path: root/scripts/Makefile
2019-06-15kbuild: remove build_unifdef target in scripts/MakefileMasahiro Yamada
Since commit 2aedcd098a94 ("kbuild: suppress annoying "... is up to date." message"), if_changed and friends nicely suppress "is up to date" messages. We do not need per-Makefile tricks. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2019-02-27scripts/gdb: do not descend into scripts/gdb from scriptsMasahiro Yamada
Currently, Kbuild descends from scripts/Makefile to scripts/gdb/Makefile just for creating symbolic links, but it does not need to do it so early. Merge the two descending paths to simplify the code. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Kieran Bingham <kieran.bingham@ideasonboard.com>
2018-12-01kbuild: descend into scripts/gcc-plugins/ via scripts/MakefileMasahiro Yamada
Now that 'archprepare' depends on 'scripts', Kbuild can descend into scripts/gcc-plugins in a more standard way. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Kees Cook <keescook@chromium.org>
2018-12-01kbuild: move modpost out of 'scripts' targetMasahiro Yamada
I am eagar to build under the scripts/ directory only with $(HOSTCC), but scripts/mod/ highly depends on the $(CC) and target arch headers. That it why the 'scripts' target must depend on 'asm-generic', 'gcc-plugins', and $(autoksyms_h). Move it to the 'prepare0' stage. I know this is a cheesy workaround, but better than the current situation. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-10-02kbuild: consolidate Devicetree dtb build rulesRob Herring
There is nothing arch specific about building dtb files other than their location under /arch/*/boot/dts/. Keeping each arch aligned is a pain. The dependencies and supported targets are all slightly different. Also, a cross-compiler for each arch is needed, but really the host compiler preprocessor is perfectly fine for building dtbs. Move the build rules to a common location and remove the arch specific ones. This is done in a single step to avoid warnings about overriding rules. The build dependencies had been a mixture of 'scripts' and/or 'prepare'. These pull in several dependencies some of which need a target compiler (specifically devicetable-offsets.h) and aren't needed to build dtbs. All that is really needed is dtc, so adjust the dependencies to only be dtc. This change enables support 'dtbs_install' on some arches which were missing the target. Acked-by: Will Deacon <will.deacon@arm.com> Acked-by: Paul Burton <paul.burton@mips.com> Acked-by: Ley Foon Tan <ley.foon.tan@intel.com> Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Michal Marek <michal.lkml@markovi.net> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Russell King <linux@armlinux.org.uk> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: James Hogan <jhogan@kernel.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Chris Zankel <chris@zankel.net> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: linux-kbuild@vger.kernel.org Cc: linux-snps-arc@lists.infradead.org Cc: linux-arm-kernel@lists.infradead.org Cc: uclinux-h8-devel@lists.sourceforge.jp Cc: linux-mips@linux-mips.org Cc: nios2-dev@lists.rocketboards.org Cc: linuxppc-dev@lists.ozlabs.org Cc: linux-xtensa@linux-xtensa.org Signed-off-by: Rob Herring <robh@kernel.org>
2018-07-18kbuild: Rename HOST_LOADLIBES to KBUILD_HOSTLDLIBSLaura Abbott
In preparation for enabling command line LDLIBS, re-name HOST_LOADLIBES to KBUILD_HOSTLDLIBS as the internal use only flags. Also rename existing usage to HOSTLDLIBS for consistency. This should not have any visible effects. Signed-off-by: Laura Abbott <labbott@redhat.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-07-18kbuild: move bin2c back to scripts/ from scripts/basic/Masahiro Yamada
Commit 8370edea81e3 ("bin2c: move bin2c in scripts/basic") moved bin2c to the scripts/basic/ directory, incorrectly stating "Kexec wants to use bin2c and it wants to use it really early in the build process. See arch/x86/purgatory/ code in later patches." Commit bdab125c9301 ("Revert "kexec/purgatory: Add clean-up for purgatory directory"") and commit d6605b6bbee8 ("x86/build: Remove unnecessary preparation for purgatory") removed the redundant purgatory build magic entirely. That means that the move of bin2c was unnecessary in the first place. fixdep is the only host program that deserves to sit in the scripts/basic/ directory. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-23Docs: clean up some DocBook loose endsJonathan Corbet
There were a few bits and pieces left over from the now-disused DocBook toolchain; git rid of them. Reported-by: Markus Heiser <markus.heiser@darmarit.de> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2017-05-16docs: remove DocBook from the building systemMauro Carvalho Chehab
