path: root/scripts/Makefile.modpost
2008-10-29kbuild: fix KBUILD_EXTRA_SYMBOLSPeter Volkov
Taken from http://bugzilla.kernel.org/show_bug.cgi?id=11567 If you even define KBUILD_EXTRA_SYMBOLS in Makefile it will not be expanded into command line argument for modpost. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-22markers: fix duplicate modpost entryMathieu Desnoyers
When a kernel was rebuilt, the previous Module.markers was not cleared. It caused markers with different format strings to appear as duplicates when a markers was changed. This problem is present since scripts/mod/modpost.c started to generate Module.markers, commit b2e3e658b344c6bcfb8fb694100ab2f2b5b2edb0 It therefore applies to 2.6.25, 2.6.26 and linux-next. I merely merged the patches from Roland, Wenji and Takashi here. Credits to Roland McGrath <roland@redhat.com> Wenji Huang <wenji.huang@oracle.com> and Takashi Nishiie <t-nishiie@np.css.fujitsu.com> for providing the individual fixes. - Changelog : - Integrated Takashi's Makefile modification to clear Module.markers upon make clean. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Roland McGrath <roland@redhat.com> Cc: Wenji Huang <wenji.huang@oracle.com> Cc: Takashi Nishiie <t-nishiie@np.css.fujitsu.com> Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-31kbuild: fix $(src) assignmnet with external modulesSam Ravnborg
When we introduced support for KBUILD_EXTRA_SYMBOLS we started to include the externam module's kbuild file when doing the final modpost step. As external modules often do: ccflags-y := -I$(src) We had problems because $(src) was unassinged and gcc then used the next parameter for -I resulting in strange build failures. Fix is to assign $(src) and $(obj) when building external modules. This fixes: http://bugzilla.kernel.org/show_bug.cgi?id=10798 Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Tvrtko <tvrtko.ursulin@sophos.com> Cc: Andrea Arcangeli <andrea@qumranet.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
2008-04-26kbuild: scripts/Makefile.modpost typo fixAdrian Bunk
-EVIUSER ;-) Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-04-25kbuild: Add new Kbuild variable KBUILD_EXTRA_SYMBOLSRichard Hacker
This patch adds a new (Kbuild) Makefile variable KBUILD_EXTRA_SYMBOLS. The space separated list of file names assigned to KBUILD_EXTRA_SYMBOLS is used when calling scripts/mod/modpost during stage 2 of the Kbuild process for non-kernel-tree modules. Signed-off-by: Richard Hacker <lerichi@gmx.net> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-03-23kbuild: soften modpost checks when doing cross buildsSam Ravnborg
The module alias support in the kernel have a consistency check where it is checked that the size of a structure in the kernel and on the build host are the same. For cross builds this check does not make sense so detect when we do cross builds and silently skip the check in these situations. This fixes a build bug for a wireless driver when cross building for arm. Acked-by: Michael Buesch <mb@bu3sch.de> Tested-by: Gordon Farquharson <gordonfarquharson@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: stable@kernel.org
2008-02-13Linux Kernel Markers: create modpost fileMathieu Desnoyers
This adds some new magic in the MODPOST phase for CONFIG_MARKERS. Analogous to the Module.symvers file, the build will now write a Module.markers file when CONFIG_MARKERS=y is set. This file lists the name, defining module, and format string of each marker, separated by \t characters. This simple text file can be used by offline build procedures for instrumentation code, analogous to how System.map and Module.symvers can be useful to have for kernels other than the one you are running right now. The strings are made easy to extract by having the __trace_mark macro define the name and format together in a single array called __mstrtab_* in the __markers_strings section. This is straightforward and reliable as long as the marker structs are always defined by this macro. It is an unreasonable amount of hairy work to extract the string pointers from the __markers section structs, which entails handling a relocation type for every machine under the sun. Mathieu : - Ran through checkpatch.pl Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: David Smith <dsmith@redhat.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-28kbuild: add verbose option to Section mismatch reporting in modpostSam Ravnborg
If the config option CONFIG_SECTION_MISMATCH is not set and we see a Section mismatch present the following to the user: modpost: Found 1 section mismatch(es). To see additional details select "Enable full Section mismatch analysis" in the Kernel Hacking menu (CONFIG_SECTION_MISMATCH). If the option CONFIG_SECTION_MISMATCH is selected then be verbose in the Section mismatch reporting from mdopost. Sample outputs: WARNING: o-x86_64/vmlinux.o(.text+0x7396): Section mismatch in reference from the function discover_ebda() to the variable .init.data:ebda_addr The function discover_ebda() references the variable __initdata ebda_addr. This is often because discover_ebda lacks a __initdata annotation or the annotation of ebda_addr is wrong. WARNING: o-x86_64/vmlinux.o(.data+0x74d58): Section mismatch in reference from the variable pci_serial_quirks to the function .devexit.text:pci_plx9050_exit() The variable pci_serial_quirks references the function __devexit pci_plx9050_exit() If the reference is valid then annotate the variable with __exit* (see linux/init.h) or name the variable: *driver, *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console, WARNING: o-x86_64/vmlinux.o(__ksymtab+0x630): Section mismatch in reference from the variable __ksymtab_arch_register_cpu to the function .cpuinit.text:arch_register_cpu() The symbol arch_register_cpu is exported and annotated __cpuinit Fix this by removing the __cpuinit annotation of arch_register_cpu or drop the export. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-25kbuild: use LDFLAGS_MODULE only for .ko linksRoland McGrath
