path: root/scripts/Makefile.lib
2010-01-13kbuild: really fix bzImage build with non-bash shJonathan Nieder
In an x86 build with CONFIG_KERNEL_LZMA enabled and dash as sh, arch/x86/boot/compressed/vmlinux.bin.lzma ends with '\xf0\x7d\x39\x00' (16 bytes) instead of the 4 bytes intended and the resulting vmlinuz fails to boot. This improves on the previous behavior, in which the file contained the characters '-ne ' as well, but not by much. Previous commits replaced "echo -ne" first with "/bin/echo -ne", then "printf" in the hope of improving portability, but none of these commands is guaranteed to support hexadecimal escapes on POSIX systems. So use the shell to convert from hexadecimal to octal. With this change, an LZMA-compressed kernel built with dash as sh boots correctly again. Reported-by: Sebastian Dalfuß <sd@sedf.de> Reported-by: Oliver Hartkopp <oliver@hartkopp.net> Reported-by: Michael Guntsche <mike@it-loops.com> Signed-off-by: Jonathan Nieder <jrnieder@gmail.com> Cc: Michael Tokarev <mjt@tls.msk.ru> Cc: Alek Du <alek.du@intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-01-11lib: add support for LZO-compressed kernelsAlbin Tonnerre
This patch series adds generic support for creating and extracting LZO-compressed kernel images, as well as support for using such images on the x86 and ARM architectures, and support for creating and using LZO-compressed initrd and initramfs images. Russell King said: : Testing on a Cortex A9 model: : - lzo decompressor is 65% of the time gzip takes to decompress a kernel : - lzo kernel is 9% larger than a gzip kernel : : which I'm happy to say confirms your figures when comparing the two. : : However, when comparing your new gzip code to the old gzip code: : - new is 99% of the size of the old code : - new takes 42% of the time to decompress than the old code : : What this means is that for a proper comparison, the results get even better: : - lzo is 7.5% larger than the old gzip'd kernel image : - lzo takes 28% of the time that the old gzip code took : : So the expense seems definitely worth the effort. The only reason I : can think of ever using gzip would be if you needed the additional : compression (eg, because you have limited flash to store the image.) : : I would argue that the default for ARM should therefore be LZO. This patch: The lzo compressor is worse than gzip at compression, but faster at extraction. Here are some figures for an ARM board I'm working on: Uncompressed size: 3.24Mo gzip 1.61Mo 0.72s lzo 1.75Mo 0.48s So for a compression ratio that is still relatively close to gzip, it's much faster to extract, at least in that case. This part contains: - Makefile routine to support lzo compression - Fixes to the existing lzo compressor so that it can be used in compressed kernels - wrapper around the existing lzo1x_decompress, as it only extracts one block at a time, while we need to extract a whole file here - config dialog for kernel compression [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: cleanup] Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Tested-by: Wu Zhangjin <wuzhangjin@gmail.com> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Tested-by: Russell King <rmk@arm.linux.org.uk> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-17Merge branch 'for-33' of git://repo.or.cz/linux-kbuildLinus Torvalds
* 'for-33' of git://repo.or.cz/linux-kbuild: (29 commits) net: fix for utsrelease.h moving to generated gen_init_cpio: fixed fwrite warning kbuild: fix make clean after mismerge kbuild: generate modules.builtin genksyms: properly consider EXPORT_UNUSED_SYMBOL{,_GPL}() score: add asm/asm-offsets.h wrapper unifdef: update to upstream revision 1.190 kbuild: specify absolute paths for cscope kbuild: create include/generated in silentoldconfig scripts/package: deb-pkg: use fakeroot if available scripts/package: add KBUILD_PKG_ROOTCMD variable scripts/package: tar-pkg: use tar --owner=root Kbuild: clean up marker net: add net_tstamp.h to headers_install kbuild: move utsrelease.h to include/generated kbuild: move autoconf.h to include/generated drop explicit include of autoconf.h kbuild: move compile.h to include/generated kbuild: drop include/asm kbuild: do not check for include/asm-$ARCH ... Fixed non-conflicting clean merge of modpost.c as per comments from Stephen Rothwell (modpost.c had grown an include of linux/autoconf.h that needed to be changed to generated/autoconf.h)
2009-12-15module: make MODULE_SYMBOL_PREFIX into a CONFIG optionAlan Jenkins