Now that we don't have any DocBook anymore, remove it from the building system. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2016-06-07GCC plugin infrastructureEmese Revfy
This patch allows to build the whole kernel with GCC plugins. It was ported from grsecurity/PaX. The infrastructure supports building out-of-tree modules and building in a separate directory. Cross-compilation is supported too. Currently the x86, arm, arm64 and uml architectures enable plugins. The directory of the gcc plugins is scripts/gcc-plugins. You can use a file or a directory there. The plugins compile with these options: * -fno-rtti: gcc is compiled with this option so the plugins must use it too * -fno-exceptions: this is inherited from gcc too * -fasynchronous-unwind-tables: this is inherited from gcc too * -ggdb: it is useful for debugging a plugin (better backtrace on internal errors) * -Wno-narrowing: to suppress warnings from gcc headers (ipa-utils.h) * -Wno-unused-variable: to suppress warnings from gcc headers (gcc_version variable, plugin-version.h) The infrastructure introduces a new Makefile target called gcc-plugins. It supports all gcc versions from 4.5 to 6.0. The scripts/gcc-plugin.sh script chooses the proper host compiler (gcc-4.7 can be built by either gcc or g++). This script also checks the availability of the included headers in scripts/gcc-plugins/gcc-common.h. The gcc-common.h header contains frequently included headers for GCC plugins and it has a compatibility layer for the supported gcc versions. The gcc-generate-*-pass.h headers automatically generate the registration structures for GIMPLE, SIMPLE_IPA, IPA and RTL passes. Note that 'make clean' keeps the *.so files (only the distclean or mrproper targets clean all) because they are needed for out-of-tree modules. Based on work created by the PaX Team. Signed-off-by: Emese Revfy <re.emese@gmail.com> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: Michal Marek <mmarek@suse.com>
2016-02-26KEYS: Reserve an extra certificate symbol for inserting without recompilingMehmet Kayaalp
Place a system_extra_cert buffer of configurable size, right after the system_certificate_list, so that inserted keys can be readily processed by the existing mechanism. Added script takes a key file and a kernel image and inserts its contents to the reserved area. The system_certificate_list_size is also adjusted accordingly. Call the script as: scripts/insert-sys-cert -b <vmlinux> -c <certfile> If vmlinux has no symbol table, supply System.map file with -s flag. Subsequent runs replace the previously inserted key, instead of appending the new one. Signed-off-by: Mehmet Kayaalp <mkayaalp@linux.vnet.ibm.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2015-09-28DocBook: Use a fixed encoding for outputBen Hutchings
Currently the encoding of documents generated by DocBook depends on the current locale. Make the output reproducible independently of the locale, by setting the encoding to UTF-8 (LC_CTYPE=C.UTF-8) by preference, or ASCII (LC_CTYPE=C) as a fallback. LC_CTYPE can normally be overridden by LC_ALL, but the top-level Makefile unsets that. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> [jc: added check-lc_ctype to .gitignore] Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2015-08-12modsign: Use extract-cert to process CONFIG_SYSTEM_TRUSTED_KEYSDavid Woodhouse
Fix up the dependencies somewhat too, while we're at it. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David Howells <dhowells@redhat.com>
2015-08-07modsign: Extract signing cert from CONFIG_MODULE_SIG_KEY if neededDavid Woodhouse
Where an external PEM file or PKCS#11 URI is given, we can get the cert from it for ourselves instead of making the user drop signing_key.x509 in place for us. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David Howells <dhowells@redhat.com>
2015-08-07MODSIGN: Use PKCS#7 messages as module signaturesDavid Howells
Move to using PKCS#7 messages as module signatures because: (1) We have to be able to support the use of X.509 certificates that don't have a subjKeyId set. We're currently relying on this to look up the X.509 certificate in the trusted keyring list. (2) PKCS#7 message signed information blocks have a field that supplies the data required to match with the X.509 certificate that signed it. (3) The PKCS#7 certificate carries fields that specify the digest algorithm used to generate the signature in a standardised way and the X.509 certificates specify the public key algorithm in a standardised way - so we don't need our own methods of specifying these. (4) We now have PKCS#7 message support in the kernel for signed kexec purposes and we can make use of this. To make this work, the old sign-file script has been replaced with a program that needs compiling in a previous patch. The rules to build it are added here. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Vivek Goyal <vgoyal@redhat.com>
