed-off-by: Andrey Konovalov <andreyknvl@google.com>
Acked-by: Nick Desaulniers <ndesaulniers@google.com>
Cc: Michal Marek <michal.lkml@markovi.net>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
In the upcoming gcc7 release, the -fsanitize=kernel-address option at
first implied new -fsanitize-address-use-after-scope option. This would
cause link errors on older kernels because they don't have two new
functions required for use-after-scope support. Therefore, gcc7 changed
default to -fno-sanitize-address-use-after-scope.
Now the kernel has everything required for that feature since commit
828347f8f9a5 ("kasan: support use-after-scope detection"). So, to make it
work, we just have to enable use-after-scope in CFLAGS.
Link: http://lkml.kernel.org/r/1481207977-28654-1-git-send-email-aryabinin@virtuozzo.com
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Acked-by: Dmitry Vyukov <dvyukov@google.com>
This patch adds arch specific code for kernel address sanitizer
(see Documentation/kasan.txt).
1/8 of kernel addresses reserved for shadow memory. There was no
big enough hole for this, so virtual addresses for shadow were
stolen from vmalloc area.
At early boot stage the whole shadow region populated with just
one physical page (kasan_zero_page). Later, this page reused
as readonly zero shadow for some memory that KASan currently
don't track (vmalloc).
After mapping the physical memory, pages for shadow memory are
allocated and mapped.
Functions like memset/memmove/memcpy do a lot of memory accesses.
If bad pointer passed to one of these function it is important
to catch this. Compiler's instrumentation cannot do this since
these functions are written in assembly.
KASan replaces memory functions with manually instrumented variants.
Original functions declared as weak symbols so strong definitions
in mm/kasan/kasan.c could replace them. Original functions have aliases
with '__' prefix in name, so we could call non-instrumented variant
if needed.
Some files built without kasan instrumentation (e.g. mm/slub.c).
Original mem* function replaced (via #define) with prefixed variants
to disable memory access checks for such files.
Signed-off-by: Andrey Ryabinin <ryabinin.a.a@gmail.com>
Tested-by: Linus Walleij <linus.walleij@linaro.org>
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
It might be annoying to constantly see this:
scripts/Makefile.kasan:16: Cannot use CONFIG_KASAN: -fsanitize=kernel-address is not supported by compiler
while performing allmodconfig/allyesconfig build tests.
Disable this warning if CONFIG_COMPILE_TEST=y.
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
Cc: Michal Marek <mmarek@suse.cz>
This feature let us to detect accesses out of bounds of global variables.
This will work as for globals in kernel image, so for globals in modules.
Currently this won't work for symbols in user-specified sections (e.g.
__init, __read_mostly, ...)
The idea of this is simple. Compiler increases each global variable by
redzone size and add constructors invoking __asan_register_globals()
function. Information about global variable (address, size, size with
redzone ...) passed to __asan_register_globals() so we could poison
variable's redzone.
This patch also forces module_alloc() to return 8*PAGE_SIZE aligned
address making shadow memory handling (
kasan_module_alloc()/kasan_module_free() ) more simple. Such alignment
guarantees that each shadow page backing modules address space correspond
to only one module_alloc() allocation.
Cc: Konstantin Serebryany <kcc@google.com>
Cc: Dmitry Chernenkov <dmitryc@google.com>
Signed-off-by: Andrey Konovalov <adech.fo@gmail.com>
Cc: Yuri Gribov <tetra2005@gmail.com>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Pekka Enberg <penberg@kernel.org>
Stack instrumentation allows to detect out of bounds memory accesses for
variables allocated on stack. Compiler adds redzones around every
variable on stack and poisons redzones in function's prologue.
Such approach significantly increases stack usage, so all in-kernel stacks
size were doubled.
Kernel Address sanitizer (KASan) is a dynamic memory error detector. It
provides fast and comprehensive solution for finding use-after-free and
out-of-bounds bugs.
KASAN uses compile-time instrumentation for checking every memory access,
therefore GCC > v4.9.2 required. v4.9.2 almost works, but has issues with
putting symbol aliases into the wrong section, which breaks kasan
instrumentation of globals.
This patch only adds infrastructure for kernel address sanitizer. It's
not available for use yet. The idea and some code was borrowed from [1].
Basic idea:
The main idea of KASAN is to use shadow memory to record whether each byte
of memory is safe to access or not, and use compiler's instrumentation to
check the shadow memory on each memory access.
Address sanitizer uses 1/8 of the memory addressable in kernel for shadow
memory and uses direct mapping with a scale and offset to translate a
memory address to its corresponding shadow address.
Here is function to translate address to corresponding shadow address:
unsigned long kasan_mem_to_shadow(unsigned long addr)
return (addr >> KASAN_SHADOW_SCALE_SHIFT) + KASAN_SHADOW_OFFSET;
where KASAN_SHADOW_SCALE_SHIFT = 3.