The next commit will require the use of MODULE_SYMBOL_PREFIX in .tmp_exports-asm.S. Currently it is mixed in with C structure definitions in "asm/module.h". Move the definition of this arch option into Kconfig, so it can be easily accessed by any code. This also lets modpost.c use the same definition. Previously modpost relied on a hardcoded list of architectures in mk_elfconfig.c. A build test for blackfin, one of the two MODULE_SYMBOL_PREFIX archs, showed the generated code was unchanged. vmlinux was identical save for build ids, and an apparently randomized suffix on a single "__key" symbol in the kallsyms data). Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Acked-by: Mike Frysinger <vapier@gentoo.org> (blackfin) CC: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-12-12kbuild: fix bzImage build for x86Michael Tokarev
As has been discussed previously (and Sam has been CC'ed), the fix is still incorrect. It replaces "echo -ne" with "/bin/echo -ne", but neither of the two are guaranteed to support the necessary arguments and necessary (hexadecimal) escape sequences. What should be used here is printf(1). The trivial patch below (on top of these kbuild changes) fixes this issue. Signed-Off-By: Michael Tokarev <mjt@tls.msk.ru> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-10-11kbuild: Fix size_append issue for bzip2/lzma kernelAlek Du
The Makefile.lib will call "echo -ne" to append uncompressed kernel size to bzip2/lzma kernel image. The "echo" here depends on the shell that /bin/sh pointing to. On Ubuntu system, the /bin/sh is pointing to dash, which does not support "echo -e" at all. Use /bin/echo instead of shell echo should always be safe. Signed-off-by: Alek Du <alek.du@intel.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-06-18gcov: add gcov profiling infrastructurePeter Oberparleiter
Enable the use of GCC's coverage testing tool gcov [1] with the Linux kernel. gcov may be useful for: * debugging (has this code been reached at all?) * test improvement (how do I change my test to cover these lines?) * minimizing kernel configurations (do I need this option if the associated code is never run?) The profiling patch incorporates the following changes: * change kbuild to include profiling flags * provide functions needed by profiling code * present profiling data as files in debugfs Note that on some architectures, enabling gcc's profiling option "-fprofile-arcs" for the entire kernel may trigger compile/link/ run-time problems, some of which are caused by toolchain bugs and others which require adjustment of architecture code. For this reason profiling the entire kernel is initially restricted to those architectures for which it is known to work without changes. This restriction can be lifted once an architecture has been tested and found compatible with gcc's profiling. Profiling of single files or directories is still available on all platforms (see config help text). [1] http://gcc.gnu.org/onlinedocs/gcc/Gcov.html Signed-off-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Huang Ying <ying.huang@intel.com> Cc: Li Wei <W.Li@Sun.COM> Cc: Michael Ellerman <michaele@au1.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Heiko Carstens <heicars2@linux.vnet.ibm.com> Cc: Martin Schwidefsky <mschwid2@linux.vnet.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: WANG Cong <xiyou.wangcong@gmail.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-10Merge branch 'x86-kbuild-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-kbuild-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (46 commits) x86, boot: add new generated files to the appropriate .gitignore files x86, boot: correct the calculation of ZO_INIT_SIZE x86-64: align __PHYSICAL_START, remove __KERNEL_ALIGN x86, boot: correct sanity checks in boot/compressed/misc.c x86: add extension fields for bootloader type and version x86, defconfig: update kernel position parameters x86, defconfig: update to current, no material changes x86: make CONFIG_RELOCATABLE the default x86: default CONFIG_PHYSICAL_START and CONFIG_PHYSICAL_ALIGN to 16 MB x86: document new bzImage fields x86, boot: make kernel_alignment adjustable; new bzImage fields x86, boot: remove dead code from boot/compressed/head_*.S x86, boot: use LOAD_PHYSICAL_ADDR on 64 bits x86, boot: make symbols from the main vmlinux available x86, boot: determine compressed code offset at compile time x86, boot: use appropriate rep string for move and clear x86, boot: zero EFLAGS on 32 bits x86, boot: set up the decompression stack as early as possible x86, boot: straighten out ranges to copy/zero in compressed/head*.S x86, boot: stylistic cleanups for boot/compressed/head_64.S ... Fixed trivial conflict in arch/x86/configs/x86_64_defconfig manually
2009-05-08kbuild: allow compressors (gzip, bzip2, lzma) to take multiple inputsH. Peter Anvin
Allow the compression commands in Kbuild (i.e. gzip, bzip2, lzma) to take multiple input files and emit the concatenated compressed output. This avoids an intermediate step when a kernel image is built from multiple components, such as the relocatable x86-32 kernel. Sam Ravnborg integrated the bin_size script into the Makefile. [ Impact: new build feature, not yet used ] Signed-off-by: H. Peter Anvin <hpa@zytor.com> Acked-by: Sam Ravnborg <sam@ravnborg.org>