2015-02-17scripts/gdb: add infrastructureJan Kiszka
This provides the basic infrastructure to load kernel-specific python helper scripts when debugging the kernel in gdb. The loading mechanism is based on gdb loading for <objfile>-gdb.py when opening <objfile>. Therefore, this places a corresponding link to the main helper script into the output directory that contains vmlinux. The main scripts will pull in submodules containing Linux specific gdb commands and functions. To avoid polluting the source directory with compiled python modules, we link to them from the object directory. Due to gdb.parse_and_eval and string redirection for gdb.execute, we depend on gdb >= 7.2. This feature is enabled via CONFIG_GDB_SCRIPTS. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Acked-by: Michal Marek <mmarek@suse.cz> [kbuild stuff] Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ben Widawsky <ben@bwidawsk.net> Cc: Borislav Petkov <bp@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08bin2c: move bin2c in scripts/basicVivek Goyal
This patch series does not do kernel signature verification yet. I plan to post another patch series for that. Now distributions are already signing PE/COFF bzImage with PKCS7 signature I plan to parse and verify those signatures. Primary goal of this patchset is to prepare groundwork so that kernel image can be signed and signatures be verified during kexec load. This should help with two things. - It should allow kexec/kdump on secureboot enabled machines. - In general it can help even without secureboot. By being able to verify kernel image signature in kexec, it should help with avoiding module signing restrictions. Matthew Garret showed how to boot into a custom kernel, modify first kernel's memory and then jump back to old kernel and bypass any policy one wants to. This patch (of 15): Kexec wants to use bin2c and it wants to use it really early in the build process. See arch/x86/purgatory/ code in later patches. So move bin2c in scripts/basic so that it can be built very early and be usable by arch/x86/purgatory/ Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Cc: Borislav Petkov <bp@suse.de> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Eric Biederman <ebiederm@xmission.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Greg Kroah-Hartman <greg@kroah.com> Cc: Dave Young <dyoung@redhat.com> Cc: WANG Chao <chaowang@redhat.com> Cc: Baoquan He <bhe@redhat.com> Cc: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-09kbuild: do not add "selinux" to subdir- twiceMasahiro Yamada
scripts/Makefile adds "selinux" to subdir-y or subdir- twice. subdir-$(CONFIG_MODVERSIONS) += genksyms subdir-y += mod subdir-$(CONFIG_SECURITY_SELINUX) += selinux <--- here subdir-$(CONFIG_DTC) += dtc # Let clean descend into subdirs subdir- += basic kconfig package selinux <--- again The latter is redundant. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-03-14kbuild: specify build_docproc as a phony targetMasahiro Yamada
PHONY target is more suitable for "build_docproc" target. Because PHONY targets are always executed, they do not have to take FORCE as a prerequisite. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-10-08X.509: Add simple ASN.1 grammar compilerDavid Howells
Add a simple ASN.1 grammar compiler. This produces a bytecode output that can be fed to a decoder to inform the decoder how to interpret the ASN.1 stream it is trying to parse. Action functions can be specified in the grammar by interpolating: ({ foo }) after a type, for example: SubjectPublicKeyInfo ::= SEQUENCE { algorithm AlgorithmIdentifier, subjectPublicKey BIT STRING ({ do_key_data }) } The decoder is expected to call these after matching this type and parsing the contents if it is a constructed type. The grammar compiler does not currently support the SET type (though it does support SET OF) as I can't see a good way of tracking which members have been encountered yet without using up extra stack space. Currently, the grammar compiler will fail if more than 256 bytes of bytecode would be produced or more than 256 actions have been specified as it uses 8-bit jump values and action indices to keep space usage down. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-05-23Merge branch 'x86-extable-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull exception table generation updates from Ingo Molnar: "The biggest change here is to allow the build-time sorting of the exception table, to speed up booting. This is achieved by the architecture enabling BUILDTIME_EXTABLE_SORT. This option is enabled for x86 and MIPS currently. On x86 a number of fixes and changes were needed to allow build-time sorting of the exception table, in particular a relocation invariant exception table format was needed. This required the abstracting out of exception table protocol and the removal of 20 years of accumulated assumptions about the x86 exception table format. While at it, this tree also cleans up various other aspects of exception handling, such as early(er) exception handling for rdmsr_safe() et al. All in one, as the result of these changes the x86 exception code is now pretty nice and modern. As an added bonus any regressions in this code will be early and violent crashes, so if you see any of those, you'll know whom to blame!" Fix up trivial conflicts in arch/{mips,x86}/Kconfig files due to nearby modifications of other core architecture options. * 'x86-extable-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (35 commits) Revert "x86, extable: Disable presorted exception table for now" scripts/sortextable: Handle relative entries, and other cleanups x86, extable: Switch to relative exception table entries x86, extable: Disable presorted exception table for now x86, extable: Add _ASM_EXTABLE_EX() macro x86, extable: Remove open-coded exception table entries in arch/x86/ia32/ia32entry.S x86, extable: Remove open-coded exception table entries in arch/x86/include/asm/xsave.h x86, extable: Remove open-coded exception table entries in arch/x86/include/asm/kvm_host.h x86, extable: Remove the now-unused __ASM_EX_SEC macros x86, extable: Remove open-coded exception table entries in arch/x86/xen/xen-asm_32.S x86, extable: Remove open-coded exception table entries in arch/x86/um/checksum_32.S x86, extable: Remove open-coded exception table entries in arch/x86/lib/usercopy_32.c x86, extable: Remove open-coded exception table entries in arch/x86/lib/putuser.S x86, extable: Remove open-coded exception table entries in arch/x86/lib/getuser.S x86, extable: Remove open-coded exception table entries in arch/x86/lib/csum-copy_64.S x86, extable: Remove open-coded exception table entries in arch/x86/lib/copy_user_nocache_64.S x86, extable: Remove open-coded exception table entries in arch/x86/lib/copy_user_64.S x86, extable: Remove open-coded exception table entries in arch/x86/lib/checksum_32.S x86, extable: Remove open-coded exception table entries in arch/x86/kernel/test_rodata.c x86, extable: Remove open-coded exception table entries in arch/x86/kernel/entry_64.S ...
2012-05-18x86, realmode: 16-bit real-mode code support for relocs toolH. Peter Anvin
A new option is added to the relocs tool called '--realmode'. This option causes the generation of 16-bit segment relocations and 32-bit linear relocations for the real-mode code. When the real-mode code is moved to the low-memory during kernel initialization, these relocation entries can be used to relocate the code properly. In the assembly code 16-bit segment relocations must be relative to the 'real_mode_seg' absolute symbol. Linear relocations must be relative to a symbol prefixed with 'pa_'. 16-bit segment relocation is used to load cs:ip in 16-bit code. Linear relocations are used in the 32-bit code for relocatable data references. They are declared in the linker script of the real-mode code. The relocs tool is moved to arch/x86/tools/relocs.c, and added new target archscripts that can be used to build scripts needed building an architecture. be compiled before building the arch/x86 tree. [ hpa: accelerating this because it detects invalid absolute relocations, a serious bug in binutils 2.22.52.0.x which currently produces bad kernels. ] Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/r/1336501366-28617-2-git-send-email-jarkko.sakkinen@intel.com Signed-off-by: Jarkko Sakkinen <jarkko.sakkinen@intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: <stable@vger.kernel.org>
2012-04-24scripts/sortextable: Handle relative entries, and other cleanupsDavid Daney
x86 is now using relative rather than absolute addresses in its exception table, so we add a sorter for these. If there are relocations on the __ex_table section, they are redundant and probably incorrect after the sort, so they are zeroed out leaving them valid and consistent. Also use the unaligned safe accessors from tools/{be,le}_byteshift.h Signed-off-by: David Daney <david.daney@cavium.com> Link: http://lkml.kernel.org/r/1335291795-26693-2-git-send-email-ddaney.cavm@gmail.com Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2012-04-19scripts: Add sortextable to sort the kernel's exception table.David Daney
Using this build-time sort saves time booting as we don't have to burn cycles sorting the exception table. Signed-off-by: David Daney <david.daney@cavium.com> Link: http://lkml.kernel.org/r/1334872799-14589-2-git-send-email-ddaney.cavm@gmail.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-05-02kbuild: move scripts/basic/docproc.c to scripts/docproc.cPeter Foley
Move docproc from scripts/basic to scripts so it is only built for *doc targets instead of every time the kernel is built.