Sam Ravnborg pointed out that Documentation/kbuild/makefiles.txt already says this is what it's for. This patch makes the reality live up to the documentation. This fixes the problem of LDFLAGS_BUILD_ID getting into too many places. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-25kbuild: do not do section mismatch checks on vmlinux in 2nd passSam Ravnborg
We already check and warn about section mismatches from vmlinux (build as vmlinux.o) during first pass so skip the checks during the 2nd pass where we process modules. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-17kbuild: do section mismatch check on full vmlinuxSam Ravnborg
Previously we did do the check on the .o files used to link vmlinux but that failed to find questionable references across the .o files. Create a dedicated vmlinux.o file used only for section mismatch checks that uses the defualt linker script so section does not get renamed. The vmlinux.o may later be used as part of the the final link of vmlinux but for now it is used fo section mismatch only. For a defconfig build this is instant but for an allyesconfig this add two minutes to a full build (that anyways takes ~2 hours). Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-02kbuild: fix section mismatch check for vmlinuxSam Ravnborg
vmlinux does not contain relocation entries which is used by the section mismatch checks. Reported by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Use the individual objects as inputs to overcome this limitation. In modpost check the .o files and skip non-ELF files. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-10-17[PATCH] kbuild: allow multi-word $M in Makefile.modpostGreg Banks
Some people want to do crazy things like pass multiple directories as the value of $(SUBDIRS) or $M. Mostly this kinda works, except that Makefile.modpost constructs a modpost commandline which fails modpost's argument parsing. This patch fixes that little wrinkle. Signed-off-by: Greg Banks <gnb@melbourne.sgi.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01kbuild: make modpost processing configurableSam Ravnborg
On request from Al Viro make modpost processing configurable. KBUILD_MODPOST_WARN can be set to make modpost warn instead of error out in case on unresolved symbols in final module link. KBUILD_MODPOST_NOFINAL can be set to avoid the final and timeconsuming .c file generation and link of .ko files. This is solely useful for speeding up when doing compile checks with for example allmodconfig Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-25kbuild: fail kernel compilation in case of unresolved module symbolsKirill Korotaev
At stage 2 modpost utility is used to check modules. In case of unresolved symbols modpost only prints warning. IMHO it is a good idea to fail compilation process in case of unresolved symbols (at least in modules coming with kernel), since usually such errors are left unnoticed, but kernel modules are broken. - new option '-w' is added to modpost: if option is specified, modpost only warns about unresolved symbols - modpost is called with '-w' for external modules in Makefile.modpost Signed-off-by: Andrey Mirkin <amirkin@sw.ru> Signed-off-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-25kbuild: modpost on vmlinux regardless of CONFIG_MODULESSam Ravnborg
Based on patch from: Magnus Damm <magnus@valinux.co.jp> This has the advantage that all section mismatch checks are run regardless of modules being enabled or not. When running modpost on vmlinux output: MODPOST vmlinux When running modpost on modules output count of modules like this: MODPOST 5 modules Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-08-01kbuild: fix typo in modpostDave Jones
Reported by a Fedora user when they tried to build some out of tree module.. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-07-01kbuild: fix ia64 breakage after introducing make -rRSam Ravnborg
kbuild used $ยค(*F to get filename of target without extension. This was used in several places all over kbuild, but introducing make -rR broke his for all cases where we specified full path to target/prerequsite. It is assumed that make -rR disables old style suffix-rules which is why is suddenly failed. ia64 was impacted by this change because several div* routines in arch/ia64/lib are build using explicit paths and then kbuild failed. Thanks to David Mosberger-Tang <David.Mosberger@acm.org> for an explanation what was the root-cause and for testing on ia64. This patch also fixes two uses of $(*F) in arch/um Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-06-26Revert "kbuild: fix make -rR breakage"Linus Torvalds