2009-04-19kbuild: introduce subdir-ccflags-ySam Ravnborg
Following patch introduce support for setting options to gcc that has effect for current directory and all subdirectories. The typical use case are an architecture or a subsystem that decide to cover all files with -Werror. Today alpha, mips and sparc uses -Werror in almost all their Makefile- with subdir-ccflag-y it is now simpler to do so as only the top-level directories needs to be covered. Likewise if we decide to cover a full subsystem such as net/ with -Werror this is done by adding a single line to net/Makefile. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de>
2009-03-27Merge branch 'core/percpu' into percpu-cpumask-x86-for-linus-2Ingo Molnar
Conflicts: arch/parisc/kernel/irq.c arch/x86/include/asm/fixmap_64.h arch/x86/include/asm/setup.h kernel/irq/handle.c Semantic merge: arch/x86/include/asm/fixmap.h Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-24dynamic debug: combine dprintk and dynamic printkJason Baron
This patch combines Greg Bank's dprintk() work with the existing dynamic printk patchset, we are now calling it 'dynamic debug'. The new feature of this patchset is a richer /debugfs control file interface, (an example output from my system is at the bottom), which allows fined grained control over the the debug output. The output can be controlled by function, file, module, format string, and line number. for example, enabled all debug messages in module 'nf_conntrack': echo -n 'module nf_conntrack +p' > /mnt/debugfs/dynamic_debug/control to disable them: echo -n 'module nf_conntrack -p' > /mnt/debugfs/dynamic_debug/control A further explanation can be found in the documentation patch. Signed-off-by: Greg Banks <gnb@sgi.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-04bzip2/lzma: handle failures from bzip2 and lzma correctlyH. Peter Anvin
Impact: Bug fix If bzip2 or lzma fails (for example, if they aren't installed on the system), we need to propagate the failure out to "make". However, they were masked by being followed by a semicolon. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-01-04bzip2/lzma: library support for gzip, bzip2 and lzma decompressionAlain Knaff
Impact: Replaces inflate.c with a wrapper around zlib_inflate; new library code This is the first part of the bzip2/lzma patch The bzip patch is based on an idea by Christian Ludwig, includes support for compressing the kernel with bzip2 or lzma rather than gzip. Both compressors give smaller sizes than gzip. Lzma's decompresses faster than bzip2. It also supports ramdisks and initramfs' compressed using these two compressors. The functionality has been successfully used for a couple of years by the udpcast project This version applies to "tip" kernel 2.6.28 This part contains: - changed inflate.c to accomodate rest of patch - implementation of bzip2 compression (not used at this stage yet) - implementation of lzma compression (not used at this stage yet) - Makefile routines to support bzip2 and lzma kernel compression Signed-off-by: Alain Knaff <alain@knaff.lu> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-12-03kbuild: expand -I in KBUILD_CPPFLAGSSam Ravnborg
kbuild failed to expand include flags in KBUILD_CPPFLAGS resulting in code like this in arch Makefiles: ifeq ($(KBUILD_SRC),) KBUILD_CPPFLAGS += -Iinclude/foo else KBUILD_CPPFLAGS += -I$(srctree)/include/foo endif Move use of LINUXINCLUDE into Makefile.lib to allow us to expand -I directives of KBUILD_CPPFLAGS so we can avoid the above code. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-10-16driver core: basic infrastructure for per-module dynamic debug messagesJason Baron
Base infrastructure to enable per-module debug messages. I've introduced CONFIG_DYNAMIC_PRINTK_DEBUG, which when enabled centralizes control of debugging statements on a per-module basis in one /proc file, currently, <debugfs>/dynamic_printk/modules. When, CONFIG_DYNAMIC_PRINTK_DEBUG, is not set, debugging statements can still be enabled as before, often by defining 'DEBUG' for the proper compilation unit. Thus, this patch set has no affect when CONFIG_DYNAMIC_PRINTK_DEBUG is not set. The infrastructure currently ties into all pr_debug() and dev_dbg() calls. That is, if CONFIG_DYNAMIC_PRINTK_DEBUG is set, all pr_debug() and dev_dbg() calls can be dynamically enabled/disabled on a per-module basis. Future plans include extending this functionality to subsystems, that define their own debug levels and flags. Usage: Dynamic debugging is controlled by the debugfs file, <debugfs>/dynamic_printk/modules. This file contains a list of the modules that can be enabled. The format of the file is as follows: <module_name> <enabled=0/1> . . . <module_name> : Name of the module in which the debug call resides <enabled=0/1> : whether the messages are enabled or not For example: snd_hda_intel enabled=0 fixup enabled=1 driver enabled=0 Enable a module: $echo "set enabled=1 <module_name>" > dynamic_printk/modules Disable a module: $echo "set enabled=0 <module_name>" > dynamic_printk/modules Enable all modules: $echo "set enabled=1 all" > dynamic_printk/modules Disable all modules: $echo "set enabled=0 all" > dynamic_printk/modules Finally, passing "dynamic_printk" at the command line enables debugging for all modules. This mode can be turned off via the above disable command. [gkh: minor cleanups and tweaks to make the build work quietly] Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-23kbuild: create new CFLAGS_REMOVE_(basename).o optionSteven Rostedt