2011-03-17KBuild: silence "'scripts/unifdef' is up to date."Mike Waychison
While changing our build system over to use the headers_install target as part of our klibc build, the following message started showing up in our logs: make[2]: `scripts/unifdef' is up to date. It turns out that the build blindly invokes a recursive make on this target, which causes make to emit this message when the target is already up to date. This isn't seen for most targets as the rest of the build relies primarily on the default target and on PHONY targets when invoking make recursively. Silence the above message when building unifdef as part of headers_install by hiding it behind a new PHONY target called "build_unifdef" that has an empty recipe. Signed-off-by: Mike Waychison <mikew@google.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-10-14ftrace/x86: Add support for C version of recordmcountSteven Rostedt
This patch adds the support for the C version of recordmcount and compile times show ~ 12% improvement. After verifying this works, other archs can add: HAVE_C_MCOUNT_RECORD in its Kconfig and it will use the C version of recordmcount instead of the perl version. Cc: <linux-arch@vger.kernel.org> Cc: Michal Marek <mmarek@suse.cz> Cc: linux-kbuild@vger.kernel.org Cc: John Reiser <jreiser@bitwagon.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-09-15sparc: Kill PROM console driver.David S. Miller
Many years ago when this driver was written, it had a use, but these days it's nothing but trouble and distributions should not enable it in any situation. Pretty much every console device a sparc machine could see has a bonafide real driver, making the PROM console hack unnecessary. If any new device shows up, we should write a driver instead of depending upon this crutch to save us. We've been able to take care of this even when no chip documentation exists (sunxvr500, sunxvr2500) so there are no excuses. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-02Move dtc and libfdt sources from arch/powerpc/boot to scripts/dtcDavid Gibson
The powerpc kernel always requires an Open Firmware like device tree to supply device information. On systems without OF, this comes from a flattened device tree blob. This blob is usually generated by dtc, a tool which compiles a text description of the device tree into the flattened format used by the kernel. Sometimes, the bootwrapper makes small changes to the pre-compiled device tree blob (e.g. filling in the size of RAM). To do this it uses the libfdt library. Because these are only used on powerpc, the code for both these tools is included under arch/powerpc/boot (these were imported and are periodically updated from the upstream dtc tree). However, the microblaze architecture, currently being prepared for merging to mainline also uses dtc to produce device tree blobs. A few other archs have also mentioned some interest in using dtc. Therefore, this patch moves dtc and libfdt from arch/powerpc into scripts, where it can be used by any architecture. The vast bulk of this patch is a literal move, the rest is adjusting the various Makefiles to use dtc and libfdt correctly from their new locations. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-06Revert "fix modules_install via NFS"David Woodhouse
This reverts commit 8b249b6856f16f09b0e5b79ce5f4d435e439b9d6. This 'fix' is not necessary; we just need to undo the damage caused accidentally by Igor/Mauro in 4b29631db33292d416dc395c56122ea865e7635c ("V4L/DVB (9533): cx88: Add support for TurboSight TBS8910 DVB-S PCI card") Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-01-07fix modules_install via NFSSam Ravnborg
Rafael reported: I get the following error from 'make modules_install' on my test boxes: HOSTCC firmware/ihex2fw /home/rafael/src/linux-2.6/firmware/ihex2fw.c:268: fatal error: opening dependency file firmware/.ihex2fw.d: Read-only file system compilation terminated. make[3]: *** [firmware/ihex2fw] Error 1 make[2]: *** [_modinst_post] Error 2 make[1]: *** [sub-make] Error 2 make: *** [all] Error 2 where the configuration is that the kernel is compiled on a build box with 'make O=<destdir> -j5' and then <destdir> is mounted over NFS read-only by each test box (full path to this directory is the same on the build box and on the test boxes). Then, I cd into <destdir>, run 'make modules_install' and get the error above. The issue turns out to be that we when we install firmware pick up the list of firmware blobs from firmware/Makefile. And this triggers the Makefile rules to update ihex2fw. There were two solutions for this issue: 1) Move the list of firmware blobs to a separate file 2) Avoid ihex2fw rebuild by moving it to scripts As I seriously beleive that the list of firmware blobs should be done in a fundamental different way solution 2) was selected. Reported-and-tested-by: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: David Woodhouse <dwmw2@infradead.org>