This reverts commit e5c44fd88c146755da6941d047de4d97651404a9. Thanks to Daniel Ritz and Michal Piotrowski for noticing the problem. Daniel says: "[The] reason is a recent change that made modules always shows as module.mod. it breaks modprobe and probably many scripts..besides lsmod looking horrible stuff like this in modprobe.conf: install pcmcia_core /sbin/modprobe --ignore-install pcmcia_core; /sbin/modprobe pcmcia makes modprobe fork/exec endlessly calling itself...until oom interrupts it" Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-24kbuild: fix make -rR breakageSam Ravnborg
make failed to supply the filename when using make -rR and using $(*F) to get target filename without extension. This bug was not reproduceable in small scale but using: $(basename $(notdir $@)) fixes it with same functionality. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-06-09kconfig: fix .config dependenciesRoman Zippel
This fixes one of the worst kbuild warts left - the broken dependencies used to check and regenerate the .config file. This was done via an indirect dependency and the .config itself had an empty command, which can cause make not to reread the changed .config file. Instead of this we generate now a new file include/config/auto.conf from .config, which is used for kbuild and has the proper dependencies. It's also the main make target now for all files generated during this step (and thus replaces include/linux/autoconf.h). This also means we can now relax the syntax requirements for the .config file and we don't have to rewrite it all the time, i.e. silentoldconfig only writes .config now when it's necessary to keep it in sync with the Kconfig files and even this can be suppressed by setting the environment variable KCONFIG_NOSILENTUPDATE, so the update can (and must) be done manually. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-03-25Merge master.kernel.org:/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/sam/kbuild: (46 commits) kbuild: remove obsoleted scripts/reference_* files kbuild: fix make help & make *pkg kconfig: fix time ordering of writes to .kconfig.d and include/linux/autoconf.h Kconfig: remove the CONFIG_CC_ALIGN_* options kbuild: add -fverbose-asm to i386 Makefile kbuild: clean-up genksyms kbuild: Lindent genksyms.c kbuild: fix genksyms build error kbuild: in makefile.txt note that Makefile is preferred name for kbuild files kbuild: replace PHONY with FORCE kbuild: Fix bug in crc symbol generating of kernel and modules kbuild: change kbuild to not rely on incorrect GNU make behavior kbuild: when warning symbols exported twice now tell user this is the problem kbuild: fix make dir/file.xx when asm symlink is missing kbuild: in the section mismatch check try harder to find symbols kbuild: fix section mismatch check for unwind on IA64 kbuild: kill false positives from section mismatch warnings for powerpc kbuild: kill trailing whitespace in modpost & friends kbuild: small update of allnoconfig description kbuild: make namespace.pl CROSS_COMPILE happy ... Trivial conflict in arch/ppc/boot/Makefile manually fixed up
2006-03-24fix typos "wich" -> "which"Uwe Zeisberger
Signed-off-by: Uwe Zeisberger <zeisberg@informatik.uni-freiburg.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-06kbuild: change kbuild to not rely on incorrect GNU make behaviorPaul Smith
The kbuild system takes advantage of an incorrect behavior in GNU make. Once this behavior is fixed, all files in the kernel rebuild every time, even if nothing has changed. This patch ensures kbuild works with both the incorrect and correct behaviors of GNU make. For more details on the incorrect behavior, see: http://lists.gnu.org/archive/html/bug-make/2006-03/msg00003.html Changes in this patch: - Keep all targets that are to be marked .PHONY in a variable, PHONY. - Add .PHONY: $(PHONY) to mark them properly. - Remove any $(PHONY) files from the $? list when determining whether targets are up-to-date or not. Signed-off-by: Paul Smith <psmith@gnu.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-02-19kbuild: improved modversioning support for external modulesSam Ravnborg
With following patch a second option is enabled to obtain symbol information from a second external module when a external module is build. The recommended approach is to use a common kbuild file but that may be impractical in certain cases. With this patch one can copy over a Module.symvers from one external module to make symbols (and symbol versions) available for another external module. Updated documentation in Documentation/kbuild/modules.txt Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-01-10spelling: s/retreive/retrieve/Adrian Bunk
2005-07-25kbuild: introduce Kbuild.includeSam Ravnborg
Kbuild.include is a placeholder for definitions originally present in both the top-level Makefile and scripts/Makefile.build. There were a slight difference in the filechk definition, so the most videly used version was kept and usr/Makefile was adopted for this syntax. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> ---