We currently have a way to add special CFLAGS to code, but we do not have a way to remove them if needed. With the case of ftrace, some files should simply not be profiled. Adding the -pg flag to these files is simply a waste, and adding "notrace" to each and every function is ugly. Currently we put in "Makefile turd" [1] to stop the compiler from adding -pg to certain files. This was clumsy and awkward. This patch now adds the revese of CFLAGS_(basename).o with CFLAGS_REMOVE_(basename).o. This allows developers to prevent certain CFLAGS from being used to compile files. For example, we can now do CFLAGS_REMOVE_string.o = -pg to remove the -pg option from the string.o file in the lib directory. Note: a space delimited list of options may be added to the REMOVE macro. [1] - what David Miller called the workaronud to remove -pg Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-28kbuild: implement modules.orderTejun Heo
When multiple built-in modules (especially drivers) provide the same capability, they're prioritized by link order specified by the order listed in Makefile. This implicit ordering is lost for loadable modules. When driver modules are loaded by udev, what comes first in modules.alias file is selected. However, the order in this file is indeterministic (depends on filesystem listing order of installed modules). This causes confusion. The solution is two-parted. This patch updates kbuild such that it generates and installs modules.order which contains the name of modules ordered according to Makefile. The second part is update to depmod such that it generates output files according to this file. Note that both obj-y and obj-m subdirs can contain modules and ordering information between those two are lost from beginning. Currently obj-y subdirs are put before obj-m subdirs. Sam Ravnborg cleaned up Makefile modifications and suggested using awk to remove duplicate lines from modules.order instead of using separate C program. Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Bill Nottingham <notting@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Jon Masters <jonathan@jonmasters.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-15kbuild: introduce ccflags-y, asflags-y and ldflags-ySam Ravnborg
Introduce ccflags-y, asflags-y and ldflags-y so we soon can deprecate use of EXTRA_CFLAGS, EXTRA_AFLAGS and EXTRA_LDFLAGS. This patch does not touch any in-tree users - thats next round. Lets get this committed first and then fix the users of the soon to be deprecated variants next. The rationale behind this change is to introduce support for makefile fragments like: ccflags-$(CONFIG_WHATEVER_DEBUG) := -DDEBUG As a replacement for the uglier: ifeq ($(CONFIG_WHATEVER_DEBUG),y) EXTRA_CFLAGS := -DDEBUG endif Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-15kbuild: enable 'make CPPFLAGS=...' to add additional options to CPPSam Ravnborg
The variable CPPFLAGS is a wellknown variable and the usage by kbuild may result in unexpected behaviour. This patch replace use of CPPFLAGS with KBUILD_CPPFLAGS all over the tree and enabling one to use: make CPPFLAGS=... to specify additional CPP commandline options. Patch was tested on following architectures: alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k, s390 Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-15kbuild: enable 'make AFLAGS=...' to add additional options to ASSam Ravnborg
The variable AFLAGS is a wellknown variable and the usage by kbuild may result in unexpected behaviour. On top of that several people over time has asked for a way to pass in additional flags to gcc. This patch replace use of AFLAGS with KBUILD_AFLAGS all over the tree. Patch was tested on following architectures: alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k, s390 Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-14kbuild: enable 'make CFLAGS=...' to add additional options to CCSam Ravnborg