2008-08-27selinux: add support for installing a dummy policy (v2)Serge E. Hallyn
In August 2006 I posted a patch generating a minimal SELinux policy. This week, David P. Quigley posted an updated version of that as a patch against the kernel. It also had nice logic for auto-installing the policy. Following is David's original patch intro (preserved especially bc it has stats on the generated policies): se interested in the changes there were only two significant changes. The first is that the iteration through the list of classes used NULL as a sentinel value. The problem with this is that the class_to_string array actually has NULL entries in its table as place holders for the user space object classes. The second change was that it would seem at some point the initial sids table was NULL terminated. This is no longer the case so that iteration has to be done on array length instead of looking for NULL. Some statistics on the policy that it generates: The policy consists of 523 lines which contain no blank lines. Of those 523 lines 453 of them are class, permission, and initial sid definitions. These lines are usually little to no concern to the policy developer since they will not be adding object classes or permissions. Of the remaining 70 lines there is one type, one role, and one user statement. The remaining lines are broken into three portions. The first group are TE allow rules which make up 29 of the remaining lines, the second is assignment of labels to the initial sids which consist of 27 lines, and file system labeling statements which are the remaining 11. In addition to the policy.conf generated there is a single file_contexts file containing two lines which labels the entire system with base_t. This policy generates a policy.23 binary that is 7920 bytes. (then a few versions later...): The new policy is 587 lines (stripped of blank lines) with 476 of those lines being the boilerplate that I mentioned last time. The remaining 111 lines have the 3 lines for type, user, and role, 70 lines for the allow rules (one for each object class including user space object classes), 27 lines to assign types to the initial sids, and 11 lines for file system labeling. The policy binary is 9194 bytes. Changelog: Aug 26: Added Documentation/SELinux.txt Aug 26: Incorporated a set of comments by Stephen Smalley: 1. auto-setup SELINUXTYPE=dummy 2. don't auto-install if selinux is enabled with non-dummy policy 3. don't re-compute policy version 4. /sbin/setfiles not /usr/sbin/setfiles Aug 22: As per JMorris comments, made sure make distclean cleans up the mdp directory. Removed a check for file_contexts which is now created in the same file as the check, making it superfluous. Signed-off-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: David Quigley <dpquigl@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2006-10-01[PATCH] allow /proc/config.gz to be built as a moduleRoss Biro
The driver for /proc/config.gz consumes rather a lot of memory and it is in fact possible to build it as a module. In some ways this is a bit risky, because the .config which is used for compiling kernel/configs.c isn't necessarily the same as the .config which was used to build vmlinux. But OTOH the potential memory savings are decent, and it'd be fairly dumb to build your configs.o with a different .config. Signed-off-by: Andrew Morton <akpm@google.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-25kbuild: modpost on vmlinux regardless of CONFIG_MODULESSam Ravnborg
Based on patch from: Magnus Damm <magnus@valinux.co.jp> This has the advantage that all section mismatch checks are run regardless of modules being enabled or not. When running modpost on vmlinux output: MODPOST vmlinux When running modpost on modules output count of modules like this: MODPOST 5 modules Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-25kbuild: use in-kernel unifdefSam Ravnborg
Let headers_install use in-kernel unifdef Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-12-16kconfig: move lxdialog to scripts/kconfig/lxdialogSam Ravnborg
The only lxdialog user i kconfig - for menuconfig. So move it to reflect this. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