So for every 8 bytes there is one corresponding byte of shadow memory.
The following encoding used for each shadow byte: 0 means that all 8 bytes
of the corresponding memory region are valid for access; k (1 <= k <= 7)
means that the first k bytes are valid for access, and other (8 - k) bytes
are not; Any negative value indicates that the entire 8-bytes are
inaccessible. Different negative values used to distinguish between
different kinds of inaccessible memory (redzones, freed memory) (see
mm/kasan/kasan.h).
To be able to detect accesses to bad memory we need a special compiler.
Such compiler inserts a specific function calls (__asan_load*(addr),
__asan_store*(addr)) before each memory access of size 1, 2, 4, 8 or 16.
These functions check whether memory region is valid to access or not by
checking corresponding shadow memory. If access is not valid an error
printed.
Historical background of the address sanitizer from Dmitry Vyukov:
"We've developed the set of tools, AddressSanitizer (Asan),
ThreadSanitizer and MemorySanitizer, for user space. We actively use
them for testing inside of Google (continuous testing, fuzzing,
running prod services). To date the tools have found more than 10'000
scary bugs in Chromium, Google internal codebase and various
open-source projects (Firefox, OpenSSL, gcc, clang, ffmpeg, MySQL and
lots of others): [2] [3] [4].
The tools are part of both gcc and clang compilers.
We have not yet done massive testing under the Kernel AddressSanitizer
(it's kind of chicken and egg problem, you need it to be upstream to
start applying it extensively). To date it has found about 50 bugs.
Bugs that we've found in upstream kernel are listed in [5].
We've also found ~20 bugs in out internal version of the kernel. Also
people from Samsung and Oracle have found some.
As others noted, the main feature of AddressSanitizer is its
performance due to inline compiler instrumentation and simple linear
shadow memory. User-space Asan has ~2x slowdown on computational
programs and ~2x memory consumption increase. Taking into account that
kernel usually consumes only small fraction of CPU and memory when
running real user-space programs, I would expect that kernel Asan will
have ~10-30% slowdown and similar memory consumption increase (when we
finish all tuning).
I agree that Asan can well replace kmemcheck. We have plans to start
working on Kernel MemorySanitizer that finds uses of unitialized
memory. Asan+Msan will provide feature-parity with kmemcheck. As
others noted, Asan will unlikely replace debug slab and pagealloc that
can be enabled at runtime. Asan uses compiler instrumentation, so even
if it is disabled, it still incurs visible overheads.
Asan technology is easily portable to other architectures. Compiler
instrumentation is fully portable. Runtime has some arch-dependent
parts like shadow mapping and atomic operation interception. They are
relatively easy to port."
Comparison with other debugging features:
KMEMCHECK:
- KASan can do almost everything that kmemcheck can. KASan uses
compile-time instrumentation, which makes it significantly faster than
kmemcheck. The only advantage of kmemcheck over KASan is detection of
uninitialized memory reads.
Some brief performance testing showed that kasan could be
x500-x600 times faster than kmemcheck:
$ netperf -l 30
MIGRATED TCP STREAM TEST from 0.0.0.0 (0.0.0.0) port 0 AF_INET to localhost (127.0.0.1) port 0 AF_INET
Recv Send Send
Socket Socket Message Elapsed
Size Size Size Time Throughput
bytes bytes bytes secs. 10^6bits/sec
no debug: 87380 16384 16384 30.00 41624.72
kasan inline: 87380 16384 16384 30.00 12870.54
kasan outline: 87380 16384 16384 30.00 10586.39
kmemcheck: 87380 16384 16384 30.03 20.23
- Also kmemcheck couldn't work on several CPUs. It always sets
number of CPUs to 1. KASan doesn't have such limitation.
DEBUG_PAGEALLOC:
- KASan is slower than DEBUG_PAGEALLOC, but KASan works on sub-page
granularity level, so it able to find more bugs.
SLUB_DEBUG (poisoning, redzones):
- SLUB_DEBUG has lower overhead than KASan.
- SLUB_DEBUG in most cases are not able to detect bad reads,
KASan able to detect both reads and writes.
- In some cases (e.g. redzone overwritten) SLUB_DEBUG detect
bugs only on allocation/freeing of object. KASan catch
bugs right before it will happen, so we always know exact
place of first bad read/write.
[1] https://code.google.com/p/address-sanitizer/wiki/AddressSanitizerForKernel
[2] https://code.google.com/p/address-sanitizer/wiki/FoundBugs
[3] https://code.google.com/p/thread-sanitizer/wiki/FoundBugs
[4] https://code.google.com/p/memory-sanitizer/wiki/FoundBugs
[5] https://code.google.com/p/address-sanitizer/wiki/AddressSanitizerForKernel#Trophies
Based on work by Andrey Konovalov.
Acked-by: Michal Marek <mmarek@suse.cz>