The variable CFLAGS is a wellknown variable and the usage by kbuild may result in unexpected behaviour. On top of that several people over time has asked for a way to pass in additional flags to gcc. This patch replace use of CFLAGS with KBUILD_CFLAGS all over the tree and enabling one to use: make CFLAGS=... to specify additional gcc commandline options. One usecase is when trying to find gcc bugs but other use cases has been requested too. Patch was tested on following architectures: alpha, arm, i386, x86_64, mips, sparc, sparc64, ia64, m68k Test was simple to do a defconfig build, apply the patch and check that nothing got rebuild. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: kill backward compatibility checksSam Ravnborg
These checks has been present for several kernel releases (> 5). So lets just get rid of them. With this we no longer check for use of: EXTRA_TARGETS, O_TARGET, L_TARGET, list-multi, export-objs There were three remaining in-tree users of O_TARGET in some unmaintained sh64 code - mail sent to the maintainer + list. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: fix directory traversal bugSam Ravnborg
Previously kbuild choked over the following: obj-y += ../../../arch/i386/kernel/bootflag.o This has resulted in some rather ugly workarounds in current x86_64 tree. This patch fixes kbuild to allow the above and enable potential cleanups in x86_64 and maybe in other places. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-07-01kbuild: fix ia64 breakage after introducing make -rRSam Ravnborg
kbuild used $¤(*F to get filename of target without extension. This was used in several places all over kbuild, but introducing make -rR broke his for all cases where we specified full path to target/prerequsite. It is assumed that make -rR disables old style suffix-rules which is why is suddenly failed. ia64 was impacted by this change because several div* routines in arch/ia64/lib are build using explicit paths and then kbuild failed. Thanks to David Mosberger-Tang <David.Mosberger@acm.org> for an explanation what was the root-cause and for testing on ia64. This patch also fixes two uses of $(*F) in arch/um Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-06-26Revert "kbuild: fix make -rR breakage"Linus Torvalds
This reverts commit e5c44fd88c146755da6941d047de4d97651404a9. Thanks to Daniel Ritz and Michal Piotrowski for noticing the problem. Daniel says: "[The] reason is a recent change that made modules always shows as module.mod. it breaks modprobe and probably many scripts..besides lsmod looking horrible stuff like this in modprobe.conf: install pcmcia_core /sbin/modprobe --ignore-install pcmcia_core; /sbin/modprobe pcmcia makes modprobe fork/exec endlessly calling itself...until oom interrupts it" Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-24kbuild: fix make -rR breakageSam Ravnborg
make failed to supply the filename when using make -rR and using $(*F) to get target filename without extension. This bug was not reproduceable in small scale but using: $(basename $(notdir $@)) fixes it with same functionality. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-04-07kbuild: properly pass options to hostcc when doing make O=..Sam Ravnborg
This fix a longstanding bug where proper options was not passed to hostcc in case of a make O=.. build. This bug showed up in (not yet merged) klibc, and is not known to have any counterpart in-kernel. Fixed by moving the flags macro to Kbuild.include so it can be used by both Makefile.lib and Makefile.host. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-12-26kbuild: set correct KBUILD_MODNAME when using well known kernel symbols as ↵Ustyugov Roman
module names This patch fixes a problem when we use well known kernel symbols as module names. For example, if module source name is current.c, idle_stack.c or etc., we have a bad KBUILD_MODNAME value. For example, KBUILD_MODNAME will be "get_current()" instead of "current", or "(init_thread_union.stack)" instead of "idle_task". The trick is to define a stringify macro on the commandline - named KBUILD_STR for namespace reasons - and then to stringify the module name. There are a few uses of KBUILD_MODNAME throughout the tree but the usage is for debug and will not be harmed by this change so left untouched for now. While at it KBUILD_BASENAME was changed too. Any spinlock usage in the unix module would have created wrong section names without it. Usage in spinlock.h fixed so it no longer stringify KBUILD_BASENAME. Original patch from Ustyogov Roman - all bugs introduced by me. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-07-25kbuild: introduce Kbuild.includeSam Ravnborg
Kbuild.include is a placeholder for definitions originally present in both the top-level Makefile and scripts/Makefile.build. There were a slight difference in the filechk definition, so the most videly used version was kept and usr/Makefile was adopted for this syntax. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> ---
2005-07-25kbuild: drop descend - converting existing usersSam Ravnborg
There was only two users left of descend. Fix them so they use $(clean)= and $(build)=. Drop definition of descend. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> ---
